This patch adds device tree support to the LPC32xx's ADC.
Signed-off-by: Roland Stigge <stigge@antcom.de>
This patch implements the basic single data conversion support for
the SPEAr600 SoC ADC. The register layout of SPEAr600 differs a bit
from other SPEAr SoC variants (e.g. SPEAr3xx). These differences are
handled via DT compatible testing. Resulting in a multi-arch binary.
This driver is currently tested only on SPEAr600. Future patches may add
support for other SoC variants (SPEAr3xx) and features like software
buffer or DMA.
Acked-by: Jonathan Cameron <jic23@kernel.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Cc: Greg KH <greg@kroah.com>
Pull "ARM: SoC fixes: from Olof Johansson:
"A bunch of fixes for regressions (and a few other problems) in
3.4-rc1:
- Fix for regression of mach/io.h cleanup on platforms with PCI or
PCMCIA (adding back the include file on those for now)
- AT91 fixes for usb and spi
- smsc911x ethernet fixes for i.MX
- smsc911x fixes for OMAP
- gpio fixes for Tegra
- A handful of build error and warning fixes for various platforms
- cpufreq kconfig dependencies, build and lowlevel debug fixes for
Samsung platforms
In other words, more or less the regular collection of -rc1/2 type
material. A few of them, in particular the smsc911x for OMAP series,
aren't technically regressions for 3.4, but they're valid fixes and
we're still relatively early in the rc cycle so it seems appropriate
to include them."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits)
ARM: fix __io macro for PCMCIA
ARM: EXYNOS: Fix compiler warning in dma.c file
ARM: EXYNOS: fix ISO C90 warning
ARM: OMAP2+: hwmod: Fix wrong SYSC_TYPE1_XXX_MASK bit definitions
ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status
ARM: OMAP2+: hwmod: Restore sysc after a reset
ARM: OMAP2+: omap_hwmod: Allow io_ring wakeup configuration for all modules
ARM: OMAP3: clock data: fill in some missing clockdomains
ARM: OMAP4: clock data: Force a DPLL clkdm/pwrdm ON before a relock
ARM: OMAP4: clock data: fix mult and div mask for USB_DPLL
ARM: OMAP2+: powerdomain: Wait for powerdomain transition in pwrdm_state_switch()
gpio: tegra: Iterate over the correct number of banks
gpio: tegra: fix register address calculations for Tegra30
EXYNOS: fix dependency for EXYNOS_CPUFREQ
ARM: at91: dt: remove unit-address part for memory nodes
ARM: at91: fix check of valid GPIO for SPI and USB
USB: ehci-atmel: add needed of.h header file
ARM: at91/NAND DT bindings: add comments
ARM: at91/at91sam9x5.dtsi: fix NAND ale/cle in DT file
USB: ohci-at91: trivial return code name change
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A bunch of smallish fixes that came up during the merge window as
things got more testing - even more fixes from Axel, a fix for error
handling in more complex systems using -EPROBE_DEFER and a couple of
small fixes for the new dummy regulators."
* tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: Remove non-existent parameter from fixed-helper.c kernel doc
regulator: Fix setting new voltage in s5m8767_set_voltage
regulator: fix sysfs name collision between dummy and fixed dummy regulator
regulator: Fix deadlock on removal of regulators with supplies
regulator: Fix comments in include/linux/regulator/machine.h
regulator: Only update [LDOx|DCx]_HIB_MODE bits in wm8350_[ldo|dcdc]_set_suspend_disable
regulator: Fix setting low power mode for wm831x aldo
regulator: Return microamps in wm8350_isink_get_current
regulator: wm8350: Fix the logic to choose best current limit setting
regulator: wm831x-isink: Fix the logic to choose best current limit setting
regulator: wm831x-dcdc: Fix the logic to choose best current limit setting
regulator: anatop: patching to device-tree property "reg".
regulator: Do proper shift to set correct bit for DC[2|5]_HIB_MODE setting
regulator: Fix restoring pmic.dcdcx_hib_mode settings in wm8350_dcdc_set_suspend_enable
regulator: Fix unbalanced lock/unlock in mc13892_regulator_probe error path
regulator: Fix set and get current limit for wm831x_buckv
regulator: tps6586x: Fix list minimal voltage setting for LDO0
Add comments to NAND "gpios" property to make it clearer.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Pull MTD changes from David Woodhouse:
- Artem's cleanup of the MTD API continues apace.
- Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst
others.
- More work on DiskOnChip G3, new driver for DiskOnChip G4.
- Clean up debug/warning printks in JFFS2 to use pr_<level>.
Fix up various trivial conflicts, largely due to changes in calling
conventions for things like dmaengine_prep_slave_sg() (new inline
wrapper to hide new parameter, clashing with rewrite of previously last
parameter that used to be an 'append' flag, and is now a bitmap of
'unsigned long flags').
(Also some header file fallout - like so many merges this merge window -
and silly conflicts with sparse fixes)
* tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits)
mtd: docg3 add protection against concurrency
mtd: docg3 refactor cascade floors structure
mtd: docg3 increase write/erase timeout
mtd: docg3 fix inbound calculations
mtd: nand: gpmi: fix function annotations
mtd: phram: fix section mismatch for phram_setup
mtd: unify initialization of erase_info->fail_addr
mtd: support ONFI multi lun NAND
mtd: sm_ftl: fix typo in major number.
mtd: add device-tree support to spear_smi
mtd: spear_smi: Remove default partition information from driver
mtd: Add device-tree support to fsmc_nand
mtd: fix section mismatch for doc_probe_device
mtd: nand/fsmc: Remove sparse warnings and errors
mtd: nand/fsmc: Add DMA support
mtd: nand/fsmc: Access the NAND device word by word whenever possible
mtd: nand/fsmc: Use dev_err to report error scenario
mtd: nand/fsmc: Use devm routines
mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform
mtd: fsmc_nand: add pm callbacks to support hibernation
Pull battery updates from Anton Vorontsov:
"Various small bugfixes and enhancements, plus two new drivers:
- A quite complex ab8500 charger driver, submitted by Arun Murthy @
ST-Ericsson;
- Summit Microelectronics SMB347 Battery Charger, submitted by Bruce
E Robertson and Alan Cox @ Intel.
And that's all."
* tag 'for-v3.4-rc1' of git://git.infradead.org/battery-2.6: (36 commits)
max17042_battery: Clean up interrupt handling
Revert "max8998_charger: Include linux/module.h just once"
ab8500_fg: Fix some build warnings on x86_64
max17042_battery: Fix CHARGE_FULL representation.
power_supply: Convert i2c drivers to module_i2c_driver
lp8727_charger: Add MODULE_DEVICE_TABLE
charger-manager: Simplify charger_get_property(), get rid of a warning
charger-manager: Clean up for better readability
da9052-battery: Convert to use module_platform_driver
da9052-battery: Fix a memory leak when unload the module
da9052-battery: Add missing platform_set_drvdata
ab8500: Turn unneeded global symbols into local ones
ab8500_fg: Fix copy-paste error
ab8500_fg: Get rid of 'struct battery_type'
ab8500_fg: Get rid of 'struct v_to_cap'
ab8500_btemp: Get rid of 'enum adc_therm'
ab8500_charger: Convert to the new USB OTG calls
ab8500-btemp: AB8500 battery temperature driver
ab8500-fg: A8500 fuel gauge driver
Pull devicetree documentation update from Grant Likely.
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6:
dt: Linux DT usage model documentation
mtd: Move fdt partition documentation to a seperate file
v2: 2nd draft
- Editorial cleanups (Randy Dunlap and Stephen Warren)
- Added missing Microblaze reference (Stephen Neuendorffer)
- Make example of platform_device creation clearer (Shawn Guo)
- Expand on PowerPC history and mention i2c mess (David Gibson)
- convert to plain text (remove bits of html formating)
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
Core:
* Support for MMC 4.5 Data Tag feature -- we tag REQ_META, so devices
that support Data Tag will provide increased throughput for metadata.
* Faster detection of card removal on I/O errors.
Drivers:
* dw_mmc now supports eMMC Power Off Notify, has PCI support, and
implements pre_req and post_req for asynchronous requests.
* omap_hsmmc now supports device tree.
* esdhc now has power management support.
* sdhci-tegra now supports Tegra30 devices.
* sdhci-spear now supports hibernation.
* tmio_mmc now supports using a GPIO for card detection.
* Intel PCH now supports 8-bit bus transfers.
* tag 'mmc-merge-for-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits)
mmc: sh_mmcif: simplify bitmask macros
mmc: sh_mobile_sdhi: support modular mmc-core with non-standard hotplug
mmc: sh_mobile_sdhi: add a callback for board specific init code
mmc: tmio: cosmetic: prettify the tmio_mmc_set_ios() function
mmc: sh_mobile_sdhi: do not manage PM clocks manually
mmc: tmio_mmc: remove unused sdio_irq_enabled flag
mmc: tmio_mmc: power status flag doesn't have to be exposed in platform data
mmc: sh_mobile_sdhi: pass card hotplug GPIO number to TMIO MMC
mmc: tmio_mmc: support the generic MMC GPIO card hotplug helper
mmc: tmio: calculate the native hotplug condition only once
mmc: simplify mmc_cd_gpio_request() by removing two parameters
mmc: sdhci-pci: allow 8-bit bus width for Intel PCH
mmc: sdhci: check interrupt flags in ISR again
mmc: sdhci-pci: Add MSI support
mmc: core: warn when card doesn't support HPI
mmc: davinci: Poll status for small size transfers
mmc: davinci: Eliminate spurious interrupts
mmc: omap_hsmmc: Avoid a regulator voltage change with dt
mmc: omap_hsmmc: Convert hsmmc driver to use device tree
mmc: sdhci-pci: add SDHCI_QUIRK2_HOST_OFF_CARD_ON for Medfield SDIO
Partitions are described in the same way for all mtd devices when using
devicetree, move the documentation to a separate file and add references
to it.
Signed-off-by: Jamie Lentin <jm@lentin.co.uk>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Pull GPIO changes for v3.4 from Grant Likely:
"Primarily gpio device driver changes with some minor side effects
under arch/arm and arch/x86. Also includes a few core changes such as
explicitly supporting (electrical) open source and open drain outputs
and some help for parsing gpio devicetree properties."
Fix up context conflict due to Laxman Dewangan adding sleep control for
the tps65910 driver separately for gpio's and regulators.
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits)
gpio/ep93xx: Remove unused inline function and useless pr_err message
gpio/sodaville: Mark broken due to core irqdomain migration
gpio/omap: fix redundant decoding of gpio offset
gpio/omap: fix incorrect update to context.irqenable1
gpio/omap: fix incorrect context restore logic in omap_gpio_runtime_*
gpio/omap: fix missing dataout context save in _set_gpio_dataout_reg
gpio/omap: fix _set_gpio_irqenable implementation
gpio/omap: fix trigger type to unsigned
gpio/omap: fix wakeup_en register update in _set_gpio_wakeup()
gpio: tegra: tegra_gpio_config shouldn't be __init
gpio/davinci: fix enabling unbanked GPIO IRQs
gpio/davinci: fix oops on unbanked gpio irq request
gpio/omap: Fix section warning for omap_mpuio_alloc_gc()
ARM: tegra: export tegra_gpio_{en,dis}able
gpio/gpio-stmpe: Fix the value returned by _get_value routine
Documentation/gpio.txt: Explain expected pinctrl interaction
GPIO: LPC32xx: Add output reading to GPO P3
GPIO: LPC32xx: Fix missing bit selection mask
gpio/omap: fix wakeups on level-triggered GPIOs
gpio/omap: Fix IRQ handling for SPARSE_IRQ
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD changes from Samuel Ortiz:
- 4 new drivers: Freescale i.MX on-chip Anatop, Ricoh's RC5T583 and
TI's TPS65090 and TPS65217.
- New variants support (8420, 8520 ab9540), cleanups and bug fixes for
the abx500 and db8500 ST-E chipsets.
- Some minor fixes and update for the wm8994 from Mark.
- The beginning of a long term TWL cleanup effort coming from the TI
folks.
- Various fixes and cleanups for the s5m, TPS659xx, pm860x, and MAX8997
drivers.
Fix up trivial conflicts due to duplicate patches and header file
cleanups (<linux/device.h> removal etc).
* tag 'mfd_3.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (97 commits)
gpio/twl: Add DT support to gpio-twl4030 driver
gpio/twl: Allocate irq_desc dynamically for SPARSE_IRQ support
mfd: Detach twl6040 from the pmic mfd driver
mfd: Replace twl-* pr_ macros by the dev_ equivalent and do various cleanups
mfd: Micro-optimization on twl4030 IRQ handler
mfd: Make twl4030 SIH SPARSE_IRQ capable
mfd: Move twl-core IRQ allocation into twl[4030|6030]-irq files
mfd: Remove references already defineid in header file from twl-core
mfd: Remove unneeded header from twl-core
mfd: Make twl-core not depend on pdata->irq_base/end
ARM: OMAP2+: board-omap4-*: Do not use anymore TWL6030_IRQ_BASE in board files
mfd: Return twl6030_mmc_card_detect IRQ for board setup
Revert "mfd: Add platform data for MAX8997 haptic driver"
mfd: Add support for TPS65090
mfd: Add some da9052-i2c section annotations
mfd: Build rtc5t583 only if I2C config is selected to y.
mfd: Add anatop mfd driver
mfd: Fix compilation error in tps65910.h
mfd: Add 8420 variant to db8500-prcmu
mfd: Add 8520 PRCMU variant to db8500-prcmu
Pull "ARM: More device tree support updates" from Olof Johansson:
"This branch contains a number of updates for device tree support on
several ARM platforms, in particular:
* AT91 continues the device tree conversion adding support for a
number of on-chip drivers and other functionality
* ux500 adds probing of some of the core SoC blocks through device
tree
* Initial device tree support for ST SPEAr600 platforms
* kirkwood continues the conversion to device-tree probing"
Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and
drivers/usb/gadget/at91_udc.c due to header file include cleanups.
Also do an "evil merge" for the MACH_U8500 config option rename that the
affected RMI4 touchscreen driver in staging. It's called MACH_MOP500
now, and it was missed during previous merges.
* tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
ARM: SPEAr600: Add device-tree support to SPEAr600 boards
ARM: ux500: Provide local timer support for Device Tree
ARM: ux500: Enable PL022 SSP Controller in Device Tree
ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree
ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree
ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree
ARM: ux500: db8500: list most devices in the snowball device tree
ARM: ux500: split dts file for snowball into generic part
ARM: ux500: combine the board init functions for DT boot
ARM: ux500: Initial Device Tree support for Snowball
ARM: ux500: CONFIG: Enable Device Tree support for future endeavours
ARM: kirkwood: use devicetree for rtc-mv
ARM: kirkwood: rtc-mv devicetree bindings
ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0
ARM: kirkwood: fdt: facilitate new boards during fdt migration
ARM: kirkwood: fdt: absorb kirkwood_init()
ARM: kirkwood: fdt: use mrvl ticker symbol
ARM: orion: wdt: use resource vice direct access
ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data.
ARM: orion: spi: remove enable_clock_fix which is not used
Change "reg" to "anatop-reg-offset" due to there is a warning of handling no
size field in reg.
This patch also adds the missing device-tree binding documentation.
Signed-off-by: Ying-Chun Liu (PaulLiu) <paul.liu@linaro.org>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Pull "ARM: device tree work" from Arnd Bergmann:
"Most of these patches convert code from using static platform data to
describing the hardware in the device tree. This is only the first
half of the changes for v3.4 because a lot of patches for this topic
came in the last week before the merge window.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fix up trivial conflicts in arch/arm/mach-vexpress/{Kconfig,core.h}
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (86 commits)
Document: devicetree: add OF documents for arch-mmp
ARM: dts: append DTS file of pxa168
ARM: mmp: append OF support on pxa168
ARM: mmp: enable rtc clk in pxa168
i2c: pxa: add OF support
serial: pxa: add OF support
arm/dts: mt_ventoux: very basic support for TeeJet Mt.Ventoux board
ARM: OMAP2+: Remove extra ifdefs for board-generic
ARM: OMAP2+: Fix build error when only ARCH_OMAP2/3 or 4 is selected
ASoC: DT: Add digital microphone binding to PAZ00 board.
ARM: dt: Add ARM PMU to tegra*.dtsi
ARM: at91: at91sam9x5cm/dt: add leds support
ARM: at91: usb_a9g20/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add leds support
ARM: at91: usb_a9g20/dt: add leds support
ARM: at91/pio: add new PIO3 features
ARM: at91: add sam9_smc.o to at91sam9x5 build
ARM: at91/tc/clocksource: Add 32 bit variant to Timer Counter
ARM: at91/tc: add device tree support to atmel_tclib
Pull "ARM: driver specific updates" from Arnd Bergmann:
"These are all specific to some driver. They are typically the
platform side of a change in the drivers directory, such as adding a
new driver or extending the interface to the platform. In cases where
there is no maintainer for the driver, or the maintainer prefers to
have the platform changes in the same branch as the driver changes,
the patches to the drivers are included as well.
A much smaller set of driver updates that depend on other branches
getting merged first will be sent later.
The new export of tegra_chip_uid conflicts with other changes in
fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED
conflicts with the cleanup of the interrupt handling of that driver.
Fixed up aforementioned trivial conflicts.
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci
mmc: sdhci-s3c: add platform data for the second capability
ARM: SAMSUNG: support the second capability for samsung-soc
ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC
ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1
ARM: EXYNOS: Enable MDMA driver
regulator: Remove bq24022 regulator driver
rtc: sa1100: add OF support
pxa: magician/hx4700: Convert to gpio-regulator from bq24022
ARM: OMAP3+: SmartReflex: fix error handling
ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API
ARM: OMAP3+: SmartReflex: micro-optimization for sanity check
ARM: OMAP3+: SmartReflex: misc cleanups
ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument
ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata()
ARM: OMAP3+: hwmod: add SmartReflex IRQs
ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need
ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register
ARM: OMAP3+: SmartReflex: Add a shutdown hook
ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP
arch/arm/mach-tegra/Makefile
arch/arm/mach-tegra/fuse.c
drivers/rtc/rtc-sa1100.c
Pull "ARM: timer cleanup work" from Arnd Bergmann:
"These are split out from the generic soc and driver updates because
there was a lot of conflicting work by multiple people. Marc Zyngier
worked on simplifying the "localtimer" interfaces, and some of the
platforms are touching the same code as they move to device tree based
booting.
* tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits)
ARM: tegra: select USB_ULPI if USB is selected
arm/tegra: pcie: fix return value of function
ARM: ux500: fix compilation after local timer rework
ARM: shmobile: remove additional __io() macro use
ARM: local timers: make the runtime registration interface mandatory
ARM: local timers: convert MSM to runtime registration interface
ARM: local timers: convert exynos to runtime registration interface
ARM: smp_twd: remove old local timer interface
ARM: imx6q: convert to twd_local_timer_register() interface
ARM: highbank: convert to twd_local_timer_register() interface
ARM: ux500: convert to twd_local_timer_register() interface
ARM: shmobile: convert to twd_local_timer_register() interface
ARM: tegra: convert to twd_local_timer_register() interface
ARM: plat-versatile: convert to twd_local_timer_register() interface
ARM: OMAP4: convert to twd_local_timer_register() interface
ARM: smp_twd: add device tree support
ARM: smp_twd: add runtime registration support
ARM: local timers: introduce a new registration interface
ARM: smp_twd: make local_timer_stop a symbol instead of a #define
ARM: mach-shmobile: default to no earlytimer
Define dt bindings for the ti-omap-hsmmc, and adapt the driver to extract
data (which was earlier passed as platform_data) from device tree.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
This patch adds support to configure the SPEAr SMI driver via
device-tree instead of platform_data.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
This patch adds support to configure the FSMC NAND driver (used amongst
others on SPEAr platforms) via device-tree instead of platform_data.
Allow both device tree (preferred) and platform data-based driver
instantiation.
Signed-off-by: Karol Lewandowski <k.lewandowsk@samsung.com>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator into next/drivers
The pxa regulator branch removes the bq24022 driver, while a lot of
other regulator drivers got added in the regulator tree. This
resolves the trivial conflicts by merging in the regulator patches
that are already merged into v3.4.
drivers/regulator/Kconfig
drivers/regulator/Makefile
Pull i2c embedded updates from Wolfram Sang:
"Nothing special from i2c-embedded for this merge window. Two new
drivers, minor feature additions, bugfixes, cleanups.
All patches have been in linux-next for some time, too."
* 'i2c-embedded/for-3.4' of git://git.pengutronix.de/git/wsa/linux:
i2c-eg20t: Remove write-only variables
i2c-eg20t: Rework pch_i2c_wait_for_bus_idle to reduce wait time
i2c-s3c2410: Add stub runtime power management
i2c-s3c2410: Convert to devm_kzalloc()
i2c: add CSR SiRFprimaII on-chip I2C controllers driver
i2c: tegra: Remove unnecessary write to INT_STATUS
i2c: imx: fix imx driver to work though signal is pending
i2c: designware: dw_i2c_init_driver as subsys initcall
misc: at24: describe platform_data with kernel_doc
i2c: Move I2C_EG20T option to the right place.
i2c: Support for Netlogic XLR/XLS I2C controller.
i2c: mpc: Add support for SMBUS_READ_BLOCK_DATA
i2c: versatile: Add Device Tree support
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"- we finally merged driver for USB version of Synaptics touchpads
(I guess most commonly found in IBM/Lenovo keyboard/touchpad combo);
- a bunch of new drivers for embedded platforms (Cypress
touchscreens, DA9052 OnKey, MAX8997-haptic, Ilitek ILI210x
touchscreens, TI touchscreen);
- input core allows clients to specify desired clock source for
timestamps on input events (EVIOCSCLOCKID ioctl);
- input core allows querying state of all MT slots for given event
code via EVIOCGMTSLOTS ioctl;
- various driver fixes and improvements."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (45 commits)
Input: ili210x - add support for Ilitek ILI210x based touchscreens
Input: altera_ps2 - use of_match_ptr()
Input: synaptics_usb - switch to module_usb_driver()
Input: convert I2C drivers to use module_i2c_driver()
Input: convert SPI drivers to use module_spi_driver()
Input: omap4-keypad - move platform_data to <linux/platform_data>
Input: kxtj9 - who_am_i check value and initial data rate fixes
Input: add driver support for MAX8997-haptic
Input: tegra-kbc - revise device tree support
Input: of_keymap - add device tree bindings for simple key matrices
Input: wacom - fix physical size calculation for 3rd-gen Bamboo
Input: twl4030-vibra - really switch from #if to #ifdef
Input: hp680_ts_input - ensure arguments to request_irq and free_irq are compatible
Input: max8925_onkey - avoid accessing input device too early
Input: max8925_onkey - allow to be used as a wakeup source
Input: atmel-wm97xx - convert to dev_pm_ops
Input: atmel-wm97xx - set driver owner
Input: add cyttsp touchscreen maintainer entry
Input: cyttsp - remove useless checks in cyttsp_probe()
Input: usbtouchscreen - add support for Data Modul EasyTouch TP 72037
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull updates of sound stuff from Takashi Iwai:
"Here is the first big update chunk of sound stuff for 3.4-rc1.
In the common sound infrastructure, there are a few changes for
dynamic PCM support (used in ASoC) and a few clean-ups. Majority of
changes are found, as usual, in HD-audio and ASoC.
Some highlights of HD-audio changes:
- All the long-standing static quirk codes for Realtek codec were
finally removed by fixing and extending the Realtek auto-parser.
- The mute-LED control is standardized over all HD-audio codec
drivers using the extended vmaster hook.
- The vmaster slave mixer elements are initialized to 0dB as default
so that the user won't be annoyed by the silent output after
updates, e.g. due to the additions of new elements.
- Other many fix-ups for the misc HD-audio devices.
In the ASoC side, this is a very active release, including a quite a
few framework enhancements. Some highlights:
- Support for widgets not associated with a CODEC, an important part
of the dynamic PCM framework.
- A library factoring out the common code shared by dmaengine based
DMA drivers contributed by Lars-Peter Clausen. This will save a
lot of code and make it much easier to deploy enhancements to
dmaengine.
- Support for binary controls, used for providing runtime
configuration of algorithm coefficients.
- A new DAPM widget type for regulator supplies allowing drivers for
devices that can power down unused supplies while active to do
without any per-driver code.
- DAPM widgets for DAIs, initially giving a speed boost for playback
startup and shutdown and also the basis for CODEC<->CODEC DAI link
support.
- Support for specifying the number of significant bits on audio
interfaces, useful for allowing applications to know how much
effort to put into generating data for a larger sample format.
- Conversion of the FSI driver used on some SH processors to
DMAEngine.
- Conversion of EP93xx drivers to DMAEngine.
- New CODEC drivers for Maxim MAX9768 and Wolfson Microelectronics
WM2200.
- Move audmux driver from arc/arm to sound/soc
- McBSP move from arch/ to sound/ and updates
Also, a few small updates and fixes for other drivers like au88x0,
ymfpci, USB 6fire, USB usx2yaudio are included."
* tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (446 commits)
ASoC: wm8994: Provide VMID mode control and fix default sequence
ASoC: wm8994: Add missing break in resume
ASoC: wm_hubs: Don't actively manage LINEOUT_VMID_BUF
ASoC: pxa-ssp: atomically set stream active masks
ASoC: fsl: p1022ds: tell the WM8776 codec driver that it's the master
ASoC: Samsung: Added to support mono recording
ALSA: hda - Fix build with CONFIG_PM=n
ALSA: au88x0 - Avoid possible Oops at unbinding
ALSA: usb-audio - Fix build error by consitification of rate list
ASoC: core: Fix obscure leak of runtime array
ALSA: pcm - Avoid GFP_ATOMIC in snd_pcm_link()
ALSA: pcm: Constify the list in snd_pcm_hw_constraint_list
ASoC: wm8996: Add 44.1kHz support
ALSA: hda - Fix build of patch_sigmatel.c without CONFIG_SND_HDA_POWER_SAVE
ASoC: mx27vis-aic32x4: Convert it to platform driver
ALSA: hda - fix printing of high HDMI sample rates
ALSA: ymfpci - Fix legacy registers on S3/S4 resume
ALSA: control - Fixe a trailing white space error
ALSA: hda - Add expose_enum_ctl flag to snd_hda_add_vmaster_hook()
ALSA: hda - Add "Mute-LED Mode" enum control
Add the DT support for the I2C GPIO expander inside the twl4030.
Note: The pdata parameters still have to be properly adapted using
dedicated bindings.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc merge from Benjamin Herrenschmidt:
"Here's the powerpc batch for this merge window. It is going to be a
bit more nasty than usual as in touching things outside of
arch/powerpc mostly due to the big iSeriesectomy :-) We finally got
rid of the bugger (legacy iSeries support) which was a PITA to
maintain and that nobody really used anymore.
Here are some of the highlights:
- Legacy iSeries is gone. Thanks Stephen ! There's still some bits
and pieces remaining if you do a grep -ir series arch/powerpc but
they are harmless and will be removed in the next few weeks
hopefully.
- The 'fadump' functionality (Firmware Assisted Dump) replaces the
previous (equivalent) "pHyp assisted dump"... it's a rewrite of a
mechanism to get the hypervisor to do crash dumps on pSeries, the
new implementation hopefully being much more reliable. Thanks
Mahesh Salgaonkar.
- The "EEH" code (pSeries PCI error handling & recovery) got a big
spring cleaning, motivated by the need to be able to implement a
new backend for it on top of some new different type of firwmare.
The work isn't complete yet, but a good chunk of the cleanups is
there. Note that this adds a field to struct device_node which is
not very nice and which Grant objects to. I will have a patch soon
that moves that to a powerpc private data structure (hopefully
before rc1) and we'll improve things further later on (hopefully
getting rid of the need for that pointer completely). Thanks Gavin
Shan.
- I dug into our exception & interrupt handling code to improve the
way we do lazy interrupt handling (and make it work properly with
"edge" triggered interrupt sources), and while at it found & fixed
a wagon of issues in those areas, including adding support for page
fault retry & fatal signals on page faults.
- Your usual random batch of small fixes & updates, including a bunch
of new embedded boards, both Freescale and APM based ones, etc..."
I fixed up some conflicts with the generalized irq-domain changes from
Grant Likely, hopefully correctly.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits)
powerpc/ps3: Do not adjust the wrapper load address
powerpc: Remove the rest of the legacy iSeries include files
powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces
init: Remove CONFIG_PPC_ISERIES
powerpc: Remove FW_FEATURE ISERIES from arch code
tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable
powerpc/spufs: Fix double unlocks
powerpc/5200: convert mpc5200 to use of_platform_populate()
powerpc/mpc5200: add options to mpc5200_defconfig
powerpc/mpc52xx: add a4m072 board support
powerpc/mpc5200: update mpc5200_defconfig to fit for charon board
Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup
powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board
powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board
MAINTAINERS: Update PowerPC 4xx tree
powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board
powerpc: document the FSL MPIC message register binding
powerpc: add support for MPIC message register API
powerpc/fsl: Added aliased MSIIR register address to MSI node in dts
powerpc/85xx: mpc8548cds - add 36-bit dts
Pull regulator updates for 3.4 from Mark Brown:
"This has been a fairly quiet release from a regulator point of view,
the only real framework features added were devm support and a
convenience helper for setting up fixed voltage regulators.
We also added a couple of drivers (but will drop the BQ240022 driver
via the arm-soc tree as it's been replaced by the more generic
gpio-regulator driver) and Axel Lin continued his relentless and
generally awesome stream of fixes and cleanups."
* tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (93 commits)
regulator: Fix up a confusing dev_warn when DT lookup fails
regulator: Convert tps6507x to set_voltage_sel
regulator: Refactor tps6507x to use one tps6507x_pmic_ops for all LDOs and DCDCs
regulator: Make s5m8767_get_voltage_register always return correct register
regulator: s5m8767: Check pdata->buck[2|3|4]_gpiodvs earlier
regulator: tps65910: Provide settling time for DCDC voltage change
regulator: Add Anatop regulator driver
regulator: Simplify implementation of tps65912_get_voltage_dcdc
regulator: Use tps65912_set_voltage_sel for both DCDCx and LDOx
regulator: tps65910: Provide settling time for enabling rails
regulator: max8925: Use DIV_ROUND_UP macro
regulator: tps65912: Use simple equations to get register address
regulator: Fix the logic of tps65910_get_mode
regulator: Merge tps65217_pmic_ldo234_ops and tps65217_pmic_dcdc_ops to tps65217_pmic_ops
regulator: Use DIV_ROUND_CLOSEST in wm8350_isink_get_current
regulator: Use array to store dcdc_range settings for tps65912
regulator: Rename s5m8767_convert_voltage to s5m8767_convert_voltage_to_sel
regulator: tps6524x: Remove unneeded comment for N_REGULATORS
regulator: Rename set_voltage_sel callback function name to *_sel
regulator: Fix s5m8767_set_voltage_time_sel calculation value
Pull SPI changes for v3.4 from Grant Likely:
"Mostly a bunch of new drivers and driver bug fixes; but this also
includes a few patches that create a core message queue infrastructure
for the spi subsystem instead of making each driver open code it."
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits)
spi/fsl-espi: Make sure pm is within 2..32
spi/fsl-espi: make the clock computation easier to read
spi: sh-hspi: modify write/read method
spi: sh-hspi: control spi clock more correctly
spi: sh-hspi: convert to using core message queue
spi: s3c64xx: Fix build
spi: s3c64xx: remove unnecessary callback msg->complete
spi: remove redundant variable assignment
spi: release lock on error path in spi_pump_messages()
spi: Compatibility with direction which is used in samsung DMA operation
spi-topcliff-pch: add recovery processing in case wait-event timeout
spi-topcliff-pch: supports a spi mode setup and bit order setup by IO control
spi-topcliff-pch: Fix issue for transmitting over 4KByte
spi-topcliff-pch: Modify pci-bus number dynamically to get DMA device info
spi/imx: simplify error handling to free gpios
spi: Convert to DEFINE_PCI_DEVICE_TABLE
spi: add Broadcom BCM63xx SPI controller driver
SPI: add CSR SiRFprimaII SPI controller driver
spi-topcliff-pch: fix -Wuninitialized warning
spi: Mark spi_register_board_info() __devinit
Pull core device tree changes for Linux v3.4 from Grant Likely:
"This branch contains a minor documentation addition, a utility
function for parsing string properties needed by some of the new ARM
platforms, disables dynamic DT code that isn't used anywhere but on a
few PPC machines, and exports DT node compatible data to userspace via
UEVENT properties. Nothing earth shattering here."
* tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6:
of: Only compile OF_DYNAMIC on PowerPC pseries and iseries
arm/dts: OMAP3: Add omap3evm and am335xevm support
drivercore: Output common devicetree information in uevent
of: Add of_property_match_string() to find index into a string list
Pull power management updates for 3.4 from Rafael Wysocki:
"Assorted extensions and fixes including:
* Introduction of early/late suspend/hibernation device callbacks.
* Generic PM domains extensions and fixes.
* devfreq updates from Axel Lin and MyungJoo Ham.
* Device PM QoS updates.
* Fixes of concurrency problems with wakeup sources.
* System suspend and hibernation fixes."
* tag 'pm-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (43 commits)
PM / Domains: Check domain status during hibernation restore of devices
PM / devfreq: add relation of recommended frequency.
PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on()
PM / shmobile: Make CMT driver use pm_genpd_dev_always_on()
PM / shmobile: Make TMU driver use pm_genpd_dev_always_on()
PM / Domains: Introduce "always on" device flag
PM / Domains: Fix hibernation restore of devices, v2
PM / Domains: Fix handling of wakeup devices during system resume
sh_mmcif / PM: Use PM QoS latency constraint
tmio_mmc / PM: Use PM QoS latency constraint
PM / QoS: Make it possible to expose PM QoS latency constraints
PM / Sleep: JBD and JBD2 missing set_freezable()
PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case
PM / Freezer: Remove references to TIF_FREEZE in comments
PM / Sleep: Add more wakeup source initialization routines
PM / Hibernate: Enable usermodehelpers in hibernate() error path
PM / Sleep: Make __pm_stay_awake() delete wakeup source timers
PM / Sleep: Fix race conditions related to wakeup source timer function
PM / Sleep: Fix possible infinite loop during wakeup source destruction
PM / Hibernate: print physical addresses consistently with other parts of kernel
Pull trivial tree from Jiri Kosina:
"It's indeed trivial -- mostly documentation updates and a bunch of
typo fixes from Masanari.
There are also several linux/version.h include removals from Jesper."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits)
kcore: fix spelling in read_kcore() comment
constify struct pci_dev * in obvious cases
Revert "char: Fix typo in viotape.c"
init: fix wording error in mm_init comment
usb: gadget: Kconfig: fix typo for 'different'
Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c"
writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header
writeback: fix typo in the writeback_control comment
Documentation: Fix multiple typo in Documentation
tpm_tis: fix tis_lock with respect to RCU
Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c"
Doc: Update numastat.txt
qla4xxx: Add missing spaces to error messages
compiler.h: Fix typo
security: struct security_operations kerneldoc fix
Documentation: broken URL in libata.tmpl
Documentation: broken URL in filesystems.tmpl
mtd: simplify return logic in do_map_probe()
mm: fix comment typo of truncate_inode_pages_range
power: bq27x00: Fix typos in comment
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
arch/arm/mach-lpc32xx/clock.c
arch/arm/mach-pxa/pxa25x.c
arch/arm/mach-pxa/pxa27x.c
The conflicts with pxa are non-obvious, we have multiple branches
adding and removing the same clock settings. According to
Haojian Zhuang, removing the sa1100 rtc dummy clock is the correct
fix here.
Pull TTY/serial patches from Greg KH:
"tty and serial merge for 3.4-rc1
Here's the big serial and tty merge for the 3.4-rc1 tree.
There's loads of fixes and reworks in here from Jiri for the tty
layer, and a number of patches from Alan to help try to wrestle the vt
layer into a sane model.
Other than that, lots of driver updates and fixes, and other minor
stuff, all detailed in the shortlog."
* tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits)
serial: pxa: add clk_prepare/clk_unprepare calls
TTY: Wrong unicode value copied in con_set_unimap()
serial: PL011: clear pending interrupts
serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset.
vt: NULL dereference in vt_do_kdsk_ioctl()
tty: serial: vt8500: fix annotations for probe/remove
serial: remove back and forth conversions in serial_out_sync
serial: use serial_port_in/out vs serial_in/out in 8250
serial: introduce generic port in/out helpers
serial: reduce number of indirections in 8250 code
serial: delete useless void casts in 8250.c
serial: make 8250's serial_in shareable to other drivers.
serial: delete last unused traces of pausing I/O in 8250
pch_uart: Add module parameter descriptions
pch_uart: Use existing default_baud in setup_console
pch_uart: Add user_uartclk parameter
pch_uart: Add Fish River Island II uart clock quirks
pch_uart: Use uartclk instead of base_baud
mpc5200b/uart: select more tolerant uart prescaler on low baudrates
tty: moxa: fix bit test in moxa_start()
arch/arm/mach-shmobile/timer.c
This resolves a nonobvious merge conflict between renesas
timer changes in the global timer changes with those
from the renesas soc branch and last minute bug fixes that
went into v3.3.
git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra into next/dt2
* 'for-3.4/dt' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra:
arm: tegra: dts: Mark USB1 as an OTG port on Seaboard
arm: tegra: dts: Add legacy mode support to Tegra2x USB1 port
arm: tegra: dts: Support host/device selection and legacy mode
This patch adds support to configure the STMMAC ethernet driver via
Currently, only the properties needed on SPEAr600 are provided. All
other properties should be added once needed on other platforms.
Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com>
This binding documents how the message register blocks found in some FSL
MPIC implementations shall be represented in a device tree.
Signed-off-by: Meador Inge <meador_inge@mentor.com>
Signed-off-by: Jia Hongtao <B38951@freescale.com>
The MSIIR register for each MSI bank is aliased to a different
address. The MSI node reg property was updated to contain this
address:
e.g. reg = <0x41600 0x200 0x44140 4>;
The first region contains the address and length of the MSI
register set and the second region contains the address of
the aliased MSIIR register at 0x44140.
Signed-off-by: Diana CRACIUN <Diana.Craciun@freescale.com>
* spear/dt:
(update to v3.3-rc7)
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-vexpress/Kconfig
The conflicts are between the previous contents of the next/dt2
branch and upstream changes from v3.3-rc7.
This patch adds a generic target for SPEAr600 board that can be
configured via the device-tree. Currently the following devices
are supported via the devicetree:
- VIC interrupts
- PL011 UART
- PL061 GPIO
- Synopsys DW I2C
- Synopsys DW ethernet
Other peripheral devices (e.g. SMI flash, FSMC NAND flash etc) will
follow in later patches.
Only the spear600-evb is currently supported. Other SPEAr600
based boards will follow later.
Since the current mainline SPEAr600 code only supports the SPEAr600
evaluation board, with nearly zero peripheral devices (only UART
and GPIO), it makes sense to switch over to DT based configuration
completely now. So this patch also removes all non-DT stuff, mainly
platform device data. The files spear600.c and spear600_evb.c are
removed completely.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
* ux500/dt:
(adds dependency on localtimer branch, irqdomain branch and ux500/soc
branch)
arch/arm/mach-ux500/devices-common.c
This adds patches from Lee Jones, Niklas Hernaeus and myself to provide
initial device tree support on the ux500 platform. The pull request from
Lee contained some other changes, so I rebased the patches on top of
the branches that are actually dependencies for this.
git://github.com/at91linux/linux-at91 into next/dt
* 'at91-3.4-cleanup2-DT2+USB' of git://github.com/at91linux/linux-at91:
ARM: at91: sam9g20 udc add dt support
USB: at91: Device udc add dt support
* 'at91-3.4-cleanup2-DT2' of git://github.com/at91linux/linux-at91: (23 commits)
ARM: at91: dt: enable usb ehci for sam9g45 and sam9x5
ARM: at91: usb ehci add dt support
ARM: at91: dt: enable usb ohci for sam9g20, sam9g45 amd sam9x5
ARM: at91: usb ohci add dt support
ARM: at91: add Shutdown Controller (SHDWC) DT support
ARM: at91: add ram controller DT support
ARM: at91: add RSTC (Reset Controller) dt support
ARM: at91: always enable sam9 restart
ARM: at91: add pmc DT support
ARM: at91/dt: add specific DT soc init
ARM: at91/dt: add Calao DAB-MMX daugther board support for USB-A9G20
ARM: at91: sam9x5 add i2c DT support
ARM: at91: sam9g45 add i2c DT support
ARM: at91: usb_a9g20 add DT i2c support
ARM: at91: sam9g20 add i2c DT support
i2c/gpio: add DT support
ARM: at91: sam9x5 add nand support
atmel/nand: add DT support
of/mtd/nand: add generic bindings and helpers
of: introduce helper to manage boolean
Allow to compile it if AT91 is enable.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Use a string to specific the wakeup mode to make it more readable.
Add the Real-time Clock Wake-up support too for sam9g45 and sam9x5.
Add AT91_SHDW_CPTWK0_MAX to specific the Max of the Wakeup Counter.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
