path: root/Documentation/IPMI.txt
2010-03-12ipmi: add parameter to limit CPU usage in kipmidMartin Wilck
In some cases kipmid can use a lot of CPU. This adds a way to tune the CPU used by kipmid to help in those cases. By setting kipmid_max_busy_us to a value between 100 and 500, it is possible to bring down kipmid CPU load to practically 0 without loosing too much ipmi throughput performance. Not setting the value, or setting the value to zero, operation is unaffected. Signed-off-by: Martin Wilck <martin.wilck@ts.fujitsu.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18IPMI: new NMI handlingCorey Minyard
Convert over to the new NMI handling for getting IPMI watchdog timeouts via an NMI. This add config options to know if there is the ability to receive NMIs and if it has an NMI post processing call. Then it modifies the IPMI watchdog to take advantage of this so that it can know if an NMI comes in. It also adds testing that the IPMI NMI watchdog works. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18IPMI: documentation fixesCorey Minyard
Clean up IPMI documentation to remove references to high-res timers and add info about the polling thread. Also fix an doc error for a parameter. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] IPMI: system interface hotplugCorey Minyard
Add the ability to hot add and remove interfaces in the ipmi_si driver. Any users who have the device open will get errors if they try to send a message. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] IPMI: Allow hot system interface removeCorey Minyard
This modifies the IPMI driver so that a lower-level interface can be dynamically removed while in use so it can support hot-removal of hardware. It also adds the ability to specify and dynamically change the IPMI interface the watchdog timer and the poweroff code use. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] IPMI: allow user to override the kernel IPMI daemon enableCorey Minyard
After the previous patch to disable the kernel IPMI daemon if interrupts were available, the issue of broken hardware was raised, and a reasonable request to add an override was mode. So here it is. Allow the user to force the kernel ipmi daemon on or off. This way, hardware with broken interrupts or users that are not concerned with performance can turn it on or off to their liking. [akpm@osdl.org: save 4 bytes in vmlinux] Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] IPMI: per-channel command registrationCorey Minyard
This patch adds the ability to register for a command per-channel in the IPMI driver. If your BMC supports multiple channels, incoming messages can be useful to have the ability to register to receive commands on a specific channel instead the current behaviour of all channels. Signed-off-by: David Barksdale <amatus@ocgnet.org> Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] Documentation/IPMI typosMatt LaPlante
Two typos in Documentation/IPMI. Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] ipmi poweroff: fix chassis controlCorey Minyard
The IPMI power control function proc_write_chassctrl was badly written, it directly used userspace pointers, it assumed that strings were NULL terminated, and it used the evil sscanf function. This converts over to using the sysctl interface for this data and changes the semantics to be a little more logical. Signed-off-by: Corey Minyard <minyard@acm.org> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] ipmi: add power cycle capabilityCorey Minyard
This patch to adds "power cycle" functionality to the IPMI power off module ipmi_poweroff. It also contains changes to support procfs control of the feature. The power cycle action is considered an optional chassis control in the IPMI specification. However, it is definitely useful when the hardware supports it. A power cycle is usually required in order to reset a firmware in a bad state. This action is critical to allow remote management of servers. The implementation adds power cycle as optional to the ipmi_poweroff module. It can be modified dynamically through the proc entry mentioned above. During a power down and enabled, the power cycle command is sent to the BMC firmware. If it fails either due to non-support or some error, it will retry to send the command as power off. Signed-off-by: Christopher A. Poblete <Chris_Poblete@dell.com> Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] ipmi: doc updatesCorey Minyard
This cleans up the IPMI documentation to fix some problems and make it more accurate for the current drivers. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
