2008-05-23module loading ELF handling: use SELFMAG instead of numeric constantCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-21HTC_EGPIO is ARM-onlytip-x86-ldt-2008-05-26_08_53_Montip-pci-for-jesse-2008-05-26_08_52_MonAl Viro
driver uses symbols defined only on ARM Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21provide out-of-line strcat() for m68kAl Viro
Whether we sidestep it in init/main.c or not, such situations will arise again; compiler does generate calls of strcat() on optimizations, so we really ought to have an out-of-line version... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21caiaq endianness fixAl Viro
2008-05-21MODULE_LICENSE expects "GPL v2", not "GPLv2"Al Viro
... and we have few enough places using the latter to make it simpler to do search and replace... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21msnd_* is ISA-onlyAl Viro
2008-05-21missing dependencies on HAS_DMAAl Viro
2008-05-21ocfs2 endianness fixesAl Viro
2008-05-21irda-usb endianness annotations and fixesAl Viro
2008-05-21sbus bpp: instances missed in s/dev_name/bpp_dev_name/Al Viro
2008-05-21ecryptfs fixesAl Viro
memcpy() from userland pointer is a Bad Thing(tm) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21misc drivers/net endianness noiseAl Viro
2008-05-21thanks to net/mac80211 we need to pull drivers/leds/Kconfig on umlAl Viro
2008-05-21missing export of csum_partial() on uml/amd64Al Viro
2008-05-21uml: add missing exports for UML_RANDOM=mAl Viro
2008-05-21fix hppfs Makefile breakageAl Viro
Fallout from commit 46d7b522ebf486edbd096965d534cc6465e9e309 ("uml: move hppfs_kern.c to hppfs.c") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21fix include order in sys-i386/registers.cAl Viro
We want sys/ptrace.h before any includes of linux/ptrace.h and asm/user.h pulls the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-21missed kmalloc() in pcap_user.cAl Viro
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (21 commits) [CIFS] Remove debug statement Fix possible access to undefined memory region. [CIFS] Enable DFS support for Windows query path info [CIFS] Enable DFS support for Unix query path info [CIFS] add missing seq_printf to cifs_show_options for hard mount option [CIFS] add more complete mount options to cifs_show_options [CIFS] Add missing defines for DFS CIFSGetDFSRefer cleanup + dfs_referral_level_3 fixed to conform REFERRAL_V3 the MS-DFSC spec. Fixed DFS code to work with new 'build_path_from_dentry', that returns full path if share in the dfs, now. [CIFS] enable parsing for transport encryption mount parm [CIFS] Finishup DFS code [CIFS] BKL-removal: convert CIFS over to unlocked_ioctl [CIFS] suppress duplicate warning [CIFS] Fix paths when share is in DFS to include proper prefix add function to convert access flags to legacy open mode clarify return value of cifs_convert_flags() [CIFS] don't explicitly do a FindClose on rewind when directory search has ended [CIFS] cleanup old checkpatch warnings [CIFS] CIFSSMBPosixLock should return -EINVAL on error fix memory leak in CIFSFindNext ...
2008-05-21[CIFS] Remove debug statementSteve French
Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-21Fix possible access to undefined memory region.Igor Mammedov
Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20Merge branch 'for-2.6.26' of git://linux-nfs.org/~bfields/linuxtip-x86-xsave-2008-05-26_08_54_Montip-x86-cpu-2008-05-26_08_53_MonLinus Torvalds
* 'for-2.6.26' of git://linux-nfs.org/~bfields/linux: (25 commits) svcrdma: Verify read-list fits within RPCSVC_MAXPAGES svcrdma: Change svc_rdma_send_error return type to void svcrdma: Copy transport address and arm CQ before calling rdma_accept svcrdma: Set rqstp transport address in rdma_read_complete function svcrdma: Use ib verbs version of dma_unmap svcrdma: Cleanup queued, but unprocessed I/O in svc_rdma_free svcrdma: Move the QP and cm_id destruction to svc_rdma_free svcrdma: Add reference for each SQ/RQ WR svcrdma: Move destroy to kernel thread svcrdma: Shrink scope of spinlock on RQ CQ svcrdma: Use standard Linux lists for context cache svcrdma: Simplify RDMA_READ deferral buffer management svcrdma: Remove unused READ_DONE context flags bit svcrdma: Return error from rdma_read_xdr so caller knows to free context svcrdma: Fix error handling during listening endpoint creation svcrdma: Free context on post_recv error in send_reply svcrdma: Free context on ib_post_recv error svcrdma: Add put of connection ESTABLISHED reference in rdma_cma_handler svcrdma: Fix return value in svc_rdma_send svcrdma: Fix race with dto_tasklet in svc_rdma_send ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Add global register dumping facility. sparc: remove CVS keywords sparc64: remove CVS keywords
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: CDC WDM driver USB: ehci-orion: the Orion EHCI root hub does have a Transaction Translator USB: serial: ch341: New VID/PID for CH341 USB-serial USB: build fix USB: pxa27x_udc - Fix Oops USB: OPTION: fix name of Onda MSA501HS HSDPA modem USB: add TELIT HDSPA UC864-E modem to option driver usb-serial: Use ftdi_sio driver for RATOC REX-USB60F
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: SCSI: fix race in device_create USB: Core: fix race in device_create USB: Phidget: fix race in device_create s390: fix race in device_create SOUND: fix race in device_create UIO: fix race in device_create Power Supply: fix race in device_create LEDS: fix race in device_create IB: fix race in device_create ide: fix race in device_create fbdev: fix race in device_create mm: bdi: fix race in bdi_class device creation Driver core: add device_create_vargs and device_create_drvdata
2008-05-20Merge branch 'from-tomtucker' into for-2.6.26J. Bruce Fields
2008-05-20pktgen: make sure that pktgen_thread_worker has been executedDenis V. Lunev
The following courruption can happen during pktgen stop: list_del corruption. prev->next should be ffff81007e8a5e70, but was 6b6b6b6b6b6b6b6b kernel BUG at lib/list_debug.c:67! :pktgen:pktgen_thread_worker+0x374/0x10b0 ? autoremove_wake_function+0x0/0x40 ? _spin_unlock_irqrestore+0x42/0x80 ? :pktgen:pktgen_thread_worker+0x0/0x10b0 kthread+0x4d/0x80 child_rip+0xa/0x12 ? restore_args+0x0/0x30 ? kthread+0x0/0x80 ? child_rip+0x0/0x12 RIP list_del+0x48/0x70 The problem is that pktgen_thread_worker can not be executed if kthread_stop has been called too early. Insert a completion on the normal initialization path to make sure that pktgen_thread_worker will gain the control for sure. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20[VLAN]: Propagate selected feature bits to VLAN devicesPatrick McHardy
Propagate feature bits from the NETDEV_FEAT_CHANGE notifier. For now only TSO is propagated for devices that announce their ability to support TSO in combination with VLAN accel by setting the NETIF_F_VLAN_TSO flag. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20[CIFS] Enable DFS support for Windows query path infoSteve French
Final piece for handling DFS in query_path_info, constructing a fake inode for the junction directory which the submount will cover. This handles the non-Unix (Windows etc.) code path. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20drivers/atm/: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20vlan: Correctly handle device notifications for layered VLAN devicesPatrick McHardy
Commit 30688a9 ([VLAN]: Handle vlan devices net namespace changing) changed the device notifier to special-case notifications for VLAN devices, effectively disabling state propagation to underlying VLAN devices. This is needed for layered VLANs though, so restore the original behaviour. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags()David Woodhouse
Am I just being particularly dim today, or can the call to dev->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() never happen? We've just set dev->flags = flags & IFF_MULTICAST, effectively. So the condition '(dev->flags ^ flags) & IFF_MULTICAST' is _never_ going to be true. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20net_sched: cls_api: fix return value for non-existant classifiersPatrick McHardy
cls_api should return ENOENT when the requested classifier doesn't exist. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20ipsec: Use the correct ip_local_out functionHerbert Xu
Because the IPsec output function xfrm_output_resume does its own dst_output call it should always call __ip_local_output instead of ip_local_output as the latter may invoke dst_output directly. Otherwise the return values from nf_hook and dst_output may clash as they both use the value 1 but for different purposes. When that clash occurs this can cause a packet to be used after it has been freed which usually leads to a crash. Because the offending value is only returned from dst_output with qdiscs such as HTB, this bug is normally not visible. Thanks to Marco Berizzi for his perseverance in tracking this down. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: iop-adma: fixup some kzalloc/memset confusions fsldma: update the fsldma driver MAINTAINERS info
2008-05-20USB: CDC WDM driverOliver Neukum
Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: ehci-orion: the Orion EHCI root hub does have a Transaction TranslatorLennert Buytenhek
Commit 7329e211b987a493cbcfca0e98c60eb108ab42df ("USB: root hubs don't lie about their number of TTs") requires the various platform EHCI glue modules to set ->has_tt if the root hub has a Transaction Translator. The Orion EHCI root hub does have a Transaction Translator, so set ->has_tt in ehci_orion_setup(). This fixes oopsing on plugging in a low speed device. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: serial: ch341: New VID/PID for CH341 USB-serialMichael F. Robbins
Recent USB-serial devices using the WinChipHead CH340/CH341 chipset are being shipped with a new vendor/product ID code pair, but an otherwise identical device. (This is confirmed by looking at INF for the included Windows driver.) Patch is tested and working, both with new and old devices. Signed-off-by: Michael F. Robbins <mrobbins@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: build fixIngo Molnar
this config: http://redhat.com/~mingo/misc/config-Wed_Apr_30_15_12_48_CEST_2008.bad fails to build due to an #error. Turn that into a #warning instead to not break randconfig builds unnecessarily. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: pxa27x_udc - Fix Oopskarl beldan
udc_disable oopses dereferencing udc_command. Signed-off-by: Karl Beldan <karl.beldan@gmail.com> Acked-by: Robert Jarzmik <rjarzmik@free.fr> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: OPTION: fix name of Onda MSA501HS HSDPA modemArnaldo Carvalho de Melo
This fixes the name of the onda MSA501HS device, I guess it is called different things in different countries. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: add TELIT HDSPA UC864-E modem to option driverGreg Kroah-Hartman
This adds the Telit UC864-E HDSPA modem support to the option driver. This lets their customers comply with the GPL instead of having to use a binary driver from the manufacturer. Cc: Simon Kissel <kissel@viprinet.com> Cc: Nico Erfurth <ne@nicoerfurth.de> Cc: Andrea Ghezzo <TS-EMEA@telit.com> Cc: Dietmar Staps <Dietmar.Staps@telit.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20usb-serial: Use ftdi_sio driver for RATOC REX-USB60FAtsushi Nemoto
This patch reverts 57833ea6b95a3995149f1f6d1a8d8862ab7a0ba2 ("usb-serial: pl2303: add support for RATOC REX-USB60F") and adds support for the device to ftdi_sio driver. Cc: Akira Tsukamoto <akirat@rd.scei.sony.co.jp> Cc: stable <stable@kernel.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20iop-adma: fixup some kzalloc/memset confusionsChristophe Jaillet
1) Remove an explicit memset(.., 0, ...) to a variable allocated with kzalloc (i.e. 'dest'). 2) Allocate 'src' with kmalloc instead of kzalloc as all elements of the 'src' buffer are initialized in a 'for(...)' loop just after. 3) remove useless 'sizeof(u8)', which always returns 1, when computing the size of the memory to be allocated. Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-05-20fsldma: update the fsldma driver MAINTAINERS infoZhang Wei
Add Li Yang as the new maintainer for fsldma driver and update my email address. Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Zhang Wei <zw@zh-kernel.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-05-20SCSI: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). It fixes the problem in all of the scsi drivers that need it. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: Core: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20USB: Phidget: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). It fixes all 3 phidget drivers, which all have the same problem. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Sean Young <sean@mess.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20s390: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
