Convert ARM CPU binding to DT schema format using json-schema.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: devicetree@vger.kernel.org
Cc: linux-mediatek@lists.infradead.org
Signed-off-by: Rob Herring <robh@kernel.org>
The unit of dynamic-power-coefficient is described as mW/MHz/uV^2 whereas
its usage in the code assumes that unit is uW/MHz/V^2
In drivers/thermal/cpu_cooling.c, the code is :
power = (u64)capacitance * freq_mhz * voltage_mv * voltage_mv;
do_div(power, 1000000000);
which can be summarized as :
power (mW) = capacitance * freq_mhz/1000 * (voltage_mv/1000)^2
or
power (mW) = (capacitance * freq_mhz * (voltage_mv/1000)^2) / 1000
then
power (mW) = power (uW) / 1000
so
power (uW) = capacitance * freq_mhz * (voltage_mv/1000)^2
Furthermore, if we test basic values like :
voltage_mv = 1000mV = 1V
freq_mhz = 1000Mhz
The minimum possible power, when dynamic-power-coefficient equals 1, will
be with current unit:
min power = 1 * 1000 * (1000000)^2 = 10^15 mW
which is not realistic
With the unit used by the code, the min power is
min power = 1 * 1000 * 1^2 = 1000uW = 1mW which is far more realistic
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Acked-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
https://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt
Renesas ARM Based SoC DT Bindings Updates for v4.19
Bindings relating to initial support for RZ/N1D (R9A06G032) SoC and its
RZN1D-DB board:
* Add Renesas R9A06G032 SMP enable method
* Document SoC and Board bindings
* tag 'renesas-dt-bindings-for-v4.19' of https://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
dt-bindings: cpu: Add Renesas R9A06G032 SMP enable method.
dt-bindings: arm: Document the RZN1D-DB board
Add compatibility string for the Carmel CPU in Tegra194.
Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add a special enable method for second CA7 of the R9A06G032
Signed-off-by: Michel Pollet <michel.pollet@bp.renesas.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Pull ARM SoC platform updates from Arnd Bergmann:
"This release brings up a new platform based on the old ARM9 core: the
Nuvoton NPCM is used as a baseboard management controller, competing
with the better known ASpeed AST2xx series.
Another important change is the addition of ARMv7-A based chips in
mach-stm32. The older parts in this platform are ARMv7-M based
microcontrollers, now they are expanding to general-purpose workloads.
The other changes are the usual defconfig updates to enable additional
drivers, lesser bugfixes. The largest updates as often are the ongoing
OMAP cleanups, but we also have a number of changes for the older PXA
and davinci platforms this time.
For the Renesas shmobile/r-car platform, some new infrastructure is
needed to make the watchdog work correctly.
Supporting Multiprocessing on Allwinner A80 required a significant
amount of new code, but is not doing anything unexpected"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (179 commits)
arm: npcm: modify configuration for the NPCM7xx BMC.
MAINTAINERS: update entry for ARM/berlin
ARM: omap2: fix am43xx build without L2X0
ARM: davinci: da8xx: simplify CFGCHIP regmap_config
ARM: davinci: da8xx: fix oops in USB PHY driver due to stack allocated platform_data
ARM: multi_v7_defconfig: add NXP FlexCAN IP support
ARM: multi_v7_defconfig: enable thermal driver for i.MX devices
ARM: multi_v7_defconfig: add RN5T618 PMIC family support
ARM: multi_v7_defconfig: add NXP graphics drivers
ARM: multi_v7_defconfig: add GPMI NAND controller support
ARM: multi_v7_defconfig: add OCOTP driver for NXP SoCs
ARM: multi_v7_defconfig: configure I2C driver built-in
arm64: defconfig: add CONFIG_UNIPHIER_THERMAL and CONFIG_SNI_AVE
ARM: imx: fix imx6sll-only build
ARM: imx: select ARM_CPU_SUSPEND for CPU_IDLE as well
ARM: mxs_defconfig: Re-sync defconfig
ARM: imx_v4_v5_defconfig: Use the generic fsl-asoc-card driver
ARM: imx_v4_v5_defconfig: Re-sync defconfig
arm64: defconfig: enable stmmac ethernet to defconfig
ARM: EXYNOS: Simplify code in coupled CPU idle hot path
Instead of having an early init function check the machine compatible
and installing multi-cluster SMP support for the A80 if it matches,
use a new cpu enable-method string. This makes the platform support
future proof in case anyone manages to add PSCI support.
The original init code for the SMP support is changed into the
.prepare_cpus callback in the smp_operations structure. Instead of
panicing when resources are missing like on some platforms, our code
merely guards against engaging SMP or CPU hotplug and returns an error.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Document the compatible string for the Kryo385 cpus found in qualcomm
SoCs.
Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Broadcom's Brahma-B53 CPU is an ARMv8A processor used on a number of
DSL, Cable Modem and Set-top-box SoCs.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
With this patch we add documentation for:
* power-management-unit: the PMU is used to bring up the cores during
SMP operations
* sram: among other things the sram is used to store the first code
executed by the core when it is powered up
* cpu-enable-method: the CPU enable method used by Amlogic Meson8 and
Meson8b SoCs
Signed-off-by: Carlo Caione <carlo@endlessm.com>
[also add Meson8 to the documentation]
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
This adds a compatible string "brcm,bcm2836-smp" for Broadcom's
BCM2836 and BCM2837 to the 32 bit ARM CPU device tree binding.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- vsprintf format specifier %pOF for device_node's. This will enable us
to stop storing the full node names. Conversion of users will happen
next cycle.
- Update documentation to point to DT specification instead of ePAPR.
- Split out graph and property functions to a separate file.
- New of-graph functions for ALSA
- Add vendor prefixes for RISC-V, Linksys, iWave Systems, Roofull,
Itead, and BananaPi.
- Improve dtx_diff utility filename printing.
* tag 'devicetree-for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (32 commits)
of: document /sys/firmware/fdt
dt-bindings: Add RISC-V vendor prefix
vsprintf: Add %p extension "%pOF" for device tree
of: find_node_by_full_name rewrite to compare each level
of: use kbasename instead of open coding
dt-bindings: thermal: add file extension to brcm,ns-thermal
of: update ePAPR references to point to Devicetree Specification
scripts/dtc: dtx_diff - Show real file names in diff header
of: detect invalid phandle in overlay
of: be consistent in form of file mode
of: make __of_attach_node() static
of: address.c header comment typo
of: fdt.c header comment typo
of: make of_fdt_is_compatible() static
dt-bindings: display-timing.txt convert non-ascii characters to ascii
Documentation: remove overlay-notes reference to non-existent file
dt-bindings: usb: exynos-usb: Add missing required VDD properties
dt-bindings: Add vendor prefix for Linksys
MAINTAINERS: add device tree ABI documentation file
of: Add vendor prefix for iWave Systems Technologies Pvt. Ltd
Pull ARM device-tree updates from Arnd Bergmann:
"Device-tree continues to see lots of updates. The majority of patches
here are smaller changes for new hardware on existing platforms, and
there are a few larger changes worth pointing out.
New machines:
- The new Action Semi S500 platform is added along with initial
support for the LeMaker Guitar board.
- STM32 gains support for three new boards: stm32h743-disco,
stm32f746-disco, and stm32f769-disco, along with new device support
for the existing stm32f429 boards.
- Renesas adds two new boards, the tiny GR-Peach based on RZ/A1H with
10MB on-chip SRAM, and the iWave G20D-Q7 System-on-Module plus
board.
- On Marvell "mvebu", we gain support for the Linksys WRT3200ACM
wireless router.
- For NXP i.MX, we gain support for the Gateworks Ventana GW5600 and
the Technexion Pico i.MX7D single-board computers.
- The BeagleBone Blue is added for OMAP, it's the latest variation of
the popular Beaglebone Black single-board computer.
- The Allwinner based Lichee Pi Zero and NanoPi M1 Plus boards are
added, these are the latest variations of a seemingly endless
supply of similar single-board computers.
Other updates:
- Linus Walleij improves support for the "Faraday" based SoC
platforms from various SoC makers (Moxart, Aspeed, Gemini)
- The ARM Mali GPU is now describe on Rockchips SoCs
- Mediatek MT7623 is extended significantly, making it much more
useful.
- Lots of individual updates on Renesas, OMAP, Rockchips, Broadcom,
Allwinner, Qualcomm, iMX
- For Amlogic, the clock support is extended a lot on meson8b.
- We now build the devicetree file for the Raspberry Pi 3 on 32-bit
ARM, in addition to the existing ARM64 support, to help users
wanting to run a 32-bit system on it"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (345 commits)
ARM: dts: socfpga: set the i2c frequency
ARM: dts: socfpga: Add second ethernet alias to VINING FPGA
ARM: dts: socfpga: Drop LED node from VINING FPGA
ARM: dts: socfpga: Remove I2C EEPROMs from VINING FPGA
ARM: dts: socfpga: Enable QSPI support on VINING FPGA
ARM: dts: socfpga: Fix the ethernet clock phandle
ARM: pxa: Use - instead of @ for DT OPP entries
ARM: dts: owl-s500: Add SPS node
ARM: dts: owl-s500: Set CPU enable-method
dt-bindings: arm: cpus: Add S500 enable-method
ARM: dts: Add Actions Semi S500 and LeMaker Guitar
dt-bindings: arm: Document Actions Semi S900
dt-bindings: timer: Document Owl timer
ARM: dts: imx6q-cm-fx6: add sdio wifi/bt nodes
dt-bindings: arm: Document Actions Semi S500
dt-bindings: Add vendor prefix for Actions Semi
ARM: dts: turris-omnia: Add generic compatible string for I2C EEPROM
ARM: dts: mvebu: add support for Linksys WRT3200ACM (Rango)
ARM: dts: armada-385-linksys: fixup button node names
ARM: dts: armada-385-linksys: group pins in pinctrl
The Devicetree Specification has superseded the ePAPR as the
base specification for bindings. Update files in Documentation
to reference the new document.
First reference to ePAPR in Documentation/devicetree/bindings/arm/cci.txt
is generic, remove it.
Some files are not updated because there is no hypervisor chapter
in the Devicetree Specification:
Documentation/devicetree/bindings/powerpc/fsl/msi-pic.txt
Documenation/virtual/kvm/api.txt
Documenation/virtual/kvm/ppc-pv.txt
Signed-off-by: Frank Rowand <frank.rowand@sony.com>
The Actions Semi S500 SoC requires a special secondary CPU boot procedure.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reference to cpu capacity binding has a wrong number. Fix it.
Reported-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Juri Lelli <juri.lelli@arm.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Add documentation for Cavium's ThunderX2 CN99XX ARM64 processor. This
SoC will use "cavium,thunderx2-cn9900" as the compatible property.
Also add a documentation entry for the "cavium,thunder2" cpu core
present in these SoCs.
Signed-off-by: Jayachandran C <jnair@caviumnetworks.com>
Pull ARM 64-bit DT updates from Arnd Bergmann:
"ARM64 DT updates are fairly small this time, only two new SoCs and a
handful of new machines get added, all of them similar to other
hardware we already support.
New SoC:
- HiSilicon Kirin960/Hi3660 and HiKey960 development board
- NXP LS1012a with three reference boards:
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/qoriq-layerscape-arm-processors/qoriq-layerscape-1012a-low-power-communication-processor:LS1012A
New development board:
- Banana Pi M64, based on Allwinner A64:
http://www.banana-pi.org/m64.html
- SolidRun MACCHIATOBin based on Marvell Armada 8K:
https://www.solid-run.com/marvell-armada-family/armada-8040-community-board/
- Broadcom BCM958712DxXMC NorthStar2 reference board (another one)
A lot of platforms improve support for existing machines by adding
extra devices for which a binding and driver is availabe:
Allwinner:
- MMC, USB
ARM Juno:
- Coresight, STM
Broadcom:
- NS2 GICv2m irqchip and PCIe
Marvell:
- Armada 3700 SPI, I2C, ethernet switch
Mediatek:
- MT8173 thermal
NXP i.MX:
- LS1046A thermal
Qualcomm:
- coresight on MSM8916, HDMI, WCNSS, SCM
Renesas:
- r8a779[56] thermal, powerdomain, ethernet, sound, pwm, can, can fd
Rockchip:
- thermal, eDP, pinctrl enhancements
Samsung:
- TM2 touchkey, Exynos5433 HDMI and power management improvements
UniPhier:
- SD reset, eMMC controller
ZTE:
- oppv2 cpufreq"
* tag 'armsoc-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (110 commits)
arm64: dts: qcom: Add msm8916 CoreSight components
arm64: dts: marvell: adjust name of sd-mmc-gop clock in syscon
arm64: allwinner: add BananaPi-M64 support
arm64: allwinner: a64: add UART1 pin nodes
arm64: allwinner: pine64: add MMC support
arm64: allwinner: a64: Increase the MMC max frequency
arm64: allwinner: a64: Add MMC pinctrl nodes
arm64: allwinner: a64: Add MMC nodes
dt-bindings: clockgen: Add compatible string for LS1012A
Documentation: DT: add LS1012A compatible for SCFG and DCFG
Documentation: DT: Add entry for FSL LS1012A RDB, FRDM, QDS boards
arm64: dts: marvell: add generic-ahci compatibles for CP110 ahci
arm64: tegra: Use symbolic reset identifiers
arm64: dts: r8a7796: Mark EthernetAVB device node disabled
arm64: dts: r8a7795: Mark EthernetAVB device node disabled
arm64: dts: r8a7795: tidyup audma definition order
arm64: dts: r8a7796: Link ARM GIC to clock and clock domain
arm64: dts: r8a7795: Link ARM GIC to clock and clock domain
arm64: dts: r8a7796: Add R-Car Gen3 thermal support
arm64: dts: r8a7795: Add R-Car Gen3 thermal support
Compared to the armada-xp the 98DX3336 uses different registers to set
the boot address for the secondary CPU so a new enable-method is needed.
This will only work if the machine definition doesn't define an overall
smp_ops because there is not currently a way of overriding this from the
device tree if it is set in the machine definition.
Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Add arm cpu type cortex-a73
Signed-off-by: Chen Feng <puck.chen@hisilicon.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
Pull ARM DT updates from Arnd Bergmann:
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: artpec: add pcie support
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
Update arm/cpus.txt with the compatible string for the Denver CPU found
on Tegra186 SoCs.
ARM systems may be configured to have cpus with different power/performance
characteristics within the same chip. In this case, additional information
has to be made available to the kernel (the scheduler in particular) for it
to be aware of such differences and take decisions accordingly.
Therefore, this patch aims at standardizing cpu capacities device tree
bindings for ARM platforms. Bindings define cpu capacity-dmips-mhz
parameter, to allow operating systems to retrieve such information from
the device tree and initialize related kernel structures, paving the way
for common code in the kernel to deal with heterogeneity.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Vincent Guittot <vincent.guittot@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt
Second Round of Renesas ARM Based SoC DT Updates for v4.8
* Use APMU on R-Car Gen2 and provide SMP for r8a7793 SoC
* Update console parameters to uniformly use chosen/stdout-path,
serial0, not provide kernel unnecessary command line parameters
* Add DU pins to silk board
* Add support for blanche/r8a7792
* Name pfc subnodes after device name
* tag 'renesas-dt2-for-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: (41 commits)
ARM: dts: r8a7792: add SMP support
ARM: dts: r8a7793: Add APMU node and second CPU core
ARM: dts: r8a7791: Add APMU node
ARM: dts: r8a7790: Add APMU nodes
devicetree: bindings: Renesas APMU and SMP Enable method
ARM: dts: kzm9g: Update console parameters
ARM: dts: kzm9d: Update console parameters
ARM: dts: marzen: Add serial port config to chosen/stdout-path
ARM: dts: genmai: Update console parameters
ARM: dts: armadillo800eva: Update console parameters
ARM: dts: r8a7792: add JPU support
ARM: dts: r8a7792: add JPU clocks
ARM: dts: silk: add DU pins
ARM: dts: blanche: add Ethernet support
ARM: dts: blanche: initial device tree
ARM: dts: blanche: document Blanche board
ARM: dts: r8a7792: add IRQC support
ARM: dts: r8a7792: add [H]SCIF support
ARM: dts: r8a7792: add SYS-DMAC support
ARM: dts: r8a7792: initial SoC device tree
Add DT binding documentation for the APMU hardware and add "renesas,apmu"
to the list of enable methods for the ARM cpus.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add binding document for Broadcom BCM23550 SoC.
BCM23550 has a Cluster Dormant Control IP block that holds cores
in an idle state. Introduce a new CPU enable method in which the CDC is
accessed to bring the core online.
Signed-off-by: Chris Brand <chris.brand@broadcom.com>
Commit 84320e1a635fcf90cff4185f029ce9e31bf1d4a7
("ARM: BCM: Clean up SMP support for Broadcom Kona") moved the
"secondary-boot-reg" property from the "cpus" node to the individual "cpu"
nodes but negelected to update brcm,bcm11351-cpu-method.txt to match.
bcm11351-cpu-method was apparently never added to the list of methods in
bindings/arm/cpus.txt.
bindings/arm/cpus.txt states that "enable-method" should be a property of
the "cpu" node rather than the "cpus" node.
This patch rectifies these two omissions and one inconsistency.
Currently ARM CPUs DT bindings allows different enable-method value for
PSCI based systems. On ARM 64-bit this property is required and must be
"psci" while on ARM 32-bit systems this property is optional and must
be "arm,psci" if present.
However, "arm,psci" has always been the compatible string for the PSCI
node, and was never intended to be the enable-method. So this is a bug
in the binding and not a deliberate attempt at specifying 32-bit
differently.
This is problematic if 32-bit OS is run on 64-bit system which has
"psci" as enable-method rather than the expected "arm,psci".
So let's unify the value into "psci" and remove support for "arm,psci"
before it finds any users.
Reported-by: Soby Mathew <Soby.Mathew@arm.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
"The arm64 device tree changes make up an increasing portion of the
overall changes, so they are kept separate from the 32-bit devicetree
changes and from the other arm64 updates.
Newly added SoCs and boards are:
- 96Boards Husky board
- AMD Overdrive board
- Amlogic S905 SoC and related Tronsmart boxes
- Annapurna Labs Alpine family and development board
- Broadcom Vulcan servers
- Broadcom Northstar 2 SoC
- Marvell Armada 3700 family and development board
- Qualcomm MSM8996 SoC
Additional devices are enabled for existing platforms from Applied
Micro, Hisilicon, Mediatek, Qualcomm, and Renesas and there are a
couple of other updates for Rockchip, Xilinx and NXP/Freescale"
* tag 'armsoc-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (102 commits)
ARM64: dts: amlogic: Add Tronsmart Vega S95 configs
Documentation: devicetree: amlogic: Document Tronsmart Vega S95 boards
ARM64: dts: Prepare configs for Amlogic Meson GXBaby
Documentation: devicetree: amlogic: Document Meson GXBaby
devicetree: bindings: Add vendor prefix for Tronsmart
arm64: dts: qcom: Fix MPP's function used for LED control
arm64: dts: alpine: add the MSIX node in the Alpine v2 dtsi
arm64: dts: add the Alpine v2 EVP
arm64: dts: marvell: re-order Device Tree nodes for Armada AP806
arm64: dts: marvell: update Armada AP806 clock description
arm64: dts: marvell: add Device Tree files for Armada 7K/8K
arm64: dts: apm: Add DT node for X-Gene v2 SLIMpro Mailbox I2C Driver
arm64: dts: apm: Mailbox device tree node for APM X-Gene v2 platform.
arm64: dts: apm: Add DT node for X-Gene v1 SLIMpro Mailbox I2C Driver
arm64: dts: apm: mailbox device tree node for APM X-Gene platform.
arm64: dts: apm: Update GPIO to control power-off on X-Gene v2 platforms
arm64: dts: apm: Update GPIO standby controller DT node for X-Gene v2 platforms
arm64: dts: apm: Update GPIO to control power-off on X-Gene v1 platforms
arm64: dts: salvator-x: enable USB 2.0 Host of channel 1 and 2
arm64: dts: salvator-x: enable usb2_phy of channel 1 and 2
"These are all the updates to device tree files for 32-bit platforms,
plus a couple of related 64-bit updates:
New SoC support:
- Allwinner A83T
- Axis Artpec-6 SoC
- Mediatek MT7623 SoC
- TI Keystone K2G SoC
- ST Microelectronics stm32f469
New board or machine support:
- ARM Juno R2
- Buffalo Linkstation LS-QVL and LS-GL
- Cubietruck plus
- D-Link DIR-885L
- DT support for ARM RealView PB1176 and PB11MPCore
- Google Nexus 7
- Homlet v2
- Itead Ibox
- Lamobo R1
- LG Optimus Black
- Logicpd dm3730
- Raspberry Pi Model A
Other changes include
- Lots of updates for Qualcomm APQ8064, MSM8974 and others
- Improved support for Nokia N900 and other OMAP machines
- Common clk support for lpc32xx
- HDLCD display on ARM
- Improved stm32f429 support
- Improved Renesas device support, r8a779x and others
- Lots of Rockchip updates
- Samsung cleanups
- ADC support for Atmel SAMA5D2
- BCM2835 (Raspberry Pi) improvements
- Broadcom Northstar Plus enhancements
- OMAP GPMC rework
- Several improvements for Atmel SAMA5D2 / Xplained
- Global change to remove inofficial "arm,amba-bus" compatible
string"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits)
ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus"
ARM: dts: artpec: dual-license on artpec6.dtsi
ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT
arm64: dts: juno/vexpress: fix node name unit-address presence warnings
arm64: dts: foundation-v8: add SBSA Generic Watchdog device node
ARM: dts: at91: sama5d2 Xplained: add leds node
ARM: dts: at91: sama5d2 Xplained: add user push button
ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host
ARM: dts: stm32f429: Enable Ethernet on Eval board
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: stm32f429: Add Ethernet support
ARM: dts: stm32f429: Add system config bank node
ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes
ARM: dts: at91: sama5d2: add dma properties to UART nodes
ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node
ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load
ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs
The binding documentation uses both "uVolt" and "uV" for micro-volt.
Improve consistency by settling on "uV".
Document the compatible string for the Kryo family of qcom cpus.
Cc: <devicetree@vger.kernel.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Update arm/cpus.txt to add "brcm,vulcan" CPU. Add documentation
for Broadcom Vulcan boards in arm/bcm/brcm,vulcan-soc.txt
Signed-off-by: Jayachandran C <jchandra@broadcom.com>
Pull ARM DT updates from Olof Johansson:
"As usual, the bulk of this release is again DT file contents.
There's a huge number of changes here, and it's challenging to give a
crisp overview of just what is in here. To start with:
New boards:
- TI-based DM3730 from LogicPD (Torpedo)
- Cosmic+ M4 (nommu) initial support (Freescale Vybrid)
- Raspberry Pi 2 DT files
- Watchdog on Meson8b
- Veyron-mickey (ASUS Chromebit) DTS
- Rockchip rk3228 SoC and eval board
- Sigma Designs Tango4
Improvements:
- Improved support for Qualcomm APQ8084, including Sony Xperia Z DT files
- Misc new devices for Rockchip rk3036 and rk3288
- Allwinner updates for misc SoCs and systems
... and a _large_ number of other changes across the field. Devices
added to SoC DTSI and board DTS files for a number of SoC vendors, new
product boards on already-supported SoCs, cleanups and refactorings of
existing DTS/DTSI files and a bunch of other changes"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (469 commits)
ARM: dts: compulab: add new board description
ARM: versatile: add the syscon LEDs to the DT
dts: vt8500: Fix errors in SDHC node for WM8505
ARM: dts: imx6q: clean up unused ipu2grp
ARM: dts: silk: Add compatible property to "partitions" node
ARM: dts: gose: Add compatible property to "partitions" node
ARM: dts: porter: Add compatible property to "partitions" node
ARM: dts: koelsch: Add compatible property to "partitions" node
ARM: dts: lager: Add compatible property to "partitions" node
ARM: dts: bockw: Add compatible property to "partitions" node
ARM: dts: meson8b: Add watchdog node
Documentation: watchdog: Add new bindings for meson8b
ARM: meson: Add status LED for Odroid-C1
ARM: dts: uniphier: fix a typo in comment block
ARM: bcm2835: Add the auxiliary clocks to the device tree.
ARM: bcm2835: Add devicetree for bcm2836 and Raspberry Pi 2 B
ARM: bcm2835: Move the CPU/peripheral include out of common RPi DT.
ARM: bcm2835: Split the DT for peripherals from the DT for the CPU
ARM: realview: set up cache correctly on the PB11MPCore
ARM: dts: Unify G2D device node with other devices on exynos4
Pull ARM SoC platform updates from Olof Johansson:
"Updates for new platform support:
- New platform: Tango4 from Sigma Designs.
- Broadcom BCM2836 (Raspberry Pi 2 SoC)
- Enable cpufreq on Freescale i.MX7D
- Rockchip: SMP support for rk3036, general support for rk3228
- SMP support on Broadcom Kona and NSP
- Cleanups for OMAP removing legacy IOMMU data
+ a bunch of misc fixes and tweaks for various platforms"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (46 commits)
ARM: tango: Fix UP build issues
ARM: tango: pass ARM arch level for smc.S
ARM: bcm2835: Add Kconfig support for bcm2836
ARM: OMAP2+: Add support for dm814x and dra62x usb
ARM: OMAP2+: Add mmc hwmod entries for dm814x
ARM: OMAP2+: Update 81xx clock and power domains for default, active and sgx
ARM: OMAP2+: Fix SoC detection for dra62x j5-eco
ARM: tango4: Initial platform support
ARM: bcm2835: Add a compat string for bcm2836 machine probe
dt-bindings: Add root properties for Raspberry Pi 2
ARM: imx: select SRC for i.MX7
ARM: uniphier: select PINCTRL
ARM: OMAP2+: Remove device creation for omap-pcm-audio
ARM: OMAP1: Remove device creation for omap-pcm-audio
ARM: rockchip: enable support for RK3228 SoCs
ARM: rockchip: use const and __initconst for rk3036 smp_operations
ARM: zynq: Select ARCH_HAS_RESET_CONTROLLER
ARM: BCM: Add SMP support for Broadcom 4708
ARM: BCM: Add SMP support for Broadcom NSP
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
- Rework and export the changeset API to make it available to users
other than DT overlays
- ARM secure devices binding
- OCTEON USB binding
- Clean-up of various SRAM binding docs
- Various other binding doc updates
* tag 'devicetree-for-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (21 commits)
drivers/of: Export OF changeset functions
Fix documentation for adp1653 DT
ARM: psci: Fix indentation in DT bindings
of/platform: export of_default_bus_match_table
of/unittest: Show broken behaviour in the platform bus
of: fix declaration of of_io_request_and_map
of/address: replace printk(KERN_ERR ...) with pr_err(...)
of/irq: optimize device node matching loop in of_irq_init()
dt-bindings: tda998x: Document the required 'port' node.
net/macb: bindings doc: Merge cdns-emac to macb
dt-bindings: Misc fix for the ATH79 DDR controllers
dt-bindings: Misc fix for the ATH79 MISC interrupt controllers
Documentation: dt: Add bindings for Secure-only devices
dt-bindings: ARM: add arm,cortex-a72 compatible string
ASoC: Atmel: ClassD: add GCK's parent clock in DT binding
DT: add Olimex to vendor prefixes
Documentation: fsl-quadspi: Add fsl,ls1021-qspi compatible string
Documentation/devicetree: document OCTEON USB bindings
usb: misc: usb3503: Describe better how to bind clock to the hub
dt-bindings: Consolidate SRAM bindings from all vendors
This adds an SMP boot method for the ARM RealView reference
designs. We also select HAVE_SMP by default and make it use
SMP_ON_UP so we only need to support one single kernel across
the RealView reference designs when using DT.
The RealViews need to have the SCU (Snoop Control Unit)
activated on boot, and this is now done by looking up its
address from the device tree and initializing it and counting
the available cores.
The RealViews boot by using a magic address register in the
system controller (SYS_FLAGS) to store the boot address,
the ROM will then read this register to the PC when the CPUs
are taken out of WFI. This code uses a handle to the syscon
regmap to access this register.
The dynamic power consumption of a device is proportional to the
square of voltage (V) and the clock frequency (f). It can be expressed as
Pdyn = dynamic-power-coefficient * V^2 * f.
The coefficient represents the running time dynamic power consumption in
units of mw/MHz/uVolt^2 and can be used in the above formula to
calculate the dynamic power in mW.
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Add a compatible string "brcm,bcm-nsp-smp" for Broadcom's
Northstar Plus CPU to the 32-bit ARM CPU device tree binding
documentation file and create a new binding documentation for
Northstar Plus CPU.
Signed-off-by: Kapil Hali <kapilh@broadcom.com>
The dual-core Cortex A7 rk3036 is a bit special in that it does not allow
to control the actual powerdomain of the cpu cores, while the rest of the
smp-bringup like reset control and entry address handling stays the same.
Its bigger sibling, the quad-core rk3128 again allows powerdomain control.
So allow that case by introducing a separate smp-enable-method, that simply
disables powerdomain handling in the common code.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Xing Zheng <zhengxing@rock-chips.com>
This commit add new cpu enable method "mediatek,mt65xx-smp" and
"mediatek,mt81xx-tz-smp".
Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
The "cpus" node cannot be inside the "soc" node, while this
works for the CoreSight blocks, the early boot code will look
for "cpus" directly under the root node, so this is a hard
convention. So move the CPU nodes.
Augment the "reg" property to match what is actually in the
hardware: 0x300 and 0x301 respectively.
Then add an SMP enablement type to be used by the SMP init
code, "ste,dbx500-smp".
The A23 is a dual Cortex-A7. Add the logic to use the IPs used to
control the CPU configuration and the CPU power so that we can
bring up secondary CPUs at boot.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This commit updates the ARM CPUs Device Tree binding to document a new
enable method of Marvell Armada 39x processors.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Add a compatible string for the NVIDIA Denver CPU to the ARM CPU DT
binding documentation file. The primary objective here is to keep
checkpatch.pl from warning when the compatible string is used in an
SoC DT file, per:
http://marc.info/?l=linux-tegra&m=142201349727836&w=2
This second version changes the string from "nvidia,denver" to
"nvidia,tegra132-denver" to more precisely describe the revision of
the Denver CPU complex that is present in the Tegra132 SoC.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Rohit Vaswani <rvaswani@codeaurora.org>
Cc: Paul Walmsley <pwalmsley@nvidia.com>
Cc: Marc Carino <marc.ceeeee@gmail.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Makes it possible to define a rockchip,pmu phandle in the cpus node directly
referencing the pmu syscon instead of searching for specific compatible.
The old way of finding the pmu stays of course available.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Pull ARM64 SoC changes from Arnd Bergmann:
"Starting with 3.18, we are merging SoC-specific changes for arm64
through the arm-soc tree, like we have been doing for arm32.
This time, there is only one set of changes, adding support for the
Cavium "Thunder" Soc family. Since the changes are relatively small,
this includes Kconfig, defconfig and DT changes.
If all goes well, we will never require adding actual C source code
for platform support in arm64, given that the architecture is more
clearly defined and we have moved out a lot of the platform specifics
into device drivers for arm32 already"
* tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64, defconfig: Enable Cavium Thunder SoC in defconfig
arm64, thunder: Add Kconfig option for Cavium Thunder SoC Family
arm64, thunder: Document devicetree bindings for Cavium Thunder SoC
arm64, thunder: Add initial dts for Cavium Thunder SoC
This patch adds documentation for the devicetree bindings used by the
DT files of Cavium Thunder SoC platforms.
Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
Signed-off-by: Robert Richter <rrichter@cavium.com>
