git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.3 kernel cycle.
There is quite a lot going on in the GPIO subsystem this merge window,
so the main matter is decribed below.
The hits in other subsystems when making the GPIO flags optional are
all ACKed by their respective subsystem maintainers.
Core changes:
- Root out the wrapper devm_gpiod_get() and gpiod_get() etc versions
of the descriptor calls that did not use the flags argument on the
end. This was around for too long and eventually Uwe Kleine-König
took the time to clean it out and the last users are removed along
with the macros in this tag. In several cases the use of flags
simplifies the code. For this reason we have (ACKed) patches
hitting in DRM, IIO, media, NFC, USB+PHY up until we hammer in the
nail with removing the macros.
- Add a fat document describing how much ready-made GPIO stuff we
have i the kernel to discourage people from reinventing a square
wheel in userspace, as so often happens.
- Create a separate lockdep class for each instance of a GPIO IRQ
chip instead of using one class for all chips, as the current code
will not work with systems with several GPIO chips doing lockdep
debugging.
- Protect against driver unloading also when a GPIO line is only used
as IRQ for the GPIOLIB_IRQCHIP helpers.
- If the GPIO chip has no designated owner, assign the parent device
driver owner as owner.
- Consolidation of chained IRQ handler install/remove replacing all
call sites where irq_set_handler_data() and
irq_set_chained_handler() were done in succession with a combined
call to irq_set_chained_handler_and_data().
This series was created by Thomas Gleixner after the problem was
observed by Russell King.
- Tglx also made another series of patches switching
__irq_set_handler_locked() for irq_set_handler_locked() which is
way cleaner.
- Tglx and Jiang Liu wrote a good bunch of patches to make use of
irq_desc_get_xxx() accessors and avoid looking up irq_descs from
IRQ numbers. The goal is to get rid of the irq number from the
handlers in the IRQ flow which is nice.
- Rob Herring killed off the set_irq_flags() for all GPIO drivers.
This was an ARM specific function that is replaced with the generic
irq_modify_status() where special flags are actually needed.
- When an OF node has a pin range for its GPIOs, return -EPROBE_DEFER
if the pin controller isn't available. Pretty logical, yet needed
to be fixed.
- If a driver using GPIOLIB_IRQCHIP has its own irq_*_resources call
back, then call these instead of the defaults provided by the
GPIOLIB.
- Fix an undocumented ABI hole: named GPIOs were not properly
documented.
Driver improvements:
- Add get_direction() support to the generic GPIO driver, it's
strange that we didn't have that before.
- Make it possible to have input-only GPIO chips using the generic
GPIO driver.
- Clean out platform data support from the Emma Mobile (EM) driver
- Finegrained runtime PM support for the RCAR driver.
- Support r8a7795 (R-car H3) in the RCAR driver.
- Support interrupts on GPIOs 16 thru 31 in the DaVinci driver.
- Some consolidation and new support in the MPC8xxx driver, we now
support MPC5125.
- Preempt-RT-friendly patches: the OMAP, MPC8xxx, drivers uses raw
spinlocks making it work better with the realime patches.
- Interrupt support for the EXTRAXFS GPIO driver.
- Make the ETRAXFS GPIO driver support also ARTPEC-3.
- Interrupt and wakeup support for the BRCMSTB driver, also for
wakeup from S5 cold boot.
- Mask MXC IRQs during suspend.
- Improve OMAP2 GPIO set_debounce() to work according to spec.
- The VF610 driver handles IRQs properly.
New drivers:
- ZTE ZX GPIO driver"
* tag 'gpio-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (87 commits)
Revert "gpio: extraxfs: fix returnvar.cocci warnings"
gpio: tc3589x: use static container helper
gpio: xlp: fix error return code
gpio: vf610: handle level IRQ's properly
gpio: max732x: Fix error handling in probe()
gpio: omap: fix clk_prepare/unprepare usage
gpio: omap: protect regs access in omap_gpio_irq_handler
gpio: omap: fix omap2_set_gpio_debounce
gpio: omap: switch to use platform_get_irq
gpio: omap: remove wrong irq_domain_remove usage in probe
gpiolib: add description for gpio irqchip fields in struct gpio_chip
gpiolib: irqchip: use different lockdep class for each gpio irqchip
gpio/grgpio: fix deadlock in grgpio_irq_unmap()
Documentation: gpio: consumer: describe active low property
gpio: mxc: fix section mismatch warning
gpio/mxc: mask gpio interrupts in suspend
gpio: omap: Fix missing raw locks conversion
gpio: brcmstb: support wakeup from S5 cold boot
gpio: brcmstb: Add interrupt and wakeup source support
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
- support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask
from Benjamin Herrenschmidt
- EEH fixes for SRIOV from Gavin
- introduce rtas_get_sensor_fast() for IRQ handlers from Thomas Huth
- use hardware RNG for arch_get_random_seed_* not arch_get_random_*
from Paul Mackerras
- seccomp filter support from Michael Ellerman
- opal_cec_reboot2() handling for HMIs & machine checks from Mahesh
Salgaonkar
- add powerpc timebase as a trace clock source from Naveen N. Rao
- misc cleanups in the xmon, signal & SLB code from Anshuman Khandual
- add an inline function to update POWER8 HID0 from Gautham R. Shenoy
- fix pte_pagesize_index() crash on 4K w/64K hash from Michael Ellerman
- drop support for 64K local store on 4K kernels from Michael Ellerman
- move dma_get_required_mask() from pnv_phb to pci_controller_ops from
Andrew Donnellan
- initialize distance lookup table from drconf path from Nikunj A
Dadhania
- enable RTC class support from Vaibhav Jain
- disable automatically blocked PCI config from Gavin Shan
- add LEDs driver for PowerNV platform from Vasant Hegde
- fix endianness issues in the HVSI driver from Laurent Dufour
- kexec endian fixes from Samuel Mendoza-Jonas
- fix corrupted pdn list from Gavin Shan
- fix fenced PHB caused by eeh_slot_error_detail() from Gavin Shan
- Freescale updates from Scott: Highlights include 32-bit memcpy/memset
optimizations, checksum optimizations, 85xx config fragments and
updates, device tree updates, e6500 fixes for non-SMP, and misc
cleanup and minor fixes.
- a ton of cxl updates & fixes:
- add explicit precision specifiers from Rasmus Villemoes
- use more common format specifier from Rasmus Villemoes
- destroy cxl_adapter_idr on module_exit from Johannes Thumshirn
- destroy afu->contexts_idr on release of an afu from Johannes
Thumshirn
- compile with -Werror from Daniel Axtens
- EEH support from Daniel Axtens
- plug irq_bitmap getting leaked in cxl_context from Vaibhav Jain
- add alternate MMIO error handling from Ian Munsie
- allow release of contexts which have been OPENED but not STARTED
from Andrew Donnellan
- remove use of macro DEFINE_PCI_DEVICE_TABLE from Vaishali Thakkar
- release irqs if memory allocation fails from Vaibhav Jain
- remove racy attempt to force EEH invocation in reset from Daniel
Axtens
- fix + cleanup error paths in cxl_dev_context_init from Ian Munsie
- fix force unmapping mmaps of contexts allocated through the kernel
api from Ian Munsie
- set up and enable PSL Timebase from Philippe Bergheaud
* tag 'powerpc-4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (140 commits)
cxl: Set up and enable PSL Timebase
cxl: Fix force unmapping mmaps of contexts allocated through the kernel api
cxl: Fix + cleanup error paths in cxl_dev_context_init
powerpc/eeh: Fix fenced PHB caused by eeh_slot_error_detail()
powerpc/pseries: Cleanup on pci_dn_reconfig_notifier()
powerpc/pseries: Fix corrupted pdn list
powerpc/powernv: Enable LEDS support
powerpc/iommu: Set default DMA offset in dma_dev_setup
cxl: Remove racy attempt to force EEH invocation in reset
cxl: Release irqs if memory allocation fails
cxl: Remove use of macro DEFINE_PCI_DEVICE_TABLE
powerpc/powernv: Fix mis-merge of OPAL support for LEDS driver
powerpc/powernv: Reset HILE before kexec_sequence()
powerpc/kexec: Reset secondary cpu endianness before kexec
powerpc/hvsi: Fix endianness issues in the HVSI driver
leds/powernv: Add driver for PowerNV platform
powerpc/powernv: Create LED platform device
powerpc/powernv: Add OPAL interfaces for accessing and modifying system LED states
powerpc/powernv: Fix the log message when disabling VF
cxl: Allow release of contexts which have been OPENED but not STARTED
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
"to receive patches queued for 4.3 merge window in HID tree. Highlights:
- a lot of improvements (regarding supported features and devices) to
Wacom driver, from Aaron Skomra and Jason Gerecke
- a lot of functional fixes and support for large I2C transfer to
cp2112 driver, from Ellen Wang
- HW support improvements to RMI driver, from Andrew Duggan
- quite some small fixes and device ID additions all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (44 commits)
HID: wacom: wacom_setup_numbered_buttons is local to wacom_wac
HID: wacom: Add support for Express Key Remote.
HID: wacom: Set button bits based on a new numbered_buttons
HID: quirks: add QUIRK_NOGET for an other TPV touchscreen
HID: usbhid: Fix the check for HID_RESET_PENDING in hid_io_error
HID: i2c-hid: Only disable irq wake if it was successfully enabled during suspend
HID: wacom: Use tablet-provided touch height/width values for INTUOSHT
HID: gembird: add new driver to fix Gembird JPD-DualForce 2
HID: lenovo: Hide middle-button press until release
HID: lenovo: Add missing return-value check
HID: lenovo: Use constants for axes names
HID: wacom: Simplify 'wacom_pl_irq'
HID: wacom: Do not repeatedly attempt to set device mode on error
HID: wacom: Remove WACOM_QUIRK_NO_INPUT
HID: wacom: Replace WACOM_QUIRK_MONITOR with WACOM_DEVICETYPE_WL_MONITOR
HID: wacom: Use calculated pkglen for wireless touch interface
HID: sony: Fix DS4 controller reporting rate issues
HID: chicony: Add support for Acer Aspire Switch 12
HID: hid-lg: Add USBID for Logitech G29 Wheel
'for-4.3/lenovo', 'for-4.3/logitech', 'for-4.3/multitouch', 'for-4.3/picolcd', 'for-4.3/rmi', 'for-4.3/sensor-hub', 'for-4.3/sony' and 'for-4.3/wacom' into for-linus
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply
Pull power supply and reset changes from Sebastian Reichel:
- new reset driver for ZTE SoCs
- add support for sama5d3 reset handling
- overhaul of twl4030 charger driver
- misc fixes and cleanups
* tag 'for-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (35 commits)
bq2415x_charger: Allow to load and use driver even if notify device is not registered yet
twl4030_charger: fix compile error when TWL4030_MADC not available.
power: bq24190_charger: Fix charge type sysfs property
power: Allow compile test of GPIO consumers if !GPIOLIB
power: Export I2C module alias information in missing drivers
twl4030_charger: Increase current carefully while watching voltage.
twl4030_charger: add ac/mode to match usb/mode
twl4030_charger: add software controlled linear charging mode.
twl4030_charger: enable manual enable/disable of usb charging.
twl4030_charger: allow max_current to be managed via sysfs.
twl4030_charger: distinguish between USB current and 'AC' current
twl4030_charger: allow fine control of charger current.
twl4030_charger: split uA calculation into a function.
twl4030_charger: trust phy to determine when USB power is available.
twl4030_charger: correctly handle -EPROBE_DEFER from devm_usb_get_phy_by_node
twl4030_charger: convert to module_platform_driver instead of ..._probe.
twl4030_charger: use runtime_pm to keep usb phy active while charging.
rx51-battery: Set name to rx51-battery
MAINTAINERS: AVS is not maintained via power supply tree
power: olpc_battery: clean up eeprom read function
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB and PHY patchset for 4.3-rc1.
As usual, the majority of the changes are in the USB gadget portion of
the tree, lots of little changes all over the place for bugs and new
hardware. Other than that, the normal mix of new hardware support and
bugfixes.
All have been in linux-next with no reported issues"
* tag 'usb-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (261 commits)
USB: qcserial: add HP lt4111 LTE/EV-DO/HSPA+ Gobi 4G Module
USB: ftdi_sio: Added custom PID for CustomWare products
USB: usb_wwan: silence read errors on disconnect
USB: option: silence interrupt errors
USB: symbolserial: Correct transferred data size
USB: symbolserial: Use usb_get_serial_port_data
usb: misc: usbtest: format max packet size for iso transfer
usb: host: ehci-sys: delete useless bus_to_hcd conversion
Revert "usb: interface authorization: Declare authorized attribute"
Revert "usb: interface authorization: Introduces the default interface authorization"
Revert "usb: interface authorization: Control interface probing and claiming"
Revert "usb: interface authorization: Introduces the USB interface authorization"
Revert "usb: interface authorization: SysFS part of USB interface authorization"
Revert "usb: interface authorization: Documentation part"
Revert "usb: interface authorization: Use a flag for the default device authorization"
usb: core: hub: Removed some warnings generated by checkpatch.pl
USB: host: ohci-at91: merge loops in ohci_hcd_at91_drv_probe
USB: host: ohci-at91: merge ohci_at91_of_init in ohci_hcd_at91_drv_probe
USB: host: ohci-at91: depend on OF
USB: host: ohci-at91: move at91_usbh_data definition in c file
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here is the big staging driver updates for 4.3-rc1.
Lots of things all over the place, almost all of them trivial fixups
and changes. The usual IIO updates and new drivers and we have added
the MOST driver subsystem which is getting cleaned up in the tree.
The ozwpan driver is finally being deleted as it is obviously
abandoned and no one cares about it.
Full details are in the shortlog, and all of these have been in
* tag 'staging-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (912 commits)
staging/lustre/o2iblnd: remove references to ib_reg_phsy_mr()
staging: wilc1000: fix build warning with setup_timer()
staging: wilc1000: remove DECLARE_WILC_BUFFER()
staging: wilc1000: remove void function return statements that are not useful
staging: wilc1000: coreconfigurator.c: fix kmalloc error check
staging: wilc1000: coreconfigurator.c: use kmalloc instead of WILC_MALLOC
staging: wilc1000: remove unused codes of gps8ConfigPacket
staging: wilc1000: remove unnecessary void pointer cast
staging: wilc1000: remove WILC_NEW and WILC_NEW_EX
staging: wilc1000: use kmalloc instead of WILC_NEW
staging: wilc1000: Process WARN, INFO options of debug levels from user
staging: wilc1000: remove unneeded tstrWILC_MsgQueueAttrs typedef
staging: wilc1000: delete wilc_osconfig.h
staging: wilc1000: delete wilc_log.h
staging: wilc1000: delete wilc_timer.h
staging: wilc1000: remove WILC_TimerStart()
staging: wilc1000: remove WILC_TimerCreate()
staging: wilc1000: remove WILC_TimerDestroy()
staging: wilc1000: remove WILC_TimerStop()
staging: wilc1000: remove tstrWILC_TimerAttrs typedef
This device is pad (buttons) only, there is no stylus or touch. Up to
five remotes can pair with the device's associated USB dongle.
Signed-off-by: Aaron Skomra <aaron.skomra@wacom.com>
Reviewed-by: Jason Gerecke <jason.gerecke@wacom.com>
This reverts commit 6ef2bf71764708f7c58ee9300acd8df05dbaa06f as the
signed-off-by address is invalid.
Cc: Stefan Koch <stefan.koch10@gmail.com>
This part adds the documentation for the interface authorization.
Signed-off-by: Stefan Koch <skoch@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v4.3 merge window
New support for Allwinne SoC on the MUSB driver has been added to the list of
glue layers. MUSB also got support for building all DMA engines in one binary;
this will be great for distros.
DWC3 now has no trace of dev_dbg()/dev_vdbg() usage. We will rely solely on
tracing to debug DWC3. There was also a fix for memory corruption with EP0 when
maxpacket size transfers are > 512 bytes.
Robert's EP capabilities flags is making EP selection a lot simpler. UDCs are
now required to set these flags up when adding endpoints to the framework.
Other than these, we have the usual set of miscelaneous cleanups and minor
fixes.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Provide a kernel API and a sysfs entry which allow a user to specify
that when a card is PERSTed, it's image will stay the same, allowing
it to participate in EEH.
cxl_reset is used to reflash the card. In that case, we cannot safely
assert that the image will not change. Therefore, disallow cxl_reset
if the flag is set.
Signed-off-by: Daniel Axtens <dja@axtens.net>
Linux 4.2-rc4
commit 926b663ce8215ba448960e1ff6e58b67a2c3b99b
"gpiolib: allow GPIOs to be named" added the ability to
name GPIO lines by an array of names stored in the GPIO
chip. This was in 2009 and has been an ABI since. Let's
document it properly.
Cc: Daniel Silverstone <dsilvers@digital-scurf.org>
Cc: Markus Pargmann <mpa@pengutronix.de>
Cc: Johan Hovold <johan@kernel.org>
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Second set of new device support, features and cleanup for the 4.3 cycle.
Take 2 also includes a fix set that was too late for the 4.2 cycle.
As we had a lot of tools and docs work in this set, I have broken those
out into their own categories in this description.
Fixes from the pull request '4th set of IIO fixes for the 4.2 cycle'.
* Poll functions for both event chardev and the buffer one were returning
negative error codes (via a positive value).
* A recent change to lsiio adding some error handling that was wrong and
stopped the tool working.
* bmg160 was missing some dependencies in Kconfig
* berlin2-adc had a misshandled register (wrote a value rather than a bitmap)
New device support
* TI opt3001 light sensor
* TXC PA12 ALS and proximity sensor.
* mcp3301 ADC support (in mcp320x driver)
* ST lsm303agr accelerometer and magnetometer drivers (plus some st-sensors
common support to allow different WHOAMI register addresses, devices with
fixed scale and allow interrupt equiped magnetometers).
* ADIS16305, ADIS16367, ADIS16445IMUs (in the adis16400 driver)
* ADIS16266 gyro (in the adis16260 driver)
* ADIS16137 gyro (in the adis16136 driver)
New functionality
* mmc35240 DT bindings.
* Inverse unit conversion macros to aid handing of values written to sysfs
attributes.
Core cleanup
* Forward declaration of struct iio_trigger to avoid a compile warning.
Driver cleanup / fixes
* mxs-lradc
- Clarify which parts are supported.
- Fix spelling erorrs.
- Missing/extra includes
- reorder includes
- add datasheet name listings for all usable channels (to allow them
to be bound by name from consumer drivers)
* acpi-als - add some function prefixes as per general iio style.
* bmc150_magn - replace a magic value with the existing define.
* vf610 - determine possible sample frequencies taking into account the
electrical characteristics (defining a minimum sample time)
* dht11
- whitespace
- additional docs
- avoid mulitple assignments in one line
- Use the new funciton ktime_get_resolution_ns to cleanup a nasty trick
previously used for timing.
* Fix all drivers that consider 0 a valid IRQ for historical reasons.
* Export I2C module alias info where previously missing (to allow autoprobing)
* Export OF module alias info where previously missing.
* mmc35240 - switch some variables into arrays to improve readability.
* mlx90614 - define some magic numbers for readability.
* bmc150_magn
- expand area locked by a mutex to cover all the use of the
data->buffer.
- use descriptive naming for a mask instead of a magic value.
* berin2-adc
- pass up an error code rather that a generic error
- constify the iio_chan_spec
- some other little tidy ups.
* stk8312
- fix a dependency on triggered buffers in kconfig
- add a check for invalid attribute values
- improve error handling by returning error codes where possible and
return immediately where relevant
- rework macro defs to use GENMASK etc
- change some variable types to reduce unnecessary casting
- clean up code style
- drop a local buffer copy for bulk reads and use the one in data->buffer
instead.
* adis16400 - the adis16448 gyroscope scale was wrong.
* adis16480 - some more wrong scales for various parts.
* adis16300 - has an undocumented product id and serial number registers so
use them.
* iio_simple_dummy - fix some wrong code indentation.
* bmc150-accel - use the chip ID to detect the chip present rather than
verifying the expected part was there. This was in response to a wrong
ACPI entry on the WinBook TW100.
* mma8452
- fix _get_hp_filter_index
- drop a double include
- pass up an error code rather than rewriting it
- range check input values to attribute writes
- register defs tidy up using GENMASK and reordering them to be easier to
follow.
- various coding style cleanups
- put the Kconfig entry in the write place (alphabetically).
Tools related
* Tools cleanup - drop an explicity NULL comparison, some unnecessary braces,
use the ARRAY_SIZE macro, send error messages to stderr instead of dropping
them in the middle of normal output.
* Fix tools to allow that scale and offset attributes are optional.
* More tools fixes including allowing true 32bit data (previously an overflow
prevented more than 31bits)
* Drop a stray header guard that ended up in a c file.
* Make calc_digits static as it isn't exported or in the header.
* Set ci_array pointer to NULL after free as a protection against non safe
usage of the tools core code. Also convert a double pointer to a single
one as the extra level of indirection was unnecessary.
Docs
* DocBook introduction by Daniel Baluta. Glad we are beginning to
draw together some more introductory docs to suplement the various
tools / examples.
* Drop bytes_per_datum sysfs attribute docs as it no longer exists.
* A whole load of missing / fixing of kernel-doc for the core of IIO.
* Document the trigger name sysfs attribute in the ABI docs.
* Minor typos in the ABI docs related to power down modes.
Fix typos in ABI documentation
Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch adds an entry in ABI Documentation for the name attribute
issued when a trigger is created.
Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com>
Acked-by: Daniel Baluta <daniel.baluta@intel.com>
Now that we have the nvmem framework, we can consolidate the common
driver code. Move the driver to the framework, and hopefully, it will
fix the sysfs file creation race.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[srinivas.kandagatla: Moved to regmap based EEPROM framework]
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Tested-by: Philipp Zabel <p.zabel@pengutronix.de>
Tested-by: Rajendra Nayak <rnayak@codeaurora.org>
'ctxid_val' array was used to store the value of ETM context ID comparator
which actually stores the process ID to be traced, so using 'ctxid_pid' as
its name instead make it easier to understand.
This patch also changes the ABI, it is normally not allowed, but
fortunately it is a testing ABI and very new for now. Nevertheless,
if you don't think it should be changed, we could always add an alias
for userspace.
Signed-off-by: Chunyan Zhang <zhang.chunyan@linaro.org>
Reviewed-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
for userspace.
The 4 sysfs files should be stable ABIs to the user space.
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
This allows AC charging to be turned off, much like usb charging.
"continuous" mode is not available though.
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: NeilBrown <neil@brown.name>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
Add a 'continuous' option for usb charging which enables
the "linear" charging mode of the twl4030.
Linear charging does a good job with not-so-reliable power sources.
Auto mode does not work well as it switches off when voltage drops
momentarily. Care must be taken not to over-charge.
It was used with a bike hub dynamo since a year or so. In that case
there are automatically charging stops when the cyclist needs a break.
Original-by: Andreas Kemnade <andreas@kemnade.info>
'off' or 'auto' to
/sys/class/power/twl4030_usb/mode
will now enable or disable charging from USB port. Normally this is
enabled on 'plug' and disabled on 'unplug'.
Unplug will still disable charging. 'plug' will only enable it if
'auto' if selected.
'max_current' sysfs attributes are created which allow the
max to be set.
Whenever a current source changes, the default is restored.
This will be followed by a uevent, so user-space can decide to
update again.
PM_RUNTIME has been replaced with PM by commit 464ed18ebdb6 ("PM:
Eliminate CONFIG_PM_RUNTIME") hence substitute the reference on
PM_RUNTIME with PM and re-arrange the text to 80 column break.
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
Fix the name of attribute
Cc: <stable@vger.kernel.org>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Add a sysfs node to make it easier to verify if LPM is supported and being
enabled for USB 3.0 devices.
Signed-off-by: Kevin Strasser <kevin.strasser@linux.intel.com>
We need the staging fixes in here as well.
Remove sysfs bytes_per_datum device attribute ABI documentation
since the attribute is not present anymore.
Jonathan writes:
First round of new drivers, cleanups and functionality for IIO in the 4.3 cycle.
Core and tools new stuff
* Allow explicit flush of hardware fifo by using an non blocking read.
This is needed to support some of the Android requirements for HW fifo
devices - also makes sense generally and clarifies a corner of the ABI.
* Add some missing modifier names. Mostly these exist for weird and
wonderful event types, but should still be present in the name array.
* Update iio_event_monitor to cope with new channel types.
* generic_buffer gains support for single byte scan elements (no idea
how this never got implemented before!)
New device support
* ROHM rpr0521 light and proximity sensor driver.
* bmc150 gains bmc156 support.
* ms5611 gains ms5607 temperature and pressure sensor support.
Driver functionality
* inv-mpu - add scale_available attributes to aid userspace in
configuring these devices.
* isl29125 - add scale_available attributes.
* stk8ba50 - sampling frequency control, triggered buffer support.
* stk8312 - sampling frequency control, triggered buffer support.
* cc10001 - ensure ADC powered up at probe time if shared by non linux
running CPUs.
* bmc150-magn - decouple the buffer and trigger allowing other triggers
to be used to drive this device's sampling.
Documentation
* Add some previously missed *scale_available attributes to the ABI docs.
Cleanups
* Clarify some crazy naming in iio_triggered_buffer_setup that seems to
have somehow ended up backwards (dates back a long way). Avoid the top
half and bottom half naming entirely given we are how dealing with a
handler and a thread in all cases.
* Tools cleanup including coding style, variable naming improvements, also
a new sanity check on a full event having been read.
* stk8ba50 - replace the scale table with a struct for clarity. Also suspend
the sensor if an error occurs in init.
* hid-sensor-prox - drop uneeded line break.
* mma9551 - use size in words for word read / write avoiding accidental
sending of an odd number of bytes.
* mma9553 - fix code alignment and document the use of a mutex.
* light/Kconfig - typo fix in commment.
* cm3323 - don't eat an error value, replace an unneeded local variable with
a generic local variable with the same use, add some blank lines for clarity.
* pressure/Kconfig - typo in Measurement Specialties name.
* bmc150-accel - actually use a mask definition rather than repeating the
value inline, code style cleanup.
* adc/Kconfig - general help description cleanup.
* ssp_sensors - drop redundant spi driver bus initialization (done in the
spi core)
* tmp006 - use genmask rather than hand generated masks.
* ms5611 - drop IIO_CHAN_INFO_SCALE as this driver provides a processed
output and as such the read only scale adds nothing useful.
* kxcjk-1013, adf4350, dummy - drop unwanted blank lines.
* Drop all owner assignments from i2c_drivers and this is done in the
i2c core.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
First set of IIO fixes for the 4.2 cycle.
* Fix a regression in hid sensors suspend time as a result of adding runtime
pm. The normal flow of waking up devices in order to go into suspend
(given the devices are normally suspended when not reading) to a regression
in suspend time on some laptops (reports of an additional 8 seconds).
Fix this by checking to see if a user action resulting in the wake up, and
make it a null operation if it didn't. Note that for hid sensors, there is
nothing useful to be done when moving into a full suspend from a runtime
suspend so they might as well be left alone.
* rochip_saradc: fix some missing MODULE_* data including the licence so that
the driver does not taint the kernel incorrectly and can build as a module.
* twl4030 - mark irq as oneshot as it always should have been.
* inv-mpu - write formats for attributes not specified, leading to miss
interpretation of the gyro scale channel when written.
* Proximity ABI clarification. This had snuck through as a mess. Some
drivers thought proximity went in one direction, some the other. We went
with the most common option, documented it and fixed up the drivers going
the other way. Fix for sx9500 included in this set.
* ad624r - fix a wrong shift in the output data.
* at91_adc - remove a false limit on the value of the STARTUP register
applied by too small a type for the device tree parameter.
* cm3323 - clear the bits when setting the integration time (otherwise
we can only ever set more bits in the relevant field).
* bmc150-accel - multiple triggers are registered, but on error were not being
unwound in the opposite order leading to removal of triggers that had not
yet successfully been registered (count down instead of up when unwinding).
* tcs3414 - ensure right part of val / val2 pair read so that the integration
time is not always 0.
* cc10001_adc - bug in kconfig dependency. Use of OR when AND was intended.
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"Fairly routine update for platform-drivers-x86.
Mostly fixes and cleanups, with a significant refactoring of toshiba*
drivers. Includes the addition of the dell-rbtn driver.
Details:
asus-wmi:
- fan control
dell*:
- add Dell airplane mode switch driver
ideapad-laptop:
- platform rfkill fixes, and regression fix
pvpanic:
- handle missing _STA correctly
toshiba*:
- rafactor bluetooth support
- haps documentation
- driver cleanup
other:
- Use acpi_video_unregister_backlight instead of
acpi_video_unregister in serveral drivers.
- Orphan msi-wmi.
* tag 'platform-drivers-x86-v4.2-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (24 commits)
MAINTAINERS: Orphan x86 driver msi-wmi
ideapad: fix software rfkill setting
dell-laptop: Use dell-rbtn instead i8042 filter when possible
dell-rbtn: Export notifier for other kernel modules
dell-rbtn: Dell Airplane Mode Switch driver
samsung-laptop: Use acpi_video_unregister_backlight instead of acpi_video_unregister
asus-wmi: Use acpi_video_unregister_backlight instead of acpi_video_unregister
apple_gmux: Use acpi_video_unregister_backlight instead of acpi_video_unregister
pvpanic: handle missing _STA correctly
ideapad_laptop: Lenovo G50-30 fix rfkill reports wireless blocked
asus-wmi: add fan control
Documentation/ABI: Add file describing the sysfs entries for toshiba_haps
toshiba_haps: Make use of DEVICE_ATTR_{RW, WO} macros
toshiba_haps: Replace sscanf with kstrtoint
toshiba_acpi: Bump driver version to 0.22
toshiba_acpi: Remove TOS_FAILURE check from some functions
toshiba_acpi: Comments cleanup
toshiba_acpi: Rename hci_{read, write}1 functions
toshiba_acpi: Remove no longer needed hci_{read, write}2 functions
toshiba_bluetooth: Change BT status message to debug
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"The main change in this kernel is Casey's generalized LSM stacking
work, which removes the hard-coding of Capabilities and Yama stacking,
allowing multiple arbitrary "small" LSMs to be stacked with a default
monolithic module (e.g. SELinux, Smack, AppArmor).
See
https://lwn.net/Articles/636056/
This will allow smaller, simpler LSMs to be incorporated into the
mainline kernel and arbitrarily stacked by users. Also, this is a
useful cleanup of the LSM code in its own right"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add()
vTPM: set virtual device before passing to ibmvtpm_reset_crq
tpm_ibmvtpm: remove unneccessary message level.
ima: update builtin policies
ima: extend "mask" policy matching support
ima: add support for new "euid" policy condition
ima: fix ima_show_template_data_ascii()
Smack: freeing an error pointer in smk_write_revoke_subj()
selinux: fix setting of security labels on NFS
selinux: Remove unused permission definitions
selinux: enable genfscon labeling for sysfs and pstore files
selinux: enable per-file labeling for debugfs files.
selinux: update netlink socket classes
signals: don't abuse __flush_signals() in selinux_bprm_committed_creds()
selinux: Print 'sclass' as string when unrecognized netlink message occurs
Smack: allow multiple labels in onlycap
Smack: fix seq operations in smackfs
ima: pass iint to ima_add_violation()
ima: wrap event related data to the new ima_event_data structure
integrity: add validity checks for 'path' parameter
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
"Here's the big, really big, staging tree patches for 4.2-rc1.
Loads of stuff in here, almost all just coding style fixes / churn,
and a few new drivers as well, one of which I just disabled from the
build a few minutes ago due to way too many build warnings.
Other than the one "disable this driver" patch, all of these have been
in linux-next for quite a while with no reported issues"
* tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits)
staging: wilc1000: disable driver due to build warnings
Staging: rts5208: fix CHANGE_LINK_STATE value
Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis
Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines
Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators
Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs
Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters
Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs
Staging: sm750fb: modedb.h: Shorten lines to under 80 characters
Staging: sm750fb: modedb.h: Replace spaces with tabs
staging: comedi: addi_apci_3120: rename 'this_board' variables
staging: comedi: addi_apci_1516: rename 'this_board' variables
staging: comedi: ni_atmio: cleanup ni_getboardtype()
staging: comedi: vmk80xx: sanity check context used to get the boardinfo
staging: comedi: vmk80xx: rename 'boardinfo' variables
staging: comedi: dt3000: rename 'this_board' variables
staging: comedi: adv_pci_dio: rename 'this_board' variables
staging: comedi: cb_pcidas64: rename 'thisboard' variables
staging: comedi: cb_pcidas: rename 'thisboard' variables
staging: comedi: me4000: rename 'thisboard' variables
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
Merge second patchbomb from Andrew Morton:
- most of the rest of MM
- lots of misc things
- procfs updates
- printk feature work
- updates to get_maintainer, MAINTAINERS, checkpatch
- lib/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits)
exit,stats: /* obey this comment */
coredump: add __printf attribute to cn_*printf functions
coredump: use from_kuid/kgid when formatting corename
fs/reiserfs: remove unneeded cast
NILFS2: support NFSv2 export
fs/befs/btree.c: remove unneeded initializations
fs/minix: remove unneeded cast
init/do_mounts.c: add create_dev() failure log
kasan: remove duplicate definition of the macro KASAN_FREE_PAGE
fs/efs: femove unneeded cast
checkpatch: emit "NOTE: <types>" message only once after multiple files
checkpatch: emit an error when there's a diff in a changelog
checkpatch: validate MODULE_LICENSE content
checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY
checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()
checkpatch: fix processing of MEMSET issues
checkpatch: suggest using ether_addr_equal*()
checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files
checkpatch: remove local from codespell path
checkpatch: add --showfile to allow input via pipe to show filenames
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull DMI updates from Jean Delvare:
"The most important change is the new sysfs interface to the DMI table,
which will let user-space tools (such as dmidecode) access the table
without relying on /dev/mem"
* 'dmi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
firmware: dmi: struct dmi_header should be packed
firmware: dmi_scan: Coding style cleanups
Documentation: ABI: sysfs-firmware-dmi: add -entries suffix to file name
firmware: dmi_scan: add SBMIOS entry and DMI tables
firmware: dmi_scan: Trim DMI table length before exporting it
firmware: dmi_scan: Rename dmi_table to dmi_decode_table
firmware: dmi: List my quilt tree
firmware: dmi_scan: Only honor end-of-table for 64-bit tables
printk log_buf keeps various metadata for each message including its
sequence number and timestamp. The metadata is currently available only
through /dev/kmsg and stripped out before passed onto console drivers. We
want this metadata to be available to console drivers too so that console
consumers can get full information including the metadata and dictionary,
which among other things can be used to detect whether messages got lost
in transit.
This patch implements support for extended console drivers. Consoles can
indicate that they want extended messages by setting the new CON_EXTENDED
flag and they'll be fed messages formatted the same way as /dev/kmsg.
"<level>,<sequnum>,<timestamp>,<contflag>;<message text>\n"
If extended consoles exist, in-kernel fragment assembly is disabled. This
ensures that all messages emitted to consoles have full metadata including
sequence number. The contflag carries enough information to reassemble
the fragments from the reader side trivially. Note that this only affects
/dev/kmsg. Regular console and /proc/kmsg outputs are not affected by
this change.
* Extended message formatting for console drivers is enabled iff there
are registered extended consoles.
* Comment describing /dev/kmsg message format updated to add missing
contflag field and help distinguishing variable from verbatim terms.
Cc: Kay Sievers <kay@vrfy.org>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
pratyush.anand@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with pratyush.anand@gmail.com.
Signed-off-by: Pratyush Anand <pratyush.anand@gmail.com>
We currently don't support on-demand device creation. The one and only
way to have N zram devices is to specify num_devices module parameter
(default value: 1). IOW if, for some reason, at some point, user wants
to have N + 1 devies he/she must umount all the existing devices, unload
the module, load the module passing num_devices equals to N + 1. And do
this again, if needed.
This patch introduces zram control sysfs class, which has two sysfs
attrs:
- hot_add -- add a new zram device
- hot_remove -- remove a specific (device_id) zram device
hot_add sysfs attr is read-only and has only automatic device id
assignment mode (as requested by Minchan Kim). read operation performed
on this attr creates a new zram device and returns back its device_id or
error status.
Usage example:
# add a new specific zram device
cat /sys/class/zram-control/hot_add
2
# remove a specific zram device
echo 4 > /sys/class/zram-control/hot_remove
Returning zram_add() error code back to user (-ENOMEM in this case)
cat: /sys/class/zram-control/hot_add: Cannot allocate memory
NOTE, there might be users who already depend on the fact that at least
zram0 device gets always created by zram_init(). Preserve this behavior.
[minchan@kernel.org: use zram->claim to avoid lockdep splat]
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
- a number of libata core changes to better support NCQ TRIM.
- ahci now supports MSI-X in single IRQ mode to support a new
controller which doesn't implement MSI or INTX.
- ahci now supports edge-triggered IRQ mode to support a new controller
which for some odd reason did edge-triggered IRQ.
- the usual controller support additions and changes.
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits)
libata: Do not blacklist Micron M500DC
ata: ahci_mvebu: add suspend/resume support
ahci, msix: Fix build error for !PCI_MSI
ahci: Add support for Cavium's ThunderX host controller
ahci: Add generic MSI-X support for single interrupts to SATA PCI driver
libata: finally use __initconst in ata_parse_force_one()
drivers: ata: add support for Ceva sata host controller
devicetree:bindings: add devicetree bindings for ceva ahci
ahci: added support for Freescale AHCI sata
ahci: Store irq number in struct ahci_host_priv
ahci: Move interrupt enablement code to a separate function
Doc: libata: Fix spelling typo found in libata.xml
ata:sata_nv - Change 1 to true for bool type variable.
ata: add Broadcom AHCI SATA3 driver for STB chips
Documentation: devicetree: add Broadcom SATA binding
libata: Fix regression when the NCQ Send and Receive log page is absent
ata: hpt366: fix constant cast warning
ata: ahci_xgene: potential NULL dereference in probe
ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller.
libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch.
The dmi-sysfs module adds DMI table structures entries under
/sys/firmware/dmi/entries only, so rename documentation file to
sysfs-firmware-dmi-entries as more appropriate. Without renaming it's
confusing to differ this from sysfs-firmware-dmi-tables that adds raw
DMI table and actually adds "dmi" kobject.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@globallogic.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Some utils, like dmidecode and smbios, need to access SMBIOS entry
table area in order to get information like SMBIOS version, size, etc.
Currently it's done via /dev/mem. But for situation when /dev/mem
usage is disabled, the utils have to use dmi sysfs instead, which
doesn't represent SMBIOS entry and adds code/delay redundancy when direct
access for table is needed.
So this patch creates dmi/tables and adds SMBIOS entry point to allow
utils in question to work correctly without /dev/mem. Also patch adds
raw dmi table to simplify dmi table processing in user space, as
proposed by Jean Delvare.
Tested-by: Roy Franz <roy.franz@linaro.org>
Pull documentation updates from Jonathan Corbet:
"The main thing here is Ingo's big subdirectory documenting feature
support for each architecture. Beyond that, it's the usual pile of
fixes, tweaks, and small additions"
* tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (79 commits)
doc:md: fix typo in md.txt.
Documentation/mic/mpssd: don't build x86 userspace when cross compiling
Documentation/prctl: don't build tsc tests when cross compiling
Documentation/vDSO: don't build tests when cross compiling
Doc:ABI/testing: Fix typo in sysfs-bus-fcoe
Doc: Docbook: Change wikipedia's URL from http to https in scsi.tmpl
Doc: Change wikipedia's URL from http to https
Documentation/kernel-parameters: add missing pciserial to the earlyprintk
Doc:pps: Fix typo in pps.txt
kbuild : Fix documentation of INSTALL_HDR_PATH
Documentation: filesystems: updated struct file_operations documentation in vfs.txt
kbuild: edit explanation of clean-files variable
Doc: ja_JP: Fix typo in HOWTO
Move freefall program from Documentation/ to tools/
Documentation: ARM: EXYNOS: Describe boot loaders interface
Doc:nfc: Fix typo in nfc-hci.txt
vfs: Minor documentation fix
Doc: networking: txtimestamp: fix printf format warning
Documentation, intel_pstate: Improve legacy mode internal governors description
Documentation: extend use case for EXPORT_SYMBOL_GPL()
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
- disable the 32-bit vdso when building LE, so we can build with a
64-bit only toolchain.
- EEH fixes from Gavin & Richard.
- enable the sys_kcmp syscall from Laurent.
- sysfs control for fastsleep workaround from Shreyas.
- expose OPAL events as an irq chip by Alistair.
- MSI ops moved to pci_controller_ops by Daniel.
- fix for kernel to userspace backtraces for perf from Anton.
- merge pseries and pseries_le defconfigs from Cyril.
- CXL in-kernel API from Mikey.
- OPAL prd driver from Jeremy.
- fix for DSCR handling & tests from Anshuman.
- Powernv flash mtd driver from Cyril.
- dynamic DMA Window support on powernv from Alexey.
- LLVM clang fixes & workarounds from Anton.
- reworked version of the patch to abort syscalls when transactional.
- fix the swap encoding to support 4TB, from Aneesh.
- various fixes as usual.
- Freescale updates from Scott: Highlights include more 8xx
optimizations, an e6500 hugetlb optimization, QMan device tree nodes,
t1024/t1023 support, and various fixes and cleanup.
* tag 'powerpc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (180 commits)
cxl: Fix typo in debug print
cxl: Add CXL_KERNEL_API config option
powerpc/powernv: Fix wrong IOMMU table in pnv_ioda_setup_bus_dma()
powerpc/mm: Change the swap encoding in pte.
powerpc/mm: PTE_RPN_MAX is not used, remove the same
powerpc/tm: Abort syscalls in active transactions
powerpc/iommu/ioda2: Enable compile with IOV=on and IOMMU_API=off
powerpc/include: Add opal-prd to installed uapi headers
powerpc/powernv: fix construction of opal PRD messages
powerpc/powernv: Increase opal-irqchip initcall priority
powerpc: Make doorbell check preemption safe
powerpc/powernv: pnv_init_idle_states() should only run on powernv
macintosh/nvram: Remove as unused
powerpc: Don't use gcc specific options on clang
powerpc: Don't use -mno-strict-align on clang
powerpc: Only use -mtraceback=no, -mno-string and -msoft-float if toolchain supports it
powerpc: Only use -mabi=altivec if toolchain supports it
powerpc: Fix duplicate const clang warning in user access code
vfio: powerpc/spapr: Support Dynamic DMA windows
vfio: powerpc/spapr: Register memory and define IOMMU v2
