path: root/Documentation/cgroups/unified-hierarchy.txt
2015-02-28mm: memcontrol: use "max" instead of "infinity" in control knobsJohannes Weiner
The memcg control knobs indicate the highest possible value using the symbolic name "infinity", which is long and awkward to type. Switch to the string "max", which is just as descriptive but shorter and sweeter. This changes a user interface, so do it before the release and before the development flag is dropped from the default hierarchy. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: memcontrol: default hierarchy interface for memoryJohannes Weiner
Introduce the basic control files to account, partition, and limit memory using cgroups in default hierarchy mode. This interface versioning allows us to address fundamental design issues in the existing memory cgroup interface, further explained below. The old interface will be maintained indefinitely, but a clearer model and improved workload performance should encourage existing users to switch over to the new one eventually. The control files are thus: - memory.current shows the current consumption of the cgroup and its descendants, in bytes. - memory.low configures the lower end of the cgroup's expected memory consumption range. The kernel considers memory below that boundary to be a reserve - the minimum that the workload needs in order to make forward progress - and generally avoids reclaiming it, unless there is an imminent risk of entering an OOM situation. - memory.high configures the upper end of the cgroup's expected memory consumption range. A cgroup whose consumption grows beyond this threshold is forced into direct reclaim, to work off the excess and to throttle new allocations heavily, but is generally allowed to continue and the OOM killer is not invoked. - memory.max configures the hard maximum amount of memory that the cgroup is allowed to consume before the OOM killer is invoked. - memory.events shows event counters that indicate how often the cgroup was reclaimed while below memory.low, how often it was forced to reclaim excess beyond memory.high, how often it hit memory.max, and how often it entered OOM due to memory.max. This allows users to identify configuration problems when observing a degradation in workload performance. An overcommitted system will have an increased rate of low boundary breaches, whereas increased rates of high limit breaches, maximum hits, or even OOM situations will indicate internally overcommitted cgroups. For existing users of memory cgroups, the following deviations from the current interface are worth pointing out and explaining: - The original lower boundary, the soft limit, is defined as a limit that is per default unset. As a result, the set of cgroups that global reclaim prefers is opt-in, rather than opt-out. The costs for optimizing these mostly negative lookups are so high that the implementation, despite its enormous size, does not even provide the basic desirable behavior. First off, the soft limit has no hierarchical meaning. All configured groups are organized in a global rbtree and treated like equal peers, regardless where they are located in the hierarchy. This makes subtree delegation impossible. Second, the soft limit reclaim pass is so aggressive that it not just introduces high allocation latencies into the system, but also impacts system performance due to overreclaim, to the point where the feature becomes self-defeating. The memory.low boundary on the other hand is a top-down allocated reserve. A cgroup enjoys reclaim protection when it and all its ancestors are below their low boundaries, which makes delegation of subtrees possible. Secondly, new cgroups have no reserve per default and in the common case most cgroups are eligible for the preferred reclaim pass. This allows the new low boundary to be efficiently implemented with just a minor addition to the generic reclaim code, without the need for out-of-band data structures and reclaim passes. Because the generic reclaim code considers all cgroups except for the ones running low in the preferred first reclaim pass, overreclaim of individual groups is eliminated as well, resulting in much better overall workload performance. - The original high boundary, the hard limit, is defined as a strict limit that can not budge, even if the OOM killer has to be called. But this generally goes against the goal of making the most out of the available memory. The memory consumption of workloads varies during runtime, and that requires users to overcommit. But doing that with a strict upper limit requires either a fairly accurate prediction of the working set size or adding slack to the limit. Since working set size estimation is hard and error prone, and getting it wrong results in OOM kills, most users tend to err on the side of a looser limit and end up wasting precious resources. The memory.high boundary on the other hand can be set much more conservatively. When hit, it throttles allocations by forcing them into direct reclaim to work off the excess, but it never invokes the OOM killer. As a result, a high boundary that is chosen too aggressively will not terminate the processes, but instead it will lead to gradual performance degradation. The user can monitor this and make corrections until the minimal memory footprint that still gives acceptable performance is found. In extreme cases, with many concurrent allocations and a complete breakdown of reclaim progress within the group, the high boundary can be exceeded. But even then it's mostly better to satisfy the allocation from the slack available in other groups or the rest of the system than killing the group. Otherwise, memory.max is there to limit this type of spillover and ultimately contain buggy or even malicious applications. - The original control file names are unwieldy and inconsistent in many different ways. For example, the upper boundary hit count is exported in the memory.failcnt file, but an OOM event count has to be manually counted by listening to memory.oom_control events, and lower boundary / soft limit events have to be counted by first setting a threshold for that value and then counting those events. Also, usage and limit files encode their units in the filename. That makes the filenames very long, even though this is not information that a user needs to be reminded of every time they type out those names. To address these naming issues, as well as to signal clearly that the new interface carries a new configuration model, the naming conventions in it necessarily differ from the old interface. - The original limit files indicate the state of an unset limit with a very high number, and a configured limit can be unset by echoing -1 into those files. But that very high number is implementation and architecture dependent and not very descriptive. And while -1 can be understood as an underflow into the highest possible value, -2 or -10M etc. do not work, so it's not inconsistent. memory.low, memory.high, and memory.max will use the string "infinity" to indicate and set the highest possible value. [akpm@linux-foundation.org: use seq_puts() for basic strings] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Greg Thelen <gthelen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-15cgroup: distinguish the default and legacy hierarchies when handling cftypesTejun Heo
Until now, cftype arrays carried files for both the default and legacy hierarchies and the files which needed to be used on only one of them were flagged with either CFTYPE_ONLY_ON_DFL or CFTYPE_INSANE. This gets confusing very quickly and we may end up exposing interface files to the default hierarchy without thinking it through. This patch makes cgroup core provide separate sets of interfaces for cftype handling so that the cftypes for the default and legacy hierarchies are clearly distinguished. The previous two patches renamed the existing ones so that they clearly indicate that they're for the legacy hierarchies. This patch adds the interface for the default hierarchy and apply them selectively depending on the hierarchy type. * cftypes added through cgroup_subsys->dfl_cftypes and cgroup_add_dfl_cftypes() only show up on the default hierarchy. * cftypes added through cgroup_subsys->legacy_cftypes and cgroup_add_legacy_cftypes() only show up on the legacy hierarchies. * cgroup_subsys->dfl_cftypes and ->legacy_cftypes can point to the same array for the cases where the interface files are identical on both types of hierarchies. * This makes all the existing subsystem interface files legacy-only by default and all subsystems will have no interface file created when enabled on the default hierarchy. Each subsystem should explicitly review and compose the interface for the default hierarchy. * A boot param "cgroup__DEVEL__legacy_files_on_dfl" is added which makes subsystems which haven't decided the interface files for the default hierarchy to present the legacy files on the default hierarchy so that its behavior on the default hierarchy can be tested. As the awkward name suggests, this is for development only. * memcg's CFTYPE_INSANE on "use_hierarchy" is noop now as the whole array isn't used on the default hierarchy. The flag is removed. v2: Updated documentation for cgroup__DEVEL__legacy_files_on_dfl. v3: Clear CFTYPE_ONLY_ON_DFL and CFTYPE_INSANE when cfts are removed as suggested by Li. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Aristeu Rozanski <aris@redhat.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2014-07-08cgroup: implement cgroup_subsys->depends_onTejun Heo
Currently, the blkio subsystem attributes all of writeback IOs to the root. One of the issues is that there's no way to tell who originated a writeback IO from block layer. Those IOs are usually issued asynchronously from a task which didn't have anything to do with actually generating the dirty pages. The memory subsystem, when enabled, already keeps track of the ownership of each dirty page and it's desirable for blkio to piggyback instead of adding its own per-page tag. blkio piggybacking on memory is an implementation detail which preferably should be handled automatically without requiring explicit userland action. To achieve that, this patch implements cgroup_subsys->depends_on which contains the mask of subsystems which should be enabled together when the subsystem is enabled. The previous patches already implemented the support for enabled but invisible subsystems and cgroup_subsys->depends_on can be easily implemented by updating cgroup_refresh_child_subsys_mask() so that it calculates cgroup->child_subsys_mask considering cgroup_subsys->depends_on of the explicitly enabled subsystems. Documentation/cgroups/unified-hierarchy.txt is updated to explain that subsystems may not become immediately available after being unused from userland and that dependency could be a factor in it. As subsystems may already keep residual references, this doesn't significantly change how subsystem rebinding can be used. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org>
2014-04-25cgroup: add documentation about unified hierarchyTejun Heo
Unified hierarchy will be the new version of cgroup interface. This patch adds Documentation/cgroups/unified-hierarchy.txt which describes the design and rationales of unified hierarchy. v2: Grammatical updates as per Randy Dunlap's review. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Randy Dunlap <rdunlap@infradead.org>
