Without this very high BCLKs will be configured incorrectly.
Reported-by: Axel Lin <axel.lin@gmail.com>
Cc: stable@vger.kernel.org
The recent fix for power-map controls (commit b0791dda813) caused
regressions on some other HP laptops. They have fixed pins but these
pins are exposed as jack-detectable. Thus the driver tries to control
the power-map dynamically per jack detection where it never gets on.
This patch adds the check of connection and it assumes the no jack
detection is available for fixed pins no matter what pin capability
says.
BugLink: http://bugs.launchpad.net/bugs/1013183
Reported-by: Luis Henriques <luis.henriques@canonical.com>
Better to clean up the caches for avoiding inconsistent codec state
after the reconfiguration.
Some caches aren't released properly at module unloading time.
Cc: <stable@vger.kernel.org> [v3.4+]
When moved to the helper code, forgot to release the verb arrays.
This chip looks very similar to ALC269 and ALC27* variants. The bug reporter
has verified that sound was working after this patch had been applied.
Cc: stable@kernel.org
BugLink: https://bugs.launchpad.net/bugs/1017017
Tested-by: Richard Crossley <richardcrossley@o2.co.uk>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
I simply forgot to remove this entry although all Realtek quirks have
been dropped.
It seems that the code duplication was added at a merge operation.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Reported-by: John McFarland <mcfarljm@gmail.com>
Tested-by: John McFarland <mcfarljm@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
The Lenovo Ideapad S205 has an internal mic where the right channel
is phase inverted.
BugLink: https://bugs.launchpad.net/bugs/884652
The codec ALC272X is a special codec for some Dell machines, and its
detection got broken in the recent kernel because SSID check (required
by ALC272X check) was moved to the later point. Now we need to move
this codec check to the right place, too.
This webcam works mostly ok, exept with skype.
Skype sends lots of ctrl messages to dynamically ajust
record level. If for some reasons it pokes some error
every thing goes broken:
- first pulseaudio blocks sound for all apps
- then video is reseted
- then skype freez
dmesg has lots of messages like:
cannot set freq 16000 to ep 0x86"
Setting ignore_ctl_error=1 fixes this problem.
Signed-off-by: Oleksij Rempel <bug-track@fisher-privat.net>
if this cam is pluged in, pulse audio can't initiate capture
device.
"cannot set freq 16000 to ep 0x86"
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: Torsten Schenk <torsten.schenk@zoho.com>
This addresses an issue encountered when a pcm is opened while
transitioning to low power state (codec->power_on == 1 &&
codec->power_transition == -1). Add snd_pcm_power_up_d3wait to
hda_codec. This function is used to power up from azx_open as opposed
to snd_hda_power_up used from codec_exec_verb. When powering up from
azx_open, wait for pending power downs to complete, avoiding the power
up continuing in parallel with the power down on the work queue.
The specific issue seen was with the CS4210 codec, it powers off the ADC
and DAC nid in its suspend handler. If it is re-opened before the
~100ms power down process completes, the ADC and DAC nid are initialized
while powered down and audio is lost until another suspend/resume cycle.
Signed-off-by: Dylan Reid <dgreid@chromium.org>
Fix a bogus sanity check for sync pipe in pcm.c. This flaw was
introduced during the streaming logic refactorization.
While at it, improve the error messages that are generated in such cases.
Reported-and-tested-by: <ben@b1c1l1.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Updates for 3.5
All driver specific and fairly small. The pxa-ssp changes are larger
than I'd like but they're build failures and are pretty clear to
inspection.
During the split to the auto-parser helper functions, the actual call
of init verbs was lost.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43366
Pin 0x1b was connected to the front panel connector, which according to
the HDA standard should contain a mic and a headphone. In this case,
the headphone was listed as "line out" by BIOS.
BugLink: https://bugs.launchpad.net/bugs/993162
as the start can be called after stop again, we need to reset state
Signed-off-by: Namarta Kohli <namartax.kohli@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
during pause the core should maintain the status-quo on the device and pointers
and not wake up. If app needs it should call DROP explcitly.
If mic detect is left enabled and the WM8903 detects a status change,
the WM8903 driver will make a callback against the free()d jack, which
will cause a crash.
This problem can be triggered by fully initializing an audio card, then
removing and re-inserting the machine driver module.
The PCI ID entries of Creative SoundCore3D HD-audio controllers should
be before the wildcard for vendor = Creative.
Otherwise we might try to write to a powered off device.
If we don't have control over the LDO but do have control over the other
regulators then we may end up trying to write to a powered off device.
We're using demv_regulator_bulk_get() so don't need to manually free and
this is in the CODEC driver not the I2C driver anyway.
We should be using the regmap API consistently for all the cache only
configuration and we should be going cache only before we power down
the supplies.
We no longer have a flat ASoC cache so can't peer directly into the array
any more but should instead use the register I/O functions to update the
cache.
Cc: stable@vger.kernel.org (v3.4)
pxa-ssp.c uses API like cpu_is_pxa3xx(), cpu_is_pxa2xx(), which is
defined under arch-pxa architecture, and drivers under mach-mmp
can't find it. so just use ssp->type to replace that API.
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
add pxa910-ssp into ssp_id_table, and fix pxa-ssp compiling issue
under mach-mmp architect.
The audio clients have to be disabled before disabling the VGA and
switching. Similarly, enabling the audio client should be done at
last. Otherwise the audio-side operation stalls, eventually leading
to Oops or lockups.
Tested-by: Jörg-Volker Peetz <jvpeetz@web.de>
Acked-by: Dave Airlie <airlied@redhat.com>
When VGA_SWITCHEROO support is enabled hda_intel initialises the HDMI
audio device on the current VGA device. When it's not enabled it only
initialises the HDMI device on the default VGA adaptor, this means
secondary cards get no audio support which is very unhelpful for
multi-seat!
With this patch, when SUPPORT_VGA_SWITCHEROO is disabled hda_intel
initialises all HDMI audio devices, not just the default VGA.
[minor optimizations by tiwai]
Signed-off-by: Steven Newbury <steve@snewbury.org.uk>
Fix a typo that is built only when CONFIG_VGA_SWITCHEROO=n.
When VGA-switcheroo is built in but unused on systems with multiple
graphics cards, the initializations of non-default graphics cards are
skipped and never enabled (because the switcheroo is activated only
when the controller supports). The current behavior is for avoiding
the system lockup by accessing the disabled GPU, but due to the recent
change in VGA-switcheroo, it determines the state simply by checking
with the default VGA device. This is the culprit.
Now with the new vga_switcheroo_get_client_state(), we can know the
initial state of the bound GPU, thus can determine the initial audio
client state more correctly.
Add vga_switcheroo_get_client_state() to get the current state of the
client. This is necessary to determine the proper initial state of
audio clients in HD-audio driver.
In 3.5 kernel, the endpoint is assigned dynamically for the
substreams, but the PCM assignment still checks the presence of the
endpoint pointer. This ended up in duplicated PCM substream creations
at probing time, resulting in kernel warnings like:
WARNING: at fs/proc/generic.c:586 proc_register+0x169/0x1a6()
Pid: 1152, comm: modprobe Not tainted 3.5.0-rc1-00110-g71fae7e #2
Call Trace:
[<ffffffff8102a400>] warn_slowpath_common+0x83/0x9c
[<ffffffff8102a4bc>] warn_slowpath_fmt+0x46/0x48
[<ffffffff813829ad>] ? add_preempt_count+0x39/0x3b
[<ffffffff811292f0>] proc_register+0x169/0x1a6
[<ffffffff8112962e>] create_proc_entry+0x74/0x8c
[<ffffffffa018eb63>] snd_info_register+0x3e/0xc3 [snd]
[<ffffffffa01fde2e>] snd_pcm_new_stream+0xb1/0x404 [snd_pcm]
[<ffffffffa024861f>] snd_usb_add_audio_stream+0xd2/0x230 [snd_usb_audio]
[<ffffffffa0241d33>] ? snd_usb_parse_audio_format+0x252/0x34f [snd_usb_audio]
[<ffffffff810d6b17>] ? kmem_cache_alloc_trace+0xab/0xbb
[<ffffffffa0248c29>] snd_usb_parse_audio_interface+0x4ac/0x567 [snd_usb_audio]
[<ffffffffa023f0ff>] snd_usb_create_stream+0xe9/0x125 [snd_usb_audio]
[<ffffffffa023f9b1>] usb_audio_probe+0x62a/0x72c [snd_usb_audio]
This patch fixes the regression by checking the fixed endpoint number
for each substream instead of the endpoint pointer.
Reported-and-tested-by: Jamie Heilman <jamie@audible.transient.net>
This allows the module to automatically load when instantiated from
device tree.
Rather than having varying timeouts depending on the transition always
use a 4s timeout. This provides better diagnostics for clocking errors
and ensures compatibility with current calibration firmwares.
We should only add source widgets to the input list.
Signed-off-by: Liam Girdwood <lrg@ti.com>
Make sure that the dpcm_get_be() only returns BE DAI links.
Volume updates may not be acted upon if there is no clock applied when
the volume update is written. Ensure this doesn't happen by writing out
registers with volume updates after we enable each of the clocks.
There are more registers updated than before as previously we were
relying on wm_hubs to set those for controls it manages.
Ensure that all the actions get taken at appropriate times by calling the
_PRE and _POST events for the aifNclk_ev functions explicitly.
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Make sure we check the correct path for capture.
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull device-mapper updates from Alasdair G Kergon:
"Improve multipath's retrying mechanism in some defined circumstances
and provide a simple reserve/release mechanism for userspace tools to
access thin provisioning metadata while the pool is in use."
* tag 'dm-3.5-changes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm:
dm thin: provide userspace access to pool metadata
dm thin: use slab mempools
dm mpath: allow ioctls to trigger pg init
dm mpath: delay retry of bypassed pg
dm mpath: reduce size of struct multipath
This patch implements two new messages that can be sent to the thin
pool target allowing it to take a snapshot of the _metadata_. This,
read-only snapshot can be accessed by userland, concurrently with the
live target.
Only one metadata snapshot can be held at a time. The pool's status
line will give the block location for the current msnap.
Since version 0.1.5 of the userland thin provisioning tools, the
thin_dump program displays the msnap as follows:
thin_dump -m <msnap root> <metadata dev>
Available here: https://github.com/jthornber/thin-provisioning-tools
Now that userland can access the metadata we can do various things
that have traditionally been kernel side tasks:
i) Incremental backups.
By using metadata snapshots we can work out what blocks have
changed over time. Combined with data snapshots we can ensure
the data doesn't change while we back it up.
A short proof of concept script can be found here:
https://github.com/jthornber/thinp-test-suite/blob/master/incremental_backup_example.rb
ii) Migration of thin devices from one pool to another.
iii) Merging snapshots back into an external origin.
iv) Asyncronous replication.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Use dedicated caches prefixed with a "dm_" name rather than relying on
kmalloc mempools backed by generic slab caches so the memory usage of
thin provisioning (and any leaks) can be accounted for independently.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
After the failure of a group of paths, any alternative paths that
need initialising do not become available until further I/O is sent to
the device. Until this has happened, ioctls return -EAGAIN.
With this patch, new paths are made available in response to an ioctl
too. The processing of the ioctl gets delayed until this has happened.
Instead of returning an error, we submit a work item to kmultipathd
(that will potentially activate the new path) and retry in ten
milliseconds.
Note that the patch doesn't retry an ioctl if the ioctl itself fails due
to a path failure. Such retries should be handled intelligently by the
code that generated the ioctl in the first place, noting that some SCSI
commands should not be retried because they are not idempotent (XOR write
commands). For commands that could be retried, there is a danger that
if the device rejected the SCSI command, the path could be errorneously
marked as failed, and the request would be retried on another path which
might fail too. It can be determined if the failure happens on the
device or on the SCSI controller, but there is no guarantee that all
SCSI drivers set these flags correctly.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
