Merge fixes from Andrew Morton:
"A bunch of fixes and one simple fbdev driver which missed the merge
window because people will still talking about it (to no great
effect)."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits)
aio: fix kioctx not being freed after cancellation at exit time
mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas
drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing
ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()
random: fix accounting race condition with lockless irq entropy_count update
drivers/char/random.c: fix priming of last_data
mm/memory_hotplug.c: fix printk format warnings
nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary
drivers/block/brd.c: fix brd_lookup_page() race
fbdev: FB_GOLDFISH should depend on HAS_DMA
drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq()
auditfilter.c: fix kernel-doc warnings
aio: fix io_getevents documentation
revert "selftest: add simple test for soft-dirty bit"
drivers/leds/leds-ot200.c: fix error caused by shifted mask
mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer
linux/kernel.h: fix kernel-doc warning
mm compaction: fix of improper cache flush in migration code
rapidio/tsi721: fix bug in MSI interrupt handling
hfs: avoid crash in hfs_bnode_create
A simple frame-buffer describes a raw memory region that may be rendered
to, with the assumption that the display hardware has already been set
up to scan out from that buffer.
This is useful in cases where a bootloader exists and has set up the
display hardware, but a Linux driver doesn't yet exist for the display
hardware.
Examples use-cases include:
* The built-in LCD panels on the Samsung ARM chromebook, and Tegra
devices, and likely many other ARM or embedded systems. These cannot
yet be supported using a full graphics driver, since the panel control
should be provided by the CDF (Common Display Framework), which has been
stuck in design/review for quite some time. One could support these
panels using custom SoC-specific code, but there is a desire to use
common infra-structure rather than having each SoC vendor invent their
own code, hence the desire to wait for CDF.
* Hardware for which a full graphics driver is not yet available, and
the path to obtain one upstream isn't yet clear. For example, the
Raspberry Pi.
* Any hardware in early stages of upstreaming, before a full graphics
driver has been tackled. This driver can provide a graphical boot
console (even full X support) much earlier in the upstreaming process,
thus making new SoC or board support more generally useful earlier.
[akpm@linux-foundation.org: make simplefb_formats[] static]
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Olof Johansson <olof@lixom.net>
Cc: Rob Clark <robclark@gmail.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
From Nicolas Ferre:
An important revert on at91rm9200 platform related
to timers that prevented the platform to boot properly.
Then one pinctrl adjustments for SPI CS and a couple of
trivial typos.
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
ARM: at91: rm9200 fix time support
ARM: at91: dts: request only spi cs-gpios used on sama5d3x cpu module
ARM: at91/trivial: typo in GEM compatible string
ARM: at91/trivial: fix model name for SAM9X25-EK
Pull device tree fixes from Grant Likely:
"Device tree bug fixes and documentation updates for v3.10
Nothing earth shattering here. A build failure fix, and fix for
releasing nodes and some documenation updates."
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
Documentation/devicetree: make semantic of initrd-end more explicit
of/base: release the node correctly in of_parse_phandle_with_args()
of/documentation: move video device bindings to a common place
<linux/of_platform.h>: fix compilation warnings with DT disabled
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Pull MIPS updates from Ralf Baechle:
- More work on DT support for various platforms
- Various fixes that were to late to make it straight into 3.9
- Improved platform support, in particular the Netlogic XLR and
BCM63xx, and the SEAD3 and Malta eval boards.
- Support for several Ralink SOC families.
- Complete support for the microMIPS ASE which basically reencodes the
existing MIPS32/MIPS64 ISA to use non-constant size instructions.
- Some fallout from LTO work which remove old cruft and will generally
make the MIPS kernel easier to maintain and resistant to compiler
optimization, even in absence of LTO.
- KVM support. While MIPS has announced hardware virtualization
extensions this KVM extension uses trap and emulate mode for
virtualization of MIPS32. More KVM work to add support for VZ
hardware virtualizaiton extensions and MIPS64 will probably already
be merged for 3.11.
Most of this has been sitting in -next for a long time. All defconfigs
have been build or run time tested except three for which fixes are being
sent by other maintainers.
Semantic conflict with kvm updates done as per Ralf
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits)
MIPS: Add new GIC clockevent driver.
MIPS: Formatting clean-ups for clocksources.
MIPS: Refactor GIC clocksource code.
MIPS: Move 'gic_frequency' to common location.
MIPS: Move 'gic_present' to common location.
MIPS: MIPS16e: Add unaligned access support.
MIPS: MIPS16e: Support handling of delay slots.
MIPS: MIPS16e: Add instruction formats.
MIPS: microMIPS: Optimise 'strnlen' core library function.
MIPS: microMIPS: Optimise 'strlen' core library function.
MIPS: microMIPS: Optimise 'strncpy' core library function.
MIPS: microMIPS: Optimise 'memset' core library function.
MIPS: microMIPS: Add configuration option for microMIPS kernel.
MIPS: microMIPS: Disable LL/SC and fix linker bug.
MIPS: microMIPS: Add vdso support.
MIPS: microMIPS: Add unaligned access support.
MIPS: microMIPS: Support handling of delay slots.
MIPS: microMIPS: Add support for exception handling.
MIPS: microMIPS: Floating point support.
MIPS: microMIPS: Fix macro naming in micro-assembler.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
Omap fixes for things that were discovered during the merge window:
- Few GPMC fixes and binding doc updates noted after sending
pull requests for the GPMC branch.
- Board fixes for beagle usb host and rx51 spi probe order
- SoC fixes dt earlyprintk, omap1 dma and omap2+ id.c error
handling fixes
Then few minor things that are not strictly fixes but are good
to get out of the way:
- Add missing legacy mux registers for am/dm73x gpio
- Add detection for am33xx pg2.1 silicon
- Enable twl4030 audio modules in defconfig
* tag 'omap-for-v3.10/fixes-for-merge-window-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: Remove bogus IS_ERR_OR_NULL checking from id.c
ARM: OMAP4+: omap2plus_defconfig: Enable audio via TWL6040 as module
ARM: OMAP2: AM33XX: id: Add support for new AM335x PG2.1 Si
omap: mux: add AM/DM37x gpios
ARM: OMAP1: DMA: fix error handling in omap1_system_dma_init()
ARM: OMAP2+: omap_device: use late_initcall_sync
ARM: OMAP: RX-51: change probe order of touchscreen and panel SPI devices
ARM: OMAP3: Beagle: Fix USB Host on beagle xM Ax/Bx
ARM: OMAP2+: only WARN if a GPMC child probe function fail
ARM: OMAP2+: only search for GPMC DT child nodes on probe
Documentation: dt: update properties in TI GPMC NAND example
Documentation: dt: update TI GPMC ethernet binding properties
Pull MTD update from David Woodhouse:
- Lots of cleanups from Artem, including deletion of some obsolete
drivers
- Support partitions larger than 4GiB in device tree
- Support for new SPI chips
* tag 'for-linus-20130509' of git://git.infradead.org/linux-mtd: (83 commits)
mtd: omap2: Use module_platform_driver()
mtd: bf5xx_nand: Use module_platform_driver()
mtd: denali_dt: Remove redundant use of of_match_ptr
mtd: denali_dt: Change return value to fix smatch warning
mtd: denali_dt: Use module_platform_driver()
mtd: denali_dt: Fix incorrect error check
mtd: nand: subpage write support for hardware based ECC schemes
mtd: omap2: use msecs_to_jiffies()
mtd: nand_ids: use size macros
mtd: nand_ids: improve LEGACY_ID_NAND macro a bit
mtd: add 4 Toshiba nand chips for the full-id case
mtd: add the support to parse out the full-id nand type
mtd: add new fields to nand_flash_dev{}
mtd: sh_flctl: Use of_match_ptr() macro
mtd: gpio: Use of_match_ptr() macro
mtd: gpio: Use devm_kzalloc()
mtd: davinci_nand: Use of_match_ptr()
mtd: dataflash: Use of_match_ptr() macro
mtd: remove h720x flash support
mtd: onenand: remove OneNAND simulator
Pull slave-dmaengine updates from Vinod Koul:
"This time we have dmatest improvements from Andy along with dw_dmac
fixes. He has also done support for acpi for dmanegine.
Also we have bunch of fixes going in DT support for dmanegine for
various folks. Then Haswell and other ioat changes from Dave and
SUDMAC support from Shimoda."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits)
dma: tegra: implement suspend/resume callbacks
dma:of: Use a mutex to protect the of_dma_list
dma: of: Fix of_node reference leak
dmaengine: sirf: move driver init from module_init to subsys_initcall
sudmac: add support for SUDMAC
dma: sh: add Kconfig
at_hdmac: move to generic DMA binding
ioatdma: ioat3_alloc_sed can be static
ioatdma: Adding write back descriptor error status support for ioatdma 3.3
ioatdma: S1200 platforms ioatdma channel 2 and 3 falsely advertise RAID cap
ioatdma: Adding support for 16 src PQ ops and super extended descriptors
ioatdma: Removing hw bug workaround for CB3.x .2 and earlier
dw_dmac: add ACPI support
dmaengine: call acpi_dma_request_slave_channel as well
dma: acpi-dma: introduce ACPI DMA helpers
dma: of: Remove unnecessary list_empty check
DMA: OF: Check properties value before running be32_to_cpup() on it
DMA: of: Constant names
ioatdma: skip silicon bug workaround for pq_align for cb3.3
ioatdma: Removing PQ val disable for cb3.3
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management update from Zhang Rui:
"The most important one is to build thermal core and governor and cpu
cooling code into one module. This fixes a regression that thermal
core does not work if it is built as module, since 3.7. I'll backport
them to stable kernel once those changes are in upstream.
The largest batch is the thermal kernel-doc & coding style
updates/cleanups from Eduardo.
Highlights:
- build all thermal framework code into one module to fix a
regression that thermal does not work if it is built as module.
- Marvell Armada 370/XP thermal sensor driver
- thermal core/cpu cooling kernel-doc & coding style updates and
cleanups.
- Add Eduardo Valentin as thermal sub-maintainer, both in mailing
list and patchwork. He will help me on arm thermal drivers."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (68 commits)
thermal: db8500_cpufreq_cooling: remove usage of IS_ERR_OR_NULL()
thermal: thermal_core: remove usage of IS_ERR_OR_NULL
thermal: cpu_cooling: improve line breaking
thermal: cpu_cooling: alignment improvements
thermal: cpu_cooling: remove checkpatch.pl warning
thermal: cpu_cooling: remove trailing blank line
thermal: cpu_cooling: align on open parenthesis
thermal: cpu_cooling: standardize comment style
thermal: cpu_cooling: standardize end of function
thermal: cpu_cooling: remove trailing white spaces
Thermal: update documentation for thermal_zone_device_register
thermal: update kernel-doc for thermal_zone_device_register
thermal: update kernel-doc for create_trip_attrs
thermal: update kernel-doc for thermal_cooling_device_register
thermal: update kernel-doc for thermal_zone_unbind_cooling_device
thermal: update kernel-doc for thermal_zone_bind_cooling_device
thermal: use EXPORT_SYMBOL_GPL
thermal: rename notify_thermal_framework to thermal_notify_framework
thermal: update driver license
thermal: use strlcpy instead of strcpy
into fixes
This patch adds binding documentation for the
compatible values of the Ralink MIPS SoCs.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/5187/
Pull late ARM Exynos multiplatform changes from Arnd Bergmann:
"These continue the multiplatform support for exynos, adding support
for building most of the essential drivers (clocksource, clk, irqchip)
when combined with other platforms. As a result, it should become
really easy to add full multiplatform exynos support in 3.11, although
we don't yet enable it for 3.10.
The changes were not included in the earlier multiplatform series in
order to avoid clashes with the other Exynos updates.
This also includes work from Tomasz Figa to fix the pwm clocksource
code on Exynos, which is not strictly required for multiplatform, but
related to the other patches in this set and needed as a bug fix for
at least one board."
* tag 'multiplatform-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (22 commits)
ARM: dts: exynops4210: really add universal_c210 dts
ARM: dts: exynos4210: Add basic dts file for universal_c210 board
ARM: dts: exynos4: Add node for PWM device
ARM: SAMSUNG: Do not register legacy timer interrupts on Exynos
clocksource: samsung_pwm_timer: Work around rounding errors in clockevents core
clocksource: samsung_pwm_timer: Correct programming of clock events
clocksource: samsung_pwm_timer: Use proper clockevents max_delta
clocksource: samsung_pwm_timer: Add support for non-DT platforms
clocksource: samsung_pwm_timer: Drop unused samsung_pwm struct
clocksource: samsung_pwm_timer: Keep all driver data in a structure
clocksource: samsung_pwm_timer: Make PWM spinlock global
clocksource: samsung_pwm_timer: Let platforms select the driver
Documentation: Add device tree bindings for Samsung PWM timers
clocksource: add samsung pwm timer driver
irqchip: exynos: look up irq using irq_find_mapping
irqchip: exynos: pass irq_base from platform
irqchip: exynos: localize irq lookup for ATAGS
irqchip: exynos: allocate combiner_data dynamically
irqchip: exynos: pass max combiner number to combiner_init
ARM: exynos: add missing properties for combiner IRQs
Pull ARM SoC late cleanups from Arnd Bergmann:
"These are cleanups and smaller changes that either depend on earlier
feature branches or came in late during the development cycle. We
normally try to get all cleanups early, so these are the exceptions:
- A follow-up on the clocksource reworks, hopefully the last time we
need to merge clocksource subsystem changes through arm-soc.
A first set of patches was part of the original 3.10 arm-soc
cleanup series because of interdependencies with timer drivers now
moved out of arch/arm.
- Migrating the SPEAr13xx platform away from using auxdata for DMA
channel descriptions towards using information in device tree,
based on the earlier SPEAr multiplatform series
- A few follow-ups on the Atmel SAMA5 support and other changes for
Atmel at91 based on the larger at91 reworks.
- Moving the armada irqchip implementation to drivers/irqchip
- Several OMAP cleanups following up on the larger series already
merged in 3.10."
* tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
ARM: OMAP4: change the device names in usb_bind_phy
ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a
ARM: SPEAr: conditionalize SMP code
ARM: arch_timer: Silence debug preempt warnings
ARM: OMAP: remove unused variable
serial: amba-pl011: fix !CONFIG_DMA_ENGINE case
ata: arasan: remove the need for platform_data
ARM: at91/sama5d34ek.dts: remove not needed compatibility string
ARM: at91: dts: add MCI DMA support
ARM: at91: dts: add i2c dma support
ARM: at91: dts: set #dma-cells to the correct value
ARM: at91: suspend both memory controllers on at91sam9263
irqchip: armada-370-xp: slightly cleanup irq controller driver
irqchip: armada-370-xp: move IRQ handler to avoid forward declaration
irqchip: move IRQ driver for Armada 370/XP
ARM: mvebu: move L2 cache initialization in init_early()
devtree: add binding documentation for sp804
ARM: integrator-cp: convert use CLKSRC_OF for timer init
ARM: versatile: use OF init for sp804 timer
ARM: versatile: add versatile dtbs to dtbs target
Pull ARM SoC device tree updates (part 2) from Arnd Bergmann:
"These are mostly new device tree bindings for existing drivers, as
well as changes to the device tree source files to add support for
those devices, and a couple of new boards, most notably Samsung's
Exynos5 based Chromebook.
The changes depend on earlier platform specific updates and touch the
usual platforms: omap, exynos, tegra, mxs, mvebu and davinci."
* tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits)
ARM: exynos: dts: cros5250: add EC device
ARM: dts: Add sbs-battery for exynos5250-snow
ARM: dts: Add i2c-arbitrator bus for exynos5250-snow
ARM: dts: add mshc controller node for Exynos4x12 SoCs
ARM: dts: Add chip-id controller node on Exynos4/5 SoC
ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
ARM: davinci: da850-evm: add SPI flash support
ARM: davinci: da850: override SPI DT node device name
ARM: davinci: da850: add SPI1 DT node
spi/davinci: add DT binding documentation
spi/davinci: no wildcards in DT compatible property
ARM: dts: mvebu: Convert mvebu device tree files to 64 bits
ARM: dts: mvebu: introduce internal-regs node
ARM: dts: mvebu: Convert all the mvebu files to use the range property
ARM: dts: mvebu: move all peripherals inside soc
ARM: dts: mvebu: fix cpus section indentation
ARM: davinci: da850: add EHRPWM & ECAP DT node
ARM/dts: OMAP3: fix pinctrl-single configuration
ARM: dts: Add OMAP3430 SDP NOR flash memory binding
ARM: dts: Add NOR flash bindings for OMAP2420 H4
Pull ARM SoC platform updates (part 3) from Arnd Bergmann:
"This is the third and smallest of the SoC specific updates. Changes
include:
- SMP support for the Xilinx zynq platform
- Smaller imx changes
- LPAE support for mvebu
- Moving the orion5x, kirkwood, dove and mvebu platforms to a common
"mbus" driver for their internal devices.
It would be good to get feedback on the location of the "mbus" driver.
Since this is used on multiple platforms may potentially get shared
with other architectures (powerpc and arm64), it was moved to
drivers/bus/. We expect other similar drivers to get moved to the
same place in order to avoid creating more top-level directories under
drivers/ or cluttering up the messy drivers/misc/ even more."
* tag 'soc-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
ARM: imx: reset_controller may be disabled
ARM: mvebu: Align the internal registers virtual base to support LPAE
ARM: mvebu: Limit the DMA zone when LPAE is selected
arm: plat-orion: remove addr-map code
arm: mach-mv78xx0: convert to use the mvebu-mbus driver
arm: mach-orion5x: convert to use mvebu-mbus driver
arm: mach-dove: convert to use mvebu-mbus driver
arm: mach-kirkwood: convert to use mvebu-mbus driver
arm: mach-mvebu: convert to use mvebu-mbus driver
ARM i.MX53: set CLK_SET_RATE_PARENT flag on the tve_ext_sel clock
ARM i.MX53: tve_di clock is not part of the CCM, but of TVE
ARM i.MX53: make tve_ext_sel propagate rate change to PLL
ARM i.MX53: Remove unused tve_gate clkdev entry
ARM i.MX5: Remove tve_sel clock from i.MX53 clock tree
ARM: i.MX5: Add PATA and SRTC clocks
ARM: imx: do not bring up unavailable cores
ARM: imx: add initial imx6dl support
ARM: imx1: mm: add call to mxc_device_init
ARM: imx_v4_v5_defconfig: Add CONFIG_GPIO_SYSFS
ARM: imx_v6_v7_defconfig: Select CONFIG_PERF_EVENTS
Pull GPIO changes from Grant Likely:
"The usual selection of bug fixes and driver updates for GPIO. Nothing
really stands out except the addition of the GRGPIO driver and some
enhacements to ACPI support"
I'm pulling this despite the earlier mess. Let's hope it compiles these
days.
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: (46 commits)
gpio: grgpio: Add irq support
gpio: grgpio: Add device driver for GRGPIO cores
gpiolib-acpi: introduce acpi_get_gpio_by_index() helper
GPIO: gpio-generic: remove kfree() from bgpio_remove call
gpio / ACPI: Handle ACPI events in accordance with the spec
gpio: lpc32xx: Fix off-by-one valid range checking for bank
gpio: mcp23s08: convert driver to DT
gpio/omap: force restore if context loss is not detectable
gpio/omap: optimise interrupt service routine
gpio/omap: remove extra context restores in *_runtime_resume()
gpio/omap: free irq domain in probe() failure paths
gpio: gpio-generic: Add 16 and 32 bit big endian byte order support
gpio: samsung: Add terminating entry for exynos_pinctrl_ids
gpio: mvebu: add dbg_show function
MAX7301 GPIO: Do not force SPI speed when using OF Platform
gpio: gpio-tps65910.c: fix checkpatch error
gpio: gpio-timberdale.c: fix checkpatch error
gpio: gpio-tc3589x.c: fix checkpatch errors
gpio: gpio-stp-xway.c: fix checkpatch error
gpio: gpio-sch.c: fix checkpatch error
Pull pwm changes from Thierry Reding:
"Nothing very exciting this time around. A couple of bug fixes and a
lot of cleanup across the board. The DaVinci 8xx family of SoCs now
use the same driver as the AM33xx family.
Many thanks to Axel Lin and Jingoo Han who have done a great job
fixing various bugs and inconsistencies."
* tag 'for-3.10-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (27 commits)
pwm: lpc32xx: Don't change PWM_ENABLE bit in lpc32xx_pwm_config
pwm: lpc32xx: Properly set PWM_ENABLE bit in lpc32xx_pwm_[enable|disable]
pwm: Constify OF match tables
pwm: pwm-tiehrpwm: Update device-tree binding document
pwm: pwm-tiecap: Update device-tree binding document
pwm: puv3: Remove unused enabled filed from struct puv3_pwm_chip
pwm: pxa: Remove PWM_ID_BASE macro
pwm: spear: Remove unused *dev from struct spear_pwm_chip
pwm: mxs: Remove unused *dev from struct mxs_pwm_chip
pwm: twl: Return proper error if twl6030_pwm_enable() fails
pwm: pxa: Remove clk_enabled field from struct pxa_pwm_chip
pwm: imx: Remove enabled field from struct imx_chip
pwm: twl: Add .owner to struct pwm_ops
pwm: twl-led: Add .owner to struct pwm_ops
pwm: atmel-tcb: Add .owner to struct pwm_ops
pwm: ab8500: Add .owner to struct pwm_ops
pwm: spear: Fix checking return value of clk_enable() and clk_prepare()
pwm: tiehrpwm: Staticize non-exported symbols
pwm: tiecap: Staticize non-exported symbols
pwm: ab8500: Fix trivial typo in dev_err message
This series from Tomasz Figa restores support for the pwm clocksource
in Exynos, which was broken during the conversion of the platform
to the common clk framework. The clocksource is only used in one
board in the mainline kernel (universal_c210), and this makes it
work for DT based probing as well as restoring the non-DT based
case.
* exynos/pwm-clocksource:
arch/arm/boot/dts/Makefile
arch/arm/mach-exynos/common.c
drivers/clocksource/Kconfig
drivers/clocksource/Makefile
There is no reason to keep the clksrc cleanups separate from the
other cleanups, and this resolves some merge conflicts.
arch/arm/mach-spear/spear13xx.c
drivers/irqchip/Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next
Pull MFD update from Samuel Ortiz:
"For 3.10 we have a few new MFD drivers for:
- The ChromeOS embedded controller which provides keyboard, battery
and power management services. This controller is accessible
through i2c or SPI.
- Silicon Laboratories 476x controller, providing access to their FM
chipset and their audio codec.
- Realtek's RTS5249, a memory stick, MMC and SD/SDIO PCI based
reader.
- Nokia's Tahvo power button and watchdog device. This device is
very similar to Retu and is thus supported by the same code base.
- STMicroelectronics STMPE1801, a keyboard and GPIO controller
supported by the stmpe driver.
- ST-Ericsson AB8540 and AB8505 power management and voltage
converter controllers through the existing ab8500 code.
Some other drivers got cleaned up or improved. In particular:
- The Linaro/STE guys got the ab8500 driver in sync with their
internal code through a series of optimizations, fixes and
improvements.
- The AS3711 and OMAP USB drivers now have DT support.
- The arizona clock and interrupt handling code got improved.
- The wm5102 register patch and boot mechanism also got improved."
* tag 'mfd-3.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (104 commits)
mfd: si476x: Don't use 0bNNN
mfd: vexpress: Handle pending config transactions
mfd: ab8500: Export ab8500_gpadc_sw_hw_convert properly
mfd: si476x: Fix i2c warning
mfd: si476x: Add header files and Kbuild plumbing
mfd: si476x: Add chip properties handling code
mfd: si476x: Add the bulk of the core driver
mfd: si476x: Add commands abstraction layer
mfd: rtsx: Support RTS5249
mfd: retu: Add Tahvo support
mfd: ucb1400: Pass ucb1400-gpio data through ac97 bus
mfd: wm8994: Add some OF properties
mfd: wm8994: Add device ID data to WM8994 OF device IDs
input: Export matrix_keypad_parse_of_params()
mfd: tps65090: Add compatible string for charger subnode
mfd: db8500-prcmu: Support platform dependant device selection
mfd: syscon: Fix warnings when printing resource_size_t
of: Add stub of_get_parent for non-OF builds
mfd: omap-usb-tll: Convert to devm_ioremap_resource()
mfd: omap-usb-host: Convert to devm_ioremap_resource()
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC update from Chris Ball:
"MMC highlights for 3.10:
Core:
- Introduce MMC_CAP2_NO_PRESCAN_POWERUP to allow skipping
mmc_power_up() at boot/initialization time if it's already
happened, for performance (faster boot time) reasons.
- Fix a bit width test failure that resulted in old eMMC cards being
put into 1-bit mode when 4-bit mode was available.
- Expose fwrev/hwrev for MMCv4 parts.
- Improve card removal logic in the case where the card's removed
slowly; we were missing card removal events if the card retained
contact with the slot pads for long enough to reply to a CMD13
while being removed.
Drivers:
- davinci_mmc: Support using PIO instead of DMA.
- dw_mmc: Add support for Exynos4412.
- mxcmmc: DT support, use slot-gpio API.
- mxs-mmc: Add broken-cd/cd-inverted/non-removable DT property
support.
- sdhci-sirf: New sdhci-pltfm driver for CSR SiRF SoCs:
SiRFprimaII: unicore ARM Cortex-A9
SiRFatlas6: unicore ARM Cortex-A9
SiRFmarco: dual core ARM Cortex-A9 SMP
- sdhci-tegra: Add support for Tegra114 platforms, use
mmc_of_parse()"
* tag 'mmc-updates-for-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits)
mmc: sdhci-tegra: fix MODULE_DEVICE_TABLE
mmc: core: fix init controller performance regression, updated patch
mmc: mxcmmc: enable DMA support on mpc512x
mmc: mxcmmc: constify mxcmci_devtype
mmc: mxcmmc: use slot-gpio API for write-protect detection
mmc: mxcmmc: add mpc512x SDHC support
mmc: mxcmmc: fix race conditions for host->req and host->data access
mmc: mxcmmc: DT support
mmc: dw_mmc: let device core setup the default pin configuration
mmc: mxs-mmc: add broken-cd property
mmc: mxs-mmc: add non-removable property
mmc: mxs-mmc: add cd-inverted property
mmc: core: call pm_runtime_put_noidle in pm_runtime_get_sync failed case
mmc: mxcmmc: Fix bug when card is present during boot
mmc: core: fix performance regression initializing MMC host controllers
Revert "mmc: core: wait while adding MMC host to ensure root mounts successfully"
mmc: atmel-mci: pio hang on block errors
mmc: core: Fix bit width test failing on old eMMC cards
mmc: dw_mmc: Use pr_info instead of printk
mmc: dw_mmc: Check return value of regulator_enable
Pull ARM SoC board specific changes (part 1) from Olof Johansson:
"These changes are all for board specific files. These used to make up
a large portion of the ARM changes in the past, but as we are
generalizing the support and moving to device tree probing, this has
gotten significantly smaller.
The only platform actually adding new code here at the moment is
Renesas shmobile, as they are still busy converting their code to
device tree and have not come far enough to not need it."
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
ARM: msm: USB_MSM_OTG needs USB_PHY
ARM: davinci: da850 evm: fix const qualifier placement
ARM: davinci: da850 board: add remoteproc support
ARM: pxa: move debug uart code
ARM: pxa: select PXA935 on saar & tavorevb
ARM: mmp: add more compatible names in gpio driver
ARM: pxa: move PXA_GPIO_TO_IRQ macro
ARM: pxa: remove cpu_is_xxx in gpio driver
ARM: Kirkwood: update Network Space Mini v2 description
ARM: Kirkwood: DT board setup for CloudBox
ARM: Kirkwood: sort board entries by ASCII-code order
ARM: OMAP: board-4430sdp: Provide regulator to pwm-backlight
ARM: OMAP: zoom: Use pwm stack for lcd and keyboard backlight
ARM: OMAP2+: omap2plus_defconfig: Add support for BMP085 pressure sensor
omap2+: Remove useless Makefile line
ARM: OMAP: RX-51: add missing regulator supply definitions for lis3lv02d
ARM: OMAP1: fix omap_udc registration
ARM: davinci: use is IS_ENABLED macro
ARM: kirkwood: add MACH_GURUPLUG_DT to defconfig
Pull ARM platform specific firmware interfaces from Olof Johansson:
"Two platforms, bcm and exynos have their own firmware interfaces using
the "secure monitor call", this adds support for those.
We had originally planned to have a third set of patches in here,
which would extend support for the existing generic "psci" call that
is used on multiple platforms as well as Xen and KVM guests, but that
ended up getting dropped because the patches were not ready in time."
* tag 'firmware-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: bcm: mark bcm_kona_smc_init as __init
ARM: bcm281xx: Add DT support for SMC handler
ARM: bcm281xx: Add L2 cache enable code
ARM: EXYNOS: Add secure firmware support to secondary CPU bring-up
ARM: EXYNOS: Add IO mapping for non-secure SYSRAM.
ARM: EXYNOS: Add support for Exynos secure firmware
ARM: EXYNOS: Add support for secure monitor calls
ARM: Add interface for registering and calling firmware-specific operations
Pull ARM SoC driver changes from Olof Johansson:
"This is a rather large set of patches for device drivers that for one
reason or another the subsystem maintainer preferred to get merged
through the arm-soc tree. There are both new drivers as well as
existing drivers that are getting converted from platform-specific
code into standalone drivers using the appropriate subsystem specific
interfaces.
In particular, we can now have pinctrl, clk, clksource and irqchip
drivers in one file per driver, without the need to call into platform
specific interface, or to get called from platform specific code, as
long as all information about the hardware is provided through a
device tree.
Most of the drivers we touch this time are for clocksource. Since now
most of them are part of drivers/clocksource, I expect that we won't
have to touch these again from arm-soc and can let the clocksource
maintainers take care of these in the future.
Another larger part of this series is specific to the exynos platform,
which is seeing some significant effort in upstreaming and
modernization of its device drivers this time around, which
unfortunately is also the cause for the churn and a lot of the merge
conflicts.
There is one new subsystem that gets merged as part of this series:
the reset controller interface, which is a very simple interface for
taking devices on the SoC out of reset or back into reset. Patches to
use this interface on i.MX follow later in this merge window, and we
are going to have other platforms (at least tegra and sirf) get
converted in 3.11. This will let us get rid of platform specific
callbacks in a number of platform independent device drivers."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits)
irqchip: s3c24xx: add missing __init annotations
ARM: dts: Disable the RTC by default on exynos5
clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3}
ARM: exynos: restore mach/regs-clock.h for exynos5
clocksource: exynos_mct: fix build error on non-DT
pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register()
irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure
reset: NULL deref on allocation failure
reset: Add reset controller API
dt: describe base reset signal binding
ARM: EXYNOS: Add arm-pmu DT binding for exynos421x
ARM: EXYNOS: Add arm-pmu DT binding for exynos5250
ARM: EXYNOS: Enable PMUs for exynos4
irqchip: exynos-combiner: Correct combined IRQs for exynos4
irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq
ARM: EXYNOS: fix compilation error introduced due to common clock migration
clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3}
clk: exynos4: export clocks required for fimc-is
clk: samsung: Fix compilation error
clk: tegra: fix enum tegra114_clk to match binding
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"Mostly many small changes spread as seen in diffstat in sound/*
directory by this update. A significant change in the subsystem level
is the introduction of snd_soc_component, which will help more generic
handling of SoC and off-SoC components.
Also, snd_BUG_ON() macro is enabled unconditionally now due to its
misuses, so people might hit kernel warnings (it's a good thing for
us).
- compress-offload: support for capture by Charles Keepax
- HD-audio: codec delay support by Dylan Reid
- HD-audio: improvements/fixes in generic parser: better headphone
mic and headset mic support, jack_modes hint consolidation, proper
beep attach/detachment, generalized power filter controls by David
Henningsson, et al
- HD-audio: Improved management of HDMI codec pins/converters
- HD-audio: Better pin/DAC assignment for VIA codecs
- HD-audio: Haswell HDMI workarounds
- HD-audio: ALC268 codec support, a few new quirks for Chromebooks
- USB: regression fixes: USB-MIDI autopm fix, the recent ISO latency
fix by Clemens Ladisch
- USB: support for DSD formats by Daniel Mack
- USB: A few UAC2 device endian/cock fixes by Eldad Zack
- USB: quirks for Emu 192kHz support, Novation Twitch DJ controller,
Yamaha THRxx devices
- HDSPM: updates for TCO controls by Adrian Knoth
- ASoC: Add a snd_soc_component object type for generic handling of
SoC and off-SoC components by Kuninori Morimoto,
- dmaengine: a large set of cleanups and conversions by Lars-Peter
Clausen
- ASoC DAPM: performance optimizations from Ryo Tsutsui
- ASoC DAPM: support for mixer control sharing by Stephen Warren
- ASoC: multiplatform ARM cleanups from Arnd Bergmann
- ASoC: new codec drivers for AK5385 and TAS5086 from Daniel Mack"
* tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (315 commits)
ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatch
ALSA: asihpi: add format support check in snd_card_asihpi_capture_formats
ALSA: pcm_format_to_bits strong-typed conversion
ALSA: compress: fix the states to check for allowing read
ALSA: hda - Move Thinkpad X220 to use auto parser
ALSA: USB: adjust for changed 3.8 USB API
ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sources
sound: oss/dmabuf: use dma_map_single
ALSA: ali5451: use mdelay instead of large udelay constants
ALSA: hda - Add the support for ALC286 codec
ALSA: usb-audio: USB quirk for Yamaha THR10C
ALSA: usb-audio: USB quirk for Yamaha THR5A
ALSA: usb-audio: Fix autopm error during probing
ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINT
ALSA: sound kconfig typo
ALSA: emu10k1: Fix dock firmware loading
ASoC: ux500: forward declare msp_i2s_platform_data
ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modes
ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializers
Pull drm updates from Dave Airlie:
"This is the main drm pull request for 3.10.
Wierd bits:
- OMAP drm changes required OMAP dss changes, in drivers/video, so I
took them in here.
- one more fbcon fix for font handover
- VT switch avoidance in pm code
- scatterlist helpers for gpu drivers - have acks from akpm
Highlights:
- qxl kms driver - driver for the spice qxl virtual GPU
Nouveau:
- fermi/kepler VRAM compression
- GK110/nvf0 modesetting support.
Tegra:
- host1x core merged with 2D engine support
i915:
- vt switchless resume
- more valleyview support
- vblank fixes
- modesetting pipe config rework
radeon:
- UVD engine support
- SI chip tiling support
- GPU registers initialisation from golden values.
exynos:
- device tree changes
- fimc block support
Otherwise:
- bunches of fixes all over the place."
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (513 commits)
qxl: update to new idr interfaces.
drm/nouveau: fix build with nv50->nvc0
drm/radeon: fix handling of v6 power tables
drm/radeon: clarify family checks in pm table parsing
drm/radeon: consolidate UVD clock programming
drm/radeon: fix UPLL_REF_DIV_MASK definition
radeon: add bo tracking debugfs
drm/radeon: add new richland pci ids
drm/radeon: add some new SI PCI ids
drm/radeon: fix scratch reg handling for UVD fence
drm/radeon: allocate SA bo in the requested domain
drm/radeon: fix possible segfault when parsing pm tables
drm/radeon: fix endian bugs in atom_allocate_fb_scratch()
OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found
OMAPDSS: VENC: Add error handling for venc_probe_pdata
OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata
OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata
OMAPDSS: DSI: Add error handling for dsi_probe_pdata
OMAPDSS: SDI: Add error handling for sdi_probe_pdata
OMAPDSS: DPI: Add error handling for dpi_probe_pdata
Pull crypto update from Herbert Xu:
- XTS mode optimisation for twofish/cast6/camellia/aes on x86
- AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia
- SSSE3/AVX/AVX2 optimisations for sha256/sha512
- Added driver for SAHARA2 crypto accelerator
- Fix for GMAC when used in non-IPsec secnarios
- Added generic CMAC implementation (including IPsec glue)
- IP update for crypto/atmel
- Support for more than one device in hwrng/timeriomem
- Added Broadcom BCM2835 RNG driver
- Misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits)
crypto: caam - fix job ring cleanup code
crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher
crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher
crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher
crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher
crypto: tcrypt - add async cipher speed tests for blowfish
crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2
crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86
crypto: aesni_intel - add more optimized XTS mode for x86-64
crypto: x86/camellia-aesni-avx - add more optimized XTS code
crypto: cast6-avx: use new optimized XTS code
crypto: x86/twofish-avx - use optimized XTS code
crypto: x86 - add more optimized XTS-mode for serpent-avx
xfrm: add rfc4494 AES-CMAC-96 support
crypto: add CMAC support to CryptoAPI
crypto: testmgr - add empty test vectors for null ciphers
crypto: testmgr - add AES GMAC test vectors
crypto: gcm - fix rfc4543 to handle async crypto correctly
crypto: gcm - make GMAC work when dst and src are different
hwrng: timeriomem - added devicetree hooks
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c changes from Wolfram Sang:
- an arbitration driver. While the driver is quite simple, it caused
discussion if we need additional arbitration on top of the one
specified in the I2C standard. Conclusion is that I accept a few
generic mechanisms, but not very specific ones.
- the core lost the detach_adapter() call. It has no users anymore and
was in the way for other cleanups. attach_adapter() is sadly still
there since there are users waiting to be converted.
- the core gained a bus recovery infrastructure. I2C defines a way to
recover if the data line is stalled. This mechanism is now in the
core and drivers can now pass some data to make use of it.
- bigger driver cleanups for designware, s3c2410
- removing superfluous refcounting from drivers
- removing Ben Dooks as second maintainer due to inactivity. Thanks
for all your work so far, Ben!
- bugfixes, feature additions, devicetree fixups, simplifications...
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: xiic: must always write 16-bit words to TX_FIFO
i2c: octeon: use HZ in timeout value
i2c: octeon: Fix i2c fail problem when a process is terminated by a signal
i2c: designware-pci: drop superfluous {get|put}_device
i2c: designware-plat: drop superfluous {get|put}_device
i2c: davinci: drop superfluous {get|put}_device
MAINTAINERS: Ben Dooks is inactive regarding I2C
i2c: mux: Add i2c-arb-gpio-challenge 'mux' driver
i2c: at91: convert to dma_request_slave_channel_compat()
i2c: mxs: do error checking and handling in PIO mode
i2c: mxs: remove races in PIO code
i2c-designware: switch to use runtime PM autosuspend
i2c-designware: use usleep_range() in the busy-loop
i2c-designware: enable/disable the controller properly
i2c-designware: use dynamic adapter numbering on Lynxpoint
i2c-designware-pci: use managed functions pcim_* and devm_*
i2c-designware-pci: use dev_err() instead of printk()
i2c-designware: move to managed functions (devm_*)
i2c: remove CONFIG_HOTPLUG ifdefs
i2c: s3c2410: Add SMBus emulation for block read
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlights this time around are:
- A pile of addition POWER8 bits and nits, such as updated
performance counter support (Michael Ellerman), new branch history
buffer support (Anshuman Khandual), base support for the new PCI
host bridge when not using the hypervisor (Gavin Shan) and other
random related bits and fixes from various contributors.
- Some rework of our page table format by Aneesh Kumar which fixes a
thing or two and paves the way for THP support. THP itself will
not make it this time around however.
- More Freescale updates, including Altivec support on the new e6500
cores, new PCI controller support, and a pile of new boards support
and updates.
- The usual batch of trivial cleanups & fixes"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
powerpc: Fix build error for book3e
powerpc: Context switch the new EBB SPRs
powerpc: Turn on the EBB H/FSCR bits
powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S
powerpc: Setup BHRB instructions facility in HFSCR for POWER8
powerpc: Fix interrupt range check on debug exception
powerpc: Update tlbie/tlbiel as per ISA doc
powerpc: Print page size info during boot
powerpc: print both base and actual page size on hash failure
powerpc: Fix hpte_decode to use the correct decoding for page sizes
powerpc: Decode the pte-lp-encoding bits correctly.
powerpc: Use encode avpn where we need only avpn values
powerpc: Reduce PTE table memory wastage
powerpc: Move the pte free routines from common header
powerpc: Reduce the PTE_INDEX_SIZE
powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format
powerpc: New hugepage directory format
powerpc: Don't truncate pgd_index wrongly
powerpc: Don't hard code the size of pte page
powerpc: Save DAR and DSISR in pt_regs on MCE
Pull ARM SoC platform updates from Olof Johansson:
"This branch contains part 1 of the platform updates for 3.10. Among
the highlights:
- Support for the new Atmel Cortex-A5 based platforms (SAMA5D3)
- New support for CSR SiRFatlas6 SoCs
- A handful of updates for NVidia T114 (a.k.a. Tegra 4)
- A bunch of updates for the shmobile platforms
- A handful of updates for davinci
- A few updates for Qualcomm MSM
- Plus a handful of other patches, defconfig updates, etc."
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits)
ARM: tegra: pm: fix build error w/o PM_SLEEP
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries
ARM: socfpga: Add clock entries into device tree
ARM: socfpga: Enable soft reset
ARM: EXYNOS: replace cpumask by the corresponding macro
ARM: EXYNOS: handle properly the return values
ARM: EXYNOS: factor out the idle states
ARM: OMAP4: Enable fix for Cortex-A9 erratas
ARM: OMAP2+: Export SoC information to userspace
ARM: OMAP2+: SoC name and revision unification
ARM: OMAP2+: Move common part of late init into common function
ARM: tegra: pm: remove duplicated include from pm.c
ARM: davinci: da850: override mmc DT node device name
ARM: davinci: da850: add mmc DT entries
mmc: davinci_mmc: add DT support
ARM: SAMSUNG: check processor type before cache restoration in resume
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
Pull ARM SoC cleanup from Olof Johansson:
"Here is a collection of cleanup patches. Among the pieces that stand
out are:
- The deletion of h720x platforms
- Split of at91 non-dt platforms to their own Kconfig file to keep
them separate
- General cleanups and refactoring of i.MX and MXS platforms
- Some restructuring of clock tables for OMAP
- Convertion of PMC driver for Tegra to dt-only
- Some renames of sunxi -> sun4i (Allwinner A10)
- ... plus a bunch of other stuff that I haven't mentioned"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: i.MX: remove unused ARCH_* configs
ARM i.MX53: remove platform ahci support
ARM: sunxi: Rework the restart code
irqchip: sunxi: Rename sunxi to sun4i
irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro
clocksource: sunxi: Rename sunxi to sun4i
clocksource: sunxi: make use of CLKSRC_OF
clocksource: sunxi: Cleanup the timer code
ARM: at91: remove trailing semicolon from macros
ARM: at91/setup: fix trivial typos
ARM: EXYNOS: remove "config EXYNOS_DEV_DRM"
ARM: EXYNOS: change the name of USB ohci header
ARM: SAMSUNG: Remove unnecessary code for dma
ARM: S3C24XX: Remove unused GPIO drive strength register definitions
ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412
ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410
ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards
ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC"
ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI"
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Assorted fixes and cleanups to the existing drivers plus a new driver
for IMS Passenger Control Unit device they use for ther in-flight
entertainment system."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (44 commits)
Input: trackpoint - Optimize trackpoint init to use power-on reset
Input: apbps2 - convert to devm_ioremap_resource()
Input: ALPS - use %ph to print buffers
ARM - shmobile: Armadillo800EVA: Move st1232 reset pin handling
Input: st1232 - add reset pin handling
Input: st1232 - convert to devm_* infrastructure
Input: MT - handle semi-mt devices in core
Input: adxl34x - use spi_get_drvdata()
Input: ad7877 - use spi_get_drvdata() and spi_set_drvdata()
Input: ads7846 - use spi_get_drvdata() and spi_set_drvdata()
Input: ims-pcu - fix a memory leak on error
Input: sysrq - supplement reset sequence with timeout functionality
Input: tegra-kbc - support for defining row/columns based on SoC
Input: imx_keypad - switch to using managed resources
Input: arc_ps2 - add support for device tree
Input: mma8450 - fix signed 12bits to 32bits conversion
Input: eeti_ts - remove redundant null check
Input: edt-ft5x06 - remove redundant null check before kfree
Input: ad714x - add CONFIG_PM_SLEEP to suspend/resume functions
Input: adxl34x - add CONFIG_PM_SLEEP to suspend/resume functions
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem update from James Morris:
"Just some minor updates across the subsystem"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
ima: eliminate passing d_name.name to process_measurement()
TPM: Retry SaveState command in suspend path
tpm/tpm_i2c_infineon: Add small comment about return value of __i2c_transfer
tpm/tpm_i2c_infineon.c: Add OF attributes type and name to the of_device_id table entries
tpm_i2c_stm_st33: Remove duplicate inclusion of header files
tpm: Add support for new Infineon I2C TPM (SLB 9645 TT 1.2 I2C)
char/tpm: Convert struct i2c_msg initialization to C99 format
drivers/char/tpm/tpm_ppi: use strlcpy instead of strncpy
tpm/tpm_i2c_stm_st33: formatting and white space changes
Smack: include magic.h in smackfs.c
selinux: make security_sb_clone_mnt_opts return an error on context mismatch
seccomp: allow BPF_XOR based ALU instructions.
Fix NULL pointer dereference in smack_inode_unlink() and smack_inode_rmdir()
Smack: add support for modification of existing rules
smack: SMACK_MAGIC to include/uapi/linux/magic.h
Smack: add missing support for transmute bit in smack_str_from_perm()
Smack: prevent revoke-subject from failing when unseen label is written to it
tomoyo: use DEFINE_SRCU() to define tomoyo_ss
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
Pull libata update from Jeff Garzik:
- More ACPI fixes, cleanups
- Minor cleanups for sata_highbank, pata_at32, pata_octeon_cf,
sata_rcar
- pata_legacy: small bug found in opti chipset code (untested fix, due
to ancient h/w)
- sata_fsl: RX water mark config knob, some h/w needs it
- pata_imx: cleanups, DeviceTree support
- SCSI<->ATA translator: properly export translator version, not device
firmware version
* tag 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
sata_highbank: Rename proc_name to the module name
ACPI/libata: Restore libata.noacpi support
[libata] acpi: make ata_ap_acpi_handle not block
[libata] SCSI: really use SATL version in VPD
pata_imx: add devicetree support
pata_imx: use void __iomem * for regs
pata_imx: cleanup error path
pata_imx: Use devm_clk_get
sata_rcar: Convert to devm_ioremap_resource()
fsl/sata: create a sysfs entry for rx water mark
libata-acpi: remove redundent code for power resource handling
sata_highbank: make ahci_highbank_pm_ops static
pata_octeon_cf: Use resource_size function
pata_legacy: bogus clock in opti82c46x_set_piomode()
pata_at32: use module_platform_driver_probe()
Pull power management and ACPI updates from Rafael J Wysocki:
- ARM big.LITTLE cpufreq driver from Viresh Kumar.
- exynos5440 cpufreq driver from Amit Daniel Kachhap.
- cpufreq core cleanup and code consolidation from Viresh Kumar and
Stratos Karafotis.
- cpufreq scalability improvement from Nathan Zimmer.
- AMD "frequency sensitivity feedback" powersave bias for the ondemand
cpufreq governor from Jacob Shin.
- cpuidle code consolidation and cleanups from Daniel Lezcano.
- ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano.
- ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv
Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto.
- ACPI core updates related to hotplug from Toshi Kani, Paul Bolle,
Yasuaki Ishimatsu, and Rafael J Wysocki.
- Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from
Rafael J Wysocki and Andy Shevchenko.
* tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits)
cpufreq: Revert incorrect commit 5800043
cpufreq: MAINTAINERS: Add co-maintainer
cpuidle: add maintainer entry
ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points
ARM: s3c64xx: cpuidle: use init/exit common routine
cpufreq: pxa2xx: initialize variables
ACPI: video: correct acpi_video_bus_add error processing
SH: cpuidle: use init/exit common routine
ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y
ACPI: Fix wrong parameter passed to memblock_reserve
cpuidle: fix comment format
pnp: use %*phC to dump small buffers
isapnp: remove debug leftovers
ARM: imx: cpuidle: use init/exit common routine
ARM: davinci: cpuidle: use init/exit common routine
ARM: kirkwood: cpuidle: use init/exit common routine
ARM: calxeda: cpuidle: use init/exit common routine
ARM: tegra: cpuidle: use init/exit common routine for tegra3
ARM: tegra: cpuidle: use init/exit common routine for tegra2
ARM: OMAP4: cpuidle: use init/exit common routine
Pull battery updates from Anton Vorontsov:
"Highlights:
- OpenFirmware/DeviceTree support for the Power Supply core: the core
now automatically populates supplied_from hierarchy from the device
tree. With these patches chargers and batteries can now lookup
each other without the board files support shim. Rhyland Klein at
NVIDIA did the work
- New ST-Ericsson ABX500 hwmon driver. The driver is heavily using
the AB85xx core and depends on some recent changes to it, so that
is why the driver comes through the battery tree. It has an
appropriate ack from the hwmon maintainer (i.e. Guenter Roeck).
Martin Persson at ST-Ericsson and Hongbo Zhang at Linaro authored
the driver
- Final bits to sync AB85xx ST-Ericsson changes into mainline. The
changes touch mfd parts, but these were acked by the appropriate
MFD maintainer (ie Samuel Ortiz). Lee Jones at Linaro did most of
the work and lead the submission process.
Minor changes, but still worth mentioning:
- Battery temperature reporting fix for Nokia N900 phones
- Versatile Express poweroff driver moved into drivers/power/reset/
- Tree-wide: use devm_kzalloc() where appropriate
- Tree-wide: dev_pm_ops cleanups/fixes"
* tag 'for-v3.10' of git://git.infradead.org/battery-2.6: (112 commits)
pm2301-charger: Fix suspend/resume
charger-manager: Use kmemdup instead of kzalloc + memcpy
power_supply: Populate supplied_from hierarchy from the device tree
power_supply: Add core support for supplied_from
power_supply: Define Binding for power-supplies
rx51_battery: Fix reporting temperature
hwmon: Add ST-Ericsson ABX500 hwmon driver
ab8500_bmdata: Export abx500_res_to_temp tables for hwmon
ab8500_{bmdata,fg}: Add const attributes to some data arrays
ab8500_bmdata: Eliminate CamelCase warning of some variables
ab8500_btemp: Make ab8500_btemp_get* interfaces public
goldfish_battery: Use resource_size()
lp8788-charger: Use PAGE_SIZE for the sysfs read operation
max8925_power: Use devm_kzalloc()
da9030_battery: Use devm_kzalloc()
da9052-battery: Use devm_kzalloc()
ds2760_battery: Use devm_kzalloc()
ds2780_battery: Use devm_kzalloc()
gpio-charger: Use devm_kzalloc()
isp1704_charger: Use devm_kzalloc()
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media update from Mauro Carvalho Chehab:
- OF documentation and patches at core and drivers, to be used by for
embedded media systems
- some I2C drivers used on go7007 were rewritten/promoted from staging:
sony-btf-mpx, tw2804, tw9903, tw9906, wis-ov7640, wis-uda1342
- add fimc-is driver (Exynos)
- add a new radio driver: radio-si476x
- add a two new tuners: r820t and tuner_it913x
- split camera code on em28xx driver and add more models
- the cypress firmware load is used outside dvb usb drivers. So, move
it to a common directory to make easier to re-use it
- siano media driver updated to work with sms2270 devices
- several work done in order to promote go7007 and solo6x1x out of
staging (still, there are some pending issues)
- several API compliance fixes at v4l2 drivers that don't behave as
expected
- as usual, lots of driver fixes, improvements, cleanups and new device
addition at the existing drivers.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (831 commits)
[media] cx88: make core less verbose
[media] em28xx: fix oops at em28xx_dvb_bus_ctrl()
[media] s5c73m3: fix indentation of the help section in Kconfig
[media] cx25821-alsa: get rid of a __must_check warning
[media] cx25821-video: declare cx25821_vidioc_s_std as static
[media] cx25821-video: remove maxw from cx25821_vidioc_try_fmt_vid_cap
[media] r820t: Remove a warning for an unused value
[media] dib0090: Fix a warning at dib0090_set_EFUSE
[media] dib8000: fix a warning
[media] dib8000: Fix sub-channel range
[media] dib8000: store dtv_property_cache in a temp var
[media] dib8000: warning fix: declare internal functions as static
[media] r820t: quiet gcc warning on n_ring
[media] r820t: memory leak in release()
[media] r820t: precendence bug in r820t_xtal_check()
[media] videodev2.h: Remove the unused old V4L1 buffer types
[media] anysee: Grammar s/report the/report to/
[media] anysee: Initialize ret = 0 in anysee_frontend_attach()
[media] media: videobuf2: fix the length check for mmap
[media] em28xx: save isoc endpoint number for DVB only if endpoint has alt settings with xMaxPacketSize != 0
Pull trivial tree updates from Jiri Kosina:
"Usual stuff, mostly comment fixes, typo fixes, printk fixes and small
code cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits)
mm: Convert print_symbol to %pSR
gfs2: Convert print_symbol to %pSR
m32r: Convert print_symbol to %pSR
iostats.txt: add easy-to-find description for field 6
x86 cmpxchg.h: fix wrong comment
treewide: Fix typo in printk and comments
doc: devicetree: Fix various typos
docbook: fix 8250 naming in device-drivers
pata_pdc2027x: Fix compiler warning
treewide: Fix typo in printks
mei: Fix comments in drivers/misc/mei
treewide: Fix typos in kernel messages
pm44xx: Fix comment for "CONFIG_CPU_IDLE"
doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP"
mmzone: correct "pags" to "pages" in comment.
kernel-parameters: remove outdated 'noresidual' parameter
Remove spurious _H suffixes from ifdef comments
sound: Remove stray pluses from Kconfig file
radio-shark: Fix printk "CONFIG_LED_CLASS"
doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE
The GPMC timing properties for device-tree have been updated
by adding a "-ns" or "-ps" suffix to indicate the units of
time the property represents. Therefore, update the timing
property names for TI GPMC NAND example.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
property names for TI GPMC ethernet binding.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Update at_hdmac driver to support generic DMA device tree binding. Devices
can still request channel with dma_request_channel() then it doesn't break
DMA for non DT boards.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Merge second batch of fixes from Andrew Morton:
- various misc bits
- some printk updates
- a new "SRAM" driver.
- MAINTAINERS updates
- the backlight driver queue
- checkpatch updates
- a few init/ changes
- a huge number of drivers/rtc changes
- fatfs updates
- some lib/idr.c work
- some renaming of the random driver interfaces
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (285 commits)
net: rename random32 to prandom
net/core: remove duplicate statements by do-while loop
net/core: rename random32() to prandom_u32()
net/netfilter: rename random32() to prandom_u32()
net/sched: rename random32() to prandom_u32()
net/sunrpc: rename random32() to prandom_u32()
scsi: rename random32() to prandom_u32()
lguest: rename random32() to prandom_u32()
uwb: rename random32() to prandom_u32()
video/uvesafb: rename random32() to prandom_u32()
mmc: rename random32() to prandom_u32()
drbd: rename random32() to prandom_u32()
kernel/: rename random32() to prandom_u32()
mm/: rename random32() to prandom_u32()
lib/: rename random32() to prandom_u32()
x86: rename random32() to prandom_u32()
x86: pageattr-test: remove srandom32 call
uuid: use prandom_bytes()
raid6test: use prandom_bytes()
sctp: convert sctp_assoc_set_id() to use idr_alloc_cyclic()
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Signed-off-by: Matus Ujhelyi <matus.ujhelyi@streamunlimited.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Enable supporting the DT structure of LP855x family devices. If the
platform data is NULL, the driver tries to parse a DT structure. Then,
the platform data is copied from the DT. Documentation is added as well.
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
