2012-07-24leds: convert Network Space v2 LED driver to devm_kzalloc() and cleanup ↵Bryan Wu
error exit path Cc: Simon Guinot <sguinot@lacie.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert DAC124S085 LED driver to devm_kzalloc()Bryan Wu
Cc: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert LM3530 LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: Shreshtha Kumar SAHU <shreshthakumar.sahu@stericsson.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert TCA6507 LED driver to devm_kzalloc()Bryan Wu
Cc: Neil Brown <neilb@suse.de> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert Freescale MC13783 LED driver to devm_kzalloc() and cleanup ↵Bryan Wu
error exit path Cc: Philippe Retornaz <philippe.retornaz@epfl.ch> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert ADP5520 LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: Michael Hennerich <hennerich@blackfin.uclinux.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert PCA955x LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: Nate Case <ncase@xes-inc.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert Sun Fire LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert PCA9532 LED driver to devm_kzalloc()Bryan Wu
Cc: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert LT3593 LED driver to devm_kzalloc()Bryan Wu
Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert Renesas TPU LED driver to devm_kzalloc() and cleanup error ↵Bryan Wu
exit path Cc: Magnus Damm <damm@opensource.se> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert LP5523 LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: Mathias Nyman <mathias.nyman@nokia.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert PCA9633 LED driver to devm_kzalloc()Bryan Wu
Cc: Peter Meerwald <p.meerwald@bct-electronic.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert BD2802 RGB LED driver to devm_kzalloc() and cleanup error exit ↵Bryan Wu
path Cc: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert LP5521 LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
2012-07-24leds: convert DA9030/DA9034 LED driver to devm_kzalloc() and cleanup error ↵Bryan Wu
exit path Cc: Eric Miao <eric.miao@canonical.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert LP3944 LED driver to devm_kzalloc()Bryan Wu
Cc: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert Atmel PWM LED driver to devm_kzalloc()Bryan Wu
2012-07-24leds: convert HTC ASIC3 LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert Big Networks LED driver to devm_kzalloc()Bryan Wu
2012-07-24leds: Use devm_kzalloc in leds-gpio.c fileSachin Kamat
devm_kzalloc() makes cleanup simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Use devm_kzalloc in leds-max8997.c fileSachin Kamat
devm_kzalloc() makes code cleanup simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Use devm_kzalloc in leds-regulator.c fileSachin Kamat
2012-07-24leds: Use devm_kzalloc in leds-pwm.c fileSachin Kamat
2012-07-24leds: Use module_platform_driver() in leds-max8997.c fileSachin Kamat
module_platform_driver() makes the code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: convert tca6507 driver to module_i2c_driver()Peter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com> Cc: NeilBrown <neilb@suse.de> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Convert S3C24XX LED driver to gpiolib APISylwester Nawrocki
The s3c2410_gpio* calls are obsolete and have been scheduled for removal since several kernel releases. Remove them and use common gpiolib API instead. This patch also adds gpio_request/gpio_free call for API corectness. It is a prerequisite for removal of the S3C24XX SoC specific arch/arm/plat-samsung/include/gpio-fns.h header. Tested on Micro2440-SDK. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Convert S3C24XX LED driver to devm_kzalloc()Sylwester Nawrocki
Use the device managed resource API for simplifying the error/driver remove paths. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds-mc13783: set platform data to NULL at mc13783_led_removeDevendra Naga
the platform_set_drvdata (pdev, NULL) to be set at the remove of the driver, as we have set the platform data to led at probe. Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds-88pm860x: use devm_kzalloc functionDevendra Naga
Using devm_kzalloc will remove all the error checks and the frees are automatically done at the driver unload side. Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds-lp5523: BUG() in error handling in probe()Dan Carpenter
Inside the error handling in lp5523_init_led(), there is a place that calls to led_classdev_unregister(). When we unregister the LED drivers, it tries to set the brightness to OFF. In this driver setting the brightness is done through a work queue and the work queue hasn't been initialized yet. The result is that we trigger a WARN_ON() in the __queue_work(). The fix is to move the INIT_WORK() in front of the call to lp5523_init_led(). Matt Renzelmann found this using a bug finding tool. Reported-by: Matt Renzelmann <mjr@cs.wisc.edu> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Add LED driver for lm3556 chipG.Shark Jeong
LM3556 : The LM3556 is a 4 MHz fixed-frequency synchronous boost converter plus 1.5A constant current driver for a high-current white LED. Datasheet: www.national.com/ds/LM/LM3556.pdf Tested on OMAP4430 (bryan.wu@canonical.com: use module_i2c_driver() rather than lm3556_init/lm3556_exit for code simplicity; fixed some typo pointed out by Rob Landley) Signed-off-by: G.Shark Jeong <gshark.jeong@gmail.com> Reviewed-by: Axel Lin <axel.lin@gmail.com> Reviewed-by: Kim, Milo <Milo.Kim@ti.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: [trivial]Remove unnecesary returnDevendra Naga
the ret is got the status returned by the led_classdev_register, returning ret if the led_classdev_register fails and returning 0 if the led_classdev_register success, can be done by doing just "return ret" at the end. Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: fix sparse warnings due to missing staticBryan Wu
drivers/leds/led-core.c:56:6: sparse: symbol 'led_blink_setup' was not declared. Should it be static? drivers/leds/led-triggers.c:233:6: sparse: symbol 'led_trigger_blink_setup' was not declared. Should it be static? Reported-by: Fengguang Wu <wfg@linux.intel.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: correct trivial type in drivers/leds/KconfigJesper Dangaard Brouer
Correct "hadrware" to "hardware", for LEDS_TRIGGER_TRANSIENT. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: use led_set_brightness in led_trigger_eventFabio Baltieri
Fix led_trigger_event() to use led_set_brightness() instead of __led_set_brightness(), so that any pending blink timer is stopped before setting the new brightness value. Without this fix LED status may be overridden by a pending timer. This allows a trigger to use a mix of led_trigger_event(), led_trigger_blink() and led_trigger_blink_oneshot() without races. (applied over: leds: Rename led_brightness_set() to led_set_brightness()) Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Cc: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Rename led_brightness_set() to led_set_brightness()Shuah Khan
Rename leds external interface led_brightness_set() to led_set_brightness(). This is the second phase of the change to reduce confusion between the leds internal and external interfaces that set brightness. With this change, now the external interface is led_set_brightness(). The first phase renamed the internal interface led_set_brightness() to __led_set_brightness(). There are no changes to the interface implementations. Signed-off-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: Rename led_set_brightness() to __led_set_brightness()Shuah Khan
Rename leds internal interface led_set_brightness() to __led_set_brightness() to reduce confusion between led_set_brightness() and the external interface led_brightness_set(). led_brightness_set() cancels the timer and then calls led_set_brightness(). Signed-off-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: add oneshot triggerFabio Baltieri
Add oneshot trigger to blink a led with configurale parameters via sysfs. Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Cc: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: fix led_brightness_set when soft-blinkingFabio Baltieri
Move led_stop_software_blink() code into led_brightness_set() to ensure software blink timer is stopped and cleared when changing trigger. Also use led_set_brightness() instead of calling led_cdev->brightness_set() directly to keep led_cdev->brightness consistent with current LED status. This ensure proper cleaning when changing triggers, as without this fix a LED may be turned off while leaving it's led_cdev->brightness = 1, leading to an erratic software-blink behaviour. The problem was easy to reproduce by changing the trigger from "timer" to "oneshot". Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24ledtrig-ide-disk: use generic one-shot blink apiFabio Baltieri
Convert ledtrig-ide-disk code to use the generic API for one-shot LED blinking. This patch changes slightly the behaviour of the trigger, as while the original version kept the LED on under heavy activity, the new one keeps a constant on-off blink at 1 / (2 * BLINK_DELAY) Hz. (bryan.wu@canonical.com: remove 2 useless included header files) Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24leds: add oneshot blink functionsFabio Baltieri
Add two new functions, led_blink_set_oneshot and led_trigger_blink_oneshot, to be used by triggers for one-shot blink of led devices. This is implemented extending the existing software-blink code, and uses the same timer and handler function. The behavior of the code is to do a blink-on, blink-off sequence when the function is called, ignoring other calls until the sequence is completed so that the leds keep blinking at constant rate if the functions are called repeatedly. This is meant to be used by drivers which needs to trigger on sporadic event, but doesn't have clear busy/idle trigger points. After the blink sequence the led remains off. This behavior can be inverted setting the "invert" argument, which blink the led off, than on and leave the led on after the sequence. (bryan.wu@canonical.com: rebase to commit 'leds: don't disable blinking when writing the same value to delay_on or delay_off') Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com> Acked-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-24led-triggers: rename *trigger to *trig for unified naming schemeBryan Wu
No functional change. Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-21Linux 3.5v3.5Linus Torvalds
2012-07-21Remove SYSTEM_SUSPEND_DISK system stateRafael J. Wysocki
The SYSTEM_SUSPEND_DISK system state is never used, so drop it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-21Merge branch 'anton-kgdb' (kgdb dmesg fixups)Linus Torvalds
Merge emailed kgdb dmesg fixups patches from Anton Vorontsov: "The dmesg command appears to be broken after the printk rework. The old logic in the kdb code makes no sense in terms of current printk/logging storage format, and KDB simply hangs forever upon entering 'dmesg' command. The first patch revives the command by switching to kmsg_dumper iterator. As a side-effect, the code is now much more simpler. A few changes were needed in the printk.c: we needed unlocked variant of the kmsg_dumper iterator, but these can surely wait for 3.6. It's probably too late even for the first patch to go to 3.5, but I'll try to convince otherwise. :-) Here we go: - The current code is broken for sure, and has no hope to work at all. It is a regression - The new code works for me, and probably works for everyone else; - If it compiles (and I urge everyone to compile-test it on your setup), it hardly can make things worse." * Merge emailed patches from Anton Vorontsov: (4 commits) kdb: Switch to nolock variants of kmsg_dump functions printk: Implement some unlocked kmsg_dump functions printk: Remove kdb_syslog_data kdb: Revive dmesg command
2012-07-21kdb: Switch to nolock variants of kmsg_dump functionsAnton Vorontsov
The locked variants are prone to deadlocks (suppose we got to the debugger w/ the logbuf lock held), so let's switch to nolock variants. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-21printk: Implement some unlocked kmsg_dump functionsAnton Vorontsov
If used from KDB, the locked variants are prone to deadlocks (suppose we got to the debugger w/ the logbuf lock held). So, we have to implement a few routines that grab no logbuf lock. Yet we don't need these functions in modules, so we don't export them. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-21printk: Remove kdb_syslog_dataAnton Vorontsov
The function is no longer needed, so remove it. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-21kdb: Revive dmesg commandAnton Vorontsov
The kgdb dmesg command is broken after the printk rework. The old logic in kdb code makes no sense in terms of current printk/logging storage format, and KDB simply hangs forever. This patch revives the command by switching to kmsg_dumper iterator. The code is now much more simpler and shorter. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
