These are OCTEON specific instructions.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-mips@linux-mips.org
To: wim@iguana.be
Patchwork: https://patchwork.linux-mips.org/patch/1496/
To: wim@iguana.be
Patchwork: https://patchwork.linux-mips.org/patch/1495/
Power throttling make deterministic delay loops impossible.
Re-implement delays using the cycle counter. This also allows us to
get rid of the code that calculates loops per jiffy.
Patchwork: https://patchwork.linux-mips.org/patch/1317/
Add support for the qi_lb60 (a.k.a QI Ben NanoNote) clamshell device.
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1472/
Add support for the battery voltage measurement part of the JZ4740 ADC unit.
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1416/
Add support for reading the ADCIN pin of the ADC unit on JZ4740 SoCs.
Cc: lm-sensors@lm-sensors.org
Acked-by: Jean Delvare <khali@linux-fr.org>
Patchwork: https://patchwork.linux-mips.org/patch/1425/
Add OHCI glue code for JZ4740 SoCs OHCI module.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: linux-usb@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/1411/
Acked-by: Matt Fleming <matt@console-pimps.org>
Cc: Matt Fleming <matt@console-pimps.org>
Cc: linux-mmc@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/1463/
Patchwork: https://patchwork.linux-mips.org/patch/1523/
Add support for the NAND controller on JZ4740 SoCs.
Cc: linux-mtd@lists.infradead.org
Patchwork: https://patchwork.linux-mips.org/patch/1470/
Add support for the LCD controller on JZ4740 SoCs.
Cc: linux-fbdev@vger.kernel.org
Add support for the RTC unit on JZ4740 SoCs.
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: rtc-linux@googlegroups.com
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>,
Patchwork: https://patchwork.linux-mips.org/patch/1424/
Add the Kbuild files for the JZ4740 architecture and adds JZ4740 support
to the MIPS Kbuild files.
Patchwork: https://patchwork.linux-mips.org/patch/1406/
Add platform devices for all the JZ4740 platform drivers.
Patchwork: https://patchwork.linux-mips.org/patch/1469/
Add support for initializing arcs_cmdline on JZ4740 based machines and
provides a prom_putchar implementation.
Patchwork: https://patchwork.linux-mips.org/patch/1404/
The JZ4740 UART interface is almost 16550 compatible.
The UART module needs to be enabled by setting a bit in the FCR register
and it has support for receive timeout interrupts. Instead of adding yet
another machine specific quirk to the 8250 serial driver we provide a
serial_out implementation which sets the required additional flags.
Patchwork: https://patchwork.linux-mips.org/patch/1403/
Add support for the PWM part of the timer unit on a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1468/
Add support for DMA transfers on JZ4740 SoCs.
Patchwork: https://patchwork.linux-mips.org/patch/1401/
Add gpiolib support for JZ4740 SoCs.
Patchwork: https://patchwork.linux-mips.org/patch/1467/
Add plat_mem_setup and get_system_type for JZ4740 SoCs.
Patchwork: https://patchwork.linux-mips.org/patch/1399/
Add support for suspend/resume and poweroff/reboot on a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1398/
Add clocksource and clockevent support for the timer/counter unit on
JZ4740 SoCs.
Patchwork: https://patchwork.linux-mips.org/patch/1397/
Add support for the timer/counter unit on a JZ4740 SoC. This code is used
as a common base for the JZ4740 clocksource/clockevent implementation and
PWM support.
Patchwork: https://patchwork.linux-mips.org/patch/1396/
Add support for IRQ handling on a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1465/
Add support for managing the clocks found on JZ4740 SoC through the
Linux clock API.
Patchwork: https://patchwork.linux-mips.org/patch/1466/
Adds a new cpu type for the JZ4740 to the Linux MIPS architecture code.
It also adds the iomem addresses for the different components found on
a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1464/
* Rename camel-case InitTLBStart_addr to octeon_bootloader_entry_addr.
* Convert calls to cvmx_read64_uint32(), to simple pointer
dereferences.
* Set proper ebase.
* Don't confuse coreid and cpu numbers.
* Try to maintain consistent bootloader coremask.
* Update the signature and boot_init_vector of supported bootloaders.
Patchwork: https://patchwork.linux-mips.org/patch/1491/
Patchwork: https://patchwork.linux-mips.org/patch/1490/
Also number offline CPUs that could potentially be brought on-line
later.
Patchwork: https://patchwork.linux-mips.org/patch/1489/
The use of handle_percpu_irq() is not really what we want for MSI, use
handle_simple_irq() instead. This is probably the prototypical case
for using handle_simple_irq(), because all the MSIs are dispatched from
the root interrupt service routine.
Also since the base IRQ is not shared, don't pass IRQF_SHARED.
Patchwork: https://patchwork.linux-mips.org/patch/1488/
MSI IRQ numbers are allocated dynamically, so there is no reason to
have all these static definitions.
Patchwork: https://patchwork.linux-mips.org/patch/1487/
The original version went behind the back of everything, leaving
things in an inconsistent state.
Now we use the irq_set_affinity() to do the work for us. This has the
advantage that the IRQ core's view of the affinity stays consistent.
Patchwork: https://patchwork.linux-mips.org/patch/1486/
The main change is to change most of the IRQs from handle_percpu_irq
to handle_fasteoi_irq. This necessitates extracting all the .ack code
to common functions that are not exposed to the irq core.
The affinity code now acts more sanely, by doing round-robin
distribution instead of broadcasting.
Because of the change to handle_fasteoi_irq and affinity, some of the
IRQs had to be split into separate groups with their own struct
irq_chip to prevent undefined operations on specific IRQ lines.
Patchwork: https://patchwork.linux-mips.org/patch/1485/
Put all the MSI code in one place (msi-octeon.c). This simplifies
octeon-irq.c and gets rid of some ugly #ifdefs
Patchwork: https://patchwork.linux-mips.org/patch/1484/
Add basic support for the General Purpose Router (GPR) board from
Trapeze ITS.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Patchwork: https://patchwork.linux-mips.org/patch/1460/
au1000_eth uses firmware calls to get a valid MAC address, and changes
it depending on platform device id. This patch moves this logic out of
the driver into the platform device registration part, where boards with
supported chips can use whatever firmware interface they need; the default
implementation maintains compatibility with existing, YAMON-based firmware.
Tested-by: Wolfgang Grandegger <wg@denx.de>
Acked-by: Florian Fainelli <florian@openwrt.org>
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
To: Linux-MIPS <linux-mips@linux-mips.org>
Cc: netdev@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/1481/
Remove the SERIAL_8250_AU1X00 config symbol. Instead, use the MIPS_ALCHEMY
one which is always defined when building an Au1x00-based platform.
Cc: Linux-serial <linux-serial@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/1461/
This one depends on a previous patch (which removes SOC_AU1X00 and changes
MACH_ALCHEMY) to apply cleanly (and then actually work), so I'd love for
this to go in via the mips tree.
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done
by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY.
Add support for the external T-cache interface. Allow for platform
independent size probing from 512KB to 8MB in powers of two.
Signed-off-by: Ricardo Mendoza <ricmm@gentoo.org>
Patchwork: https://patchwork.linux-mips.org/patch/1477/
Small cleanup of the cache code to get rid of inline asm, in preparation
to give tertiary cache support.
Patchwork: https://patchwork.linux-mips.org/patch/1476/
The commit "MIPS: Tracing: Cleanup the arguments passing of
prepare_ftrace_return" has moved the "jal prepare_ftrace_return"
instruction after the handling of the 3rd argument but forgot to remove
the superfluous space before the related instructions.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1475/
Based somewhat on the PPC implementation.
32-bit processes have the heap randomized in an 8MB space, 256MB for
64-bit processes.
Patchwork: https://patchwork.linux-mips.org/patch/1479/
Fairly straight forward: For 32-bit address spaces randomize within a
16MB space, for 64-bit within a 256MB space.
Patchwork: https://patchwork.linux-mips.org/patch/1480/
Add some comments about mtx1_pci_idsel() and remove a dead block of old code.
Signed-off-by: Bruno Randolf <br1@einfach.org>
To: manuel.lauss@googlemail.com
Cc: florian@openwrt.org
Patchwork: https://patchwork.linux-mips.org/patch/1449/
* Remove unnecessary 'if (int_status & (1 <<10))' statement
* s/if (foo != 0)/if (foo)/
* Remove unused 'inst_status &= ~(1 << i);' line
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
To: wuzhangjin@gmail.com
CC: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1433/
Acked-by: Wu Zhangjin <wuzhangjin@gmail.com>
Don't duplicate worthless lines.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi.px@renesas.com>
Patchwork: https://patchwork.linux-mips.org/patch/1390/
Patchwork: https://patchwork.linux-mips.org/patch/1389/
Although all EMMAxxx SoCs can support IP2 and IP3 hardware interrupts,
current EMMA2RH plat_irq_dispatch() supports IP2 only. We can make it
configurable in the future, but for the time being, would like to make
things explicitly allcated to IP2 in accordance with plat_irq_dispatch().
Patchwork: https://patchwork.linux-mips.org/patch/1388/
For historical reasons, we used to put MIPS CPU IRQs behind SoC-specific
IRQs in the queue, and have been using CPU_IRQ_BASE as MIPS_CPU_IRQ_BASE.
In recent years, however, we've brought it back to normal order, and now
CPU_IRQ_BASE just redefines the generic MIPS_CPU_IRQ_BASE.
At the same time, NUM_CPU_IRQ is also removed as useless.
Patchwork: https://patchwork.linux-mips.org/patch/1387/
OCTEON implements __builtin_popcount with a single instruction, so lets use it.
Cc: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/1431/
Some MIPS ISA processor varients can do hweight operations
efficiently.
Split arch_hweight.h into a seperate file, and implement the
operations with __builtin_popcount{,ll} if supported.
Patchwork: https://patchwork.linux-mips.org/patch/1430/
