* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86:
x86: intel_cacheinfo.c: cpu cache info entry for Intel Tolapai
x86: fix die() to not be preemptible
* 'for-linus' of git://oss.sgi.com:8090/xfs/xfs-2.6:
[XFS] Initialise current offset in xfs_file_readdir correctly
[XFS] Fix mknod regression
After reading the directory contents into the temporary buffer, we grab
each dirent and pass it to filldir witht eh current offset of the dirent.
The current offset was not being set for the first dirent in the temporary
buffer, which coul dresult in bad offsets being set in the f_pos field
result in looping and duplicate entries being returned from readdir.
SGI-PV: 974905
SGI-Modid: xfs-linux-melb:xfs-kern:30282a
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
This was broken by my '[XFS] simplify xfs_create/mknod/symlink prototype',
which assigned the re-shuffled ondisk dev_t back to the rdev variable in
xfs_vn_mknod. Because of that i_rdev is set to the ondisk dev_t instead of
the linux dev_t later down the function.
Fortunately the fix for it is trivial: we can just remove the assignment
because xfs_revalidate_inode has done the proper job before unlocking the
inode.
SGI-PV: 974873
SGI-Modid: xfs-linux-melb:xfs-kern:30273a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
This patch adds a cpu cache info entry for the Intel Tolapai cpu.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
Andrew "Eagle Eye" Morton noticed that we use raw_local_save_flags()
instead of raw_local_irq_save(flags) in die(). This allows the
preemption of oopsing contexts - which is highly undesirable. It also
causes CONFIG_DEBUG_PREEMPT to complain, as reported by Miles Lane.
this bug was introduced via:
commit 39743c9ef717fd4f2b5583f010115c5f2482b8ae
Author: Andi Kleen <ak@suse.de>
Date: Fri Oct 19 20:35:03 2007 +0200
x86: use raw locks during oopses
- spin_lock_irqsave(&die.lock, flags);
+ __raw_spin_lock(&die.lock);
+ raw_local_save_flags(flags);
that is not a correct open-coding of spin_lock_irqsave(): both the
ordering is wrong (irqs should be disabled _first_), and the wrong
flags-saving API was used.
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched:
debug: add end-of-oops marker
sched: rt: account the cpu time during the tick
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm crypt: use bio_add_page
dm: merge max_hw_sector
dm: trigger change uevent on rename
dm crypt: fix write endio
dm mpath: hp requires scsi
dm: table detect io beyond device
Fix possible max_phys_segments violation in cloned dm-crypt bio.
In write operation dm-crypt needs to allocate new bio request
and run crypto operation on this clone. Cloned request has always
the same size, but number of physical segments can be increased
and violate max_phys_segments restriction.
This can lead to data corruption and serious hardware malfunction.
This was observed when using XFS over dm-crypt and at least
two HBA controller drivers (arcmsr, cciss) recently.
Fix it by using bio_add_page() call (which tests for other
restrictions too) instead of constructing own biovec.
All versions of dm-crypt are affected by this bug.
Cc: stable@kernel.org
Cc: dm-crypt@saout.de
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Make sure dm honours max_hw_sectors of underlying devices
We still have no firm testing evidence in support of this patch but
believe it may help to resolve some bug reports. - agk
Signed-off-by: Neil Brown <neilb@suse.de>
Insert a missing KOBJ_CHANGE notification when a device is renamed.
Cc: Scott James Remnant <scott@ubuntu.com>
Fix BIO_UPTODATE test for write io.
With CONFIG_SCSI=n __scsi_print_sense() is never linked in.
drivers/built-in.o: In function `hp_sw_end_io':
dm-mpath-hp-sw.c:(.text+0x914f8): undefined reference to `__scsi_print_sense'
Caught with a randconfig on current git.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
This patch fixes a panic on shrinking a DM device if there is
outstanding I/O to the part of the device that is being removed.
(Normally this doesn't happen - a filesystem would be resized first,
for example.)
The bug is that __clone_and_map() assumes dm_table_find_target()
always returns a valid pointer. It may fail if a bio arrives from the
block layer but its target sector is no longer included in the DM
btree.
This patch appends an empty entry to table->targets[] which will
be returned by a lookup beyond the end of the device.
After calling dm_table_find_target(), __clone_and_map() and target_message()
check for this condition using
dm_target_is_valid().
Sample test script to trigger oops:
The problem was introduced by commit "mm: variable length argument
support" (b6a2fea39318e43fee84fa7b0b90d68bed92d2ba)
as it didn't update fs/binfmt_aout.c like other binfmt's.
I noticed that on alpha when accidentally launched old OSF/1
Acrobat Reader binary. Obviously, other architectures are affected
as well.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ollie Wild <aaw@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Adrian Bunk <bunk@stusta.de>
Right now it's nearly impossible for parsers that collect kernel crashes
from logs or emails (such as www.kerneloops.org) to detect the
end-of-oops condition. In addition, it's not currently possible to
detect whether or not 2 oopses that look alike are actually the same
oops reported twice, or are truly two unique oopses.
This patch adds an end-of-oops marker, and makes the end marker include
a very simple 64-bit random ID to be able to detect duplicate reports.
Normally, this ID is calculated as a late_initcall() (in the hope that
at that time there is enough entropy to get a unique enough ID); however
for early oopses the oops_exit() function needs to generate the ID on
the fly.
We do this all at the _end_ of an oops printout, so this does not impact
our ability to get the most important portions of a crash out to the
console first.
[ Sidenote: the already existing oopses-since-bootup counter we print
during crashes serves as the differentiator between multiple oopses
that trigger during the same bootup. ]
Tested on 32-bit and 64-bit x86. Artificially injected very early
crashes as well, as expected they result in this constant ID after
multiple bootups:
---[ end trace ca143223eefdc828 ]---
because the random pools are still all zero. But it all still works
fine and causes no additional problems (which is the main goal of
instrumentation code).
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Realtime tasks would not account their runtime during ticks. Which would lead
to:
struct sched_param param = { .sched_priority = 10 };
pthread_setschedparam(pthread_self(), SCHED_FIFO, ¶m);
while (1) ;
Not showing up in top.
when called by setup_arch) after smp_store_cpu_info() had set it to the
correct value.
The error shows up in 'cat /proc/cpuinfo' will all cpus = 0.
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Suresh B Siddha <suresh.b.siddha@intel.com>
CONFIG_HOTPLUG_CPU=y:
WARNING: vmlinux.o(.text+0xfa52): Section mismatch: reference to .init.data:disable_pse (between 'identify_cpu' and 'identify_secondary_cpu')
[ akpm@linux-foundation.org: initializer fix. ]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
WARNING: vmlinux.o(.text+0x1199a): Section mismatch: reference to .init.text.5:select_idle_routine (between 'init_intel' and 'init_nexgen')
WARNING: vmlinux.o(.text+0x22c60): Section mismatch: reference to .init.data:cpu_idle_tasks (between 'do_boot_cpu' and 'do_warm_boot_cpu')
WARNING: vmlinux.o(.text+0x22c99): Section mismatch: reference to .init.data:cpu_idle_tasks (between 'do_boot_cpu' and 'do_warm_boot_cpu')
WARNING: vmlinux.o(.text+0x2359b): Section mismatch: reference to .init.data:smp_b_stepping (between 'smp_store_cpu_info' and 'cpu_exit_clear')
WARNING: vmlinux.o(.text+0x235a0): Section mismatch: reference to .init.data:smp_b_stepping (between 'smp_store_cpu_info' and 'cpu_exit_clear')
WARNING: vmlinux.o(.text+0x2390d): Section mismatch: reference to .init.text.5:setup_local_APIC (between 'start_secondary' and 'check_tsc_warp')
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Adjust CMCI mask on CPU hotplug
[IA64] make flush_tlb_kernel_range() an inline function
[IA64] Guard elfcorehdr_addr with #if CONFIG_PROC_FS
[IA64] Fix Altix BTE error return status
[IA64] Remove assembler warnings on head.S
[IA64] Remove compiler warinings about uninitialized variable in irq_ia64.c
[IA64] set_thread_area fails in IA32 chroot
[IA64] print kernel release in OOPS to make kerneloops.org happy
[IA64] Two trivial spelling fixes
[IA64] Avoid unnecessary TLB flushes when allocating memory
[IA64] ia32 nopage
[IA64] signal: remove redundant code in setup_sigcontext()
IA64: Slim down __clear_bit_unlock
Bug #9261
Signed-off-by: Alan Cox <alan@redhat.com>
The dev_id arg passed to free_irq() must match that passed to
request_irq().
Fixes this PS3 error message:
Trying to free already-free IRQ 44
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
ps3fb: Update for firmware 2.10
As of PS3 firmware version 2.10, the GPU command buffer size must be at least 2
MiB large. Since we use only a small part of the GPU command buffer and don't
want to waste precious XDR memory, move the GPU command buffer back to the
start of the XDR memory reserved for ps3fb and let the unused part overlap with
the actual frame buffer.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] initio: bugfix for accessors patch
[SCSI] st: fix kernel BUG at include/linux/scatterlist.h:59!
[SCSI] initio: fix conflict when loading driver
[SCSI] sym53c8xx: fix "irq X: nobody cared" regression
[SCSI] dpt_i2o: driver is only 32 bit so don't set 64 bit DMA mask
[SCSI] sym53c8xx: fix free_irq() regression
Krzysztof Oledzki noticed a dirty page accounting leak on some of his
machines, causing the machine to eventually lock up when the kernel
decided that there was too much dirty data, but nobody could actually
write anything out to fix it.
The culprit turns out to be filesystems (cough ext3 with data=journal
cough) that re-dirty the page when the "->invalidatepage()" callback is
called.
Fix it up by doing a final dirty page accounting check when we actually
remove the page from the page cache.
This fixes bugzilla entry 9182:
http://bugzilla.kernel.org/show_bug.cgi?id=9182
Tested-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Krzysztof Oledzki <olel@ans.pl>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Currently CMCI mask of hot-added CPU is always disabled after CPU hotplug.
We should adjust this mask depending on CMC polling state.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
This fixes an unused variable warning in mm/vmalloc.c.
Tony: also fix resulting fallout in uncached.c with a
typo in args to flush_tlb_kernel_range().
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Access to elfcorehdr_addr needs to be guarded by #if CONFIG_PROC_FS
as well as the existing #if guards.
Fixes the following build problem:
arch/ia64/hp/common/built-in.o: In function
`sba_init':arch/ia64/hp/common/sba_iommu.c:2043: undefined reference to `elfcorehdr_addr'
Signed-off-by: Simon Horman <horms@verge.net.au>
The Altix shub2 BTE error detail bits are in a different location
than on shub1. The current code does not take this into account
resulting in all shub2 BTE failures mapping to "unknown".
This patch reads the error detail bits from the proper location,
so the correct BTE failure reason is returned for both shub1
and shub2.
Signed-off-by: Russ Anderson <rja@sgi.com>
This patch removes the following assembler warning messages.
AS arch/ia64/kernel/head.o
arch/ia64/kernel/head.S: Assembler messages:
arch/ia64/kernel/head.S:1179: Warning: Use of 'ld8' violates RAW dependency 'CR[PTA]' (data)
arch/ia64/kernel/head.S:1179: Warning: Only the first path encountering the conflict is reported
arch/ia64/kernel/head.S:1178: Warning: This is the location of the conflicting usage
arch/ia64/kernel/head.S:1180: Warning: Use of 'ld8' violates RAW dependency 'CR[PTA]' (data)
arch/ia64/kernel/head.S:1180: Warning: Only the first path encountering the conflict is reported
arch/ia64/kernel/head.S:1213: Warning: Use of 'ldf.fill.nta' violates RAW dependency 'CR[PTA]' (data)
arch/ia64/kernel/head.S:1213: Warning: Only the first path encountering the conflict is reported
This patch removes the following compiler warning messages.
CC arch/ia64/kernel/irq_ia64.o
arch/ia64/kernel/irq_ia64.c: In function 'create_irq':
arch/ia64/kernel/irq_ia64.c:343: warning: 'domain.bits[0u]' may be used uninitialized in this function
arch/ia64/kernel/irq_ia64.c: In function 'assign_irq_vector':
arch/ia64/kernel/irq_ia64.c:203: warning: 'domain.bits[0u]' may be used uninitialized in this function
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
I tried to upgrade an IA32 chroot on my IA64 to a new glibc with TLS.
It kept dying because set_thread_area was returning -ESRCH
(bugs.debian.org/451939).
I instrumented arch/ia64/ia32/sys_ia32.c:get_free_idx() and ended up
seeing output like
[pid] idx desc->a desc->b
[2710] 0 -> c6b0ffff 40dff31b
[2710] 1 -> 0 0
[2710] 2 -> 0 0
[2710] 1 -> c6b0ffff 40dff31b
[2710] 2 -> 0 0
[2711] 0 -> c6b0ffff 40dff31b
[2711] 1 -> c6b0ffff 40dff31b
[2711] 2 -> 48c0ffff 40dff317
which suggested to me that TLS pointers were surviving exec() calls,
leading to GDT pointers filling up and the eventual failure of
get_free_idx().
I think the solution is flushing the tls array on exec.
Signed-Off-By: Ian Wienand <ianw@gelato.unsw.edu.au>
The ia64 oops message doesn't include the kernel version, which
makes it hard to automatically categorize oops messages scraped
from mailing lists and bug databases.
s/addres/address/
s/performanc/performance/
Improve performance of memory allocations on ia64 by avoiding a global TLB
purge to purge a single page from the file cache. This happens whenever we
evict a page from the buffer cache to make room for some other allocation.
Test case: Run 'find /usr -type f | xargs cat > /dev/null' in the
background to fill the buffer cache, then run something that uses memory,
e.g. 'gmake -j50 install'. Instrumentation showed that the number of
global TLB purges went from a few millions down to about 170 over a 12
hours run of the above.
The performance impact is particularly noticeable under virtualization,
because a virtual TLB is generally both larger and slower to purge than
a physical one.
Signed-off-by: Christophe de Dinechin <ddd@hp.com>
Convert ia64's ia32 support from nopage to fault.
Signed-off-by: Nick Piggin <npiggin@suse.de>
This patch removes some redundant code in the function setup_sigcontext().
The registers ar.ccv,b7,r14,ar.csd,ar.ssd,r2-r3 and r16-r31 are not
restored in restore_sigcontext() when (flags & IA64_SC_FLAG_IN_SYSCALL) is
true. So we don't need to zero those variables in setup_sigcontext().
Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com>
__clear_bit_unlock does not need to perform atomic operations on the
variable. Avoid a cmpxchg and simply do a store with release semantics.
Add a barrier to be safe that the compiler does not do funky things.
Tony: Use intrinsic rather than inline assembler
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Acked-by: Nick Piggin <nickpiggin@yahoo.com.au>
patch: [SCSI] initio: convert to use the data buffer accessors had a
small but fatal bug in that it didn't increment the pointer into the
initio scatterlist descriptors as it looped over the block generated
ones. Fixed here.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
This is caused by a missing scatterlist initialisation (it only shows
up when sg list handling debugging is turned on).
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Kai Makisara <Kai.Makisara@kolumbus.fi>
> I have a scanner connected to a Initio INI-950 SCSI card and I recently
> upgraded from SuSE 10.2 to 10.3. The new kernel doesn't see any of my
> devices. I get the following in /var/log/messages:
> ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 17 (level, low) -> IRQ 16
> initio: I/O port range 0x0 is busy.
> ACPI: PCI interrupt for device 0000:00:0a.0 disabled
Humm not a collision - thats a bug in the driver updating. Looks like the
changes I made and combined with Christoph's lost a line somewhere when I
was merging it all.
The patch described by the following excerpt from ChangeLog-2.6.24-rc1
eventually causes a "irq X: nobody cared" error after a while:
commit 99c9e0a1d6cfe1ba1169a7a81435ee85bc00e4a1
Author: Matthew Wilcox <matthew@wil.cx>
Date: Fri Oct 5 15:55:12 2007 -0400
[SCSI] sym53c8xx: Make interrupt handler capable of returning IRQ_NONE
After this happens, the kernel disables the IRQ, causing the SCSI card
to stop working until the next reboot. The problem is caused by the
interrupt handler returning IRQ_NONE instead of IRQ_HANDLED after
handling an interrupt-on-the-fly (INTF) condition. The following patch
fixes the problem.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
Acked-by: Matthew Wilcox <willy@linux.intel.com>
This fixes a potential corruption bug where the truncation would cause
reading or writing to the wrong memory area on machines with >4GB of
main memory.
Cc: Stable Kernel Tree <stable@kernel.org>
The following commit changed the pointer passed to request_irq(), but
failed to change the pointer passed to free_irq():
The result is that free_irq() doesn't actually take any action. This
patch fixes it.
Acked-by: Christoph Hellwig <hch@infradead.org>
x86: fix "Kernel panic - not syncing: IO-APIC + timer doesn't work!"
genirq: revert lazy irq disable for simple irqs
x86: also define AT_VECTOR_SIZE_ARCH
x86: kprobes bugfix
x86: jprobe bugfix
timer: kernel/timer.c section fixes
genirq: add unlocked version of set_irq_handler()
clockevents: fix reprogramming decision in oneshot broadcast
oprofile: op_model_athlon.c support for AMD family 10h barcelona performance counters
this is the tale of a full day spent debugging an ancient but elusive bug.
after booting up thousands of random .config kernels, i finally happened
to generate a .config that produced the following rare bootup failure
on 32-bit x86:
| ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
| ..MP-BIOS bug: 8254 timer not connected to IO-APIC
| ...trying to set up timer (IRQ0) through the 8259A ... failed.
| ...trying to set up timer as Virtual Wire IRQ... failed.
| ...trying to set up timer as ExtINT IRQ... failed :(.
| Kernel panic - not syncing: IO-APIC + timer doesn't work! Boot with apic=debug
| and send a report. Then try booting with the 'noapic' option
this bug has been reported many times during the years, but it was never
reproduced nor fixed.
the bug that i hit was extremely sensitive to .config details.
First i did a .config-bisection - suspecting some .config detail.
That led to CONFIG_X86_MCE: enabling X86_MCE magically made the bug disappear
and the system would boot up just fine.
Debugging my way through the MCE code ended up identifying two unlikely
candidates: the thing that made a real difference to the hang was that
X86_MCE did two printks:
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#1.
Adding the same printks to a !CONFIG_X86_MCE kernel made the bug go away!
this left timing as the main suspect: i experimented with adding various
udelay()s to the arch/x86/kernel/io_apic_32.c:check_timer() function, and
the race window turned out to be narrower than 30 microseconds (!).
That made debugging especially funny, debugging without having printk
ability before the bug hits is ... interesting ;-)
eventually i started suspecting IRQ activities - those are pretty much the
only thing that happen this early during bootup and have the timescale of
a few dozen microseconds. Also, check_timer() changes the IRQ hardware
in various creative ways, so the main candidate became IRQ0 interaction.
i've added a counter to track timer irqs (on which core they arrived, at
what exact time, etc.) and found that no timer IRQ would arrive after the
bug condition hits - even if we re-enable IRQ0 and re-initialize the i8259A,
but that we'd get a small number of timer irqs right around the time when we
call the check_timer() function.
Eventually i got the following backtrace triggered from debug code in the
timer interrupt:
Pid: 1, comm: swapper Not tainted (2.6.24-rc5 #57)
EIP: 0060:[<c044d57e>] EFLAGS: 00000246 CPU: 0
EIP is at _spin_unlock_irqrestore+0x5/0x1c
EAX: c0634178 EBX: 00000000 ECX: c4947d63 EDX: 00000246
ESI: 00000002 EDI: 00010031 EBP: c04e0f2e ESP: f7c41df4
DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
CR0: 8005003b CR2: ffe04000 CR3: 00630000 CR4: 000006d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
[<c05f5784>] setup_IO_APIC+0x9c3/0xc5c
the spin_unlock() was called from init_8259A(). Wait ... we have an IRQ0
entry while we are in the middle of setting up the local APIC, the i8259A
and the PIT??
That is certainly not how it's supposed to work! check_timer() was supposed
to be called with irqs turned off - but this eroded away sometime in the
past. This code would still work most of the time because this code runs
very quickly, but just the right timing conditions are present and IRQ0
hits in this small, ~30 usecs window, timer irqs stop and the system does
not boot up. Also, given how early this is during bootup, the hang is
very deterministic - but it would only occur on certain machines (and
certain configs).
The fix was quite simple: disable/restore interrupts properly in this
function. With that in place the test-system now boots up just fine.
(64-bit x86 io_apic_64.c had the same bug.)
Phew! One down, only 1500 other kernel bugs are left ;-)
In commit 76d2160147f43f982dfe881404cfde9fd0a9da21 lazy irq disabling
was implemented, and the simple irq handler had a masking set to it.
Remy Bohmer discovered that some devices in the ARM architecture
would trigger the mask, but never unmask it. His patch to do the
unmasking was questioned by Russell King about masking simple irqs
to begin with. Looking further, it was discovered that the problems
Remy was seeing was due to improper use of the simple handler by
devices, and he later submitted patches to fix those. But the issue
that was uncovered was that the simple handler should never mask.
This patch reverts the masking in the simple handler.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
