Introduce a new "protect-exec" reserved sram area type which is
makes use of the the existing functionality provided for the "pool"
sram region type for use with the genalloc framework and with the
added requirement that it be maintained as read-only and executable
while allowing for an arbitrary number of drivers to share the space.
This introduces a common way to maintain a region of sram as read-only
and executable and also introduces a helper function, sram_exec_copy,
which allows for copying data to this protected region while maintaining
locking to avoid conflicts between multiple users of the same space. A
region of memory that is marked with the "protect-exec" flag in the
device tree also has the requirement of providing a page aligned block
of memory so that the page attribute manipulation does not affect
surrounding regions.
Also, selectively enable this only for builds that support set_memory_*
calls, for now just ARM, through the use of Kconfig.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
IDT 89HPESx PCIe-switches exposes SMBus interface to have an access to
the device CSRs and EEPROM. So to properly utilize the interface
functionality, developer should declare a valid dts-file node, which
would refer to the corresponding 89HPESx device.
Signed-off-by: Serge Semin <fancer.lancer@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Falling back unconditionally to HostNotify as primary client's interrupt
breaks some drivers which alter their functionality depending on whether
interrupt is present or not, so let's introduce a board flag telling I2C
core explicitly if we want wired interrupt or HostNotify-based one:
I2C_CLIENT_HOST_NOTIFY.
For DT-based systems we introduce "host-notify" property that we convert
to I2C_CLIENT_HOST_NOTIFY board flag.
Tested-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Specify the power button interrupt number which is from the datasheet.
Signed-off-by: Milo Kim <woogyom.kim@gmail.com>
Add interrupt specifiers for USB and AC charger input. Interrupt numbers
are from the datasheet.
Fix wrong property for compatible string.
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc
Pull MMC fixes from Ulf Hansson:
"MMC core:
- further fix thread wake-up for requests
- use a bounce buffer to fix DMA issue for SSR register read
MMC host:
- sdhci: Fix a regression for runtime PM
- sdhci-cadence: Add a proper SoC specific DT compatible"
* tag 'mmc-v4.10-3' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc:
mmc: sd: Meet alignment requirements for raw_ssr DMA
mmc: core: Further fix thread wake-up
mmc: sdhci: Fix to handle MMC_POWER_UNDEFINED
mmc: sdhci-cadence: add Socionext UniPhier specific compatible string
Pull networking fixes and cleanups from David Miller:
1) Use rb_entry() instead of hardcoded container_of(), from Geliang
Tang.
2) Use correct memory barriers in stammac driver, from Pavel Machek.
3) Fix assoc bind address handling in SCTP, from Xin Long.
4) Make the length check for UFO handling consistent between
__ip_append_data() and ip_finish_output(), from Zheng Li.
5) HSI driver compatible strings were busted fro hix5hd2, from Dongpo
Li.
6) Handle devm_ioremap() errors properly in cavium driver, from Arvind
Yadav.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (22 commits)
RDS: use rb_entry()
net_sched: sch_netem: use rb_entry()
net_sched: sch_fq: use rb_entry()
net/mlx5: use rb_entry()
ethernet: sfc: Add Kconfig entry for vendor Solarflare
sctp: not copying duplicate addrs to the assoc's bind address list
sctp: reduce indent level in sctp_copy_local_addr_list
ARM: dts: hix5hd2: don't change the existing compatible string
net: hix5hd2_gmac: fix compatible strings name
openvswitch: Add a missing break statement.
net: netcp: ethss: fix 10gbe host port tx pri map configuration
net: netcp: ethss: fix errors in ethtool ops
fsl/fman: enable compilation on ARM64
fsl/fman: A007273 only applies to PPC SoCs
powerpc: fsl/fman: remove fsl,fman from of_device_ids[]
fsl/fman: fix 1G support for QSGMII interfaces
dt: bindings: net: use boolean dt properties for eee broken modes
net: phy: use boolean dt properties for eee broken modes
net: phy: fix sign type error in genphy_config_eee_advert
ipv4: Should use consistent conditional judgement for ip fragment in __ip_append_data and ip_finish_output
The SoC hix5hd2 compatible string has the suffix "-gmac" and
we should not change its compatible string.
So we should name all the compatible string with the suffix "-gmac".
Creating a new name suffix "-gemac" is unnecessary.
We also add another SoC compatible string in dt binding documentation
and describe which generic version the SoC belongs to.
Fixes: d0fb6ba75dc0 ("net: hix5hd2_gmac: add generic compatible string")
Signed-off-by: Dongpo Li <lidongpo@hisilicon.com>
The patches regarding eee-broken-modes was merged before all people
involved could find an agreement on the best way to move forward.
While we agreed on having a DT property to mark particular modes as broken,
the value used for eee-broken-modes mapped the phy register in very direct
way. Because of this, the concern is that it could be used to implement
configuration policies instead of describing a broken HW.
In the end, having a boolean property for each mode seems to be preferred
over one bit field value mapping the register (too) directly.
Cc: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Add a Socionext SoC specific compatible (suggested by Rob Herring).
No SoC specific data are associated with the compatible strings for
now, but other SoC vendors may use this IP and want to differentiate
IP variants in the future.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Device Support
- Add support for Ricoh RC5T619 PMIC to rn5t618
- Add support for PM8821 PMIC to qcom-pm8xxx
New Functionality:
- Add support for GPIO to lpc_ich
- Add support for GPADC to sun4i
- Add ability for rk808 to shutdown
Fix-ups:
- Simplify/strip unnecessary code; tps65218, palmas, tps65217
- Device Tree binding updates; tps65218, altera-a10sr
- Provide/export device ID info; tps65218, axp20x-i2c, hi655x-pmic,
fsl-imx25-tsadc, intel_soc_pmic_bxtwc
- Use MFD API instead of of_platform_populate(); tps65218
- Generalise name-space; pm8xxx
- Supply/edit regmap configuration; axp20x, cs47l24-tables, axp20x
- Enable compile testing; max77620, max77686, exynos-lpass,
abx500-core
- Coding style issues; wm8994-core, wm5102-tables
- Supply endian support; syscon
- Remove module support; ab3100-core, ab8500-debugfs, ab8500-gpadc,
abx500-core
Bug Fixes:
- Fix ordering issues; wm8994
- Fix dependencies (build-time/run-time); exynos_lpass, sun4i-gpadc
- Fix compiler warnings; sun4i-gpadc
- Fix leaks; mfd-core
- Fix page fault during module unload; tps65217"
* tag 'mfd-for-linus-4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (49 commits)
mfd: tps65217: Support an interrupt pin as the system wakeup
mfd: tps65217: Make an interrupt handler simpler
mfd: tps65217: Update register interrupt mask bits instead of writing operation
mfd: tps65217: Specify the IRQ name
mfd: tps65217: Fix page fault on unloading modules
mfd: palmas: Remove redundant check in palmas_power_off
mfd: arizona: Disable IRQs during driver remove
mfd: pm8xxx: add support to pm8821
mfd: intel-lpss: Try to enable Memory-Write-Invalidate
mfd: rn5t618: Add Ricoh RC5T619 PMIC support
mfd: axp20x: Add address extension registers for AXP806 regmap
mfd: intel_soc_pmic_bxtwc: Fix a typo in MODULE_DEVICE_TABLE()
mfd: core: Fix device reference leak in mfd_clone_cell
mfd: bcm590xx: Simplify a test
mfd: sun4i-gpadc: Select regmap-irq
mfd: abx500-core: drop unused MODULE_ tags from non-modular code
mfd: ab8500: make sysctrl explicitly non-modular
mfd: ab8500-gpadc: Make it explicitly non-modular
mfd: ab8500-debugfs: Make it explicitly non-modular
mfd: ab8500-core: Make it explicitly non-modular
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"Subsystem:
- non-modular drivers are now explicitly non-modular
New driver:
- Epson Toyocom rtc-7301sf/dg
Drivers:
- cmos: reject unsupported alarm values wrt the RTC capabilities
- ds1307: ACPI support
- jz4740: DT support, jz4780 handling, can now be used as a system
power controller
- mcp795: many fixes, in particular proper month handling
- twl: driver is now DT only"
* tag 'rtc-4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (31 commits)
rtc: mcp795: Fix whitespace and indentation.
rtc: mcp795: Prefer using the BIT() macro.
rtc: mcp795: fix month write resetting date to 1.
rtc: mcp795: fix time range difference between linux and RTC chip.
rtc: mcp795: fix bitmask value for leap year (LP).
rtc: mcp795: use bcd2bin/bin2bcd.
rtc: add support for EPSON TOYOCOM RTC-7301SF/DG
rtc: ds1307: Add ACPI support
rtc: imxdi: (trivial) fix a typo
rtc: ds1374: Merge conditional + WARN_ON()
rtc: twl: make driver DT only
rtc: twl: kill static variables
rtc: fix typos in Kconfig
rtc: jz4740: make the driver builtin only
rtc: jz4740: remove unused EXPORT_SYMBOL
Documentation: bindings: fix twl-rtc documentation
rtc: Enable compile testing for Maxim and Samsung drivers
MIPS: jz4740: Remove obsolete code
MIPS: qi_lb60: Probe RTC driver from DT and use it as power controller
MIPS: jz4740: DTS: Probe the jz4740-rtc driver from devicetree
This adds support for EPSON TOYOCOM RTC-7301SF/DG which has parallel
interface compatible with SRAM.
This driver supports basic clock, calendar and alarm functionality.
Tested with Microblaze linux running on Artix7 FPGA board with my own
custom IP for RTC-7301.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
- updated support for Synaptics RMI4 devices, including support for
SMBus controllers, firmware update support, sensor tuning, and PS/2
guest support
- ALPS driver now supports tracksticks on SS5 controllers
- i8042 now uses chassis info to skip selftest on Asus laptops as list
of individual models became too unwieldy
- miscellaneous fixes to other drivers
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (67 commits)
Input: imx6ul_tsc - generalize the averaging property
Input: drv260x - use generic device properties
Input: drv260x - use temporary for &client->dev
Input: drv260x - fix input device's parent assignment
Input: synaptics-rmi4 - add support for F34 V7 bootloader
Input: drv260x - fix initializing overdrive voltage
Input: ALPS - fix protcol -> protocol
Input: i8042 - comment #else/#endif of CONFIG_PNP
Input: lpc32xx-keys - fix invalid error handling of a requested irq
Input: synaptics-rmi4 - fix debug for sensor clip
Input: synaptics-rmi4 - store the attn data in the driver
Input: synaptics-rmi4 - allow to add attention data
Input: synaptics-rmi4 - f03 - grab data passed by transport device
Input: synaptics-rmi4 - add support for F03
Input: imx6ul_tsc - convert int to u32
Input: imx6ul_tsc - add mask when set REG_ADC_CFG
Input: synaptics-rmi4 - have only one struct platform data
Input: synaptics-rmi4 - remove EXPORT_SYMBOL_GPL for internal functions
Input: synaptics-rmi4 - remove mutex calls while updating the firmware
Input: drv2667 - fix misuse of regmap_update_bits
Pull MTD updates from Brian Norris:
"Nothing enormous here, though notably we have some of the first work
of a few new maintainers. I think for now I'll still be sending pull
requests, but that's open to change in the future. Summary:
Core:
- dynamic BDI object allocation (resolves some problems when built as
a module)
- cleanups in the ooblayout handling
NAND:
- new tango NAND controller driver
- new ox820 NAND controller driver
- addition of a new full-ID entry in the nand_ids table
- rework of the s3c240 driver to support DT
- extension of the nand_sdr_timings to expose tCCS, tPROG and tR
- addition of a new flag to ask the core to wait for tCCS when
sending a RNDIN/RNDOUT command
- addition of a new flag to ask the core to let the controller driver
send the READ/PROGPAGE command
Minor fixes/cleanup/cosmetic changes:
- properly support 512 ECC step size in the sunxi driver
- improve the error messages in the PXA probe path
- fix module autoload in the omap2 driver
- cleanup of several nand drivers to return nand_scan{_tail}() error
code instead of returning -EIO
- various cleanups in the denali driver
- fix an error check in nandsim
SPI NOR:
- new flash IDs
- wait for Spansion flash to be ready after quad-enable
- error handling fixes for Candence QSPI
- constify some structures in Freescale QSPI driver"
* tag 'for-linus-20161216' of git://git.infradead.org/linux-mtd: (71 commits)
mtd: Allocate bdi objects dynamically
mtd: nand: tango: Add standard legalese header
mtd: maps: add missing iounmap() in error path
mtd: spi-nor: constify fsl_qspi_devtype_data
mtd: spi-nor: Add support for mr25h40
mtd: spi-nor: Add support for N25Q016A
mtd: spi-nor: Add at25df321 spi-nor flash support
mtd: spi-nor: Fix some error codes in cqspi_setup_flash()
mtd: spi-nor: Off by one in cqspi_setup_flash()
mtd: spi-nor: add support for s25fl208k
mtd: spi-nor: fix flags for s25fl128s
mtd: spi-nor: fix spansion quad enable
mtd: spi-nor: add Macronix mx25u25635f to list of known devices.
mtd: mtdswap: fix spelling mistake "erassure" -> "erasure"
mtd: bcm47xxpart: fix parsing first block after aligned TRX
mtd: nand: tango: Use nand_to_mtd() instead of directly accessing chip->mtd
mtd: remove unneeded initializer in mtd_ooblayout_count_bytes()
mtd: use min_t() to refactor mtd_ooblayout_{get, set}_bytes()
mtd: remove unneeded initializer in mtd_ooblayout_{get, set}_bytes()
mtd: nand: nandsim: fix error check
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- new Mediatek drivers: mtk-mdp and mtk-vcodec
- some additions at the media documentation
- the CEC core and drivers were promoted from staging to mainstream
- some cleanups at the DVB core
- the LIRC serial driver got promoted from staging to mainstream
- added a driver for Renesas R-Car FDP1 driver
- add DVBv5 statistics support to mn88473 driver
- several fixes related to printk continuation lines
- add support for HSV encoding formats
- lots of other cleanups, fixups and driver improvements.
* tag 'media/v4.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (496 commits)
[media] v4l: tvp5150: Add missing break in set control handler
[media] v4l: tvp5150: Don't inline the tvp5150_selmux() function
[media] v4l: tvp5150: Compile tvp5150_link_setup out if !CONFIG_MEDIA_CONTROLLER
[media] em28xx: don't store usb_device at struct em28xx
[media] em28xx: use usb_interface for dev_foo() calls
[media] em28xx: don't change the device's name
[media] mn88472: fix chip id check on probe
[media] mn88473: fix chip id check on probe
[media] lirc: fix error paths in lirc_cdev_add()
[media] s5p-mfc: Add support for MFC v8 available in Exynos 5433 SoCs
[media] s5p-mfc: Rework clock handling
[media] s5p-mfc: Don't keep clock prepared all the time
[media] s5p-mfc: Kill all IS_ERR_OR_NULL in clocks management code
[media] s5p-mfc: Remove dead conditional code
[media] s5p-mfc: Ensure that clock is disabled before turning power off
[media] s5p-mfc: Remove special clock rate management
[media] s5p-mfc: Use printk_ratelimited for reporting ioctl errors
[media] s5p-mfc: Set DMA_ATTR_ALLOC_SINGLE_PAGES
[media] vivid: Set color_enc on HSV formats
[media] v4l2-tpg: Init hv_enc field with a valid value
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights include:
- Support for the kexec_file_load() syscall, which is a prereq for
secure and trusted boot.
- Prevent kernel execution of userspace on P9 Radix (similar to
SMEP/PXN).
- Sort the exception tables at build time, to save time at boot, and
store them as relative offsets to save space in the kernel image &
memory.
- Allow building the kernel with thin archives, which should allow us
to build an allyesconfig once some other fixes land.
- Build fixes to allow us to correctly rebuild when changing the
kernel endian from big to little or vice versa.
- Plumbing so that we can avoid doing a full mm TLB flush on P9
Radix.
- Initial stack protector support (-fstack-protector).
- Support for dumping the radix (aka. Linux) and hash page tables via
debugfs.
- Fix an oops in cxl coredump generation when cxl_get_fd() is used.
- Freescale updates from Scott: "Highlights include 8xx hugepage
support, qbman fixes/cleanup, device tree updates, and some misc
cleanup."
- Many and varied fixes and minor enhancements as always.
Thanks to:
Alexey Kardashevskiy, Andrew Donnellan, Aneesh Kumar K.V, Anshuman
Khandual, Anton Blanchard, Balbir Singh, Bartlomiej Zolnierkiewicz,
Christophe Jaillet, Christophe Leroy, Denis Kirjanov, Elimar
Riesebieter, Frederic Barrat, Gautham R. Shenoy, Geliang Tang, Geoff
Levand, Jack Miller, Johan Hovold, Lars-Peter Clausen, Libin,
Madhavan Srinivasan, Michael Neuling, Nathan Fontenot, Naveen N.
Rao, Nicholas Piggin, Pan Xinhui, Peter Senna Tschudin, Rashmica
Gupta, Rui Teng, Russell Currey, Scott Wood, Simon Guo, Suraj
Jitindar Singh, Thiago Jung Bauermann, Tobias Klauser, Vaibhav Jain"
[ And thanks to Michael, who took time off from a new baby to get this
pull request done. - Linus ]
* tag 'powerpc-4.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (174 commits)
powerpc/fsl/dts: add FMan node for t1042d4rdb
powerpc/fsl/dts: add sg_2500_aqr105_phy4 alias on t1024rdb
powerpc/fsl/dts: add QMan and BMan nodes on t1024
powerpc/fsl/dts: add QMan and BMan nodes on t1023
soc/fsl/qman: test: use DEFINE_SPINLOCK()
powerpc/fsl-lbc: use DEFINE_SPINLOCK()
powerpc/8xx: Implement support of hugepages
powerpc: get hugetlbpage handling more generic
powerpc: port 64 bits pgtable_cache to 32 bits
powerpc/boot: Request no dynamic linker for boot wrapper
soc/fsl/bman: Use resource_size instead of computation
soc/fsl/qe: use builtin_platform_driver
powerpc/fsl_pmc: use builtin_platform_driver
powerpc/83xx/suspend: use builtin_platform_driver
powerpc/ftrace: Fix the comments for ftrace_modify_code
powerpc/perf: macros for power9 format encoding
powerpc/perf: power9 raw event format encoding
powerpc/perf: update attribute_group data structure
powerpc/perf: factor out the event format field
powerpc/mm/iommu, vfio/spapr: Put pages on VFIO container shutdown
Merge updated Synaptics RMI4 support, including support for SMBus
controllers and flashing firmware.
Make the avarage-samples property a general touchscreen property
rather than imx6ul device specific.
Signed-off-by: Guy Shapiro <guy.shapiro@mobi-wize.com>
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- A new driver for the power management controller on TI Keystone
- Support for the prerelease "SCPI" firmware protocol that ended up
being shipped by Amlogic in their GXBB SoC.
- A soc_device can now be matched using a glob from inside the
kernel, when another driver wants to know the specific chip it is
running on and cannot find out from DT, firmware or hardware.
- Renesas SoCs now support identification through the soc_device
interface, both in user space and kernel.
- Renesas r8a7743 and r8a7745 gain support for their system
controller
- A new checking module for the ARM "PSCI" (not to be confused with
"SCPI" mentioned above) firmware interface.
- A new driver for the Tegra GMI memory interface
- Support for the Tegra firmware interfaces with their power
management controllers
As usual, the updates for the reset controller framework are merged
here, as they tend to touch multiple SoCs as well, including a new
driver for the Oxford (now Broadcom) OX820 chip and the Tegra bpmp
interface.
The existing drivers for Atmel, Qualcomm, NVIDIA, TI Davinci, and
Rockchips SoCs see some further updates"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits)
misc: sram: remove useless #ifdef
drivers: psci: Allow PSCI node to be disabled
drivers: psci: PSCI checker module
soc: renesas: Identify SoC and register with the SoC bus
firmware: qcom: scm: Return PTR_ERR when devm_clk_get fails
firmware: qcom: scm: Remove core, iface and bus clocks dependency
dt-bindings: firmware: scm: Add MSM8996 DT bindings
memory: da8xx-ddrctl: drop the call to of_flat_dt_get_machine_name()
bus: da8xx-mstpri: drop the call to of_flat_dt_get_machine_name()
ARM: shmobile: Document DT bindings for Product Register
soc: renesas: rcar-sysc: add R8A7745 support
reset: Add Tegra BPMP reset driver
dt-bindings: firmware: Allow child nodes inside the Tegra BPMP
dt-bindings: Add power domains to Tegra BPMP firmware
firmware: tegra: Add BPMP support
firmware: tegra: Add IVC library
dt-bindings: firmware: Add bindings for Tegra BPMP
mailbox: tegra-hsp: Use after free in tegra_hsp_remove_doorbells()
mailbox: Add Tegra HSP driver
firmware: arm_scpi: add support for pre-v1.0 SCPI compatible
Pull ARM 64-bit DT updates from Arnd Bergmann:
"A couple of interesting new SoC platforms are now supported, these are
the respective DTS sources:
- Samsung Exynos5433 mobile phone platform, including an (almost)
fully supported phone reference board.
- Hisilicon Hip07 server platform and D05 board, the latest iteration
of their product line, now with 64 Cortex-A72 cores across two
sockets.
- Allwinner A64 SoC, the first 64-bit chip from their "sunxi" product
line, used in Android tablets and ultra-cheap development boards
- NXP LS1046A Communication processor, improving on the earlier
LS1043A with faster CPU cores
- Qualcomm MSM8992 (Snapdragon 808) and MSM8994 (Snapdragon 810)
mobile phone SoCs
- Early support for the Nvidia Tegra Tegra186 SoC
- Amlogic S905D is a minor variant of their existing Android consumer
product line
- Rockchip PX5 automotive platform, a close relative of their popular
rk3368 Android tablet chips
Aside from the respective evaluation platforms for the above chips,
there are only a few consumer devices and boards added this time:
- Huawei Nexus 6P (Angler) mobile phone
- LG Nexus 5x (Bullhead) mobile phone
- Nexbox A1 and A95X Android TV boxes
- Pine64 development board based on Allwinner A64
- Globalscale Marvell ESPRESSOBin community board based on Armada 3700
- Renesas "R-Car Starter Kit Pro" (M3ULCB) low-cost automotive board
For the existing platforms, we get bug fixes and new peripheral
support for Juno, Renesas, Uniphier, Amlogic, Samsung, Broadcom,
Rockchip, Berlin, and ZTE"
* tag 'armsoc-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (168 commits)
arm64: dts: fix build errors from missing dependencies
ARM64: dts: meson-gxbb: add SCPI pre-1.0 compatible
ARM64: dts: meson-gxl: Add support for Nexbox A95X
ARM64: dts: meson-gxm: Add support for the Nexbox A1
ARM: dts: artpec: add pcie support
arm64: dts: berlin4ct-dmp: add missing unit name to /memory node
arm64: dts: berlin4ct-stb: add missing unit name to /memory node
arm64: dts: berlin4ct: add missing unit name to /soc node
arm64: dts: qcom: msm8916: Add ddr support to sdhc1
arm64: dts: exynos: Enable HS400 mode for eMMC for TM2
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM64: dts: Add support for Meson GXM
dt-bindings: add rockchip RK1108 Evaluation board
arm64: dts: NS2: Add PCI PHYs
arm64: dts: NS2: enable sdio1
arm64: dts: exynos: Add the mshc_2 node for supporting T-Flash
arm64: tegra: Add NVIDIA P2771 board support
arm64: tegra: Enable PSCI on P3310
arm64: tegra: Add NVIDIA P3310 processor module support
arm64: tegra: Add GPIO controllers on Tegra186
Pull ARM DT updates from Arnd Bergmann:
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- Added support for the TI DRA71x family of SoCs in mach-omap2, this
is an new variant of the the DRA72x/DRA74x automotive infotainment
chips we already supported for a while.
- Added support for the ST STM32F746 SoC, the first Cortex-M7 based
microcontroller we support, related to the smaller STM32F4 family.
- Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see
http://elinux.org/RZ-G
- SMP is now supported on the OX820 platform
- A lot of code in mach-omap2 gets removed as a follow-up to removing
support for board files in the previous release
- Davinci has some new work to improve USB support
- For i.MX, the performance monitor now supports profiling the memory
controller using 'perf'"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits)
ARM: davinci: da830-evm: use gpio descriptor for mmc pins
ARM: davinci: da850-evm: use gpio descriptor for mmc pins
ARM: davinci: hawk: use gpio descriptor for mmc pins
ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6
ARM: davinci: da8xx: Fix ohci device name
ARM: oxnas: Add OX820 config and makefile entry
ARM: oxnas: Add OX820 SMP support
ARM: davinci: PM: fix build when da850 not compiled in
ARM: orion5x: remove legacy support of ls-chl
ARM: integrator: drop EBI access use syscon
ARM: BCM5301X: Add back handler ignoring external imprecise aborts
ARM: davinci: PM: support da8xx DT platforms
ARM: davinci: PM: cleanup: remove references to pdata
ARM: davinci: PM: rework init, remove platform device
ARM: Kconfig: Introduce MACH_STM32F746 flag
ARM: mach-stm32: Add a new SOC - STM32F746
ARM: shmobile: document SK-RZG1E board
ARM: shmobile: r8a7745: basic SoC support
ARM: imx: mach-imx6ul: add imx6ull support
ARM: zynq: Reserve correct amount of non-DMA RAM
Pull ARM SoC non-urgent fixes from Arnd Bergmann:
"As usual, we queue up a few fixes that don't seem urgent enough to go
in through -rc, or that just came a little too late given their size.
The zx fixes make the platform finally boot on real hardware, the
davinci and imx31 get the DT support working better for some of the
machines that are still normally used with classic board files. One
tegra fix is important for new bootloader versions, but the bug has
been around for a while without anyone noticing.
The other changes are mostly cosmetic"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (22 commits)
arm64: tegra: Add missing Smaug revision
arm64: tegra: Add VDD_GPU regulator to Jetson TX1
arm64: dts: zte: clean up gic-v3 redistributor properties
arm64: dts: zx: Fix gic GICR property
bus: vexpress-config: fix device reference leak
soc: ti: qmss: fix the case when !SMP
ARM: lpc32xx: drop duplicate header device.h
ARM: ixp4xx: drop duplicate header gpio.h
ARM: socfpga: fix spelling mistake in error message
ARM: dts: imx6q-cm-fx6: fix fec pinctrl
ARM: dts: imx7d-pinfunc: fix UART pinmux defines
ARM: dts: imx6qp: correct LDB clock inputs
ARM: OMAP2+: pm-debug: Use seq_putc() in two functions
ARM: OMAP2+: Remove the omapdss_early_init_of() function
mfd: tps65217: Fix mismatched interrupt number
ARM: zx: Fix error handling
ARM: spear: Fix error handling
ARM: davinci: da850: Fix pwm name matching
ARM: clk: imx31: properly init clocks for machines with DT
clk: imx31: fix rewritten input argument of mx31_clocks_init()
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC updates from Vineet Gupta:
"These are mostly timer/clocksource driver updates which were
Reviewed/Acked by Daniel but had to be merged via ARC tree due to
dependencies.
I will follow up with another pull request with actual ARC changes
early next week !
Summary:
- Moving ARC timer driver into drivers/clocksource
- EZChip timer driver updates [Noam]
- ARC AXS103 and HAPS platform updates [Alexey]"
* tag 'arc-4.10-rc1-part1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: axs10x: really enable ARC PGU
ARC: rename Zebu platform support to HAPS
clocksource: nps: avoid maybe-uninitialized warning
clocksource: Add clockevent support to NPS400 driver
clocksource: update "fn" at CLOCKSOURCE_OF_DECLARE() of nps400 timer
soc: Support for NPS HW scheduling
clocksource: import ARC timer driver
ARC: breakout timer include code into separate header ...
ARC: move mcip.h into include/soc and adjust the includes
ARC: breakout aux handling into a separate header
ARC: time: move time_init() out of the driver
ARC: timer: gfrc, rtc: build under same option (64-bit timers)
ARC: timer: gfrc, rtc: Read BCR to detect whether hardware exists ...
ARC: timer: gfrc, rtc: deuglify big endian code
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- the first series of making i2c_device_id optional instead of
mandatory (in favor of alternatives like of_device_id).
This involves adding a new probe callback (probe_new) which removes
some peculiarities I2C had for a long time now. The new probe is
matching the other subsystems now and the old one will be removed
once all users are converted. It is expected to take a while but
there is ongoing interest in that.
- SMBus Host Notify introduced 4.9 got refactored. They are now using
interrupts instead of the alert callback which solves multiple
issues.
- new drivers for iMX LowPower I2C, Mellanox CPLD and its I2C mux
- significant refactoring for bcm2835 driver
- the usual set of driver updates and improvements
* 'i2c/for-4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (46 commits)
i2c: fsl-lpi2c: read lpi2c fifo size in probe()
i2c: octeon: thunderx: Remove double-check after interrupt
i2c: octeon: thunderx: TWSI software reset in recovery
i2c: cadence: Allow Cadence I2C to be selected for Cadence Xtensa CPUs
i2c: sh_mobile: Add per-Generation fallback bindings
i2c: rcar: Add per-Generation fallback bindings
i2c: imx-lpi2c: add low power i2c bus driver
dt-bindings: i2c: imx-lpi2c: add devicetree bindings
i2c: designware-pcidrv: Add 10bit address feature to medfield/merrifield
i2c: pxa: Add support for the I2C units found in Armada 3700
i2c: pxa: Add definition of fast and high speed modes via the regs layout
dt-bindings: i2c: pxa: Update the documentation for the Armada 3700
i2c: qup: support SMBus block read
i2c: qup: add ACPI support
i2c: designware: Consolidate default functionality bits
i2c: i2c-mux-gpio: update mux with gpiod_set_array_value_cansleep
i2c: mux: pca954x: Add ACPI support for pca954x
i2c: use an IRQ to report Host Notify events, not alert
i2c: i801: remove SMBNTFDDAT reads as they always seem to return 0
i2c: i801: use the BIT() macro for FEATURES_* also
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes:
- add support for PCI on ARM64 boxes with ACPI. We already had this
for theoretical spec-compliant hardware; now we're adding quirks
for the actual hardware (Cavium, HiSilicon, Qualcomm, X-Gene)
- add runtime PM support for hotplug ports
- enable runtime suspend for Intel UHCI that uses platform-specific
wakeup signaling
- add yet another host bridge registration interface. We hope this is
extensible enough to subsume the others
- expose device revision in sysfs for DRM
- to avoid device conflicts, make sure any VF BAR updates are done
before enabling the VF
- avoid unnecessary link retrains for ASPM
- allow INTx masking on Mellanox devices that support it
- allow access to non-standard VPD for Chelsio devices
- update Broadcom iProc support for PAXB v2, PAXC v2, inbound DMA,
etc
- update Rockchip support for max-link-speed
- add NVIDIA Tegra210 support
- add Layerscape LS1046a support
- update R-Car compatibility strings
- add Qualcomm MSM8996 support
- remove some uninformative bootup messages"
* tag 'pci-v4.10-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (115 commits)
PCI: Enable access to non-standard VPD for Chelsio devices (cxgb3)
PCI: Expand "VPD access disabled" quirk message
PCI: pciehp: Remove loading message
PCI: hotplug: Remove hotplug core message
PCI: Remove service driver load/unload messages
PCI/AER: Log AER IRQ when claiming Root Port
PCI/AER: Log errors with PCI device, not PCIe service device
PCI/AER: Remove unused version macros
PCI/PME: Log PME IRQ when claiming Root Port
PCI/PME: Drop unused support for PMEs from Root Complex Event Collectors
PCI: Move config space size macros to pci_regs.h
x86/platform/intel-mid: Constify mid_pci_platform_pm
PCI/ASPM: Don't retrain link if ASPM not possible
PCI: iproc: Skip check for legacy IRQ on PAXC buses
PCI: pciehp: Leave power indicator on when enabling already-enabled slot
PCI: pciehp: Prioritize data-link event over presence detect
PCI: rcar: Add gen3 fallback compatibility string for pcie-rcar
PCI: rcar: Use gen2 fallback compatibility last
PCI: rcar-gen2: Use gen2 fallback compatibility last
PCI: rockchip: Move the deassert of pm/aclk/pclk after phy_init()
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- add various vendor prefixes.
- fix NUMA node handling when "numa=off" is passed on kernel command
line.
- coding style Clean-up of overlay handling code.
- DocBook fixes in DT platform driver code
- Altera SoCFPGA binding addtions for freeze bridge, arria10 FPGA
manager and FPGA bridges.
- a couple of printk message fixes.
* tag 'devicetree-for-4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (33 commits)
dt: pwm: bcm2835: fix typo in clocks property name
devicetree: add vendor prefix for National Instruments
Revert "of: base: add support to get machine model name"
of: Fix issue where code would fall through to error case.
drivers/of: fix missing pr_cont()s in of_print_phandle_args
devicetree: bindings: Add vendor prefix for Oki
devicetree: bindings: Add vendor prefix for Andes Technology Corporation
dt-bindings: add MYIR Tech hardware vendor prefix
add bindings document for altera freeze bridge
ARM: socfpga: add bindings doc for arria10 fpga manager
ARM: socfpga: add bindings document for fpga bridge drivers
of/platform: clarify of_find_device_by_node refcounting
of/platform: fix of_platform_device_destroy comment
of: Remove unused variable overlay_symbols
of: Move setting of pointer to beside test for non-null
of: Add back an error message, restructured
of: Update comments to reflect changes and increase clarity
of: Remove redundant size check
of: Update structure of code to be clearer, also remove BUG_ON()
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This is a very tiny pull request, with just a new driver for HiSilicon
BVT SoCs and a cleanup for the Amlogic Meson driver.
There are other patches on the list, but my timing was really bad this
time and I ended up not having the time to look at them in enough
detail to be comfortable merging them"
* tag 'pwm/for-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: Add PWM driver for HiSilicon BVT SOCs
pwm: meson: Remove unneeded platform MODULE_ALIAS
* patchwork: (496 commits)
Pull dmaengine updates from Vinod Koul:
"Fairly routine update this time around with all changes specific to
drivers:
- New driver for STMicroelectronics FDMA
- Memory-to-memory transfers on dw dmac
- Support for slave maps on pl08x devices
- Bunch of driver fixes to use dma_pool_zalloc
- Bunch of compile and warning fixes spread across drivers"
[ The ST FDMA driver already came in earlier through the remoteproc tree ]
* tag 'dmaengine-4.10-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (68 commits)
dmaengine: sirf-dma: remove unused ‘sdesc’
dmaengine: pl330: remove unused ‘regs’
dmaengine: s3c24xx: remove unused ‘cdata’
dmaengine: stm32-dma: remove unused ‘src_addr’
dmaengine: stm32-dma: remove unused ‘dst_addr’
dmaengine: stm32-dma: remove unused ‘sfcr’
dmaengine: pch_dma: remove unused ‘cookie’
dmaengine: mic_x100_dma: remove unused ‘data’
dmaengine: img-mdc: remove unused ‘prev_phys’
dmaengine: usb-dmac: remove unused ‘uchan’
dmaengine: ioat: remove unused ‘res’
dmaengine: ioat: remove unused ‘ioat_dma’
dmaengine: ioat: remove unused ‘is_raid_device’
dmaengine: pl330: do not generate unaligned access
dmaengine: k3dma: move to dma_pool_zalloc
dmaengine: at_hdmac: move to dma_pool_zalloc
dmaengine: at_xdmac: don't restore unsaved status
dmaengine: ioat: set error code on failures
dmaengine: DW DMAC: add multi-block property to device tree
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Generally pretty quiet for this release. Highlights:
Yama:
- allow ptrace access for original parent after re-parenting
TPM:
- add documentation
- many bugfixes & cleanups
- define a generic open() method for ascii & bios measurements
Integrity:
- Harden against malformed xattrs
SELinux:
- bugfixes & cleanups
Smack:
- Remove unnecessary smack_known_invalid label
- Do not apply star label in smack_setprocattr hook
- parse mnt opts after privileges check (fixes unpriv DoS vuln)"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (56 commits)
Yama: allow access for the current ptrace parent
tpm: adjust return value of tpm_read_log
tpm: vtpm_proxy: conditionally call tpm_chip_unregister
tpm: Fix handling of missing event log
tpm: Check the bios_dir entry for NULL before accessing it
tpm: return -ENODEV if np is not set
tpm: cleanup of printk error messages
tpm: replace of_find_node_by_name() with dev of_node property
tpm: redefine read_log() to handle ACPI/OF at runtime
tpm: fix the missing .owner in tpm_bios_measurements_ops
tpm: have event log use the tpm_chip
tpm: drop tpm1_chip_register(/unregister)
tpm: replace dynamically allocated bios_dir with a static array
tpm: replace symbolic permission with octal for securityfs files
char: tpm: fix kerneldoc tpm2_unseal_trusted name typo
tpm_tis: Allow tpm_tis to be bound using DT
tpm, tpm_vtpm_proxy: add kdoc comments for VTPM_PROXY_IOC_NEW_DEV
tpm: Only call pm_runtime_get_sync if device has a parent
tpm: define a generic open() method for ascii & bios measurements
Documentation: tpm: add the Physical TPM device tree binding documentation
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.10:
API:
- add skcipher walk interface
- add asynchronous compression (acomp) interface
- fix algif_aed AIO handling of zero buffer
Algorithms:
- fix unaligned access in poly1305
- fix DRBG output to large buffers
Drivers:
- add support for iMX6UL to caam
- fix givenc descriptors (used by IPsec) in caam
- accelerated SHA256/SHA512 for ARM64 from OpenSSL
- add SSE CRCT10DIF and CRC32 to ARM/ARM64
- add AEAD support to Chelsio chcr
- add Armada 8K support to omap-rng"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (148 commits)
crypto: testmgr - fix overlap in chunked tests again
crypto: arm/crc32 - accelerated support based on x86 SSE implementation
crypto: arm64/crc32 - accelerated support based on x86 SSE implementation
crypto: arm/crct10dif - port x86 SSE implementation to ARM
crypto: arm64/crct10dif - port x86 SSE implementation to arm64
crypto: testmgr - add/enhance test cases for CRC-T10DIF
crypto: testmgr - avoid overlap in chunked tests
crypto: chcr - checking for IS_ERR() instead of NULL
crypto: caam - check caam_emi_slow instead of re-lookup platform
crypto: algif_aead - fix AIO handling of zero buffer
crypto: aes-ce - Make aes_simd_algs static
crypto: algif_skcipher - set error code when kcalloc fails
crypto: caam - make aamalg_desc a proper module
crypto: caam - pass key buffers with typesafe pointers
crypto: arm64/aes-ce-ccm - Fix AEAD decryption length
MAINTAINERS: add crypto headers to crypto entry
crypt: doc - remove misleading mention of async API
crypto: doc - fix header file name
crypto: api - fix comment typo
crypto: skcipher - Add separate walker for AEAD decryption
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"No dramatic changes are found in this development cycle, but as usual,
many commits are applied in a wide range of drivers.
Most of big changes are in ASoC, where a few bits of framework work
and quite a lot of cleanups and improvements to existing code have
been done. The rest are usual stuff, a few HD-audio and USB-audio
quirks and fixes, as well as the drop of kthread usages in the whole
subsystem.
Below are some highlights:
ASoC:
- support for stereo DAPM controls
- some initial work on the of-graph sound card
- regmap conversions of the remaining AC'97 drivers
- a new version of the topology ABI; this should be backward
compatible
- updates / cleanups of rsnd, sunxi, sti, nau8825, samsung, arizona,
Intel skylake, atom-sst
- new drivers for Cirrus Logic CS42L42, Qualcomm MSM8916-WCD, and
Realtek RT5665
USB-audio:
- yet another race fix at disconnection
- tolerated packet size calculation for some Android devices
- quirks for Axe-Fx II, QuickCam, TEAC 501/503
HD-audio:
- improvement of Dell pin fixup mapping
- quirks for HP Z1 Gen3, Alienware 15 R2 2016 and ALC622 headset mic
Misc:
- replace all kthread usages with simple works"
* tag 'sound-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (296 commits)
ALSA: hiface: Fix M2Tech hiFace driver sampling rate change
ALSA: usb-audio: Eliminate noise at the start of DSD playback.
ALSA: usb-audio: Add native DSD support for TEAC 501/503 DAC
ASoC: wm_adsp: wm_adsp_buf_alloc should use kfree in error path
ASoC: topology: avoid uninitialized kcontrol_type
ALSA: usb-audio: Add QuickCam Communicate Deluxe/S7500 to volume_control_quirks
ALSA: usb-audio: add implicit fb quirk for Axe-Fx II
ASoC: zte: spdif: correct ZX_SPDIF_CLK_RAT define
ASoC: zte: spdif and i2s drivers are not zx296702 specific
ASoC: rsnd: setup BRGCKR/BRRA/BRRB when starting
ASoC: rsnd: enable/disable ADG when suspend/resume timing
ASoC: rsnd: tidyup ssi->usrcnt counter check in hw_params
ALSA: cs46xx: add a new line
ASoC: Intel: update bxt_da7219_max98357a to support quad ch dmic capture
ASoC: nau8825: disable sinc filter for high THD of ADC
ALSA: usb-audio: more tolerant packetsize
ALSA: usb-audio: avoid setting of sample rate multiple times on bus
ASoC: cs35l34: Simplify the logic to set CS35L34_MCLK_CTL setting
ALSA: hda - Gate the mic jack on HP Z1 Gen3 AiO
ALSA: hda: when comparing pin configurations, ignore assoc in addition to seq
Pull SCSI updates from James Bottomley:
"This update includes the usual round of major driver updates (ncr5380,
lpfc, hisi_sas, megaraid_sas, ufs, ibmvscsis, mpt3sas).
There's also an assortment of minor fixes, mostly in error legs or
other not very user visible stuff. The major change is the
pci_alloc_irq_vectors replacement for the old pci_msix_.. calls; this
effectively makes IRQ mapping generic for the drivers and allows
blk_mq to use the information"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (256 commits)
scsi: qla4xxx: switch to pci_alloc_irq_vectors
scsi: hisi_sas: support deferred probe for v2 hw
scsi: megaraid_sas: switch to pci_alloc_irq_vectors
scsi: scsi_devinfo: remove synchronous ALUA for NETAPP devices
scsi: be2iscsi: set errno on error path
scsi: hpsa: fallback to use legacy REPORT PHYS command
scsi: scsi_dh_alua: Fix RCU annotations
scsi: hpsa: use %phN for short hex dumps
scsi: hisi_sas: fix free'ing in probe and remove
scsi: isci: switch to pci_alloc_irq_vectors
scsi: ipr: Fix runaway IRQs when falling back from MSI to LSI
scsi: dpt_i2o: double free on error path
scsi: cxlflash: Migrate scsi command pointer to AFU command
scsi: cxlflash: Migrate IOARRIN specific routines to function pointers
scsi: cxlflash: Cleanup queuecommand()
scsi: cxlflash: Cleanup send_tmf()
scsi: cxlflash: Remove AFU command lock
scsi: cxlflash: Wait for active AFU commands to timeout upon tear down
scsi: cxlflash: Remove private command pool
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
- struct thread_info moved off-stack (also touching
include/linux/thread_info.h and include/linux/restart_block.h)
- cpus_have_cap() reworked to avoid __builtin_constant_p() for static
key use (also touching drivers/irqchip/irq-gic-v3.c)
- uprobes support (currently only for native 64-bit tasks)
- Emulation of kernel Privileged Access Never (PAN) using TTBR0_EL1
switching to a reserved page table
- CPU capacity information passing via DT or sysfs (used by the
scheduler)
- support for systems without FP/SIMD (IOW, kernel avoids touching
these registers; there is no soft-float ABI, nor kernel emulation for
AArch64 FP/SIMD)
- handling of hardware watchpoint with unaligned addresses, varied
lengths and offsets from base
- use of the page table contiguous hint for kernel mappings
- hugetlb fixes for sizes involving the contiguous hint
- remove unnecessary I-cache invalidation in flush_cache_range()
- CNTHCTL_EL2 access fix for CPUs with VHE support (ARMv8.1)
- boot-time checks for writable+executable kernel mappings
- simplify asm/opcodes.h and avoid including the 32-bit ARM counterpart
and make the arm64 kernel headers self-consistent (Xen headers patch
merged separately)
- Workaround for broken .inst support in certain binutils versions
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (60 commits)
arm64: Disable PAN on uaccess_enable()
arm64: Work around broken .inst when defective gas is detected
arm64: Add detection code for broken .inst support in binutils
arm64: Remove reference to asm/opcodes.h
arm64: Get rid of asm/opcodes.h
arm64: smp: Prevent raw_smp_processor_id() recursion
arm64: head.S: Fix CNTHCTL_EL2 access on VHE system
arm64: Remove I-cache invalidation from flush_cache_range()
arm64: Enable HIBERNATION in defconfig
arm64: Enable CONFIG_ARM64_SW_TTBR0_PAN
arm64: xen: Enable user access before a privcmd hvc call
arm64: Handle faults caused by inadvertent user access with PAN enabled
arm64: Disable TTBR0_EL1 during normal kernel execution
arm64: Introduce uaccess_{disable,enable} functionality based on TTBR0_EL1
arm64: Factor out TTBR0_EL1 post-update workaround into a specific asm macro
arm64: Factor out PAN enabling/disabling into separate uaccess_* macros
arm64: Update the synchronous external abort fault description
selftests: arm64: add test for unaligned/inexact watchpoint handling
arm64: Allow hw watchpoint of length 3,5,6 and 7
arm64: hw_breakpoint: Handle inexact watchpoint addresses
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon updates from Guenter Roeck:
- new drivers for TMP108 and TC654
- hwmon core code cleanup
- coretemp driver cleanup
- fix overflow issues in several drivers
- minor fixes, cleanups and enhancements in various drivers
* tag 'hwmon-for-linus-v4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (41 commits)
hwmon: (g762) Fix overflows and crash seen when writing limit attributes
hwmon: (emcw201) Fix overflows seen when writing into limit attributes
hwmon: (emc2103) Fix overflows seen when temperature limit attributes
hwmon: (lm85) Fix overflows seen when writing voltage limit attributes
hwmon: (lm87) Fix overflow seen when writing voltage limit attributes
hwmon: (nct7802) Fix overflows seen when writing into limit attributes
hwmon: (adt7470) Fix overflows seen when writing into limit attributes
hwmon: (adt7462) Fix overflows seen when writing into limit attributes
hwmon: (adm1026) Fix overflows seen when writing into limit attributes
hwmon: (adm1025) Fix overflows seen when writing voltage limits
hwmon: (via-cputemp) Convert to hotplug state machine
devicetree: hwmon: Add documentation for TMP108 driver.
hwmon: Add Texas Instruments TMP108 temperature sensor driver.
hwmon: (core) Simplify sysfs attribute name allocation
hwmon: (core) Rename groups parameter in API to extra_groups
hwmon: (core) Explain why at least two attribute groups are allocated
hwmon: (core) Make is_visible callback truly mandatory
hwmon: (core) Deprecate hwmon_device_register()
hwmon: (core) Clarify use of chip attributes
hwmon: (core) Add support for string attributes to new API
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"The nicest things about this release for me is seeing some older
drivers getting some cleanups and modernization, it's really good to
see things moving forwards even for older drivers.
In content terms it's a fairly humdrum release but where the work has
been happening is great.
- Support for simultaneous use of internal and GPIO chip selects for
devices that require the use of the internal select even if it's
not connected and a GPIO is actually routed to the slave device.
- A major rework and cleanup of the fsl-espi driver from Heiner
Kallweit which should make it work substantially better.
- DMA support for Freescale DSPI IPs.
- New drivers for Freescale LPSPI IPs and Marvell Armada 3700.
- Support for Allwinner H3"
* tag 'spi-v4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (85 commits)
spi: mvebu: fix baudrate calculation for armada variant
spi: Add support for Armada 3700 SPI Controller
spi: armada-3700: Add documentation for the Armada 3700 SPI Controller
spi: fsl-lpspi: quit reading rx fifo under error condition
spi: fsl-lpspi: use GPL as module license
spi: fsl-espi: fix ioread16/iowrite16 endianness
spi: fsl-espi: remove unused linearization code
spi: fsl-espi: eliminate need for linearization when reading from hardware
spi: fsl-espi: eliminate need for linearization when writing to hardware
spi: fsl-espi: determine need for byte swap only once
spi: fsl-lpspi: read lpspi tx/rx fifo size in probe()
spi: fsl-lpspi: use wait_for_completion_timeout() while waiting transfer done
spi: orion: fix comment to mention MVEBU
spi: atmel: remove the use of private channel fields
spi: atmel: trivial: remove unused fields in DMA structure
spi: atmel: Use SPI core DMA mapping framework
spi: atmel: Use core SPI_MASTER_MUST_[RT]X handling
spi: atmel: trivial: move info banner to latest probe action
spi: imx: replace schedule() with cond_resched()
spi: imx: fix potential shift truncation
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver patches for 4.10-rc1. Lots of tiny
changes over lots of "minor" driver subsystems, the largest being some
new FPGA drivers. Other than that, a few other new drivers, but no new
driver subsystems added for this kernel cycle, a nice change.
All of these have been in linux-next with no reported issues"
* tag 'char-misc-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (107 commits)
uio-hv-generic: store physical addresses instead of virtual
Tools: hv: kvp: configurable external scripts path
uio-hv-generic: new userspace i/o driver for VMBus
vmbus: add support for dynamic device id's
hv: change clockevents unbind tactics
hv: acquire vmbus_connection.channel_mutex in vmbus_free_channels()
hyperv: Fix spelling of HV_UNKOWN
mei: bus: enable non-blocking RX
mei: fix the back to back interrupt handling
mei: synchronize irq before initiating a reset.
VME: Remove shutdown entry from vme_driver
auxdisplay: ht16k33: select framebuffer helper modules
MAINTAINERS: add git url for fpga
fpga: Clarify how write_init works streaming modes
fpga zynq: Fix incorrect ISR state on bootup
fpga zynq: Remove priv->dev
fpga zynq: Add missing \n to messages
fpga: Add COMPILE_TEST to all drivers
uio: pruss: add clk_disable()
char/pcmcia: add some error checking in scr24x_read()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO updates from Greg KH:
"Here's the "big" staging/iio pull request for 4.10-rc1.
Not as big as 4.9 was, but still just over a thousand changes. We
almost broke even of lines added vs. removed, as the slicoss driver
was removed (got a "clean" driver for the same hardware through the
netdev tree), and some iio drivers were also dropped, but I think we
ended up adding a few thousand lines to the source tree in the end.
Other than that it's a lot of minor fixes all over the place, nothing
major stands out at all.
All of these have been in linux-next for a while. There will be a
merge conflict with Al's vfs tree in the lustre code, but the
resolution for that should be pretty simple, that too has been in
linux-next"
* tag 'staging-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1002 commits)
staging: comedi: comedidev.h: Document usage of 'detach' handler
staging: fsl-mc: remove unnecessary info prints from bus driver
staging: fsl-mc: add sysfs ABI doc
staging/lustre/o2iblnd: Fix misspelled attemps->attempts
staging/lustre/o2iblnd: Fix misspelling intialized->intialized
staging/lustre: Convert all bare unsigned to unsigned int
staging/lustre/socklnd: Fix whitespace problem
staging/lustre/o2iblnd: Add missing space
staging/lustre/lnetselftest: Fix potential integer overflow
staging: greybus: audio_module: remove redundant OOM message
staging: dgnc: Fix lines longer than 80 characters
staging: dgnc: fix blank line after '{' warnings.
staging/android: remove Sync Framework tasks from TODO
staging/lustre/osc: Revert erroneous list_for_each_entry_safe use
staging: slicoss: remove the staging driver
staging: lustre: libcfs: remove lnet upcall code
staging: lustre: remove set but unused variables
staging: lustre: osc: set lock data for readahead lock
staging: lustre: import: don't reconnect during connect interpret
staging: lustre: clio: remove mtime check in vvp_io_fault_start()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY updates from Greg KH:
"Here's the big set of USB/PHY patches for 4.10-rc1.
A number of new drivers are here in this set of changes. We have a new
USB controller type "mtu3", a new usb-serial driver, and the usual
churn in the gadget subsystem and the xhci host controller driver,
along with a few other new small drivers added. And lots of little
other changes all over the USB and PHY driver tree. Full details are
in the shortlog
All of these have been in linux-next for a while with no reported
issues"
* tag 'usb-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (309 commits)
USB: serial: option: add dlink dwm-158
USB: serial: option: add support for Telit LE922A PIDs 0x1040, 0x1041
USB: OHCI: nxp: fix code warnings
USB: OHCI: nxp: remove useless extern declaration
USB: OHCI: at91: remove useless extern declaration
usb: misc: rio500: fix result type for error message
usb: mtu3: fix U3 port link issue
usb: mtu3: enable auto switch from U3 to U2
usbip: fix warning in vhci_hcd_probe/lockdep_init_map
usb: core: usbport: Use proper LED API to fix potential crash
usbip: add missing compile time generated files to .gitignore
usb: hcd.h: construct hub class request constants from simpler constants
USB: OHCI: ohci-pxa27x: remove useless functions
USB: OHCI: omap: remove useless extern declaration
USB: OHCI: ohci-omap: remove useless functions
USB: OHCI: ohci-s3c2410: remove useless functions
USB: cdc-acm: add device id for GW Instek AFG-125
fsl/usb: Workarourd for USB erratum-A005697
usb: hub: Wait for connection to be reestablished after port reset
usbip: vudc: Refactor init_vudc_hw() to be more obvious
Pull power management updates from Rafael Wysocki:
"Again, cpufreq gets more changes than the other parts this time (one
new driver, one old driver less, a bunch of enhancements of the
existing code, new CPU IDs, fixes, cleanups)
There also are some changes in cpuidle (idle injection rework, a
couple of new CPU IDs, online/offline rework in intel_idle, fixes and
cleanups), in the generic power domains framework (mostly related to
supporting power domains containing CPUs), and in the Operating
Performance Points (OPP) library (mostly related to supporting devices
with multiple voltage regulators)
In addition to that, the system sleep state selection interface is
modified to make it easier for distributions with unchanged user space
to support suspend-to-idle as the default system suspend method, some
issues are fixed in the PM core, the latency tolerance PM QoS
framework is improved a bit, the Intel RAPL power capping driver is
cleaned up and there are some fixes and cleanups in the devfreq
subsystem
Specifics:
- New cpufreq driver for Broadcom STB SoCs and a Device Tree binding
for it (Markus Mayer)
- Support for ARM Integrator/AP and Integrator/CP in the generic DT
cpufreq driver and elimination of the old Integrator cpufreq driver
(Linus Walleij)
- Support for the zx296718, r8a7743 and r8a7745, Socionext UniPhier,
and PXA SoCs in the the generic DT cpufreq driver (Baoyou Xie,
Geert Uytterhoeven, Masahiro Yamada, Robert Jarzmik)
- cpufreq core fix to eliminate races that may lead to using inactive
policy objects and related cleanups (Rafael Wysocki)
- cpufreq schedutil governor update to make it use SCHED_FIFO kernel
threads (instead of regular workqueues) for doing delayed work (to
reduce the response latency in some cases) and related cleanups
(Viresh Kumar)
- New cpufreq sysfs attribute for resetting statistics (Markus Mayer)
- cpufreq governors fixes and cleanups (Chen Yu, Stratos Karafotis,
Viresh Kumar)
- Support for using generic cpufreq governors in the intel_pstate
driver (Rafael Wysocki)
- Support for per-logical-CPU P-state limits and the EPP/EPB (Energy
Performance Preference/Energy Performance Bias) knobs in the
intel_pstate driver (Srinivas Pandruvada)
- New CPU ID for Knights Mill in intel_pstate (Piotr Luc)
- intel_pstate driver modification to use the P-state selection
algorithm based on CPU load on platforms with the system profile in
the ACPI tables set to "mobile" (Srinivas Pandruvada)
- intel_pstate driver cleanups (Arnd Bergmann, Rafael Wysocki,
- cpufreq powernv driver updates including fast switching support
(for the schedutil governor), fixes and cleanus (Akshay Adiga,
Andrew Donnellan, Denis Kirjanov)
- acpi-cpufreq driver rework to switch it over to the new CPU
offline/online state machine (Sebastian Andrzej Siewior)
- Assorted cleanups in cpufreq drivers (Wei Yongjun, Prashanth
Prakash)
- Idle injection rework (to make it use the regular idle path instead
of a home-grown custom one) and related powerclamp thermal driver
updates (Peter Zijlstra, Jacob Pan, Petr Mladek, Sebastian Andrzej
Siewior)
- New CPU IDs for Atom Z34xx and Knights Mill in intel_idle (Andy
Shevchenko, Piotr Luc)
- intel_idle driver cleanups and switch over to using the new CPU
offline/online state machine (Anna-Maria Gleixner, Sebastian
Andrzej Siewior)
- cpuidle DT driver update to support suspend-to-idle properly
(Sudeep Holla)
- cpuidle core cleanups and misc updates (Daniel Lezcano, Pan Bian,
Rafael Wysocki)
- Preliminary support for power domains including CPUs in the generic
power domains (genpd) framework and related DT bindings (Lina Iyer)
- Assorted fixes and cleanups in the generic power domains (genpd)
framework (Colin Ian King, Dan Carpenter, Geert Uytterhoeven)
- Preliminary support for devices with multiple voltage regulators
and related fixes and cleanups in the Operating Performance Points
(OPP) library (Viresh Kumar, Masahiro Yamada, Stephen Boyd)
- System sleep state selection interface rework to make it easier to
(Rafael Wysocki)
- PM core fixes and cleanups, mostly related to the interactions
between the system suspend and runtime PM frameworks (Ulf Hansson,
Sahitya Tummala, Tony Lindgren)
- Latency tolerance PM QoS framework imorovements (Andrew Lutomirski)
- New Knights Mill CPU ID for the Intel RAPL power capping driver
(Piotr Luc)
- Intel RAPL power capping driver fixes, cleanups and switch over to
using the new CPU offline/online state machine (Jacob Pan, Thomas
Gleixner, Sebastian Andrzej Siewior)
- Fixes and cleanups in the exynos-ppmu, exynos-nocp, rk3399_dmc,
rockchip-dfi devfreq drivers and the devfreq core (Axel Lin,
Chanwoo Choi, Javier Martinez Canillas, MyungJoo Ham, Viresh Kumar)
- Fix for false-positive KASAN warnings during resume from ACPI S3
(suspend-to-RAM) on x86 (Josh Poimboeuf)
- Memory map verification during resume from hibernation on x86 to
ensure a consistent address space layout (Chen Yu)
- Wakeup sources debugging enhancement (Xing Wei)
- rockchip-io AVS driver cleanup (Shawn Lin)"
* tag 'pm-4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (127 commits)
devfreq: rk3399_dmc: Don't use OPP structures outside of RCU locks
devfreq: rk3399_dmc: Remove dangling rcu_read_unlock()
devfreq: exynos: Don't use OPP structures outside of RCU locks
Documentation: intel_pstate: Document HWP energy/performance hints
cpufreq: intel_pstate: Support for energy performance hints with HWP
cpufreq: intel_pstate: Add locking around HWP requests
PM / sleep: Print active wakeup sources when blocking on wakeup_count reads
PM / core: Fix bug in the error handling of async suspend
PM / wakeirq: Fix dedicated wakeirq for drivers not using autosuspend
PM / Domains: Fix compatible for domain idle state
PM / OPP: Don't WARN on multiple calls to dev_pm_opp_set_regulators()
PM / OPP: Allow platform specific custom set_opp() callbacks
PM / OPP: Separate out _generic_set_opp()
PM / OPP: Add infrastructure to manage multiple regulators
PM / OPP: Pass struct dev_pm_opp_supply to _set_opp_voltage()
PM / OPP: Manage supply's voltage/current in a separate structure
PM / OPP: Don't use OPP structure outside of rcu protected section
PM / OPP: Reword binding supporting multiple regulators per device
PM / OPP: Fix incorrect cpu-supply property in binding
cpuidle: Add a kerneldoc comment to cpuidle_use_deepest_state()
Pull drm updates from Dave Airlie:
"This is the main pull request for drm for 4.10 kernel.
New drivers:
- ZTE VOU display driver (zxdrm)
- Amlogic Meson Graphic Controller GXBB/GXL/GXM SoCs (meson)
- MXSFB support (mxsfb)
Core:
- Format handling has been reworked
- Better atomic state debugging
- drm_mm leak debugging
- Atomic explicit fencing support
- fbdev helper ops
- Documentation updates
- MST fbcon fixes
Bridge:
- Silicon Image SiI8620 driver
Panel:
- Add support for new simple panels
i915:
- GVT Device model
- Better HDMI2.0 support on skylake
- More watermark fixes
- GPU idling rework for suspend/resume
- DP Audio workarounds
- Scheduler prep-work
- Opregion CADL handling
- GPU scheduler and priority boosting
amdgfx/radeon:
- Support for virtual devices
- New VM manager for non-contig VRAM buffers
- UVD powergating
- SI register header cleanup
- Cursor fixes
- Powermanagement fixes
nouveau:
- Powermangement reworks for better voltage/clock changes
- Atomic modesetting support
- Displayport Multistream (MST) support.
- GP102/104 hang and cursor fixes
- GP106 support
hisilicon:
- hibmc support (BMC chip for aarch64 servers)
armada:
- add tracing support for overlay change
- refactor plane support
- de-midlayer the driver
omapdrm:
- Timing code cleanups
rcar-du:
- R8A7792/R8A7796 support
- Misc fixes.
sunxi:
- A31 SoC display engine support
imx-drm:
- YUV format support
- Cleanup plane atomic update
mali-dp:
- Misc fixes
dw-hdmi:
- Add support for HDMI i2c master controller
tegra:
- IOMMU support fixes
- Error handling fixes
tda998x:
- Fix connector registration
- Improved robustness
- Fix infoframe/audio compliance
virtio:
- fix busid issues
- allocate more vbufs
qxl:
- misc fixes and cleanups.
vc4:
- Fragment shader threading
- ETC1 support
- VEC (tv-out) support
msm:
- A5XX GPU support
- Lots of atomic changes
tilcdc:
- Misc fixes and cleanups.
etnaviv:
- Fix dma-buf export path
- DRAW_INSTANCED support
- fix driver on i.MX6SX
exynos:
- HDMI refactoring
fsl-dcu:
- fbdev changes"
* tag 'drm-for-v4.10' of git://people.freedesktop.org/~airlied/linux: (1343 commits)
drm/nouveau/kms/nv50: fix atomic regression on original G80
drm/nouveau/bl: Do not register interface if Apple GMUX detected
drm/nouveau/bl: Assign different names to interfaces
drm/nouveau/bios/dp: fix handling of LevelEntryTableIndex on DP table 4.2
drm/nouveau/ltc: protect clearing of comptags with mutex
drm/nouveau/gr/gf100-: handle GPC/TPC/MPC trap
drm/nouveau/core: recognise GP106 chipset
drm/nouveau/ttm: wait for bo fence to signal before unmapping vmas
drm/nouveau/gr/gf100-: FECS intr handling is not relevant on proprietary ucode
drm/nouveau/gr/gf100-: properly ack all FECS error interrupts
drm/nouveau/fifo/gf100-: recover from host mmu faults
drm: Add fake controlD* symlinks for backwards compat
drm/vc4: Don't use drm_put_dev
drm/vc4: Document VEC DT binding
drm/vc4: Add support for the VEC (Video Encoder) IP
drm: Add TV connector states to drm_connector_state
drm: Turn DRM_MODE_SUBCONNECTOR_xx definitions into an enum
drm/vc4: Fix ->clock_select setting for the VEC encoder
drm/amdgpu/dce6: Set MASTER_UPDATE_MODE to 0 in resume_mc_access as well
drm/amdgpu: use pin rather than pin_restricted in a few cases
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull pstore updates from Kees Cook:
"Improvements and fixes to pstore subsystem:
- add additional checks for bad platform data
- remove bounce buffer in console writer
- protect read/unlink race with a mutex
- correctly give up during dump locking failures
- increase ftrace bandwidth by splitting ftrace buffers per CPU"
* tag 'pstore-v4.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
ramoops: add pdata NULL check to ramoops_probe
pstore: Convert console write to use ->write_buf
pstore: Protect unlink with read_mutex
pstore: Use global ftrace filters for function trace filtering
ftrace: Provide API to use global filtering for ftrace ops
pstore: Clarify context field przs as dprzs
pstore: improve error report for failed setup
pstore: Merge per-CPU ftrace records into one
pstore: Add ftrace timestamp counter
ramoops: Split ftrace buffer space into per-CPU zones
pstore: Make ramoops_init_przs generic for other prz arrays
pstore: Allow prz to control need for locking
pstore: Warn on PSTORE_TYPE_PMSG using deprecated function
pstore: Make spinlock per zone instead of global
pstore: Actually give up during locking failure
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
- Thermal core code reorganization and cleanup. Two new files are
created for thermal sysfs I/F code and thermal helper functions
(Eduardo Valentin).
- Sanitize hotplug and locking for x86_pkg_temp driver (Thomas
Gleixner)
- Update MAINTAINER file for pwm-fan driver and Samsung thermal driver
(Lukasz Majewski)
- Fix module auto-load for max77620, tango and db8500 thermal driver
(Javier Martinez Canillas)
- Fix a bug that thermal hwmon sysfs I/F returns wrong critical trip
point temperature value (Krzysztof Kozlowski)
- Add Skylake PCH 100 series support for intel_pch_thermal driver
(OGAWA Hirofumi)
- Small fixes and cleanups for platform thermal drivers (Julia Lawall,
Luis Henriques, Leo Yan, Stephen Boyd, Shawn Lin, Javi Merino and
Lukasz Luba)
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (76 commits)
MAINTAINERS: Samsung: Update maintainer for PWM FAN and SAMSUNG THERMAL
thermal/x86 pkg temp: Convert to hotplug state machine
thermal/x86_pkg_temp: Sanitize package management
thermal/x86_pkg_temp: Move work into package struct
thermal/x86_pkg_temp: Move work scheduled flag into package struct
thermal/x86_pkg_temp: Sanitize locking
thermal/x86_pkg_temp: Cleanup code some more
thermal/x86_pkg_temp: Cleanup namespace
thermal/x86_pkg_temp: Get rid of ref counting
thermal/x86_pkg_temp: Sanitize callback (de)initialization
thermal/x86_pkg_temp: Replace open coded cpu search
thermal/x86_pkg_temp: Remove redundant package search
thermal/x86_pkg_temp: Cleanup thermal interrupt handling
thermal: hwmon: Properly report critical temperature in sysfs
devfreq_cooling: pass a pointer to devfreq in the power model callbacks
devfreq_cooling: make the structs devfreq_cooling_xxx visible for all
dt-bindings: rockchip-thermal: fix the misleading description
thermal: rockchip: improve the warning log
thermal: db8500: Fix module autoload
thermal: tango: Fix module autoload
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"This is a fairly quiet release. We don't have any patches to the core
framework. The only patch that can even be considered "core" adds
another clk_get() variant. The rest of the changes are in drivers for
various SoCs, and we have a few bits for ARM shmobile architecture
code (dts and mach) due to the dependency we're breaking between
shmobile architecture code and its clk driver. Those shmobile bits
have also been pulled into arm-soc tree. Here's the summary:
Core:
- Support for devm_get_clk_from_child() used with DT bindings that
have subnodes with the 'clocks' property
New Drivers:
- Allwinner A64 (sun50i)
- i.MX imx6ull
- Socionext's UniPhier SoC CPUs
- Mediatek MT2701 SoCs
- Rockchip rk1108 SoCs
- Qualcomm MSM8994/MSM8992 SoCS
- Qualcomm RPM Clocks
- Hisilicon Hi3516CV300 and Hi3798CV200 CRG
- Oxford Semiconductor OX820 and OX810SE SoCs
- Renesas RZ/G1M and RZ/GIE SoCs
- Renesas R-Car RST driver for mode pin states
Updates:
- Four Allwinner SoCs are migrated to the new style clk driver
- Rockchip rk3399,rk3066 PLL optimizations
- i.MX LVDS display glitch fixes and AV PLL precision improvements
- Qualcomm MSM8996 GPU GDSCs, hw controlled GDSCs, and Alpha PLL
support
- Explicit demodularization of always builtin drivers
- Freescale Qoriq ls1012a and ls1046a support
- Exynos 5433 parent typo fix and critical clock tagging
- Renesas r8a7743/r8a7745 CPG
- Renesas R-Car M3-W CSI2/VIN/SYS-DMAC/(H)SCIF/I2C/DRIF/gfx support
- stm32f4* LSI, LSE, RTC, and QSPI clocks
- pxa27x and pxa25x cpufreq as clks
- TI omap36xx sprz319 advisory 2.1 workaround
- Broadcom bcm2835 rate change propogation to PLLH_AUX from VEC"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (150 commits)
clk: bcm: Fix 'maybe-uninitialized' warning in bcm2835_clock_choose_div_and_prate()
clk: add devm_get_clk_from_child() API
clk: st: clk-flexgen: Unmap region obtained by of_iomap
clk: keystone: pll: Unmap region obtained by of_iomap
clk:mmp:clk-of-mmp2: Free memory and Unmap region obtained by kzalloc and of_iomap
clk:mmp:clk-of-pxa910: Free memory and Unmap region obtained by kzmalloc and of_iomap
clk: mmp: clk-of-pxa1928: Free memory obtained by kzalloc
clk: cdce925: Fix limit check
clk: bcm: Make COMMON_CLK_IPROC into a library
clk: qoriq: added ls1012a clock configuration
clk: ti: dra7: fix "failed to lookup clock node gmac_gmii_ref_clk_div" boot message
clk: bcm: Allow rate change propagation to PLLH_AUX on VEC clock
clk: bcm: Support rate change propagation on bcm2835 clocks
clk: bcm2835: Avoid overwriting the div info when disabling a pll_div clk
clk: ti: omap36xx: Work around sprz319 advisory 2.1
clk: clk-wm831x: fix a logic error
clk: uniphier: add cpufreq data for LD11, LD20 SoCs
clk: uniphier: add CPU-gear change (cpufreq) support
clk: qcom: Put venus core0/1 gdscs to hw control mode
clk: qcom: gdsc: Add support for gdscs with HW control
Pull remoteproc updates from Bjorn Andersson:
- introduce remoteproc "subdevice" support, which allows remoteproc
driver to associate devices to the "running" state of the remoteproc,
allowing devices to be probed and removed as the remote processor is
booted, shut down or recovering from a crash.
- handling of virtio device resources was improved, vring memory is now
allocated as part of other memory allocation. This ensures that all
vrings for all virtio devices are allocated before we boot the remote
processor.
- the debugfs mechanism for starting and stopping remoteproc instances
was replaced with a sysfs interface, also providing a mechanism for
specifying firmware to use by the instance. This allows user space to
load and boot use case specific firmware on remote processors.
- new drivers for the ST Slimcore and Qualcomm Hexagon DSP as well as
removal of the unused StE modem loader.
- finally support for crash recovery in the Qualcomm Wirelss subsystem
(used for WiFi/BT/FM on a number of platforms) and a number of bug
fixes and cleanups
* tag 'rproc-v4.10' of git://github.com/andersson/remoteproc: (49 commits)
remoteproc: qcom_adsp_pil: select qcom_scm
remoteproc: Drop wait in __rproc_boot()
remoteproc/ste: Delete unused driver
remoteproc: Remove "experimental" warning
dt-binding: soc: qcom: smd: Add label property
remoteproc: qcom: mdt_loader: add include for sizes
remoteproc: Update last rproc_put users to rproc_free
remoteproc: qcom: adsp: Add missing MODULE_DEVICE_TABLE
remoteproc: wcnss-pil: add QCOM_SMD dependency
dmaengine: st_fdma: Revert: "Revert: Update st_fdma to 'depends on REMOTEPROC'"
remoteproc: Add support for xo clock
remoteproc: adsp-pil: fix recursive dependency
remoteproc: Introduce Qualcomm ADSP PIL
dt-binding: remoteproc: Introduce ADSP loader binding
remoteproc: qcom_wcnss: Fix circular module dependency
remoteproc: Merge table_ptr and cached_table pointers
remoteproc: Remove custom vdev handler list
remoteproc: Update max_notifyid as we allocate vrings
remoteproc: Decouple vdev resources and devices
Pull MMC updates from Ulf Hansson:
"It's been an busy period for mmc. Quite some changes in the mmc core,
two new mmc host drivers, some existing drivers being extended to
support new IP versions and lots of other updates.
MMC core:
- Delete eMMC packed command support
- Introduce mmc_abort_tuning() to enable eMMC tuning to fail
gracefully
- Introduce mmc_can_retune() to see if a host can be retuned
- Re-work and improve the sequence when sending a CMD6 for mmc
- Enable CDM13 polling when switching to HS and HS DDR mode for mmc
- Relax checking for CMD6 errors after switch to HS200
- Re-factoring the code dealing with the mmc block queue
- Recognize whether the eMMC card supports CMDQ
- Fix 4K native sector check
- Don't power off the card when starting the host
- Increase MMC_IOC_MAX_BYTES to support bigger firmware binaries
- Improve error handling and drop meaningless BUG_ONs()
- Lots of clean-ups and changes to improve the quality of the code
MMC host:
- sdhci: Fix tuning sequence and clean-up the related code
- sdhci: Add support to via DT override broken SDHCI cap register
bits
- sdhci-cadence: Add new driver for Cadence SD4HC SDHCI variant
- sdhci-msm: Update clock management
- sdhci-msm: Add support for eMMC HS400 mode
- sdhci-msm: Deploy runtime/system PM support
- sdhci-iproc: Extend driver support to newer IP versions
- sdhci-pci: Add support for Intel GLK
- sdhci-pci: Add support for Intel NI byt sdio
- sdhci-acpi: Add support for 80860F14 UID 2 SDIO bus
- sdhci: Lots of various small improvements and clean-ups
- tmio: Add support for tuning
- sh_mobile_sdhi: Add support for tuning
- sh_mobile_sdhi: Extend driver to support SDHI IP on R7S72100 SoC
- sh_mobile_sdhi: remove support for sh7372
- davinci: Use mmc_of_parse() to enable generic mmc DT bindings
- meson: Add new driver to support GX platforms
- dw_mmc: Deploy generic runtime/system PM support
- dw_mmc: Lots of various small improvements
As a part of the mmc changes this time, I have also pulled in an
immutable branch/tag (soc-device-match-tag1) hosted by Geert
Uytterhoeven, to share the implementation of the new
soc_device_match() interface. This is needed by these mmc related
changes:
- mmc: sdhci-of-esdhc: Get correct IP version for T4240-R1.0-R2.0
- soc: fsl: add GUTS driver for QorIQ platforms"
* tag 'mmc-v4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: (136 commits)
mmc: sdhci-cadence: add Cadence SD4HC support
mmc: sdhci: export sdhci_execute_tuning()
mmc: sdhci: Tidy tuning loop
mmc: sdhci: Simplify tuning block size logic
mmc: sdhci: Factor out tuning helper functions
mmc: sdhci: Use mmc_abort_tuning()
mmc: mmc: Introduce mmc_abort_tuning()
mmc: sdhci: Always allow tuning to fall back to fixed sampling
mmc: sdhci: Fix tuning reset after exhausting the maximum number of loops
mmc: sdhci: Fix recovery from tuning timeout
Revert "mmc: sdhci: Reset cmd and data circuits after tuning failure"
mmc: mmc: Relax checking for switch errors after HS200 switch
mmc: sdhci-acpi: support 80860F14 UID 2 SDIO bus
mmc: sdhci-of-at91: remove bogus MMC_SDHCI_IO_ACCESSORS select
mmc: sdhci-pci: Use ACPI to get max frequency for Intel NI byt sdio
mmc: sdhci-pci: Add PCI ID for Intel NI byt sdio
mmc: sdhci-s3c: add spin_unlock_irq() before calling clk_round_rate
mmc: dw_mmc: display the clock message only one time when card is polling
mmc: dw_mmc: add the debug message for polling and non-removable
mmc: dw_mmc: check the "present" variable before checking flags
