Adding documentation for adgs1408/1409 multiplexer. The bindings
follow the standard SPI and mux bindings and do not require any
additional custom properties.
Signed-off-by: Mircea Caprioru <mircea.caprioru@analog.com>
Reviewed-by: Rob Herring <robh@kernel.org>
[peda: reword idle-state to non-array for singular mux controller]
Signed-off-by: Peter Rosin <peda@axentia.se>
This adds device tree binding documentation for mmio-based syscon
multiplexers controlled by a bitfields in a syscon register range.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Rob Herring <robh@kernel.org>
Analog Devices ADG792A/G is a triple 4:1 mux.
Acked-by: Jonathan Cameron <jic23@kernel.org>
Allow specifying that a single multiplexer controller can be used to
control several parallel multiplexers, thus enabling sharing of the
multiplexer controller by different consumers.
Add a binding for a first mux controller in the form of a GPIO based mux
controller.
