Pull MTD changes from Brian Norris:
- Unify some compile-time differences so that we have fewer uses of
#ifdef CONFIG_OF in atmel_nand
- Other general cleanups (removing unused functions, options,
variables, fields; use correct interfaces)
- Fix BUG() for new odd-sized NAND, which report non-power-of-2
dimensions via ONFI
- Miscellaneous driver fixes (SPI NOR flash; BCM47xx NAND flash; etc.)
- Improve differentiation between SLC and MLC NAND -- this clarifies an
ABI issue regarding the MTD "type" (in sysfs and in the MEMGETINFO
ioctl), where the MTD_MLCNANDFLASH type was present but
inconsistently used
- Extend GPMI NAND to support multi-chip-select NAND for some platforms
- Many improvements to the OMAP2/3 NAND driver, including an expanded
DT binding to bring us closer to mainline support for some OMAP
systems
- Fix a deadlock in the error path of the Atmel NAND driver probe
- Correct the error codes from MTD mmap() to conform to POSIX and the
Linux Programmer's Manual. This is an acknowledged change in the MTD
ABI, but I can't imagine somebody relying on the non-standard -ENOSYS
error code specifically. Am I just being unimaginative? :)
- Fix a few important GPMI NAND bugs (one regression from 3.12 and one
long-standing race condition)
- More? Read the log!
* tag 'for-linus-20131112' of git://git.infradead.org/linux-mtd: (98 commits)
mtd: gpmi: fix the NULL pointer
mtd: gpmi: fix kernel BUG due to racing DMA operations
mtd: mtdchar: return expected errors on mmap() call
mtd: gpmi: only scan two chips for imx6
mtd: gpmi: Use devm_kzalloc()
mtd: atmel_nand: fix bug driver will in a dead lock if no nand detected
mtd: nand: use a local variable to simplify the nand_scan_tail
mtd: nand: remove deprecated IRQF_DISABLED
mtd: dataflash: Say if we find a device we don't support
mtd: nand: omap: fix error return code in omap_nand_probe()
mtd: nand_bbt: kill NAND_BBT_SCANALLPAGES
mtd: m25p80: fixup device removal failure path
mtd: mxc_nand: Include linux/of.h header
mtd: remove duplicated include from mtdcore.c
mtd: m25p80: add support for Macronix mx25l3255e
mtd: nand: omap: remove selection of BCH ecc-scheme via KConfig
mtd: nand: omap: updated devm_xx for all resource allocation and free calls
mtd: nand: omap: use drivers/mtd/nand/nand_bch.c wrapper for BCH ECC instead of lib/bch.c
mtd: nand: omap: clean-up ecc layout for BCH ecc schemes
mtd: nand: omap2: clean-up BCHx_HW and BCHx_SW ECC configurations in device_probe
Pull networking updates from David Miller:
1) The addition of nftables. No longer will we need protocol aware
firewall filtering modules, it can all live in userspace.
At the core of nftables is a, for lack of a better term, virtual
machine that executes byte codes to inspect packet or metadata
(arriving interface index, etc.) and make verdict decisions.
Besides support for loading packet contents and comparing them, the
interpreter supports lookups in various datastructures as
fundamental operations. For example sets are supports, and
therefore one could create a set of whitelist IP address entries
which have ACCEPT verdicts attached to them, and use the appropriate
byte codes to do such lookups.
Since the interpreted code is composed in userspace, userspace can
do things like optimize things before giving it to the kernel.
Another major improvement is the capability of atomically updating
portions of the ruleset. In the existing netfilter implementation,
one has to update the entire rule set in order to make a change and
this is very expensive.
Userspace tools exist to create nftables rules using existing
netfilter rule sets, but both kernel implementations will need to
co-exist for quite some time as we transition from the old to the
new stuff.
Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have
worked so hard on this.
2) Daniel Borkmann and Hannes Frederic Sowa made several improvements
to our pseudo-random number generator, mostly used for things like
UDP port randomization and netfitler, amongst other things.
In particular the taus88 generater is updated to taus113, and test
cases are added.
3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet
and Yang Yingliang.
4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin
Sujir.
5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet,
Neal Cardwell, and Yuchung Cheng.
6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary
control message data, much like other socket option attributes.
From Francesco Fusco.
7) Allow applications to specify a cap on the rate computed
automatically by the kernel for pacing flows, via a new
SO_MAX_PACING_RATE socket option. From Eric Dumazet.
8) Make the initial autotuned send buffer sizing in TCP more closely
reflect actual needs, from Eric Dumazet.
9) Currently early socket demux only happens for TCP sockets, but we
can do it for connected UDP sockets too. Implementation from Shawn
Bohrer.
10) Refactor inet socket demux with the goal of improving hash demux
performance for listening sockets. With the main goals being able
to use RCU lookups on even request sockets, and eliminating the
listening lock contention. From Eric Dumazet.
11) The bonding layer has many demuxes in it's fast path, and an RCU
conversion was started back in 3.11, several changes here extend the
RCU usage to even more locations. From Ding Tianhong and Wang
Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav
Falico.
12) Allow stackability of segmentation offloads to, in particular, allow
segmentation offloading over tunnels. From Eric Dumazet.
13) Significantly improve the handling of secret keys we input into the
various hash functions in the inet hashtables, TCP fast open, as
well as syncookies. From Hannes Frederic Sowa. The key fundamental
operation is "net_get_random_once()" which uses static keys.
Hannes even extended this to ipv4/ipv6 fragmentation handling and
our generic flow dissector.
14) The generic driver layer takes care now to set the driver data to
NULL on device removal, so it's no longer necessary for drivers to
explicitly set it to NULL any more. Many drivers have been cleaned
up in this way, from Jingoo Han.
15) Add a BPF based packet scheduler classifier, from Daniel Borkmann.
16) Improve CRC32 interfaces and generic SKB checksum iterators so that
SCTP's checksumming can more cleanly be handled. Also from Daniel
Borkmann.
17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces
using the interface MTU value. This helps avoid PMTU attacks,
particularly on DNS servers. From Hannes Frederic Sowa.
18) Use generic XPS for transmit queue steering rather than internal
(re-)implementation in virtio-net. From Jason Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
random32: add test cases for taus113 implementation
random32: upgrade taus88 generator to taus113 from errata paper
random32: move rnd_state to linux/random.h
random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized
random32: add periodic reseeding
random32: fix off-by-one in seeding requirement
PHY: Add RTL8201CP phy_driver to realtek
xtsonic: add missing platform_set_drvdata() in xtsonic_probe()
macmace: add missing platform_set_drvdata() in mace_probe()
ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe()
ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh
vlan: Implement vlan_dev_get_egress_qos_mask as an inline.
ixgbe: add warning when max_vfs is out of range.
igb: Update link modes display in ethtool
netfilter: push reasm skb through instead of original frag skbs
ip6_output: fragment outgoing reassembled skb properly
MAINTAINERS: mv643xx_eth: take over maintainership from Lennart
net_sched: tbf: support of 64bit rates
ixgbe: deleting dfwd stations out of order can cause null ptr deref
ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS
Pull leftover IRQ fixes from Ingo Molnar:
"Two (minor) fixlets that missed v3.12"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
genirq: Set the irq thread policy without checking CAP_SYS_NICE
irq: DocBook/genericirq.tmpl: Correct various typos
Pull RCU updates from Ingo Molnar:
"The main RCU changes in this cycle are:
- Idle entry/exit changes, to throttle callback execution and other
refinements to speed up kbuild, primarily to address performance
issues located by Tibor Billes.
- Grace-period related changes, primarily to aid in debugging,
inspired by an -rt debugging session.
- Code reorganization moving RCU's source files into its own
kernel/rcu/ directory.
- RCU documentation updates
- Miscellaneous fixes.
Note, the following commit:
5c889690aa08 mm: Place preemption point in do_mlockall() loop
is identical to the commit already in your tree via email:
22356f447ceb mm: Place preemption point in do_mlockall() loop
[ Your version of the changelog nicely demonstrates it how kernel oops
messages should be trimmed properly :-/ ]"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits)
rcu: Move RCU-related source code to kernel/rcu directory
rcu: Fix occurrence of "the the" in checklist.txt
kthread: Add pointer to vmstat-avoidance patch
rcu: Update stall-warning documentation
rcu: Consistent rcu_is_watching() naming
rcu: Change EXPORT_SYMBOL() to EXPORT_SYMBOL_GPL()
rcu: Is it safe to enter an RCU read-side critical section?
rcu: Throttle invoke_rcu_core() invocations due to non-lazy callbacks
rcu: Throttle rcu_try_advance_all_cbs() execution
rcu: Remove redundant code from rcu_cleanup_after_idle()
rcu: Fix CONFIG_RCU_NOCB_CPU_ALL panic on machines with sparse CPU mask
rcu: Avoid sparse warnings in rcu_nocb_wake trace event
rcu: Track rcu_nocb_kthread()'s sleeping and awakening
rcu: Distinguish between NOCB and non-NOCB rcu_callback trace events
rcu: Add tracing for rcuo no-CBs CPU wakeup handshake
rcu: Add tracing of normal (non-NOCB) grace-period requests
rcu: Add tracing to rcu_gp_kthread()
rcu: Flag lockless access to ->gp_flags with ACCESS_ONCE()
rcu: Prevent spurious-wakeup DoS attack on rcu_gp_kthread()
rcu: Improve grace-period start logic
Now that the last user of NAND_BBT_SCANALLPAGES has been removed, let's
kill this peculiar BBT feature flag.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Reviewed-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Two functions were changed but their references weren't
updated in the docbook template, propagate the change.
Typo corrections for DocBook/genericirq.tmpl.
Link: http://lkml.kernel.org/r/5261D400.30400@infradead.org
Reviewed-by: Ingo Molnar <mingo@kernel.org>
With the previous changes, sysfs regular file code is ready to handle
bin files too. This patch makes bin files share the regular file
path.
* sysfs_create/remove_bin_file() are moved to fs/sysfs/file.c.
* sysfs_init_inode() is updated to use the new sysfs_bin_operations
instead of bin_fops for bin files.
* fs/sysfs/bin.c and the related pieces are removed.
This patch shouldn't introduce any behavior difference to bin file
accesses.
Overall, this unification reduces the amount of duplicate logic, makes
behaviors more consistent and paves the road for building simpler and
more versatile interface which will allow other subsystems to make use
of sysfs for their pseudo filesystems.
v2: Stale fs/sysfs/bin.c reference dropped from
Documentation/DocBook/filesystems.tmpl. Reported by kbuild test
robot.
Cc: Kay Sievers <kay@vrfy.org>
Cc: kbuild test robot <fengguang.wu@intel.com>
Pull mtd updates from David Woodhouse:
- factor out common code from MTD tests
- nand-gpio cleanup and portability to non-ARM
- m25p80 support for 4-byte addressing chips, other new chips
- pxa3xx cleanup and support for new platforms
- remove obsolete alauda, octagon-5066 drivers
- erase/write support for bcm47xxsflash
- improve detection of ECC requirements for NAND, controller setup
- NFC acceleration support for atmel-nand, read/write via SRAM
- etc
* tag 'for-linus-20130909' of git://git.infradead.org/linux-mtd: (184 commits)
mtd: chips: Add support for PMC SPI Flash chips in m25p80.c
mtd: ofpart: use for_each_child_of_node() macro
mtd: mtdswap: replace strict_strtoul() with kstrtoul()
mtd cs553x_nand: use kzalloc() instead of memset
mtd: atmel_nand: fix error return code in atmel_nand_probe()
mtd: bcm47xxsflash: writing support
mtd: bcm47xxsflash: implement erasing support
mtd: bcm47xxsflash: convert to module_platform_driver instead of init/exit
mtd: bcm47xxsflash: convert kzalloc to avoid invalid access
mtd: remove alauda driver
mtd: nand: mxc_nand: mark 'const' properly
mtd: maps: cfi_flagadm: add missing __iomem annotation
mtd: spear_smi: add missing __iomem annotation
mtd: r852: Staticize local symbols
mtd: nandsim: Staticize local symbols
mtd: impa7: add missing __iomem annotation
mtd: sm_ftl: Staticize local symbols
mtd: m25p80: add support for mr25h10
mtd: m25p80: make CONFIG_M25PXX_USE_FAST_READ safe to enable
mtd: m25p80: Pass flags through CAT25_INFO macro
Pull trivial tree from Jiri Kosina:
"The usual trivial updates all over the tree -- mostly typo fixes and
documentation updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits)
doc: Documentation/cputopology.txt fix typo
treewide: Convert retrun typos to return
Fix comment typo for init_cma_reserved_pageblock
Documentation/trace: Correcting and extending tracepoint documentation
mm/hotplug: fix a typo in Documentation/memory-hotplug.txt
power: Documentation: Update s2ram link
doc: fix a typo in Documentation/00-INDEX
Documentation/printk-formats.txt: No casts needed for u64/s64
doc: Fix typo "is is" in Documentations
treewide: Fix printks with 0x%#
zram: doc fixes
Documentation/kmemcheck: update kmemcheck documentation
doc: documentation/hwspinlock.txt fix typo
PM / Hibernate: add section for resume options
doc: filesystems : Fix typo in Documentations/filesystems
scsi/megaraid fixed several typos in comments
ppc: init_32: Fix error typo "CONFIG_START_KERNEL"
treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks
page_isolation: Fix a comment typo in test_pages_isolated()
doc: fix a typo about irq affinity
Pull networking changes from David Miller:
"Noteworthy changes this time around:
1) Multicast rejoin support for team driver, from Jiri Pirko.
2) Centralize and simplify TCP RTT measurement handling in order to
reduce the impact of bad RTO seeding from SYN/ACKs. Also, when
both timestamps and local RTT measurements are available prefer
the later because there are broken middleware devices which
scramble the timestamp.
From Yuchung Cheng.
3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel
memory consumed to queue up unsend user data. From Eric Dumazet.
4) Add a "physical port ID" abstraction for network devices, from
Jiri Pirko.
5) Add a "suppress" operation to influence fib_rules lookups, from
Stefan Tomanek.
6) Add a networking development FAQ, from Paul Gortmaker.
7) Extend the information provided by tcp_probe and add ipv6 support,
8) Use RCU locking more extensively in openvswitch data paths, from
Pravin B Shelar.
9) Add SCTP support to openvswitch, from Joe Stringer.
10) Add EF10 chip support to SFC driver, from Ben Hutchings.
11) Add new SYNPROXY netfilter target, from Patrick McHardy.
12) Compute a rate approximation for sending in TCP sockets, and use
this to more intelligently coalesce TSO frames. Furthermore, add
a new packet scheduler which takes advantage of this estimate when
available. From Eric Dumazet.
13) Allow AF_PACKET fanouts with random selection, from Daniel
Borkmann.
14) Add ipv6 support to vxlan driver, from Cong Wang"
Resolved conflicts as per discussion.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits)
openvswitch: Fix alignment of struct sw_flow_key.
netfilter: Fix build errors with xt_socket.c
tcp: Add missing braces to do_tcp_setsockopt
caif: Add missing braces to multiline if in cfctrl_linkup_request
bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize
vxlan: Fix kernel panic on device delete.
net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls
net: mvneta: properly disable HW PHY polling and ensure adjust_link() works
icplus: Use netif_running to determine device state
ethernet/arc/arc_emac: Fix huge delays in large file copies
tuntap: orphan frags before trying to set tx timestamp
tuntap: purge socket error queue on detach
qlcnic: use standard NAPI weights
ipv6:introduce function to find route for redirect
bnx2x: VF RSS support - VF side
bnx2x: VF RSS support - PF side
vxlan: Notify drivers for listening UDP port changes
net: usbnet: update addr_assign_type if appropriate
driver/net: enic: update enic maintainers and driver
driver/net: enic: Exposing symbols for Cisco's low latency driver
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"This series contains:
- Exynos s5p-mfc driver got support for VP8 encoder
- Some SoC drivers gained support for asynchronous registration
(needed for DT)
- The RC subsystem gained support for RC activity LED;
- New drivers added: a video decoder(adv7842), a video encoder
(adv7511), a new GSPCA driver (stk1135) and support for Renesas
R-Car (vsp1)
- the first SDR kernel driver: mirics msi3101. Due to some troubles
with the driver, and because the API is still under discussion, it
will be merged at staging for 3.12. Need to rework on it
- usual new boards additions, fixes, cleanups and driver
improvements"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (242 commits)
[media] cx88: Fix regression: CX88_AUDIO_WM8775 can't be 0
[media] exynos4-is: Fix entity unregistration on error path
[media] exynos-gsc: Register v4l2 device
[media] exynos4-is: Fix fimc-lite bayer formats
[media] em28xx: fix assignment of the eeprom data
[media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe()
[media] usbtv: Throw corrupted frames away
[media] usbtv: Fix deinterlacing
[media] v4l2: added missing mutex.h include to v4l2-ctrls.h
[media] DocBook: upgrade media_api DocBook version to 4.2
[media] ml86v7667: fix compile warning: 'ret' set but not used
[media] s5p-g2d: Fix registration failure
[media] media: coda: Fix DT driver data pointer for i.MX27
[media] s5p-mfc: Fix input/output format reporting
[media] v4l: vsp1: Fix mutex double lock at streamon time
[media] v4l: vsp1: Add support for RT clock
[media] v4l: vsp1: Initialize media device bus_info field
[media] davinci: vpif_capture: fix error return code in vpif_probe()
[media] davinci: vpif_display: fix error return code in vpif_probe()
[media] MAINTAINERS: add entries for adv7511 and adv7842
Fixes the last three errors of media_api DocBook validatation:
media_api.xml:414: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set
media_api.xml:432: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set
media_api.xml:452: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: stable@vger.kernel.org
into drm-next
Alex writes:
This is the radeon drm-next request. Big changes include:
- support for dpm on CIK parts
- support for ASPM on CIK parts
- support for berlin GPUs
- major ring handling cleanup
- remove the old 3D blit code for bo moves in favor of CP DMA or sDMA
- lots of bug fixes
[airlied: fix up a bunch of conflicts from drm_order removal]
* 'drm-next-3.12' of git://people.freedesktop.org/~agd5f/linux: (898 commits)
drm/radeon/dpm: make sure dc performance level limits are valid (CI)
drm/radeon/dpm: make sure dc performance level limits are valid (BTC-SI) (v2)
drm/radeon: gcc fixes for extended dpm tables
drm/radeon: gcc fixes for kb/kv dpm
drm/radeon: gcc fixes for ci dpm
drm/radeon: gcc fixes for si dpm
drm/radeon: gcc fixes for ni dpm
drm/radeon: gcc fixes for trinity dpm
drm/radeon: gcc fixes for sumo dpm
drm/radeonn: gcc fixes for rv7xx/eg/btc dpm
drm/radeon: gcc fixes for rv6xx dpm
drm/radeon: gcc fixes for radeon_atombios.c
drm/radeon: enable UVD interrupts on CIK
drm/radeon: fix init ordering for r600+
drm/radeon/dpm: only need to reprogram uvd if uvd pg is enabled
drm/radeon: check the return value of uvd_v1_0_start in uvd_v1_0_init
drm/radeon: split out radeon_uvd_resume from uvd_v4_2_resume
radeon kms: fix uninitialised hotplug work usage in r100_irq_process()
drm/radeon/audio: set up the sads on DCE3.2 asics
drm/radeon: fix handling of variable sized arrays for router objects
drivers/gpu/drm/i915/i915_dma.c
drivers/gpu/drm/i915/i915_gem_dmabuf.c
drivers/gpu/drm/i915/intel_pm.c
drivers/gpu/drm/radeon/cik.c
drivers/gpu/drm/radeon/ni.c
drivers/gpu/drm/radeon/r600.c
NAND_BBT_SCANEMPTY is a strange, badly-supported option with omap as its
single remaining user.
NAND_BBT_SCANEMPTY was likely used by accident in omap2[1]. And anyway,
omap2 doesn't scan the chip for bad blocks (courtesy of
NAND_SKIP_BBTSCAN), and so its use of this option is irrelevant.
This patch drops the NAND_BBT_SCANEMPTY option.
[1] http://lists.infradead.org/pipermail/linux-mtd/2012-July/042902.html
Cc: Ivan Djelic <ivan.djelic@parrot.com>
Render nodes provide an API for userspace to use non-privileged GPU
commands without any running DRM-Master. It is useful for offscreen
rendering, GPGPU clients, and normal render clients which do not perform
modesetting.
Compared to legacy clients, render clients no longer need any
authentication to perform client ioctls. Instead, user-space controls
render/client access to GPUs via filesystem access-modes on the
render-node. Once a render-node was opened, a client has full access to
the client/render operations on the GPU. However, no modesetting or ioctls
that affect global state are allowed on render nodes.
To prevent privilege-escalation, drivers must explicitly state that they
support render nodes. They must mark their render-only ioctls as
DRM_RENDER_ALLOW so render clients can use them. Furthermore, they must
support clients without any attached master.
If filesystem access-modes are not enough for fine-grained access control
to render nodes (very unlikely, considering the versaitlity of FS-ACLs),
you may still fall-back to fd-passing from server to client (which allows
arbitrary access-control). However, note that revoking access is
currently impossible and unlikely to get implemented.
Note: Render clients no longer have any associated DRM-Master as they are
supposed to be independent of any server state. DRM core highly depends on
file_priv->master to be non-NULL for modesetting/ctx/etc. commands.
Therefore, drivers must be very careful to not require DRM-Master if they
support DRIVER_RENDER.
So far render-nodes are protected by "drm_rnodes". As long as this
module-parameter is not set to 1, a driver will not create render nodes.
This allows us to experiment with the API a bit before we stabilize it.
v2: drop insecure GEM_FLINK to force use of dmabuf
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
drivers/net/wireless/iwlwifi/pcie/trans.c
Fix double words "is is" in Documentations.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Rob Landley <rob@landley.net>
> docproc: kernel/printk.c: No such file or directory
So rename the file.
Noticed-by: kbuild test robot <fengguang.wu@intel.com>
It has way too much potential for driver writers to do stupid things
like delayed hw setup because the load sequence is somehow racy (e.g.
the imx driver in staging). So don't call it for modesetting drivers,
which reduces the complexity of the drm core -> driver interface a
notch.
v2: Don't forget to update DocBook.
v3: Go with Laurent's slightly more elaborate proposal for the DocBook
update. Add a few words on top of his diff to elaborate a bit on what
KMS drivers should and shouldn't do in lastclose. There was already a
paragraph present talking about restoring properties, I've simply
extended that one.
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
I've forgotten this and shuffling all the little pieces into the
respective patches is rather cumbersome ...
A small helper to queue up work to do, from workqueue context, after a
flip. Typically useful to defer unreffing buffers that may be read by
the display controller until vblank.
v1: original
v2: wire up docbook + couple docbook fixes
Signed-off-by: Rob Clark <robdclark@gmail.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
So I've stumbled over drm_fasync and wondered what it does. Digging
that up is quite a story.
First I've had to read up on what this does and ended up being rather
bewildered why peopled loved signals so much back in the days that
they've created SIGIO just for that ...
Then I wondered how this ever works, and what that strange "No-op."
comment right above it should mean. After all calling the core fasync
helper is pretty obviously not a noop. After reading through the
kernels FASYNC implementation I've noticed that signals are only sent
out to the processes attached with FASYNC by calling kill_fasync.
No merged drm driver has ever done that.
After more digging I've found out that the only driver that ever used
this is the so called GAMMA driver. I've frankly never heard of such a
gpu brand ever before. Now FASYNC seems to not have been the only bad
thing with that driver, since Dave Airlie removed it from the drm
driver with prejudice:
commit 1430163b4bbf7b00367ea1066c1c5fe85dbeefed
Author: Dave Airlie <airlied@linux.ie>
Date: Sun Aug 29 12:04:35 2004 +0000
Drop GAMMA DRM from a great height ...
Long story short, the drm fasync support seems to be doing absolutely
nothing. And the only user of it was never merged into the upstream
kernel. And we don't need any fops->fasync callback since the fcntl
implementation in the kernel already implements the noop case
correctly.
So stop this particular cargo-cult and rip it all out.
v2: Kill drm_fasync assignments in rcar (newly added) and imx drivers
(somehow I've missed that one in staging). Also drop the reference in
the drm DocBook. ARM compile-fail reported by Rob Clark.
v3: Move the removal of dev->buf_asnyc assignment in drm_setup to this
patch here.
v4: Actually git add ... tsk.
Cc: Dave Airlie <airlied@linux.ie>
Cc: Rob Clark <robdclark@gmail.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
The sample code erroneously scales the y1, pb and pr variables from the
[0.0 .. 1.0] and [-0.5 .. 0.5] ranges to [0 .. 255] and [-128 .. 127].
Fix it.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Clarify that the il_vfrontporch, il_vsync and il_vbackporch fields must
always be 0 for progressive formats.
NV16M and NV61M are planar YCbCr 4:2:2 and YCrCb 4:2:2 formats with a
luma plane followed by an interleaved chroma plane. The planes are not
required to be contiguous in memory, and the formats can only be used
with the multi-planar formats API.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi>
The V4L2_MBUS_FMT_YUV10_1X30 code is documented as being equal to
0x2014, while the v4l2-mediabus.h header defines it as 0x2016. Fix the
documentation.
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
The VIDIOC_CREATE_BUFS ioctl takes a format argument that must contain a
valid format supported by the driver. Clarify the documentation.
This patch adds new V4L controls for VP8 encoding.
Signed-off-by: Kiran AVND <avnd.kiran@samsung.com>
Signed-off-by: Arun Kumar K <arun.kk@samsung.com>
Signed-off-by: Kamil Debski <k.debski@samsung.com>
A lot of drivers check the frame protocol for ETH_P_PAE,
for various reasons (like making those more reliable).
Add a new flags bitmap to the TX control info and a new
flag indicating the control port protocol is in use to
let all drivers also apply such logic to other control
port protocols, should they be configured.
Also use the new flag in the iwlwifi drivers.
Pull media fixes from Mauro Carvalho Chehab:
"Some driver fixes (em28xx, coda, usbtv, s5p, hdpvr and ml86v7667) and
a fix for media DocBook"
[media] usbtv: fix dependency
Make it easier to break up printk into bite-sized chunks.
Remove printk path/filename from comment.
Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Ming Lei <ming.lei@canonical.com>
All lirc drivers that can transmit, return EINVAL when they are passed
more than IR data than they can send. That is, except for two drivers
which I touched.
Signed-off-by: Sean Young <sean@mess.org>
Replace the erroneous V4L2_CID_JPEG_IMAGE_QUALITY control name
with V4L2_CID_JPEG_COMPRESSION_QUALITY.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
If we want to map GPU memory into user-space, we need to linearize the
addresses to not confuse mm-core. Currently, GEM and TTM both implement
their own offset-managers to assign a pgoff to each object for user-space
CPU access. GEM uses a hash-table, TTM uses an rbtree.
This patch provides a unified implementation that can be used to replace
both. TTM allows partial mmaps with a given offset, so we cannot use
hashtables as the start address may not be known at mmap time. Hence, we
use the rbtree-implementation of TTM.
We could easily update drm_mm to use an rbtree instead of a linked list
for it's object list and thus drop the rbtree from the vma-manager.
However, this would slow down drm_mm object allocation for all other
use-cases (rbtree insertion) and add another 4-8 bytes to each mm node.
Hence, use the separate tree but allow for later migration.
This is a rewrite of the 2012-proposal by David Airlie <airlied@linux.ie>
v2:
- fix Docbook integration
- drop drm_mm_node_linked() and use drm_mm_node_allocated()
- remove unjustified likely/unlikely usage (but keep for rbtree paths)
- remove BUG_ON() as drm_mm already does that
- clarify page-based vs. byte-based addresses
- use drm_vma_node_reset() for initialization, too
v4:
- allow external locking via drm_vma_offset_un/lock_lookup()
- add locked lookup helper drm_vma_offset_lookup_locked()
v5:
- fix drm_vma_offset_lookup() to correctly validate range-mismatches
(fix (offset > start + pages))
- fix drm_vma_offset_exact_lookup() to actually do what it says
- remove redundant vm_pages member (add drm_vma_node_size() helper)
- remove unneeded goto
- fix documentation
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Dave Airlie <airlied@gmail.com>
"This series contain:
- new i2c video drivers: ml86v7667 (video decoder),
ths8200 (video encoder)
- a new video driver for EasyCap cards based on Fushicai USBTV007
- Improved support for OF and embedded systems, with V4L2 async
initialization and a better support for clocks
- API cleanups on the ioctls used by the v4l2 debug tool
- Lots of cleanups
- As usual, several driver improvements and new cards additions
- Revert two changesets that change the minimal symbol rate for
stv0399, as request by Manu
- Update MAINTAINERS and other files to point to my new e-mail"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (378 commits)
MAINTAINERS & ABI: Update to point to my new email
[media] stb0899: restore minimal rate to 5Mbauds
[media] exynos4-is: Correct colorspace handling at FIMC-LITE
[media] exynos4-is: Set valid initial format on FIMC.n subdevs
[media] exynos4-is: Set valid initial format on FIMC-IS-ISP subdev pads
[media] exynos4-is: Fix format propagation on FIMC-IS-ISP subdev
[media] exynos4-is: Set valid initial format at FIMC-LITE
[media] exynos4-is: Fix format propagation on FIMC-LITE.n subdevs
[media] MAINTAINERS: Update S5P/Exynos FIMC driver entry
[media] Documentation: Update driver's directory in video4linux/fimc.txt
[media] exynos4-is: Change fimc-is firmware file names
[media] exynos4-is: Add support for Exynos5250 MIPI-CSIS
[media] exynos4-is: Add Exynos5250 SoC support to fimc-lite driver
[media] exynos4-is: Drop drvdata handling in fimc-lite for non-dt platforms
[media] media: i2c: tvp514x: remove manual setting of subdev name
[media] media: i2c: tvp7002: remove manual setting of subdev name
[media] mem2mem: set missing v4l2_dev pointer
[media] wl128x: add missing struct v4l2_device
[media] tvp514x: Fix init seqeunce
[media] saa7134: Fix sparse warnings by adding __user annotation
"This is a re-do of the net-next pull request for the current merge
window. The only difference from the one I made the other day is that
this has Eliezer's interface renames and the timeout handling changes
made based upon your feedback, as well as a few bug fixes that have
trickeled in.
Highlights:
1) Low latency device polling, eliminating the cost of interrupt
handling and context switches. Allows direct polling of a network
device from socket operations, such as recvmsg() and poll().
Currently ixgbe, mlx4, and bnx2x support this feature.
Full high level description, performance numbers, and design in
commit 0a4db187a999 ("Merge branch 'll_poll'")
From Eliezer Tamir.
2) With the routing cache removed, ip_check_mc_rcu() gets exercised
more than ever before in the case where we have lots of multicast
addresses. Use a hash table instead of a simple linked list, from
Eric Dumazet.
3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from
Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski,
Marek Puzyniak, Michal Kazior, and Sujith Manoharan.
4) Support reporting the TUN device persist flag to userspace, from
Pavel Emelyanov.
5) Allow controlling network device VF link state using netlink, from
Rony Efraim.
6) Support GRE tunneling in openvswitch, from Pravin B Shelar.
7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from
Daniel Borkmann and Eric Dumazet.
8) Allow controlling of TCP quickack behavior on a per-route basis,
from Cong Wang.
9) Several bug fixes and improvements to vxlan from Stephen
Hemminger, Pravin B Shelar, and Mike Rapoport. In particular,
support receiving on multiple UDP ports.
10) Major cleanups, particular in the area of debugging and cookie
lifetime handline, to the SCTP protocol code. From Daniel
Borkmann.
11) Allow packets to cross network namespaces when traversing tunnel
devices. From Nicolas Dichtel.
12) Allow monitoring netlink traffic via AF_PACKET sockets, in a
manner akin to how we monitor real network traffic via ptype_all.
From Daniel Borkmann.
13) Several bug fixes and improvements for the new alx device driver,
from Johannes Berg.
14) Fix scalability issues in the netem packet scheduler's time queue,
by using an rbtree. From Eric Dumazet.
15) Several bug fixes in TCP loss recovery handling, from Yuchung
Cheng.
16) Add support for GSO segmentation of MPLS packets, from Simon
Horman.
17) Make network notifiers have a real data type for the opaque
pointer that's passed into them. Use this to properly handle
network device flag changes in arp_netdev_event(). From Jiri
Pirko and Timo Teräs.
18) Convert several drivers over to module_pci_driver(), from Peter
Huewe.
19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a
O(1) calculation instead. From Eric Dumazet.
20) Support setting of explicit tunnel peer addresses in ipv6, just
like ipv4. From Nicolas Dichtel.
21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet.
22) Prevent a single high rate flow from overruning an individual cpu
during RX packet processing via selective flow shedding. From
Willem de Bruijn.
23) Don't use spinlocks in TCP md5 signing fast paths, from Eric
Dumazet.
24) Don't just drop GSO packets which are above the TBF scheduler's
burst limit, chop them up so they are in-bounds instead. Also
from Eric Dumazet.
25) VLAN offloads are missed when configured on top of a bridge, fix
from Vlad Yasevich.
26) Support IPV6 in ping sockets. From Lorenzo Colitti.
27) Receive flow steering targets should be updated at poll() time
too, from David Majnemer.
28) Fix several corner case regressions in PMTU/redirect handling due
to the routing cache removal, from Timo Teräs.
29) We have to be mindful of ipv4 mapped ipv6 sockets in
upd_v6_push_pending_frames(). From Hannes Frederic Sowa.
30) Fix L2TP sequence number handling bugs, from James Chapman."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits)
drivers/net: caif: fix wrong rtnl_is_locked() usage
drivers/net: enic: release rtnl_lock on error-path
vhost-net: fix use-after-free in vhost_net_flush
net: mv643xx_eth: do not use port number as platform device id
net: sctp: confirm route during forward progress
virtio_net: fix race in RX VQ processing
virtio: support unlocked queue poll
net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit
Documentation: Fix references to defunct linux-net@vger.kernel.org
net/fs: change busy poll time accounting
net: rename low latency sockets functions to busy poll
bridge: fix some kernel warning in multicast timer
sfc: Fix memory leak when discarding scattered packets
sit: fix tunnel update via netlink
dt:net:stmmac: Add dt specific phy reset callback support.
dt:net:stmmac: Add support to dwmac version 3.610 and 3.710
dt:net:stmmac: Allocate platform data only if its NULL.
net:stmmac: fix memleak in the open method
ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available
net: ipv6: fix wrong ping_v6_sendmsg return value
Pull drm updates from Dave Airlie:
"Okay this is the big one, I was stalled on the fbdev pull req as I
stupidly let fbdev guys merge a patch I required to fix a warning with
some patches I had, they ended up merging the patch from the wrong
place, but the warning should be fixed. In future I'll just take the
patch myself!
Outside drm:
There are some snd changes for the HDMI audio interactions on haswell,
they've been acked for inclusion via my tree. This relies on the
wound/wait tree from Ingo which is already merged.
Major changes:
AMD finally released the dynamic power management code for all their
GPUs from r600->present day, this is great, off by default for now but
also a huge amount of code, in fact it is most of this pull request.
Since it landed there has been a lot of community testing and Alex has
sent a lot of fixes for any bugs found so far. I suspect radeon might
now be the biggest kernel driver ever :-P p.s. radeon.dpm=1 to enable
dynamic powermanagement for anyone.
New drivers:
Renesas r-car display unit.
Other highlights:
- core: GEM CMA prime support, use new w/w mutexs for TTM
reservations, cursor hotspot, doc updates
- dvo chips: chrontel 7010B support
- i915: Haswell (fbc, ips, vecs, watermarks, audio powerwell),
Valleyview (enabled by default, rc6), lots of pll reworking, 30bpp
support (this time for sure)
- nouveau: async buffer object deletion, context/register init
updates, kernel vp2 engine support, GF117 support, GK110 accel
support (with external nvidia ucode), context cleanups.
- exynos: memory leak fixes, Add S3C64XX SoC series support, device
tree updates, common clock framework support,
- qxl: cursor hotspot support, multi-monitor support, suspend/resume
support
- mgag200: hw cursor support, g200 mode limiting
- shmobile: prime support
- tegra: fixes mostly
I've been banging on this quite a lot due to the size of it, and it
seems to okay on everything I've tested it on."
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (811 commits)
drm/radeon/dpm: implement vblank_too_short callback for si
drm/radeon/dpm: implement vblank_too_short callback for cayman
drm/radeon/dpm: implement vblank_too_short callback for btc
drm/radeon/dpm: implement vblank_too_short callback for evergreen
drm/radeon/dpm: implement vblank_too_short callback for 7xx
drm/radeon/dpm: add checks against vblank time
drm/radeon/dpm: add helper to calculate vblank time
drm/radeon: remove stray line in old pm code
drm/radeon/dpm: fix display_gap programming on rv7xx
drm/nvc0/gr: fix gpc firmware regression
drm/nouveau: fix minor thinko causing bo moves to not be async on kepler
drm/radeon/dpm: implement force performance level for TN
drm/radeon/dpm: implement force performance level for ON/LN
drm/radeon/dpm: implement force performance level for SI
drm/radeon/dpm: implement force performance level for cayman
drm/radeon/dpm: implement force performance levels for 7xx/eg/btc
drm/radeon/dpm: add infrastructure to force performance levels
drm/radeon: fix surface setup on r1xx
drm/radeon: add support for 3d perf states on older asics
drm/radeon: set default clocks for SI when DPM is disabled
Pull trivial tree updates from Jiri Kosina:
"The usual stuff from trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
treewide: relase -> release
Documentation/cgroups/memory.txt: fix stat file documentation
sysctl/net.txt: delete reference to obsolete 2.4.x kernel
spinlock_api_smp.h: fix preprocessor comments
treewide: Fix typo in printk
doc: device tree: clarify stuff in usage-model.txt.
open firmware: "/aliasas" -> "/aliases"
md: bcache: Fixed a typo with the word 'arithmetic'
irq/generic-chip: fix a few kernel-doc entries
frv: Convert use of typedef ctl_table to struct ctl_table
sgi: xpc: Convert use of typedef ctl_table to struct ctl_table
doc: clk: Fix incorrect wording
Documentation/arm/IXP4xx fix a typo
Documentation/networking/ieee802154 fix a typo
Documentation/DocBook/media/v4l fix a typo
Documentation/video4linux/si476x.txt fix a typo
Documentation/virtual/kvm/api.txt fix a typo
Documentation/early-userspace/README fix a typo
Documentation/video4linux/soc-camera.txt fix a typo
lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
Add Fast User Mutexes (futexes) to kernel-locking docbook.
drivers/net/ethernet/freescale/fec_main.c
drivers/net/ethernet/renesas/sh_eth.c
net/ipv4/gre.c
The GRE conflict is between a bug fix (kfree_skb --> kfree_skb_list)
and the splitting of the gre.c code into seperate files.
The FEC conflict was two sets of changes adding ethtool support code
in an "!CONFIG_M5272" CPP protected block.
Finally the sh_eth.c conflict was between one commit add bits set
in the .eesr_err_check mask whilst another commit removed the
.tx_error_check member and assignments.
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull "exotic" arch fixes from Geert Uytterhoeven:
"This is a collection of several exotic architecture fixes, and a few
other fixes for issues that were detected while doing the former"
* 'exotic-arch-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (35 commits)
lib: Move fonts from drivers/video/console/ to lib/fonts/
console/font: Refactor font support code selection logic
Revert "staging/solo6x10: depend on CONFIG_FONTS"
input: cros_ec_keyb_clear_keyboard() depends on CONFIG_PM_SLEEP
score: Wire up asm-generic/xor.h
score: Remove unneeded <asm/dma-mapping.h>
openrisc: Wire up asm-generic/xor.h
h8300/boot: Use POSIX "$((..))" instead of bashism "$[...]"
h8300: Mark H83002 and H83048 CPU support broken
h8300: Switch h8300 to drivers/Kconfig
h8300: Limit timer channel ranges in Kconfig
h8300: Wire up asm-generic/xor.h
h8300: Fill the system call table using a CALL() macro
h8300: Fix <asm/tlb.h>
h8300: Hardcode symbol prefixes in asm sources
h8300: add missing definition for read_barries_depends()
frv: head.S - Remove commented-out initialization code
cris: Wire up asm-generic/vga.h
parport: disable PC-style parallel port support on cris
console: Disable VGA text console support on cris
Pull core irq changes from Ingo Molnar:
"The main changes:
- generic-irqchip driver additions, cleanups and fixes
- 3 new irqchip drivers: ARMv7-M NVIC, TB10x and Marvell Orion SoCs
- irq_get_trigger_type() simplification and cross-arch cleanup
- various cleanups, simplifications
- documentation updates"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
softirq: Use _RET_IP_
genirq: Add the generic chip to the genirq docbook
genirq: generic-chip: Export some irq_gc_ functions
genirq: Fix can_request_irq() for IRQs without an action
irqchip: exynos-combiner: Staticize combiner_init
irqchip: Add support for ARMv7-M NVIC
irqchip: Add TB10x interrupt controller driver
irqdomain: Use irq_get_trigger_type() to get IRQ flags
MIPS: octeon: Use irq_get_trigger_type() to get IRQ flags
arm: orion: Use irq_get_trigger_type() to get IRQ flags
mfd: stmpe: use irq_get_trigger_type() to get IRQ flags
mfd: twl4030-irq: Use irq_get_trigger_type() to get IRQ flags
gpio: mvebu: Use irq_get_trigger_type() to get IRQ flags
genirq: Add irq_get_trigger_type() to get IRQ flags
genirq: Irqchip: document gcflags arg of irq_alloc_domain_generic_chips
genirq: Set irq thread to RT priority on creation
irqchip: Add support for Marvell Orion SoCs
genirq: Add kerneldoc for irq_disable.
genirq: irqchip: Add mask to block out invalid irqs
genirq: Generic chip: Add linear irq domain support
Cc: Randy Dunlap <rdunlap@infradead.org>
Several drivers need font support independent of CONFIG_VT, cfr. commit
9cbce8d7e1dae0744ca4f68d62aa7de18196b6f4, "console/font: Refactor font
support code selection logic").
Hence move the fonts and their support logic from drivers/video/console/ to
its own library directory lib/fonts/.
This also allows to limit processing of drivers/video/console/Makefile to
CONFIG_VT=y again.
[Kevin Hilman <khilman@linaro.org>: Update arch/arm/boot/compressed/Makefile]
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
