path: root/Documentation/ABI
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-27USB: add power/level sysfs attributeAlan Stern
This patch (as874) adds another piece to the user-visible part of the USB autosuspend interface. The new power/level sysfs attribute allows users to force the device on (with autosuspend off), force the device to sleep (with autoresume off), or return to normal automatic operation. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: Allow autosuspend delay to equal 0Alan Stern
This patch (as867) adds an entry for the new power/autosuspend attribute in Documentation/ABI/testing, and it changes the behavior of the delay value. Now a delay of 0 means to autosuspend as soon as possible, and negative values will prevent autosuspend. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-09ieee1394: change deprecation status of dv1394Stefan Richter
Nobody ported ffmpeg from dv1394 to rawiso yet, and there is no justification to remove dv1394 right now. Nevertheless, a strong deprecation of this ABI makes a lot of sense, especially as Kristian H's drivers shape up to be an attractive alternative to the existing ones. But we don't have a schedule at the moment. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-02-11[PATCH] pktcdvd: cleanupThomas Maier
- update documentation - use clear_bdi_congested/set_bdi_congested functions directly instead of old wrappers - removed DECLARE_BUF_AS_STRING macro Signed-off-by: Thomas Maier <balagi@justmail.de> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] pktcdvd: add sysfs and debugfs interfaceThomas Maier
Add a sysfs and debugfs interface to the pktcdvd driver. Look into the Documentation/ABI/testing/* files in the patch for more info. Signed-off-by: Thomas Maier <balagi@justmail.de> Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] swsusp: debuggingRafael J. Wysocki
Add a swsusp debugging mode. This does everything that's needed for a suspend except for actually suspending. So we can look in the log messages and work out a) what code is being slow and b) which drivers are misbehaving. (1) # echo testproc > /sys/power/disk # echo disk > /sys/power/state This should turn off the non-boot CPU, freeze all processes, wait for 5 seconds and then thaw the processes and the CPU. (2) # echo test > /sys/power/disk # echo disk > /sys/power/state This should turn off the non-boot CPU, freeze all processes, shrink memory, suspend all devices, wait for 5 seconds, resume the devices etc. Cc: Pavel Machek <pavel@ucw.cz> Cc: Stefan Seyfried <seife@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25PM: add /sys/power documentation to Documentation/ABIRafael J. Wysocki
The file sysfs-power that documents the interface in the /sys/power/ directory is added to Documentation/ABI/testing. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25Documentation/ABI: devfs is not obsolete, but removed!jens m. noedler
Signed-off-by: Jens M. Noedler <noedler@web.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Add kernel<->userspace ABI stability documentationGreg Kroah-Hartman
Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
