2008-02-06rtc: cleanup example codeMike Frysinger
No functional changes here, just tighten up style/whitespace. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: update documentation wrt irq_set_freqMike Frysinger
Document the proper use of the irq_set_freq function. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc ds1307: ds_1340 change initfrederic Rodo
For DS140, clear the oscillator fault flag as needed. Signed-off-by: Frederic RODO <f.rodo@til-technologies.fr> [ And remove some "sparse" warnings. ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: add support for Epson RTC-9701JE V4Magnus Damm
Add support for the Epson RTC-9701JE SPI RTC device. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: add support for Epson RTC-9701JE V2Magnus Damm
2008-02-06ip27-rtc: convert ioctl to unlocked_ioctlCyrill Gorcunov
Convert ioctl call to unlocked_ioctl form. It is possible (in that simple way) due to a spinlock protection. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: add HPET RTC emulation to RTC_DRV_CMOSBernhard Walle
That patch adds the RTC emulation of the HPET timer to the new RTC_DRV_CMOS. The old drivers/char/rtc.ko driver had that functionality and it's important on new systems. [akpm@linux-foundation.org: unbreak alpha build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Robert Picco <Robert.Picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Blackfin RTC driver: convert sync wait to use the irq write complete noticeMike Frysinger
- thus clearing out the need for spin locks - add a small optimization for reading of the rtc field Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Blackfin RTC driver: shave off another memcpy() by using assignment.Mike Frysinger
2008-02-06Blackfin RTC driver: read_alarm() checks the enabled field, not the pending ↵Mike Frysinger
field. also, dont bother using memcpy since we can just do an assignment of the same structure. Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Blackfin RTC driver: use dev_dbg() rather than pr_stamp()Mike Frysinger
2008-02-06Blackfin RTC driver: cleanup proc handler (we dont need RTC reg dump now ↵Mike Frysinger
that we have MMR filesystem in sysfs) Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Blackfin RTC driver: we pass in a (struct device*) to the irq handler, not a ↵Mike Frysinger
(struct platform_device*), so fix the irq handler Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Blackfin RTC driver: the frequency function is in units of Hz, not units of ↵Mike Frysinger
seconds, so lock our driver down to 1 Hz Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Platform real time clock driver for Dallas 1511 chipAndrew Sharp
Add RTC support for DS1511 RTC/WDT chip. Signed-off-by: Andy Sharp <andy.sharp@onstor.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-cmos alarm acts as oneshotDavid Brownell
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling that alarm after its IRQ fires. (ACPI hooks are also needed.) The Linux RTC framework has previously been a bit vague in this area, but any other behavior is problematic and not very portable. RTCs with full YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with partial match criteria, with the most visible example being the PC RTC, get confused. (Because the criteria will match repeatedly.) Update comments relating to that oneshot behavior and timezone handling. (Timezones are another issue that's mostly visible with rtc-cmos. That's because PCs often dual-boot MS-Windows, which likes its RTC to match local wall-clock time instead of UTC.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: ds1302 rtc supportPaul Mundt
This adds a basic ds1302 RTC driver, which is basically a cleanup and move of the in-tree SH SecureEdge5410 code (which is currently located in arch/sh/board/snapgear/rtc.c) to drivers/rtc. This aims to be a building block that the M32R and CRIS code can be worked on top of, so we can get rid of drivers/char/ds1302.c and arch/cris/arch-v10/drivers/ds1302.c respectively, though more work is needed for this. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-cmos: export nvram in sysfsDavid Brownell
This makes rtc-cmos export its NVRAM, like several other RTC drivers. It still works within the limits of the current CMOS_READ/CMOS_WRITE calls, which don't understand how to access multiple register banks. The primary impact of that limitation is that Linux can't access the uppermost 128 bytes of NVRAM on many systems. Note that this isn't aiming to be a drop-in replacement for the legacy /dev/nvram support. (Presumably that has real users, and isn't just getting carried forward automatically?) Userspace handles more work: - When userspace code updates NVRAM, that will need to include updating any platform-specific checksums that may apply. - No /proc/driver/nvram file will parse and display NVRAM data according to whichever boot firmware your board expects. Also minor pnp-related updates: update a comment, remove dead code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-s3c: Use is_power_of_2() macro for simplicity.Robert P. J. Day
Use is_power_of_2() macro for simplicity. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-pcf8583: Don't abuse I2C_M_NOSTARTJean Delvare
The rtc-pcf8583 driver is using the I2C_M_NOSTART flag but shouldn't. This flag is only meant for broken chips and the PCF8583 RTC chip is not one of these. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Cosmetic fixes to RTC subsystem's KconfigAlessandro Zummo
Add adds a warning if a potentially conflicting RTC option has been selected and makes some other cosmetic fixes to the Kconfig. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fuse: limit queued background requestsMiklos Szeredi
Libfuse basically creates a new thread for each new request. This is fine for synchronous requests, which are naturally limited. However background requests (especially writepage) can cause a thread creation storm. To avoid this, limit the number of background requests available to userspace. This is done by introducing another queue for background requests, and a counter for the number of "active" requests, which are currently available for userspace. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fuse: save space in struct fuse_reqMiklos Szeredi
Move the fields 'dentry' and 'vfsmount' into the request specific union, since these are only used for the RELEASE request. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fuse: fix attribute caching after createMiklos Szeredi
Invalidate attributes on create, since st_ctime is updated. Reported by Szabolcs Szakacsits. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ecryptfs: check for existing key_tfm at mount timeEric Sandeen
Jeff Moyer pointed out that a mount; umount loop of ecryptfs, with the same cipher & other mount options, created a new ecryptfs_key_tfm_cache item each time, and the cache could grow quite large this way. Looking at this with mhalcrow, we saw that ecryptfs_parse_options() unconditionally called ecryptfs_add_new_key_tfm(), which is what was adding these items. Refactor ecryptfs_get_tfm_and_mutex_for_cipher_name() to create a new helper function, ecryptfs_tfm_exists(), which checks for the cipher on the cached key_tfm_list, and sets a pointer to it if it exists. This can then be called from ecryptfs_parse_options(), and new key_tfm's can be added only when a cached one is not found. With list locking changes suggested by akpm. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: change the type of cipher_code from u16 to u8Trevor Highland
Only the lower byte of cipher_code is ever used, so it makes sense for its type to be u8. Signed-off-by: Trevor Highland <trevor.highland@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: Minor fixes to printk messagesMichael Halcrow
The printk statements that result when the user does not have the proper key available could use some refining. Signed-off-by: Mike Halcrow <mhalcrow@us.ibm.com> Cc: Mike Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ecryptfs: remove debug as mount option, and warn if set via modprobeEric Sandeen
ecryptfs_debug really should not be a mount option; it is not per-mount, but rather sets a global "ecryptfs_verbosity" variable which affects all mounted filesysytems. It's already settable as a module load option, I think we can leave it at that. Also, if set, since secret values come out in debug messages, kick things off with a stern warning. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Mike Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ecryptfs: make show_options reflect actual mount optionsEric Sandeen
Change ecryptfs_show_options to reflect the actual mount options in use. Note that this does away with the "dir=" output, which is not a valid mount option and appears to be unused. Mount options such as "ecryptfs_verbose" and "ecryptfs_xattr_metadata" are somewhat indeterminate for a given fs, but in any case the reported mount options can be used in a new mount command to get the same behavior. [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: set inode key only once per crypto operationTrevor Highland
There is no need to keep re-setting the same key for any given eCryptfs inode. This patch optimizes the use of the crypto API and helps performance a bit. Signed-off-by: Trevor Highland <trevor.highland@gmail.com> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: track header bytes rather than extentsMichael Halcrow
Remove internal references to header extents; just keep track of header bytes instead. Headers can easily span multiple pages with the recent persistent file changes. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs/ecryptfs/: possible cleanupsAdrian Bunk
- make the following needlessly global code static: - crypto.c:ecryptfs_lower_offset_for_extent() - crypto.c:key_tfm_list - crypto.c:key_tfm_list_mutex - inode.c:ecryptfs_getxattr() - main.c:ecryptfs_init_persistent_file() - remove the no longer used mmap.c:ecryptfs_lower_page_cache - #if 0 the unused read_write.c:ecryptfs_read() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/isdn/hardware/eicon/debug.c: fix uninitialized var warningAndrew Morton
drivers/isdn/hardware/eicon/debug.c: In function 'SuperTraceASSIGN': drivers/isdn/hardware/eicon/debug.c:1191: warning: 'rx_dma_magic' may be used uninitialized in this function Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/isdn/hardware/eicon/message.c fix 'and' typo in eicons' AddInfo()Roel Kluin
'!' has a higher priority than '&'. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ser_gigaset: convert mutex to completionTilman Schmidt
The ser_gigaset ISDN driver was using a mutex in its close() method for waiting for other running ldisc methods to finish. That's what completions are for. Incidentally, this also avoids a spurious "BUG: lock held at task exit time" message when the driver's userspace daemon daemonizes itself. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Gigaset: permit module unloadTilman Schmidt
Fix the initialization and reference counting of the Gigaset driver modules so that they can be unloaded when they are not actually in use. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Greg KH <gregkh@suse.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gigaset: atomic cleanupTilman Schmidt
Convert atomic_t variables that don't actually use atomic_t functionality to int. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06usb_gigaset: suspend supportTilman Schmidt
Add basic suspend/resume support to the usb_gigaset driver for the Siemens Gigaset M105 USB DECT adapter. Only the USB aspects are handled so far; the ISDN subsystem is not notified in any way, for lack of information about how to do that. The driver does not check for active connections before suspending. They will be dropped when the device loses USB power. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Greg KH <gregkh@suse.de> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06bas_gigaset: suspend supportTilman Schmidt
Add basic suspend/resume support to the bas_gigaset ISDN driver for the Siemens Gigaset SX255 series of ISDN DECT bases. Only the USB aspects are handled so far; the ISDN subsystem is not notified in any way, for lack of information about how to do that. The driver will refuse to suspend if a connection is active. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Greg KH <gregkh@suse.de> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gigaset: code cleanupsTilman Schmidt
Some cleanups to the bas-gigaset and usb-gigaset USB ISDN drivers: - simplified error handling - improved debug messages - readability improvements - removal of obsolete defines and comments Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Greg KH <gregkh@suse.de> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gigaset: clean up urb->status usageTilman Schmidt
Make there only be one reference to urb->status per URB callback, and none outside, in preparation for removal of that field. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Greg KH <gregkh@suse.de> Cc: Hansjoerg Lipp <hjlipp@web.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kprobes: kretprobe user entry-handlerAbhishek Sagar
Provide support to add an optional user defined callback to be run at function entry of a kretprobe'd function. Also modify the kprobe smoke tests to include an entry-handler during the kretprobe sanity test. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi: remove more dev->power.power_state usageDavid Brownell
Remove some more references to dev->power.power_state. That field is overdue for removal, but we can't do that while it's still referenced in the kernel. The only reason to update it was to make the /sys/devices/.../power/state files (now removed) work better. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi_bfin: headers are not for changelogsMike Frysinger
Use simpler comment headers, and strip out information that is maintained in GIT history Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi_bfin: wait for tx to complete on write pathsSonic Zhang
SPI writes should also not return until the last bit is sent. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi_bfin: wait for tx to complete on full duplex pathsBryan Wu
Full duplex SPI operation should not read a dummy byte at the first transfer. Bug and fix by Jean-Christian de Rivaz <jc@eclis.ch>: http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3678 Signed-off-by: Jean-Christian de Rivaz <jc@eclis.ch> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi_bfin: wait for tx to complete on some cs_chg pathsBryan Wu
PBX 2 SPI devices need the nonstandard "cs change per word" mechanism. This patch is one of three updating this driver to make the last data bits get sent before advancing the transfer ... in this case, before the chipselect gets deactivated. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi_bfin: use more useful GPIO labelsBryan Wu
Use the SPI driver's name when requesting gpio lines. When there are gpio conflicts, this helps to narrow down the problems; "bfin-spi" is not informative. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi_bfin: remove useless fault pathBryan Wu
Remove useless return status check in restore_state function. Issue was pointed out by Michael. Cc: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06spi: omap2_mcspi handles omap3 tooGirish
This adds driver OMAP SPI specific changes to support OMAP 3430 Signed-off-by: Girish S G <girishsg@ti.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
