PREEMPT_RCU and TREE_PREEMPT_RCU serve the same function after
TINY_PREEMPT_RCU has been removed. This patch removes TREE_PREEMPT_RCU
and uses PREEMPT_RCU config option in its place.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
All other add functions for lists have the new item as first argument
and the position where it is added as second argument. This was changed
for no good reason in this function and makes using it unnecessary
confusing.
The name was changed to hlist_add_behind() to cause unconverted code to
generate a compile error instead of using the wrong parameter order.
Signed-off-by: Ken Helias <kenhelias@firemail.de>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> [intel driver bits]
This commit updates the list of RCU API members in whatisRCU.txt.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
These interfaces never did get used, so this commit removes them,
their rcutorture tests, and documentation referencing them.
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
One of the code samples in whatisRCU.txt shows a bug, but someone scanning
the document quickly might mistake it for a valid use of RCU. Add some
screaming comments to help keep speed-readers on track.
Reported-by: Nathan Zimmer <nzimmer@sgi.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
'srcu.2012.10.27a', 'stall.2012.11.13a', 'tracing.2012.11.08a' and 'idle.2012.10.24a' into HEAD
urgent.2012.10.27a: Fix for RCU user-mode transition (already in -tip).
doc.2012.11.08a: Documentation updates, most notably codifying the
memory-barrier guarantees inherent to grace periods.
fixes.2012.11.13a: Miscellaneous fixes.
srcu.2012.10.27a: Allow statically allocated and initialized srcu_struct
structures (courtesy of Lai Jiangshan).
stall.2012.11.13a: Add more diagnostic information to RCU CPU stall
warnings, also decrease from 60 seconds to 21 seconds.
hotplug.2012.11.08a: Minor updates to CPU hotplug handling.
tracing.2012.11.08a: Improved debugfs tracing, courtesy of Michael Wang.
idle.2012.10.24a: Updates to RCU idle/adaptive-idle handling, including
a boot parameter that maps normal grace periods to expedited.
Resolved conflict in kernel/rcutree.c due to side-by-side change.
The list_for_each_continue_rcu() macro is no longer used, so this commit
removes it. The list_for_each_entry_continue_rcu() macro should be
used instead.
Mention kfree_rcu() in the call_rcu() section. Additionally fix the
example code for list replacement that used the wrong structure element.
The current documentation did not help someone grepping for SRCU to
learn that disabling preemption is not a replacement for srcu_read_lock(),
so upgrade the documentation to bring this out, not just for SRCU,
but also for RCU-bh. Also document the fact that SRCU readers are
respected on CPUs executing in user mode, idle CPUs, and even on
offline CPUs.
The advent of call_srcu() and srcu_barrier() obsoleted some of the
documentation, so this commit brings that up to date.
Tyler Hicks pointed me at an additional article on RCU and I figured
it should probably be mentioned with the others.
Update various files in Documentation/RCU to reflect srcu_read_lock_raw()
and srcu_read_unlock_raw(). Credit to Peter Zijlstra for suggesting
use of the existing _raw suffix instead of the earlier bulkref names.
Reported-by: Paul Mackerras <paulus@samba.org>
Update examples and lists of APIs to include these new
primitives.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
Cc: eric.dumazet@gmail.com
LKML-Reference: <1270852752-25278-3-git-send-email-paulmck@linux.vnet.ibm.com>
Adds a lockdep.txt file and updates checklist.txt and
whatisRCU.txt to reflect the new lockdep-enabled capabilities of
RCU.
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-13-git-send-email-paulmck@linux.vnet.ibm.com>
Add expedited functions. Review documentation and update
obsolete verbiage. Also fix the advice for the RCU CPU-stall
kernel configuration parameter, and document RCU CPU-stall
warnings.
Cc: niv@us.ibm.com
LKML-Reference: <12635142581866-git-send-email->
Acked-by: Josh Triplett <josh@joshtriplett.org>
Cc: niv@us.ibm.com
Cc: avi@redhat.com
Cc: mtosatti@redhat.com
LKML-Reference: <12565226354176-git-send-email->
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no
further need for CONFIG_PREEMPT_RCU. Remove it, along with
whatever subtle bugs it may (or may not) contain.
Cc: akpm@linux-foundation.org
Cc: josht@linux.vnet.ibm.com
Cc: niv@us.ibm.com
LKML-Reference: <125097461396-git-send-email->
This patch updates the rcutorture documentation to include
updated output format. It also brings the RCU documentation up
to date.
Cc: torvalds@linux-foundation.org
Cc: davem@davemloft.net
Cc: dada1@cosmosbay.com
Cc: zbr@ioremap.net
Cc: jeff.chua.linux@gmail.com
Cc: paulus@samba.org
Cc: jengelh@medozas.de
Cc: r000n@r000n.net
Cc: benh@kernel.crashing.org
LKML-Reference: <12459460983193-git-send-email->
All of the in-tree uses of list_for_each_rcu() have been converted to
list_for_each_entry_rcu(), so list_for_each_rcu() can now be removed.
Long-delayed update to the RCU documentation, including adding the new
call_rcu_sched() and rcu_barrier_sched() APIs.
Updated patch adding a variant of RCU that permits sleeping in read-side
critical sections. SRCU is as follows:
o Each use of SRCU creates its own srcu_struct, and each
srcu_struct has its own set of grace periods. This is
critical, as it prevents one subsystem with a blocking
reader from holding up SRCU grace periods for other
subsystems.
o The SRCU primitives (srcu_read_lock(), srcu_read_unlock(),
and synchronize_srcu()) all take a pointer to a srcu_struct.
o The SRCU primitives must be called from process context.
o srcu_read_lock() returns an int that must be passed to
the matching srcu_read_unlock(). Realtime RCU avoids the
need for this by storing the state in the task struct,
but SRCU needs to allow a given code path to pass through
multiple SRCU domains -- storing state in the task struct
would therefore require either arbitrary space in the
task struct or arbitrary limits on SRCU nesting. So I
kicked the state-storage problem up to the caller.
Of course, it is not permitted to call synchronize_srcu()
while in an SRCU read-side critical section.
o There is no call_srcu(). It would not be hard to implement
one, but it seems like too easy a way to OOM the system.
(Hey, we have enough trouble with call_rcu(), which does
-not- permit readers to sleep!!!) So, if you want it,
please tell me why...
[josht@us.ibm.com: sparse notation]
Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com>
Signed-off-by: Josh Triplett <josh@freedesktop.org>
Remove many duplicated words under Documentation/ and do other small
cleanups.
Examples:
"and and" --> "and"
"in in" --> "in"
"the the" --> "the"
"the the" --> "to the"
Signed-off-by: Paolo Ornati <ornati@fastwebnet.it>
This patch fixes typos in various Documentation txts. The patch addresses
some words starting with the letter 'S'.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Acked-by: Alan Cox <alan@redhat.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Updater should use _rcu variant of list_del().
Signed-off-by: Urs Thuermann <urs@isnogud.escape.de>
Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com>
An update to the RCU documentation calling out the
self-limiting-update-rate advantages of synchronize_rcu(), and describing
how to use call_rcu() in a way that results in self-limiting updates.
Self-limiting updates are important to avoiding RCU-induced OOM in face of
denial-of-service attacks.
Remove synchronize_kernel() (deprecated 2-APR-2005 in
http://lkml.org/lkml/2005/4/3/11) and makes the RCU API inaccessible to
non-GPL Linux kernel modules (as was announced more than one year ago in
http://lkml.org/lkml/2005/4/3/8). Tested on x86 and ppc64.
Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com>
Replace for_each_cpu with for_each_possible_cpu.
Modifies occurences in documentaion.
for_each_cpu in whatisRCU.txt should be for_each_online_cpu ???
(I'm not sure..)
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The RCU documentation uses an fp variable which is not declared in the code
snippets. Use the new_fp variable instead.
Signed-Off-By: Baruch Even <baruch@ev-en.org>
Acked-by: <paulmck@us.ibm.com>
Updates to in-tree RCU documentation based on comments over the past few
months.
hlist_for_each_entry_rcu
Remove the hlist_for_each_rcu() API, which is used only in one place, and
is trivially converted to hlist_for_each_entry_rcu(), making the code
shorter and more readable. Any out-of-tree uses may be similarly
converted.
Update RCU documentation based on discussions and review of RCU-based tree
patches. Add an introductory whatisRCU.txt file.
Signed-off-by: <paulmck@us.ibm.com>
