path: root/Documentation/arm
2008-04-22[MTD] [NAND] S3C2410 Large page NAND supportBen Dooks
This adds support for using large page NAND devices with the S3C24XX NAND controller. This also adds the file Documentation/arm/Samsung-S3C24XX/NAND.txt to describe the differences. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-03fix typo 'the same the\>'Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12[ARM] Add missing entries to Documentation/arm/00-INDEXRob Landley
Add several missing entries to Documentation/arm/00-INDEX Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix "deprecated" typoes.Robert P. J. Day
Fix remaining misspellings of "depreciated" to "deprecated." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-02[ARM] 4238/1: S3C24XX: docs: update suspend and resumeBen Dooks
Remove some of the explicit use of S3C2410 where it is generic to all the S3C24XX series. Add more info on the CRC code, and add an example of using IRQ_EINT0 to resume from suspend Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4181/1: S3C24XX: Document new layoutBen Dooks
Update Documentation/arm/Samsung-S3C24XX/Overview.txt with the new directory layout. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4180/1: S3C24XX: Update docs for S3C2412 and S3C2413Ben Dooks
The S3C2412 and S3C2413 are supported, so document this as so Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4177/1: S3C24XX: Add DMA channel allocation orderBen Dooks
Allow the CPU code, and any board specific initialisation code to change the allocation order of the DMA channels, or stop a peripheral allocating any DMA at-all. This is due to the scarce mapping of DMA channels on some earlier S3C24XX cpus, where the selection changes depending on the channel in use. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4071/1: S3C24XX: Documentation updateBen Dooks
Add documentation for the following items: - new machines (AML M5900, VMTS, NexVision) - updated rtc section - removed comments about mtd cvs - added spi section - led section Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-30typo fixes: disadvantadge -> disadvantageAdrian Bunk
2006-06-26[ARM] 3657/1: S3C24XX: Documentation update of Overview.txtBen Dooks
Patch from Ben Dooks Update the list of supported devices, and remove the changelog. Add SMDK2413 information.-- Signed-off-by: Ben Dooks <ben-linux@fluff.org>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26[ARM] 3656/1: S3C2412: Add S3C2412 and S3C2413 documenationBen Dooks
Patch from Ben Dooks Add some basic documentation about the support for the S3C2412 and S3C2413 CPUs-- Signed-off-by: Ben Dooks <ben-linux@fluff.org>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-18[ARM] 3407/1: lpd7x: documetation updateMarc Singer
Patch from Marc Singer New documentation for the touchscreen controllers and LCD panels. Signed-off-by: Marc Singer <elf@buici.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-27[ARM] 3416/1: Update LART site URLErik Mouw
Patch from Erik Mouw The LART website moved to http://www.lartmaker.nl/. This patch updates the URL in ARM specific files. Signed-off-by: Erik Mouw <erik@bitwizard.nl> Acked-by: Jan-Derk Bakker <jdb@lartmaker.nl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-24Fix simple typosAndrzej Zaborowski
This corrects some trivial errors in ARM docs and comments, Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-21[ARM] 3332/1: S3C24XX - documentation updateBen Dooks
Patch from Ben Dooks Add devices that we have drivers for, and update list of machines that are supported Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-04[ARM] Add memory.txt to 00-INDEXRussell King
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-17[ARM] Fix some corner cases in new mm initialisationRussell King
Document that the VMALLOC_END address must be aligned to 2MB since it must align with a PGD boundary. Allocate the vectors page early so that the flush_cache_all() later will cause any dirty cache lines in the direct mapping will be safely written back. Move the flush_cache_all() to the second local_flush_cache_tlb() and remove the now redundant first local_flush_cache_tlb(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-05[ARM] Documentation/arm/README: small updateAdrian Bunk
- egcs is not supported by kernel 2.6 - gcc 3.3 seems to be a good choice on ARM Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-01[ARM] 3076/1: S3C2410 - updated documentation for platfrom data initBen Dooks
Patch from Ben Dooks Update the Documentation/arm/Samsung-S3C24XX to add example platform data initialisation, and add the linux-arm mailing list URL. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-10[PATCH] ARM: 2847/1: S3C24XX - Documentation for USB OHCI hostBen Dooks
Patch from Ben Dooks Documentation for the in-built OHCI host controller and the support for it in Linux. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
