Since function tables are a common target for attackers, it's best to keep
them in read-only memory. As such, this makes the CDROM device ops tables
const. This drops additionally n_minors, since it isn't used meaningfully,
and sets the only user of cdrom_dummy_generic_packet explicitly so the
variables can all be const.
Inspired by similar changes in grsecurity/PaX.
Signed-off-by: Jens Axboe <axboe@fb.com>
Now unregister_cdrom() always returns 0.
Make it return void and update all callers that check the return value.
Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Cc: Borislav Petkov <petkovbb@gmail.com>
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
infrastructure for it.
Let it rip!
