path: root/Documentation/DocBook/Makefile
2006-12-06[PATCH] Clean up 'make help' output for documentation targets.Jesper Juhl
Here's a patch that cleans up the "make help" output a bit for the documentation targets. Currently the documentation targets are listed completely different than all the other targets : Documentation targets: Linux kernel internal documentation in different formats: xmldocs (XML DocBook), psdocs (Postscript), pdfdocs (PDF) htmldocs (HTML), mandocs (man pages, use installmandocs to install) with this patch they are more in line with the rest of the output : Documentation targets: Linux kernel internal documentation in different formats: htmldocs - HTML installmandocs - install man pages generated by mandocs mandocs - man pages pdfdocs - PDF psdocs - Postscript xmldocs - XML DocBook Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] docbook: merge journal-api into filesystems.tmplRandy Dunlap
Move journal-api into filesystems.tmpl as a Chapter. Applies on top of the previous docbook: make a filesystems book patch. Remove trailing whitespace from journal-api chapter. Align some of the tags. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] docbook: make a filesystems bookRandy Dunlap
Make a filesystems DocBook book/file by moving all filesystems info from kernel-api.tmpl. Will also merge journal-api.tmpl into it soon (with permission from Roger Gammans). Localizes filesystem info and reduces size of the huge (produced) kernel-api output files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: doc: add design documentationThomas Gleixner
Add docbook file - includes API documentation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01typos: s/ducument/document/Adrian Bunk
s/ducument/document/ Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-25Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild: (46 commits) kbuild: remove obsoleted scripts/reference_* files kbuild: fix make help & make *pkg kconfig: fix time ordering of writes to .kconfig.d and include/linux/autoconf.h Kconfig: remove the CONFIG_CC_ALIGN_* options kbuild: add -fverbose-asm to i386 Makefile kbuild: clean-up genksyms kbuild: Lindent genksyms.c kbuild: fix genksyms build error kbuild: in makefile.txt note that Makefile is preferred name for kbuild files kbuild: replace PHONY with FORCE kbuild: Fix bug in crc symbol generating of kernel and modules kbuild: change kbuild to not rely on incorrect GNU make behavior kbuild: when warning symbols exported twice now tell user this is the problem kbuild: fix make dir/file.xx when asm symlink is missing kbuild: in the section mismatch check try harder to find symbols kbuild: fix section mismatch check for unwind on IA64 kbuild: kill false positives from section mismatch warnings for powerpc kbuild: kill trailing whitespace in modpost & friends kbuild: small update of allnoconfig description kbuild: make namespace.pl CROSS_COMPILE happy ... Trivial conflict in arch/ppc/boot/Makefile manually fixed up
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-04[PATCH] remove obsolete sis900 documentationAdrian Bunk
This documentation is mostly obsolete, and should therefore either be updated or removed (this patch does the latter). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-13[PATCH] DocBook: revert xmlto use for .ps and .pdf documentationMartin Waitz
As xmlto doesn't work for print documentation, we need docbook-utils again for these targets. This patch allows the user to choose the method he wants to use. (I'm still hoping that someone will fix passivetex ;-) Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] docbook build fixJiri Slaby
Fix documentation build with `make O=' Cc: Martin Waitz <tali@admingilde.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20merge by hand - fix up rejections in Documentation/DocBook/MakefileJames Bottomley
2005-05-20[SCSI] remove Documentation/DocBook/scsidrivers.tmplChristoph Hellwig
This document is rather rudimentary and totally outdated. Fortunately Documentation/scsi/scsi_mid_low_api.txt replaces it quite nicely. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-01[PATCH] docbook: Tell users to install xmlto, not stylesheetsSam Ravnborg
We have at least two users which were confused by these messages, myself included. Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: fix html linkMartin Waitz
The start page for each book has changed from book1.html to index.html. Update our generated links acocrdingly. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Docbook: use custom stylesheetMartin Waitz
With the custom stylesheet, functions are rendered using ANSI-C syntax and xmlto is a bit quieter. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: Use xmlto to process the DocBook files.Martin Waitz
xmlto uses standared XSLT templates to generate manpages, (x)html pages, and XML FO files which can be processed with passivetex. This is much faster than using jadetex for everything. This patch also reduces the number of kernel-specific scripts that are needed to generate documentation. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: remove obsolete templatesJeff Garzik
As the author of tulip-user and via-audio docbooks, I can say that they are out of date and should be deleted. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
