When I started adding support for lockdep to 64-bit powerpc, I got a
lockdep_init_error and with this patch was able to pinpoint why and where
to put lockdep_init(). Let's support this generally for others adding
lockdep support to their architecture.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Arjan van de Ven <arjan@infradead.org>
optionally add class->name_version and class->subclass to the class name
__acquire
lock _____
| __contended
| wait
| _______/
__acquired
__release
unlock
We measure acquisition and contention bouncing.
This is done by recording a cpu stamp in each lock instance.
Contention bouncing requires the cpu stamp to be set on acquisition. Hence we
move __acquired into the generic path.
__acquired is then used to measure acquisition bouncing by comparing the
current cpu with the old stamp before replacing it.
__contended is used to measure contention bouncing (only useful for preemptable
locks)
[akpm@linux-foundation.org: cleanups]
the two init sites resulted in inconsistend names for the lock class.
- update the copyright notices
- use the default hash function
- fix a thinko in a BUILD_BUG_ON
- add a WARN_ON to spot inconsitent naming
- fix a termination issue in /proc/lock_stat
Call the new lockstat tracking functions from the various lock primitives.
Acked-by: Jason Baron <jbaron@redhat.com>
Present all this fancy new lock statistics information:
*warning, _wide_ output ahead*
(output edited for purpose of brevity)
# cat /proc/lock_stat
lock_stat version 0.1
class name contentions waittime-min waittime-max waittime-total acquisitions holdtime-min holdtime-max holdtime-total
&inode->i_mutex: 14458 6.57 398832.75 2469412.23 6768876 0.34 11398383.65 339410830.89
&inode->i_mutex 4486 [<ffffffff802a08f9>] pipe_wait+0x86/0x8d
&inode->i_mutex 0 [<ffffffff802a01e8>] pipe_write_fasync+0x29/0x5d
&inode->i_mutex 0 [<ffffffff802a0e18>] pipe_read+0x74/0x3a5
&inode->i_mutex 0 [<ffffffff802a1a6a>] do_lookup+0x81/0x1ae
&inode->i_data.tree_lock-W: 491 0.27 62.47 493.89 2477833 0.39 468.89 1146584.25
&inode->i_data.tree_lock-R: 65 0.44 4.27 48.78 26288792 0.36 184.62 10197458.24
&inode->i_data.tree_lock 46 [<ffffffff80277095>] __do_page_cache_readahead+0x69/0x24f
&inode->i_data.tree_lock 31 [<ffffffff8026f9fb>] add_to_page_cache+0x31/0xba
&inode->i_data.tree_lock 0 [<ffffffff802770ee>] __do_page_cache_readahead+0xc2/0x24f
&inode->i_data.tree_lock 0 [<ffffffff8026f6e4>] find_get_page+0x1a/0x58
proc_inum_idr.lock: 0 0.00 0.00 0.00 36 0.00 65.60 148.26
proc_subdir_lock: 0 0.00 0.00 0.00 3049859 0.00 106.81 1563212.42
shrinker_rwsem-W: 0 0.00 0.00 0.00 5 0.00 1.73 3.68
shrinker_rwsem-R: 0 0.00 0.00 0.00 633 2.57 246.57 10909.76
'contentions' and 'acquisitions' are the number of such events measured (since
the last reset). The waittime- and holdtime- (min, max, total) numbers are
presented in microseconds.
If there are any contention points, the lock class is presented in the block
format (as i_mutex and tree_lock above), otherwise a single line of output is
presented.
The output is sorted on absolute number of contentions (read + write), this
should get the worst offenders presented first, so that:
# grep : /proc/lock_stat | head
will quickly show who's bad.
The stats can be reset using:
# echo 0 > /proc/lock_stat
[bunk@stusta.de: make 2 functions static]
[akpm@linux-foundation.org: fix printk warning]
Introduce the core lock statistics code.
Lock statistics provides lock wait-time and hold-time (as well as the count
of corresponding contention and acquisitions events). Also, the first few
call-sites that encounter contention are tracked.
Lock wait-time is the time spent waiting on the lock. This provides insight
into the locking scheme, that is, a heavily contended lock is indicative of
a too coarse locking scheme.
Lock hold-time is the duration the lock was held, this provides a reference for
the wait-time numbers, so they can be put into perspective.
1)
lock
2)
... do stuff ..
unlock
3)
The time between 1 and 2 is the wait-time. The time between 2 and 3 is the
hold-time.
The lockdep held-lock tracking code is reused, because it already collects locks
into meaningful groups (classes), and because it is an existing infrastructure
for lock instrumentation.
Currently lockdep tracks lock acquisition with two hooks:
lock()
lock_acquire()
_lock()
... code protected by lock ...
unlock()
lock_release()
_unlock()
We need to extend this with two more hooks, in order to measure contention.
lock_contended() - used to measure contention events
lock_acquired() - completion of the contention
These are then placed the following way:
lock()
lock_acquire()
if (!_try_lock())
lock_contended()
_lock()
lock_acquired()
... do locked stuff ...
unlock()
lock_release()
_unlock()
(Note: the try_lock() 'trick' is used to avoid instrumenting all platform
dependent lock primitive implementations.)
It is also possible to toggle the two lockdep features at runtime using:
/proc/sys/kernel/prove_locking
/proc/sys/kernel/lock_stat
(esp. turning off the O(n^2) prove_locking functionaliy can help)
[akpm@linux-foundation.org: build fixes]
[akpm@linux-foundation.org: nuke unneeded ifdefs]
Move code around to get fewer but larger #ifdef sections. Break some
in-function #ifdefs out into their own functions.
Ensure that all of the lock dependency tracking code is under
CONFIG_PROVE_LOCKING. This allows us to use the held lock tracking code for
other purposes.
Use the lockdep infrastructure to track lock contention and other lock
statistics.
It tracks lock contention events, and the first four unique call-sites that
encountered contention.
It also measures lock wait-time and hold-time in nanoseconds. The minimum and
maximum times are tracked, as well as a total (which together with the number
of event can give the avg).
All statistics are done per lock class, per write (exclusive state) and per read
(shared state).
The statistics are collected per-cpu, so that the collection overhead is
minimized via having no global cachemisses.
This new lock statistics feature is independent of the lock dependency checking
traditionally done by lockdep; it just shares the lock tracking code. It is
also possible to enable both and runtime disabled either component - thereby
avoiding the O(n^2) lock chain walks for instance.
This patch:
raw_spinlock_t should not use lockdep (and doesn't) since lockdep itself
relies on it.
Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu>
Similar information can easily be obtained with strace -c.
The sb_info structure only contains a single pointer to the character device,
there is no need for the added indirection.
Venus returns an ENOENT error on open, so we shouldn't try to grab the
filehandle for the returned fd.
We ignore signals for about 30 seconds to give userspace a chance to see the
upcall. As we did not block signals we ended up in a busy loop for the
remainder of the period when a signal is received.
Make the code that processes upcall responses more straightforward, uncovered
at least one bad assumption. We trusted that vc_inuse would be 0 when upcalls
are aborted, however the device may have been reopened.
- Make sure device index is not a negative number.
- Unlink queued requests when the device is closed to avoid passing them
to the next opener.
Set MS_NOATIME flag to avoid unnecessary calls when the coda inode is
accessed.
Also, set statfs.f_bsize to 4k. 1k is obviously too small for the suggested
IO size.
A directory without children may still be busy when it is the cwd for some
process. We can safely remove such a directory because the VFS prevents
further operations. Also we don't need to call d_delete as it is already
called in vfs_rmdir.
The Coda client sets the directory link count to 1 when it isn't sure how many
subdirectories we have. In this case we shouldn't change the link count in
the kernel when a subdirectory is created or removed.
Change the epoch value to forces a refresh instead of clearing the cached
rights mask and block all further accesses to the object.
When open fails the fd in the response is uninitialized and we ended up taking
a reference on the file struct and never released it.
This change passes the --build-id when linking the kernel and when linking
modules, if ld supports it. This is a new GNU ld option that synthesizes an
ELF note section inside the read-only data. The note in this section contains
unique identifying bits called the "build ID", which are generated so as to be
different for any two linked ELF files that aren't identical. The build ID
can be recovered from stripped files, memory dumps, etc. and used to look up
the original program built, locate debuginfo or other details or history
associated with it. For normal program linking, the compiler passes
--build-id to ld by default, but the option is needed when using ld directly
as we do.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
This patch adds the /sys/kernel/notes magic file. Reading this delivers the
contents of the kernel's .notes section. This lets userland easily glean any
detailed information about the running kernel's build that was stored there at
compile time.
This changes the s390 linker script to use the asm-generic NOTES macro so that
ELF note sections with SHF_ALLOC set are linked into the kernel image along
with other read-only data. The PT_NOTE also points to their location.
This paves the way for putting useful build-time information into ELF notes
that can be found easily later in a kernel memory dump.
This changes the powerpc linker script to use the asm-generic NOTES macro so
that ELF note sections with SHF_ALLOC set are linked into the kernel image
along with other read-only data. The PT_NOTE also points to their location.
This changes the alpha linker script to use the asm-generic NOTES macro so
This changes the x86_64 linker script to use the asm-generic NOTES macro so
This changes the i386 linker script and the asm-generic macro it uses so that
Looking at the current linus-git tree jbd_debug() define in
include/linux/jbd2.h
extern u8 journal_enable_debug;
#define jbd_debug(n, f, a...) \
do { \
if ((n) <= journal_enable_debug) { \
printk (KERN_DEBUG "(%s, %d): %s: ", \
__FILE__, __LINE__, __FUNCTION__); \
printk (f, ## a); \
} while (0)
> fs/ext4/inode.c: In function âext4_write_inodeâ:
> fs/ext4/inode.c:2906: warning: comparison is always true due to limited
> range of data type
> fs/jbd2/recovery.c: In function âjbd2_journal_recoverâ:
> fs/jbd2/recovery.c:254: warning: comparison is always true due to
> limited range of data type
> fs/jbd2/recovery.c:257: warning: comparison is always true due to
> fs/jbd2/recovery.c: In function âjbd2_journal_skip_recoveryâ:
> fs/jbd2/recovery.c:301: warning: comparison is always true due to
Noticed all warnings are occurs when the debug level is 0. Then found
the "jbd2: Move jbd2-debug file to debugfs" patch
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=0f49d5d019afa4e94253bfc92f0daca3badb990b
changed the jbd2_journal_enable_debug from int type to u8, makes the
jbd_debug comparision is always true when the debugging level is 0. Thus
the compile warning occurs.
Thought about changing the jbd2_journal_enable_debug data type back to
int, but can't, because the jbd2-debug is moved to debug fs, where
calling debugfs_create_u8() to create the debugfs entry needs the value
to be u8 type.
Even if we changed the data type back to int, the code is still buggy,
kernel should not print jbd2 debug message if the
jbd2_journal_enable_debug is set to 0. But this is not the case.
The fix is change the level of debugging to 1. The same should fixed in
ext3/JBD, but currently ext3 jbd-debug via /proc fs is broken, so we
probably should fix it all together.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Theodore Tso <tytso@mit.edu>
This version brings a number of new checks, and a number of bug
fixes. Of note:
- warnings for multiple assignments per line
- warnings for multiple declarations per line
- checks for single statement blocks with braces
This patch includes an update for feature-removal-schedule.txt to
better target checks.
Andy Whitcroft (12):
Version: 0.08
only apply printk checks where there is a string literal
allow suppression of errors for when no patch is found
warn about multiple assignments
warn on declaration of multiple variables
check for kfree() with needless null check
check for single statement braced blocks
check for aggregate initialisation on the next line
handle the => operator
check for spaces between function name and open parenthesis
move to explicit Check: entries in feature-removal-schedule.txt
handle pointer attributes
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
Update the MAINTAINERS file: Thomas Gleixner has been the de-facto
maintainer of POSIX timers and clocks for quite some time.
Cc: Tom Zanussi <zanussi@us.ibm.com>
This patch adds the documentation for /proc/<pid>/coredump_filter.
Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
This patch enables core dump filtering for ELF-FDPIC-formatted core file.
This patch removes an unused argument from elf_fdpic_dump_segments().
This patch enables core dump filtering for ELF-formatted core file.
This patch adds an interface to set/reset flags which determines each memory
segment should be dumped or not when a core file is generated.
/proc/<pid>/coredump_filter file is provided to access the flags. You can
change the flag status for a particular process by writing to or reading from
the file.
The flag status is inherited to the child process when it is created.
This patch changes mm_struct.dumpable to a pair of bit flags.
set_dumpable() converts three-value dumpable to two flags and stores it into
lower two bits of mm_struct.flags instead of mm_struct.dumpable.
get_dumpable() behaves in the opposite way.
[akpm@linux-foundation.org: export set_dumpable]
This patch series is version 5 of the core dump masking feature, which
controls which VMAs should be dumped based on their memory types and
per-process flags.
I adopted most of Andrew's suggestion at the previous version. He also
suggested using system call instead of /proc/<pid>/ interface, I decided to
use the latter continuously because adding new system call with pid argument
will give a big impact on the kernel.
You can access the per-process flags via /proc/<pid>/coredump_filter
interface. coredump_filter represents a bitmask of memory types, and if a bit
is set, VMAs of corresponding memory type are written into a core file when
the process is dumped. The bitmask is inherited from the parent process when
a process is created.
The original purpose is to avoid longtime system slowdown when a number of
processes which share a huge shared memory are dumped at the same time. To
achieve this purpose, this patch series adds an ability to suppress dumping
anonymous shared memory for specified processes. In this version, three other
memory types are also supported.
Here are the coredump_filter bits:
bit 0: anonymous private memory
bit 1: anonymous shared memory
bit 2: file-backed private memory
bit 3: file-backed shared memory
The default value of coredump_filter is 0x3. This means the new core dump
routine has the same behavior as conventional behavior by default.
In this version, coredump_filter bits and mm.dumpable are merged into
mm.flags, and it is accessed by atomic bitops.
The supported core file formats are ELF and ELF-FDPIC. ELF has been tested,
but ELF-FDPIC has not been built and tested because I don't have the test
environment.
This patch limits a value of suid_dumpable sysctl to the range of 0 to 2.
Remove include/linux/rmap.h from kernel-api.tmpl since it no longer
contains kernel-doc. Fixes this warning:
Warning(linux-2.6.22//include/linux/rmap.h): no structured comments found
If a parameter description begins with a '.', this indicates a "request"
for "man" mode output (*roff), so it needs special handling.
Problem case is in include/asm-i386/atomic.h for function
atomic_add_unless():
* @u: ...unless v is equal to u.
This parameter description is currently not printed in man mode output.
[akpm@linux-foundation.org: cleanup]
Strip C99-style comments from the input stream.
/*...*/ comments are already stripped.
C99 comments confuse the kernel-doc script.
Also update some comments.
