2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aic7xxx_old, eata_pio, ips, libsas: don't zero out sense_buffer in ↵FUJITA Tomonori
queuecommand LLDs don't need to zero out scsi_cmnd::sense_buffer in queuecommand since scsi-ml does. This is a preparation of the future changes to allocate the sense_buffer only when necessary. Many LLDs zero out the sense_buffer before touching it on the error case. This patch lets them alone for now because new APIs for them would be added later on. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: "Salyzyn, Mark" <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] megaraid: fix section mismatchRandy Dunlap
Change megaraid_pci_driver_g variable name so that it matches the modpost whitelist that allows pointers to init text/data. WARNING: vmlinux.o(.data+0x1a8e30): Section mismatch: reference to .init.text:megaraid_probe_one (between 'megaraid_pci_driver_g' and 'class_device_attr_megaraid_mbox_app_hndl') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] libsas: fix sense_buffer overrunFUJITA Tomonori
2008-01-23[SCSI] aacraid: SMC vendor identificationSalyzyn, Mark
Due to an internal limit associated with the AdapterTypeText field, SMC required a product ID that overloaded the combined vendor and product ID. A decision was made to ship the SMC products without a vendor string dropping the defacto space that used to delineate vendor and product to boot. To correct this, we needed to adjust the code in the driver to parse out the vendor and product strings for the adapter. We match of 'AOC' in the AdapterTypeText, if so we set the vendor to SMC and place the entire AdapterTypeText into the product field. This only affects the cosmetic presentation of the Adapter vendor and product in the logs and in sysfs. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: respond to enclosure service eventsSalyzyn, Mark
Added support to respond to enclosure service events (controller AIFs) to add, online or offline physical targets reported to sg. Also added online and offlining of arrays. Removed an automatic variable definition in a sub block that hid an earlier definition, determined to be inert as the sub-block use did not interfere. Bumped the driver versioning to stamp the addition of this feature. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sym53c8xx: fixes two bugs related to chip resetKrzysztof Helt
This patch fixes two bugs pointed by James Bottomley: 1. the if (!sym_data->io_reset). That variable is only ever filled by a stack based completion. If we find it non empty it means this code has been entered twice and we have a severe problem, so that should just become a BUG_ON(sym_data->io_reset). 2. sym_data->io_reset should be set to NULL before the routine is exited otherwise the PCI recovery code could end up completing what will be a bogus pointer into the stack. Big thanks to James Bottomley for help with the patch. Signed-off-by: Krzysztof Helt <krzysztof.h1@w.pl> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: add call to flush_kernel_dcache_pageSalyzyn, Mark
Some architectures require a call to flush_kernel_dcache_page for processor spoofed DMA operations. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] mpt fusion: Fix for module unload problem in flash less controller ↵Prakash, Sathya
environment This patch fixes the module unload problem in flash less 1030 controller environment where firmware download boot functionality is invoked. The problem is due to the firmware download is being done in the reverse order, which this patch solves by insureing the download occurs to the last controller being reset. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Update lpfc driver version to 8.2.4James Smart
Update lpfc driver version to 8.2.4 Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Rework misplaced reference taking on node structureJames Smart
Rework misplaced reference taking on node structure Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Enhance debugfs useJames Smart
Enhance debugfs to dump HBA SLIM as well as Host SLIM Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Fix Unsolicited Data itemsJames Smart
Fix Drivers Unsolicited CT command handling - we did not handle multiframe sequences well. Fix error due to delay in replenishing buffers for unsolicited data. Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Add additional sysfs and module parametersJames Smart
Made link speed and link topology modifiable via sysfs Make scatter gather Segment Count into a module parameter. Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Make lpfc legacy I/O port freeTomohiro Kusumi
This is a patch written by Tomohiro Kusumi and submitted to linux-scsi: http://marc.info/?l=linux-scsi&m=118673720712152&w=2 The original patch comment: This patch makes Emulex lpfc driver legacy I/O port free. It has already been acked quite long time ago. So I resubmit the patch. http://lkml.org/lkml/2006/11/22/28 Current lpfc driver is already using pci_select_bars() and pci_enable_device_bars() when the PCI bus has been reset. So I think this patch should also be acked. Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Miscellaneous FixesJames Smart
Miscellaneous Fixes: - Fix a couple of sparse complaints - Reset the FCP recovery flag when the node is not a FCP2 device. - Speed up offline prep delays - Fixed a memory leak in lpfc_mem_alloc failure path - Fixed external loopback test. - Fixed error code returned from the driver when HBA is over heated. - Correct Max NPIV vport to limits read from adapter - Add missing locks around fc_flag and FC_NEEDS_REG_VPI - Add missing hba ids for device identification - Added support for SET_VARIABLE and MBX_WRITE_WWN mailbox commands - Changed all temperature event messages from warning to error - Fix reporting of link speed when link is down - Added support for MBX_WRITE_WWN mailbox command - Change del_timer_sync() in ISR to del_timer() in interrupt handler - Correct instances of beXX_to_cpu() that should be cpu_to_beXX() - Perform target flush before releasing node references on module unload - Avoid bogus devloss_tmo messages when driver unloads - Fix panic when HBA generates ERATT interupt - Fix mbox race condition and a workaround on back-to-back mailbox commands - Force NPIV off for pt2pt mode between 2 NPorts - Stop worker thread before removing fc_host. - Fix up discovery timeout error case due to missing clear_la - Tighten mailbox polling code to speed up detection of fast completions - Only allow DUMP_MEMORY if adapter offline due to overtemp errors - Added extended error information to the log messages in chip init. Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Add parameters to enable and disable heartbeat and hba ↵James Smart
resets Add parameters to enable and disable heartbeat and hba resets Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Correct abort handler logicJames Smart
Correct Abort handler logic. It was unconditionally waiting a minimum of 2 seconds rather than looking for abort completion. Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] lpfc 8.2.4 : Miscellaneous Discovery/ELS FixesJames Smart
Miscellaneous Discovery/ELS Fixes: - Delay free's of ELS requests if adapter reject conditions - Fix concurrent PLOGI vs ADISC state handling - Add retry mechanism for GFF_ID - Correct some illegal state transitions around RSCN timeouts - Fix missing return in FAN handling Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: improve queue balancingSalyzyn, Mark
The adapter queue is divided up equally to all the arrays to prevent command starvation to any individual array. On the other hand, physical targets are only granted a queue depth of one each. The code prior to this patch used to deal with the incremental discovery of targets, but the driver knows how many arrays are present prior to the scan so this knowledge is used to generate a better estimate for the queue depth. Remove the capability of 'physical=0' from preventing access to the class of adapters that have the RAID/SCSI mode of operation since none of the physicals on the SCSI channel are candidates ever for an array. As always, the user can override this default queue depth policy by making the appropriate adjustments utilizing sysfs. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: OS panic after Adapter panic (hardening).Salyzyn, Mark
In experiments in the lab we managed to trigger an Adapter firmware panic (BlinkLED) coincidentally while several pass-through ioctl command from the management software were outstanding on a bug only present on a class of RAID Adapters that require a hardware reset rather than a commanded reset. The net result was an attempt to time out the management software command as if it came from the SCSI layer resulting in an OS panic. Adapters that use commanded reset, management commands are returned failed by the Adapter correctly. The adapter firmware panic that resulted in this condition was also resolved, and there were no adapters in the field with this specific firmware bug so we do not expect any field reports. This is a rare or unlikely corner condition, and no reports have ever been forwarded from the field. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: fix multiple definition of automatic variable warning.Salyzyn, Mark
The 'entry' automatic variable was defined at the top and within a block that uses it, removed the definition from the block that uses it. Some cosmetic changes were made while in the same file. This patch should be inert. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: fix big endian issuesSalyzyn, Mark
Big endian systems issues discovered in the aacraid driver. Somewhat reverses a patch from November 7th of last year that removed swap operations because they formerly were being assigned to an u8 array when they should have been assigned to an le32 array. This patch is largely inert for any little endian processor architecture. It resolves a bug in delivering the BlinkLED AIF event to registered applications when the adapter or associated hardware was reset due to ill health. A rare corner case occurrence, also largely unnoticed by any as it was a new (untested!) feature. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: variable redefinition hides earlier warningSalyzyn, Mark
The parameter 'info' is reused, renamed the second to sinfo to represent supplemental adapter info, to suppress compile warning message. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: add sysfs report of RAID levelSalyzyn, Mark
Report the RAID level string for the SCSI device representing the array. Report is in /sys/class/scsi_device/#:#:#:#/device/level. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] aacraid: add parameter to control FUA and SYNCHRONIZE_CACHE policySalyzyn, Mark
aacraid.cache parameter, Disable Queue Flush commands: bit 0 - Disable FUA in WRITE SCSI commands bit 1 - Disable SYNCHRONIZE_CACHE SCSI command bit 2 - Disable only if Battery not protecting adapter supplied Cache e.g.: aacraid.cache=7 will disable the FUA and SYNCHRONIZE_CACHE commands if the adapter has reported that it's cache is battery backed up. This parameter permits experimentation with tradeoffs between performance and caching policy. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] scsi_transport_spi: convert to attribute groupsJames Bottomley
This conversion makes full use of the is_visible() callback on attribute groups. Now, each device appears only with its capability flags in the transport class directory. Previously each device appeared with the capability of the host, so this is a functionality improvement. Converting to attribute groups allows us to sweep away most of the home grown #defines that were effectively doing the same thing. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sysfs: add filter function to groupsJames Bottomley
This patch allows the various users of attribute_groups to selectively allow the appearance of group attributes. The primary consumer of this will be the transport classes in which we currently have elaborate attribute selection algorithms to do this same thing. Acked-by: Greg KH <greg@kroah.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] add missing transport configure points for target and hostJames Bottomley
While trying to convert the SPI transport class to attribute groups, I discovered that we don't actually have any transport configure points for either the target or the host. This patch adds these missing transport class triggers. The host one is simply done after the add, the target one tries to be more clever and add it after devices may have been placed on the target (so the device configure will have set up the target parameters). Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] attribute_container: update to use the group interfaceJames Bottomley
This patch is the beginning of moving the attribute_containers to use attribute groups exclusively. The attr element is now deprecated and will eventually be removed (along with all the hand rolled code for doing exactly what attribute groups do) when all the consumers are converted to attribute groups. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sysfs: fix the sysfs_add_file_to_group interfacesJames Bottomley
I can't see a reason why these shouldn't work on every group. However, they only seem to work on named groups. This patch allows the group functions to work on anonymous groups (those with NULL names). Acked-by: Tejun Heo <htejun@gmail.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] libata: fix corruption induced by relaxed DMA alignment in SCSIJames Bottomley
Hugh Dickens noticed that SMART commands issued from user space can end up corupting memory. The problem occurs if the buffer used to read data spans two pages. The reason is that the PIO sector routines in libata are expecting physically contiguous pages when they do sector operations, so the left overs on the second page go into the next physically adjacent page rather than the next page in the sg mapping. Fix this by enforcing strict 512 byte alignment on all buffers from userspace. Acked-by: Hugh Dickins <hugh@veritas.com> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] relax scsi dma alignmentJames Bottomley
This patch relaxes the default SCSI DMA alignment from 512 bytes to 4 bytes. I remember from previous discussions that usb and firewire have sector size alignment requirements, so I upped their alignments in the respective slave allocs. The reason for doing this is so that we don't get such a huge amount of copy overhead in bio_copy_user() for udev. (basically all inquiries it issues can now be directly mapped). Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] block: Introduce new blk_queue_update_dma_alignment interfaceJames Bottomley
The purpose of this is to allow stacked alignment settings, with the ultimate queue alignment being set to the largest alignment requirement in the stack. The reason for this is so that the SCSI mid-layer can relax the default alignment requirements (which are basically causing a lot of superfluous copying to go on in the SG_IO interface) while allowing transports, devices or HBAs to add stricter limits if they need them. Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] fix scsi_setup_command_freelist failure path raceFUJITA Tomonori
Looks like that host_cmd_pool_mutex are necessary here. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sr: update to follow tray status correctlyJames Bottomley
Based on an original patch from: David Martin <tasio@tasio.net> When trying to get the drive status via ioctl CDROM_DRIVE_STATUS, with no disk it gives CDS_TRAY_OPEN even if the tray is closed. ioctl works as expected with ide-cd driver. Gentoo bug report: http://bugs.gentoo.org/show_bug.cgi?id=196879 Cc: Maarten Bressers <mbres@gentoo.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: don't use made up error codesJames Bottomley
This is bad for two reasons: 1. If they're returned to outside applications, no-one knows what they mean. 2. Eventually they'll clash with the ever expanding standard error codes. The problem error code in question is ETASK. I've replaced this by ECOMM (communications error on send) a network error code that seems to most closely relay what ETASK meant. Acked-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas, bsg: pass errors through correctlyJames Bottomley
Currently in BSG, errors returned in req->errors aren't passed back to the calling programme (either via SG_IO or via read/write). Fix this, while preserving the SCSI convention of returning status in req->errors. Now update libsas to return errors correctly instead of to ignore them. Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: don't treat underrun as an error on SMP tasksJames Bottomley
All SMP tasks sent through bsg generate messages like: sas: smp_execute_task: task to dev 500605b000001450 response: 0x0 status 0x81 Three times (because the task gets retried). Firstly, don't retry either overrun or underrun (the data buffer isn't going to change size) and secondly, just report the underrun but don't set an error for it. This is necessary so bsg can report back the residual. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: add host SMP processingJames Bottomley
This adds support for host side SMP processing, via a separate SMP interpreter file. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] mpt fusion: make mptsas_smp_handler update residFUJITA Tomonori
This patch fixes mptsas_smp_handler to update both din_resid or dout_resid on success. bsg can report back the residual. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: Hold queue lock when checking port/unit handle for task ↵Christof Schmitt
management cmd We need to hold the queue-lock when checking whether we still have a valid unit/port handle for the task management command, i.e whether we can issue this request for this unit/port. If the error recovery is about to close this unit/port, then it competes for the queue-lock. If the close request issued by the error recovery wins, then it is guaranteed that this unit/port has been blocked for other requests. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: Hold queue lock when checking port/unit handle for FCP commandChristof Schmitt
We need to hold the queue-lock when checking whether we still have a valid unit/port handle for the FCP command, i.e whether we can issue this request for this unit/port. If the error recovery is about to close this unit/port, then it competes for the queue-lock. If the close request issued by the error recovery wins, then it is guaranteed that this unit/port has been blocked for other requests. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: Hold queue lock when checking port handle for ELS commandChristof Schmitt
We need to hold the queue-lock when checking whether we still have a valid port handle for the ELS command, i.e whether we can issue this request for this port. If the error recovery is about to close this port, then it competes for the queue-lock. If the close request issued by the error recovery wins, then it is guaranteed that this port has been blocked for other requests. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: Hold queue lock when checking port/unit handle for abort commandChristof Schmitt
We need to hold the queue-lock when checking whether we still have a valid unit/port handle for the abort command, i.e whether we can issue this request for this unit/port. If the error recovery is about to close this unit/port, then it competes for the queue-lock. If the close request issued by the error recovery wins, then it is guaranteed that this unit/port has been blocked for other requests. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: Fix evaluation of port handles in abort handlerChristof Schmitt
According to the FSF spec, word 0 (bytes 0-3) has the handle specified with the abort command and word 1 (bytes 4-7) has the handle for the command to be aborted. Fix the if statements that try to compare those. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: fix use after free bug.Heiko Carstens
zfcp_erp_strategy_check_fsfreq() checks if it is safe to access the fsf_req associated with the erp_action that gets passed. To test if it is safe it accesses the fsf_req in order to get its index into the hash list. This is broken since the fsf_req might be freed already and the read index has no meaning. It could lead to memory corruption. Fix this by introducing a new zfcp_reqlist_find_safe() method which just checks if addresses are equal. This is slower, but only gets called in case of error recovery. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] megaraid: add __devexit annotationAdrian Bunk
megaraid_remove_one() can become __devexit. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: "Patro, Sumant" <Sumant.Patro@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] atari_NCR5380, sun3_NCR5380: operator precedence fixRoel Kluin
SR_REQ is defined 0x20, but bitanding has no effect because '!' has a higher priority than '&' Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] zfcp: update MAINTAINERSSwen Schillig
we are planning a major rewrite of the zfcp driver, meaning that a lot of patches will hit the mailing-list in the near future. Since I can't support this additional work-load along with my other responsibilities we are shifting the maintainership to Christof Schmitt as the maintainer and Martin Peschke as the co-maintainer. Please support the two in providing us a new and more stable zfcp environment. Thanks Swen Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
