git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg KH:
"Here's the big USB pull request for 3.15-rc1.
The normal set of patches, lots of controller driver updates, and a
smattering of individual USB driver updates as well.
All have been in linux-next for a while"
* tag 'usb-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (249 commits)
xhci: Transition maintainership to Mathias Nyman.
USB: disable reset-resume when USB_QUIRK_RESET is set
USB: unbind all interfaces before rebinding any
usb: phy: Add ulpi IDs for SMSC USB3320 and TI TUSB1210
usb: gadget: tcm_usb_gadget: stop format strings
usb: gadget: f_fs: add missing spinlock and mutex unlock
usb: gadget: composite: switch over to ERR_CAST()
usb: gadget: inode: switch over to memdup_user()
usb: gadget: f_subset: switch over to PTR_RET
usb: gadget: lpc32xx_udc: fix wrong clk_put() sequence
USB: keyspan: remove dead debugging code
USB: serial: add missing newlines to dev_<level> messages.
USB: serial: add missing braces
USB: serial: continue to write on errors
USB: serial: continue to read on errors
USB: serial: make bulk_out_size a lower limit
USB: cypress_m8: fix potential scheduling while atomic
devicetree: bindings: document lsi,zevio-usb
usb: chipidea: add support for USB OTG controller on LSI Zevio SoCs
usb: chipidea: imx: Use dev_name() for ci_hdrc name to distinguish USBs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver update from Greg KH:
"Here's the big tty/serial driver update for 3.15-rc1.
Nothing major, a number of serial driver updates and a few tty core
fixes as well.
* tag 'tty-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (71 commits)
tty/serial: omap: empty the RX FIFO at the end of half-duplex TX
tty/serial: omap: fix RX interrupt enable/disable in half-duplex TX
serial: sh-sci: Neaten dev_<level> uses
serial: sh-sci: Replace hardcoded 3 by UART_PM_STATE_OFF
serial: sh-sci: Add more register documentation
serial: sh-sci: Remove useless casts
serial: sh-sci: Replace printk() by pr_*()
serial_core: Avoid NULL pointer dereference in uart_close()
serial_core: Get a reference for port->tty in uart_remove_one_port()
serial: clps711x: Give a chance to perform useful tasks during wait loop
serial_core: Grammar s/ports/port's/
serial_core: Spelling s/contro/control/
serial: efm32: properly namespace location property
serial: max310x: Add missing #include <linux/uaccess.h>
synclink: fix info leak in ioctl
serial: 8250: Clean up the locking for -rt
serial: 8250_pci: change BayTrail default uartclk
serial: 8250_pci: more BayTrail error-free bauds
serial: sh-sci: Add missing call to uart_remove_one_port() in failure path
serial_core: Unregister console in uart_remove_one_port()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the huge drivers/staging/ update for 3.15-rc1.
Loads of cleanup fixes, a few drivers removed, and some new ones
added.
* tag 'staging-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1375 commits)
staging: xillybus: XILLYBUS_PCIE depends on PCI_MSI
staging: xillybus: Added "select CRC32" for XILLYBUS in Kconfig
staging: comedi: poc: remove obsolete driver
staging: unisys: replace kzalloc/kfree with UISMALLOC/UISFREE
staging: octeon-usb: prevent memory corruption
staging: usbip: fix line over 80 characters
staging: usbip: fix quoted string split across lines
Staging: unisys: Remove RETINT macro
Staging: unisys: Remove FAIL macro
Staging: unisys: Remove RETVOID macro
Staging: unisys: Remove RETPTR macro
Staging: unisys: Remove RETBOOL macro
Staging: unisys: Remove FAIL_WPOSTCODE_1 macro
Staging: unisys: Cleanup macros to get rid of goto statements
Staging: unisys: include: Remove unused macros from timskmod.h
staging: dgap: fix the rest of the checkpatch warnings in dgap.c
Staging: bcm: Remove unnecessary parentheses
staging: wlags49_h2: Delete unnecessary braces
staging: wlags49_h2: Do not use assignment in if condition
staging: wlags49_h2: Enclose macro in a do-while loop
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core and sysfs updates from Greg KH:
"Here's the big driver core / sysfs update for 3.15-rc1.
Lots of kernfs updates to make it useful for other subsystems, and a
few other tiny driver core patches.
* tag 'driver-core-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (42 commits)
Revert "sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()"
kernfs: cache atomic_write_len in kernfs_open_file
numa: fix NULL pointer access and memory leak in unregister_one_node()
Revert "driver core: synchronize device shutdown"
kernfs: fix off by one error.
kernfs: remove duplicate dir.c at the top dir
x86: align x86 arch with generic CPU modalias handling
cpu: add generic support for CPU feature based module autoloading
sysfs: create bin_attributes under the requested group
driver core: unexport static function create_syslog_header
firmware: use power efficient workqueue for unloading and aborting fw load
firmware: give a protection when map page failed
firmware: google memconsole driver fixes
firmware: fix google/gsmi duplicate efivars_sysfs_init()
drivers/base: delete non-required instances of include <linux/init.h>
kernfs: fix kernfs_node_from_dentry()
ACPI / platform: drop redundant ACPI_HANDLE check
kernfs: fix hash calculation in kernfs_rename_ns()
kernfs: add CONFIG_KERNFS
sysfs, kobject: add sysfs wrapper for kernfs_enable_ns()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg KH:
"Here's the big char/misc driver updates for 3.15-rc1.
Lots of various things here, including the new mcb driver subsystem.
All of these have been in linux-next for a while"
* tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits)
extcon: Move OF helper function to extcon core and change function name
extcon: of: Remove unnecessary function call by using the name of device_node
extcon: gpio: Use SIMPLE_DEV_PM_OPS macro
extcon: palmas: Use SIMPLE_DEV_PM_OPS macro
mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro
mei: amthif: fix checkpatch error
mei: client.h fix checkpatch errors
mei: use cl_dbg where appropriate
mei: fix Unnecessary space after function pointer name
mei: report consistently copy_from/to_user failures
mei: drop pr_fmt macros
mei: make me hw headers private to me hw.
mei: fix memory leak of pending write cb objects
mei: me: do not reset when less than expected data is received
drivers: mcb: Fix build error discovered by 0-day bot
cs5535-mfgpt: Simplify dependencies
spmi: pm: drop bus-level PM suspend/resume routines
spmi: pmic_arb: make selectable on ARCH_QCOM
Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle
pch_phub: Report error writing MAC back to user
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"There have been lots of changes in ALSA core, HD-audio and ASoC, also
most of PCI drivers touched by conversions of printks. All these
resulted in a high volume and wide ranged patch sets in this release.
Many changes are fairly trivial, but also lots of nice cleanups and
refactors. There are a few new drivers, most notably, the Intel
Haswell and Baytrail ASoC driver.
Core changes:
- A bit modernization; embed the device struct into snd_card struct,
so that it may be referred from the beginning. A new
snd_card_new() function is introduced for that, and all drivers
have been converted.
- Simplification in the device management code in ALSA core; now
managed by a simple priority list instead
- Converted many kernel messages to use the standard dev_err() & co;
this would be the pretty visible difference, especially for
HD-audio.
HD-audio:
- Conexant codecs use the auto-parser as default now; the old static
code still remains in case of regressions. Some old quirks have
been rewritten with the fixups for auto-parser.
- C-Media codecs also use the auto-parser as default now, too.
- A device struct is assigned to each HD-audio codec, and the
formerly hwdep attributes are accessible over the codec sysfs, too.
hwdep attributes still remain for compatibility.
- Split the PCI-specific stuff for HD-audio controller into a
separate module, ane make a helper module for the generic
controller driver. This is a preliminary change for supporting
Tegra HDMI controller in near future, which slipped from 3.15
merge.
- Device-specific fixes: mute LED support for Lenovo Ideapad, mic LED
fix for HP laptops, more ASUS subwoofer quirks, yet more Dell
laptop headset quirks
- Make the HD-audio codec response a bit more robust
- A few improvements on Realtek ALC282 / 283 about the pop noises
- A couple of Intel HDMI fixes
ASoC:
- Lots of cleanups for enumerations; refactored lots of error prone
original codes to use more modern APIs
- Elimination of the ASoC level wrappers for I2C and SPI moving us
closer to converting to regmap completely and avoiding some
randconfig hassle
- Provide both manually and transparently locked DAPM APIs rather
than a mix of the two fixing some concurrency issues
- Start converting CODEC drivers to use separate bus interface
drivers rather than having them all in one file helping avoid
dependency issues
- DPCM support for Intel Haswell and Bay Trail platforms, lots of
fixes
- Lots of work on improvements for simple-card, DaVinci and the
Renesas rcar drivers.
- New drivers for Analog Devices ADAU1977, TI PCM512x and parts of
the CSR SiRF SoC, TLV320AIC31XXX, Armada 370 DB, Cirrus cs42xx8
- Fixes for the simple-card DAI format DT mess
- DT support for a couple more devices.
- Use of the tdm_slot mapping in a few drivers
Others:
- Support of reset_resume callback for improved S4 in USB-audio
driver; the device with boot quirks have been little tested, which
we need to watch out in this development cycle
- Add PM support for ICE1712 driver (finally!); it's still pretty
partial support, only for M-Audio devices"
* tag 'sound-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (610 commits)
ALSA: ice1712: Add suspend support for M-Audio ICE1712-based cards
ALSA: ice1712: add suspend support for ICE1712 chip
ALSA: hda - Enable beep for ASUS 1015E
ALSA: asihpi: fix some indenting in snd_card_asihpi_pcm_new()
ALSA: hda - add headset mic detect quirks for three Dell laptops
ASoC: tegra: move AC97 clock handling to the machine driver
ASoC: simple-card: Handle many DAI links
ASoC: simple-card: Add DT documentation for multi-DAI links
ASoC: simple-card: dynamically allocate the DAI link and properties
ASoC: imx-ssi: Add .xlate_tdm_slot_mask() support.
ASoC: fsl-esai: Add .xlate_tdm_slot_mask() support.
ASoC: fsl-utils: Add fsl_asoc_xlate_tdm_slot_mask() support.
ASoC: core: remove the 'of_' prefix of of_xlate_tdm_slot_mask.
ASoC: rcar: subnode tidyup for renesas,rsnd.txt
ASoC: Remove name_prefix unset during DAI link init hack
ALSA: hda - Inform the unexpectedly ignored pins by auto-parser
ASoC: rcar: bugfix: it cares about the non-src case
ARM: bockw: fixup SND_SOC_DAIFMT_CBx_CFx flags
ASoC: pcm: Drop incorrect double/extra frees
ASoC: mfld_machine: Fix compile error
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Increment max correctly in pci_scan_bridge() (Andreas Noever)
- Clarify the "scan anyway" comment in pci_scan_bridge() (Andreas Noever)
- Assign CardBus bus number only during the second pass (Andreas Noever)
- Use request_resource_conflict() instead of insert_ for bus numbers (Andreas Noever)
- Make sure bus number resources stay within their parents bounds (Andreas Noever)
- Remove pci_fixup_parent_subordinate_busnr() (Andreas Noever)
- Check for child busses which use more bus numbers than allocated (Andreas Noever)
- Don't scan random busses in pci_scan_bridge() (Andreas Noever)
- x86: Drop pcibios_scan_root() check for bus already scanned (Bjorn Helgaas)
- x86: Use pcibios_scan_root() instead of pci_scan_bus_with_sysdata() (Bjorn Helgaas)
- x86: Use pcibios_scan_root() instead of pci_scan_bus_on_node() (Bjorn Helgaas)
- x86: Merge pci_scan_bus_on_node() into pcibios_scan_root() (Bjorn Helgaas)
- x86: Drop return value of pcibios_scan_root() (Bjorn Helgaas)
NUMA
- x86: Add x86_pci_root_bus_node() to look up NUMA node from PCI bus (Bjorn Helgaas)
- x86: Use x86_pci_root_bus_node() instead of get_mp_bus_to_node() (Bjorn Helgaas)
- x86: Remove mp_bus_to_node[], set_mp_bus_to_node(), get_mp_bus_to_node() (Bjorn Helgaas)
- x86: Use NUMA_NO_NODE, not -1, for unknown node (Bjorn Helgaas)
- x86: Remove acpi_get_pxm() usage (Bjorn Helgaas)
- ia64: Use NUMA_NO_NODE, not MAX_NUMNODES, for unknown node (Bjorn Helgaas)
- ia64: Remove acpi_get_pxm() usage (Bjorn Helgaas)
- ACPI: Fix acpi_get_node() prototype (Bjorn Helgaas)
Resource management
- i2o: Fix and refactor PCI space allocation (Bjorn Helgaas)
- Add resource_contains() (Bjorn Helgaas)
- Add %pR support for IORESOURCE_UNSET (Bjorn Helgaas)
- Mark resources as IORESOURCE_UNSET if we can't assign them (Bjorn Helgaas)
- Don't clear IORESOURCE_UNSET when updating BAR (Bjorn Helgaas)
- Check IORESOURCE_UNSET before updating BAR (Bjorn Helgaas)
- Don't try to claim IORESOURCE_UNSET resources (Bjorn Helgaas)
- Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit (Bjorn Helgaas)
- Don't enable decoding if BAR hasn't been assigned an address (Bjorn Helgaas)
- Add "weak" generic pcibios_enable_device() implementation (Bjorn Helgaas)
- alpha, microblaze, sh, sparc, tile: Use default pcibios_enable_device() (Bjorn Helgaas)
- s390: Use generic pci_enable_resources() (Bjorn Helgaas)
- Don't check resource_size() in pci_bus_alloc_resource() (Bjorn Helgaas)
- Set type in __request_region() (Bjorn Helgaas)
- Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region() (Bjorn Helgaas)
- Change pci_bus_alloc_resource() type_mask to unsigned long (Bjorn Helgaas)
- Log IDE resource quirk in dmesg (Bjorn Helgaas)
- Revert "[PATCH] Insert GART region into resource map" (Bjorn Helgaas)
PCI device hotplug
- Make check_link_active() non-static (Rajat Jain)
- Use link change notifications for hot-plug and removal (Rajat Jain)
- Enable link state change notifications (Rajat Jain)
- Don't disable the link permanently during removal (Rajat Jain)
- Don't check adapter or latch status while disabling (Rajat Jain)
- Disable link notification across slot reset (Rajat Jain)
- Ensure very fast hotplug events are also processed (Rajat Jain)
- Add hotplug_lock to serialize hotplug events (Rajat Jain)
- Remove a non-existent card, regardless of "surprise" capability (Rajat Jain)
- Don't turn slot off when hot-added device already exists (Yijing Wang)
MSI
- Keep pci_enable_msi() documentation (Alexander Gordeev)
- ahci: Fix broken single MSI fallback (Alexander Gordeev)
- ahci, vfio: Use pci_enable_msi_range() (Alexander Gordeev)
- Check kmalloc() return value, fix leak of name (Greg Kroah-Hartman)
- Fix leak of msi_attrs (Greg Kroah-Hartman)
- Fix pci_msix_vec_count() htmldocs failure (Masanari Iida)
Virtualization
- Device-specific ACS support (Alex Williamson)
Freescale i.MX6
- Wait for retraining (Marek Vasut)
Marvell MVEBU
- Use Device ID and revision from underlying endpoint (Andrew Lunn)
- Fix incorrect size for PCI aperture resources (Jason Gunthorpe)
- Call request_resource() on the apertures (Jason Gunthorpe)
- Fix potential issue in range parsing (Jean-Jacques Hiblot)
Renesas R-Car
- Check platform_get_irq() return code (Ben Dooks)
- Add error interrupt handling (Ben Dooks)
- Fix bridge logic configuration accesses (Ben Dooks)
- Register each instance independently (Magnus Damm)
- Break out window size handling (Magnus Damm)
- Make the Kconfig dependencies more generic (Magnus Damm)
Synopsys DesignWare
- Fix RC BAR to be single 64-bit non-prefetchable memory (Mohit Kumar)
Miscellaneous
- Remove unused SR-IOV VF Migration support (Bjorn Helgaas)
- Enable INTx if BIOS left them disabled (Bjorn Helgaas)
- Fix hex vs decimal typo in cpqhpc_probe() (Dan Carpenter)
- Clean up par-arch object file list (Liviu Dudau)
- Set IORESOURCE_ROM_SHADOW only for the default VGA device (Sander Eikelenboom)
- ACPI, ARM, drm, powerpc, pcmcia, PCI: Use list_for_each_entry() for bus traversal (Yijing Wang)
- Fix pci_bus_b() build failure (Paul Gortmaker)"
* tag 'pci-v3.15-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (108 commits)
PCI: Log IDE resource quirk in dmesg
PCI: Change pci_bus_alloc_resource() type_mask to unsigned long
PCI: Check all IORESOURCE_TYPE_BITS in pci_bus_alloc_from_region()
resources: Set type in __request_region()
PCI: Don't check resource_size() in pci_bus_alloc_resource()
s390/PCI: Use generic pci_enable_resources()
tile PCI RC: Use default pcibios_enable_device()
sparc/PCI: Use default pcibios_enable_device() (Leon only)
sh/PCI: Use default pcibios_enable_device()
microblaze/PCI: Use default pcibios_enable_device()
alpha/PCI: Use default pcibios_enable_device()
PCI: Add "weak" generic pcibios_enable_device() implementation
PCI: Don't enable decoding if BAR hasn't been assigned an address
PCI: Enable INTx in pci_reenable_device() only when MSI/MSI-X not enabled
PCI: Mark 64-bit resource as IORESOURCE_UNSET if we only support 32-bit
PCI: Don't try to claim IORESOURCE_UNSET resources
PCI: Check IORESOURCE_UNSET before updating BAR
PCI: Don't clear IORESOURCE_UNSET when updating BAR
PCI: Mark resources as IORESOURCE_UNSET if we can't assign them
arch/x86/include/asm/topology.h
drivers/ata/ahci.c
Pull EDAC updates from Borislav Petkov:
"A bunch of EDAC updates all over the place:
- Support for new AMD models, along with more graceful fallback for
unsupported hw.
- Bunch of fixes from SUSE accumulated from bug reports
- Misc other fixes and cleanups"
* tag 'edac_for_3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Add support for newer F16h models
i7core_edac: Drop unused variable
i82875p_edac: Drop redundant call to pci_get_device()
amd8111_edac: Fix leaks in probe error paths
e752x_edac: Drop pvt->bridge_ck
MCE, AMD: Fix decoding module loading on unsupported hw
i5100_edac: Remove an unneeded condition in i5100_init_csrows()
sb_edac: Degrade log level for device registration
amd64_edac: Fix logic to determine channel for F15 M30h processors
edac/85xx: Remove deprecated IRQF_DISABLED
i3200_edac: Add a missing pci_disable_device() on the exit path
i5400_edac: Disable device when unloading module
e752x_edac: Simplify call to pci_get_device()
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon updates from Guenter Roeck:
- New drivers for ADC128D818, LTC2945, LTC4260, and LTC4222
- Added support for LTM4676 to ltc2978 driver
- Converted several drivers to use devm_hwmon_device_register_with_groups
- Various cleanup in several drivers
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (36 commits)
hwmon: (pmbus/ltc2978) Add support for LTM4676
hwmon: (pmbus/ltc2978) Add new chip ID for LTC2974
hwmon: Do not accept invalid name attributes
hwmon: (max6639) Use SIMPLE_DEV_PM_OPS macro
hwmon: (lm95245) Make temp2_crit_hyst read-only
hwmon: (lm95245) Convert to use devm_hwmon_device_register_with_groups
hwmon: (lm95245) Drop useless debug message
hwmon: (lm95245) Fix hysteresis temperatures
hwmon: (max6639) Convert to use devm_hwmon_device_register_with_groups
hwmon: (max6639) Introduce local dev variable, and reduce noisiness
hwmon: (max6650) Introduce local 'dev' variable
hwmon: (max6650) Drop error message after memory allocation failures
hwmon: (max6650) Convert to use devm_hwmon_device_register_with_groups
hwmon: (max6650) Rearrange code to no longer require forward declarations
hwmon: (ltc4215) Convert to devm_hwmon_device_register_with_groups
hwmon: (coretemp) Convert to use devm_hwmon_device_register_with_groups
hwmon: (coretemp) Allocate platform data with devm_kzalloc
hwmon: (coretemp) Use sysfs_create_group to create sysfs attributes
hwmon: (ltc4245) Remove devicetree conditionals
hwmon: (ltc4245) Drop debug messages
Pull watchdog updates from Wim Van Sebroeck:
"This patchset contains:
- Various small clean-ups and fixes
- boot logic hanegs for mpc8xxx_wdt
- it87_wdt: Work around non-working CIR interrupts
- iTCO_wdt: Fix the parent device
- Kconfig dependencies
- simplification of code with devm_ioremap_resource() or
platform_driver_probe()
- conversion of xilinx watchdog driver to Generic watchdog Framework
- addition of extra functionality and devices for the xilinx watchdog
driver
- Addition of Tegra watchdog"
* git://www.linux-watchdog.org/linux-watchdog: (38 commits)
watchdog: Fix Elan SC520 dependencies
watchdog: ib700wdt: Use platform_driver_probe
watchdog: geodewdt: Use platform_driver_probe
watchdog: advantechwdt: Use platform_driver_probe
watchdog: acquirewdt: Use platform_driver_probe
watchdog: iTCO_wdt: Fix the parent device
watchdog: it87_wdt: Work around non-working CIR interrupts
watchdog: bcm281xx: Fix Kconfig dependency
watchdog: s3c2410_wdt: Check return value of clk_prepare_enable
watchdog: s3c2410_wdt: Remove unneeded initialization
watchdog: sunxi: Change compatibles
watchdog: orion: prepare new Dove DT Kconfig variable
watchdog: fix checkpatch warnings and error
watchdog: Add tegra watchdog
watchdog: xilinx: Remove no_timeout variable
watchdog: xilinx: Enable this driver for Zynq
watchdog: xilinx: Add missing binding
watchdog: xilinx: Use correct comment indentation
watchdog: xilinx: Use of_property_read_u32
watchdog: xilinx: Fix all printk messages
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi Updates from Mark Brown:
"A busy release for both cleanups and new drivers this time along with
further factoring out of replicated code into the core:
- Provide support in the core for DMA mapping transfers - essentially
all drivers weren't implementing this properly, now there's no
excuse.
- Dual and quad mode support for spidev.
- Fix handling of cs_change in the generic implementation.
- Remove the S3C_DMA code from the s3c64xx driver now that all the
platforms using it have been converted to dmaengine.
- Lots of improvements to the Renesas SPI controllers.
- Drivers for Allwinner A10 and A31, Qualcomm QUP and Xylinx xtfpga.
- Removal of the bitrotted ti-ssp driver"
* tag 'spi-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (199 commits)
spi: Fix handling of cs_change in core implementation
spi: bitbang: Make spi_bitbang_stop() return void
spi: mpc52xx: Convert to use bits_per_word_mask
spi: omap-100k: Fix memory leak
spi: dw: Don't call kfree for memory allocated by devm_kzalloc
spi: fsl-dspi: Fix memory leak
spi: omap-uwire: add missing iounmap
spi: clps711x: Convert to use master->max_speed_hz
spi: clps711x: Enable driver compilation with COMPILE_TEST
spi: omap-uwire: Remove full duplex check
spi: Do not require a completion
spi: topcliff-pch: Transform noisy message to dev_vdbg
spi: coldfire-qspi: Simplify the code to set register bits for transfer speed
spi: bcm63xx: Remove unused define for PFX
spi: efm32: use $vendor,$device scheme for compatible string
spi: clps711x: Remove <mach/hardware.h> dependency
spi: topcliff-pch: Properly unregister platform devices on probe() error paths
spi: fsl-espi: Remove unused bits_per_word variable in fsl_espi_bufs
spi: altera: Remove the code to get unused platform_data
spi: fsl-lib: Fix memory leak of pinfo
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator updates from Mark Brown:
"This release has lots and lots of small cleanups and fixes in the
regulator subsystem, mainly cleaning up some bad patterns that got
duplicated in DT code, but otherwise very little of note outside of
the scope of the relevant drivers:
- Support for configuration of the initial state for gpio regulators
with multi-voltage support.
- Support for calling regulator_set_voltage() on fixed regulators.
- New drivers for Broadcom BCM590xx, Freescale pfuze200, Samsung
S2MPA01 & S2MPS11/4, some PWM controlled regulators found on some
ST boards and TI TPS65218"
* tag 'regulator-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (154 commits)
regulator: aat2870: Use regulator_map_voltage_ascend
regulator: st-pwm: Convert to get_voltage_sel
regulator: Add new driver for ST's PWM controlled voltage regulators
regulator: bcm590xx: Remove **rdev from struct bcm590xx_reg
regulator: bcm590xx: Make the modalias matches the driver name
regulator: s5m8767: Convert to use regulator_[enable|disable|is_enabled]_regmap
regulator: db8500-prcmu: Set 1.8V as a fixed voltage for vsmps2
regulator: s2mps11: Add missing of_node_put
regulator: s2mps11: Use of_get_child_by_name
Documentation: mfd: s2mps11: Document support for S2MPS14
regulator: s2mps11: Add set_suspend_disable for S2MPS14
regulator: s2mps11: Add support for S2MPS14 regulators
regulator: max8660: Fix brace alignment
regulator: dbx500: use seq_puts() instead of seq_printf()
regulator: dbx500-prcmu: Silence checkpatch warnings
regulator: anatop: Remove checking control_reg in [set|get]_voltage_sel
regulator: max8952: Silence checkpatch warning
regulator: max8925: Silence checkpatch warning
regulator: max8660: Silence checkpatch warnings
regulator: arizona-ldo1: Correct default regulator init_data
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap updates from Mark Brown:
"Quite a busy release for regmap this time around, the standout changes
are:
- A real implementation of regmap_multi_write() and a bypassed
version of it for use by drivers doing patch-like things with more
open coding for surrounding startup sequences.
- Support fast_io on bulk operations.
- Support split device binding and map initialisation for use by
devices required in early init (mainly system controllers).
- Fixes for some operations on maps with strides set.
- Export the value parsing operations to help generic code built on
top of the API.
- Support for MMIO regmaps with non-32 bit register sizes.
plus a few smaller fixes"
* tag 'regmap-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: (22 commits)
regmap: mmio: Add regmap_mmio_regbits_check.
regmap: mmio: Add support for 1/2/8 bytes wide register address.
regmap: mmio: add regmap_mmio_{regsize, count}_check.
regmap: cache: Don't attempt to sync non-writeable registers
regmap: cache: Step by stride in default sync
regmap: Fix possible sleep-in-atomic in regmap_bulk_write()
regmap: Ensure regmap_register_patch() is compatible with fast_io
regmap: irq: Set data pointer only on regmap_add_irq_chip success
regmap: Implementation for regmap_multi_reg_write
regmap: add regmap_parse_val api
mfd: arizona: Use new regmap features for manual register patch
regmap: Base regmap_register_patch on _regmap_multi_reg_write
regmap: Add bypassed version of regmap_multi_reg_write
regmap: Mark reg_defaults in regmap_multi_reg_write as const
regmap: fix coccinelle warnings
regmap: Check stride of register patch as we register it
regmap: Clean up _regmap_update_bits()
regmap: Separate regmap dev initialization
regmap: Check readable regs in _regmap_read
regmap: irq: Remove domain on exit
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control bulk changes from Linus Walleij:
"Pin control bulk changes for the v3.15 series, no new core
functionality this time, just incremental driver updates:
- A large refactoring of the MVEBU (Marvell) driver.
- A large refactoring of the Tegra (nVidia) driver.
- GPIO interrupt including soft edges support in the STi driver.
- Misc updates to PFC (Renesas), AT91, ADI2 (Blackfin),
pinctrl-single, sirf (CSR), msm (Qualcomm), Exynos (Samsung), sunxi
(AllWinner), i.MX (Freescale), Baytrail"
* tag 'pinctrl-v3.15-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (72 commits)
pinctrl: tegra: add some missing Tegra114 entries
pinctrl: tegra: fix some mistakes in Tegra124
pinctrl: msm: fix up out-of-order merge conflict
pinctrl: st: Fix error check for of_irq_to_resource usage
pinctrl: tegra: consistency cleanup
pinctrl: tegra: dynamically calculate function list of groups
pinctrl: tegra: init Tegra20/30 at module_init time
pinctrl: st: Use ARRAY_SIZE instead of raw value for number of delays
pinctrl: st: add pinctrl support for the STiH407 SoC
pinctrl: st: Enhance the controller to manage unavailable registers
pinctrl: msm: Simplify msm_config_reg() and callers
pinctrl: msm: Remove impossible WARN_ON()s
pinctrl: msm: Replace lookup tables with math
pinctrl: msm: Drop OF_IRQ dependency
pinctrl: msm: Drop unused includes
pinctrl: msm: Check for ngpios > MAX_NR_GPIO
pinctrl: msm: Silence recursive lockdep warning
pinctrl: mvebu: silence WARN to dev_warn
pinctrl: msm: drop wake_irqs bitmap
pinctrl-baytrail: add function mux checking in gpio pin request
Pull ACPI and power management updates from Rafael Wysocki:
"The majority of this material spent some time in linux-next, some of
it even several weeks. There are a few relatively fresh commits in
it, but they are mostly fixes and simple cleanups.
ACPI took the lead this time, both in terms of the number of commits
and the number of modified lines of code, cpufreq follows and there
are a few changes in the PM core and in cpuidle too.
A new feature that already got some LWN.net's attention is the device
PM QoS extension allowing latency tolerance requirements to be
propagated from leaf devices to their ancestors with hardware
interfaces for specifying latency tolerance. That should help systems
with hardware-driven power management to avoid going too far with it
in cases when there are latency tolerance constraints.
There also are some significant changes in the ACPI core related to
the way in which hotplug notifications are handled. They affect PCI
hotplug (ACPIPHP) and the ACPI dock station code too. The bottom line
is that all those notification now go through the root notify handler
and are propagated to the interested subsystems by means of callbacks
instead of having to install a notify handler for each device object
that we can potentially get hotplug notifications for.
In addition to that ACPICA will now advertise "Windows 2013"
compatibility for _OSI, because some systems out there don't work
correctly if that is not done (some of them don't even boot).
On the system suspend side of things, all of the device suspend and
resume callbacks, except for ->prepare() and ->complete(), are now
going to be executed asynchronously as that turns out to speed up
system suspend and resume on some platforms quite significantly and we
have a few more optimizations in that area.
Apart from that, there are some new device IDs and fixes and cleanups
all over. In particular, the system suspend and resume handling by
cpufreq should be improved and the cpuidle menu governor should be a
bit more robust now.
Specifics:
- Device PM QoS support for latency tolerance constraints on systems
with hardware interfaces allowing such constraints to be specified.
That is necessary to prevent hardware-driven power management from
becoming overly aggressive on some systems and to prevent power
management features leading to excessive latencies from being used
in some cases.
- Consolidation of the handling of ACPI hotplug notifications for
device objects. This causes all device hotplug notifications to go
through the root notify handler (that was executed for all of them
anyway before) that propagates them to individual subsystems, if
necessary, by executing callbacks provided by those subsystems
(those callbacks are associated with struct acpi_device objects
during device enumeration). As a result, the code in question
becomes both smaller in size and more straightforward and all of
those changes should not affect users.
- ACPICA update, including fixes related to the handling of _PRT in
cases when it is broken and the addition of "Windows 2013" to the
list of supported "features" for _OSI (which is necessary to
support systems that work incorrectly or don't even boot without
it). Changes from Bob Moore and Lv Zheng.
- Consolidation of ACPI _OST handling from Jiang Liu.
- ACPI battery and AC fixes allowing unusual system configurations to
be handled by that code from Alexander Mezin.
- New device IDs for the ACPI LPSS driver from Chiau Ee Chew.
- ACPI fan and thermal optimizations related to system suspend and
resume from Aaron Lu.
- Cleanups related to ACPI video from Jean Delvare.
- Assorted ACPI fixes and cleanups from Al Stone, Hanjun Guo, Lan
Tianyu, Paul Bolle, Tomasz Nowicki.
- Intel RAPL (Running Average Power Limits) driver cleanups from
Jacob Pan.
- intel_pstate fixes and cleanups from Dirk Brandewie.
- cpufreq fixes related to system suspend/resume handling from Viresh
Kumar.
- cpufreq core fixes and cleanups from Viresh Kumar, Stratos
Karafotis, Saravana Kannan, Rashika Kheria, Joe Perches.
- cpufreq drivers updates from Viresh Kumar, Zhuoyu Zhang, Rob
Herring.
- cpuidle fixes related to the menu governor from Tuukka Tikkanen.
- cpuidle fix related to coupled CPUs handling from Paul Burton.
- Asynchronous execution of all device suspend and resume callbacks,
except for ->prepare and ->complete, during system suspend and
resume from Chuansheng Liu.
- Delayed resuming of runtime-suspended devices during system suspend
for the PCI bus type and ACPI PM domain.
- New set of PM helper routines to allow device runtime PM callbacks
to be used during system suspend and resume more easily from Ulf
Hansson.
- Assorted fixes and cleanups in the PM core from Geert Uytterhoeven,
Prabhakar Lad, Philipp Zabel, Rashika Kheria, Sebastian Capella.
- devfreq fix from Saravana Kannan"
* tag 'pm+acpi-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits)
PM / devfreq: Rewrite devfreq_update_status() to fix multiple bugs
PM / sleep: Correct whitespace errors in <linux/pm.h>
intel_pstate: Set core to min P state during core offline
cpufreq: Add stop CPU callback to cpufreq_driver interface
cpufreq: Remove unnecessary braces
cpufreq: Fix checkpatch errors and warnings
cpufreq: powerpc: add cpufreq transition latency for FSL e500mc SoCs
MAINTAINERS: Reorder maintainer addresses for PM and ACPI
PM / Runtime: Update runtime_idle() documentation for return value meaning
video / output: Drop display output class support
fujitsu-laptop: Drop unneeded include
acer-wmi: Stop selecting VIDEO_OUTPUT_CONTROL
ACPI / gpu / drm: Stop selecting VIDEO_OUTPUT_CONTROL
ACPI / video: fix ACPI_VIDEO dependencies
cpufreq: remove unused notifier: CPUFREQ_{SUSPENDCHANGE|RESUMECHANGE}
cpufreq: Do not allow ->setpolicy drivers to provide ->target
cpufreq: arm_big_little: set 'physical_cluster' for each CPU
cpufreq: arm_big_little: make vexpress driver depend on bL core driver
ACPI / button: Add ACPI Button event via netlink routine
ACPI: Remove duplicate definitions of PREFIX
Pull irq code updates from Thomas Gleixner:
"The irq department proudly presents:
- Another tree wide sweep of irq infrastructure abuse. Clear winner
of the trainwreck engineering contest was:
#include "../../../kernel/irq/settings.h"
- Tree wide update of irq_set_affinity() callbacks which miss a cpu
online check when picking a single cpu out of the affinity mask.
- Tree wide consolidation of interrupt statistics.
- Updates to the threaded interrupt infrastructure to allow explicit
wakeup of the interrupt thread and a variant of synchronize_irq()
which synchronizes only the hard interrupt handler. Both are
needed to replace the homebrewn thread handling in the mmc/sdhci
code.
- New irq chip callbacks to allow proper support for GPIO based irqs.
The GPIO based interrupts need to request/release GPIO resources
from request/free_irq.
- A few new ARM interrupt chips. No revolutionary new hardware, just
differently wreckaged variations of the scheme.
- Small improvments, cleanups and updates all over the place"
I was hoping that that trainwreck engineering contest was a April Fools'
joke. But no.
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits)
irqchip: sun7i/sun6i: Disable NMI before registering the handler
ARM: sun7i/sun6i: dts: Fix IRQ number for sun6i NMI controller
ARM: sun7i/sun6i: irqchip: Update the documentation
ARM: sun7i/sun6i: dts: Add NMI irqchip support
ARM: sun7i/sun6i: irqchip: Add irqchip driver for NMI controller
genirq: Export symbol no_action()
arm: omap: Fix typo in ams-delta-fiq.c
m68k: atari: Fix the last kernel_stat.h fallout
irqchip: sun4i: Simplify sun4i_irq_ack
irqchip: sun4i: Use handle_fasteoi_irq for all interrupts
genirq: procfs: Make smp_affinity values go+r
softirq: Add linux/irq.h to make it compile again
m68k: amiga: Add linux/irq.h to make it compile again
irqchip: sun4i: Don't ack IRQs > 0, fix acking of IRQ 0
irqchip: sun4i: Fix a comment about mask register initialization
irqchip: sun4i: Fix irq 0 not working
genirq: Add a new IRQCHIP_EOI_THREADED flag
genirq: Document IRQCHIP_ONESHOT_SAFE flag
ARM: sunxi: dt: Convert to the new irq controller compatibles
irqchip: sunxi: Change compatibles
Pull timer changes from Thomas Gleixner:
"This assorted collection provides:
- A new timer based timer broadcast feature for systems which do not
provide a global accessible timer device. That allows those
systems to put CPUs into deep idle states where the per cpu timer
device stops.
- A few NOHZ_FULL related improvements to the timer wheel
- The usual updates to timer devices found in ARM SoCs
- Small improvements and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits)
tick: Remove code duplication in tick_handle_periodic()
tick: Fix spelling mistake in tick_handle_periodic()
x86: hpet: Use proper destructor for delayed work
workqueue: Provide destroy_delayed_work_on_stack()
clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS
timer: Remove code redundancy while calling get_nohz_timer_target()
hrtimer: Rearrange comments in the order struct members are declared
timer: Use variable head instead of &work_list in __run_timers()
clocksource: exynos_mct: silence a static checker warning
arm: zynq: Add support for cpufreq
arm: zynq: Don't use arm_global_timer with cpufreq
clocksource/cadence_ttc: Overhaul clocksource frequency adjustment
clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled
clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI
sh: Remove Kconfig entries for TMU, CMT and MTU2
ARM: shmobile: Remove CMT, TMU and STI Kconfig entries
clocksource: armada-370-xp: Use atomic access for shared registers
clocksource: orion: Use atomic access for shared registers
clocksource: timer-keystone: Delete unnecessary variable
clocksource: timer-keystone: introduce clocksource driver for Keystone
Pull x86 iommu quirk fix from Thomas Gleixner:
"A quirk for the iommu quirk to include silicon which was assumed not
to be out in the wild.
This time with the correct logic applied"
* 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Adjust irq remapping quirk for older revisions of 5500/5520 chipsets
Pull x86 threadinfo changes from Ingo Molnar:
"The main change here is the consolidation/unification of 32 and 64 bit
thread_info handling methods, from Steve Rostedt"
* 'x86-threadinfo-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, threadinfo: Redo "x86: Use inline assembler to get sp"
x86: Clean up dumpstack_64.c code
x86: Keep thread_info on thread stack in x86_32
x86: Prepare removal of previous_esp from i386 thread_info structure
x86: Nuke GET_THREAD_INFO_WITH_ESP() macro for i386
x86: Nuke the supervisor_stack field in i386 thread_info
Pull timer updates from Ingo Molnar:
"The main purpose is to fix a full dynticks bug related to
virtualization, where steal time accounting appears to be zero in
/proc/stat even after a few seconds of competing guests running busy
loops in a same host CPU. It's not a regression though as it was
there since the beginning.
The other commits are preparatory work to fix the bug and various
cleanups"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
arch: Remove stub cputime.h headers
sched: Remove needless round trip nsecs <-> tick conversion of steal time
cputime: Fix jiffies based cputime assumption on steal accounting
cputime: Bring cputime -> nsecs conversion
cputime: Default implementation of nsecs -> cputime conversion
cputime: Fix nsecs_to_cputime() return type cast
Pull x86 cpufeature update from Ingo Molnar:
"Two refinements to clflushopt support"
* 'x86-cpufeature-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, cpufeature: If we disable CLFLUSH, we should disable CLFLUSHOPT
x86, cpufeature: Rename X86_FEATURE_CLFLSH to X86_FEATURE_CLFLUSH
Pull x86 reboot changes from Ingo Molnar:
"Refine the reboot logic around the CF9 and EFI reboot methods, to make
it more robust. The expectation is for no working system to break,
and for a couple of reboot-force systems to start rebooting
automatically again"
* 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, reboot: Only use CF9_COND automatically, not CF9
x86, reboot: Add EFI and CF9 reboot methods into the default list
Pull x86 mm change from Ingo Molnar:
"A micro-optimization for acpi_numa_slit_init()"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Avoid duplicated pxm_to_node() calls
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32
Pull AVR32 updates from Hans-Christian Egtvedt.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32:
avr32: replace simple_strtoul() with kstrtoul()
arch/avr32/mm/cache.c: export symbol flush_icache_range() for module using
avr32: remove cpu_data macro to fix compiles
simple_strtoul() is marked for obsoletion; use the newer and more
pleasant kstrtoul() in its place.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
"A lot of activities on libata side this time.
- A lot of changes around ahci. Various embedded platforms are
implementing ahci controllers. Some were built atop ahci_platform,
others were doing their own things. Hans made some structural
changes to libahci and librarized ahci_platform so that ahci
platform drivers can share more common code. A couple platform
drivers are added on top of that and several are added to replace
older drivers which were doing their own things (older ones are
scheduled to be removed).
- Dan finishes the patchset to make libata PM operations
asynchronous. Combined with one patch being routed through scsi,
this should speed resume measurably.
- Various fixes and cleanups from Bartlomiej and others"
* 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (61 commits)
ata: fix Marvell SATA driver dependencies
ata: fix ARASAN CompactFlash PATA driver dependencies
ata: remove superfluous casts
ata: sata_highbank: remove superfluous cast
ata: fix Calxeda Highbank SATA driver dependencies
ata: fix R-Car SATA driver dependencies
ARM: davinci: da850: update SATA AHCI support
ata: add new-style AHCI platform driver for DaVinci DA850 AHCI controller
ata: move library code from ahci_platform.c to libahci_platform.c
ata: ahci_platform: fix ahci_platform_data->suspend method handling
libata: remove unused ata_sas_port_async_resume() stub
libata.h: add stub for ata_sas_port_resume
libata: async resume
libata, libsas: kill pm_result and related cleanup
ata: Fix compiler warning with APM X-Gene host controller driver
arm64: Add APM X-Gene SoC AHCI SATA host controller DTS entries
ata: Add APM X-Gene SoC AHCI SATA host controller driver
Documentation: Add documentation for the APM X-Gene SoC SATA host controller DTS binding
arm64: Add APM X-Gene SoC 15Gbps Multi-purpose PHY DTS entries
ata: ahci_sunxi: fix code formatting
Pull workqueue changes from Tejun Heo:
"PREPARE_[DELAYED_]WORK() were used to change the work function of work
items without fully reinitializing it; however, this makes workqueue
consider the work item as a different one from before and allows the
work item to start executing before the previous instance is finished
which can lead to extremely subtle issues which are painful to debug.
The interface has never been popular. This pull request contains
patches to remove existing usages and kill the interface. As one of
the changes was routed during the last devel cycle and another
depended on a pending change in nvme, for-3.15 contains a couple merge
commits.
In addition, interfaces which were deprecated quite a while ago -
__cancel_delayed_work() and WQ_NON_REENTRANT - are removed too"
* 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: remove deprecated WQ_NON_REENTRANT
workqueue: Spelling s/instensive/intensive/
workqueue: remove PREPARE_[DELAYED_]WORK()
staging/fwserial: don't use PREPARE_WORK
afs: don't use PREPARE_WORK
nvme: don't use PREPARE_WORK
usb: don't use PREPARE_DELAYED_WORK
floppy: don't use PREPARE_[DELAYED_]WORK
ps3-vuart: don't use PREPARE_WORK
wireless/rt2x00: don't use PREPARE_WORK in rt2800usb.c
workqueue: Remove deprecated __cancel_delayed_work()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu changes from Tejun Heo:
"The percpu allocation is now popular enough for the extremely naive
range allocator to cause scalability issues.
The existing allocator linearly scanned the allocation map on both
alloc and free without making use of hint or anything. Al
reimplemented the range allocator so that it can use binary search
instead of linear scan during free and alloc path uses simple hinting
to avoid scanning in common cases. Combined, the new allocator
resolves the scalability issue percpu allocator was showing during
container benchmark workload"
* 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: renew the max_contig if we merge the head and previous block
percpu: allocation size should be even
percpu: speed alloc_pcpu_area() up
percpu: store offsets instead of lengths in ->map[]
perpcu: fold pcpu_split_block() into the only caller
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull ARM64 updates from Catalin Marinas:
- KGDB support for arm64
- PCI I/O space extended to 16M (in preparation of PCIe support
patches)
- Dropping ZONE_DMA32 in favour of ZONE_DMA (we only need one for the
time being), together with swiotlb late initialisation to correctly
setup the bounce buffer
- DMA API cache maintenance support (not all ARMv8 platforms have
hardware cache coherency)
- Crypto extensions advertising via ELF_HWCAP2 for compat user space
- Perf support for dwarf unwinding in compat mode
- asm/tlb.h converted to the generic mmu_gather code
- asm-generic rwsem implementation
- Code clean-up
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (42 commits)
arm64: Remove pgprot_dmacoherent()
arm64: Support DMA_ATTR_WRITE_COMBINE
arm64: Implement custom mmap functions for dma mapping
arm64: Fix __range_ok macro
arm64: Fix duplicated Kconfig entries
arm64: mm: Route pmd thp functions through pte equivalents
arm64: rwsem: use asm-generic rwsem implementation
asm-generic: rwsem: de-PPCify rwsem.h
arm64: enable generic CPU feature modalias matching for this architecture
arm64: smp: make local symbol static
arm64: debug: make local symbols static
ARM64: perf: support dwarf unwinding in compat mode
ARM64: perf: add support for frame pointer unwinding in compat mode
ARM64: perf: add support for perf registers API
arm64: Add boot time configuration of Intermediate Physical Address size
arm64: Do not synchronise I and D caches for special ptes
arm64: Make DMA coherent and strongly ordered mappings not executable
arm64: barriers: add dmb barrier
arm64: topology: Implement basic CPU topology support
arm64: advertise ARMv8 extensions to 32-bit compat ELF binaries
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 updates from Tony Luck:
"Miscellaneous ia64 fixes for 3.15 merge window"
* tag 'please-pull-misc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
[IA64] Keep format strings from leaking into printk
Fix warning in make defconfig
[IA64] sba_iommu: fix section mismatch To: linux-kernel@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k updates from Geert Uytterhoeven.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Update defconfigs for v3.14-rc1
[SCSI] atari_scsi: Fix sleep_on race
m68k: head.S - Remove bogus L prefix in comment
m68k: Remove dead code
m68k: Remove CONSOLE_PENGUIN macro, adopt CONFIG_LOGO
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"There are two memory management related changes, the CMMA support for
KVM to avoid swap-in of freed pages and the split page table lock for
the PMD level. These two come with common code changes in mm/.
A fix for the long standing theoretical TLB flush problem, this one
comes with a common code change in kernel/sched/.
Another set of changes is Heikos uaccess work, included is the initial
set of patches with more to come.
And fixes and cleanups as usual"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (36 commits)
s390/con3270: optionally disable auto update
s390/mm: remove unecessary parameter from pgste_ipte_notify
s390/mm: remove unnecessary parameter from gmap_do_ipte_notify
s390/mm: fixing comment so that parameter name match
s390/smp: limit number of cpus in possible cpu mask
hypfs: Add clarification for "weight_min" attribute
s390: update defconfigs
s390/ptrace: add support for PTRACE_SINGLEBLOCK
s390/perf: make print_debug_cf() static
s390/topology: Remove call to update_cpu_masks()
s390/compat: remove compat exec domain
s390: select CONFIG_TTY for use of tty in unconditional keyboard driver
s390/appldata_os: fix cpu array size calculation
s390/checksum: remove memset() within csum_partial_copy_from_user()
s390/uaccess: remove copy_from_user_real()
s390/sclp_early: Return correct HSA block count also for zero
s390: add some drivers/subsystems to the MAINTAINERS file
s390: improve debug feature usage
s390/airq: add support for irq ranges
s390/mm: enable split page table lock for PMD level
Pull s390 compat wrapper rework from Heiko Carstens:
"S390 compat system call wrapper simplification work.
The intention of this work is to get rid of all hand written assembly
compat system call wrappers on s390, which perform proper sign or zero
extension, or pointer conversion of compat system call parameters.
Instead all of this should be done with C code eg by using Al's
COMPAT_SYSCALL_DEFINEx() macro.
Therefore all common code and s390 specific compat system calls have
been converted to the COMPAT_SYSCALL_DEFINEx() macro.
In order to generate correct code all compat system calls may only
have eg compat_ulong_t parameters, but no unsigned long parameters.
Those patches which change parameter types from unsigned long to
compat_ulong_t parameters are separate in this series, but shouldn't
cause any harm.
The only compat system calls which intentionally have 64 bit
parameters (preadv64 and pwritev64) in support of the x86/32 ABI
haven't been changed, but are now only available if an architecture
defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64.
System calls which do not have a compat variant but still need proper
zero extension on s390, like eg "long sys_brk(unsigned long brk)" will
get a proper wrapper function with the new s390 specific
COMPAT_SYSCALL_WRAPx() macro:
COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk);
which generates the following code (simplified):
asmlinkage long sys_brk(unsigned long brk);
asmlinkage long compat_sys_brk(long brk)
return sys_brk((u32)brk);
Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines
includes both linux/syscall.h and linux/compat.h, it will generate
build errors, if the declaration of sys_brk() doesn't match, or if
there exists a non-matching compat_sys_brk() declaration.
In addition this will intentionally result in a link error if
somewhere else a compat_sys_brk() function exists, which probably
should have been used instead. Two more BUILD_BUG_ONs make sure the
size and type of each compat syscall parameter can be handled
correctly with the s390 specific macros.
I converted the compat system calls step by step to verify the
generated code is correct and matches the previous code. In fact it
did not always match, however that was always a bug in the hand
written asm code.
In result we get less code, less bugs, and much more sanity checking"
* 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits)
s390/compat: add copyright statement
compat: include linux/unistd.h within linux/compat.h
s390/compat: get rid of compat wrapper assembly code
s390/compat: build error for large compat syscall args
mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
security/compat: convert to COMPAT_SYSCALL_DEFINE
kernel/compat: convert to COMPAT_SYSCALL_DEFINE
fs/compat: optional preadv64/pwrite64 compat system calls
ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t
s390/compat: partial parameter conversion within syscall wrappers
s390/compat: automatic zero, sign and pointer conversion of syscalls
s390/compat: add sync_file_range and fallocate compat syscalls
Pull x86 LTO changes from Peter Anvin:
"More infrastructure work in preparation for link-time optimization
(LTO). Most of these changes is to make sure symbols accessed from
assembly code are properly marked as visible so the linker doesn't
remove them.
My understanding is that the changes to support LTO are still not
upstream in binutils, but are on the way there. This patchset should
conclude the x86-specific changes, and remaining patches to actually
enable LTO will be fed through the Kbuild tree (other than keeping up
with changes to the x86 code base, of course), although not
necessarily in this merge window"
* 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits)
Kbuild, lto: Handle basic LTO in modpost
Kbuild, lto: Disable LTO for asm-offsets.c
Kbuild, lto: Add a gcc-ld script to let run gcc as ld
Kbuild, lto: add ld-version and ld-ifversion macros
Kbuild, lto: Drop .number postfixes in modpost
Kbuild, lto, workaround: Don't warn for initcall_reference in modpost
lto: Disable LTO for sys_ni
lto: Handle LTO common symbols in module loader
lto, workaround: Add workaround for initcall reordering
lto: Make asmlinkage __visible
x86, lto: Disable LTO for the x86 VDSO
initconst, x86: Fix initconst mistake in ts5500 code
initconst: Fix initconst mistake in dcdbas
asmlinkage: Make trace_hardirqs_on/off_caller visible
asmlinkage, x86: Fix 32bit memcpy for LTO
asmlinkage Make __stack_chk_failed and memcmp visible
asmlinkage: Mark rwsem functions that can be called from assembler asmlinkage
asmlinkage: Make main_extable_sort_needed visible
asmlinkage, mutex: Mark __visible
asmlinkage: Make trace_hardirq visible
Commit 03bbcb2e7e2 (iommu/vt-d: add quirk for broken interrupt
remapping on 55XX chipsets) properly disables irq remapping on the
5500/5520 chipsets that don't correctly perform that feature.
However, when I wrote it, I followed the errata sheet linked in that
commit too closely, and explicitly tied the activation of the quirk to
revision 0x13 of the chip, under the assumption that earlier revisions
were not in the field. Recently a system was reported to be suffering
from this remap bug and the quirk hadn't triggered, because the
revision id register read at a lower value that 0x13, so the quirk
test failed improperly. Given this, it seems only prudent to adjust
this quirk so that any revision less than 0x13 has the quirk asserted.
[ tglx: Removed the 0x12 comparison of pci id 3405 as this is covered
by the <= 0x13 check already ]
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: x86@kernel.org
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/1394649873-14913-1-git-send-email-nhorman@tuxdriver.com
Pull x86 kaslr update from Ingo Molnar:
"This adds kernel module load address randomization"
* 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, kaslr: fix module lock ordering problem
x86, kaslr: randomize module base load address
Pull x86 hyperv change from Ingo Molnar:
"Skip the timer_irq_works() check on hyperv systems"
* 'x86-hyperv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, hyperv: Bypass the timer_irq_works() check
Pull x86 hashing changes from Ingo Molnar:
"Small fixes and cleanups to the librarized arch_fast_hash() methods,
used by the net/openvswitch code"
* 'x86-hash-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, hash: Simplify switch, add __init annotation
x86, hash: Swap arguments passed to crc32_u32()
x86, hash: Fix build failure with older binutils
Pull x86 EFI changes from Ingo Molnar:
"The main changes:
- Add debug code to the dump EFI pagetable - Borislav Petkov
- Make 1:1 runtime mapping robust when booting on machines with lots
of memory - Borislav Petkov
- Move the EFI facilities bits out of 'x86_efi_facility' and into
efi.flags which is the standard architecture independent place to
keep EFI state, by Matt Fleming.
- Add 'EFI mixed mode' support: this allows 64-bit kernels to be
booted from 32-bit firmware. This needs a bootloader that supports
the 'EFI handover protocol'. By Matt Fleming"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
x86, efi: Abstract x86 efi_early calls
x86/efi: Restore 'attr' argument to query_variable_info()
x86/efi: Rip out phys_efi_get_time()
x86/efi: Preserve segment registers in mixed mode
x86/boot: Fix non-EFI build
x86, tools: Fix up compiler warnings
x86/efi: Re-disable interrupts after calling firmware services
x86/boot: Don't overwrite cr4 when enabling PAE
x86/efi: Wire up CONFIG_EFI_MIXED
x86/efi: Add mixed runtime services support
x86/efi: Firmware agnostic handover entry points
x86/efi: Split the boot stub into 32/64 code paths
x86/efi: Add early thunk code to go from 64-bit to 32-bit
x86/efi: Build our own EFI services pointer table
efi: Add separate 32-bit/64-bit definitions
x86/efi: Delete dead code when checking for non-native
x86/mm/pageattr: Always dump the right page table in an oops
x86, tools: Consolidate #ifdef code
x86/boot: Cleanup header.S by removing some #ifdefs
efi: Use NULL instead of 0 for pointer
Pull x86 debug cleanup from Ingo Molnar:
"A single trivial cleanup"
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
i386: Remove unneeded test of 'task' in dump_trace() (again)
Pull x86 cpu handling changes from Ingo Molnar:
"Bigger changes:
- Intel CPU hardware-enablement: new vector instructions support
(AVX-512), by Fenghua Yu.
- Support the clflushopt instruction and use it in appropriate
places. clflushopt is similar to clflush but with more relaxed
ordering, by Ross Zwisler.
- MSR accessor cleanups, by Borislav Petkov.
- 'forcepae' boot flag for those who have way too much time to spend
on way too old Pentium-M systems and want to live way too
dangerously, by Chris Bainbridge"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, cpu: Add forcepae parameter for booting PAE kernels on PAE-disabled Pentium M
Rename TAINT_UNSAFE_SMP to TAINT_CPU_OUT_OF_SPEC
x86, intel: Make MSR_IA32_MISC_ENABLE bit constants systematic
x86, Intel: Convert to the new bit access MSR accessors
x86, AMD: Convert to the new bit access MSR accessors
x86: Add another set of MSR accessor functions
x86: Use clflushopt in drm_clflush_virt_range
x86: Use clflushopt in drm_clflush_page
x86: Use clflushopt in clflush_cache_range
x86: Add support for the clflushopt instruction
x86, AVX-512: Enable AVX-512 States Context Switch
x86, AVX-512: AVX-512 Feature Detection
Pull x86 cleanups from Ingo Molnar:
"Various smaller cleanups"
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, pageattr: Correct WBINVD spelling in comment
x86, crash: Unify ifdef
x86, boot: Correct max ramdisk size name
Pull x86 build change from Ingo Molnar:
"Explicitly disable x87 FPU instructions, to catch mistaken floating
point use at build time, instead of crashing or misbehaving during run
time"
* 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Disable generation of traditional x87 instructions
Pull x86 apic changes from Ingo Molnar:
"An xAPIC CPU hotplug race fix, plus cleanups and minor fixes"
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/apic: Plug racy xAPIC access of CPU hotplug code
x86/apic: Always define nox2apic and define it as initdata
x86/apic: Remove unused function prototypes
x86/apic: Switch wait_for_init_deassert() to a bool flag
x86/apic: Only use default_wait_for_init_deassert()
Pull x86 acpi numa fix from Ingo Molnar:
"A single NUMA CPU hotplug fix"
* 'x86-acpi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, acpi: Fix bug in associating hot-added CPUs with corresponding NUMA node
Pull scheduler changes from Ingo Molnar:
"Bigger changes:
- sched/idle restructuring: they are WIP preparation for deeper
integration between the scheduler and idle state selection, by
Nicolas Pitre.
- add NUMA scheduling pseudo-interleaving, by Rik van Riel.
- optimize cgroup context switches, by Peter Zijlstra.
- RT scheduling enhancements, by Thomas Gleixner.
The rest is smaller changes, non-urgnt fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits)
sched: Clean up the task_hot() function
sched: Remove double calculation in fix_small_imbalance()
sched: Fix broken setscheduler()
sparc64, sched: Remove unused sparc64_multi_core
sched: Remove unused mc_capable() and smt_capable()
sched/numa: Move task_numa_free() to __put_task_struct()
sched/fair: Fix endless loop in idle_balance()
sched/core: Fix endless loop in pick_next_task()
sched/fair: Push down check for high priority class task into idle_balance()
sched/rt: Fix picking RT and DL tasks from empty queue
trace: Replace hardcoding of 19 with MAX_NICE
sched: Guarantee task priority in pick_next_task()
sched/idle: Remove stale old file
sched: Put rq's sched_avg under CONFIG_FAIR_GROUP_SCHED
cpuidle/arm64: Remove redundant cpuidle_idle_call()
cpuidle/powernv: Remove redundant cpuidle_idle_call()
sched, nohz: Exclude isolated cores from load balancing
sched: Fix select_task_rq_fair() description comments
workqueue: Replace hardcoding of -20 and 19 with MIN_NICE and MAX_NICE
sys: Replace hardcoding of -20 and 19 with MIN_NICE and MAX_NICE
Pull perf changes from Ingo Molnar:
"Main changes:
Kernel side changes:
- Add SNB/IVB/HSW client uncore memory controller support (Stephane
Eranian)
- Fix various x86/P4 PMU driver bugs (Don Zickus)
Tooling, user visible changes:
- Add several futex 'perf bench' microbenchmarks (Davidlohr Bueso)
- Speed up thread map generation (Don Zickus)
- Introduce 'perf kvm --list-cmds' command line option for use by
scripts (Ramkumar Ramachandra)
- Print the evsel name in the annotate stdio output, prep to fix
support outputting annotation for multiple events, not just for the
first one (Arnaldo Carvalho de Melo)
- Allow setting preferred callchain method in .perfconfig (Jiri Olsa)
- Show in what binaries/modules 'perf probe's are set (Masami
Hiramatsu)
- Support distro-style debuginfo for uprobe in 'perf probe' (Masami
Hiramatsu)
Tooling, internal changes and fixes:
- Use tid in mmap/mmap2 events to find maps (Don Zickus)
- Record the reason for filtering an address_location (Namhyung Kim)
- Apply all filters to an addr_location (Namhyung Kim)
- Merge al->filtered with hist_entry->filtered in report/hists
(Namhyung Kim)
- Fix memory leak when synthesizing thread records (Namhyung Kim)
- Use ui__has_annotation() in 'report' (Namhyung Kim)
- hists browser refactorings to reuse code accross UIs (Namhyung Kim)
- Add support for the new DWARF unwinder library in elfutils (Jiri
Olsa)
- Fix build race in the generation of bison files (Jiri Olsa)
- Further streamline the feature detection display, trimming it a bit
to show just the libraries detected, using VF=1 gets a more verbose
output, showing the less interesting feature checks as well (Jiri
Olsa).
- Check compatible symtab type before loading dso (Namhyung Kim)
- Check return value of filename__read_debuglink() (Stephane Eranian)
- Move some hashing and fs related code from tools/perf/util/ to
tools/lib/ so that it can be used by more tools/ living utilities
(Borislav Petkov)
- Prepare DWARF unwinding code for using an elfutils alternative
unwinding library (Jiri Olsa)
- Fix DWARF unwind max_stack processing (Jiri Olsa)
- Add dwarf unwind 'perf test' entry (Jiri Olsa)
- 'perf probe' improvements including memory leak fixes, sharing the
intlist class with other tools, uprobes/kprobes code sharing and
use of ref_reloc_sym (Masami Hiramatsu)
- Shorten sample symbol resolving by adding cpumode to struct
addr_location (Arnaldo Carvalho de Melo)
- Fix synthesizing mmaps for threads (Don Zickus)
- Fix invalid output on event group stdio report (Namhyung Kim)
- Fixup header alignment in 'perf sched latency' output (Ramkumar
Ramachandra)
- Fix off-by-one error in 'perf timechart record' argv handling
Tooling, cleanups:
- Remove unused thread__find_map function (Jiri Olsa)
- Remove unused simple_strtoul() function (Ramkumar Ramachandra)
Tooling, documentation updates:
- Update function names in debug messages (Ramkumar Ramachandra)
- Update some code references in design.txt (Ramkumar Ramachandra)
- Clarify load-latency information in the 'perf mem' docs (Andi
Kleen)
- Clarify x86 register naming in 'perf probe' docs (Andi Kleen)"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (96 commits)
perf tools: Remove unused simple_strtoul() function
perf tools: Update some code references in design.txt
perf evsel: Update function names in debug messages
perf tools: Remove thread__find_map function
perf annotate: Print the evsel name in the stdio output
perf report: Use ui__has_annotation()
perf tools: Fix memory leak when synthesizing thread records
perf tools: Use tid in mmap/mmap2 events to find maps
perf report: Merge al->filtered with hist_entry->filtered
perf symbols: Apply all filters to an addr_location
perf symbols: Record the reason for filtering an address_location
perf sched: Fixup header alignment in 'latency' output
perf timechart: Fix off-by-one error in 'record' argv handling
perf machine: Factor machine__find_thread to take tid argument
perf tools: Speed up thread map generation
perf kvm: introduce --list-cmds for use by scripts
perf ui hists: Pass evsel to hpp->header/width functions explicitly
perf symbols: Introduce thread__find_cpumode_addr_location
perf session: Change header.misc dump from decimal to hex
perf ui/tui: Reuse generic __hpp__fmt() code
Pull hweight type fix from Ingo Molnar:
"This lone commit makes sure that __const_hweight8() is unsigned, which
addresses a build warning if code is built with -Wsign-compare.
I hope the type cast in this cleanup is fine - another option would be
to eliminate the double unary negation and use a construct with more
obvious integer type characteristics, along the lines of:
((w) & (1ULL << 1) ? 1U : 0U)
or so"
* 'core-types-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
bitops: Fix signedness of compile-time hweight implementations
Pull RCU updates from Ingo Molnar:
"Main changes:
- Torture-test changes, including refactoring of rcutorture and
introduction of a vestigial locktorture.
- Real-time latency fixes.
- Documentation updates.
- Miscellaneous fixes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (77 commits)
rcu: Provide grace-period piggybacking API
rcu: Ensure kernel/rcu/rcu.h can be sourced/used stand-alone
rcu: Fix sparse warning for rcu_expedited from kernel/ksysfs.c
notifier: Substitute rcu_access_pointer() for rcu_dereference_raw()
Documentation/memory-barriers.txt: Clarify release/acquire ordering
rcutorture: Save kvm.sh output to log
rcutorture: Add a lock_busted to test the test
rcutorture: Place kvm-test-1-run.sh output into res directory
rcutorture: Rename TREE_RCU-Kconfig.txt
locktorture: Add kvm-recheck.sh plug-in for locktorture
rcutorture: Gracefully handle NULL cleanup hooks
locktorture: Add vestigial locktorture configuration
rcutorture: Introduce "rcu" directory level underneath configs
rcutorture: Rename kvm-test-1-rcu.sh
rcutorture: Remove RCU dependencies from ver_functions.sh API
rcutorture: Create CFcommon file for common Kconfig parameters
rcutorture: Create config files for scripted test-the-test testing
rcutorture: Add an rcu_busted to test the test
locktorture: Add a lock-torture kernel module
rcutorture: Abstract kvm-recheck.sh
Pull core locking updates from Ingo Molnar:
"The biggest change is the MCS spinlock generalization changes from Tim
Chen, Peter Zijlstra, Jason Low et al. There's also lockdep
fixes/enhancements from Oleg Nesterov, in particular a false negative
fix related to lockdep_set_novalidate_class() usage"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits)
locking/mutex: Fix debug checks
locking/mutexes: Add extra reschedule point
locking/mutexes: Introduce cancelable MCS lock for adaptive spinning
locking/mutexes: Unlock the mutex without the wait_lock
locking/mutexes: Modify the way optimistic spinners are queued
locking/mutexes: Return false if task need_resched() in mutex_can_spin_on_owner()
locking: Move mcs_spinlock.h into kernel/locking/
m68k: Skip futex_atomic_cmpxchg_inatomic() test
futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() test
Revert "sched/wait: Suppress Sparse 'variable shadowing' warning"
lockdep: Change lockdep_set_novalidate_class() to use _and_name
lockdep: Change mark_held_locks() to check hlock->check instead of lockdep_no_validate
lockdep: Don't create the wrong dependency on hlock->check == 0
lockdep: Make held_lock->check and "int check" argument bool
locking/mcs: Allow architecture specific asm files to be used for contended case
locking/mcs: Order the header files in Kbuild of each architecture in alphabetical order
hung_task/Documentation: Fix hung_task_warnings description
locking/mcs: Allow architectures to hook in to contended paths
locking/mcs: Micro-optimize the MCS code, add extra comments
