Acked-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Link: https://lore.kernel.org/r/20210127104343.5647-1-wsa+renesas@sang-engineering.com
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Add info that "early_param()" kernel boot parameters are also listed
in kernel-parameters.txt.
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: linux-doc@vger.kernel.org
Link: https://lore.kernel.org/r/20201226174433.7885-1-rdunlap@infradead.org
architectures
early_param memmap is only implemented on X86, MIPS and XTENSA. To avoid
wasting users’ time on trying this on platform like ARM, mark it clearly.
Signed-off-by: Barry Song <song.bao.hua@hisilicon.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Link: https://lore.kernel.org/r/20201128195121.2556-1-song.bao.hua@hisilicon.com
Add device links after the devices are created (but before they are
probed) by looking at common DT bindings like clocks and
interconnects.
Automatically adding device links for functional dependencies at the
framework level provides the following benefits:
- Optimizes device probe order and avoids the useless work of
attempting probes of devices that will not probe successfully
(because their suppliers aren't present or haven't probed yet).
For example, in a commonly available mobile SoC, registering just
one consumer device's driver at an initcall level earlier than the
supplier device's driver causes 11 failed probe attempts before the
consumer device probes successfully. This was with a kernel with all
the drivers statically compiled in. This problem gets a lot worse if
all the drivers are loaded as modules without direct symbol
dependencies.
- Supplier devices like clock providers, interconnect providers, etc
need to keep the resources they provide active and at a particular
state(s) during boot up even if their current set of consumers don't
request the resource to be active. This is because the rest of the
consumers might not have probed yet and turning off the resource
before all the consumers have probed could lead to a hang or
undesired user experience.
Some frameworks (Eg: regulator) handle this today by turning off
"unused" resources at late_initcall_sync and hoping all the devices
have probed by then. This is not a valid assumption for systems with
loadable modules. Other frameworks (Eg: clock) just don't handle
this due to the lack of a clear signal for when they can turn off
resources. This leads to downstream hacks to handle cases like this
that can easily be solved in the upstream kernel.
By linking devices before they are probed, we give suppliers a clear
count of the number of dependent consumers. Once all of the
consumers are active, the suppliers can turn off the unused
resources without making assumptions about the number of consumers.
By default we just add device-links to track "driver presence" (probe
succeeded) of the supplier device. If any other functionality provided
by device-links are needed, it is left to the consumer/supplier
devices to change the link when they probe.
kbuild test robot reported clang error about missing const
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Saravana Kannan <saravanak@google.com>
Link: https://lore.kernel.org/r/20190904211126.47518-4-saravanak@google.com
Convert the m68k kernel-options.txt file to ReST.
The conversion is trivial, as the document is already on a format
close enough to ReST. Just some small adjustments were needed in
order to make it both good for being parsed while keeping it on
a good txt shape.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
The current ReStructuredText formatting results in "--", used to
indicate the end of the kernel command-line parameters, appearing as
an en-dash instead of two hyphens; this patch formats them as code,
"``--``", as done elsewhere in the documentation.
Signed-off-by: Stephen Kitt <steve@sk2.org>
Mostly due to x86 and acpi conversion, several documentation
links are still pointing to the old file. Fix them.
Reviewed-by: Wolfram Sang <wsa@the-dreams.de>
Reviewed-by: Sven Van Asbroeck <TheSven73@gmail.com>
Reviewed-by: Bhupesh Sharma <bhsharma@redhat.com>
Acked-by: Mark Brown <broonie@kernel.org>
Add ARM64 to the legend of architectures. It's already used in several
places in kernel-parameters.txt.
Suggested-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
The Analog Devices Blackfin port was added in 2007 and was rather
active for a while, but all work on it has come to a standstill
over time, as Analog have changed their product line-up.
Aaron Wu confirmed that the architecture port is no longer relevant,
and multiple people suggested removing blackfin independently because
of some of its oddities like a non-working SMP port, and the amount of
duplication between the chip variants, which cause extra work when
doing cross-architecture changes.
Link: https://docs.blackfin.uclinux.org/
Acked-by: Aaron Wu <Aaron.Wu@analog.com>
Acked-by: Bryan Wu <cooloney@gmail.com>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mike Frysinger <vapier@chromium.org>
The "isolcpus=" and "nohz_full=" boot parameters depend on CPU Isolation
support. Let's document that.
Signed-off-by: Frederic Weisbecker <frederic@kernel.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Wanpeng Li <kernellwp@gmail.com>
Cc: kernel test robot <xiaolong.ye@intel.com>
Link: http://lkml.kernel.org/r/1513275507-29200-4-git-send-email-frederic@kernel.org
Command line options allow us to ignore features that we don't want.
Also we can re-enable options that have been disabled on a platform
(so long as the underlying h/w actually supports the option).
[ tglx: Marked the option array __initdata and the helper function __init ]
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: Fenghua" <fenghua.yu@intel.com>
Cc: Ravi V" <ravi.v.shankar@intel.com>
Cc: "Peter Zijlstra" <peterz@infradead.org>
Cc: "Stephane Eranian" <eranian@google.com>
Cc: "Andi Kleen" <ak@linux.intel.com>
Cc: "David Carrillo-Cisneros" <davidcc@google.com>
Cc: Vikas Shivappa <vikas.shivappa@linux.intel.com>
Link: http://lkml.kernel.org/r/0c37b0d4dbc30977a3c1cee08b66420f83662694.1503512900.git.tony.luck@intel.com
Pull documentation update from Jonathan Corbet:
"A reasonably busy cycle for documentation this time around. There is a
new guide for user-space API documents, rather sparsely populated at
the moment, but it's a start. Markus improved the infrastructure for
converting diagrams. Mauro has converted much of the USB documentation
over to RST. Plus the usual set of fixes, improvements, and tweaks.
There's a bit more than the usual amount of reaching out of
Documentation/ to fix comments elsewhere in the tree; I have acks for
those where I could get them"
* tag 'docs-4.12' of git://git.lwn.net/linux: (74 commits)
docs: Fix a couple typos
docs: Fix a spelling error in vfio-mediated-device.txt
docs: Fix a spelling error in ioctl-number.txt
MAINTAINERS: update file entry for HSI subsystem
Documentation: allow installing man pages to a user defined directory
Doc/PM: Sync with intel_powerclamp code behavior
zr364xx.rst: usb/devices is now at /sys/kernel/debug/
usb.rst: move documentation from proc_usb_info.txt to USB ReST book
convert philips.txt to ReST and add to media docs
docs-rst: usb: update old usbfs-related documentation
arm: Documentation: update a path name
docs: process/4.Coding.rst: Fix a couple of document refs
docs-rst: fix usb cross-references
usb: gadget.h: be consistent at kernel doc macros
usb: composite.h: fix two warnings when building docs
usb: get rid of some ReST doc build errors
usb.rst: get rid of some Sphinx errors
usb/URB.txt: convert to ReST and update it
usb/persist.txt: convert to ReST and add to driver-api book
usb/hotplug.txt: convert to ReST and add to driver-api book
The AVR32 architecture support has been removed from the Linux kernel,
hence remove all references to it from Documentation.
Signed-off-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Håvard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
In Documentation/process/4.Coding.rst there were a couple of paragraphs
that spilled over the 80 character line length. This was likely caused
when the document was converted to reStructuredText. Re-flow the
paragraphs and make the document references proper reStructuredText
:ref: links.
This also adds the appropriate reStructuredText file heading to
kernel-parameters.rst as referenced by the kernel-parameters link in
this patch.
Signed-off-by: Andrew Clayton <andrew@digital-domain.net>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Fix typos in admin-guide directory.
Make documentation clear and grammatically correct.
Signed-off-by: Tamara Diaconita <diaconita.tamara@gmail.com>
Include the literal kernel parameter list from a separate file. This
helps the pdf build.
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
The admin guide is a good start, but it's time to turn it into something
better than an unordered blob of files. This is a first step in that
direction. The TOC has been split up and annotated, the guides have been
reordered, and minor tweaks have been applied to a few of them.
One consequence of splitting up the TOC is that we don't really want to use
:numbered: anymore, since the count resets every time and there doesn't
seem to be a way to change that. Eventually we probably want to group the
documents into sub-books, at which point we can go back to a single TOC,
but it's probably early to do that.
Reviewed-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
The previous patch renamed several files that are cross-referenced
along the Kernel documentation. Adjust the links to point to
the right places.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Place README, REPORTING-BUGS, SecurityBugs and kernel-parameters
on an user's manual book.
As we'll be numbering the user's manual, remove the manual
numbering from SecurityBugs.
