This is a quite large renaming to consolidate display related bindings
into a single "display" directory from various scattered locations of
video, drm, gpu, fb, mipi, and panel. The prior location was somewhat
based on the Linux driver location, but bindings should be independent
of that.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
The dsi host looks for the connected panel node by parsing for a child
named 'panel'. This hierarchy isn't very flexible. The connected
panel is forced to be a child to the dsi host, and hence, a mipi dsi
device. This isn't suitable for dsi devices that don't use mipi dsi
as their control bus.
Follow the of_graph approach of creating ports and endpoints to
represent the connections between the dsi host and the panel connected
to it. In our case, the dsi host will only have one output port, linked
to the panel's input port.
Update DT binding documentation with device graph usage info.
v3:
- Fix return value checks of of_graph_* calls.
- Don't make port a mandatory DT property
- Fix defer check when no panel node specified
- Rename parse_dt func to align with other dsi_host funcs
Reviewed-by: Hai Li <hali@codeaurora.org>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
For all of these devices, msm89xy was the lead chip, so standardize the
compatible names to align with convention used by rest of the qcom/msm
drivers.
This change adds the MDP and HDMI support for msm8x94.
Note that HDMI PHY registers are not being accessed anymore from
the driver.
Signed-off-by: Stephane Viau <sviau@codeaurora.org>
[rename compatible s/8x94/8994/ since preference is to not trust the
marketing folks who invent chip #'s but instead name things after the
lead chip.. we should rename some 80XY to 89XY to standardize on the
lead chip but leave that for another patch. Also, update dt bindings
doc]
DSI controller on msm8x94 is version 1.3, which requires different
power supplies and works with 20nm DSI PHY. This change is to add
the basic support for this version.
Signed-off-by: Hai Li <hali@codeaurora.org>
Some targets use pinctrl framework to configure some
pins. This change allows DSI driver to set default and
sleep pinctrl status.
The current term of *dual panel* in DSI driver code causes confusion.
It is supposed to indicate the panel using two DSI links. Rename it
to *dual DSI*.
The parallel-display driver used an undocumented, non-standard property
"fsl,panel" to optionally associate with a drm_panel device. This patch
fixes the driver to use the same OF graph bindings as the LDB driver
instead:
parallel-display {
compatible = "fsl,imx-parallel-display";
port@1 {
reg = <1>;
parallel_out: endpoint {
remote_endpoint = <&panel_in>;
panel {
port {
panel_in: endpoint {
remote-endpoint = <¶llel_out>;
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Tested-by: Gary Bisson <gary.bisson@boundarydevices.com>
Some targets (eg: msm8994) use the pinctrl framework to configure
interface pins. This change adds support for initialization and
pinctrl active/sleep state control for the HDMI driver.
There are different types of PHY from one chipset to another, while
the DSI host controller is relatively consistent across platforms.
Also, the PLL inside PHY is providing the source of DSI byte and
pixel clocks, which are used by DSI host controller. Separated devices
for clock provider and clock consumer make DSI driver better fit into
common clock framework.
Add support for an external compontised DRM encoder. The external
encoder can be connected to tilcdc trough device tree graph binding.
The binding document for tilcdc has been updated. The current
implementation supports only tda998x encoder.
To be able to filter out the unsupported video modes the tilcdc driver
needs to hijack the external connectors helper functions. The tilcdc
installes new helper functions that are otherwise identical to
orignals, but the mode_valid() call-back check the mode first localy,
before calling the original call-back. The tilcdc dirver restores the
original helper functions before it is unbound from the external
device.
I got the idea and some lines of code from Jean-Francois Moine's
"drm/tilcdc: Change the interface with the tda998x driver"-patch.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Remove tilcdc slave support for tda998x driver. The tilcdc slave
support would conflicts with componentized use of tda998x.
This patch allows to optionally attach the lvds-channel to a panel
supported by a drm_panel driver using of-graph bindings, instead of
supplying the modes via display-timings in the device tree.
This depends on of_graph_get_port_by_id and uses the OF graph to
link the optional DRM panel to the LDB lvds-channel. The output
port number is 1 on devices without the 4-port input multiplexer
(i.MX5) and 4 on devices with the mux (i.MX6).
Before:
ldb {
lvds-channel@0 {
display-timings {
native-timing = <&timing1>;
timing1: etm0700g0dh6 {
hactive = <800>;
vactive = <480>;
clock-frequency = <33260000>;
hsync-len = <128>;
hback-porch = <88>;
hfront-porch = <40>;
vsync-len = <2>;
vback-porch = <33>;
vfront-porch = <10>;
hsync-active = <0>;
vsync-active = <0>;
After:
ldb {
lvds-channel@0 {
port@4 {
reg = <4>;
lvds_out: endpoint {
panel {
compatible = "edt,etm0700g0dh6", "simple-panel";
port {
remote-endpoint = <&lvds_out>;
[Fixed build error due to missing select on DRM_PANEL --rmk]
In the same idea mdp5_cfg was added, this change allows us to quickly
add new instances, such as apq8084's HDMI in this case.
This change add the regulator/clock configuration for MDP5 v1.3.
This config is close to the one already existing for 8x74, except
that one more regulator is needed (hpd-5v-en).
Move drm/bridge documentation to video/bridge.
Also, add proper documentation for gpios used by ptn3460.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Acked-by: Inki Dae <inki.dae@samsung.com>
Tested-by: Rahul Sharma <rahul.sharma@samsung.com>
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Tested-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Tested-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add drm_panel calls to the driver to make the panel and
bridge work together in tandem.
The Atmel HLCDC (HLCD Controller) IP available on some Atmel SoCs (i.e.
at91sam9n12, at91sam9x5 family or sama5d3 family) provides a display
controller device.
The HLCDC block provides a single RGB output port, and only supports LCD
panels connection to LCD panels for now.
The atmel,panel property link the HLCDC RGB output with the LCD panel
connected on this port (note that the HLCDC RGB connector implementation
makes use of the DRM panel framework).
Connection to other external devices (DRM bridges) might be added later by
mean of a new atmel,xxx (atmel,bridge) property.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
The imx-drm driver was put into staging mostly for the following reasons,
all of which have been addressed or superseded:
- convert the irq driver to use linear irq domains
- work out the device tree bindings, this lead to the common of_graph
bindings being used
- factor out common helper functions, this mostly resulted in the
component framework and drm of_graph helpers.
Before adding new fixes, and certainly before adding new features,
move it into its proper place below drivers/gpu/drm.
In order to support the "enable GPIO" available in many panel devices,
this commit adds a proper devicetree binding.
By providing an enable GPIO in the devicetree, the driver can now turn
off and on the panel device, and/or the backlight device. Both the
backlight and the GPIO are optional properties.
Tested-by: Darren Etheridge <detheridge@ti.com>
Tested-by: Johannes Pointner <johannes.pointner@br-automation.com>
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
The current backlight support is broken; the driver expects a backlight-class
in the panel devicetree node. Fix this by implementing it properly, getting
an optional backlight from a phandle.
This shouldn't cause any backward-compatibility DT issue because the current
implementation doesn't work and is not even documented.
into drm-next
This builds upon the previous set of fixes which were pulled on 6th July.
Included in this set are:
- an update from Jean-Francois to add the missing reg documentation entry
to the device tree documentation.
- conversion of the tda998x driver to the component helpers.
* 'tda998x-devel' of git://ftp.arm.linux.org.uk/~rmk/linux-cubox:
drm/i2c: tda998x: add component support
drm/i2c: tda998x: allow re-use of tda998x support code
drm/i2c: tda998x: fix lack of required reg in DT documentation
drivers/gpu/drm/i2c/tda998x_drv.c
Now that we (almost) have enough dependencies in place (MMCC, RPM, etc),
add necessary DT support so that we can use drm/msm on upstream kernel.
v2: update for review comments
v3: rebase on component helper changes
Add the Marvell Dove LCD controller DT binding documentation. The
clock names used here are intentionally taken from the specification
for the Dove SoC.
The I2C address (reg) is required for the TDA998x driver to be loaded
and initialized.
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
This patch adds a drm_bridge driver for the PTN3460 DisplayPort to LVDS
bridge chip.
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Adding support for max-pixelclock and max-width device tree
entries. As some devices that use the tilcdc hardware module
have restrictions on the allowed/tested values. Also update DT
bindings document to reflect new parameters.
Signed-off-by: Darren Etheridge <detheridge@ti.com>
Acked-by: Rob Clark <robdclark@gmail.com>
Pull device tree fixes from Grant Likely:
"Device tree bug fixes and documentation updates for v3.10
Nothing earth shattering here. A build failure fix, and fix for
releasing nodes and some documenation updates."
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
Documentation/devicetree: make semantic of initrd-end more explicit
of/base: release the node correctly in of_parse_phandle_with_args()
of/documentation: move video device bindings to a common place
<linux/of_platform.h>: fix compilation warnings with DT disabled
This reverts commit 09495dda6a62c74b13412a63528093910ef80edd.
The description is incomplete and the location of this file
is incorrect. Based on discussion with the Samsung media and DRM subsystem
maintainers, the documentaion of Samsung G2D bindings has been placed at:
Documentation/devicetree/bindings/gpu/samsung-g2d.txt
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Binding Documents for drm-devices are placed in
Documentation/devicetree/bindings/drm/*. But these devices are common
for v4l framework, hence moved to a common place at
Documentation/devicetree/bindings/video/. 'exynos_' prefix is added to
associate them with exynos soc series.
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
Pull drm merge from Dave Airlie:
"Highlights:
- TI LCD controller KMS driver
- TI OMAP KMS driver merged from staging
- drop gma500 stub driver
- the fbcon locking fixes
- the vgacon dirty like zebra fix.
- open firmware videomode and hdmi common code helpers
- major locking rework for kms object handling - pageflip/cursor
won't block on polling anymore!
- fbcon helper and prime helper cleanups
- i915: all over the map, haswell power well enhancements, valleyview
macro horrors cleaned up, killing lots of legacy GTT code,
- radeon: CS ioctl unification, deprecated UMS support, gpu reset
rework, VM fixes
- nouveau: reworked thermal code, external dp/tmds encoder support
(anx9805), fences sleep instead of polling,
- exynos: all over the driver fixes."
Lovely conflict in radeon/evergreen_cs.c between commit de0babd60d8d
("drm/radeon: enforce use of radeon_get_ib_value when reading user cmd")
and the new changes that modified that evergreen_dma_cs_parse()
function.
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (508 commits)
drm/tilcdc: only build on arm
drm/i915: Revert hdmi HDP pin checks
drm/tegra: Add list of framebuffers to debugfs
drm/tegra: Fix color expansion
drm/tegra: Split DC_CMD_STATE_CONTROL register write
drm/tegra: Implement page-flipping support
drm/tegra: Implement VBLANK support
drm/tegra: Implement .mode_set_base()
drm/tegra: Add plane support
drm/tegra: Remove bogus tegra_framebuffer structure
drm: Add consistency check for page-flipping
drm/radeon: Use generic HDMI infoframe helpers
drm/tegra: Use generic HDMI infoframe helpers
drm: Add EDID helper documentation
drm: Add HDMI infoframe helpers
video: Add generic HDMI infoframe helpers
drm: Add some missing forward declarations
drm: Move mode tables to drm_edid.c
drm: Remove duplicate drm_mode_cea_vic()
gma500: Fix n, m1 and m2 clock limits for sdvo and lvds
Add an output panel driver for LCD panels. Tested with LCD3 cape on
beaglebone.
v1: original
v2: s/of_find_node_by_name()/of_get_child_by_name()/ from Pantelis
Antoniou
v3: add backlight support
v4: rebase to latest of video timing helpers
v5: remove some unneeded fields from panel-info struct, add DT bindings
docs
Tested-by: Koen Kooi <koen@dominion.thruhere.net>
Add output panel driver for i2c encoder slaves.
v1: original
v2: add DT bindings docs, and minor updates for review comments
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
A simple DRM/KMS driver for the TI LCD Controller found in various
smaller TI parts (AM33xx, OMAPL138, etc). This driver uses the
CMA helpers. Currently only the TFP410 DVI encoder is supported
(tested with beaglebone + DVI cape). There are also various LCD
displays, for which support can be added (as I get hw to test on),
and an external i2c HDMI encoder found on some boards.
The display controller supports a single CRTC. And the encoder+
connector are split out into sub-devices. Depending on which LCD
or external encoder is actually present, the appropriate output
module(s) will be loaded.
v1: original
v2: fix fb refcnting and few other cleanups
v3: get +/- vsync/hsync from timings rather than panel-info, add
option DT max-bandwidth field so driver doesn't attempt to
pick a display mode with too high memory bandwidth, and other
small cleanups
v4: remove some unneeded stuff from panel-info struct, properly
set high bits for hfp/hsw/hbp for rev 2, add DT bindings docs
Add documentation for the DT bindings in exynos G2D driver.
This patch adds support for device tree based discovery for exynos5
hdmi ddc.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
hdmiphy.
mixer. Mixer node is also renamed with "exynos5-mixer".
hdmi. Hdmi node is also renamed with "exynos5-hdmi".
