commit 44b3834b2eed595af07021b1c64e6f9bc396398b upstream.
Cortex-A57 and Cortex-A72 have an erratum where an interrupt that
occurs between a pair of AES instructions in aarch32 mode may corrupt
the ELR. The task will subsequently produce the wrong AES result.
The AES instructions are part of the cryptographic extensions, which are
optional. User-space software will detect the support for these
instructions from the hwcaps. If the platform doesn't support these
instructions a software implementation should be used.
Remove the hwcap bits on affected parts to indicate user-space should
not use the AES instructions.
Acked-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: James Morse <james.morse@arm.com>
Link: https://lore.kernel.org/r/20220714161523.279570-3-james.morse@arm.com
Signed-off-by: Will Deacon <will@kernel.org>
[florian: resolved conflicts in arch/arm64/tools/cpucaps and cpu_errata.c]
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 171df58028bf4649460fb146a56a58dcb0c8f75a upstream.
Cortex-A55 is affected by an erratum where in rare circumstances the
CPUs may not handle a race between a break-before-make sequence on one
CPU, and another CPU accessing the same page. This could allow a store
to a page that has been unmapped.
Work around this by adding the affected CPUs to the list that needs
TLB sequences to be done twice.
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20220930131959.3082594-1-james.morse@arm.com
commit e89d120c4b720e232cc6a94f0fcbd59c15d41489 upstream.
The AMU counter AMEVCNTR01 (constant counter) should increment at the same
rate as the system counter. On affected Cortex-A510 cores, AMEVCNTR01
increments incorrectly giving a significantly higher output value. This
results in inaccurate task scheduler utilization tracking and incorrect
feedback on CPU frequency.
Work around this problem by returning 0 when reading the affected counter
in key locations that results in disabling all users of this counter from
using it either for frequency invariance or as FFH reference counter. This
effect is the same to firmware disabling affected counters.
Details on how the two features are affected by this erratum:
- AMU counters will not be used for frequency invariance for affected
CPUs and CPUs in the same cpufreq policy. AMUs can still be used for
frequency invariance for unaffected CPUs in the system. Although
unlikely, if no alternative method can be found to support frequency
invariance for affected CPUs (cpufreq based or solution based on
platform counters) frequency invariance will be disabled. Please check
the chapter on frequency invariance at
Documentation/scheduler/sched-capacity.rst for details of its effect.
- Given that FFH can be used to fetch either the core or constant counter
values, restrictions are lifted regarding any of these counters
returning a valid (!0) value. Therefore FFH is considered supported
if there is a least one CPU that support AMUs, independent of any
counters being disabled or affected by this erratum. Clarifying
comments are now added to the cpc_ffh_supported(), cpu_read_constcnt()
and cpu_read_corecnt() functions.
The above is achieved through adding a new erratum: ARM64_ERRATUM_2457168.
Signed-off-by: Ionela Voinescu <ionela.voinescu@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Will Deacon <will@kernel.org>
Cc: James Morse <james.morse@arm.com>
Link: https://lore.kernel.org/r/20220819103050.24211-1-ionela.voinescu@arm.com
commit 39fdb65f52e9a53d32a6ba719f96669fd300ae78 upstream.
Cortex-A510 is affected by an erratum where in rare circumstances the
Link: https://lore.kernel.org/r/20220704155732.21216-1-james.morse@arm.com
Signed-off-by: Lucas Wei <lucaswei@google.com>
[ Upstream commit 51f559d66527e238f9a5f82027bff499784d4eac ]
Add KRYO4XX gold/big cores to the list of CPUs that need the
repeat TLBI workaround. Apply this to the affected
KRYO4XX cores (rcpe to rfpe).
The variant and revision bits are implementation defined and are
different from the their Cortex CPU counterparts on which they are
based on, i.e., (r0p0 to r3p0) is equivalent to (rcpe to rfpe).
Signed-off-by: Shreyas K K <quic_shrekk@quicinc.com>
Reviewed-by: Sai Prakash Ranjan <quic_saipraka@quicinc.com>
Link: https://lore.kernel.org/r/20220512110134.12179-1-quic_shrekk@quicinc.com
commit 1175011a7d0030d49dc9c10bde36f08f26d0a8ee upstream.
Add a new HWCAP to detect the Increased precision of Reciprocal Estimate
and Reciprocal Square Root Estimate feature (FEAT_RPRES), introduced in Armv8.7.
Also expose this to userspace in the ID_AA64ISAR2_EL1 feature register.
Signed-off-by: Joey Gouly <joey.gouly@arm.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Acked-by: Marc Zyngier <maz@kernel.org>
Link: https://lore.kernel.org/r/20211210165432.8106-4-joey.gouly@arm.com
commit 5c13f042e73200b50573ace63e1a6b94e2917616 upstream.
Add a new HWCAP to detect the Alternate Floating-point Behaviour
feature (FEAT_AFP), introduced in Armv8.7.
Also expose this to userspace in the ID_AA64MMFR1_EL1 feature register.
Link: https://lore.kernel.org/r/20211210165432.8106-2-joey.gouly@arm.com
commit fee29f008aa3f2aff01117f28b57b1145d92cb9b upstream.
Since userspace can make use of the CNTVSS_EL0 instruction, expose
it via a HWCAP.
Suggested-by: Will Deacon <will@kernel.org>
Acked-by: Will Deacon <will@kernel.org>
Signed-off-by: Marc Zyngier <maz@kernel.org>
Link: https://lore.kernel.org/r/20211017124225.3018098-18-maz@kernel.org
* tip/sched/arm64: (785 commits)
Documentation: arm64: describe asymmetric 32-bit support
arm64: Remove logic to kill 32-bit tasks on 64-bit-only cores
arm64: Hook up cmdline parameter to allow mismatched 32-bit EL0
arm64: Advertise CPUs capable of running 32-bit applications in sysfs
arm64: Prevent offlining first CPU with 32-bit EL0 on mismatched system
arm64: exec: Adjust affinity for compat tasks with mismatched 32-bit EL0
arm64: Implement task_cpu_possible_mask()
sched: Introduce dl_task_check_affinity() to check proposed affinity
sched: Allow task CPU affinity to be restricted on asymmetric systems
sched: Split the guts of sched_setaffinity() into a helper function
sched: Introduce task_struct::user_cpus_ptr to track requested affinity
sched: Reject CPU affinity changes based on task_cpu_possible_mask()
cpuset: Cleanup cpuset_cpus_allowed_fallback() use in select_fallback_rq()
cpuset: Honour task_cpu_possible_mask() in guarantee_online_cpus()
cpuset: Don't use the cpu_possible_mask as a last resort for cgroup v1
sched: Introduce task_cpu_possible_mask() to limit fallback rq selection
sched: Cgroup SCHED_IDLE support
sched/topology: Skip updating masks for non-online nodes
Linux 5.14-rc6
lib: use PFN_PHYS() in devmem_is_allowed()
remote-tracking branch 'arm64/for-next/perf' into for-next/core
* arm64/for-next/perf:
arm64/perf: Replace '0xf' instances with ID_AA64DFR0_PMUVER_IMP_DEF
* for-next/mte:
: Miscellaneous MTE improvements.
arm64/cpufeature: Optionally disable MTE via command-line
arm64: kasan: mte: remove redundant mte_report_once logic
arm64: kasan: mte: use a constant kernel GCR_EL1 value
arm64: avoid double ISB on kernel entry
arm64: mte: optimize GCR_EL1 modification on kernel entry/exit
Documentation: document the preferred tag checking mode feature
arm64: mte: introduce a per-CPU tag checking mode preference
arm64: move preemption disablement to prctl handlers
arm64: mte: change ASYNC and SYNC TCF settings into bitfields
arm64: mte: rename gcr_user_excl to mte_ctrl
arm64: mte: avoid TFSRE0_EL1 related operations unless in async mode
* for-next/misc:
: Miscellaneous updates.
arm64: Do not trap PMSNEVFR_EL1
arm64: mm: fix comment typo of pud_offset_phys()
arm64: signal32: Drop pointless call to sigdelsetmask()
arm64/sve: Better handle failure to allocate SVE register storage
arm64: Document the requirement for SCR_EL3.HCE
arm64: head: avoid over-mapping in map_memory
arm64/sve: Add a comment documenting the binutils needed for SVE asm
arm64/sve: Add some comments for sve_save/load_state()
arm64: replace in_irq() with in_hardirq()
arm64: mm: Fix TLBI vs ASID rollover
arm64: entry: Add SYM_CODE annotation for __bad_stack
arm64: fix typo in a comment
arm64: move the (z)install rules to arch/arm64/Makefile
arm64/sve: Make fpsimd_bind_task_to_cpu() static
arm64: unnecessary end 'return;' in void functions
arm64/sme: Document boot requirements for SME
arm64: use __func__ to get function name in pr_err
arm64: SSBS/DIT: print SSBS and DIT bit when printing PSTATE
arm64: cpufeature: Use defined macro instead of magic numbers
arm64/kexec: Test page size support with new TGRAN range values
* for-next/kselftest:
: Kselftest additions for arm64.
kselftest/arm64: signal: Add a TODO list for signal handling tests
kselftest/arm64: signal: Add test case for SVE register state in signals
kselftest/arm64: signal: Verify that signals can't change the SVE vector length
kselftest/arm64: signal: Check SVE signal frame shows expected vector length
kselftest/arm64: signal: Support signal frames with SVE register data
kselftest/arm64: signal: Add SVE to the set of features we can check for
kselftest/arm64: pac: Fix skipping of tests on systems without PAC
kselftest/arm64: mte: Fix misleading output when skipping tests
kselftest/arm64: Add a TODO list for floating point tests
kselftest/arm64: Add tests for SVE vector configuration
kselftest/arm64: Validate vector lengths are set in sve-probe-vls
kselftest/arm64: Provide a helper binary and "library" for SVE RDVL
kselftest/arm64: Ignore check_gcr_el1_cswitch binary
It is amazing that we never documented this absolutely basic
requirement: if you boot the kernel at EL2, you'd better
enable the HVC instruction from EL3.
Really, just do it.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Link: https://lore.kernel.org/r/20210812190213.2601506-6-maz@kernel.org
Document support for running 32-bit tasks on asymmetric 32-bit systems
and its impact on the user ABI when enabled.
Link: https://lore.kernel.org/r/20210730112443.23245-17-will@kernel.org
Document our requirements for initialisation of the Scalable Matrix
Extension (SME) at kernel start. While we do have the ability to handle
mismatched vector lengths we will reject any late CPUs that can't support
the minimum set we determine at boot so for clarity we document a
requirement that all CPUs make the same vector length available.
Signed-off-by: Mark Brown <broonie@kernel.org>
Link: https://lore.kernel.org/r/20210720204220.22951-1-broonie@kernel.org
Document the functionality added in the previous patches.
Link: https://linux-review.googlesource.com/id/I48217cc3e8b8da33abc08cbaddc11cf4360a1b86
Signed-off-by: Peter Collingbourne <pcc@google.com>
Link: https://lore.kernel.org/r/20210727205300.2554659-6-pcc@google.com
[catalin.marinas@arm.com: clarify that the change happens on task scheduling]
Patch series "userfaultfd: do not untag user pointers", v5.
If a user program uses userfaultfd on ranges of heap memory, it may end
up passing a tagged pointer to the kernel in the range.start field of
the UFFDIO_REGISTER ioctl. This can happen when using an MTE-capable
allocator, or on Android if using the Tagged Pointers feature for MTE
readiness [1].
When a fault subsequently occurs, the tag is stripped from the fault
address returned to the application in the fault.address field of struct
uffd_msg. However, from the application's perspective, the tagged
address *is* the memory address, so if the application is unaware of
memory tags, it may get confused by receiving an address that is, from
its point of view, outside of the bounds of the allocation. We observed
this behavior in the kselftest for userfaultfd [2] but other
applications could have the same problem.
Address this by not untagging pointers passed to the userfaultfd ioctls.
Instead, let the system call fail. Also change the kselftest to use
mmap so that it doesn't encounter this problem.
[1] https://source.android.com/devices/tech/debug/tagged-pointers
[2] tools/testing/selftests/vm/userfaultfd.c
This patch (of 2):
Do not untag pointers passed to the userfaultfd ioctls. Instead, let
the system call fail. This will provide an early indication of problems
with tag-unaware userspace code instead of letting the code get confused
later, and is consistent with how we decided to handle brk/mmap/mremap
in commit dcde237319e6 ("mm: Avoid creating virtual address aliases in
brk()/mmap()/mremap()"), as well as being consistent with the existing
tagged address ABI documentation relating to how ioctl arguments are
handled.
The code change is a revert of commit 7d0325749a6c ("userfaultfd: untag
user pointers") plus some fixups to some additional calls to
validate_range that have appeared since then.
Link: https://lkml.kernel.org/r/20210714195437.118982-1-pcc@google.com
Link: https://lkml.kernel.org/r/20210714195437.118982-2-pcc@google.com
Link: https://linux-review.googlesource.com/id/I761aa9f0344454c482b83fcfcce547db0a25501b
Fixes: 63f0c6037965 ("arm64: Introduce prctl() options to control the tagged user addresses ABI")
Reviewed-by: Andrey Konovalov <andreyknvl@gmail.com>
Cc: Alistair Delva <adelva@google.com>
Cc: Dave Martin <Dave.Martin@arm.com>
Cc: Evgenii Stepanov <eugenis@google.com>
Cc: Lokesh Gidra <lokeshgidra@google.com>
Cc: Mitch Phillips <mitchp@google.com>
Cc: Vincenzo Frascino <vincenzo.frascino@arm.com>
Cc: William McVicker <willmcvicker@google.com>
Cc: <stable@vger.kernel.org> [5.4]
v8.7 of the architecture introduced FEAT_HCX which adds an additional
hypervisor configuration register HCRX_EL2. Even though Linux does not
currently make use of this feature let's document that the EL3 trap for
access to the register should be disabled so that we are able to make
use of it in future.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Link: https://lore.kernel.org/r/20210512162350.20349-1-broonie@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull more arm64 updates from Catalin Marinas:
"A mix of fixes and clean-ups that turned up too late for the first
pull request:
- Restore terminal stack frame records. Their previous removal caused
traces which cross secondary_start_kernel to terminate one entry
too late, with a spurious "0" entry.
- Fix boot warning with pseudo-NMI due to the way we manipulate the
PMR register.
- ACPI fixes: avoid corruption of interrupt mappings on watchdog
probe failure (GTDT), prevent unregistering of GIC SGIs.
- Force SPARSEMEM_VMEMMAP as the only memory model, it saves with
having to test all the other combinations.
- Documentation fixes and updates: tagged address ABI exceptions on
brk/mmap/mremap(), event stream frequency, update booting
requirements on the configuration of traps"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: kernel: Update the stale comment
arm64: Fix the documented event stream frequency
arm64: entry: always set GIC_PRIO_PSR_I_SET during entry
arm64: Explicitly document boot requirements for SVE
arm64: Explicitly require that FPSIMD instructions do not trap
arm64: Relax booting requirements for configuration of traps
arm64: cpufeatures: use min and max
arm64: stacktrace: restore terminal records
arm64/vdso: Discard .note.gnu.property sections in vDSO
arm64: doc: Add brk/mmap/mremap() to the Tagged Address ABI Exceptions
psci: Remove unneeded semicolon
ACPI: irq: Prevent unregistering of GIC SGIs
ACPI: GTDT: Don't corrupt interrupt mappings on watchdow probe failure
arm64: Show three registers per line
arm64: remove HAVE_DEBUG_BUGVERBOSE
arm64: alternative: simplify passing alt_region
arm64: Force SPARSEMEM_VMEMMAP as the only memory management model
arm64: vdso32: drop -no-integrated-as flag
It should be 10KHz, matching the ARCH_TIMER_EVT_STREAM_PERIOD_US of
100us.
Note that this is only a documentation bug.
Fixes: 611a7bc74ed2 ("arm64: docs: describe ELF hwcaps")
Cc: Mark Rutland <mark.rutland@arm.com>
Link: https://lore.kernel.org/r/20210505132845.23698-1-catalin.marinas@arm.com
We do not currently document the requirements for configuration of the
SVE system registers when booting the kernel, let's do so for completeness.
We don't have a hard requirement that the vector lengths configured on
different CPUs on initial boot be consistent since we have logic to
constrain to the minimum supported value but we will reject any late CPUs
which can't support the current maximum and introducing the concept of
late CPUs seemed more complex than was useful so we require that all CPUs
use the same value.
Link: https://lore.kernel.org/r/20210412151955.16078-4-broonie@kernel.org
We do not explicitly require that systems with FPSIMD support and EL3 have
disabled EL3 traps when the kernel is started, while it is unlikely that
systems will get this wrong for the sake of completeness let's spell it
out.
Link: https://lore.kernel.org/r/20210412151955.16078-3-broonie@kernel.org
Currently we require that a number of system registers be configured to
disable traps when starting the kernel. Add an explicit note that the
requirement is that the system behave as if the traps are disabled so
transparent handling of the traps is fine, this should be implicit for
people familiar with working with standards documents but it doesn't hurt
to be explicit.
Link: https://lore.kernel.org/r/20210412151955.16078-2-broonie@kernel.org
Prior to commit dcde237319e6 ("mm: Avoid creating virtual address
aliases in brk()/mmap()/mremap()"), the kernel allowed tagged addresses
to be passed to the brk/mmap/mremap() syscalls. This relaxation was
tightened in 5.6 (backported to stable 5.4) but the
tagged-address-abi.rst document was only partially updated.
Fixes: dcde237319e6 ("mm: Avoid creating virtual address aliases in brk()/mmap()/mremap()")
Reported-by: Peter Maydell <peter.maydell@linaro.org>
Link: https://lore.kernel.org/r/20210423175134.14838-1-catalin.marinas@arm.com
Pull arm64 updates from Catalin Marinas:
- MTE asynchronous support for KASan. Previously only synchronous
(slower) mode was supported. Asynchronous is faster but does not
allow precise identification of the illegal access.
- Run kernel mode SIMD with softirqs disabled. This allows using NEON
in softirq context for crypto performance improvements. The
conditional yield support is modified to take softirqs into account
and reduce the latency.
- Preparatory patches for Apple M1: handle CPUs that only have the VHE
mode available (host kernel running at EL2), add FIQ support.
- arm64 perf updates: support for HiSilicon PA and SLLC PMU drivers,
new functions for the HiSilicon HHA and L3C PMU, cleanups.
- Re-introduce support for execute-only user permissions but only when
the EPAN (Enhanced Privileged Access Never) architecture feature is
available.
- Disable fine-grained traps at boot and improve the documented boot
requirements.
- Support CONFIG_KASAN_VMALLOC on arm64 (only with KASAN_GENERIC).
- Add hierarchical eXecute Never permissions for all page tables.
- Add arm64 prctl(PR_PAC_{SET,GET}_ENABLED_KEYS) allowing user programs
to control which PAC keys are enabled in a particular task.
- arm64 kselftests for BTI and some improvements to the MTE tests.
- Minor improvements to the compat vdso and sigpage.
- Miscellaneous cleanups.
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (86 commits)
arm64/sve: Add compile time checks for SVE hooks in generic functions
arm64/kernel/probes: Use BUG_ON instead of if condition followed by BUG.
arm64: pac: Optimize kernel entry/exit key installation code paths
arm64: Introduce prctl(PR_PAC_{SET,GET}_ENABLED_KEYS)
arm64: mte: make the per-task SCTLR_EL1 field usable elsewhere
arm64/sve: Remove redundant system_supports_sve() tests
arm64: fpsimd: run kernel mode NEON with softirqs disabled
arm64: assembler: introduce wxN aliases for wN registers
arm64: assembler: remove conditional NEON yield macros
kasan, arm64: tests supports for HW_TAGS async mode
arm64: mte: Report async tag faults before suspend
arm64: mte: Enable async tag check fault
arm64: mte: Conditionally compile mte_enable_kernel_*()
arm64: mte: Enable TCO in functions that can read beyond buffer limits
kasan: Add report for async mode
arm64: mte: Drop arch_enable_tagging()
kasan: Add KASAN mode kernel parameter
arm64: mte: Add asynchronous mode support
arm64: Get rid of CONFIG_ARM64_VHE
arm64: Cope with CPUs stuck in VHE mode
* for-next/pac-set-get-enabled-keys:
: Introduce arm64 prctl(PR_PAC_{SET,GET}_ENABLED_KEYS).
'for-next/vdso', 'for-next/fiq', 'for-next/epan', 'for-next/kasan-vmalloc', 'for-next/fgt-boot-init', 'for-next/vhe-only' and 'for-next/neon-softirqs-disabled', remote-tracking branch 'arm64/for-next/perf' into for-next/core
* for-next/misc:
: Miscellaneous patches
arm64: mte: Remove unused mte_assign_mem_tag_range()
arm64: Add __init section marker to some functions
arm64/sve: Rework SVE access trap to convert state in registers
docs: arm64: Fix a grammar error
arm64: smp: Add missing prototype for some smp.c functions
arm64: setup: name `tcr` register
arm64: setup: name `mair` register
arm64: stacktrace: Move start_backtrace() out of the header
arm64: barrier: Remove spec_bar() macro
arm64: entry: remove test_irqs_unmasked macro
ARM64: enable GENERIC_FIND_FIRST_BIT
arm64: defconfig: Use DEBUG_INFO_REDUCED
: Various kselftests for arm64
kselftest: arm64: Add BTI tests
kselftest/arm64: mte: Report filename on failing temp file creation
kselftest/arm64: mte: Fix clang warning
kselftest/arm64: mte: Makefile: Fix clang compilation
kselftest/arm64: mte: Output warning about failing compiler
kselftest/arm64: mte: Use cross-compiler if specified
kselftest/arm64: mte: Fix MTE feature detection
kselftest/arm64: mte: common: Fix write() warnings
kselftest/arm64: mte: user_mem: Fix write() warning
kselftest/arm64: mte: ksm_options: Fix fscanf warning
kselftest/arm64: mte: Fix pthread linking
kselftest/arm64: mte: Fix compilation with native compiler
* for-next/xntable:
: Add hierarchical XN permissions for all page tables
arm64: mm: use XN table mapping attributes for user/kernel mappings
arm64: mm: use XN table mapping attributes for the linear region
arm64: mm: add missing P4D definitions and use them consistently
* for-next/vdso:
: Minor improvements to the compat vdso and sigpage
arm64: compat: Poison the compat sigpage
arm64: vdso: Avoid ISB after reading from cntvct_el0
arm64: compat: Allow signal page to be remapped
arm64: vdso: Remove redundant calls to flush_dcache_page()
arm64: vdso: Use GFP_KERNEL for allocating compat vdso and signal pages
* for-next/fiq:
: Support arm64 FIQ controller registration
arm64: irq: allow FIQs to be handled
arm64: Always keep DAIF.[IF] in sync
arm64: entry: factor irq triage logic into macros
arm64: irq: rework root IRQ handler registration
arm64: don't use GENERIC_IRQ_MULTI_HANDLER
genirq: Allow architectures to override set_handle_irq() fallback
* for-next/epan:
: Support for Enhanced PAN (execute-only permissions)
arm64: Support execute-only permissions with Enhanced PAN
* for-next/kasan-vmalloc:
: Support CONFIG_KASAN_VMALLOC on arm64
arm64: Kconfig: select KASAN_VMALLOC if KANSAN_GENERIC is enabled
arm64: kaslr: support randomized module area with KASAN_VMALLOC
arm64: Kconfig: support CONFIG_KASAN_VMALLOC
arm64: kasan: abstract _text and _end to KERNEL_START/END
arm64: kasan: don't populate vmalloc area for CONFIG_KASAN_VMALLOC
* for-next/fgt-boot-init:
: Booting clarifications and fine grained traps setup
arm64: Require that system registers at all visible ELs be initialized
arm64: Disable fine grained traps on boot
arm64: Document requirements for fine grained traps at boot
* for-next/vhe-only:
: Dealing with VHE-only CPUs (a.k.a. M1)
arm64: cpufeature: Allow early filtering of feature override
arm64: perf: Remove redundant initialization in perf_event.c
perf/arm_pmu_platform: Clean up with dev_printk
perf/arm_pmu_platform: Fix error handling
perf/arm_pmu_platform: Use dev_err_probe() for IRQ errors
docs: perf: Address some html build warnings
docs: perf: Add new description on HiSilicon uncore PMU v2
drivers/perf: hisi: Add support for HiSilicon PA PMU driver
drivers/perf: hisi: Add support for HiSilicon SLLC PMU driver
drivers/perf: hisi: Update DDRC PMU for programmable counter
drivers/perf: hisi: Add new functions for HHA PMU
drivers/perf: hisi: Add new functions for L3C PMU
drivers/perf: hisi: Add PMU version for uncore PMU drivers.
drivers/perf: hisi: Refactor code for more uncore PMUs
drivers/perf: hisi: Remove unnecessary check of counter index
drivers/perf: Simplify the SMMUv3 PMU event attributes
drivers/perf: convert sysfs sprintf family to sysfs_emit
drivers/perf: convert sysfs scnprintf family to sysfs_emit_at() and sysfs_emit()
drivers/perf: convert sysfs snprintf family to sysfs_emit
* for-next/neon-softirqs-disabled:
: Run kernel mode SIMD with softirqs disabled
This change introduces a prctl that allows the user program to control
which PAC keys are enabled in a particular task. The main reason
why this is useful is to enable a userspace ABI that uses PAC to
sign and authenticate function pointers and other pointers exposed
outside of the function, while still allowing binaries conforming
to the ABI to interoperate with legacy binaries that do not sign or
authenticate pointers.
The idea is that a dynamic loader or early startup code would issue
this prctl very early after establishing that a process may load legacy
binaries, but before executing any PAC instructions.
This change adds a small amount of overhead to kernel entry and exit
due to additional required instruction sequences.
On a DragonBoard 845c (Cortex-A75) with the powersave governor, the
overhead of similar instruction sequences was measured as 4.9ns when
simulating the common case where IA is left enabled, or 43.7ns when
simulating the uncommon case where IA is disabled. These numbers can
be seen as the worst case scenario, since in more realistic scenarios
a better performing governor would be used and a newer chip would be
used that would support PAC unlike Cortex-A75 and would be expected
to be faster than Cortex-A75.
On an Apple M1 under a hypervisor, the overhead of the entry/exit
instruction sequences introduced by this patch was measured as 0.3ns
in the case where IA is left enabled, and 33.0ns in the case where
IA is disabled.
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
Link: https://linux-review.googlesource.com/id/Ibc41a5e6a76b275efbaa126b31119dc197b927a5
Link: https://lore.kernel.org/r/d6609065f8f40397a4124654eb68c9f490b4d477.1616123271.git.pcc@google.com
Currently we require that software at a higher exception level initialise
all registers at the exception level the kernel will be entered prior to
starting the kernel in order to ensure that there is nothing uninitialised
which could result in an UNKNOWN state while running the kernel. The
expectation is that the software running at the highest exception levels
will be tightly coupled to the system and can ensure that all available
features are appropriately initialised and that the kernel can initialise
anything else.
There is a gap here in the case where new registers are added to lower
exception levels that require initialisation but the kernel does not yet
understand them. Extend the requirement to also include exception levels
below the one where the kernel is entered to cover this.
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Link: https://lore.kernel.org/r/20210401180942.35815-4-broonie@kernel.org
The arm64 FEAT_FGT extension introduces a set of traps to EL2 for accesses
to small sets of registers and instructions from EL1 and EL0, access to
which is controlled by EL3. Require access to it so that it is
available to us in future and so that we can ensure these traps are
disabled during boot.
Link: https://lore.kernel.org/r/20210401180942.35815-2-broonie@kernel.org
depending -> depending on
Signed-off-by: He Ying <heying24@huawei.com>
Link: https://lore.kernel.org/r/20210330085817.86185-1-heying24@huawei.com
On NVIDIA Carmel cores, CNP behaves differently than it does on standard
ARM cores. On Carmel, if two cores have CNP enabled and share an L2 TLB
entry created by core0 for a specific ASID, a non-shareable TLBI from
core1 may still see the shared entry. On standard ARM cores, that TLBI
will invalidate the shared entry as well.
This causes issues with patchsets that attempt to do local TLBIs based
on cpumasks instead of broadcast TLBIs. Avoid these issues by disabling
CNP support for NVIDIA Carmel cores.
Signed-off-by: Rich Wiley <rwiley@nvidia.com>
Link: https://lore.kernel.org/r/20210324002809.30271-1-rwiley@nvidia.com
[will: Fix pre-existing whitespace issue]
In commit 94bccc340710 ("iscsi_ibft: make ISCSI_IBFT dependson ACPI instead
of ISCSI_IBFT_FIND") Kconfig was disentangled to make ISCSI_IBFT selection
not depend on x86.
Update arm64 acpi documentation, changing IBFT support status from
"Not Supported" to "Optional".
Opportunistically re-flow paragraph for changed lines.
Link: https://lore.kernel.org/lkml/1563475054-10680-1-git-send-email-thomas.tai@oracle.com/
Signed-off-by: Tom Saeger <tom.saeger@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Link: https://lore.kernel.org/r/9efc652df2b8d6b53d9acb170eb7c9ca3938dfef.1615920441.git.tom.saeger@oracle.com
Pull KVM updates from Paolo Bonzini:
"Much x86 work was pushed out to 5.12, but ARM more than made up for it.
ARM:
- PSCI relay at EL2 when "protected KVM" is enabled
- New exception injection code
- Simplification of AArch32 system register handling
- Fix PMU accesses when no PMU is enabled
- Expose CSV3 on non-Meltdown hosts
- Cache hierarchy discovery fixes
- PV steal-time cleanups
- Allow function pointers at EL2
- Various host EL2 entry cleanups
- Simplification of the EL2 vector allocation
s390:
- memcg accouting for s390 specific parts of kvm and gmap
- selftest for diag318
- new kvm_stat for when async_pf falls back to sync
x86:
- Tracepoints for the new pagetable code from 5.10
- Catch VFIO and KVM irqfd events before userspace
- Reporting dirty pages to userspace with a ring buffer
- SEV-ES host support
- Nested VMX support for wait-for-SIPI activity state
- New feature flag (AVX512 FP16)
- New system ioctl to report Hyper-V-compatible paravirtualization features
Generic:
- Selftest improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (171 commits)
KVM: SVM: fix 32-bit compilation
KVM: SVM: Add AP_JUMP_TABLE support in prep for AP booting
KVM: SVM: Provide support to launch and run an SEV-ES guest
KVM: SVM: Provide an updated VMRUN invocation for SEV-ES guests
KVM: SVM: Provide support for SEV-ES vCPU loading
KVM: SVM: Provide support for SEV-ES vCPU creation/loading
KVM: SVM: Update ASID allocation to support SEV-ES guests
KVM: SVM: Set the encryption mask for the SVM host save area
KVM: SVM: Add NMI support for an SEV-ES guest
KVM: SVM: Guest FPU state save/restore not needed for SEV-ES guest
KVM: SVM: Do not report support for SMM for an SEV-ES guest
KVM: x86: Update __get_sregs() / __set_sregs() to support SEV-ES
KVM: SVM: Add support for CR8 write traps for an SEV-ES guest
KVM: SVM: Add support for CR4 write traps for an SEV-ES guest
KVM: SVM: Add support for CR0 write traps for an SEV-ES guest
KVM: SVM: Add support for EFER write traps for an SEV-ES guest
KVM: SVM: Support string IO operations for an SEV-ES guest
KVM: SVM: Support MMIO for an SEV-ES guest
KVM: SVM: Create trace events for VMGEXIT MSR protocol processing
KVM: SVM: Create trace events for VMGEXIT processing
Pull documentation updates from Jonathan Corbet:
"A much quieter cycle for documentation (happily), with, one hopes, the
bulk of the churn behind us. Significant stuff in this pull includes:
- A set of new Chinese translations
- Italian translation updates
- A mechanism from Mauro to automatically format
Documentation/features for the built docs
- Automatic cross references without explicit :ref: markup
- A new reset-controller document
- An extensive new document on reporting problems from Thorsten
That last patch also adds the CC-BY-4.0 license to LICENSES/dual;
there was some discussion on this, but we seem to have consensus and
an ack from Greg for that addition"
* tag 'docs-5.11' of git://git.lwn.net/linux: (50 commits)
docs: fix broken cross reference in translations/zh_CN
docs: Note that sphinx 1.7 will be required soon
docs: update requirements to install six module
docs: reporting-issues: move 'outdated, need help' note to proper place
docs: Update documentation to reflect what TAINT_CPU_OUT_OF_SPEC means
docs: add a reset controller chapter to the driver API docs
docs: make reporting-bugs.rst obsolete
docs: Add a new text describing how to report bugs
LICENSES: Add the CC-BY-4.0 license
Documentation: fix multiple typos found in the admin-guide subdirectory
Documentation: fix typos found in admin-guide subdirectory
kernel-doc: Fix example in Nested structs/unions
docs: clean up sysctl/kernel: titles, version
docs: trace: fix event state structure name
docs: nios2: add missing ReST file
scripts: get_feat.pl: reduce table width for all features output
scripts: get_feat.pl: change the group by order
scripts: get_feat.pl: make complete table more coincise
scripts: kernel-doc: fix parsing function-like typedefs
Documentation: fix typos found in process, dev-tools, and doc-guide subdirectories
'for-next/lto', 'for-next/mem-hotplug', 'for-next/cppc-ffh', 'for-next/pad-image-header', 'for-next/zone-dma-default-32-bit', 'for-next/signal-tag-bits' and 'for-next/cmdline-extended' into for-next/core
* for-next/kvm-build-fix:
: Fix KVM build issues with 64K pages
KVM: arm64: Fix build error in user_mem_abort()
* for-next/va-refactor:
: VA layout changes
arm64: mm: don't assume struct page is always 64 bytes
Documentation/arm64: fix RST layout of memory.rst
arm64: mm: tidy up top of kernel VA space
arm64: mm: make vmemmap region a projection of the linear region
arm64: mm: extend linear region for 52-bit VA configurations
* for-next/lto:
: Upgrade READ_ONCE() to RCpc acquire on arm64 with LTO
arm64: lto: Strengthen READ_ONCE() to acquire when CONFIG_LTO=y
arm64: alternatives: Remove READ_ONCE() usage during patch operation
arm64: cpufeatures: Add capability for LDAPR instruction
arm64: alternatives: Split up alternative.h
arm64: uaccess: move uao_* alternatives to asm-uaccess.h
* for-next/mem-hotplug:
: Memory hotplug improvements
arm64/mm/hotplug: Ensure early memory sections are all online
arm64/mm/hotplug: Enable MEM_OFFLINE event handling
arm64/mm/hotplug: Register boot memory hot remove notifier earlier
arm64: mm: account for hotplug memory when randomizing the linear region
* for-next/cppc-ffh:
: Add CPPC FFH support using arm64 AMU counters
arm64: abort counter_read_on_cpu() when irqs_disabled()
arm64: implement CPPC FFH support using AMUs
arm64: split counter validation function
arm64: wrap and generalise counter read functions
* for-next/pad-image-header:
: Pad Image header to 64KB and unmap it
arm64: head: tidy up the Image header definition
arm64/head: avoid symbol names pointing into first 64 KB of kernel image
arm64: omit [_text, _stext) from permanent kernel mapping
* for-next/zone-dma-default-32-bit:
: Default to 32-bit wide ZONE_DMA (previously reduced to 1GB for RPi4)
of: unittest: Fix build on architectures without CONFIG_OF_ADDRESS
mm: Remove examples from enum zone_type comment
arm64: mm: Set ZONE_DMA size based on early IORT scan
arm64: mm: Set ZONE_DMA size based on devicetree's dma-ranges
of: unittest: Add test for of_dma_get_max_cpu_address()
of/address: Introduce of_dma_get_max_cpu_address()
arm64: mm: Move zone_dma_bits initialization into zone_sizes_init()
arm64: mm: Move reserve_crashkernel() into mem_init()
arm64: Force NO_BLOCK_MAPPINGS if crashkernel reservation is required
arm64: Ignore any DMA offsets in the max_zone_phys() calculation
* for-next/signal-tag-bits:
: Expose the FAR_EL1 tag bits in siginfo
arm64: expose FAR_EL1 tag bits in siginfo
signal: define the SA_EXPOSE_TAGBITS bit in sa_flags
signal: define the SA_UNSUPPORTED bit in sa_flags
arch: provide better documentation for the arch-specific SA_* flags
signal: clear non-uapi flag bits when passing/returning sa_flags
arch: move SA_* definitions to generic headers
parisc: start using signal-defs.h
parisc: Drop parisc special case for __sighandler_t
* for-next/cmdline-extended:
: Add support for CONFIG_CMDLINE_EXTENDED
arm64: Extend the kernel command line from the bootloader
arm64: kaslr: Refactor early init command line parsing
Add a feature list matrix for each architecture to their
respective Kernel books.
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
Link: https://lore.kernel.org/r/9c39d4dd93e05c0008205527d2c3450912f029ed.1606748711.git.mchehab+huawei@kernel.org
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This is a Chinese translated version of
Documentation/arm64/elf_hwcaps.rst
Signed-off-by: Bailu Lin <bailu.lin@vivo.com>
Reviewed-by: Alex Shi <alex.shi@linux.alibaba.com>
Link: https://lore.kernel.org/r/20201124023846.34826-1-bailu.lin@vivo.com
The kernel currently clears the tag bits (i.e. bits 56-63) in the fault
address exposed via siginfo.si_addr and sigcontext.fault_address. However,
the tag bits may be needed by tools in order to accurately diagnose
memory errors, such as HWASan [1] or future tools based on the Memory
Tagging Extension (MTE).
Expose these bits via the arch_untagged_si_addr mechanism, so that
they are only exposed to signal handlers with the SA_EXPOSE_TAGBITS
flag set.
[1] http://clang.llvm.org/docs/HardwareAssistedAddressSanitizerDesign.html
Link: https://linux-review.googlesource.com/id/Ia8876bad8c798e0a32df7c2ce1256c4771c81446
Link: https://lore.kernel.org/r/0010296597784267472fa13b39f8238d87a72cf8.1605904350.git.pcc@google.com
Since ARM64_HARDEN_EL2_VECTORS is really a mitigation for Spectre-v3a,
rename it accordingly for consistency with the v2 and v4 mitigation.
Cc: Marc Zyngier <maz@kernel.org>
Cc: Quentin Perret <qperret@google.com>
Link: https://lore.kernel.org/r/20201113113847.21619-9-will@kernel.org
Documentation/arm64/perf.rst
Link: https://lore.kernel.org/r/20201030040541.8733-1-bailu.lin@vivo.com
Stephen reports that commit f4693c2716b3 ("arm64: mm: extend linear region
for 52-bit VA configurations") triggers the following warnings when building
the htmldocs make target of today's linux-next:
Documentation/arm64/memory.rst:35: WARNING: Literal block ends without a blank line; unexpected unindent.
Documentation/arm64/memory.rst:53: WARNING: Literal block ends without a blank line; unexpected unindent.
Let's tweak the memory layout table to work around this.
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Fixes: f4693c2716b3 ("arm64: mm: extend linear region for 52-bit VA configurations")
Link: https://lore.kernel.org/r/20201110130851.15751-1-ardb@kernel.org
Tidy up the way the top of the kernel VA space is organized, by mirroring
the 256 MB region we have below the vmalloc space, and populating it top
down with the PCI I/O space, some guard regions, and the fixmap region.
The latter region is itself populated top down, and today only covers
about 4 MB, and so 224 MB is ample, and no guard region is therefore
required.
The resulting layout is identical between 48-bit/4k and 52-bit/64k
configurations.
Reviewed-by: Steve Capper <steve.capper@arm.com>
Link: https://lore.kernel.org/r/20201008153602.9467-5-ardb@kernel.org
Now that we have reverted the introduction of the vmemmap struct page
pointer and the separate physvirt_offset, we can simplify things further,
and place the vmemmap region in the VA space in such a way that virtual
to page translations and vice versa can be implemented using a single
arithmetic shift.
One happy coincidence resulting from this is that the 48-bit/4k and
52-bit/64k configurations (which are assumed to be the two most
prevalent) end up with the same placement of the vmemmap region. In
a subsequent patch, we will take advantage of this, and unify the
memory maps even more.
Link: https://lore.kernel.org/r/20201008153602.9467-4-ardb@kernel.org
For historical reasons, the arm64 kernel VA space is configured as two
equally sized halves, i.e., on a 48-bit VA build, the VA space is split
into a 47-bit vmalloc region and a 47-bit linear region.
When support for 52-bit virtual addressing was added, this equal split
was kept, resulting in a substantial waste of virtual address space in
the linear region:
48-bit VA 52-bit VA
0xffff_ffff_ffff_ffff +-------------+ +-------------+
| vmalloc | | vmalloc |
0xffff_8000_0000_0000 +-------------+ _PAGE_END(48) +-------------+
| linear | : :
0xffff_0000_0000_0000 +-------------+ : :
: : : currently :
: unusable : : :
: : : unused :
: by : : :
: hardware : : :
0xfff8_0000_0000_0000 : : _PAGE_END(52) +-------------+
: unusable : | |
: : | linear |
: by : | |
: : | region |
: hardware : | |
0xfff0_0000_0000_0000 +-------------+ PAGE_OFFSET +-------------+
As illustrated above, the 52-bit VA kernel uses 47 bits for the vmalloc
space (as before), to ensure that a single 64k granule kernel image can
support any 64k granule capable system, regardless of whether it supports
the 52-bit virtual addressing extension. However, due to the fact that
the VA space is still split in equal halves, the linear region is only
2^51 bytes in size, wasting almost half of the 52-bit VA space.
Let's fix this, by abandoning the equal split, and simply assigning all
VA space outside of the vmalloc region to the linear region.
The KASAN shadow region is reconfigured so that it ends at the start of
the vmalloc region, and grows downwards. That way, the arrangement of
the vmalloc space (which contains kernel mappings, modules, BPF region,
the vmemmap array etc) is identical between non-KASAN and KASAN builds,
which aids debugging.
Link: https://lore.kernel.org/r/20201008153602.9467-3-ardb@kernel.org
On Cortex-A77 r0p0 and r1p0, a sequence of a non-cacheable or device load
and a store exclusive or PAR_EL1 read can cause a deadlock.
The workaround requires a DMB SY before and after a PAR_EL1 register
read. In addition, it's possible an interrupt (doing a device read) or
KVM guest exit could be taken between the DMB and PAR read, so we
also need a DMB before returning from interrupt and before returning to
a guest.
A deadlock is still possible with the workaround as KVM guests must also
have the workaround. IOW, a malicious guest can deadlock an affected
systems.
This workaround also depends on a firmware counterpart to enable the h/w
to insert DMB SY after load and store exclusive instructions. See the
errata document SDEN-1152370 v10 [1] for more information.
[1] https://static.docs.arm.com/101992/0010/Arm_Cortex_A77_MP074_Software_Developer_Errata_Notice_v10.pdf
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Cc: Julien Thierry <julien.thierry.kdev@gmail.com>
Cc: kvmarm@lists.cs.columbia.edu
Link: https://lore.kernel.org/r/20201028182839.166037-2-robh@kernel.org
On exception entry, the kernel explicitly resets the PSTATE.TCO (tag
check override) so that any kernel memory accesses will be checked (the
bit is restored on exception return). This has the side-effect that the
uaccess routines will not honour the PSTATE.TCO that may have been set
by the user prior to a syscall.
There is no issue in practice since PSTATE.TCO is expected to be used
only for brief periods in specific routines (e.g. garbage collection).
To control the tag checking mode of the uaccess routines, the user will
have to invoke a corresponding prctl() call.
Document the kernel behaviour w.r.t. PSTATE.TCO accordingly.
Fixes: df9d7a22dd21 ("arm64: mte: Add Memory Tagging Extension documentation")
Reviewed-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
Cc: Szabolcs Nagy <szabolcs.nagy@arm.com>
Pull documentation fixes from Jonathan Corbet:
"A handful of late-arriving documentation fixes"
* tag 'docs-5.10-2' of git://git.lwn.net/linux:
docs: Add two missing entries in vm sysctl index
docs/vm: trivial fixes to several spelling mistakes
docs: submitting-patches: describe preserving review/test tags
Documentation: Chinese translation of Documentation/arm64/hugetlbpage.rst
Documentation: x86: fix a missing word in x86_64/mm.rst.
docs: driver-api: remove a duplicated index entry
docs: lkdtm: Modernize and improve details
docs: deprecated.rst: Expand str*cpy() replacement notes
docs/cpu-load: format the example code.
Link: https://lore.kernel.org/r/20201014022003.43862-1-bailu.lin@vivo.com
"As hoped, things calmed down for docs this cycle; fewer changes and
almost no conflicts at all. This includes:
- A reworked and expanded user-mode Linux document
- Some simplifications and improvements for submitting-patches.rst
- An emergency fix for (some) problems with Sphinx 3.x
- Some welcome automarkup improvements to automatically generate
cross-references to struct definitions and other documents
- The usual collection of translation updates, typo fixes, etc"
* tag 'docs-5.10' of git://git.lwn.net/linux: (81 commits)
gpiolib: Update indentation in driver.rst for code excerpts
Documentation/admin-guide: tainted-kernels: Fix typo occured
Documentation: better locations for sysfs-pci, sysfs-tagging
docs: programming-languages: refresh blurb on clang support
Documentation: kvm: fix a typo
Documentation: Chinese translation of Documentation/arm64/amu.rst
doc: zh_CN: index files in arm64 subdirectory
mailmap: add entry for <mstarovoitov@marvell.com>
doc: seq_file: clarify role of *pos in ->next()
docs: trace: ring-buffer-design.rst: use the new SPDX tag
Documentation: kernel-parameters: clarify "module." parameters
Fix references to nommu-mmap.rst
docs: rewrite admin-guide/sysctl/abi.rst
docs: fb: Remove vesafb scrollback boot option
docs: fb: Remove sstfb scrollback boot option
docs: fb: Remove matroxfb scrollback boot option
docs: fb: Remove framebuffer scrollback boot option
docs: replace the old User Mode Linux HowTo with a new one
Documentation/admin-guide: blockdev/ramdisk: remove use of "rdev"
Documentation/admin-guide: README & svga: remove use of "rdev"
We offer both PTRACE_PEEKMTETAGS and PTRACE_POKEMTETAGS requests via
ptrace().
Reported-by: Andrey Konovalov <andreyknvl@google.com>
This is a Chinese translated version of Documentation/arm64/amu.rst
Link: https://lore.kernel.org/r/20200926025233.47214-1-bailu.lin@vivo.com
