Add resources for the AX88796 on the Simtec BAST.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Add support for the partition layour used on the
revision B modules which ship with large page NAND
flash as default.
The differnce between the old and new layouts is that
the large page devices use 128KiB blocks, so the
initial loader partition now ends at 128KiB boundary
pushing the begining of partition 1 up. The rest of
the partitions are in the same place as the small page
NAND devices.
Add resources for the SM501 present on the
Simtec Anubis board, including the framebuffer
and the I2C for DDC.
This patch adds the resources necessary for the
AX88796 driver to attach to the AX88796 network
controller fitted on the Simtec Anubis board.
Woo-hoo. I'm sure somebody will report a "this doesn't compile, and
I have a new root exploit" five minutes after release, but it still
feels good ;)
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
qd65xx: fix PIO mode selection
sis5513: adding PCI-ID
Commit 1c710c896eb461895d3c399e15bb5f20b39c9073 added the utimensat()
system call, but didn't handle the case of checking for the writability
of the target right, when the target was a file descriptor, not a
filename.
We cannot use vfs_permission(MAY_WRITE) for that case, and need to
simply check whether the file descriptor is writable. The oops from
using the wrong function was noticed and narrowed down by Markus
Trippelsdorf.
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Acked-by: Al Viro <viro@ftp.linux.org.uk>
Fix a post-2.6.21 regression.
read_cache_page_async() has two invocations of mark_page_accessed() which will
launch pages right onto the active list.
Remove the first one, keeping the latter one. This avoids marking unwanted
pages active (in the retry loop).
Acked-by: Nick Piggin <nickpiggin@yahoo.com.au>
PIO4 is a maximum PIO mode supported by a driver. Using "255" as a max_mode
argument to ide_get_best_pio_mode() could result in wrong timings being used
by a driver (for "pio" equal to 5) or OOPS (for "pio" values > 5 && < 255).
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Reviewed-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
The SiS966 has one additional PCI-ID 1180.
If the chipset is using this PCI-ID, the primary channel is connected to the
first PATA-port. The secondary channel is connected to SATA-ports in IDE
emulation mode. The legacy IO-ports are used.
The including of the PCI-ID into pata_sis is not sufficient, because the legacy
driver in drivers/ide is initialized before pata_sis.
Signed-off-by: Uwe Koziolek <uwe.koziolek@gmx.net>
The dependency of DLM on SYSFS got lost in
commit 6ed7257b46709e87d79ac2b6b819b7e0c9184998 resulting in the
following compile error with CONFIG_DLM=y, CONFIG_SYSFS=n:
<-- snip -->
LD .tmp_vmlinux1
fs/built-in.o: In function `dlm_lockspace_init':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/fs/dlm/lockspace.c:231: undefined reference to `kernel_subsys'
fs/built-in.o: In function `configfs_init':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/fs/configfs/mount.c:143: undefined reference to `kernel_subsys'
make[1]: *** [.tmp_vmlinux1] Error 1
<-- snip -->
The printk level in this printk is bogus, as the previous printk
didn't have a terminating \n resulting in ..
Intel E7520/7320/7525 detected.<6>Disabling irq balancing and affinity
It also never printed a \n at all in the case where we didn't do
the quirk.
Change it to only make noise if it actually does something useful.
Signed-off-by: Dave Jones <davej@redhat.com>
This patch fixes the following 2.6.22 regression with CONFIG_KALLSYMS=n:
<-- snip -->
CC arch/m32r/kernel/traps.o
In file included from /home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/arch/m32r/kernel/traps.c:14:
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h: In function 'lookup_symbol_name':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:66: error: 'ERANGE' undeclared (first use in this function)
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:66: error: (Each undeclared identifier is reported only once
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:66: error: for each function it appears in.)
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h: In function 'lookup_symbol_attrs':
/home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/kallsyms.h:71: error: 'ERANGE' undeclared (first use in this function)
make[2]: *** [arch/m32r/kernel/traps.o] Error 1
<-- snip -->
When cleaning up HIDP sessions, we currently close the ACL connection
before deregistering the input device. Closing the ACL connection
schedules a workqueue to remove the associated objects from sysfs, but
the input device still refers to them -- and if the workqueue happens to
run before the input device removal, the kernel will oops when trying to
look up PHYSDEVPATH for the removed input device.
Fix this by deregistering the input device before closing the
connections.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
kmem_cache_open is static. EXPORT_SYMBOL was leftover from some earlier
time period where kmem_cache_open was usable outside of slub.
(Fixes powerpc build error)
Signed-off-by: Chrsitoph Lameter <clameter@sgi.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
davem kindly moved the list from osdl to vger.
Signed-of-by: maximilian attems <max@stro.at>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Writing to MSR 0x51400017 forces a hard reset on CS5536-based machines,
this has the reboot fixup do just that if such a board is detected.
Acked-by: Jordan Crouse <jordan.crouse@amd.com>
Signed-off-by: Andres Salomon <dilinger@debian.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Andi Kleen <ak@suse.de>
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[NETPOLL]: Fixups for 'fix soft lockup when removing module'
[NET]: net/core/netevent.c should #include <net/netevent.h>
[NETFILTER]: nf_conntrack_h323: add checking of out-of-range on choices' index values
[NET] skbuff: remove export of static symbol
SCTP: Add scope_id validation for link-local binds
SCTP: Check to make sure file is valid before setting timeout
SCTP: Fix thinko in sctp_copy_laddrs()
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fix scheduling latency issue on 24K, 34K and 74K cores
[MIPS] Add macros to encode processor revisions.
[MIPS] RM7000: Enable ICACHE_REFILLS_WORKAROUND_WAR.
[MIPS] SMTC: Fix cut'n'paste bug in Kconfig.debug
[MIPS] Change libgcc-style functions from lib-y to obj-y
[MIPS] Fix timer/performance interrupt detection
[MIPS] AP/SP: Avoid triggering the 34K E125 performance issue
[MIPS] 64-bit TO_PHYS_MASK macro for RM9000 processors
Line up the vmstat_text with zone_stat_item
enum zone_stat_item {
/* First 128 byte cacheline (assuming 64 bit words) */
NR_FREE_PAGES,
NR_INACTIVE,
NR_ACTIVE,
We current have nr_active and nr_inactive reversed.
[ "OK with patch, though using initializers canbe handy to prevent such
things in future:
static const char * const vmstat_text[] = {
[NR_FREE_PAGES] = "nr_free_pages",
- Alexey ]
Acked-by: Alexey Dobriyan <adobriyan@gmail.com>
In 7d12e780e003f93433d49ce78cfedf4b4c52adc5 David Howells performed
this evolution:
"IRQ: Maintain regs pointer globally rather than passing to IRQ handlers"
He correctly updated many of the function definitions that were using this
extra regs pointer parameter but forgot to update some caller sites of
those functions. The reason the modifications was not properly done on all
drivers is that some drivers were rarely compiled because they are for
AMIGA, or that some code sites were inside #ifdefs where the option is not
set or inside #if 0.
Here is the semantic patch that found the occurences
and fixed the problem.
@ rule1 @
identifier fn;
identifier irq, dev_id;
typedef irqreturn_t;
static irqreturn_t fn(int irq, void *dev_id)
identifier rule1.fn;
expression E1, E2, E3;
fn(E1, E2
- ,E3
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Greg KH <greg@kroah.com>
o Commit 1833d6bc72893265f22addd79cf52e6987496e0f broke the build if
compiled with CONFIG_ES7000=y and CONFIG_X86_GENERICARCH=n
arch/i386/kernel/built-in.o(.init.text+0x4fa9): In function `acpi_parse_madt':
: undefined reference to `acpi_madt_oem_check'
arch/i386/kernel/built-in.o(.init.text+0x7406): In function `smp_read_mpc':
: undefined reference to `mps_oem_check'
arch/i386/kernel/built-in.o(.init.text+0x8990): In function
`connect_bsp_APIC':
: undefined reference to `enable_apic_mode'
make: *** [.tmp_vmlinux1] Error 1
o Fix the build issue. Provided the definitions of missing functions.
o Don't have ES7000 machine. Only compile tested.
Cc: Len Brown <lenb@kernel.org>
Cc: Natalie Protasevich <protasnb@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
When we enable the SMCf010 IR device, the Toshiba Portege 4000 BIOS claims
the device is working, but it really isn't configured correctly. The BIOS
*will* configure it, but only if we call _SRS after (1) reversing the order
of the SIR and FIR I/O port regions and (2) changing the IRQ from
active-high to active-low.
This patch addresses the 2.6.22 regression:
"no irda0 interface (2.6.21 was OK), smsc does not find chip"
I tested this on a Portege 4000. The smsc-ircc2 driver correctly detects
the device, and "irattach irda0 -s && irdadump" shows transmitted and
received packets.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Andrey Borzenkov <arvidjaar@mail.ru>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com>
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Cc: Adam Belay <ambx1@neo.rr.com>
When calling a semctl(IPC_STAT) without IPC_64 the check if the memory is
unevaluated. This patch fixes this.
A bug in headers_install for ARCH=x86_64 yields an asm/ directory full of
files all of which are using the same #ifdef guard, "__ASM_STUB_" with no
postfix. So the second and later asm files #included in the same C file
(often through standard headers like ioctl.h) yields no symbols.
Strangeness with the Ubuntu 'tell me if I support something that's not
explcitly mentioned in POSIX, and I'll strip it out' shell, I believe.
We don't need the 'export' but we do need a semicolon at the end of the
FNAME line:
Signed-off-by: Rob Landley <rob@landley.net>
Processors synchronization in set_mtrr requires the .gate field to be set
after .count field is properly initialized. Without an explicit barrier,
the compiler was reordering those memory stores. That was sometimes
causing a processor (in ipi_handler) to see the .gate change and decrement
.count before the latter is set by set_mtrr() (which then hangs in a
infinite loop with irqs disabled).
Signed-off-by: Loic Prylli <loic@myri.com>
The commit 635cf99a80f4ebee59d70eb64bb85ce829e4591f introduced a
regression. Executing a ptrace single step after certain int80
accesses will infinitely loop and never advance the PC.
The TIF_SINGLESTEP check should be done on the return from the syscall
and not before it.
I loops on each single step on the pop right after the int80 which writes out
to the console. At that point you can issue as many single steps as you want
and it will not advance any further.
The test case is below:
/* Test whether singlestep through an int80 syscall works.
#define _GNU_SOURCE
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/ptrace.h>
#include <sys/wait.h>
#include <sys/mman.h>
#include <asm/user.h>
#include <string.h>
static int child, status;
static struct user_regs_struct regs;
static void do_child()
char str[80] = "child: int80 test\n";
ptrace(PTRACE_TRACEME, 0, 0, 0);
kill(getpid(), SIGUSR1);
write(fileno(stdout),str,strlen(str));
asm ("int $0x80" : : "a" (20)); /* getpid */
static void do_parent()
unsigned long eip, expected = 0;
again:
waitpid(child, &status, 0);
if (WIFEXITED(status) || WIFSIGNALED(status))
return;
if (WIFSTOPPED(status)) {
ptrace(PTRACE_GETREGS, child, 0, ®s);
eip = regs.eip;
if (expected)
fprintf(stderr, "child stop @ %08lx, expected %08lx %s\n",
eip, expected,
eip == expected ? "" : " <== ERROR");
if (*(unsigned short *)eip == 0x80cd) {
fprintf(stderr, "int 0x80 at %08x\n", (unsigned int)eip);
expected = eip + 2;
} else
expected = 0;
ptrace(PTRACE_SINGLESTEP, child, NULL, NULL);
goto again;
int main(int argc, char * const argv[])
child = fork();
if (child)
do_parent();
else
do_child();
return 0;
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Cc: <stable@kernel.org>
Cc: Chuck Ebbert <76306.1226@compuserve.com>
Acked-by: Andi Kleen <ak@suse.de>
elf_core_dump() supports dumping arch specific ELF notes, via the #define
ELF_CORE_WRITE_EXTRA_NOTES. Currently the only user of this is the powerpc
spu coredump code.
There is a bug in the handling of foffset WRT the arch notes, which causes
us to erroneously increment foffset by the size of the arch notes, leaving
a block of zeroes in the file, and causing all subsequent data in the file
to be at <supposed position> + <arch note size>. eg:
LOAD 0x050000 0x00100000 0x00000000 0x20000 0x20000 R E 0x10000
Tells us we should have a chunk of data at 0x50000. The truth is the data
is at 0x90dbc = 0x50000 + 0x40dbc (the size of the arch notes).
This bug prevents gdb from reading the core file correctly.
The simplest fix is to simply remember the size of the arch notes, and add
it to foffset after we've written the arch notes. The only drawback is
that if the arch code doesn't write as many bytes as it said it would, we
end up with a broken core dump again. For now I think that's a reasonable
requirement.
Tested on a Cell blade, gdb no longer complains about the core file being
bogus.
While I'm here I should point out that the spu coredump code does not work
if we're dumping to a pipe - we'll have to wait for 23 to fix that.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Paul Mackerras <paulus@samba.org>
The idle loop goes to sleep using the WAIT instruction if !need_resched().
This has is suffering from from a race condition that if if just after
need_resched has returned 0 an interrupt might set TIF_NEED_RESCHED but
we've just completed the test so go to sleep anyway. This would be
trivial to fix by just disabling interrupts during that sequence as in:
local_irq_disable();
if (!need_resched())
__asm__("wait");
local_irq_enable();
but the processor architecture leaves it undefined if a processor calling
WAIT with interrupts disabled will ever restart its pipeline and indeed
some processors have made use of the freedom provided by the architecture
definition. This has been resolved and the Config7.WII bit indicates that
the use of WAIT is safe on 24K, 24KE and 34K cores. It also is safe on
74K starting revision 2.1.0 so enable the use of WAIT with interrupts
disabled for 74K based on a c0_prid of at least that.
Older processors used to encode processor version and revision in two
4-bit bitfields, the 4K seems to simply count up and even newer MTI cores
have switched to use the 8-bits as 3:3:2 bitfield with the last field as
the patch number.
The RM7000 processors and the E9000 cores have a bug (though PMC-Sierra
opposes it being called that) where invalid instructions in the same
I-cache line worth of instructions being fetched may case spurious
exceptions.
The workaround for this was only enabled for E9000 cores; enable it also
for all RM7000-based platforms.
This effectivly turned the SMTC_IDLE_HOOK_DEBUG debug option into a no-op.
Reported by Eugene Surovegin <ebs@ebshome.net>.
If only modules were users of these functions they did not get linked into
the kernel proper, so later module loads would fail as well.
Signed-off-by: Chris Dearman <chris@mips.com>
C0_status doesn't need to be initialized at this point anyway; the register
will be initialized later.
Signed-off-by: Andrew Sharp <tigerand@gmail.com>
>From my recent patch:
> > #1
> > Until kernel ver. 2.6.21 (including) cancel_rearming_delayed_work()
> > required a work function should always (unconditionally) rearm with
> > delay > 0 - otherwise it would endlessly loop. This patch replaces
> > this function with cancel_delayed_work(). Later kernel versions don't
> > require this, so here it's only for uniformity.
But Oleg Nesterov <oleg@tv-sign.ru> found:
> But 2.6.22 doesn't need this change, why it was merged?
> In fact, I suspect this change adds a race,
His description was right (thanks), so this patch reverts #1.
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl>
Every file should include the headers containing the prototypes for
its global functions.
index values
Choices' index values may be out of range while still encoded in the fixed
length bit-field. This bug may cause access to undefined types (NULL
pointers) and thus crashes (Reported by Zhongling Wen).
This patch also adds checking of decode flag when decoding SEQUENCEs.
Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com>
skb_clone_fraglist is static so it shouldn't be exported.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
SCTP currently permits users to bind to link-local addresses,
but doesn't verify that the scope id specified at bind matches
the interface that the address is configured on. It was report
that this can hang a system.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
In-kernel sockets created with sock_create_kern don't usually
have a file and file descriptor allocated to them. As a result,
when SCTP tries to check the non-blocking flag, we Oops when
dereferencing a NULL file pointer.
Correctly dereference bytes_copied in sctp_copy_laddrs().
I totally must have spaced when doing this.
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] always allow dump_stack() to produce a backtrace
[ARM] Fix non-page aligned boot time mappings
[ARM] 4458/1: pxa: Fix CKEN usage and hence fix pxa suspend/resume
[ARM] 4454/1: Use word accesses in Versatile PCI config reads
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: document some of keycodes
Input: add a new EV_SW SW_RADIO event, for radio switches on laptops
Input: serio - take drv_mutex in serio_cleanup()
Input: atkbd - use printk_ratelimit for spurious ACK messages
Input: atkbd - throttle LED switching
Input: i8042 - add HP Pavilion ZT1000 to the MUX blacklist
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Update defconfigs
[POWERPC] Uninline and export virq_to_hw() for the pasemi_mac driver
[POWERPC] Fix PMI breakage in cbe_cbufreq driver
[POWERPC] Disable old EMAC driver in arch/powerpc
Commit b46b8f19c9cd435ecac4d9d12b39d78c137ecd66 fixed a couple of bugs
by switching the redzone to 64 bits. Unfortunately, it neglected to
ensure that the _second_ redzone, after the slab object, is aligned
correctly. This caused illegal instruction faults on sparc32, which for
some reason not entirely clear to me are not trapped and fixed up.
Two things need to be done to fix this:
- increase the object size, rounding up to alignof(long long) so
that the second redzone can be aligned correctly.
- If SLAB_STORE_USER is set but alignof(long long)==8, allow a
full 64 bits of space for the user word at the end of the buffer,
even though we may not _use_ the whole 64 bits.
This patch should be a no-op on any 64-bit architecture or any 32-bit
architecture where alignof(long long) == 4. Of the others, it's tested
on ppc32 by myself and a very similar patch was tested on sparc32 by
Mark Fortescue, who reported the new problem.
Also, fix the conditions for FORCED_DEBUG, which hadn't been adjusted to
the new sizes. Again noticed by Mark.
Don't make this dependent on CONFIG_DEBUG_KERNEL - if we hit a WARN_ON
we need the stack trace to work out how we got to that point.
Yeah, we could have just disabled it, but there's work on a new one that
isn't as fundamentally broken, so there really doesn't seem to be any
point in keeping it around.
The recent timer cleanup broke the only valid use, and when I say
"valid", I obviously mean "totally broken". So it's not like it works,
or really even can work in the current format that uses the unsafe
"panic" LED blinking routines..
AT91SAM9260 stopped booting with the recent changes to MM
initialisation - it was asking for a non-aligned virtual address
which caused loops to be non-terminal. Fix this by rounding
virtual addresses down, but remember to include the offset in
the length, and round the length up to the following page.
This means that asking for a mapping of 4K starting at 2K into
a page maps two pages as one would expect.
