2009-12-05V4L/DVB (13099): ir-functions: Export ir_rc5_decode() for use by the cx23885 ↵Andy Walls
module Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13098): cx23885: Add integrated IR subdevice interrupt and ↵Andy Walls
notification handling Add integrated IR subdevice interrupt and notification handling. This is in preparation of input keypress handling changes for the cx23885 module. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13097): cx23885: Complete CX23888 IR subdev implementation for Rx & ↵Andy Walls
almost for Tx This change completes the v4l2_subdev implementation for IR receive for the IR controller built into the CX23888. This changes almost completes the IR transmit side also, but doesn't. Instead notes in the comments describe what needs to be done for IR Tx to work in the subdevice implementation. The current Tx behavior is skeletal and benign. If left alone, it does nothing. It will only ever generate a Tx interrupt on Tx init by a caller or when the tx_write() method is called. The ISR, when called, will then disable the Tx FIFO service interrupt. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13096): v4l2-subdev: Add v4l2_subdev_ir_ops and IR notify defines ↵Andy Walls
for v4l2_device Add v4l2_subdev_ir_ops and IR notify defines for v4l2_device. This change is specifically needed at this time to support the integrated IR controller in the CX2388[58] chips. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13092): cx25840: Improvements to the cx23885/7/8 chip detection ↵Steven Toth
mechanism. The prior mechanism wasn't reliable with the cx23887. This new mechanism tests correctly against cx23885, 7 and 8 based products. Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13091): cx23885: Enable HVR-1850 CX23888 A/V core to get VID_CLK ↵Andy Walls
running for IR For the IR controller on the CX23888 to work for the HVR-1850 and in general, the A/V core must be initialized to get the VID_CLK going. The VID_CLK is the timing reference for the CX23888's integrated IR controller. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13090): cx25840: Init PLLs properly for CX2388[578] A/V coresAndy Walls
The SYS and AUX PLLs need to be initialized to different values based on the chip: CX23885, CX23887, CX23888, as each uses a different crystal frequency: 28.6363 MHz, 25.0 MHz, 50.0 MHz. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13089): cx25840: Separate set_audclk_freq functionality for the ↵Andy Walls
different chips Separate out the set_audclk_freq() function into separate functions for the four families of cores. These cores all use slightly different sample clock schemes and may be assuming slightly (+/- 3 Hz) different reference frequencies. The code resuse was not worth the maintenance and testing headache of have all chips use the same function peppered with conditional logic. Added comments on how PLL and SRC parameters values are computed. Fixed a few bugs related to the shared code having a large number of conditional statements. Noted inconsistencies with FIXME in the comments. This is done in preparation for getting the CX2388[578] PLL/clock setting logic cleaned up for CX23888 analog video and IR (which need the VID PLL set right). Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13088): cx25840: Convert chip/core family checks to static inline ↵Andy Walls
functions Change logic to check for various chip or core families to inline functions. Checks for specific chips should be made against the state->id field now. This is in preparation for chip/core specific code for setting up PLLs for the CX2388[578] family of cores, that all run with different crystal frequencies. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13087): cx25840: Improve detection of CX2388[578] A/V coresAndy Walls
Add improved logic to detect the exact CX2388[578] A/V core that is being probed. Also cleaned up detection and logging for CX2310[12], CX2583[67], and CX2584[0123] cores and chips. Also added code to identify a CX2388[578] A/V decoder core that is not responding properly. Typical symptoms include registers 0x00-0xff responding properly but all other registers returning the same value (0x13 and 0x5 have been observed). This state will cause proper detection of '885 vs. '887 vs. '888 to fail and the chip won't respond to get configured properly anyway. I have no method of reseting the core to a working state at this time; but I didn't try too hard to work one out either. The problem likely only occurs in development. I suspect configuring the SYS PLL VCO to oscillate too slowly (286.3 MHz?) before post divide may be the root cause, when encountered. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13086): cx23885: Add skeleton v4l2_subdev for the CX23888 ↵Andy Walls
integrated IR controller This change adds a skeletal implementation of a v4l2_subdevice to provide encapsulation and abstraction of the CX23888's integrated consumer infrared controller. This change also instantiates the cx23888_ir subdev for the HVR-1850 which has IR hardware physically wired up to a CX23888. The cx23888_ir subdev code is being written with long-term objectives to: 1. port it to the cx25840 module for the CX2584x, CX2583x, CX23885, & CX231xx IR controllers 2. possibly port it to the cx18 module for the CX23418 IR controller 3. have the IR subdevice accessed abstractly in the cx23885 module, so the driver can ignore the difference between the CX23885 and CX23888. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13085): cx23885: Fix support for v4l2-dbg access to CX2388[578] and ↵Andy Walls
CX23417 regs This changes corrects the ioctl() operations for both the CX2388[578] analog video and MPEG video device nodes to properly and consistently support VIDIOC_G_CHIP_IDENT, VIDIOC_DBG_G_REGISTER and VIDIOC_DBG_S_REGISTER ioctl()s. This caused some ioctl() support routines to be broken out into a separate source file. Now v4l2-dbg can be used to manipulate CX2388[578] and CX23417 registers including the CX2388[57] functions handled by the cx25840 module. This was done in anticipation of developing a new v4l2_subdev for the integrated IR controller of the CX23888. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13084): v4l2-chip-ident: Add ID's needed for the cx23885 and ↵Andy Walls
cx25840 modules Add identifiers for CX2388[578] chips, CX2310[012] chips, integrated A/V decoders cores, integrated IR controller core, and the CX23417 MPEG encoder. The cx23885 module and cx25840 module will use these identifiers in upcoming changes. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13082): em28xx: remove "not validated" status from Terratec Cinergy ↵Devin Heitmueller
T XS (005e) The board support has been validated by the user, so get rid of the warning that shows up on board load. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13081): saa7134: use the #define for the xc5000 radio_input fieldDevin Heitmueller
Dmitri's patch for the Behold X7 didn't use the #define I had setup for XC5000_RADIO_FM1, so cut over to using that instead of "1". Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13080): saa7134: add support for the digital side of the Behold X7Beholder Intl. Ltd. Dmitry Belimov
Add support for the digital side of the Behold X7 Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13078): em28xx: fix support for Terratec Cinergy T XS (005e)Uroš Vampl
Make analog audio, dvb and the remote work on a Terratec Cinergy Hybrid XS (em2882). Note by djh: Thanks go out fo Andrej Suligoi for his contribution in providing and testing pretty much the exact same patch as provided by Uros. Between the two of them, they got all the core functionality working for the device. Cc: Andrej Suligoi <suligoi@gmail.com> Signed-off-by: Uroš Vampl <mobile.leecher@gmail.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13077): em28xx: Add support for new variant of KWorld 2800dDevin Heitmueller
Seems that the reference design used for the KWorld 2800d switched from the em2860 to em2862, so we need to add the new USB id (and the i2c hash remains so all we need is the default em2862 id. Thanks to Ian Young for reporting the issue and testing the fix. Cc: Ian Young <ian@duffrecords.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13076): xc5000: make the definition of the FM input part of the ↵Devin Heitmueller
xc5000 config struct Remove hard-coded definition of the xc5000 FM radio input, making it a parameter passed in when doing the attach call. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13075): xc5000: add FM radio supportBeholder Intl. Ltd. Dmitry Belimov
Add FM radio for the xc5000 silicon tuner chip. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13073): radio-mr800: set radio frequency only upon successDavid Ellingsworth
Set radio frequency only upon success. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13072): radio-mr800: simplify device warningsDavid Ellingsworth
Simplify device warnings. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13071): radio-mr800: preserve radio state during suspend/resumeDavid Ellingsworth
Preserve radio state during suspend/resume. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13070): radio-mr800: fix behavior of set_stereo functionDavid Ellingsworth
Fix behavior of set_stereo function. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13069): radio-mr800: ensure the radio is initialized to a ↵David Ellingsworth
consistent state Ensure the radio is initialized to a consistent state. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13068): radio-mr800: remove device initialization from open/closeDavid Ellingsworth
Remove device initialization from open/close. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13067): radio-mr800: fix potential use after freeDavid Ellingsworth
Fix portential use after free. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13066): radio-mr800: remove device removed indicatorDavid Ellingsworth
Remove device removed indicator Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13065): radio-mr800: simplify locking in ioctl callbacksDavid Ellingsworth
Simplify locking in ioctl callbacks. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13064): radio-mr800: simplify access to amradio_deviceDavid Ellingsworth
Simplify access to amradio_device. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13063): radio-mr800: remove unnecessary local variableDavid Ellingsworth
Remove unnecessary local variable. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13062): radio-mr800: simplify error paths in usb probe callbackDavid Ellingsworth
Simplify error paths in usb probe callback. Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13061): radio-mr800: simplify video_device allocationDavid Ellingsworth
simplify video_device allocation Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13060): radio-mr800: implement proper lockingDavid Ellingsworth
Implement proper locking Signed-off-by: David Ellingsworth <david@identd.dyndns.org> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13058): af9015: enable remote polling when eeprom contains 0x04Antti Palosaari
Looks like eeprom IR mode byte value 0x04 means there is remote which should be polled. Patch enables polling also in case of 0x04. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13057): af9015: add MSI DIGIVOX mini III remoteAntti Palosaari
Support for MSI DIGIVOX mini III remote. Thanks to Aleksandr V. Piskunov <aleksandr.v.piskunov@gmail.com> Thanks to Roman <lists@hasnoname.de> Cc: Aleksandr V. Piskunov <aleksandr.v.piskunov@gmail.com> Cc: Roman <lists@hasnoname.de> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13056): af9015: add LeadTek Y04G0051 remote buttonsAntti Palosaari
Add missing LeadTek Y04G0051 remote buttons. Thanks to Matthew Skinner <matt@pcmus.com> Cc: Matthew Skinner <matt@pcmus.com> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13055): af9015: fix few typosAntti Palosaari
2009-12-05V4L/DVB (13054): af9015: add USB ID for KWorld PlusTV DVB-T PCI Pro Card ↵Antti Palosaari
(DVB-T PC160-T) Add USB ID 1b80:c161 for KWorld PlusTV DVB-T PCI Pro Card (DVB-T PC160-T). Thanks to Andrew Cruickshank <atcrank@gmail.com> for reporting this. Cc: Andrew Cruickshank <atcrank@gmail.com> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13052): DiB0700: EvolutePC TvWay+ USB ISDB-Tb fullseg device supportS?rgio Fortier
Patch for EvolutePC TvWay+ USB ISDB-Tb fullseg device support. Signed-off-by: S?rgio C Fortier <sergiofortier@yahoo.com.br> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13051): DiB7000P: improve rebostness of HAS_LOCK indicatorOlivier Grenie
Update the dib7000p: The status is HAS_LOCK only if the demod is able to decode the TPS. Sometimes, there is a TPS data lock, even if the demod is not able to decode it (ex: no RF signal). For the STK7770P: correct value for the charge pump Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13049): dib8000: SNR in 10th of dBOlivier Grenie
dib7000p/dib8000: added pid filtering dib8000: the SNR is in 10th of dB (not in dB) dib7000p and dib8000: added the pid filtering. This feature is enabled by module option (dvb-usb module). Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13045): Fix debug messaging for stv0900 demod.Igor M. Liplianin
Signed-off-by: Igor M. Liplianin <liplianin@netup.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13044): dib0700: Be less verbose when an IR key is pressedMauro Carvalho Chehab
2009-12-05V4L/DVB (13043): Add support for Pixelview SBTVD IRMauro Carvalho Chehab
This IR uses NEC protocol. In order to use, dvb_usb_dib0700_ir_proto=0 should be used. Cc: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13042): Add NEC protocol to firmware v1.2 handlerMauro Carvalho Chehab
Currently, dvb_usb_dib0700_ir_proto is supported only with firmwares older than 1.2. Adds support for it also with the newer firmware. This is needed in order to support PixelView SBTVD IR. Cc: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13040): V4L2: Add a v4l2-subdev (soc-camera) driver for OmniVision ↵Marek Vasut
OV9640 sensor Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits) tracing: Separate raw syscall from syscall tracer ring-buffer-benchmark: Add parameters to set produce/consumer priorities tracing, function tracer: Clean up strstrip() usage ring-buffer benchmark: Run producer/consumer threads at nice +19 tracing: Remove the stale include/trace/power.h tracing: Only print objcopy version warning once from recordmcount tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used ring-buffer: Move access to commit_page up into function used tracing: do not disable interrupts for trace_clock_local ring-buffer: Add multiple iterations between benchmark timestamps kprobes: Sanitize struct kretprobe_instance allocations tracing: Fix to use __always_unused attribute compiler: Introduce __always_unused tracing: Exit with error if a weak function is used in recordmcount.pl tracing: Move conditional into update_funcs() in recordmcount.pl tracing: Add regex for weak functions in recordmcount.pl tracing: Move mcount section search to front of loop in recordmcount.pl tracing: Fix objcopy revision check in recordmcount.pl tracing: Check absolute path of input file in recordmcount.pl tracing: Correct the check for number of arguments in recordmcount.pl ...
2009-12-05Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix trace_marker output tracing: Fix event format export tracing: Fix return value of tracing_stats_read()
2009-12-05Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix spurious irq seqfile conversion genirq: switch /proc/irq/*/spurious to seq_file irq: Do not attempt to create subdirectories if /proc/irq/<irq> failed irq: Remove unused debug_poll_all_shared_irqs() irq: Fix docbook comments irq: trivial: Fix typo in comment for #endif
