path: root/Documentation/devices.txt
2006-06-25[PATCH] update-devices.txtJan Engelhardt
Update Documentation/devices.txt with a new version from the LANANA site http://www.lanana.org/docs/device-list/devices-2.6+.txt Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Update devices.txtJan Engelhardt
Update Documentation/devices.txt with a new version from the LANANA site http://www.lanana.org/docs/device-list/devices-2.6+.txt Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Torben Mathiasen <device@lanana.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] devices.txt: remove pktcdvd entryPeter Osterlund
Changing the driver to use dynamic device numbers was one of the many changes that were made in order to have the driver accepted into the mainline kernel. Therefore I would say that the entry in devices.txt is obsolete. This patch removes it. Signed-off-by: Peter Osterlund <petero2@telia.com> Cc: Torben Mathiasen <device@lanana.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[PATCH] USB: Delete leftovers from bluetty driverMarcel Holtmann
This patch deletes the bluetooth.txt help file of the bluetty driver and hands over its major device nodes for character devices to the RFCOMM TTY implementation of the Bluetooth subsystem. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Accessing dump file in linear raw format (/dev/oldmem)Vivek Goyal
Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that enables us to access the previous kernel's memory as /dev/oldmem. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
