2016-06-10vfs: make the string hashes salt the hashLinus Torvalds
We always mixed in the parent pointer into the dentry name hash, but we did it late at lookup time. It turns out that we can simplify that lookup-time action by salting the hash with the parent pointer early instead of late. A few other users of our string hashes also wanted to mix in their own pointers into the hash, and those are updated to use the same mechanism. Hash users that don't have any particular initial salt can just use the NULL pointer as a no-salt. Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: George Spelvin <linux@sciencehorizons.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-09Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma fixes from Doug Ledford: "This is the first -rc pull for the RDMA subsystem. The patch count is high, but they are all smallish patches fixing simple things for the most part, and the overall line count of changes here is smaller than the patch count would lead a person to believe. Code is up and running in my labs, including direct testing of cxgb4, mlx4, mlx5, ocrdma, and qib. Summary: - Multiple minor fixes to the rdma core - Multiple minor fixes to hfi1 - Multiple minor fixes to mlx5 - A very few other minor fixes (SRP, IPoIB, usNIC, mlx4)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (35 commits) IB/IPoIB: Don't update neigh validity for unresolved entries IB/mlx5: Fix alternate path code IB/mlx5: Fix pkey_index length in the QP path record IB/mlx5: Fix entries check in mlx5_ib_resize_cq IB/mlx5: Fix entries checks in mlx5_ib_create_cq IB/mlx5: Check BlueFlame HCA support IB/mlx5: Fix returned values of query QP IB/mlx5: Limit query HCA clock IB/mlx5: Fix FW version diaplay in sysfs IB/mlx5: Return PORT_ERR in Active to Initializing tranisition IB/mlx5: Set flow steering capability bit IB/core: Make all casts in ib_device_cap_flags enum consistent IB/core: Fix bit curruption in ib_device_cap_flags structure IB/core: Initialize sysfs attributes before sysfs create group IB/IPoIB: Disable bottom half when dealing with device address IB/core: Fix removal of default GID cache entry IB/IPoIB: Fix race between ipoib_remove_one to sysfs functions IB/core: Fix query port failure in RoCE IB/core: fix error unwind in sysfs hw counters code IB/core: Fix array length allocation ...
2016-06-09Merge tag 'arc-4.7-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: - Revert of ll-sc backoff retry workaround in atomics/spinlocks as hardware is now proven to work just fine - Typo fixes (Thanks Andrea Gelmini) - Removal of obsolete DT property (Alexey) - Other minor fixes * tag 'arc-4.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: Revert "ARCv2: spinlock/rwlock/atomics: Delayed retry of failed SCOND with exponential backoff" Revert "ARCv2: spinlock/rwlock: Reset retry delay when starting a new spin-wait cycle" Revert "ARCv2: spinlock/rwlock/atomics: reduce 1 instruction in exponential backoff" ARC: don't enable DISCONTIGMEM unconditionally ARC: [intc-compact] simplify code for 2 priority levels arc: Get rid of root core-frequency property Fix typos
2016-06-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Fixes for crap of assorted ages: EOPENSTALE one is 4.2+, autofs one is 4.6, d_walk - 3.2+. The atomic_open() and coredump ones are regressions from this window" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coredump: fix dumping through pipes fix a regression in atomic_open() fix d_walk()/non-delayed __d_free() race autofs braino fix for do_last() fix EOPENSTALE bug in do_last()
2016-06-07coredump: fix dumping through pipesMateusz Guzik
The offset in the core file used to be tracked with ->written field of the coredump_params structure. The field was retired in favour of file->f_pos. However, ->f_pos is not maintained for pipes which leads to breakage. Restore explicit tracking of the offset in coredump_params. Introduce ->pos field for this purpose since ->written was already reused. Fixes: a00839395103 ("get rid of coredump_params->written"). Reported-by: Zbigniew Jędrzejewski-Szmek <zbyszek@in.waw.pl> Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07fix a regression in atomic_open()Al Viro
open("/foo/no_such_file", O_RDONLY | O_CREAT) on should fail with EACCES when /foo is not writable; failing with ENOENT is obviously wrong. That got broken by a braino introduced when moving the creat_error logics from atomic_open() to lookup_open(). Easy to fix, fortunately. Spotted-by: "Yan, Zheng" <ukernel@gmail.com> Tested-by: "Yan, Zheng" <ukernel@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07fix d_walk()/non-delayed __d_free() raceAl Viro
Ascend-to-parent logics in d_walk() depends on all encountered child dentries not getting freed without an RCU delay. Unfortunately, in quite a few cases it is not true, with hard-to-hit oopsable race as the result. Fortunately, the fix is simiple; right now the rule is "if it ever been hashed, freeing must be delayed" and changing it to "if it ever had a parent, freeing must be delayed" closes that hole and covers all cases the old rule used to cover. Moreover, pipes and sockets remain _not_ covered, so we do not introduce RCU delay in the cases which are the reason for having that delay conditional in the first place. Cc: stable@vger.kernel.org # v3.2+ (and watch out for __d_materialise_dentry()) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clk fixes from Stephen Boyd: "This finally removes the CLK_IS_ROOT flag by picking up the last few stragglers that didn't get merged by anyone this time around. Better to do it now than wait for another one to pop up. There's also a minor maintainers update and a Kconfig fix" * tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: clk: nxp: Select MFD_SYSCON for creg driver MAINTAINERS: Add file patterns for clock device tree bindings clk: Remove CLK_IS_ROOT flag clk: microchip: Remove CLK_IS_ROOT powerpc/512x: clk: Remove CLK_IS_ROOT vexpress/spc: Remove CLK_IS_ROOT
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull userns fixes from Eric Biederman: "This contains two small but significant fixes to fs/namespace.c. The first adds a filesystem refcount drop on error. The second corrects a test in fs_fully_visible which could be abused to allow mounting of proc or sysfs, when that should not be allowed. To keep myself honest I have tested to ensure the incorrect test in fs_fully_visible actually allows improper mounting of proc before the fix and that when fixed the improper mounting is not allowed" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: mnt: fs_fully_visible test the proper mount for MNT_LOCKED mnt: If fs_fully_visible fails call put_filesystem.
2016-06-07IB/IPoIB: Don't update neigh validity for unresolved entriesErez Shitrit
ipoib_neigh_get unconditionally updates the "alive" variable member on any packet send. This prevents the neighbor garbage collection from cleaning out a dead neighbor entry if we are still queueing packets for it. If the queue for this neighbor is full, then don't update the alive timestamp. That way the neighbor can time out even if packets are still being queued as long as none of them are being sent. Fixes: b63b70d87741 ("IPoIB: Use a private hash table for path lookup in xmit path") Signed-off-by: Erez Shitrit <erezsh@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Fix alternate path codeAchiad Shochat
Userspace flag IBV_QP_ALT_PATH is supposed to set the alternate path including fields alt_pkey_index and alt_timeout. Added IB_QP_PKEY_INDEX and IB_QP_TIMEOUT to the attribute mask when calling mlx5_set_path for the alternate path to force setting the alt_pkey_index and alt_timeout values. Fixes: bf24481a3a7c4 ('IB/mlx5: Consider alternate path in pkey ...') Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Fix pkey_index length in the QP path recordNoa Osherovich
Pkey index fields in the QP context path record are extended to 16 bits, as required by IB spec (version 1.3). This change affects all QP commands which include path records. To enable this change, moved the free adaptive routing flag bit (free_ar) to the most significant byte of the QP path record. Fixes: e126ba97dba9e ('mlx5: Add driver for Mellanox Connect-IB ...') Signed-off-by: Noa Osherovich <noaos@mellanox.com> Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Fix entries check in mlx5_ib_resize_cqNoa Osherovich
Verify that number of entries is less than device capability. Add an appropriate warning message for error flow. Fixes: bde51583f49b ('IB/mlx5: Add support for resize CQ') Signed-off-by: Majd Dibbiny <majd@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Fix entries checks in mlx5_ib_create_cqNoa Osherovich
Number of entries shouldn't be greater than the device's max capability. This should be checked before rounding the entries number to power of two. Fixes: 51ee86a4af639 ('IB/mlx5: Fix check of number of entries...') Signed-off-by: Majd Dibbiny <majd@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Check BlueFlame HCA supportNoa Osherovich
BlueFlame support is reported only for PFs when the HCA capability is on. Fixes: 938fe83c8dcbb ('net/mlx5_core: New device capabilities...') Signed-off-by: Majd Dibbiny <majd@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Fix returned values of query QPNoa Osherovich
Some variables were not initialized properly: max_recv_wr, max_recv_sge, max_send_wr, qp_context and max_inline_data. Fixes: e126ba97dba9 ('mlx5: Add driver for Mellanox Connect-IB...') Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Limit query HCA clockNoa Osherovich
When PAGE_SIZE is larger than 4K, the user shouldn't be able to query the HCA core clock. This counter is within 4KB boundary and the user-space shall not read information that's after this boundary. Fixes: b368d7cb8ceb7 ('IB/mlx5: Add hca_core_clock_offset to...') Signed-off-by: Majd Dibbiny <majd@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Fix FW version diaplay in sysfsEran Ben Elisha
Add a 4-digit padding to show FW version in proper format. Fixes: 9603b61de1eee ('mlx5: Move pci device handling from...') Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Return PORT_ERR in Active to Initializing tranisitionNoa Osherovich
FW port-change events are fired on Active <-> non Active port state transitions only. When the port state changes from Active to Initializing (Active -> Down -> Initializing), a single event is fired. The HCA transitions from Down to Initializing unless prevented from doing so, hence the driver should also propagate events when the port state is Initializing to consumers so they'll be aware that the port is no longer Active and act accordingly. Fixes: e126ba97dba9e ('mlx5: Add driver for Mellanox Connect-IB...') Signed-off-by: Noa Osherovich <noaos@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/mlx5: Set flow steering capability bitMaor Gottlieb
Flow steering is supported by mlx5 device when the following features are supported by firmware: 1. NIC RX flow table. 2. Device has enough flow steering levels. 3. Atomic modification of flow table entry. 4. Flow tables chaining. To check if flow steering is supported it's enough to check if the driver opened the mlx5 bypass namespace. Signed-off-by: Maor Gottlieb <maorg@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: Make all casts in ib_device_cap_flags enum consistentMax Gurtovoy
Replace the few u64 casts with ULL to match the rest of the casts. Signed-off-by: Max Gurtovoy <maxg@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: Fix bit curruption in ib_device_cap_flags structureMax Gurtovoy
ib_device_cap_flags 64-bit expansion caused caps overlapping and made consumers read wrong device capabilities. For example IB_DEVICE_SG_GAPS_REG was falsely read by the iser driver causing it to use a non-existing capability. This happened because signed int becomes sign extended when converted it to u64. Fix this by casting IB_DEVICE_ON_DEMAND_PAGING enumeration to ULL. Fixes: f5aa9159a418 ('IB/core: Add arbitrary sg_list support') Reported-by: Robert LeBlanc <robert@leblancnet.us> Cc: Stable <stable@vger.kernel.org> #[v4.6+] Acked-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Max Gurtovoy <maxg@mellanox.com> Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: Initialize sysfs attributes before sysfs create groupMark Bloch
For dynamically allocated sysfs attributes there is a need to call sysfs_attr_init in order to comply with lockdep, not calling it will result in error complaining key is not in .data section. Fixes: b40f4757daa1 ("IB/core: Make device counter infrastructure dynamic") Signed-off-by: Mark Bloch <markb@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/IPoIB: Disable bottom half when dealing with device addressMark Bloch
Align locking usage when touching device address with rest of the kernel. Lock the bottom half when doing so using netif_addr_lock_bh. This also solves the following case as reported by lockdep: CPU0 CPU1 ---- ---- lock(_xmit_INFINIBAND); local_irq_disable(); lock(&(&mc->mca_lock)->rlock); lock(_xmit_INFINIBAND); <Interrupt> lock(&(&mc->mca_lock)->rlock); *** DEADLOCK *** Fixes: 492a7e67ff83 ("IB/IPoIB: Allow setting the device address") Signed-off-by: Mark Bloch <markb@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: Fix removal of default GID cache entryAviv Heller
When deleting a default GID from the cache, its gid_type field is set to 0. This could set the gid_type to RoCE v1 for a RoCE v2 default GID, essentially making it inaccessible to future modifications, since it is no longer found by find_gid(). This fix preserves the gid_type value for default gids during cache operations. Fixes: b39ffa1df505 ('IB/core: Add gid_type to gid attribute') Signed-off-by: Aviv Heller <avivh@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/IPoIB: Fix race between ipoib_remove_one to sysfs functionsErez Shitrit
In ipoib_remove_one the driver holds the rtnl_lock and tries to do some operation like dev_change_flags or unregister_netdev, while sysfs callback like ipoib_vlan_delete holds sysfs mutex and tries to hold the rtnl_lock via rtnl_trylock() and restart_syscall() if the lock is not free, meanwhile ipoib_remove_one tries to get the sysfs lock in order to free its sysfs directory, and we will get a->b, b->a deadlock. Trace like the following: schedule+0x37/0x80 schedule_preempt_disabled+0xe/0x10 __mutex_lock_slowpath+0xb5/0x120 mutex_lock+0x23/0x40 rtnl_lock+0x15/0x20 netdev_run_todo+0x17c/0x320 rtnl_unlock+0xe/0x10 ipoib_vlan_delete+0x11b/0x1b0 [ib_ipoib] delete_child+0x54/0x80 [ib_ipoib] dev_attr_store+0x18/0x30 sysfs_kf_write+0x37/0x40 mutex_lock+0x16/0x40 SyS_write+0x55/0xc0 entry_SYSCALL_64_fastpath+0x16/0x75 And schedule+0x37/0x80 __kernfs_remove+0x1a8/0x260 ? wake_atomic_t_function+0x60/0x60 kernfs_remove+0x25/0x40 sysfs_remove_dir+0x50/0x80 kobject_del+0x18/0x50 device_del+0x19f/0x260 netdev_unregister_kobject+0x6a/0x80 rollback_registered_many+0x1fd/0x340 rollback_registered+0x3c/0x70 unregister_netdevice_queue+0x55/0xc0 unregister_netdev+0x20/0x30 ipoib_remove_one+0x114/0x1b0 [ib_ipoib] ib_unregister_client+0x4a/0x170 [ib_core] ? find_module_all+0x71/0xa0 ipoib_cleanup_module+0x10/0x94 [ib_ipoib] SyS_delete_module+0x1b5/0x210 entry_SYSCALL_64_fastpath+0x16/0x75 The fix is by checking the flag IPOIB_FLAG_INTF_ON_DESTROY in order to get out from the sysfs function. Fixes: 862096a8bbf8 ("IB/ipoib: Add more rtnl_link_ops callbacks") Fixes: 9baa0b036410 ("IB/ipoib: Add rtnl_link_ops support") Signed-off-by: Erez Shitrit <erezsh@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: Fix query port failure in RoCEEli Cohen
Currently ib_query_port always attempts to to read the subnet prefix by calling ib_query_gid(). For RoCE/iWARP there is no subnet manager and no subnet prefix. Fix this by querying GID[0] only for IB networks. Fixes: fad61ad4e755 ('IB/core: Add subnet prefix to port info') Signed-off-by: Eli Cohen <eli@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: fix error unwind in sysfs hw counters codeDoug Ledford
Between the initial and final versions of the function setup_hw_stats, the order of variable initialization was changed. However, the unwind flow on error did not properly keep up with the flow changes. Make the unwind flow match a proper unwind of the allocation flow, then remove no longer needed variable initializations. Fixes: b40f4757daa1 (IB/core: Make device counter infrastructure dynamic) Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-07IB/core: Fix array length allocationDoug Ledford
The new sysfs hw_counters code had an off by one in its array allocation length. Fix that and the comment along with it. Reported-by: Mark Bloch <markb@mellanox.com> Fixes: b40f4757daa1 (IB/core: Make device counter infrastructure dynamic) Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06mnt: fs_fully_visible test the proper mount for MNT_LOCKEDEric W. Biederman
MNT_LOCKED implies on a child mount implies the child is locked to the parent. So while looping through the children the children should be tested (not their parent). Typically an unshare of a mount namespace locks all mounts together making both the parent and the slave as locked but there are a few corner cases where other things work. Cc: stable@vger.kernel.org Fixes: ceeb0e5d39fc ("vfs: Ignore unlocked mounts in fs_fully_visible") Reported-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-06mnt: If fs_fully_visible fails call put_filesystem.Eric W. Biederman
Add this trivial missing error handling. Cc: stable@vger.kernel.org Fixes: 1b852bceb0d1 ("mnt: Refactor the logic for mounting sysfs and proc in a user namespace") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-06IB/hfi1: Suppress sparse warningsBart Van Assche
Avoid that sparse reports the following warnings for the hfi1 driver: trace.c:217:13: warning: no previous prototype for ‘print_u64_array’ [-Wmissing-prototypes] user_sdma.c:1361:17: warning: dubious: !x & y Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Mike Marciniszyn <mike.marciniszyn@intel.com> Cc: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/hfi1: Use bit 0 instead of bit 1Bart Van Assche
The first argument of test_bit() and clear_bit() is a bit number and not a bitmask. Hence change that first argument from (1 << 0) into 0. This patch avoids that smatch reports the following warnings: user_sdma.c:1059: sdma_cache_evict() warn: test_bit() takes a bit number user_sdma.c:1590: sdma_rb_remove() warn: test_bit() takes a bit number Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Mike Marciniszyn <mike.marciniszyn@intel.com> Cc: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/hfi1: Fix indentationBart Van Assche
Make the indentation of the source code consistent. Detected by smatch. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Mike Marciniszyn <mike.marciniszyn@intel.com> Cc: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/rdmavt: Annotate rvt_reset_qp()Bart Van Assche
This patch avoids that sparse reports the following warning: rdmavt/qp.c:507:17: warning: context imbalance in 'rvt_reset_qp' - unexpected unlock Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Mike Marciniszyn <mike.marciniszyn@intel.com> Cc: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/mad: Fix indentationBart Van Assche
Make indentation consistent. Detected by smatch. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Hal Rosenstock <hal@mellanox.com> Cc: Ira Weiny <ira.weiny@intel.com> Reviewed-By: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Hal Rosenstock <hal@mellanox.com> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06RDMA/core: Fix indentationBart Van Assche
Make indentation consistent. Detected by smatch. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com> Cc: Steve Wise <swise@opengridcomputing.com> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Reviewed-by: Sagi Grimberg <sagi@gimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/srp: Fix srp_map_sg_dma()Bart Van Assche
Because patch "IB/srp: Move common code into the caller" was applied partially srp_map_sg_dma() doesn't work properly. Fix this by applying the remainder of that patch. See also http://thread.gmane.org/gmane.linux.drivers.rdma/35803/focus=35811. Fixes: 3849e44d1c4b ("IB/srp: Move common code into the caller") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Mike Marciniszyn <mike.marciniszyn@intel.com> Cc: Sagi Grimberg <sai@grimberg.me> Cc: Christoph Hellwig <hch@lst.de> Cc: Laurence Oberman <loberman@redhat.com> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/srp: Always initialize use_fast_reg and use_fmrBart Van Assche
Avoid that mapping fails due to use_fast_reg != 0 or use_fmr != 0 if both member variables should be zero (if never_register == 1 or if neither FMR nor FR is supported). Remove an initialization that became superfluous due to changing a kmalloc() into a kzalloc() call. Fixes: 509c5f33f4f6 ("IB/srp: Prevent mapping failures") Cc: Sagi Grimberg <sai@grimberg.m> Cc: Christoph Hellwig <hch@lst.de> Cc: Laurence Oberman <loberman@redhat.com> Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/mlx4: Fix device managed flow steering support testBart Van Assche
Perform the test for device managed flow steering support even if memory windows are not supported. I noticed this because smatch reported inconsistent indentation for the device managed flow steering support test. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Cc: Yishai Hadas <yishaih@mellanox.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/usnic: Remove unused DMA attributesKrzysztof Kozlowski
The DMA attributes are set but never used. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/core: fix null pointer deref and mem leak in error handlingColin Ian King
The current error handling in setup_hw_stats has a couple of issues. It is possible to generate a null pointer deference on the kfree of hsag->attrs[i] because two of the early error exit paths jump to the kfree when hsags NULL and not allocated. Fix this by moving the kfree on stats and jumping to that, avoiding the hsag freeing. Secondly, there is a memory leak of stats if the hsag allocation fails; instead of returning, jump to the kfree on stats. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/core: fix an error code in ib_core_init()Dan Carpenter
We should return the error code if ib_add_ibnl_clients() fails. The current code returns success. Fixes: 735c631ae99d ('IB/core: Register SA ibnl client during ib_core initialization') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Mark Bloch <markb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/hfi1: Avoid large frame size warningLeon Romanovsky
When CONFIG_FRAME_WARN is set to 1024 bytes, which is useful to find stack consumers, we get a warning in hfi1 driver. drivers/infiniband/hw/hfi1/affinity.c: In function ‘hfi1_get_proc_affinity’: drivers/infiniband/hw/hfi1/affinity.c:415:1: warning: the frame size of 1056 bytes is larger than 1024 bytes [-Wframe-larger-than=] This change removes unneeded buf[1024] declaration and usage. Fixes: f48ad614c100 ("IB/hfi1: Move driver out of staging") Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Acked-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/hfi1: fix some indentingDan Carpenter
That extra tabs are misleading. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06IB/cm: Fix a recently introduced locking bugBart Van Assche
ib_cm_notify() can be called from interrupt context. Hence do not reenable interrupts unconditionally in cm_establish(). This patch avoids that lockdep reports the following warning: WARNING: CPU: 0 PID: 23317 at kernel/locking/lockdep.c:2624 trace _hardirqs_on_caller+0x112/0x1b0 DEBUG_LOCKS_WARN_ON(current->hardirq_context) Call Trace: <IRQ> [<ffffffff812bd0e5>] dump_stack+0x67/0x92 [<ffffffff81056f21>] __warn+0xc1/0xe0 [<ffffffff81056f8a>] warn_slowpath_fmt+0x4a/0x50 [<ffffffff810a5932>] trace_hardirqs_on_caller+0x112/0x1b0 [<ffffffff810a59dd>] trace_hardirqs_on+0xd/0x10 [<ffffffff815992c7>] _raw_spin_unlock_irq+0x27/0x40 [<ffffffffa0382e9c>] ib_cm_notify+0x25c/0x290 [ib_cm] [<ffffffffa068fbc1>] srpt_qp_event+0xa1/0xf0 [ib_srpt] [<ffffffffa04efb97>] mlx4_ib_qp_event+0x67/0xd0 [mlx4_ib] [<ffffffffa034ec0a>] mlx4_qp_event+0x5a/0xc0 [mlx4_core] [<ffffffffa03365f8>] mlx4_eq_int+0x3d8/0xcf0 [mlx4_core] [<ffffffffa0336f9c>] mlx4_msi_x_interrupt+0xc/0x20 [mlx4_core] [<ffffffff810b0914>] handle_irq_event_percpu+0x64/0x100 [<ffffffff810b09e4>] handle_irq_event+0x34/0x60 [<ffffffff810b3a6a>] handle_edge_irq+0x6a/0x150 [<ffffffff8101ad05>] handle_irq+0x15/0x20 [<ffffffff8101a66c>] do_IRQ+0x5c/0x110 [<ffffffff8159a2c9>] common_interrupt+0x89/0x89 [<ffffffff81297a17>] blk_run_queue_async+0x37/0x40 [<ffffffffa0163e53>] rq_completed+0x43/0x70 [dm_mod] [<ffffffffa0164896>] dm_softirq_done+0x176/0x280 [dm_mod] [<ffffffff812a26c2>] blk_done_softirq+0x52/0x90 [<ffffffff8105bc1f>] __do_softirq+0x10f/0x230 [<ffffffff8105bec8>] irq_exit+0xa8/0xb0 [<ffffffff8103653e>] smp_trace_call_function_single_interrupt+0x2e/0x30 [<ffffffff81036549>] smp_call_function_single_interrupt+0x9/0x10 [<ffffffff8159a959>] call_function_single_interrupt+0x89/0x90 <EOI> Fixes: commit be4b499323bf (IB/cm: Do not queue work to a device that's going away) Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Erez Shitrit <erezsh@mellanox.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Nikolay Borisov <kernel@kyup.com> Cc: stable <stable@vger.kernel.org> # v4.2+ Acked-by: Erez Shitrit <erezsh@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-06-06Merge tag 'edac_fixes_for_4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull EDAC fixes from Borislav Petkov: "EDAC fixes to recent fallout from workqueue cleanup and Broadwell enablement: - sb_edac fallout fixes from recent Broadwell enablement (Tony Luck) - EDAC workqueue poll period resetting fix (Nicholas Krause)" * tag 'edac_fixes_for_4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: EDAC, sb_edac: Readd accidentally dropped Broadwell-D support EDAC: Fix workqueues poll period resetting EDAC, sb_edac: Fix rank lookup on Broadwell
2016-06-05Linux 4.7-rc2Linus Torvalds
2016-06-05Merge branch 'parisc-4.7-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fixes from Helge Deller: - Fix printk time stamps on SMP systems which got wrong due to a patch which was added during the merge window - Fix two bugs in the stack backtrace code: Races in module unloading and possible invalid accesses to memory due to wrong instruction decoding (Mikulas Patocka) - Fix userspace crash when syscalls access invalid unaligned userspace addresses. Those syscalls will now return EFAULT as expected. (tagged for stable kernel series) * 'parisc-4.7-2' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Move die_if_kernel() prototype into traps.h header parisc: Fix pagefault crash in unaligned __get_user() call parisc: Fix printk time during boot parisc: Fix backtrace on PA-RISC
2016-06-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull key handling update from James Morris: "This alters a new keyctl function added in the current merge window to allow for a future extension planned for the next merge window" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: KEYS: Add placeholder for KDF usage with DH
