2016-10-03Merge tag 'char-misc-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the "big" char and misc driver update for 4.9-rc1. Lots of little things here, all over the driver tree for subsystems that flow through me. Nothing major that I can discern, full details are in the shortlog. All have been in the linux-next tree with no reported issues" * tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits) drivers/misc/hpilo: Changes to support new security states in iLO5 FW at25: fix debug and error messaging misc/genwqe: ensure zero initialization vme: fake: remove unexpected unlock in fake_master_set() vme: fake: mark symbols static where possible spmi: pmic-arb: Return an error code if sanity check fails Drivers: hv: get rid of id in struct vmbus_channel Drivers: hv: make VMBus bus ids persistent mcb: Add a dma_device to mcb_device mcb: Enable PCI bus mastering by default mei: stop the stall timer worker if not needed clk: probe common clock drivers earlier vme: fake: fix build for 64-bit dma_addr_t ttyprintk: Neaten and simplify printing mei: me: add kaby point device ids coresight: tmc: mark symbols static where possible coresight: perf: deal with error condition properly Drivers: hv: hv_util: Avoid dynamic allocation in time synch fpga manager: Add hardware dependency to Zynq driver Drivers: hv: utils: Support TimeSync version 4.0 protocol samples. ...
2016-10-03Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull CPU hotplug updates from Thomas Gleixner: "Yet another batch of cpu hotplug core updates and conversions: - Provide core infrastructure for multi instance drivers so the drivers do not have to keep custom lists. - Convert custom lists to the new infrastructure. The block-mq custom list conversion comes through the block tree and makes the diffstat tip over to more lines removed than added. - Handle unbalanced hotplug enable/disable calls more gracefully. - Remove the obsolete CPU_STARTING/DYING notifier support. - Convert another batch of notifier users. The relayfs changes which conflicted with the conversion have been shipped to me by Andrew. The remaining lot is targeted for 4.10 so that we finally can remove the rest of the notifiers" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) cpufreq: Fix up conversion to hotplug state machine blk/mq: Reserve hotplug states for block multiqueue x86/apic/uv: Convert to hotplug state machine s390/mm/pfault: Convert to hotplug state machine mips/loongson/smp: Convert to hotplug state machine mips/octeon/smp: Convert to hotplug state machine fault-injection/cpu: Convert to hotplug state machine padata: Convert to hotplug state machine cpufreq: Convert to hotplug state machine ACPI/processor: Convert to hotplug state machine virtio scsi: Convert to hotplug state machine oprofile/timer: Convert to hotplug state machine block/softirq: Convert to hotplug state machine lib/irq_poll: Convert to hotplug state machine x86/microcode: Convert to hotplug state machine sh/SH-X3 SMP: Convert to hotplug state machine ia64/mca: Convert to hotplug state machine ARM/OMAP/wakeupgen: Convert to hotplug state machine ARM/shmobile: Convert to hotplug state machine arm64/FP/SIMD: Convert to hotplug state machine ...
2016-10-03Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "The irq departement proudly presents: - A rework of the core infrastructure to optimally spread interrupt for multiqueue devices. The first version was a bit naive and failed to take thread siblings and other details into account. Developed in cooperation with Christoph and Keith. - Proper delegation of softirqs to ksoftirqd, so if ksoftirqd is active then no further softirq processsing on interrupt return happens. Otherwise we try to delegate and still run another batch of network packets in the irq return path, which then tries to delegate to ksoftirqd ..... - A proper machine parseable sysfs based alternative for /proc/interrupts. - ACPI support for the GICV3-ITS and ARM interrupt remapping - Two new irq chips from the ARM SoC zoo: STM32-EXTI and MVEBU-PIC - A new irq chip for the JCore (SuperH) - The usual pile of small fixlets in core and irqchip drivers" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (42 commits) softirq: Let ksoftirqd do its job genirq: Make function __irq_do_set_handler() static ARM/dts: Add EXTI controller node to stm32f429 ARM/STM32: Select external interrupts controller drivers/irqchip: Add STM32 external interrupts support Documentation/dt-bindings: Document STM32 EXTI controller bindings irqchip/mips-gic: Use for_each_set_bit to iterate over local IRQs pci/msi: Retrieve affinity for a vector genirq/affinity: Remove old irq spread infrastructure genirq/msi: Switch to new irq spreading infrastructure genirq/affinity: Provide smarter irq spreading infrastructure genirq/msi: Add cpumask allocation to alloc_msi_entry genirq: Expose interrupt information through sysfs irqchip/gicv3-its: Use MADT ITS subtable to do PCI/MSI domain initialization irqchip/gicv3-its: Factor out PCI-MSI part that might be reused for ACPI irqchip/gicv3-its: Probe ITS in the ACPI way irqchip/gicv3-its: Refactor ITS DT init code to prepare for ACPI irqchip/gicv3-its: Cleanup for ITS domain initialization PCI/MSI: Setup MSI domain on a per-device basis using IORT ACPI table ACPI: Add new IORT functions to support MSI domain handling ...
2016-10-03Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "A rather smalish set of updates for timers and timekeeping: - Two core fixes to prevent potential undefinded behaviour about which gcc is complaining rightfully. - A fix to prevent stopping the tick on an (soon) offline CPU so it can complete the shutdown procedure. - Wait for clocks to stabilize before making decisions, so a not yet validated clock is not rejected. - The usual pile of fixes to the various clocksource drivers. - Core code typo and include fixlets" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timekeeping: Include the correct header for errno definitions clocksource/drivers/ti-32k: Prevent ftrace recursion clocksource/mips-gic-timer: Stop checking cpu_has_counter clocksource/mips-gic-timer: Print an error if IRQ setup fails tick/nohz: Prevent stopping the tick on an offline CPU clocksource/drivers/oxnas: Add OX820 compatible clocksource/drivers/timer-atmel-pit: Simplify IRQ handler clocksource/drivers/timer-atmel-pit: Remove uselesss WARN_ON_ONCE clocksource/drivers/timer-atmel-pit: Drop at91sam926x_pit_common_init clocksource/drivers/moxart: Replace panic by pr_err clocksource/drivers/moxart: Replace setup_irq by request_irq clocksource/drivers/moxart: Add Aspeed support clocksource/drivers/moxart: Use struct to hold state clocksource/drivers/moxart: Refactor enable/disable time: Avoid undefined behaviour in ktime_add_safe() time: Avoid undefined behaviour in timespec64_add_safe() timekeeping: Prints the amounts of time spent during suspend clocksource: Defer override invalidation unless clock is unstable hrtimer: Spelling fixes
2016-10-03Merge tag 'arc-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC updates from Vineet Gupta: - ARCv2 support for native 64-bit atomics using LLOCK/SCONDD instructions - Support for upcoming 3.0 release of HS38 cores - Dwarf unwindinder improvements: - enable unwinding of hand written assembler code using CFI pseudo-ops - switch to .eh_frame (as opposed to historic .debug_frame) - get rid of a bunch of adhoc band-aids in the process - Misc fixes: - perf supporting generic cache-references and cache-misses (Alexey) - default NODE_SHIFT (Noam Camus) - usage of KFLAG instruction to set IE (Yuriy) - Platforms: - Add "model" property across the DT (Alexey) - Enable MODULE_* in defconfigs * tag 'arc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: [plat*] enables MODULE* ARCv2: fix local_save_flags ARC: CONFIG_NODES_SHIFT fix default values ARCv2: intc: Use kflag if STATUS32.IE must be reset ARC: .exit.* sections can be discarded in .eh_frame regime ARC: dw2 unwind: enable cfi pseudo ops in string lib ARC: dw2 unwind: add infrastructure for adding cfi pseudo ops to asm ARC: entry: make ret_from_system_call local label ARC: dw2 unwind: don't force dwarf 2 ARC: dw2 unwind: switch to .eh_frame based unwinding ARC: dw2 unwind: factor CIE specifics for .eh_frame/.debug_frame ARC: module: support R_ARC_32_PCREL relocation arc: perf: Enable generic "cache-references" and "cache-misses" events ARC: [plat-eznps] add missing atomic_fetch_xxx operations ARCv2: Implement atomic64 based on LLOCKD/SCONDD instructions ARCv2: Support dynamic peripheral address space in HS38 rel 3.0 cores ARCv2: identify HS38 rel 3.0 cores ARCv2: Add support for ZeBu Emulation platform for HS cores arc: Add "model" properly in device tree description of all boards
2016-10-03Merge tag 'm68k-for-v4.9-tag1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - cleanups - defconfig updates - GPG fingerprint update * tag 'm68k-for-v4.9-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Migrate exception table users off module.h and onto extable.h CREDITS: Update fingerprint for Geert Uytterhoeven m68k: Use IS_ENABLED() instead of checking for built-in or module m68k/defconfig: Update defconfigs for v4.8-rc1
2016-10-03Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 vdso updates from Ingo Molnar: "The main changes in this cycle centered around adding support for 32-bit compatible C/R of the vDSO on 64-bit kernels, by Dmitry Safonov" * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vdso: Use CONFIG_X86_X32_ABI to enable vdso prctl x86/vdso: Only define map_vdso_randomized() if CONFIG_X86_64 x86/vdso: Only define prctl_map_vdso() if CONFIG_CHECKPOINT_RESTORE x86/signal: Add SA_{X32,IA32}_ABI sa_flags x86/ptrace: Down with test_thread_flag(TIF_IA32) x86/coredump: Use pr_reg size, rather that TIF_IA32 flag x86/arch_prctl/vdso: Add ARCH_MAP_VDSO_* x86/vdso: Replace calculate_addr in map_vdso() with addr x86/vdso: Unmap vdso blob on vvar mapping failure
2016-10-03Merge branch 'x86-timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 timer updates from Ingo Molnar: "This tree includes a HPET overhead micro-optimization plus new TSC frequencies for newer Intel CPUs" * 'x86-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/tsc: Add additional Intel CPU models to the crystal quirk list x86/tsc: Use cpu id defines instead of hex constants x86/hpet: Reduce HPET counter read contention
2016-10-03Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform changes from Ingo Molnar: "The main changes in this cycle were: - SGI UV updates (Andrew Banman) - Intel MID updates (Andy Shevchenko) - Initial Mellanox systems platform (Vadim Pasternak)" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/platform/mellanox: Fix return value check in mlxplat_init() x86/platform/mellanox: Introduce support for Mellanox systems platform x86/platform/uv/BAU: Add UV4-specific functions x86/platform/uv/BAU: Fix payload queue setup on UV4 hardware x86/platform/uv/BAU: Disable software timeout on UV4 hardware x86/platform/uv/BAU: Populate ->uvhub_version with UV4 version information x86/platform/uv/BAU: Use generic function pointers x86/platform/uv/BAU: Add generic function pointers x86/platform/uv/BAU: Convert uv_physnodeaddr() use to uv_gpa_to_offset() x86/platform/uv/BAU: Clean up pq_init() x86/platform/uv/BAU: Clean up and update printks x86/platform/uv/BAU: Clean up vertical alignment x86/platform/intel-mid: Keep SRAM powered on at boot x86/platform/intel-mid: Add Intel Penwell to ID table x86/cpu: Rename Merrifield2 to Moorefield x86/platform/intel-mid: Implement power off sequence x86/platform/intel-mid: Enable SD card detection on Merrifield x86/platform/intel-mid: Enable WiFi on Intel Edison x86/platform/intel-mid: Run PWRMU command immediately
2016-10-03Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Header file and a wrapper functions cleanup" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Migrate exception table users off module.h and onto extable.h x86: Clean up various simple wrapper functions
2016-10-03Merge branch 'x86-boot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 boot updates from Ingo Molnar: "The changes in this cycle were: - Save e820 table RAM footprint on larger kernel configurations. (Denys Vlasenko) - pmem related fixes (Dan Williams) - theoretical e820 boundary condition fix (Wei Yang)" * 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/boot: Fix kdump, cleanup aborted E820_PRAM max_pfn manipulation x86/e820: Use much less memory for e820/e820_saved, save up to 120k x86/e820: Prepare e280 code for switch to dynamic storage x86/e820: Mark some static functions __init x86/e820: Fix very large 'size' handling boundary condition
2016-10-03Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull low-level x86 updates from Ingo Molnar: "In this cycle this topic tree has become one of those 'super topics' that accumulated a lot of changes: - Add CONFIG_VMAP_STACK=y support to the core kernel and enable it on x86 - preceded by an array of changes. v4.8 saw preparatory changes in this area already - this is the rest of the work. Includes the thread stack caching performance optimization. (Andy Lutomirski) - switch_to() cleanups and all around enhancements. (Brian Gerst) - A large number of dumpstack infrastructure enhancements and an unwinder abstraction. The secret long term plan is safe(r) live patching plus maybe another attempt at debuginfo based unwinding - but all these current bits are standalone enhancements in a frame pointer based debug environment as well. (Josh Poimboeuf) - More __ro_after_init and const annotations. (Kees Cook) - Enable KASLR for the vmemmap memory region. (Thomas Garnier)" [ The virtually mapped stack changes are pretty fundamental, and not x86-specific per se, even if they are only used on x86 right now. ] * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits) x86/asm: Get rid of __read_cr4_safe() thread_info: Use unsigned long for flags x86/alternatives: Add stack frame dependency to alternative_call_2() x86/dumpstack: Fix show_stack() task pointer regression x86/dumpstack: Remove dump_trace() and related callbacks x86/dumpstack: Convert show_trace_log_lvl() to use the new unwinder oprofile/x86: Convert x86_backtrace() to use the new unwinder x86/stacktrace: Convert save_stack_trace_*() to use the new unwinder perf/x86: Convert perf_callchain_kernel() to use the new unwinder x86/unwind: Add new unwind interface and implementations x86/dumpstack: Remove NULL task pointer convention fork: Optimize task creation by caching two thread stacks per CPU if CONFIG_VMAP_STACK=y sched/core: Free the stack early if CONFIG_THREAD_INFO_IN_TASK lib/syscall: Pin the task stack in collect_syscall() x86/process: Pin the target stack in get_wchan() x86/dumpstack: Pin the target stack when dumping it kthread: Pin the stack via try_get_task_stack()/put_task_stack() in to_live_kthread() function sched/core: Add try_get_task_stack() and put_task_stack() x86/entry/64: Fix a minor comment rebase error iommu/amd: Don't put completion-wait semaphore on stack ...
2016-10-03Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 apic updates from Ingo Molnar: "The main changes are: - Persistent CPU/node numbering across CPU hotplug/unplug events. This is a pretty involved series of changes that first fetches all the information during bootup and then uses it for the various hotplug/unplug methods. (Gu Zheng, Dou Liyang) - IO-APIC hot-add/remove fixes and enhancements. (Rui Wang) - ... various fixes, cleanups and enhancements" * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits) x86/apic: Fix silent & fatal merge conflict in __generic_processor_info() acpi: Fix broken error check in map_processor() acpi: Validate processor id when mapping the processor acpi: Provide mechanism to validate processors in the ACPI tables x86/acpi: Set persistent cpuid <-> nodeid mapping when booting x86/acpi: Enable MADT APIs to return disabled apicids x86/acpi: Introduce persistent storage for cpuid <-> apicid mapping x86/acpi: Enable acpi to register all possible cpus at boot time x86/numa: Online memory-less nodes at boot time x86/apic: Get rid of apic_version[] array x86/apic: Order irq_enter/exit() calls correctly vs. ack_APIC_irq() x86/ioapic: Ignore root bridges without a companion ACPI device x86/apic: Update comment about disabling processor focus x86/smpboot: Check APIC ID before setting up default routing x86/ioapic: Fix IOAPIC failing to request resource x86/ioapic: Fix lost IOAPIC resource after hot-removal and hotadd x86/ioapic: Fix setup_res() failing to get resource x86/ioapic: Support hot-removal of IOAPICs present during boot x86/ioapic: Change prototype of acpi_ioapic_add() x86/apic, ACPI: Fix incorrect assignment when handling apic/x2apic entries ...
2016-10-03Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes are: - irqtime accounting cleanups and enhancements. (Frederic Weisbecker) - schedstat debugging enhancements, make it more broadly runtime available. (Josh Poimboeuf) - More work on asymmetric topology/capacity scheduling. (Morten Rasmussen) - sched/wait fixes and cleanups. (Oleg Nesterov) - PELT (per entity load tracking) improvements. (Peter Zijlstra) - Rewrite and enhance select_idle_siblings(). (Peter Zijlstra) - sched/numa enhancements/fixes (Rik van Riel) - sched/cputime scalability improvements (Stanislaw Gruszka) - Load calculation arithmetics fixes. (Dietmar Eggemann) - sched/deadline enhancements (Tommaso Cucinotta) - Fix utilization accounting when switching to the SCHED_NORMAL policy. (Vincent Guittot) - ... plus misc cleanups and enhancements" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits) sched/irqtime: Consolidate irqtime flushing code sched/irqtime: Consolidate accounting synchronization with u64_stats API u64_stats: Introduce IRQs disabled helpers sched/irqtime: Remove needless IRQs disablement on kcpustat update sched/irqtime: No need for preempt-safe accessors sched/fair: Fix min_vruntime tracking sched/debug: Add SCHED_WARN_ON() sched/core: Fix set_user_nice() sched/fair: Introduce set_curr_task() helper sched/core, ia64: Rename set_curr_task() sched/core: Fix incorrect utilization accounting when switching to fair class sched/core: Optimize SCHED_SMT sched/core: Rewrite and improve select_idle_siblings() sched/core: Replace sd_busy/nr_busy_cpus with sched_domain_shared sched/core: Introduce 'struct sched_domain_shared' sched/core: Restructure destroy_sched_domain() sched/core: Remove unused @cpu argument from destroy_sched_domain*() sched/wait: Introduce init_wait_entry() sched/wait: Avoid abort_exclusive_wait() in __wait_on_bit_lock() sched/wait: Avoid abort_exclusive_wait() in ___wait_event() ...
2016-10-03Merge branch 'ras-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RAS updates from Ingo Molnar: "The main changes were: - Lots of enhancements for AMD SMCA (Scalable MCA features/extensions) systems: extract, decode and print more hardware error information and add matching support on the injection/testing side as well. (Yazn Ghannam) - Various MCE handling improvements on modern Intel Xeons. (Tony Luck) - Plus misc fixes and enhancements" * 'ras-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86/RAS/mce_amd_inj: Remove debugfs dir recursively on exit x86/RAS/mce_amd_inj: Fix signed wrap around when decrementing index 'i' x86/RAS/mce_amd_inj: Fix some W= warnings x86/MCE/AMD, EDAC: Handle reserved bank 4 on Fam17h properly x86/mce/AMD: Extract the error address on SMCA systems x86/mce, EDAC/mce_amd: Print MCA_SYND and MCA_IPID during MCE on SMCA systems x86/mce/AMD: Save MCA_IPID in MCE struct on SMCA systems x86/mce/AMD: Ensure the deferred error interrupt is of type APIC on SMCA systems x86/mce/AMD: Update sysfs bank names for SMCA systems x86/mce/AMD, EDAC/mce_amd: Define and use tables for known SMCA IP types EDAC/mce_amd: Use SMCA prefix for error descriptions arrays EDAC/mce_amd: Add missing SMCA error descriptions x86/mce/AMD: Read MSRs on the CPU allocating the threshold blocks x86/RAS: Add syndrome support to mce_amd_inj EDAC/mce_amd: Print syndrome register value on SMCA systems x86/mce: Add support for new MCA_SYND register x86/mce/AMD: Use msr_ops.misc() in allocate_threshold_blocks() x86/mce: Drop X86_FEATURE_MCE_RECOVERY and the related model string test x86/mce: Improve memcpy_mcsafe() x86/mce: Add PCI quirks to identify Xeons with machine check recovery ...
2016-10-03Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "The main kernel side changes were: - uprobes enhancements (Masami Hiramatsu) - Uncore group events enhancements (David Carrillo-Cisneros) - x86 Intel: Add support for Skylake server uncore PMUs (Kan Liang) - x86 Intel: LBR cleanups and enhancements, for better branch annotation tracking (Peter Zijlstra) - x86 Intel: Add support for PTWRITE and power event tracing (Alexander Shishkin) - ... various fixes, cleanups and smaller enhancements. Lots of tooling changes - a couple of highlights: - Support event group view with hierarchy mode in 'perf top' and 'perf report' (Namhyung Kim) e.g.: $ perf record -e '{cycles,instructions}' make $ perf report --hierarchy --stdio ... # Overhead Command / Shared Object / Symbol # ...................... .................................. ... 25.74% 27.18%sh 19.96% 24.14%libc-2.24.so 9.55% 14.64%[.] __strcmp_sse2 1.54% 0.00%[.] __tfind 1.07% 1.13%[.] _int_malloc 0.95% 0.00%[.] __strchr_sse2 0.89% 1.39%[.] __tsearch 0.76% 0.00%[.] strlen - Add branch stack / basic block info to 'perf annotate --stdio', where for each branch, we add an asm comment after the instruction with information on how often it was taken and predicted. See example with color output at: http://vger.kernel.org/~acme/perf/annotate_basic_blocks.png (Peter Zijlstra) - Add support for using symbols in address filters with Intel PT and ARM CoreSight (hardware assisted tracing facilities) (Adrian Hunter, Mathieu Poirier) - Add support for interacting with Coresight PMU ETMs/PTMs, that are IP blocks to perform hardware assisted tracing on a ARM CPU core (Mathieu Poirier) - Support generating cross arch probes, i.e. if you specify a vmlinux file for different arch than the one in the host machine, $ perf probe --definition function_name args will generate the probe definition string needed to append to the target machine /sys/kernel/debug/tracing/kprobes_events file, using scripting (Masami Hiramatsu). - Allow configuring the default 'perf report -s' sort order in ~/.perfconfig, for instance, "sym,dso" may be more fitting for kernel developers. (Arnaldo Carvalho de Melo) - ... plus lots of other changes, refactorings, features and fixes" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (149 commits) perf tests: Add dwarf unwind test for powerpc perf probe: Match linkage name with mangled name perf probe: Fix to cut off incompatible chars from group name perf probe: Skip if the function address is 0 perf probe: Ignore the error of finding inline instance perf intel-pt: Fix decoding when there are address filters perf intel-pt: Enable decoder to handle TIP.PGD with missing IP perf intel-pt: Read address filter from AUXTRACE_INFO event perf intel-pt: Record address filter in AUXTRACE_INFO event perf intel-pt: Add a helper function for processing AUXTRACE_INFO perf intel-pt: Fix missing error codes processing auxtrace_info perf intel-pt: Add support for recording the max non-turbo ratio perf intel-pt: Fix snapshot overlap detection decoder errors perf probe: Increase debug level of SDT debug messages perf record: Add support for using symbols in address filters perf symbols: Add dso__last_symbol() perf record: Fix error paths perf record: Rename label 'out_symbol_exit' perf script: Fix vanished idle symbols perf evsel: Add support for address filters ...
2016-10-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The main changes in this cycle were: - rwsem micro-optimizations (Davidlohr Bueso) - Improve the implementation and optimize the performance of percpu-rwsems. (Peter Zijlstra.) - Convert all lglock users to better facilities such as percpu-rwsems or percpu-spinlocks and remove lglocks. (Peter Zijlstra) - Remove the ticket (spin)lock implementation. (Peter Zijlstra) - Korean translation of memory-barriers.txt and related fixes to the English document. (SeongJae Park) - misc fixes and cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) x86/cmpxchg, locking/atomics: Remove superfluous definitions x86, locking/spinlocks: Remove ticket (spin)lock implementation locking/lglock: Remove lglock implementation stop_machine: Remove stop_cpus_lock and lg_double_lock/unlock() fs/locks: Use percpu_down_read_preempt_disable() locking/percpu-rwsem: Add down_read_preempt_disable() fs/locks: Replace lg_local with a per-cpu spinlock fs/locks: Replace lg_global with a percpu-rwsem locking/percpu-rwsem: Add DEFINE_STATIC_PERCPU_RWSEMand percpu_rwsem_assert_held() locking/pv-qspinlock: Use cmpxchg_release() in __pv_queued_spin_unlock() locking/rwsem, x86: Drop a bogus cc clobber futex: Add some more function commentry locking/hung_task: Show all locks locking/rwsem: Scan the wait_list for readers only once locking/rwsem: Remove a few useless comments locking/rwsem: Return void in __rwsem_mark_wake() locking, rcu, cgroup: Avoid synchronize_sched() in __cgroup_procs_write() locking/Documentation: Add Korean translation locking/Documentation: Fix a typo of example result locking/Documentation: Fix wrong section reference ...
2016-10-03Merge branch 'efi-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI updates from Ingo Molnar: "Main changes in this cycle were: - Refactor the EFI memory map code into architecture neutral files and allow drivers to permanently reserve EFI boot services regions on x86, as well as ARM/arm64. (Matt Fleming) - Add ARM support for the EFI ESRT driver. (Ard Biesheuvel) - Make the EFI runtime services and efivar API interruptible by swapping spinlocks for semaphores. (Sylvain Chouleur) - Provide the EFI identity mapping for kexec which allows kexec to work on SGI/UV platforms with requiring the "noefi" kernel command line parameter. (Alex Thorlton) - Add debugfs node to dump EFI page tables on arm64. (Ard Biesheuvel) - Merge the EFI test driver being carried out of tree until now in the FWTS project. (Ivan Hu) - Expand the list of flags for classifying EFI regions as "RAM" on arm64 so we align with the UEFI spec. (Ard Biesheuvel) - Optimise out the EFI mixed mode if it's unsupported (CONFIG_X86_32) or disabled (CONFIG_EFI_MIXED=n) and switch the early EFI boot services function table for direct calls, alleviating us from having to maintain the custom function table. (Lukas Wunner) - Miscellaneous cleanups and fixes" * 'efi-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits) x86/efi: Round EFI memmap reservations to EFI_PAGE_SIZE x86/efi: Allow invocation of arbitrary boot services x86/efi: Optimize away setup_gop32/64 if unused x86/efi: Use kmalloc_array() in efi_call_phys_prolog() efi/arm64: Treat regions with WT/WC set but WB cleared as memory efi: Add efi_test driver for exporting UEFI runtime service interfaces x86/efi: Defer efi_esrt_init until after memblock_x86_fill efi/arm64: Add debugfs node to dump UEFI runtime page tables x86/efi: Remove unused find_bits() function fs/efivarfs: Fix double kfree() in error path x86/efi: Map in physical addresses in efi_map_region_fixed lib/ucs2_string: Speed up ucs2_utf8size() firmware-gsmi: Delete an unnecessary check before the function call "dma_pool_destroy" x86/efi: Initialize status to ensure garbage is not returned on small size efi: Replace runtime services spinlock with semaphore efi: Don't use spinlocks for efi vars efi: Use a file local lock for efivars efi/arm*: esrt: Add missing call to efi_esrt_init() efi/esrt: Use memremap not ioremap to access ESRT table in memory x86/efi-bgrt: Use efi_mem_reserve() to avoid copying image data ...
2016-10-03Merge branch 'core-smp-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core SMP updates from Ingo Molnar: "Two main change is generic vCPU pinning and physical CPU SMP-call support, for Xen to be able to perform certain calls on specific physical CPUs - by Juergen Gross" * 'core-smp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: smp: Allocate smp_call_on_cpu() workqueue on stack too hwmon: Use smp_call_on_cpu() for dell-smm i8k dcdbas: Make use of smp_call_on_cpu() xen: Add xen_pin_vcpu() to support calling functions on a dedicated pCPU smp: Add function to execute a function synchronously on a CPU virt, sched: Add generic vCPU pinning support xen: Sync xen header
2016-10-03Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle were: - Expedited grace-period changes, most notably avoiding having user threads drive expedited grace periods, using a workqueue instead. - Miscellaneous fixes, including a performance fix for lists that was sent with the lists modifications. - CPU hotplug updates, most notably providing exact CPU-online tracking for RCU. This will in turn allow removal of the checks supporting RCU's prior heuristic that was based on the assumption that CPUs would take no longer than one jiffy to come online. - Torture-test updates. - Documentation updates" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits) list: Expand list_first_entry_or_null() torture: TOROUT_STRING(): Insert a space between flag and message rcuperf: Consistently insert space between flag and message rcutorture: Print out barrier error as document says torture: Add task state to writer-task stall printk()s torture: Convert torture_shutdown() to hrtimer rcutorture: Convert to hotplug state machine cpu/hotplug: Get rid of CPU_STARTING reference rcu: Provide exact CPU-online tracking for RCU rcu: Avoid redundant quiescent-state chasing rcu: Don't use modular infrastructure in non-modular code sched: Make wake_up_nohz_cpu() handle CPUs going offline rcu: Use rcu_gp_kthread_wake() to wake up grace period kthreads rcu: Use RCU's online-CPU state for expedited IPI retry rcu: Exclude RCU-offline CPUs from expedited grace periods rcu: Make expedited RCU CPU stall warnings respond to controls rcu: Stop disabling expedited RCU CPU stall warnings rcu: Drive expedited grace periods from workqueue rcu: Consolidate expedited grace period machinery documentation: Record reason for rcu_head two-byte alignment ...
2016-10-03Merge tag 'pnp-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull PNP update from Rafael Wysocki: "This makes more PNP core code explicitly non-modular (Paul Gortmaker)" * tag 'pnp-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PNP: isapnp: make core more explicitly non-modular
2016-10-03Merge tag 'acpi-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI updates from Rafael Wysocki: "First off, the ACPICA code in the kernel is updated to upstream revision 20160831 that brings in a few bug fixes and cleanups. In particular, it is possible to mask GPEs now (and the sysfs interface for GPE control is fixed on top of that), problems related to the table loading mechanism are fixed and all code related to FADT version 2 (which has never been part of the ACPI specification) is dropped. On the new features front, there is a new watchdog driver based on the ACPI WDAT (ACPI Watchdog Action Table), needed on some platforms to replace the iTCO watchdog that doesn't work there, and some UART devices get new definitions of built-in properties (to be accessed via the generic device properties API). Also, included is a fix for an ACPI-related PCI resorces allocation issue and a few problems in the EC driver and in the button and battery drivers are fixed. In addition to that, the ACPI CPPC library is updated to make batching of requests sent over the PCC channel possible (which reduces the PCC usage overhead substantially in some cases) and to support functional fixed hardware (FFH) type of CPPC registers access (which will allow CPPC to be used on x86 too in the future). As usual, there are some assorted fixes and cleanups too. Specifics: - Update of the ACPICA code in the kernel to upstream revision 20160831 with the following major changes: * New mechanism for GPE masking. * Fixes for issues related to the LoadTable operator and table loading. * Fixes for issues related to so-called module-level code (MLC), that is AML that doesn't belong to any methods. * Change of the return value of the _OSI method to reflect the Windows behavior. * GAS (Generic Address Structure) support fix related to 32-bit FADT addresses. * Elimination of unnecessary FADT version 2 support. * ACPI tools fixes and cleanups. From Bob Moore, Lv Zheng, and Jung-uk Kim. - ACPI sysfs interface updates to fix GPE handling (on top of the new GPE masking mechanism in ACPICA) and issues related to table loading (Lv Zheng). - New watchdog driver based on the ACPI WDAT (ACPI Watchdog Action Table), needed on some platforms to replace the iTCO watchdog that doesn't work there and related updates of the intel_pmc_ipc, i2c/i801 and MFD/lcp_ich drivers (Mika Westerberg). - Driver core fix to prevent it from leaking secondary fwnode objects during device removal (Lukas Wunner). - New definitions of built-in properties for UART in ACPI-based x86 SoC drivers and a 8250_dw driver quirk for the APM X-Gene SoC (Heikki Krogerus). - New device ID for the Vulcan SPI controller and constification of local strucures in the AMD SoC (APD) ACPI driver (Kamlakant Patel, Julia Lawall). - Fix for a bug causing the allocation of PCI resorces to fail if ACPI-enumerated child platform devices are registered below the PCI devices in question (Mika Westerberg). - Change of the default polarity for PCI legacy IRQs to high on systems booting wth ACPI on platforms with a GIC interrupt controller model fixing the discrepancy between the specification and HW behavior (Lorenzo Pieralisi). - Fixes for the handling of system suspend/resume in the ACPI EC driver and update of that driver to make it cope with the cases when the EC device defined in the ECDT has to be used throughout the entire system life cycle (Lv Zheng). - Update of the ACPI CPPC library to allow it to batch requests sent over the PCC channel (to reduce overhead), to support the fixed functional hardware (FFH) CPPC registers access type, to notify the mailbox framework about TX completions when the interrupt flag is set for the PCC mailbox, and to support HW-Reduced Communication Subspace type 2 (Ashwin Chaugule, Prashanth Prakash, Srinivas Pandruvada, Hoan Tran). - ACPI button driver fix and documentation update related to the handling of laptop lids (Lv Zheng). - ACPI battery driver initialization fix (Carlos Garnacho). - ACPI GPIO enumeration documentation update (Mika Westerberg). - Assorted updates of the core ACPI bus type code (Lukas Wunner, Lv Zheng). - Assorted cleanups of the ACPI table parsing code and the x86-specific ACPI code (Al Stone). - Fixes for assorted ACPI-related issues found in linux-next (Wei Yongjun)" * tag 'acpi-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (98 commits) ACPI / documentation: Use recommended name in GPIO property names watchdog: wdat_wdt: Fix warning for using 0 as NULL watchdog: wdat_wdt: fix return value check in wdat_wdt_probe() platform/x86: intel_pmc_ipc: Do not create iTCO watchdog when WDAT table exists i2c: i801: Do not create iTCO watchdog when WDAT table exists mfd: lpc_ich: Do not create iTCO watchdog when WDAT table exists ACPI / bus: Adjust ACPI subsystem initialization for new table loading mode ACPICA: Parser: Fix a regression in LoadTable support ACPICA: Tables: Fix "UNLOAD" code path lock issues ACPI / watchdog: Add support for WDAT hardware watchdog ACPI / platform: Pay attention to parent device's resources PCI: Add pci_find_resource() ACPI / CPPC: Support PCC with interrupt flag ACPI / sysfs: Update sysfs signature handling code ACPI / sysfs: Fix an issue for LoadTable opcode ACPICA: Tables: Fix a regression in acpi_tb_find_table() ACPI / tables: Remove duplicated include from tables.c ACPI / APD: constify local structures x86: ACPI: make variable names clearer in acpi_parse_madt_lapic_entries() x86: ACPI: remove extraneous white space after semicolon ...
2016-10-03Merge tag 'pm-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: "Traditionally, cpufreq is the area with the greatest number of changes, but there are fewer of them than last time. There also is some activity in the generic power domains and the devfreq frameworks, a couple of system suspend and hibernation fixes and some assorted changes in other places. One new feature is the cpufreq change to allow the scheduler to pass hints to the governors' utilization update callbacks and some code rework based on that. Another one is the support for domain removal in the generic power domains framework. Also it is now possible to use hibernation with PAGE_POISONING_ZERO enabled and devfreq supports the RockChip DFI controller and the rk3399 DMC. The rest of the changes is mostly fixes and cleanups in a number of places. Specifics: - Add a mechanism for passing hints from the scheduler to cpufreq governors via their utilization update callbacks and use it to introduce "IOwait boosting" into the schedutil governor and intel_pstate that will make them boost performance if the enqueued task was previously waiting on I/O (Rafael Wysocki). - Fix a schedutil governor problem that causes it to overestimate utilization if SMT is in use (Steve Muckle). - Update defconfigs trying to use the schedutil governor as a module which is not possible any more (Javier Martinez Canillas). - Update the intel_pstate's pstate_sample tracepoint to take "IOwait boosting" into account (Srinivas Pandruvada). - Fix a problem in the cpufreq core causing it to mishandle the initialization of CPUs registered after the cpufreq driver (Viresh Kumar, Rafael Wysocki). - Make the cpufreq-dt driver support per-policy governor tunables, clean it up and update its Kconfig description (Viresh Kumar). - Add support for more ARM platforms to the cpufreq-dt driver (Chanwoo Choi, Dave Gerlach, Geert Uytterhoeven). - Make the cpufreq CPPC driver report frequencies in KHz to avoid user space compatiblility issues (Al Stone, Hoan Tran). - Clean up a few cpufreq drivers (st, kirkwood, SCPI) a bit (Colin Ian King, Markus Elfring). - Constify some local structures in the intel_pstate driver (Julia Lawall). - Add a Documentation/cpu-freq/ entry to MAINTAINERS (Jean Delvare). - Add support for PM domain removal to the generic power domains (genpd) framework, add new DT helper functions to it and make it always enable debugfs support if available (Jon Hunter, Tomeu Vizoso). - Clean up the generic power domains (genpd) framework and make it avoid measuring power-on and power-off latencies during system-wide PM transitions (Ulf Hansson). - Add support for the RockChip DFI controller and the rk3399 DMC to the devfreq framework (Lin Huang, Axel Lin, Arnd Bergmann). - Add COMPILE_TEST to the devfreq framework (Krzysztof Kozlowski, Stephen Rothwell). - Fix a minor issue in the exynos-ppmu devfreq driver and fix up devfreq Kconfig indentation style (Wei Yongjun, Jisheng Zhang). - Fix the system suspend interface to make suspend-to-idle work if platform suspend operations have not been registered (Sudeep Holla). - Make it possible to use hibernation with PAGE_POISONING_ZERO enabled (Anisse Astier). - Increas the default timeout of the system suspend/resume watchdog and make it depend on EXPERT (Chen Yu). - Make the operating performance points (OPP) framework avoid using OPPs that aren't supported by the platform and fix a build warning in it (Dave Gerlach, Arnd Bergmann). - Fix the ARM cpuidle driver's return value (Christophe Jaillet). - Make the SmartReflex AVS (Adaptive Voltage Scaling) driver use more common logging style (Joe Perches)" * tag 'pm-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (58 commits) PM / OPP: Don't support OPP if it provides supported-hw but platform does not cpufreq: st: add missing \n to end of dev_err message cpufreq: kirkwood: add missing \n to end of dev_err messages PM / Domains: Rename pm_genpd_sync_poweron|poweroff() PM / Domains: Don't measure latency of ->power_on|off() during system PM PM / Domains: Remove redundant system PM callbacks PM / Domains: Simplify detaching a device from its genpd PM / devfreq: rk3399_dmc: Remove explictly regulator_put call in .remove PM / devfreq: rockchip: add PM_DEVFREQ_EVENT dependency PM / OPP: avoid maybe-uninitialized warning PM / Domains: Allow holes in genpd_data.domains array cpufreq: CPPC: Avoid overflow when calculating desired_perf cpufreq: ti: Use generic platdev driver cpufreq: intel_pstate: Add io_boost trace partial revert of "PM / devfreq: Add COMPILE_TEST for build coverage" cpufreq: intel_pstate: Use IOWAIT flag in Atom algorithm cpufreq: schedutil: Add iowait boosting cpufreq / sched: SCHED_CPUFREQ_IOWAIT flag to indicate iowait condition PM / Domains: Add support for removing nested PM domains by provider PM / Domains: Add support for removing PM domains ...
2016-10-03Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Will Deacon: "It's a bit all over the place this time with no "killer feature" to speak of. Support for mismatched cache line sizes should help people seeing whacky JIT failures on some SoCs, and the big.LITTLE perf updates have been a long time coming, but a lot of the changes here are cleanups. We stray outside arch/arm64 in a few areas: the arch/arm/ arch_timer workaround is acked by Russell, the DT/OF bits are acked by Rob, the arch_timer clocksource changes acked by Marc, CPU hotplug by tglx and jump_label by Peter (all CC'd). Summary: - Support for execute-only page permissions - Support for hibernate and DEBUG_PAGEALLOC - Support for heterogeneous systems with mismatches cache line sizes - Errata workarounds (A53 843419 update and QorIQ A-008585 timer bug) - arm64 PMU perf updates, including cpumasks for heterogeneous systems - Set UTS_MACHINE for building rpm packages - Yet another head.S tidy-up - Some cleanups and refactoring, particularly in the NUMA code - Lots of random, non-critical fixes across the board" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (100 commits) arm64: tlbflush.h: add __tlbi() macro arm64: Kconfig: remove SMP dependence for NUMA arm64: Kconfig: select OF/ACPI_NUMA under NUMA config arm64: fix dump_backtrace/unwind_frame with NULL tsk arm/arm64: arch_timer: Use archdata to indicate vdso suitability arm64: arch_timer: Work around QorIQ Erratum A-008585 arm64: arch_timer: Add device tree binding for A-008585 erratum arm64: Correctly bounds check virt_addr_valid arm64: migrate exception table users off module.h and onto extable.h arm64: pmu: Hoist pmu platform device name arm64: pmu: Probe default hw/cache counters arm64: pmu: add fallback probe table MAINTAINERS: Update ARM PMU PROFILING AND DEBUGGING entry arm64: Improve kprobes test for atomic sequence arm64/kvm: use alternative auto-nop arm64: use alternative auto-nop arm64: alternative: add auto-nop infrastructure arm64: lse: convert lse alternatives NOP padding to use __nops arm64: barriers: introduce nops and __nops macros for NOP sequences arm64: sysreg: replace open-coded mrs_s/msr_s with {read,write}_sysreg_s ...
2016-10-02Linux 4.8Linus Torvalds
2016-10-02Merge branch 'fixes' of git://git.armlinux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Three relatively small fixes for ARM: - Roger noticed that dma_max_pfn() was calculating the upper limit wrongly, by adding the PFN offset of memory twice. - A fix from Robin to correct parsing of MPIDR values when the address size is larger than one BE32 unit. - A fix from Srinivas to ensure that we do not rely on the boot loader (or previous Linux kernel) setting the translation table base register a certain way in the decompressor, which can lead to crashes" * 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm: ARM: 8618/1: decompressor: reset ttbcr fields to use TTBR0 on ARMv7 ARM: 8617/1: dma: fix dma_max_pfn() ARM: 8616/1: dt: Respect property size when parsing CPUs
2016-10-02ARM: 8618/1: decompressor: reset ttbcr fields to use TTBR0 on ARMv7Srinivas Ramana
If the bootloader uses the long descriptor format and jumps to kernel decompressor code, TTBCR may not be in a right state. Before enabling the MMU, it is required to clear the TTBCR.PD0 field to use TTBR0 for translation table walks. The commit dbece45894d3a ("ARM: 7501/1: decompressor: reset ttbcr for VMSA ARMv7 cores") does the reset of TTBCR.N, but doesn't consider all the bits for the size of TTBCR.N. Clear TTBCR.PD0 field and reset all the three bits of TTBCR.N to indicate the use of TTBR0 and the correct base address width. Fixes: dbece45894d3 ("ARM: 7501/1: decompressor: reset ttbcr for VMSA ARMv7 cores") Acked-by: Robin Murphy <robin.murphy@arm.com> Signed-off-by: Srinivas Ramana <sramana@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2016-10-02Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Thomas Gleixner: "The last regression fixes for 4.8 final: - Two patches addressing the fallout of the CR4 optimizations which caused CR4-less machines to fail. - Fix the VDSO build on big endian machines - Take care of FPU initialization if no CPUID is available otherwise task struct size ends up being zero - Fix up context tracking in case load_gs_index fails" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/entry/64: Fix context tracking state warning when load_gs_index fails x86/boot: Initialize FPU and X86_FEATURE_ALWAYS even if we don't have CPUID x86/vdso: Fix building on big endian host x86/boot: Fix another __read_cr4() case on 486 x86/init: Fix cr4_init_shadow() on CR4-less machines
2016-10-02Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "Another round of fixes: - CM: Fix mips_cm_max_vp_width for non-MT kernels on MT systems - CPS: Avoid BUG() when offlining pre-r6 CPUs - DEC: Avoid gas warnings due to suspicious instruction scheduling by manually expanding assembler macros. - FTLB: Fix configuration by moving confiuguratoin after probing - FTLB: clear execution hazard after changing FTLB enable - Highmem: Fix detection of unsupported highmem with cache aliases - I6400: Don't touch FTLBP chicken bits - microMIPS: Fix BUILD_ROLLBACK_PROLOGUE - Malta: Fix IOCU disable switch read for MIPS64 - Octeon: Fix probing of devices attached to GPIO lines - uprobes: Misc small fixes" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: CM: Fix mips_cm_max_vp_width for non-MT kernels on MT systems MIPS: Fix detection of unsupported highmem with cache aliases MIPS: Malta: Fix IOCU disable switch read for MIPS64 MIPS: Fix BUILD_ROLLBACK_PROLOGUE for microMIPS MIPS: clear execution hazard after changing FTLB enable MIPS: Configure FTLB after probing TLB sizes from config4 MIPS: Stop setting I6400 FTLBP MIPS: DEC: Avoid la pseudo-instruction in delay slots MIPS: Octeon: mark GPIO controller node not populated after IRQ init. MIPS: uprobes: fix use of uninitialised variable MIPS: uprobes: remove incorrect set_orig_insn MIPS: fix uretprobe implementation MIPS: smp-cps: Avoid BUG() when offlining pre-r6 CPUs
2016-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: 1) Fix section mismatches in some builds, from Paul Gortmaker. 2) Need to count huge zero page mappings when doing TSB sizing, from Mike Kravetz. 3) Fix handing of cpu_possible_mask when nr_cpus module option is specified, from Atish Patra. 4) Don't allocate irq stacks until nr_irqs has been processed, also from Atish Patra. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix non-SMP build. sparc64: Fix irq stack bootmem allocation. sparc64: Fix cpu_possible_mask if nr_cpus is set sparc64 mm: Fix more TSB sizing issues sparc64: fix section mismatch in find_numa_latencies_for_group
2016-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix wrong TCP checksums on MTU probing when checksum offloading is disabled, from Douglas Caetano dos Santos. 2) Fix qdisc backlog updates in qfq and sfb schedulers, from Cong Wang. 3) Route lookup flow key protocol value is wrong in ip6gre_xmit_other(), fix from Lance Richardson. 4) Scheduling while atomic in multicast routing code of ipv4 and ipv6, fix from Nikolay Aleksandrov. 5) Fix packet alignment in fec driver, from Eric Nelson. 6) Fix perf regression in sctp due to struct layout and cache misses, from Xin Long. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: sctp: fix the issue sctp_diag uses lock_sock in rcu_read_lock sctp: change to check peer prsctp_capable when using prsctp polices sctp: remove prsctp_param from sctp_chunk sctp: move sent_count to the memory hole in sctp_chunk tg3: Avoid NULL pointer dereference in tg3_io_error_detected() act_ife: Fix false encoding act_ife: Fix external mac header on encode VSOCK: Don't dec ack backlog twice for rejected connections Revert "net: ethernet: bcmgenet: use phydev from struct net_device" net: fec: align IP header in hardware net: fec: remove QUIRK_HAS_RACC from i.mx27 net: fec: remove QUIRK_HAS_RACC from i.mx25 ipmr, ip6mr: fix scheduling while atomic and a deadlock with ipmr_get_route ip6_gre: fix flowi6_proto value in ip6gre_xmit_other() tcp: fix a compile error in DBGUNDO() tcp: fix wrong checksum calculation on MTU probing sch_sfb: keep backlog updated with qlen sch_qfq: keep backlog updated with qlen can: dev: fix deadlock reported after bus-off
2016-10-02Merge branches 'pm-devfreq' and 'pm-sleep'Rafael J. Wysocki
* pm-devfreq: PM / devfreq: rk3399_dmc: Remove explictly regulator_put call in .remove PM / devfreq: rockchip: add PM_DEVFREQ_EVENT dependency partial revert of "PM / devfreq: Add COMPILE_TEST for build coverage" PM / devfreq: rockchip: add devfreq driver for rk3399 dmc Documentation: bindings: add dt documentation for rk3399 dmc PM / devfreq: event: support rockchip dfi controller Documentation: bindings: add dt documentation for dfi controller PM / devfreq: event: remove duplicate devfreq_event_get_drvdata() PM / devfreq: fix Kconfig indent style PM / devfreq: Add COMPILE_TEST for build coverage PM / devfreq: exynos-ppmu: remove unneeded of_node_put() * pm-sleep: PM / Hibernate: allow hibernation with PAGE_POISONING_ZERO PM / sleep: enable suspend-to-idle even without registered suspend_ops PM / sleep: Increase default DPM watchdog timeout to 120
2016-10-02Merge branches 'pm-cpuidle', 'pm-opp' and 'pm-avs'Rafael J. Wysocki
* pm-cpuidle: ARM: cpuidle: Fix error return code * pm-opp: PM / OPP: Don't support OPP if it provides supported-hw but platform does not PM / OPP: avoid maybe-uninitialized warning * pm-avs: PM / AVS: SmartReflex: Neaten logging
2016-10-02Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: (24 commits) cpufreq: st: add missing \n to end of dev_err message cpufreq: kirkwood: add missing \n to end of dev_err messages cpufreq: CPPC: Avoid overflow when calculating desired_perf cpufreq: ti: Use generic platdev driver cpufreq: intel_pstate: Add io_boost trace cpufreq: intel_pstate: Use IOWAIT flag in Atom algorithm cpufreq: schedutil: Add iowait boosting cpufreq / sched: SCHED_CPUFREQ_IOWAIT flag to indicate iowait condition cpufreq: CPPC: Force reporting values in KHz to fix user space interface cpufreq: create link to policy only for registered CPUs intel_pstate: constify local structures cpufreq: dt: Support governor tunables per policy cpufreq: dt: Update kconfig description cpufreq: dt: Remove unused code MAINTAINERS: Add Documentation/cpu-freq/ cpufreq: dt: Add support for r8a7792 cpufreq / sched: ignore SMT when determining max cpu capacity cpufreq: Drop unnecessary check from cpufreq_policy_alloc() ARM: multi_v7_defconfig: Don't attempt to enable schedutil governor as module ARM: exynos_defconfig: Don't attempt to enable schedutil governor as module ...
2016-10-02Merge branch 'pm-cpufreq-sched' into pm-cpufreqRafael J. Wysocki
2016-10-02Merge branch 'pm-domains'Rafael J. Wysocki
* pm-domains: PM / Domains: Rename pm_genpd_sync_poweron|poweroff() PM / Domains: Don't measure latency of ->power_on|off() during system PM PM / Domains: Remove redundant system PM callbacks PM / Domains: Simplify detaching a device from its genpd PM / Domains: Allow holes in genpd_data.domains array PM / Domains: Add support for removing nested PM domains by provider PM / Domains: Add support for removing PM domains PM / Domains: Store the provider in the PM domain structure PM / Domains: Prepare for adding support to remove PM domains PM / Domains: Verify the PM domain is present when adding a provider PM / Domains: Don't expose xlate and provider helper functions PM / Domains: Don't expose generic_pm_domain structure to clients staging: board: Remove calls to of_genpd_get_from_provider() ARM: EXYNOS: Remove calls to of_genpd_get_from_provider() PM / Domains: Add new helper functions for device-tree PM / Domains: Always enable debugfs support if available
2016-10-02MIPS: CM: Fix mips_cm_max_vp_width for non-MT kernels on MT systemsPaul Burton
When discovering the number of VPEs per core, smp_num_siblings will be incorrect for kernels built without support for the MIPS MultiThreading (MT) ASE running on systems which implement said ASE. This leads to accesses to VPEs in secondary cores being performed incorrectly since mips_cm_vp_id calculates the wrong ID to write to the local "other" registers. Fix this by examining the number of VPEs in the core as reported by the CM. This patch presumes that the number of VPEs will be the same in each core of the system. As this path only applies to systems with CM version 2.5 or lower, and this property is true of all such known systems, this is likely to be fine but is described in a comment for good measure. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14338/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-10-02Merge branches 'acpi-button', 'acpi-battery' and 'acpi-doc'Rafael J. Wysocki
* acpi-button: ACPI / button: Add document for ACPI control method lid device restrictions ACPI / button: Fix an issue in button.lid_init_state=ignore mode * acpi-battery: ACPI / battery: Add sysfs representation after checking _BST * acpi-doc: ACPI / documentation: Use recommended name in GPIO property names
2016-10-02Merge branches 'acpi-wdat' and 'acpi-ec'Rafael J. Wysocki
* acpi-wdat: watchdog: wdat_wdt: Fix warning for using 0 as NULL watchdog: wdat_wdt: fix return value check in wdat_wdt_probe() platform/x86: intel_pmc_ipc: Do not create iTCO watchdog when WDAT table exists i2c: i801: Do not create iTCO watchdog when WDAT table exists mfd: lpc_ich: Do not create iTCO watchdog when WDAT table exists ACPI / watchdog: Add support for WDAT hardware watchdog * acpi-ec: ACPI / EC: Fix issues related to boot_ec ACPI / EC: Fix a gap that ECDT EC cannot handle EC events ACPI / EC: Fix a memory leakage issue in acpi_ec_add() ACPI / EC: Cleanup first_ec/boot_ec code ACPI / EC: Enable event freeze mode to improve event handling for suspend process ACPI / EC: Add PM operations to improve event handling for suspend process ACPI / EC: Add PM operations to improve event handling for resume process ACPI / EC: Fix an issue that SCI_EVT cannot be detected after event is enabled ACPI / EC: Add EC_FLAGS_QUERY_ENABLED to reveal a hidden logic ACPI / EC: Add PM operations for suspend/resume noirq stage
2016-10-02Merge branches 'acpi-x86', 'acpi-cppc' and 'acpi-soc'Rafael J. Wysocki
* acpi-x86: x86: ACPI: make variable names clearer in acpi_parse_madt_lapic_entries() x86: ACPI: remove extraneous white space after semicolon * acpi-cppc: ACPI / CPPC: Support PCC with interrupt flag ACPI / CPPC: Add prefix cppc to cpudata structure name ACPI / CPPC: Add support for functional fixed hardware address ACPI / CPPC: Don't return on CPPC probe failure ACPI / CPPC: Allow build with ACPI_CPU_FREQ_PSS config ACPI / CPPC: check for error bit in PCC status field ACPI / CPPC: move all PCC related information into pcc_data ACPI / CPPC: add sysfs support to compute delivered performance ACPI / CPPC: set a non-zero value for transition_latency ACPI / CPPC: support for batching CPPC requests ACPI / CPPC: acquire pcc_lock only while accessing PCC subspace ACPI / CPPC: restructure read/writes for efficient sys mapped reg ops mailbox: pcc: Support HW-Reduced Communication Subspace type 2 * acpi-soc: ACPI / APD: constify local structures ACPI / APD: Add device HID for Vulcan SPI controller
2016-10-02Merge branch 'acpi-bus'Rafael J. Wysocki
* acpi-bus: ACPI / bus: Adjust ACPI subsystem initialization for new table loading mode ACPI / bus: Make acpi_get_first_physical_node() public
2016-10-02Merge branches 'acpi-sysfs', 'acpi-pci' and 'acpi-tables'Rafael J. Wysocki
* acpi-sysfs: ACPI / sysfs: Update sysfs signature handling code ACPI / sysfs: Fix an issue for LoadTable opcode ACPI / sysfs: Use new GPE masking mechanism in GPE interface * acpi-pci: ACPI / platform: Pay attention to parent device's resources PCI: Add pci_find_resource() ACPI / PCI: fix GIC irq model default PCI IRQ polarity * acpi-tables: ACPI / tables: Remove duplicated include from tables.c ACPI / tables: do not report the number of entries ignored by acpi_parse_entries() ACPI / tables: fix acpi_parse_entries_array() so it traverses all subtables ACPI / tables: fix incorrect counts returned by acpi_parse_entries_array()
2016-10-02Merge branch 'acpica'Rafael J. Wysocki
* acpica: (45 commits) ACPICA: Parser: Fix a regression in LoadTable support ACPICA: Tables: Fix "UNLOAD" code path lock issues ACPICA: Tables: Fix a regression in acpi_tb_find_table() ACPICA: Update version to 20160831 ACPICA: Tables: Tune table mutex to be a leaf lock ACPICA: Dispatcher: Fix a mutex issue for method auto serialization ACPICA: Namespace: Fix dynamic table loading issues ACPICA: Namespace: Add acpi_ns_get_node_unlocked() ACPICA: Interpreter: Fix MLC issues by switching to new term_list grammar for table loading ACPICA: Update return value for intenal _OSI method ACPICA: Tables: Override all 64-bit GAS fields when acpi_gbl_use32_bit_fadt_addresses is TRUE ACPICA: Tables: Add new table events indicating table installation/uninstallation ACPICA: Tables: Remove wrong table event macros ACPICA: Tables: Remove acpi_tb_install_fixed_table() ACPICA: Add a couple of casts to uthex.c ACPICA: Cleanup for all string-to-integer conversions ACPICA: Debugger: Add subcommand for predefined name execution ACPICA: Update version to 20160729 ACPICA: OSL: Fix a regression that old GCC requires a workaround for strchr() ACPICA: OSL: Cleanup the inclusion order of the compiler-specific headers ...
2016-10-02Merge branch 'device-properties'Rafael J. Wysocki
* device-properties: serial: 8250_dw: Add quirk for APM X-Gene SoC ACPI / LPSS: Provide build-in properties of the UART ACPI / APD: Provide build-in properties of the UART driver core: Don't leak secondary fwnode on device removal
2016-10-01Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fix from James Bottomley: "One final fix before 4.8. There was a memory leak triggered by turning scsi mq off due to the fact that we assume on host release that the already running hosts weren't mq based because that's the state of the global flag (even though they were). Fix it by tracking this on a per host host basis" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: Avoid that toggling use_blk_mq triggers a memory leak
2016-09-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input fix from Dmitry Torokhov: "One small change to make joydev (which is used by older games) to bind to devices that export Z axis but not X or Y (such as TRC rudder)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: joydev - recognize devices with Z axis as joysticks
2016-09-30Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more fixes from Andrew Morton: "Three fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: include/linux/property.h: fix typo/compile error ocfs2: fix deadlock on mmapped page in ocfs2_write_begin_nolock() mm: workingset: fix crash in shadow node shrinker caused by replace_page_cache_page()
2016-09-30include/linux/property.h: fix typo/compile errorJohn Youn
This fixes commit d76eebfa175e ("include/linux/property.h: fix build issues with gcc-4.4.4"). With that commit we get the following compile error when using the PROPERTY_ENTRY_INTEGER_ARRAY macro. include/linux/property.h:201:39: error: `u32_data' undeclared (first use in this function) PROPERTY_ENTRY_INTEGER_ARRAY(_name_, u32, _val_) ^ include/linux/property.h:193:17: note: in definition of macro `PROPERTY_ENTRY_INTEGER_ARRAY' { .pointer = { _type_##_data = _val_ } }, \ ^ This needs a '.' to reference the union member. It seems this was just overlooked here since it is done correctly in similar constructs in other parts of the original commit. This fix is in preparation of upcoming commits that will use this macro. Fixes: commit d76eebfa175e ("include/linux/property.h: fix build issues with gcc-4.4.4") Link: http://lkml.kernel.org/r/2de3b929290d88a723ed829a3e3cbd02044714df.1475114627.git.johnyoun@synopsys.com Signed-off-by: John Youn <johnyoun@synopsys.com> Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-30ocfs2: fix deadlock on mmapped page in ocfs2_write_begin_nolock()Eric Ren
The testcase "mmaptruncate" of ocfs2-test deadlocks occasionally. In this testcase, we create a 2*CLUSTER_SIZE file and mmap() on it; there are 2 process repeatedly performing the following operations respectively: one is doing memset(mmaped_addr + 2*CLUSTER_SIZE - 1, 'a', 1), while the another is playing ftruncate(fd, 2*CLUSTER_SIZE) and then ftruncate(fd, CLUSTER_SIZE) again and again. This is the backtrace when the deadlock happens: __wait_on_bit_lock+0x50/0xa0 __lock_page+0xb7/0xc0 ocfs2_write_begin_nolock+0x163f/0x1790 [ocfs2] ocfs2_page_mkwrite+0x1c7/0x2a0 [ocfs2] do_page_mkwrite+0x66/0xc0 handle_mm_fault+0x685/0x1350 __do_page_fault+0x1d8/0x4d0 trace_do_page_fault+0x37/0xf0 do_async_page_fault+0x19/0x70 async_page_fault+0x28/0x30 In ocfs2_write_begin_nolock(), we first grab the pages and then allocate disk space for this write; ocfs2_try_to_free_truncate_log() will be called if -ENOSPC is returned; if we're lucky to get enough clusters, which is usually the case, we start over again. But in ocfs2_free_write_ctxt() the target page isn't unlocked, so we will deadlock when trying to grab the target page again. Also, -ENOMEM might be returned in ocfs2_grab_pages_for_write(). Another deadlock will happen in __do_page_mkwrite() if ocfs2_page_mkwrite() returns non-VM_FAULT_LOCKED, and along with a locked target page. These two errors fail on the same path, so fix them by unlocking the target page manually before ocfs2_free_write_ctxt(). Jan Kara helps me clear out the JBD2 part, and suggest the hint for root cause. Changes since v1: 1. Also put ENOMEM error case into consideration. Link: http://lkml.kernel.org/r/1474173902-32075-1-git-send-email-zren@suse.com Signed-off-by: Eric Ren <zren@suse.com> Reviewed-by: He Gang <ghe@suse.com> Acked-by: Joseph Qi <joseph.qi@huawei.com> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Cc: Junxiao Bi <junxiao.bi@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-30mm: workingset: fix crash in shadow node shrinker caused by ↵Johannes Weiner
replace_page_cache_page() Antonio reports the following crash when using fuse under memory pressure: kernel BUG at /build/linux-a2WvEb/linux-4.4.0/mm/workingset.c:346! invalid opcode: 0000 [#1] SMP Modules linked in: all of them CPU: 2 PID: 63 Comm: kswapd0 Not tainted 4.4.0-36-generic #55-Ubuntu Hardware name: System manufacturer System Product Name/P8H67-M PRO, BIOS 3904 04/27/2013 task: ffff88040cae6040 ti: ffff880407488000 task.ti: ffff880407488000 RIP: shadow_lru_isolate+0x181/0x190 Call Trace: __list_lru_walk_one.isra.3+0x8f/0x130 list_lru_walk_one+0x23/0x30 scan_shadow_nodes+0x34/0x50 shrink_slab.part.40+0x1ed/0x3d0 shrink_zone+0x2ca/0x2e0 kswapd+0x51e/0x990 kthread+0xd8/0xf0 ret_from_fork+0x3f/0x70 which corresponds to the following sanity check in the shadow node tracking: BUG_ON(node->count & RADIX_TREE_COUNT_MASK); The workingset code tracks radix tree nodes that exclusively contain shadow entries of evicted pages in them, and this (somewhat obscure) line checks whether there are real pages left that would interfere with reclaim of the radix tree node under memory pressure. While discussing ways how fuse might sneak pages into the radix tree past the workingset code, Miklos pointed to replace_page_cache_page(), and indeed there is a problem there: it properly accounts for the old page being removed - __delete_from_page_cache() does that - but then does a raw raw radix_tree_insert(), not accounting for the replacement page. Eventually the page count bits in node->count underflow while leaving the node incorrectly linked to the shadow node LRU. To address this, make sure replace_page_cache_page() uses the tracked page insertion code, page_cache_tree_insert(). This fixes the page accounting and makes sure page-containing nodes are properly unlinked from the shadow node LRU again. Also, make the sanity checks a bit less obscure by using the helpers for checking the number of pages and shadows in a radix tree node. Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check") Link: http://lkml.kernel.org/r/20160919155822.29498-1-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Antonio SJ Musumeci <trapexit@spawn.link> Debugged-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <stable@vger.kernel.org> [3.15+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
