path: root/Documentation/DocBook/writing-an-alsa-driver.tmpl
2013-03-11ALSA: Make snd_BUG_ON() always evaluate and return the conditional expressionChristine Spang
Having snd_BUG_ON() only evaluate its conditional when CONFIG_SND_DEBUG is set leads to frequent bugs, since other similar macros in the kernel have different behavior. Let's make snd_BUG_ON() act like those macros so it will stop being accidentally misused. Signed-off-by: Christine Spang <christine.spang@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-05ALSA: Replace 0 with NULL in writing-an-alsa-driver.tmplTakashi Iwai
Spotted while correcting the sentences. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-05ALSA: Fix wrong description about hw constraintsTakashi Iwai
The definitions of hw constraint functions are wrongly placed, and the description about the function is also wrong. hw_rule_channels_by_format actually refines the channels depending on the format, not vice versa. Reported-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-29ALSA: Documentation: fix some typosAntonio Ospite
s/PAUSE_PUSE/PAUSE_PUSH/ s/happense/happens/ Signed-off-by: Antonio Ospite <ao2@amarulasolutions.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-29ALSA: Documentation: fix some thinkosAntonio Ospite
2012-12-07ALSA: DocBook: Remove the description of __dev*Takashi Iwai
Remove obsoleted __devinit* and __devexit* from the example codes and the descriptions, or modified the descriptions a bit to match with the current situation. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-14ALSA: Update document for using KBUILD_MODNAMETakashi Iwai
2010-04-13ALSA: Update the documentation for changes of proc filesTakashi Iwai
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-07dma-mapping: update the old macro DMA_nBIT_MASK related documentationsYang Hongyang
Update the old macro DMA_nBIT_MASK related documentations Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-09ALSA: Move ALSA docbooks to be with the rest of the kernel docbooksRandy Dunlap
Move ALSA docbooks to be with the rest of the kernel docbooks and add them to the Makefile so that they build. Latter required a few minor changes to alsa .tmpl files. (I did not remove all of the trailing whitespace in the .tmpl files.) Fixes kernel bugzilla #12726: http://bugzilla.kernel.org/show_bug.cgi?id=12726 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: documentation_man-pages@kernel-bugs.osdl.org Cc: Nicola Soranzo <nsoranzo@tiscali.it> Signed-off-by: Takashi Iwai <tiwai@suse.de>
