path: root/Documentation/devicetree/bindings/pci
2013-08-12PCI: exynos: Split into Synopsys part and Exynos partJingoo Han
Exynos PCIe IP consists of Synopsys specific part and Exynos specific part. Only core block is a Synopsys Designware part; other parts are Exynos specific. Also, the Synopsys Designware part can be shared with other platforms; thus, it can be split two parts such as Synopsys Designware part and Exynos specific part. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Pratyush Anand <pratyush.anand@st.com> Cc: Mohit KUMAR <Mohit.KUMAR@st.com>
2013-06-26pci: Add PCIe driver for Samsung ExynosJingoo Han
Exynos5440 has a PCIe controller which can be used as Root Complex. This driver supports a PCIe controller as Root Complex mode. Signed-off-by: Surendranath Gurivireddy Balla <suren.reddy@samsung.com> Signed-off-by: Siva Reddy Kallam <siva.kallam@samsung.com> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Pratyush Anand <pratyush.anand@st.com> Cc: Mohit KUMAR <Mohit.KUMAR@st.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-20Merge tag 'integrator-pci-for-arm-soc' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into next/soc From Linus Walleij: This is a patch series that: - Pulls the Integrator/AP PCI bridge driver into one file - Adds full device tree support for it - Keeps ATAG support around for the time being * tag 'integrator-pci-for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator: ARM: integrator: basic PCIv3 device tree support ARM: integrator: move static ioremapping into PCIv3 driver ARM: integrator: move VGA base assignment ARM: integrator: remap PCIv3 base dynamically ARM: integrator: move V3 register definitions into driver ARM: integrator: move PCI base address grab to probe ARM: integrator: grab PCI error IRQ in probe() ARM: integrator: convert PCIv3 bridge to platform device ARM: integrator: merge PCIv3 driver into one file ARM: pci: create pci_common_init_dev() Documentation/devicetree: add a small note on PCI Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-15ARM: integrator: basic PCIv3 device tree supportLinus Walleij
This registers the memory ranges for I/O, non-prefetched and prefetched memory and configuration space for the PCIv3 bridge and let us fetch these basic memory resources from the device tree in the device tree boot path. Remove the stepping stone platform device. This is an either/or approach - the platform data path is mutually exclusive to the plain platform data path and provided addresses from the device tree have to be correct. This adds the interrupt-map property to the PCIv3 DTS file and makes the bridge obtain mappings from the device tree. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-03Documentation/devicetree: add a small note on PCILinus Walleij
Throw in a file with references to the IEEE binding documents. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-27pci: mvebu: enable driver usage on KirkwoodThomas Petazzoni
We allow the pci-mvebu driver to be compiled on the Kirkwood platform, and add the 'marvell,kirkwood-pcie' as a compatible string supported by the driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-20pci: PCIe driver for Marvell Armada 370/XP systemsThomas Petazzoni
This driver implements the support for the PCIe interfaces on the Marvell Armada 370/XP ARM SoCs. In the future, it might be extended to cover earlier families of Marvell SoCs, such as Dove, Orion and Kirkwood. The driver implements the hw_pci operations needed by the core ARM PCI code to setup PCI devices and get their corresponding IRQs, and the pci_ops operations that are used by the PCI core to read/write the configuration space of PCI devices. Since the PCIe interfaces of Marvell SoCs are completely separate and not linked together in a bus, this driver sets up an emulated PCI host bridge, with one PCI-to-PCI bridge as child for each hardware PCIe interface. In addition, this driver enumerates the different PCIe slots, and for those having a device plugged in, it sets up the necessary address decoding windows, using the mvebu-mbus driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2011-01-31dt: Move device tree documentation out of powerpc directoryGrant Likely
The device tree is used by more than just PowerPC. Make the documentation directory available to all. v2: reorganized files while moving to create arch and driver specific directories. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
