path: root/Documentation/ABI
2019-07-17platform/x86: asus: Rename "fan mode" to "fan boost mode"Daniel Drake
The Asus WMI spec indicates that the function being controlled here is called "Fan Boost Mode". The user-facing documentation also calls it this. The spec uses the term "fan mode" is used to refer to other things, including functionality expected to appear on future products. We missed this before as we are not dealing with the most readable of specs, and didn't forsee any confusion around shortening the name. Rename "fan mode" to "fan boost mode" to improve consistency with the spec and to avoid a future naming conflict. There is no interface breakage here since this has yet to be included in an official kernel release. I also updated the kernel version listed under ABI accordingly. Signed-off-by: Daniel Drake <drake@endlessm.com> Acked-by: Yurii Pavlovskyi <yurii.pavlovskyi@gmail.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2019-07-16Merge tag 'docs/v5.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull rst conversion of docs from Mauro Carvalho Chehab: "As agreed with Jon, I'm sending this big series directly to you, c/c him, as this series required a special care, in order to avoid conflicts with other trees" * tag 'docs/v5.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (77 commits) docs: kbuild: fix build with pdf and fix some minor issues docs: block: fix pdf output docs: arm: fix a breakage with pdf output docs: don't use nested tables docs: gpio: add sysfs interface to the admin-guide docs: locking: add it to the main index docs: add some directories to the main documentation index docs: add SPDX tags to new index files docs: add a memory-devices subdir to driver-api docs: phy: place documentation under driver-api docs: serial: move it to the driver-api docs: driver-api: add remaining converted dirs to it docs: driver-api: add xilinx driver API documentation docs: driver-api: add a series of orphaned documents docs: admin-guide: add a series of orphaned documents docs: cgroup-v1: add it to the admin-guide book docs: aoe: add it to the driver-api book docs: add some documentation dirs to the driver-api book docs: driver-model: move it to the driver-api book docs: lp855x-driver.rst: add it to the driver-api book ...
2019-07-15Merge branch 'i2c/for-5.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "New stuff from the I2C world: - in the core, getting irqs from ACPI is now similar to OF - new driver for MediaTek MT7621/7628/7688 SoCs - bcm2835, i801, and tegra drivers got some more attention - GPIO API cleanups - cleanups in the core headers - lots of usual driver updates" * 'i2c/for-5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (74 commits) i2c: mt7621: Fix platform_no_drv_owner.cocci warnings i2c: cpm: remove casting dma_alloc dt-bindings: i2c: sun6i-p2wi: Fix the binding example dt-bindings: i2c: mv64xxx: Fix the example compatible i2c: i801: Documentation update i2c: i801: Add support for Intel Tiger Lake i2c: i801: Fix PCI ID sorting dt-bindings: i2c-stm32: document optional dmas i2c: i2c-stm32f7: Add I2C_SMBUS_I2C_BLOCK_DATA support i2c: core: Tidy up handling of init_irq i2c: core: Move ACPI gpio IRQ handling into i2c_acpi_get_irq i2c: core: Move ACPI IRQ handling to probe time i2c: acpi: Factor out getting the IRQ from ACPI i2c: acpi: Use available IRQ helper functions i2c: core: Allow whole core to use i2c_dev_irq_from_resources eeprom: at24: modify a comment referring to platform data dt-bindings: i2c: omap: Add new compatible for J721E SoCs dt-bindings: i2c: mv64xxx: Add YAML schemas dt-bindings: i2c: sun6i-p2wi: Add YAML schemas i2c: mt7621: Add MediaTek MT7621/7628/7688 I2C driver ...
2019-07-15Merge tag 'for-v5.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply Pull power supply and reset updates from Sebastian Reichel: "Core: - add HWMON compat layer - new properties: - input power limit - input voltage limit Drivers: - qcom-pon: add gen2 support - new driver for storing reboot move in NVMEM - new driver for Wilco EC charger configuration - simplify getting the adapter of a client" * tag 'for-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: power: reset: nvmem-reboot-mode: add CONFIG_OF dependency power_supply: wilco_ec: Add charging config driver power: supply: cros: allow to set input voltage and current limit power: supply: add input power and voltage limit properties power: supply: fix semicolon.cocci warnings power: reset: nvmem-reboot-mode: use NVMEM as reboot mode write interface dt-bindings: power: reset: add document for NVMEM based reboot-mode reset: qcom-pon: Add support for gen2 pon dt-bindings: power: reset: qcom: Add qcom,pm8998-pon compatibility line power: supply: Add HWMON compatibility layer power: supply: sbs-manager: simplify getting the adapter of a client power: supply: rt9455_charger: simplify getting the adapter of a client power: supply: rt5033_battery: simplify getting the adapter of a client power: supply: max17042_battery: simplify getting the adapter of a client power: supply: max17040_battery: simplify getting the adapter of a client power: supply: max14656_charger_detector: simplify getting the adapter of a client power: supply: bq25890_charger: simplify getting the adapter of a client power: supply: bq24257_charger: simplify getting the adapter of a client power: supply: bq24190_charger: simplify getting the adapter of a client
2019-07-15Merge tag 'pci-v5.3-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Enumeration changes: - Evaluate PCI Boot Configuration _DSM to learn if firmware wants us to preserve its resource assignments (Benjamin Herrenschmidt) - Simplify resource distribution (Nicholas Johnson) - Decode 32 GT/s link speed (Gustavo Pimentel) Virtualization: - Fix incorrect caching of VF config space size (Alex Williamson) - Fix VF driver probing sysfs knobs (Alex Williamson) Peer-to-peer DMA: - Fix dma_virt_ops check (Logan Gunthorpe) Altera host bridge driver: - Allow building as module (Ley Foon Tan) Armada 8K host bridge driver: - add PHYs support (Miquel Raynal) DesignWare host bridge driver: - Export APIs to support removable loadable module (Vidya Sagar) - Enable Relaxed Ordering erratum workaround only on Tegra20 & Tegra30 (Vidya Sagar) Hyper-V host bridge driver: - Fix use-after-free in eject (Dexuan Cui) Mobiveil host bridge driver: - Clean up and fix many issues, including non-identify mapped windows, 64-bit windows, multi-MSI, class code, INTx clearing (Hou Zhiqiang) Qualcomm host bridge driver: - Use clk bulk API for 2.4.0 controllers (Bjorn Andersson) - Add QCS404 support (Bjorn Andersson) - Assert PERST for at least 100ms (Niklas Cassel) R-Car host bridge driver: - Add r8a774a1 DT support (Biju Das) Tegra host bridge driver: - Add support for Gen2, opportunistic UpdateFC and ACK (PCIe protocol details) AER, GPIO-based PERST# (Manikanta Maddireddy) - Fix many issues, including power-on failure cases, interrupt masking in suspend, UPHY settings, AFI dynamic clock gating, pending DLL transactions (Manikanta Maddireddy) Xilinx host bridge driver: - Fix NWL Multi-MSI programming (Bharat Kumar Gogada) Endpoint support: - Fix 64bit BAR support (Alan Mikhak) - Fix pcitest build issues (Alan Mikhak, Andy Shevchenko) Bug fixes: - Fix NVIDIA GPU multi-function power dependencies (Abhishek Sahu) - Fix NVIDIA GPU HDA enablement issue (Lukas Wunner) - Ignore lockdep for sysfs "remove" (Marek Vasut) Misc: - Convert docs to reST (Changbin Du, Mauro Carvalho Chehab)" * tag 'pci-v5.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (107 commits) PCI: Enable NVIDIA HDA controllers tools: PCI: Fix installation when `make tools/pci_install` PCI: dwc: pci-dra7xx: Fix compilation when !CONFIG_GPIOLIB PCI: Fix typos and whitespace errors PCI: mobiveil: Fix INTx interrupt clearing in mobiveil_pcie_isr() PCI: mobiveil: Fix infinite-loop in the INTx handling function PCI: mobiveil: Move PCIe PIO enablement out of inbound window routine PCI: mobiveil: Add upper 32-bit PCI base address setup in inbound window PCI: mobiveil: Add upper 32-bit CPU base address setup in outbound window PCI: mobiveil: Mask out hardcoded bits in inbound/outbound windows setup PCI: mobiveil: Clear the control fields before updating it PCI: mobiveil: Add configured inbound windows counter PCI: mobiveil: Fix the valid check for inbound and outbound windows PCI: mobiveil: Clean-up program_{ib/ob}_windows() PCI: mobiveil: Remove an unnecessary return value check PCI: mobiveil: Fix error return values PCI: mobiveil: Refactor the MEM/IO outbound window initialization PCI: mobiveil: Make some register updates more readable PCI: mobiveil: Reformat the code for readability dt-bindings: PCI: mobiveil: Change gpio_slave and apb_csr to optional ...
2019-07-15Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdmaLinus Torvalds
Pull rdma updates from Jason Gunthorpe: "A smaller cycle this time. Notably we see another new driver, 'Soft iWarp', and the deletion of an ancient unused driver for nes. - Revise and simplify the signature offload RDMA MR APIs - More progress on hoisting object allocation boiler plate code out of the drivers - Driver bug fixes and revisions for hns, hfi1, efa, cxgb4, qib, i40iw - Tree wide cleanups: struct_size, put_user_page, xarray, rst doc conversion - Removal of obsolete ib_ucm chardev and nes driver - netlink based discovery of chardevs and autoloading of the modules providing them - Move more of the rdamvt/hfi1 uapi to include/uapi/rdma - New driver 'siw' for software based iWarp running on top of netdev, much like rxe's software RoCE. - mlx5 feature to report events in their raw devx format to userspace - Expose per-object counters through rdma tool - Adaptive interrupt moderation for RDMA (DIM), sharing the DIM core from netdev" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (194 commits) RMDA/siw: Require a 64 bit arch RDMA/siw: Mark expected switch fall-throughs RDMA/core: Fix -Wunused-const-variable warnings rdma/siw: Remove set but not used variable 's' rdma/siw: Add missing dependencies on LIBCRC32C and DMA_VIRT_OPS RDMA/siw: Add missing rtnl_lock around access to ifa rdma/siw: Use proper enumerated type in map_cqe_status RDMA/siw: Remove unnecessary kthread create/destroy printouts IB/rdmavt: Fix variable shadowing issue in rvt_create_cq RDMA/core: Fix race when resolving IP address RDMA/core: Make rdma_counter.h compile stand alone IB/core: Work on the caller socket net namespace in nldev_newlink() RDMA/rxe: Fill in wc byte_len with IB_WC_RECV_RDMA_WITH_IMM RDMA/mlx5: Set RDMA DIM to be enabled by default RDMA/nldev: Added configuration of RDMA dynamic interrupt moderation to netlink RDMA/core: Provide RDMA DIM support for ULPs linux/dim: Implement RDMA adaptive moderation (DIM) IB/mlx5: Report correctly tag matching rendezvous capability docs: infiniband: add it to the driver-api bookset IB/mlx5: Implement VHCA tunnel mechanism in DEVX ...
2019-07-15docs: gpio: add sysfs interface to the admin-guideMauro Carvalho Chehab
While this is stated as obsoleted, the sysfs interface described there is still valid, and belongs to the admin-guide. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2019-07-15docs: driver-api: add a series of orphaned documentsMauro Carvalho Chehab
There are lots of documents under Documentation/*.txt and a few other orphan documents elsehwere that belong to the driver-API book. Move them to their right place. Reviewed-by: Cornelia Huck <cohuck@redhat.com> # vfio-related parts Acked-by: Logan Gunthorpe <logang@deltatee.com> # switchtec Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-15docs: admin-guide: add a series of orphaned documentsMauro Carvalho Chehab
There are lots of documents that belong to the admin-guide but are on random places (most under Documentation root dir). Move them to the admin guide. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
2019-07-15docs: admin-guide: add laptops documentationMauro Carvalho Chehab
The docs under Documentation/laptops contain users specific information. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2019-07-15docs: laptops: convert to ReSTMauro Carvalho Chehab
Rename the laptops documentation files to ReST, add an index for them and adjust in order to produce a nice html output via the Sphinx build system. At its new index.rst, let's add a :orphan: while this is not linked to the main index.rst file, in order to avoid build warnings. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2019-07-14Merge tag 'platform-drivers-x86-v5.3-1' of ↵Linus Torvalds
git://git.infradead.org/linux-platform-drivers-x86 Pull x86 platform driver updates from Andy Shevchenko: "Gathered a bunch of x86 platform driver changes. It's rather big, since includes two big refactors and completely new driver: - ASUS WMI driver got a big refactoring in order to support the TUF Gaming laptops. Besides that, the regression with backlight being permanently off on various EeePC laptops has been fixed. - Accelerometer on HP ProBook 450 G0 shows wrong measurements due to X axis being inverted. This has been fixed. - Intel PMC core driver has been extended to be ACPI enumerated if the DSDT provides device with _HID "INT33A1". This allows to convert the driver to be pure platform and support new hardware purely based on ACPI DSDT. - From now on the Intel Speed Select Technology is supported thru a corresponding driver. This driver provides an access to the features of the ISST, such as Performance Profile, Core Power, Base frequency and Turbo Frequency. - Mellanox platform drivers has been refactored and now extended to support more systems, including new coming ones. - The OLPC XO-1.75 platform is now supported. - CB4063 Beckhoff Automation board is using PMC clocks, provided via pmc_atom driver, for ethernet controllers in a way that they can't be managed by the clock driver. The quirk has been extended to cover this case. - Touchscreen on Chuwi Hi10 Plus tablet has been enabled. Meanwhile the information of Chuwi Hi10 Air has been fixed to cover more models based on the same platform. - Xiaomi notebooks have WMI interface enabled. Thus, the driver to support it has been provided. It required some extension of the generic WMI library, which allows to propagate opaque context to the ->probe() of the individual drivers. This release includes debugfs clean up from Greg KH for several drivers that drop return code check and make debugfs absence or failure non-fatal. Also miscellaneous fixes here and there, mostly for Acer WMI and various Intel drivers" * tag 'platform-drivers-x86-v5.3-1' of git://git.infradead.org/linux-platform-drivers-x86: (74 commits) platform/x86: Fix PCENGINES_APU2 Kconfig warning tools/power/x86/intel-speed-select: Add .gitignore file platform/x86: mlx-platform: Fix error handling in mlxplat_init() platform/x86: intel_pmc_core: Attach using APCI HID "INT33A1" platform/x86: intel_pmc_core: transform Pkg C-state residency from TSC ticks into microseconds platform/x86: asus-wmi: Use dev_get_drvdata() Documentation/ABI: Add new attribute for mlxreg-io sysfs interfaces platform/x86: mlx-platform: Add more reset cause attributes platform/x86: mlx-platform: Modify DMI matching order platform/x86: mlx-platform: Add regmap structure for the next generation systems platform/x86: mlx-platform: Change API for i2c-mlxcpld driver activation platform/x86: mlx-platform: Move regmap initialization before all drivers activation MAINTAINERS: Update for Intel Speed Select Technology tools/power/x86: A tool to validate Intel Speed Select commands platform/x86: ISST: Restore state on resume platform/x86: ISST: Add Intel Speed Select PUNIT MSR interface platform/x86: ISST: Add Intel Speed Select mailbox interface via MSRs platform/x86: ISST: Add Intel Speed Select mailbox interface via PCI platform/x86: ISST: Add Intel Speed Select mmio interface platform/x86: ISST: Add IOCTL to Translate Linux logical CPU to PUNIT CPU number ...
2019-07-12Merge tag 'f2fs-for-5.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "In this round, we've introduced native swap file support which can exploit DIO, enhanced existing checkpoint=disable feature with additional mount option to tune the triggering condition, and allowed user to preallocate physical blocks in a pinned file which will be useful to avoid f2fs fragmentation in append-only workloads. In addition, we've fixed subtle quota corruption issue. Enhancements: - add swap file support which uses DIO - allocate blocks for pinned file - allow SSR and mount option to enhance checkpoint=disable - enhance IPU IOs - add more sanity checks such as memory boundary access Bug fixes: - quota corruption in very corner case of error-injected SPO case - fix root_reserved on remount and some wrong counts - add missing fsck flag Some patches were also introduced to clean up ambiguous i_flags and debugging messages codes" * tag 'f2fs-for-5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (33 commits) f2fs: improve print log in f2fs_sanity_check_ckpt() f2fs: avoid out-of-range memory access f2fs: fix to avoid long latency during umount f2fs: allow all the users to pin a file f2fs: support swap file w/ DIO f2fs: allocate blocks for pinned file f2fs: fix is_idle() check for discard type f2fs: add a rw_sem to cover quota flag changes f2fs: set SBI_NEED_FSCK for xattr corruption case f2fs: use generic EFSBADCRC/EFSCORRUPTED f2fs: Use DIV_ROUND_UP() instead of open-coding f2fs: print kernel message if filesystem is inconsistent f2fs: introduce f2fs_<level> macros to wrap f2fs_printk() f2fs: avoid get_valid_blocks() for cleanup f2fs: ioctl for removing a range from F2FS f2fs: only set project inherit bit for directory f2fs: separate f2fs i_flags from fs_flags and ext4 i_flags f2fs: replace ktype default_attrs with default_groups f2fs: Add option to limit required GC for checkpoint=disable f2fs: Fix accounting for unusable blocks ...
2019-07-12Merge tag 'driver-core-5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core and debugfs updates from Greg KH: "Here is the "big" driver core and debugfs changes for 5.3-rc1 It's a lot of different patches, all across the tree due to some api changes and lots of debugfs cleanups. Other than the debugfs cleanups, in this set of changes we have: - bus iteration function cleanups - scripts/get_abi.pl tool to display and parse Documentation/ABI entries in a simple way - cleanups to Documenatation/ABI/ entries to make them parse easier due to typos and other minor things - default_attrs use for some ktype users - driver model documentation file conversions to .rst - compressed firmware file loading - deferred probe fixes All of these have been in linux-next for a while, with a bunch of merge issues that Stephen has been patient with me for" * tag 'driver-core-5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (102 commits) debugfs: make error message a bit more verbose orangefs: fix build warning from debugfs cleanup patch ubifs: fix build warning after debugfs cleanup patch driver: core: Allow subsystems to continue deferring probe drivers: base: cacheinfo: Ensure cpu hotplug work is done before Intel RDT arch_topology: Remove error messages on out-of-memory conditions lib: notifier-error-inject: no need to check return value of debugfs_create functions swiotlb: no need to check return value of debugfs_create functions ceph: no need to check return value of debugfs_create functions sunrpc: no need to check return value of debugfs_create functions ubifs: no need to check return value of debugfs_create functions orangefs: no need to check return value of debugfs_create functions nfsd: no need to check return value of debugfs_create functions lib: 842: no need to check return value of debugfs_create functions debugfs: provide pr_fmt() macro debugfs: log errors when something goes wrong drivers: s390/cio: Fix compilation warning about const qualifiers drivers: Add generic helper to match by of_node driver_find_device: Unify the match function with class_find_device() bus_find_device: Unify the match callback with class_find_device ...
2019-07-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge updates from Andrew Morton: "Am experimenting with splitting MM up into identifiable subsystems perhaps with a view to gitifying it in complex ways. Also with more verbose "incoming" emails. Most of MM is here and a few other trees. Subsystems affected by this patch series: - hotfixes - iommu - scripts - arch/sh - ocfs2 - mm:slab-generic - mm:slub - mm:kmemleak - mm:kasan - mm:cleanups - mm:debug - mm:pagecache - mm:swap - mm:memcg - mm:gup - mm:pagemap - mm:infrastructure - mm:vmalloc - mm:initialization - mm:pagealloc - mm:vmscan - mm:tools - mm:proc - mm:ras - mm:oom-kill hotfixes: mm: vmscan: scan anonymous pages on file refaults mm/nvdimm: add is_ioremap_addr and use that to check ioremap address mm/memcontrol: fix wrong statistics in memory.stat mm/z3fold.c: lock z3fold page before __SetPageMovable() nilfs2: do not use unexported cpu_to_le32()/le32_to_cpu() in uapi header MAINTAINERS: nilfs2: update email address iommu: include/linux/dmar.h: replace single-char identifiers in macros scripts: scripts/decode_stacktrace: match basepath using shell prefix operator, not regex scripts/decode_stacktrace: look for modules with .ko.debug extension scripts/spelling.txt: drop "sepc" from the misspelling list scripts/spelling.txt: add spelling fix for prohibited scripts/decode_stacktrace: Accept dash/underscore in modules scripts/spelling.txt: add more spellings to spelling.txt arch/sh: arch/sh/configs/sdk7786_defconfig: remove CONFIG_LOGFS sh: config: remove left-over BACKLIGHT_LCD_SUPPORT sh: prevent warnings when using iounmap ocfs2: fs: ocfs: fix spelling mistake "hearbeating" -> "heartbeat" ocfs2/dlm: use struct_size() helper ocfs2: add last unlock times in locking_state ocfs2: add locking filter debugfs file ocfs2: add first lock wait time in locking_state ocfs: no need to check return value of debugfs_create functions fs/ocfs2/dlmglue.c: unneeded variable: "status" ocfs2: use kmemdup rather than duplicating its implementation mm:slab-generic: Patch series "mm/slab: Improved sanity checking": mm/slab: validate cache membership under freelist hardening mm/slab: sanity-check page type when looking up cache lkdtm/heap: add tests for freelist hardening mm:slub: mm/slub.c: avoid double string traverse in kmem_cache_flags() slub: don't panic for memcg kmem cache creation failure mm:kmemleak: mm/kmemleak.c: fix check for softirq context mm/kmemleak.c: change error at _write when kmemleak is disabled docs: kmemleak: add more documentation details mm:kasan: mm/kasan: print frame description for stack bugs Patch series "Bitops instrumentation for KASAN", v5: lib/test_kasan: add bitops tests x86: use static_cpu_has in uaccess region to avoid instrumentation asm-generic, x86: add bitops instrumentation for KASAN Patch series "mm/kasan: Add object validation in ksize()", v3: mm/kasan: introduce __kasan_check_{read,write} mm/kasan: change kasan_check_{read,write} to return boolean lib/test_kasan: Add test for double-kzfree detection mm/slab: refactor common ksize KASAN logic into slab_common.c mm/kasan: add object validation in ksize() mm:cleanups: include/linux/pfn_t.h: remove pfn_t_to_virt() Patch series "remove ARCH_SELECT_MEMORY_MODEL where it has no effect": arm: remove ARCH_SELECT_MEMORY_MODEL s390: remove ARCH_SELECT_MEMORY_MODEL sparc: remove ARCH_SELECT_MEMORY_MODEL mm/gup.c: make follow_page_mask() static mm/memory.c: trivial clean up in insert_page() mm: make !CONFIG_HUGE_PAGE wrappers into static inlines include/linux/mm_types.h: ifdef struct vm_area_struct::swap_readahead_info mm: remove the account_page_dirtied export mm/page_isolation.c: change the prototype of undo_isolate_page_range() include/linux/vmpressure.h: use spinlock_t instead of struct spinlock mm: remove the exporting of totalram_pages include/linux/pagemap.h: document trylock_page() return value mm:debug: mm/failslab.c: by default, do not fail allocations with direct reclaim only Patch series "debug_pagealloc improvements": mm, debug_pagelloc: use static keys to enable debugging mm, page_alloc: more extensive free page checking with debug_pagealloc mm, debug_pagealloc: use a page type instead of page_ext flag mm:pagecache: Patch series "fix filler_t callback type mismatches", v2: mm/filemap.c: fix an overly long line in read_cache_page mm/filemap: don't cast ->readpage to filler_t for do_read_cache_page jffs2: pass the correct prototype to read_cache_page 9p: pass the correct prototype to read_cache_page mm/filemap.c: correct the comment about VM_FAULT_RETRY mm:swap: mm, swap: fix race between swapoff and some swap operations mm/swap_state.c: simplify total_swapcache_pages() with get_swap_device() mm, swap: use rbtree for swap_extent mm/mincore.c: fix race between swapoff and mincore mm:memcg: memcg, oom: no oom-kill for __GFP_RETRY_MAYFAIL memcg, fsnotify: no oom-kill for remote memcg charging mm, memcg: introduce memory.events.local mm: memcontrol: dump memory.stat during cgroup OOM Patch series "mm: reparent slab memory on cgroup removal", v7: mm: memcg/slab: postpone kmem_cache memcg pointer initialization to memcg_link_cache() mm: memcg/slab: rename slab delayed deactivation functions and fields mm: memcg/slab: generalize postponed non-root kmem_cache deactivation mm: memcg/slab: introduce __memcg_kmem_uncharge_memcg() mm: memcg/slab: unify SLAB and SLUB page accounting mm: memcg/slab: don't check the dying flag on kmem_cache creation mm: memcg/slab: synchronize access to kmem_cache dying flag using a spinlock mm: memcg/slab: rework non-root kmem_cache lifecycle management mm: memcg/slab: stop setting page->mem_cgroup pointer for slab pages mm: memcg/slab: reparent memcg kmem_caches on cgroup removal mm, memcg: add a memcg_slabinfo debugfs file mm:gup: Patch series "switch the remaining architectures to use generic GUP", v4: mm: use untagged_addr() for get_user_pages_fast addresses mm: simplify gup_fast_permitted mm: lift the x86_32 PAE version of gup_get_pte to common code MIPS: use the generic get_user_pages_fast code sh: add the missing pud_page definition sh: use the generic get_user_pages_fast code sparc64: add the missing pgd_page definition sparc64: define untagged_addr() sparc64: use the generic get_user_pages_fast code mm: rename CONFIG_HAVE_GENERIC_GUP to CONFIG_HAVE_FAST_GUP mm: reorder code blocks in gup.c mm: consolidate the get_user_pages* implementations mm: validate get_user_pages_fast flags mm: move the powerpc hugepd code to mm/gup.c mm: switch gup_hugepte to use try_get_compound_head mm: mark the page referenced in gup_hugepte mm/gup: speed up check_and_migrate_cma_pages() on huge page mm/gup.c: remove some BUG_ONs from get_gate_page() mm/gup.c: mark undo_dev_pagemap as __maybe_unused mm:pagemap: asm-generic, x86: introduce generic pte_{alloc,free}_one[_kernel] alpha: switch to generic version of pte allocation arm: switch to generic version of pte allocation arm64: switch to generic version of pte allocation csky: switch to generic version of pte allocation m68k: sun3: switch to generic version of pte allocation mips: switch to generic version of pte allocation nds32: switch to generic version of pte allocation nios2: switch to generic version of pte allocation parisc: switch to generic version of pte allocation riscv: switch to generic version of pte allocation um: switch to generic version of pte allocation unicore32: switch to generic version of pte allocation mm/pgtable: drop pgtable_t variable from pte_fn_t functions mm/memory.c: fail when offset == num in first check of __vm_map_pages() mm:infrastructure: mm/mmu_notifier: use hlist_add_head_rcu() mm:vmalloc: Patch series "Some cleanups for the KVA/vmalloc", v5: mm/vmalloc.c: remove "node" argument mm/vmalloc.c: preload a CPU with one object for split purpose mm/vmalloc.c: get rid of one single unlink_va() when merge mm/vmalloc.c: switch to WARN_ON() and move it under unlink_va() mm/vmalloc.c: spelling> s/informaion/information/ mm:initialization: mm/large system hash: use vmalloc for size > MAX_ORDER when !hashdist mm/large system hash: clear hashdist when only one node with memory is booted mm:pagealloc: arm64: move jump_label_init() before parse_early_param() Patch series "add init_on_alloc/init_on_free boot options", v10: mm: security: introduce init_on_alloc=1 and init_on_free=1 boot options mm: init: report memory auto-initialization features at boot time mm:vmscan: mm: vmscan: remove double slab pressure by inc'ing sc->nr_scanned mm: vmscan: correct some vmscan counters for THP swapout mm:tools: tools/vm/slabinfo: order command line options tools/vm/slabinfo: add partial slab listing to -X tools/vm/slabinfo: add option to sort by partial slabs tools/vm/slabinfo: add sorting info to help menu mm:proc: proc: use down_read_killable mmap_sem for /proc/pid/maps proc: use down_read_killable mmap_sem for /proc/pid/smaps_rollup proc: use down_read_killable mmap_sem for /proc/pid/pagemap proc: use down_read_killable mmap_sem for /proc/pid/clear_refs proc: use down_read_killable mmap_sem for /proc/pid/map_files mm: use down_read_killable for locking mmap_sem in access_remote_vm mm: smaps: split PSS into components mm: vmalloc: show number of vmalloc pages in /proc/meminfo mm:ras: mm/memory-failure.c: clarify error message mm:oom-kill: mm: memcontrol: use CSS_TASK_ITER_PROCS at mem_cgroup_scan_tasks() mm, oom: refactor dump_tasks for memcg OOMs mm, oom: remove redundant task_in_mem_cgroup() check oom: decouple mems_allowed from oom_unkillable_task mm/oom_kill.c: remove redundant OOM score normalization in select_bad_process()" * akpm: (147 commits) mm/oom_kill.c: remove redundant OOM score normalization in select_bad_process() oom: decouple mems_allowed from oom_unkillable_task mm, oom: remove redundant task_in_mem_cgroup() check mm, oom: refactor dump_tasks for memcg OOMs mm: memcontrol: use CSS_TASK_ITER_PROCS at mem_cgroup_scan_tasks() mm/memory-failure.c: clarify error message mm: vmalloc: show number of vmalloc pages in /proc/meminfo mm: smaps: split PSS into components mm: use down_read_killable for locking mmap_sem in access_remote_vm proc: use down_read_killable mmap_sem for /proc/pid/map_files proc: use down_read_killable mmap_sem for /proc/pid/clear_refs proc: use down_read_killable mmap_sem for /proc/pid/pagemap proc: use down_read_killable mmap_sem for /proc/pid/smaps_rollup proc: use down_read_killable mmap_sem for /proc/pid/maps tools/vm/slabinfo: add sorting info to help menu tools/vm/slabinfo: add option to sort by partial slabs tools/vm/slabinfo: add partial slab listing to -X tools/vm/slabinfo: order command line options mm: vmscan: correct some vmscan counters for THP swapout mm: vmscan: remove double slab pressure by inc'ing sc->nr_scanned ...
2019-07-12mm: smaps: split PSS into componentsLuigi Semenzato
Report separate components (anon, file, and shmem) for PSS in smaps_rollup. This helps understand and tune the memory manager behavior in consumer devices, particularly mobile devices. Many of them (e.g. chromebooks and Android-based devices) use zram for anon memory, and perform disk reads for discarded file pages. The difference in latency is large (e.g. reading a single page from SSD is 30 times slower than decompressing a zram page on one popular device), thus it is useful to know how much of the PSS is anon vs. file. All the information is already present in /proc/pid/smaps, but much more expensive to obtain because of the large size of that procfs entry. This patch also removes a small code duplication in smaps_account, which would have gotten worse otherwise. Also updated Documentation/filesystems/proc.txt (the smaps section was a bit stale, and I added a smaps_rollup section) and Documentation/ABI/testing/procfs-smaps_rollup. [semenzato@chromium.org: v5] Link: http://lkml.kernel.org/r/20190626234333.44608-1-semenzato@chromium.org Link: http://lkml.kernel.org/r/20190626180429.174569-1-semenzato@chromium.org Signed-off-by: Luigi Semenzato <semenzato@chromium.org> Acked-by: Yu Zhao <yuzhao@chromium.org> Cc: Sonny Rao <sonnyrao@chromium.org> Cc: Yu Zhao <yuzhao@chromium.org> Cc: Brian Geffon <bgeffon@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-11Merge tag 'tag-chrome-platform-for-v5.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chrome-platform/linux Pull chrome platform updates from Benson Leung "CrOS EC: - Add new CrOS ISHTP transport protocol - Add proper documentation for debugfs entries and expose resume and uptime files - Select LPC transport protocol variant at runtime. - Add lid angle sensor driver - Fix oops on suspend/resume for lightbar driver - Set CrOS SPI transport protol in realtime Wilco EC: - Add telemetry char device interface - Add support for event handling - Add new sysfs attributes Misc: - Contains ib-mfd-cros-v5.3 immutable branch from mfd, with cros_ec_commands.h header freshly synced with Chrome OS's EC project" * tag 'tag-chrome-platform-for-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/chrome-platform/linux: (54 commits) mfd / platform: cros_ec_debugfs: Expose resume result via debugfs platform/chrome: lightbar: Get drvdata from parent in suspend/resume iio: cros_ec: Add lid angle driver platform/chrome: wilco_ec: Add circular buffer as event queue platform/chrome: cros_ec_lpc_mec: Fix kernel-doc comment first line platform/chrome: cros_ec_lpc: Choose Microchip EC at runtime platform/chrome: cros_ec_lpc: Merge cros_ec_lpc and cros_ec_lpc_reg Input: cros_ec_keyb: mask out extra flags in event_type platform/chrome: wilco_ec: Fix unreleased lock in event_read() platform/chrome: cros_ec_debugfs: cros_ec_uptime_fops can be static platform/chrome: cros_ec_debugfs: Add debugfs ABI documentation platform/chrome: cros_ec_debugfs: Fix kernel-doc comment first line platform/chrome: cros_ec_debugfs: Add debugfs entry to retrieve EC uptime mfd: cros_ec: Update I2S API mfd: cros_ec: Add Management API entry points mfd: cros_ec: Add SKU ID and Secure storage API mfd: cros_ec: Add API for rwsig mfd: cros_ec: Add API for Fingerprint support mfd: cros_ec: Add API for Touchpad support mfd: cros_ec: Add API for EC-EC communication ...
2019-07-11Merge tag 'staging-5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging and IIO driver updates from Greg KH: "Here is the big Staging and IIO driver update for 5.3-rc1. Lots of new IIO drivers are in here, along with loads of tiny staging driver cleanups and fixes. Overall we almost break even with the same lines added as removed. Full details are in the shortlog, they are too large to list here. All of these changes have been in linux-next for a while with no reported issues" * tag 'staging-5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (608 commits) staging: kpc2000: simplify comparison to NULL in fileops.c staging: kpc2000: simplify comparison to NULL in dma.c staging: kpc2000: simplify comparison to NULL in kpc2000_spi.c staging: rtl8723bs: hal: remove redundant assignment to packetType staging: rtl8723bs: Change return type of hal_btcoex_IsBtDisabled() staging: rtl8723bs: Remove rtw_btcoex_DisplayBtCoexInfo() staging: rtl8723bs: Remove function rtw_btcoex_GetDBG() staging: rtl8723bs: Remove function rtw_btcoex_SetDBG() staging: rtl8723bs: Remove rtw_btcoex_IsBTCoexCtrlAMPDUSize() staging: rtl8723bs: Remove rtw_btcoex_BtInfoNotify() staging: rtl8723bs: Remove rtw_btcoex_ScanNotify() staging: rtl8723bs: Remove rtw_btcoex_SetSingleAntPath() staging: rtl8723bs: Remove rtw_btcoex_SetPGAntNum() staging: rtl8192e: remove redundant initialization of rtstatus staging: rtl8723bs: Remove rtw_btcoex_GetRaMask() staging: rtl8723bs: Remove rtw_btcoex_SetChipType() staging: rtl8723bs: Remove rtw_btcoex_ConnectNotify() staging: rtl8723bs: Remove rtw_btcoex_SetBTCoexist() staging: rtl8723bs: Remove rtw_btcoex_IsBtDisabled() staging: rtl8723bs: Remove rtw_btcoex_IsBtControlLps() ...
2019-07-11Merge tag 'char-misc-5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc driver updates from Greg KH: "Here is the "large" pull request for char and misc and other assorted smaller driver subsystems for 5.3-rc1. It seems that this tree is becoming the funnel point of lots of smaller driver subsystems, which is fine for me, but that's why it is getting larger over time and does not just contain stuff under drivers/char/ and drivers/misc. Lots of small updates all over the place here from different driver subsystems: - habana driver updates - coresight driver updates - documentation file movements and updates - Android binder fixes and updates - extcon driver updates - google firmware driver updates - fsi driver updates - smaller misc and char driver updates - soundwire driver updates - nvmem driver updates - w1 driver fixes All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (188 commits) coresight: Do not default to CPU0 for missing CPU phandle dt-bindings: coresight: Change CPU phandle to required property ocxl: Allow contexts to be attached with a NULL mm fsi: sbefifo: Don't fail operations when in SBE IPL state coresight: tmc: Smatch: Fix potential NULL pointer dereference coresight: etm3x: Smatch: Fix potential NULL pointer dereference coresight: Potential uninitialized variable in probe() coresight: etb10: Do not call smp_processor_id from preemptible coresight: tmc-etf: Do not call smp_processor_id from preemptible coresight: tmc-etr: alloc_perf_buf: Do not call smp_processor_id from preemptible coresight: tmc-etr: Do not call smp_processor_id() from preemptible docs: misc-devices: convert files without extension to ReST fpga: dfl: fme: align PR buffer size per PR datawidth fpga: dfl: fme: remove copy_to_user() in ioctl for PR fpga: dfl-fme-mgr: fix FME_PR_INTFC_ID register address. intel_th: msu: Start read iterator from a non-empty window intel_th: msu: Split sgt array and pointer in multiwindow mode intel_th: msu: Support multipage blocks intel_th: pci: Add Ice Lake NNPI support intel_th: msu: Fix single mode with disabled IOMMU ...
2019-07-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Some highlights from this development cycle: 1) Big refactoring of ipv6 route and neigh handling to support nexthop objects configurable as units from userspace. From David Ahern. 2) Convert explored_states in BPF verifier into a hash table, significantly decreased state held for programs with bpf2bpf calls, from Alexei Starovoitov. 3) Implement bpf_send_signal() helper, from Yonghong Song. 4) Various classifier enhancements to mvpp2 driver, from Maxime Chevallier. 5) Add aRFS support to hns3 driver, from Jian Shen. 6) Fix use after free in inet frags by allocating fqdirs dynamically and reworking how rhashtable dismantle occurs, from Eric Dumazet. 7) Add act_ctinfo packet classifier action, from Kevin Darbyshire-Bryant. 8) Add TFO key backup infrastructure, from Jason Baron. 9) Remove several old and unused ISDN drivers, from Arnd Bergmann. 10) Add devlink notifications for flash update status to mlxsw driver, from Jiri Pirko. 11) Lots of kTLS offload infrastructure fixes, from Jakub Kicinski. 12) Add support for mv88e6250 DSA chips, from Rasmus Villemoes. 13) Various enhancements to ipv6 flow label handling, from Eric Dumazet and Willem de Bruijn. 14) Support TLS offload in nfp driver, from Jakub Kicinski, Dirk van der Merwe, and others. 15) Various improvements to axienet driver including converting it to phylink, from Robert Hancock. 16) Add PTP support to sja1105 DSA driver, from Vladimir Oltean. 17) Add mqprio qdisc offload support to dpaa2-eth, from Ioana Radulescu. 18) Add devlink health reporting to mlx5, from Moshe Shemesh. 19) Convert stmmac over to phylink, from Jose Abreu. 20) Add PTP PHC (Physical Hardware Clock) support to mlxsw, from Shalom Toledo. 21) Add nftables SYNPROXY support, from Fernando Fernandez Mancera. 22) Convert tcp_fastopen over to use SipHash, from Ard Biesheuvel. 23) Track spill/fill of constants in BPF verifier, from Alexei Starovoitov. 24) Support bounded loops in BPF, from Alexei Starovoitov. 25) Various page_pool API fixes and improvements, from Jesper Dangaard Brouer. 26) Just like ipv4, support ref-countless ipv6 route handling. From Wei Wang. 27) Support VLAN offloading in aquantia driver, from Igor Russkikh. 28) Add AF_XDP zero-copy support to mlx5, from Maxim Mikityanskiy. 29) Add flower GRE encap/decap support to nfp driver, from Pieter Jansen van Vuuren. 30) Protect against stack overflow when using act_mirred, from John Hurley. 31) Allow devmap map lookups from eBPF, from Toke Høiland-Jørgensen. 32) Use page_pool API in netsec driver, Ilias Apalodimas. 33) Add Google gve network driver, from Catherine Sullivan. 34) More indirect call avoidance, from Paolo Abeni. 35) Add kTLS TX HW offload support to mlx5, from Tariq Toukan. 36) Add XDP_REDIRECT support to bnxt_en, from Andy Gospodarek. 37) Add MPLS manipulation actions to TC, from John Hurley. 38) Add sending a packet to connection tracking from TC actions, and then allow flower classifier matching on conntrack state. From Paul Blakey. 39) Netfilter hw offload support, from Pablo Neira Ayuso" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2080 commits) net/mlx5e: Return in default case statement in tx_post_resync_params mlx5: Return -EINVAL when WARN_ON_ONCE triggers in mlx5e_tls_resync(). net: dsa: add support for BRIDGE_MROUTER attribute pkt_sched: Include const.h net: netsec: remove static declaration for netsec_set_tx_de() net: netsec: remove superfluous if statement netfilter: nf_tables: add hardware offload support net: flow_offload: rename tc_cls_flower_offload to flow_cls_offload net: flow_offload: add flow_block_cb_is_busy() and use it net: sched: remove tcf block API drivers: net: use flow block API net: sched: use flow block API net: flow_offload: add flow_block_cb_{priv, incref, decref}() net: flow_offload: add list handling functions net: flow_offload: add flow_block_cb_alloc() and flow_block_cb_free() net: flow_offload: rename TCF_BLOCK_BINDER_TYPE_* to FLOW_BLOCK_BINDER_TYPE_* net: flow_offload: rename TC_BLOCK_{UN}BIND to FLOW_BLOCK_{UN}BIND net: flow_offload: add flow_block_cb_setup_simple() net: hisilicon: Add an tx_desc to adapt HI13X1_GMAC net: hisilicon: Add an rx_desc to adapt HI13X1_GMAC ...
2019-07-09Merge tag 'docs-5.3' of git://git.lwn.net/linuxLinus Torvalds
Pull Documentation updates from Jonathan Corbet: "It's been a relatively busy cycle for docs: - A fair pile of RST conversions, many from Mauro. These create more than the usual number of simple but annoying merge conflicts with other trees, unfortunately. He has a lot more of these waiting on the wings that, I think, will go to you directly later on. - A new document on how to use merges and rebases in kernel repos, and one on Spectre vulnerabilities. - Various improvements to the build system, including automatic markup of function() references because some people, for reasons I will never understand, were of the opinion that :c:func:``function()`` is unattractive and not fun to type. - We now recommend using sphinx 1.7, but still support back to 1.4. - Lots of smaller improvements, warning fixes, typo fixes, etc" * tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits) docs: automarkup.py: ignore exceptions when seeking for xrefs docs: Move binderfs to admin-guide Disable Sphinx SmartyPants in HTML output doc: RCU callback locks need only _bh, not necessarily _irq docs: format kernel-parameters -- as code Doc : doc-guide : Fix a typo platform: x86: get rid of a non-existent document Add the RCU docs to the core-api manual Documentation: RCU: Add TOC tree hooks Documentation: RCU: Rename txt files to rst Documentation: RCU: Convert RCU UP systems to reST Documentation: RCU: Convert RCU linked list to reST Documentation: RCU: Convert RCU basic concepts to reST docs: filesystems: Remove uneeded .rst extension on toctables scripts/sphinx-pre-install: fix out-of-tree build docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/ Documentation: PGP: update for newer HW devices Documentation: Add section about CPU vulnerabilities for Spectre Documentation: platform: Delete x86-laptop-drivers.txt docs: Note that :c:func: should no longer be used ...
2019-07-09Merge tag 'pm-5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: "These update PCI and ACPI power management (improved handling of ACPI power resources and PCIe link delays, fixes related to corner cases, hibernation handling rework), fix and extend the operating performance points (OPP) framework, add new cpufreq drivers for Raspberry Pi and imx8m chips, update some other cpufreq drivers, clean up assorted pieces of PM code and documentation and update tools. Specifics: - Improve the handling of shared ACPI power resources in the PCI bus type layer (Mika Westerberg). - Make the PCI layer take link delays required by the PCIe spec into account as appropriate and avoid polling devices in D3cold for PME (Mika Westerberg). - Fix some corner case issues in ACPI device power management and in the PCI bus type layer, optimiza and clean up the handling of runtime-suspended PCI devices during system-wide transitions to sleep states (Rafael Wysocki). - Rework hibernation handling in the ACPI core and the PCI bus type to resume runtime-suspended devices before hibernation (which allows some functional problems to be avoided) and fix some ACPI power management issues related to hiberation (Rafael Wysocki). - Extend the operating performance points (OPP) framework to support a wider range of devices (Rajendra Nayak, Stehpen Boyd). - Fix issues related to genpd_virt_devs and issues with platforms using the set_opp() callback in the OPP framework (Viresh Kumar, Dmitry Osipenko). - Add new cpufreq driver for Raspberry Pi (Nicolas Saenz Julienne). - Add new cpufreq driver for imx8m and imx7d chips (Leonard Crestez). - Fix and clean up the pcc-cpufreq, brcmstb-avs-cpufreq, s5pv210, and armada-37xx cpufreq drivers (David Arcari, Florian Fainelli, Paweł Chmiel, YueHaibing). - Clean up and fix the cpufreq core (Viresh Kumar, Daniel Lezcano). - Fix minor issue in the ACPI system sleep support code and export one function from it (Lenny Szubowicz, Dexuan Cui). - Clean up assorted pieces of PM code and documentation (Kefeng Wang, Andy Shevchenko, Bart Van Assche, Greg Kroah-Hartman, Fuqian Huang, Geert Uytterhoeven, Mathieu Malaterre, Rafael Wysocki). - Update the pm-graph utility to v5.4 (Todd Brandt). - Fix and clean up the cpupower utility (Abhishek Goel, Nick Black)" * tag 'pm-5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (57 commits) ACPI: PM: Make acpi_sleep_state_supported() non-static PM: sleep: Drop dev_pm_skip_next_resume_phases() ACPI: PM: Unexport acpi_device_get_power() Documentation: ABI: power: Add missing newline at end of file ACPI: PM: Drop unused function and function header ACPI: PM: Introduce "poweroff" callbacks for ACPI PM domain and LPSS ACPI: PM: Simplify and fix PM domain hibernation callbacks PCI: PM: Simplify bus-level hibernation callbacks PM: ACPI/PCI: Resume all devices during hibernation cpufreq: Avoid calling cpufreq_verify_current_freq() from handle_update() cpufreq: Consolidate cpufreq_update_current_freq() and __cpufreq_get() kernel: power: swap: use kzalloc() instead of kmalloc() followed by memset() cpufreq: Don't skip frequency validation for has_target() drivers PCI: PM/ACPI: Refresh all stale power state data in pci_pm_complete() PCI / ACPI: Add _PR0 dependent devices ACPI / PM: Introduce concept of a _PR0 dependent device PCI / ACPI: Use cached ACPI device state to get PCI device power state ACPI: PM: Allow transitions to D0 to occur in special cases ACPI: PM: Avoid evaluating _PS3 on transitions from D3hot to D3cold cpufreq: Use has_target() instead of !setpolicy ...
2019-07-09Merge tag 'media/v5.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - new Atmel microship ISC driver - coda has gained support for mpeg2 and mpeg4 - cxusb gained support for analog TV - rockchip staging driver was split into two separate staging drivers - added a new staging driver for Allegro DVT video IP core - added a new staging driver for Amlogic Meson video decoder - lots of improvements and cleanups * tag 'media/v5.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (398 commits) media: allegro: use new v4l2_m2m_ioctl_try_encoder_cmd funcs media: doc-rst: Fix typos media: radio-raremono: change devm_k*alloc to k*alloc media: stv0297: fix frequency range limit media: rc: Prefer KEY_NUMERIC_* for number buttons on remotes media: dvb_frontend: split dvb_frontend_handle_ioctl function media: mceusb: disable "nonsensical irdata" messages media: rc: remove redundant dev_err message media: cec-notifier: add new notifier functions media: cec: add struct cec_connector_info support media: cec-notifier: rename variables, check kstrdup and n->conn_name media: MAINTAINERS: Add maintainers for Media Controller media: staging: media: tegra-vde: Defer dmabuf's unmapping media: staging: media: tegra-vde: Add IOMMU support media: hdpvr: fix locking and a missing msleep media: v4l2: Test type instead of cfg->type in v4l2_ctrl_new_custom() media: atmel: atmel-isc: fix i386 build error media: v4l2-ctrl: Move compound control initialization media: hantro: Use vb2_get_buffer media: pci: cx88: Change the type of 'missed' to u64 ...
2019-07-09Merge tag 'iommu-updates-v5.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull iommu updates from Joerg Roedel: - Make the dma-iommu code more generic so that it can be used outside of the ARM context with other IOMMU drivers. Goal is to make use of it on x86 too. - Generic IOMMU domain support for the Intel VT-d driver. This driver now makes more use of common IOMMU code to allocate default domains for the devices it handles. - An IOMMU fault reporting API to userspace. With that the IOMMU fault handling can be done in user-space, for example to forward the faults to a VM. - Better handling for reserved regions requested by the firmware. These can be 'relaxed' now, meaning that those don't prevent a device being attached to a VM. - Suspend/Resume support for the Renesas IOMMU driver. - Added support for dumping SVA related fields of the DMAR table in the Intel VT-d driver via debugfs. - A pile of smaller fixes and cleanups. * tag 'iommu-updates-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (90 commits) iommu/omap: No need to check return value of debugfs_create functions iommu/arm-smmu-v3: Invalidate ATC when detaching a device iommu/arm-smmu-v3: Fix compilation when CONFIG_CMA=n iommu/vt-d: Cleanup unused variable iommu/amd: Flush not present cache in iommu_map_page iommu/amd: Only free resources once on init error iommu/amd: Move gart fallback to amd_iommu_init iommu/amd: Make iommu_disable safer iommu/io-pgtable: Support non-coherent page tables iommu/io-pgtable: Replace IO_PGTABLE_QUIRK_NO_DMA with specific flag iommu/io-pgtable-arm: Add support to use system cache iommu/arm-smmu-v3: Increase maximum size of queues iommu/vt-d: Silence a variable set but not used iommu/vt-d: Remove an unused variable "length" iommu: Fix integer truncation iommu: Add padding to struct iommu_fault iommu/vt-d: Consolidate domain_init() to avoid duplication iommu/vt-d: Cleanup after delegating DMA domain to generic iommu iommu/vt-d: Fix suspicious RCU usage in probe_acpi_namespace_devices() iommu/vt-d: Allow DMA domain attaching to rmrr locked device ...
2019-07-08Merge branch 'next-integrity' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity Pull integrity updates from Mimi Zohar: "Bug fixes, code clean up, and new features: - IMA policy rules can be defined in terms of LSM labels, making the IMA policy dependent on LSM policy label changes, in particular LSM label deletions. The new environment, in which IMA-appraisal is being used, frequently updates the LSM policy and permits LSM label deletions. - Prevent an mmap'ed shared file opened for write from also being mmap'ed execute. In the long term, making this and other similar changes at the VFS layer would be preferable. - The IMA per policy rule template format support is needed for a couple of new/proposed features (eg. kexec boot command line measurement, appended signatures, and VFS provided file hashes). - Other than the "boot-aggregate" record in the IMA measuremeent list, all other measurements are of file data. Measuring and storing the kexec boot command line in the IMA measurement list is the first buffer based measurement included in the measurement list" * 'next-integrity' of git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity: integrity: Introduce struct evm_xattr ima: Update MAX_TEMPLATE_NAME_LEN to fit largest reasonable definition KEXEC: Call ima_kexec_cmdline to measure the boot command line args IMA: Define a new template field buf IMA: Define a new hook to measure the kexec boot command line arguments IMA: support for per policy rule template formats integrity: Fix __integrity_init_keyring() section mismatch ima: Use designated initializers for struct ima_event_data ima: use the lsm policy update notifier LSM: switch to blocking policy update notifiers x86/ima: fix the Kconfig dependency for IMA_ARCH_POLICY ima: Make arch_policy_entry static ima: prevent a file already mmap'ed write to be mmap'ed execute x86/ima: check EFI SetupMode too
2019-07-08Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 CPU feature updates from Thomas Gleixner: "Updates for x86 CPU features: - Support for UMWAIT/UMONITOR, which allows to use MWAIT and MONITOR instructions in user space to save power e.g. in HPC workloads which spin wait on synchronization points. The maximum time a MWAIT can halt in userspace is controlled by the kernel and can be adjusted by the sysadmin. - Speed up the MTRR handling code on CPUs which support cache self-snooping correctly. On those CPUs the wbinvd() invocations can be omitted which speeds up the MTRR setup by a factor of 50. - Support for the new x86 vendor Zhaoxin who develops processors based on the VIA Centaur technology. - Prevent 'cat /proc/cpuinfo' from affecting isolated NOHZ_FULL CPUs by sending IPIs to retrieve the CPU frequency and use the cached values instead. - The addition and late revert of the FSGSBASE support. The revert was required as it turned out that the code still has hard to diagnose issues. Yet another engineering trainwreck... - Small fixes, cleanups, improvements and the usual new Intel CPU family/model addons" * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) x86/fsgsbase: Revert FSGSBASE support selftests/x86/fsgsbase: Fix some test case bugs x86/entry/64: Fix and clean up paranoid_exit x86/entry/64: Don't compile ignore_sysret if 32-bit emulation is enabled selftests/x86: Test SYSCALL and SYSENTER manually with TF set x86/mtrr: Skip cache flushes on CPUs with cache self-snooping x86/cpu/intel: Clear cache self-snoop capability in CPUs with known errata Documentation/ABI: Document umwait control sysfs interfaces x86/umwait: Add sysfs interface to control umwait maximum time x86/umwait: Add sysfs interface to control umwait C0.2 state x86/umwait: Initialize umwait control values x86/cpufeatures: Enumerate user wait instructions x86/cpu: Disable frequency requests via aperfmperf IPI for nohz_full CPUs x86/acpi/cstate: Add Zhaoxin processors support for cache flush policy in C3 ACPI, x86: Add Zhaoxin processors support for NONSTOP TSC x86/cpu: Create Zhaoxin processors architecture support file x86/cpu: Split Tremont based Atoms from the rest Documentation/x86/64: Add documentation for GS/FS addressing mode x86/elf: Enumerate kernel FSGSBASE capability in AT_HWCAP2 x86/cpu: Enable FSGSBASE on 64bit by default and add a chicken bit ...
2019-07-08Merge tag 's390-5.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Vasily Gorbik: - Improve stop_machine wait logic: replace cpu_relax_yield call in generic stop_machine function with a weak stop_machine_yield function. This is overridden on s390, which yields the current cpu to the neighbouring cpu after a couple of retries, instead of blindly giving up the cpu to the hipervisor. This significantly improves stop_machine performance on s390 in overcommitted scenarios. This includes common code changes which have been Acked by Peter Zijlstra and Thomas Gleixner. - Improve jump label transformation speed: transform jump labels without using stop_machine. - Refactoring of the vfio-ccw cp handling, simplifying the code and avoiding unneeded allocating/copying. - Various vfio-ccw fixes (ccw translation, state machine). - Add support for vfio-ap queue interrupt control in the guest. This includes s390 kvm changes which have been Acked by Christian Borntraeger. - Add protected virtualization support for virtio-ccw. - Enforce both CONFIG_SMP and CONFIG_HOTPLUG_CPU, which allows to remove some code which most likely isn't working at all, besides that s390 didn't even compile for !CONFIG_SMP. - Support for special flagged EP11 CPRBs for zcrypt. - Handle PCI devices with no support for new MIO instructions. - Avoid KASAN false positives in reworked stack unwinder. - Couple of fixes for the QDIO layer. - Convert s390 specific documentation to ReST format. - Let s390 crypto modules return -ENODEV instead of -EOPNOTSUPP if hardware is missing. This way our modules behave like most other modules and which is also what systemd's systemd-modules-load.service expects. - Replace defconfig with performance_defconfig, so there is one config file less to maintain. - Remove the SCLP call home device driver, which was never useful. - Cleanups all over the place. * tag 's390-5.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (83 commits) docs: s390: s390dbf: typos and formatting, update crash command docs: s390: unify and update s390dbf kdocs at debug.c docs: s390: restore important non-kdoc parts of s390dbf.rst vfio-ccw: Fix the conversion of Format-0 CCWs to Format-1 s390/pci: correctly handle MIO opt-out s390/pci: deal with devices that have no support for MIO instructions s390: ap: kvm: Enable PQAP/AQIC facility for the guest s390: ap: implement PAPQ AQIC interception in kernel vfio: ap: register IOMMU VFIO notifier s390: ap: kvm: add PQAP interception for AQIC s390/unwind: cleanup unused READ_ONCE_TASK_STACK s390/kasan: avoid false positives during stack unwind s390/qdio: don't touch the dsci in tiqdio_add_input_queues() s390/qdio: (re-)initialize tiqdio list entries s390/dasd: Fix a precision vs width bug in dasd_feature_list() s390/cio: introduce driver_override on the css bus vfio-ccw: make convert_ccw0_to_ccw1 static vfio-ccw: Remove copy_ccw_from_iova() vfio-ccw: Factor out the ccw0-to-ccw1 transition vfio-ccw: Copy CCW data outside length calculation ...
2019-07-05power_supply: wilco_ec: Add charging config driverNick Crews
Add a driver to control the charging algorithm used on Wilco devices. See Documentation/ABI/testing/sysfs-class-power-wilco for the userspace interface and other info. Signed-off-by: Nick Crews <ncrews@chromium.org> Reviewed-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
2019-07-04Merge branches 'x86/vt-d', 'x86/amd', 'arm/smmu', 'arm/omap', ↵Joerg Roedel
'generic-dma-ops' and 'core' into next
2019-07-03Documentation/ABI: Add new attribute for mlxreg-io sysfs interfacesVadim Pasternak
Add documentation for the new attributes for exposing reset causes for the next type of resets: caused by different watchdog, BIOS reload, ASIC reset request. Signed-off-by: Vadim Pasternak <vadimp@mellanox.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2019-07-03Documentation: ABI: power: Add missing newline at end of fileGeert Uytterhoeven
"git diff" says: \ No newline at end of file after modifying the files. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2019-07-02s390/cio: introduce driver_override on the css busCornelia Huck
Sometimes, we want to control which of the matching drivers binds to a subchannel device (e.g. for subchannels we want to handle via vfio-ccw). For pci devices, a mechanism to do so has been introduced in 782a985d7af2 ("PCI: Introduce new device binding path using pci_dev.driver_override"). It makes sense to introduce the driver_override attribute for subchannel devices as well, so that we can easily extend the 'driverctl' tool (which makes use of the driver_override attribute for pci). Note that unlike pci we still require a driver override to match the subchannel type; matching more than one subchannel type is probably not useful anyway. Signed-off-by: Cornelia Huck <cohuck@redhat.com> Reviewed-by: Halil Pasic <pasic@linux.ibm.com> Reviewed-by: Sebastian Ott <sebott@linux.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.ibm.com> Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
2019-07-01habanalabs: Add debugfs node for engines statusTomer Tayar
Command submissions sent to the device are composed of command buffers which are targeted to different device engines, like DMA and compute entities. When a command submission gets stuck, knowing in which engine the stuck is, is crucial for debugging. This patch adds a debugfs node that exports this information, by displaying the engines' various registers that assemble their idle/busy status. The information retrieval is based on the is_device_idle ASIC function. The printout in this function, of the first detected busy engine, is removed because it becomes redundant in the presence of the more elaborated info of the new debugfs node. Signed-off-by: Tomer Tayar <ttayar@habana.ai> Reviewed-by: Oded Gabbay <oded.gabbay@gmail.com> Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
2019-07-01mfd / platform: cros_ec_debugfs: Expose resume result via debugfsEvan Green
For ECs that support it, the EC returns the number of slp_s0 transitions and whether or not there was a timeout in the resume response. Expose the last resume result to usermode via debugfs so that usermode can detect and report S0ix timeouts. Signed-off-by: Evan Green <evgreen@chromium.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2019-07-01Merge tag 'iio-for-5.3b' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: Second set of IIO device support, features, cleanups and minor fixes for 5.3. A few bits for the counters subsystem mixed in here as well. There are some late breaking fixes as well, which aren't so urgent they can't wait for the merge window. New Device Support * adf4371 - New driver + bindings. - Support the adf4372 PLL. Mostly ID and bindings. * ad8366 (note includes rework of driver needed to allow support for these). - Support the ADL5240 variable gain amplifier (VGA). - Support the ADA4961 digital gain amplifier (DGA). * dps310 - New driver, in several parts from different authors for this temp and pressure sensor. - Includes errata workaround for a temperature reading issue. * stk3310 - Support the stk3335, mostly ID. Features and cleanups * core - drop error handling on debugfs registration. - harden by making sure we don't overrun iio_chan_info_postfix. * docs - convert remaining docs to rst. At somepoint we'll fit these few into the main IIO docs. - improve sampling_frequency_available docs but explaining the range form. * ad_sigma_delta - Drop a pointless goto. * ad2s1210 - Drop pointless platform data null check seeing as we don't actually use platform data anymore. * ad7124 - Relax limitation on channel numbers to allow pseudo different channels. - Support control of whether the input is buffered via DT. - Use dynamic allocation for channel configuration to make it easier to support new devices. - YAML binding conversion. * ad7150 - Comment tidy up. - Consistent and simple if (ret) handling of i2c errors. - FIELD_GET and GENMASK. - Ternary rather than !!(condition) for readability. - Use macros to avoid repetition of channel definitions. * ad7606 - Add software channel config (rather that pin controlled) - Refactor to simplify addition of new part in future. * ad7746 - of_deivce_id table. * ad7780 - MAINTAINERS entry - YAML DT bindings. * ad8366 - Stop using core mlock in favour of well scoped local lock. - SPDX + copyright date update. * ad9834 - of_device_id table * adf4371 - Add support for output stage muting before lock on has occured. * adis library - MAINTAINERS entry to reflect that this now Alexandru's problem ;) * adis162xx: - Fix a slightly incorrect set of comments and print statements on minimum supported voltage. * adis16203 - of_device_id table. * adis16240 - Add of_device_id table (in two parts as first patch only used it for MODULE_DEVICE_TABLE.) * adt7316-spi - of_device_id table * adxl372 - YAML DT binding conversion. - Cleanup use of buffer callback functions (precursor to core rework). * bh1710 - Simplify getting the i2c adapter from the client. * dht11 - Mote to newer GPIO consumer interface. * kxcjk-1013.c - Add binding for sensor in display of some ultrabooks after userspace tools updated for it not be a problem to report two similar sensors. * imx7d - drop unused variables. - white space - define instead of variable for clock frequency that is fixed. - drop pointless error message. * messon_saradc - SPDX * sps30 - MAINTAINERS entry - YAML binding conversion. * st_accel - Tidy up ordering in various buffer related callbacks. This is part of a long running effort to simplify the core code. * stm32-dfsdm: - Manage the resolution cleanly in triggerd modes. - Add fast mode support which allows more flexible filter choices. - Add a comment on the reason for a 16 bit record when technically not 'required'. * st_lsm6dsx - Embed device name in the sensor_settings struct as i3c doesn't have a convenient name field to use for this. * xilinx-adc - Relax constraints on supported platforms to reflect that this can used with FPGAs on PCIe cards and hence many architectures. * counters/ftm-quaddec - Fix some formatting io MODULE_AUTHOR - MAINTAINERS entry Fixes * tools - fix incorrect handling of 32 bit channels. * sca3000 - Potential endian bug that is unlikely to bite anyone (be64 host seems unlikely for this old part). * stm32-adc - Add vdda-supply. On some boards it needs to be turned on to supply the ADC. DT bindings included. * stm32-dfsdm - Fix output resolution to work with filter orders other than 3. - Fix output datatype as it's signed and previously claimed not to be. * tag 'iio-for-5.3b' of git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio: (68 commits) iio: iio-utils: Fix possible incorrect mask calculation iio: frequency: adf4371: Add support for output stage mute dt-bindings: iio: frequency: Add ADF4372 PLL documentation iio: frequency: adf4371: Add support for ADF4372 PLL dt-bindings: iio: adc: Add buffered input property Convert AD7124 bindings documentation to YAML format. iio: adc: ad7124: Shift to dynamic allocation for channel configuration iio: adc: ad7124: Add buffered input support iio: adc: ad7124: Remove input number limitation MAINTAINERS: add ADIS IMU driver library entry iio: adis162xx: fix low-power docs & reports counter/ftm-quaddec: Add missing '>' in MODULE_AUTHOR iio: core: no need to check return value of debugfs_create functions docs: iio: convert to ReST iio: adc: stm32-adc: add missing vdda-supply dt-bindings: iio: adc: stm32: add missing vdda supply iio: adc: stm32-dfsdm: add comment for 16 bits record iio: adc: stm32-dfsdm: add fast mode support iio: adc: stm32-dfsdm: manage data resolution in trigger mode iio: adc: stm32-dfsdm: fix data type ...
2019-06-28Merge tag 'v5.2-rc6' into rdma.git for-nextJason Gunthorpe
For dependencies in next patches. Resolve conflicts: - Use uverbs_get_cleared_udata() with new cq allocation flow - Continue to delete nes despite SPDX conflict - Resolve list appends in mlx5_command_str() - Use u16 for vport_rule stuff - Resolve list appends in struct ib_client Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
2019-06-28power: supply: add input power and voltage limit propertiesEnric Balletbo i Serra
For thermal management strategy you might be interested on limit the input power for a power supply. We already have current limit but basically what we probably want is to limit power. So, introduce the input_power_limit property. Although the common use case is limit the input power, in some specific cases it is the voltage that is problematic (i.e some regulators have different efficiencies at higher voltage resulting in more heat). So introduce also the input_voltage_limit property. This happens in one Chromebook and is used on the Pixel C's thermal management strategy to effectively limit the input power to 5V 3A when the screen is on. When the screen is on, the display, the CPU, and the GPU all contribute more heat to the system than while the screen is off, and we made a tradeoff to throttle the charger in order to give more of the thermal budget to those other components. So there's nothing fundamentally broken about the hardware that would cause the Pixel C to malfunction if we were charging at 9V or 12V instead of 5V when the screen is on, i.e. if userspace doesn't change this. What would happen is that you wouldn't meet Google's skin temperature targets on the system if the charger was allowed to run at 9V or 12V with the screen on. For folks hacking on Pixel Cs (which is now outside of Google's official support window for Android) and customizing their own kernel and userspace this would be acceptable, but we wanted to expose this feature in the power supply properties because the feature does exist in the Emedded Controller firmware of the Pixel C and all of Google's Chromebooks with USB-C made since 2015 in case someone running an up to date kernel wanted to limit the charging power for thermal or other reasons. This patch exposes a new property, similar to input current limit, to re-configure the maximum voltage from the external supply at runtime based on system-level knowledge or user input. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Reviewed-by: Guenter Roeck <groeck@chromium.org> Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Reviewed-by: Benson Leung <bleung@chromium.org> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
2019-06-24IMA: Define a new hook to measure the kexec boot command line argumentsPrakhar Srivastava
Currently during soft reboot(kexec_file_load) boot command line arguments are not measured. Define hooks needed to measure kexec command line arguments during soft reboot(kexec_file_load). - A new ima hook ima_kexec_cmdline is defined to be called by the kexec code. - A new function process_buffer_measurement is defined to measure the buffer hash into the IMA measurement list. - A new func policy KEXEC_CMDLINE is defined to control the measurement. Signed-off-by: Prakhar Srivastava <prsriva02@gmail.com> Signed-off-by: Mimi Zohar <zohar@linux.ibm.com>
2019-06-24Documentation/ABI: Document umwait control sysfs interfacesFenghua Yu
Since two new sysfs interface files are created for umwait control, add an ABI document entry for the files: /sys/devices/system/cpu/umwait_control/enable_c02 /sys/devices/system/cpu/umwait_control/max_time [ tglx: Made the write value instructions readable ] Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ashok Raj <ashok.raj@intel.com> Cc: "Borislav Petkov" <bp@alien8.de> Cc: "H Peter Anvin" <hpa@zytor.com> Cc: "Andy Lutomirski" <luto@kernel.org> Cc: "Peter Zijlstra" <peterz@infradead.org> Cc: "Tony Luck" <tony.luck@intel.com> Cc: "Ravi V Shankar" <ravi.v.shankar@intel.com> Link: https://lkml.kernel.org/r/1560994438-235698-6-git-send-email-fenghua.yu@intel.com
2019-06-23Merge 5.2-rc6 into staging-nextGreg Kroah-Hartman
We want the fixes and this resolves a merge issue as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Minor SPDX change conflict. Signed-off-by: David S. Miller <davem@davemloft.net>
2019-06-22i2c: mux: demux-pinctrl: use proper email address for ABI requestsWolfram Sang
Use my commercial address, not my community one. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Reviewed-by: Simon Horman <horms+renesas@verge.net.au> [Removed a misplaced newline. /Peter] Signed-off-by: Peter Rosin <peda@axentia.se>
2019-06-21Merge tag 'char-misc-5.2-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg KH: "Here are a number of small driver fixes for 5.2-rc6 Nothing major, just fixes for reported issues: - soundwire fixes - thunderbolt fixes - MAINTAINERS update for fpga maintainer change - binder bugfix - habanalabs 64bit pointer fix - documentation updates All of these have been in linux-next with no reported issues" * tag 'char-misc-5.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: habanalabs: use u64_to_user_ptr() for reading user pointers doc: fix documentation about UIO_MEM_LOGICAL using MAINTAINERS / Documentation: Thorsten Scherer is the successor of Gavin Schenk docs: fb: Add TER16x32 to the available font names MAINTAINERS: fpga: hand off maintainership to Moritz thunderbolt: Implement CIO reset correctly for Titan Ridge binder: fix possible UAF when freeing buffer thunderbolt: Make sure device runtime resume completes before taking domain lock soundwire: intel: set dai min and max channels correctly soundwire: stream: fix bad unlock balance soundwire: stream: fix out of boundary access on port properties
2019-06-21ABI: sysfs-driver-mlxreg-io: fix the what fieldsMauro Carvalho Chehab
The author of this file should be given an award for creativity: the What: fields on this file technically fulfills the description at README. Yet, the way it is, it can't be parsed on a script, and if someone would try to do something like: grep hwmon*/jtag_enable It wouldn't find anything. Fix the What fields in a way that it can be parseable by a script and other search tools. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-19IMA: support for per policy rule template formatsMatthew Garrett
Admins may wish to log different measurements using different IMA templates. Add support for overriding the default template on a per-rule basis. Inspired-by: Roberto Sassu <roberto.sassu@huawei.com> Signed-off-by: Matthew Garrett <mjg59@google.com> Signed-off-by: Mimi Zohar <zohar@linux.ibm.com>
2019-06-19MAINTAINERS / Documentation: Thorsten Scherer is the successor of Gavin SchenkGavin Schenk
Due to new challenges in my life I can no longer take care of SIOX. Thorsten takes over my SIOX tasks. Signed-off-by: Gavin Schenk <g.schenk@eckelmann.de> Acked-by: Thorsten Scherer <t.scherer@eckelmann.de> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-18platform/chrome: cros_ec_debugfs: Add debugfs ABI documentationEnric Balletbo i Serra
Add the missing ABI documentation for the already available debugfs entries: console_log, panicinfo and pdinfo. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2019-06-18platform/chrome: cros_ec_debugfs: Add debugfs entry to retrieve EC uptimeTim Wawrzynczak
The new debugfs entry 'uptime' is being made available to userspace so that a userspace daemon can synchronize EC logs with host time. Signed-off-by: Tim Wawrzynczak <twawrzynczak@chromium.org> [rework based on Tim's first approach] Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Tested-by: Tim Wawrzynczak <twawrzynczak@chromium.org>
2019-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Honestly all the conflicts were simple overlapping changes, nothing really interesting to report. Signed-off-by: David S. Miller <davem@davemloft.net>
2019-06-17iio: frequency: adf4371: Add support for ADF4371 PLLStefan Popa
The ADF4371 is a frequency synthesizer with an integrated voltage controlled oscillator (VCO) for phase-locked loops (PLLs). The ADF4371 has an integrated VCO with a fundamental output frequency ranging from 4000 MHz to 8000 MHz. In addition, the VCO frequency is connected to divide by 1, 2, 4, 8, 16, 32, or 64 circuits that allows the user to generate radio frequency (RF) output frequencies as low as 62.5 MHz at RF8x. A frequency multiplier at RF16x generates from 8 GHz to 16 GHz. A frequency quadrupler generates frequencies from 16 GHz to 32 GHz at RF32x. RFAUX8x duplicates the frequency range of RF8x or permits direct access to the VCO output. The driver takes the reference input frequency from the device tree and uses it to calculate and maximize the PFD frequency (frequency of the phase frequency detector). The PFD frequency is further used to calculate the timeouts: synthesizer lock, VCO band selection, automatic level calibration (ALC) and PLL settling time. This initial driver exposes the attributes for setting the frequency and enabling/disabling the different adf4371 channels. Datasheet: Link: https://www.analog.com/media/en/technical-documentation/data-sheets/adf4371.pdf Signed-off-by: Stefan Popa <stefan.popa@analog.com> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
