path: root/CREDITS
2006-09-29[PATCH] /sys/modules: allow full length section namesIan S. Nelson
I've been using systemtap for some debugging and I noticed that it can't probe a lot of modules. Turns out it's kind of silly, the sections section of /sys/module is limited to 32byte filenames and many of the actual sections are a a bit longer than that. [akpm@osdl.org: rewrite to use dymanic allocation] Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Small update to CREDITSJesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[NetLabel]: documentationPaul Moore
Documentation for the NetLabel system, this includes a basic overview of how NetLabel works, how LSM developers can integrate it into their favorite LSM, as well as documentation on the CIPSO related sysctl variables. Also, due to the difficulty of finding expired IETF drafts, I am including the IETF CIPSO draft that is the basis of the NetLabel CIPSO implementation. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-26[DCCP]: Update contact details and copyrightIan McDonald
Just updating copyright and contacts Signed off by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-10[PATCH] Updates CREDITS fileLuiz Fernando N. Capitulino
Updates my personal entry in the CREDITS file. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (23 commits) [PARISC] Move os_id_to_string() inside #ifndef __ASSEMBLY__ [PARISC] Fix do_gettimeofday() hang [PARISC] Fix PCREL22F relocation problem for most modules [PARISC] Refactor show_regs in traps.c [PARISC] Add os_id_to_string helper [PARISC] OS_ID_LINUX == 0x0006 [PARISC] Ensure Space ID hashing is turned off [PARISC] Match show_cache_info with reality [PARISC] Remove unused macro fixup_branch in syscall.S [PARISC] Add is_compat_task() helper [PARISC] Update Thibaut Varene's CREDITS entry [PARISC] Reduce data footprint in pdc_stable.c [PARISC] pdc_stable version 0.30 [PARISC] Work around machines which do not support chassis warnings [PARISC] PDC_CHASSIS is implemented on all machines [PARISC] Remove unconditional #define PIC in syscall macros [PARISC] Use MFIA in current_text_addr on pa2.0 processors [PARISC] Remove dead function pc_in_user_space [PARISC] Test ioc_needs_fdc variable instead of open coding [PARISC] Fix gcc 4.1 warnings in sba_iommu.c ...
2006-06-27[PARISC] Update Thibaut Varene's CREDITS entryThibaut Varene
Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-26move acknowledgment for Mark Adler to CREDITSAdrian Bunk
The place in the documentation of the Linux kernel to acknowledge contributions is the CREDITS file. Give Mark Adler an entry there instead of including a string in the kernel image. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] Update contact information in CREDITSNiels Kristian Bech Jensen
Update my contact information in CREDITS. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] Marcelo has movedMarcelo Tosatti
Signed-off-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-04CREDITS file update (Tristan Greaves)Linus Torvalds
By request from Tristan. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Update contact info for Geert UytterhoevenGeert Uytterhoeven
Update contact info for Geert Uytterhoeven Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Philip Gladstone has movedPhilip Gladstone
I noticed that my email address is four jobs ago. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: classAlessandro Zummo
Add the basic RTC subsystem infrastructure to the kernel. rtc/class.c - registration facilities for RTC drivers rtc/interface.c - kernel/rtc interface functions rtc/hctosys.c - snippet of code that copies hw clock to sw clock at bootup, if configured to do so. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Remova long-incorrect address for Jamie LokierJamie Lokier
Nice place isn't it? I've lived in 7 other houses since then. Signed-off-by: Jamie Lokier <jamie@shareable.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] USB: CREDITS: Add credits about the ZC0301 and ET61X[12]51 USB driversLuca Risolia
This patch adds credits about the ZC0301 and ET61X[12]51 USB drivers which have been included in the mainline kernel recently. Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-19[PATCH] Remove obsolete CREDITS addressAndrea Arcangeli
This address is going to be obsolete, so I should update it.
2006-03-11[PATCH] update email addressChris Wright
Update email address. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] MAINTAINERS/CREDITS: Update SELinux contact infoStephen Smalley
Update my contact info. Please apply. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] CREDITS update: Eugene SuroveginEugene Surovegin
Add EMAC to my CREDITS entry. Signed-off-by: Eugene Surovegin <ebs@ebshome.net Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] Add support for the CS5535 Audio deviceJaya Kumar
Add support for the CS5535 Audio device. I've fixed up some errors as per Takashi's advice from the thread: http://lkml.org/lkml/2005/9/15/119 From: Alan Cox <alan@lxorguk.ukuu.org.uk> cs5535 is a 32bit x86 only device using weird CPU features Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-18[PARISC] Update CREDITS entriesKyle McMartin
Update Randolph Chung's location, and add Thibaut Varene. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Thibaut Varene <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06Update Michal Wronski contact infoMichal Wronski
2005-10-21[PARISC] Update MAINTAINERS and CREDITSKyle McMartin
Add Kyle McMartin and Thibaut Varene as maintainers for ALSA ad1889 driver. Add myself to CREDITS. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-17[DCCP]: Add MAINTAINERS and CREDITS entriesArnaldo Carvalho de Melo
Also remove the SPX entry in MAINTAINERS, forgot to do that when I removed it. Signed-off-by: Ian McDonald <iam4@cs.waikato.ac.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-18[PATCH] Update email addresses for ZwaneZwane Mwaikambo
Some folks have been emailing me and having trouble due to these stale addresses; Signed-off-by: Zwane Mwaikambo <zwane@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] Update contact info for James MorrisJames Morris
2005-07-27[PATCH] Update CREDITS entry and listings in source files for Jesper JuhlJesper Juhl
a) update entry in CREDITS for Jesper Juhl b) remove email address from source files so it's only listed in credits. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] Update my credits entryJames Morris
2005-06-21[PATCH] Framebuffer driver for Arc LCD boardJaya Kumar
Add support for the Arc monochrome LCD board. The board uses KS108 controllers to drive individual 64x64 LCD matrices. The board can be paneled in a variety of setups such as 2x1=128x64, 4x4=256x256 and so on. The board/host interface is through GPIO. Signed-off-by: Jaya Kumar <jayalk@intworks.biz> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-09[PATCH] ARM: 2706/1: Fix compile on SA-based iPAQs and remove stale CREDITS infoDave Neuer
Patch from Dave Neuer This fixes the "multiple definitions of cpufreq_get" errors on StrongARM-based iPAQs. Signed-off-by: Dave Neuer Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-17[PATCH] update CREDITSrandy_dunlap
free agent Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] CREDITS updateColin Leroy
Update Colin's credits entry. Signed-off-by: Colin Leroy <colin@colino.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] update maintainer for /dev/randomMatt Mackall
Ted has agreed to let me take over as maintainer of /dev/random and friends. I've gone ahead and added a line to his entry in CREDITS. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
