Use dev_printk like format.
Sample (real machine + dummy error injected by aer-inject):
- Before:
+------ PCI-Express Device Error ------+
Error Severity : Corrected
PCIE Bus Error type : Data Link Layer
Bad TLP :
Receiver ID : 2800
VendorID=8086h, DeviceID=1096h, Bus=28h, Device=00h, Function=00h
Bad TLP :
Bad DLLP :
Receiver ID : 2801
VendorID=8086h, DeviceID=1096h, Bus=28h, Device=00h, Function=01h
Error of this Agent(2801) is reported first
- After:
pcieport-driver 0000:00:02.0: AER: Multiple Corrected error received: id=2801
e1000e 0000:28:00.0: PCIE Bus Error: severity=Corrected, type=Data Link Layer, id=2800(Receiver ID)
e1000e 0000:28:00.0: device [8086:1096] error status/mask=00000040/00000000
e1000e 0000:28:00.0: [ 6] Bad TLP
e1000e 0000:28:00.1: PCIE Bus Error: severity=Corrected, type=Data Link Layer, id=2801(Receiver ID)
e1000e 0000:28:00.1: device [8086:1096] error status/mask=000000c0/00000000
e1000e 0000:28:00.1: [ 6] Bad TLP
e1000e 0000:28:00.1: [ 7] Bad DLLP
e1000e 0000:28:00.1: Error of this Agent(2801) is reported first
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Compact struct and codes.
Cleanup.
Multiple bits might be set in the Uncorrectable Error Status
register. But aer_print_error_source() only report a error of
the lowest bit set in the error status register.
So print strings for all bits unmasked and set.
And check First Error Pointer to mark the error occured first.
This FEP is not valid when the corresponing bit of the Uncorrectable
Error Status register is not set, or unimplemented or undefined.
ERR_{,UN}CORRECTABLE_ERROR_MASK are set of error bits which linux know,
set of PCI_ERR_COR_* and PCI_ERR_UNC_* defined in linux/pci_regs.h.
This masks make aerdrv not to report errors of unknown bit, while aerdrv
have ability to report such undefined errors as "Unknown Error Bit %2d".
OTOH aerdrv_errprint does not have any check of setting in mask register.
So it could report masked wrong error by finding bit in status without
knowing that the bit is masked in the mask register.
This patch changes aerdrv to use mask state in mask register propely
instead of defined/hardcoded ERR_{,UN}CORRECTABLE_ERROR_MASK.
This change prevents aerdrv from reporting masked error, and also enable
reporting unknown errors.
Reviewed-by: Andrew Patterson <andrew.patterson@hp.com>
The static buffer errmsg_buff[] is used only for building error
message in fixed format, and is protected by a spinlock.
This patch removes this buffer and the spinlock.
The flag AER_MULTI_ERROR_VALID_FLAG in info->flag does mean that the
root port receives multiple error messages. Error messages can be
posted from different devices, so it does not mean that each reported
device has multiple errors.
If there are multiple error devices and the root port has valid error
source ID, it would be nice to report which device is the error source
reported first.
In case of multiple errors, struct aer_err_info would be reused among
all reported devices. So the info->status should be initialized before
recycled. Otherwise error of one device might be reported as the error
of another device. Also info->flags has similar problem on reporting
TLP header.
Definitions of MASK macros in aerdrv_errprint.c are tricky and unsafe.
For example, AER_AGENT_TRANSMITTER_MASK(_sev, _stat) does work like:
static inline func(int _sev, int _stat)
if (_sev == AER_CORRECTABLE)
return (_stat & (PCI_ERR_COR_REP_ROLL|PCI_ERR_COR_REP_TIMER));
else
return (_stat & PCI_ERR_COR_REP_ROLL);
In case of else path here, for uncorrectable errors, testing bits in
_stat by PCI_ERR_COR_* does not make sense because _stat should have only
PCI_ERR_UNC_* bits originated in uncorrectable error status register.
But at this time this is safe because uncorrectable error using bit
position same to PCI_ERR_COR_REP_ROLL(= bit position 8) is not defined.
Likewise, AER_AGENT_COMPLETER_MASK is always PCI_ERR_UNC_COMP_ABORT but
it works because bit 15 of correctable error status is not defined.
It means that these MASK macros will turn to be wrong once if new error
is defined. (In fact, bit 15 of correctable is now defined in PCIe 2.1)
This patch changes these MASK macros to be more strict, not to return
PCI_ERR_COR_* bits for uncorrectable error status and vise versa.
Add workaround macro to reduce the number of checkpatch warning:
WARNING: printk() should include KERN_ facility level
Before:
total: 0 errors, 10 warnings, 247 lines checked
After:
total: 0 errors, 1 warnings, 243 lines checked
Before:
drivers/pci/pcie/aer/aer_inject.c
total: 4 errors, 4 warnings, 473 lines checked
drivers/pci/pcie/aer/aerdrv.c
total: 5 errors, 2 warnings, 333 lines checked
drivers/pci/pcie/aer/aerdrv.h
total: 1 errors, 0 warnings, 139 lines checked
drivers/pci/pcie/aer/aerdrv_core.c
total: 4 errors, 3 warnings, 872 lines checked
drivers/pci/pcie/aer/aerdrv_errprint.c
total: 12 errors, 11 warnings, 248 lines checked
After:
total: 0 errors, 0 warnings, 466 lines checked
total: 0 errors, 0 warnings, 335 lines checked
total: 0 errors, 0 warnings, 139 lines checked
total: 0 errors, 0 warnings, 869 lines checked
Add ids module parameter which allows specifying initial IDs for the
pci-stub driver. When built into the kernel, pci-stub is linked
before any real pci drivers and by setting up IDs from initialization
it can prevent built-in drivers from attaching to specific devices.
While at it, make pci_stub_probe() print out about devices it grabbed
to weed out "but my controller isn't being probed" bug reports.
Separate out pci_add_dynid() from store_new_id() and export it so that
in-kernel code can add PCI IDs dynamically. As the function will be
available regardless of HOTPLUG, put it and pull pci_free_dynids()
outside of CONFIG_HOTPLUG.
This will be used by pci-stub to initialize initial IDs via module
param.
While at it, remove bogus get_driver() failure check.
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Add support for PCI-E 5.0 GT/s in max_bus_speed and cur_bus_speed.
Reviewed-by: Matthew Wilcox <matthew@wil.cx>
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Fix typo in PCI-E link speed.
The L0s state can be managed separately for each direction (upstream
direction and downstream direction) of the link. But in the current
implementation, those are mixed up. With this patch, L0s for each
direction are managed separately.
To maintain three states (upstream direction L0s, downstream L0s and
L1), 'aspm_support', 'aspm_enabled', 'aspm_capable', 'aspm_disable'
and 'aspm_default' fields in struct pcie_link_state are changed to
3-bit from 2-bit. The 'latency' field is separated to two 'latency_up'
and 'latency_dw' fields to maintain exit latencies for each direction
of the link. For L0, 'latency_up.l0' and 'latency_dw.l0' are used to
configure upstream direction L0s and downstream direction L0s
respectively. For L1, larger value of 'latency_up.l1' and
'latency_dw.l1' is considered as L1 exit latency.
Acked-by: Shaohua Li <shaohua.li@intel.com>
In the current implementation, ASPM L0s/L1 is disabled for all links
in the hierarchy if one of the link doesn't meet latency requirement.
But we can partially enable ASPM L0s/L1 on sub-tree in the hierarchy.
This patch allows partial L0s/L1 enablement in the hierarchy. And it
also reduce the calculation cost of ASPM configuration very much.
In the previous implementation, all links were enabled with the same
state. With this patch, enabled state for each link is determined
simply as follows (the 'requested' is from policy_to_aspm_state()).
enabled = requested & (link->aspm_capable & link->aspm_disable)
Introduce 'aspm_capable' field to maintain the capable ASPM setting of
the link. By the 'aspm_capable', we don't need to recheck latency
every time ASPM policy is changed.
Each bit in 'aspm_capable' is associated to ASPM state (L0S/L1). The
bit is set if the associated ASPM state is supported by the link and
it satisfies the latency requirement (i.e. exit latency < endpoint
acceptable latency). The 'aspm_capable' is updated when
- an endpoint device is added (boot time or hot-plug time)
- an endpoint device is removed (hot-unplug time)
- PCI power state is changed.
Introduce 'aspm_disable' flag to manage disabled ASPM state more
robust way.
Fix possible NULL dereference in pcie_aspm_exit_link_state(). This
patch also cleanup some code.
Remove the following check in __pcie_aspm_config_link() because it
nerver be true.
We must not clear bits in 'aspm_enabled' using 'aspm_support', or
'aspm_enabled' and 'aspm_default' might be different from the actual
state. In addtion, 'aspm_default' should be intialized even if
'aspm_support' is 0.
This patch adds the most recent additions to the list of 82576 device IDs
to the list of devices needing the SR-IOV quirk.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Document the new VGA arbiter.
Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com>
Fix some warnings reported in linux-next + also cleanup some
comment errors noticed by Pekka Paalanen.
By default, the EEH framework on powerpc does what's known as a "hot
reset" during recovery of a PCI Express device. We've found a case
where the device needs a "fundamental reset" to recover properly. The
current PCI error recovery and EEH frameworks do not support this
distinction.
The attached patch makes changes to EEH to utilize the new bit field.
Signed-off-by: Mike Mason <mmlnx@us.ibm.com>
Signed-off-by: Richard Lary <rlary@us.ibm.com>
The attached patch updates the Documentation/PCI/pci-error-recovery.txt
file with changes related to this new bit field, as well a few unrelated
updates.
Signed-off-by: Linas Vepstas <linasvepstas@gmail.com>
This is the first of three patches that implement a bit field that PCI
Express device drivers can use to indicate they need a fundamental reset
during error recovery.
distinction.
The attached patch (courtesy of Richard Lary) adds a bit field to
pci_dev that indicates whether the device requires a fundamental reset
during recovery.
These patches supersede the previously submitted patch that implemented
a fundamental reset bit field.
Background:
Graphic devices are accessed through ranges in I/O or memory space. While most
modern devices allow relocation of such ranges, some "Legacy" VGA devices
implemented on PCI will typically have the same "hard-decoded" addresses as
they did on ISA. For more details see "PCI Bus Binding to IEEE Std 1275-1994
Standard for Boot (Initialization Configuration) Firmware Revision 2.1"
Section 7, Legacy Devices.
The Resource Access Control (RAC) module inside the X server currently does
the task of arbitration when more than one legacy device co-exists on the same
machine. But the problem happens when these devices are trying to be accessed
by different userspace clients (e.g. two server in parallel). Their address
assignments conflict. Therefore an arbitration scheme _outside_ of the X
server is needed to control the sharing of these resources. This document
introduces the operation of the VGA arbiter implemented for Linux kernel.
Cleanups (nearly based on checkpatch).
Before: total: 11 errors, 2 warnings, 0 checks, 842 lines checked
After: total: 0 errors, 0 warnings, 0 checks, 842 lines checked
v2: fix it's/its mistakes in comment
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
Cleanup based on the prototype from Matthew Milcox.
Move it from the middle of the function to the end.
Unify msi_free_irqs() and msix_free_all_irqs(), and rename it to a
common void function free_msi_irqs().
And relocate the common function to where the prototype is located now.
use list_first_entry() instead of list_entry().
The msi_list never have MSI-X's msi_desc while MSI is enabled,
and also it never have MSI's msi_desc while MSI-X is enabled.
This patch remove check for MSI-X entry from the pci_disable_msi(),
referring that pci_disable_msix() does not have any check for MSI
entry.
This avoids a "Malformed early option 'iommu'" on boot when trying
to use pass-through mode.
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
IDs should generally only be added to pci_ids.h when they're shared
across several files in the tree. IDs that are just used by a single
driver should be defined in the driver instead.
Perhaps documenting this is a good idea to prevent things being moved there,
as it still seems to be happening judging from the git log.
(based on discussion w/gregkh and others).
Signed-off-by: Dave Jones <davej@redhat.com>
We already print it out for pci bridges, so also print it out for pci devices.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
http://bugzilla.kernel.org/show_bug.cgi?id=12542 reports that with the
quirk not applied on resume, msi stops working after resuming and mcp78s
ahci fails due to IRQ mis-delivery. Apply it on resume too.
Cc: Peer Chen <pchen@nvidia.com>
Cc: Tj <linux@tjworld.net>
Reported-by: Nicolas Derive <kalon33@ubuntu.com>
Cc: Greg KH <greg@kroah.com>
Cc: <stable@kernel.org>
Shut off the long standing
linux/drivers/pci/search.c:144: warning: 'pci_find_device' is deprecated (declared at linux/drivers/pci/search.c:136)
warnings that appear on every build when CONFIG_PCI_LEGACY is enabled.
gcc warns for the use in EXPORT_SYMBOL
I moved these to a separate file and disabled the warning in the Makefile for that file.
One more form factor for Compaq Evo D510, which needs the same quirk
as the other form factors. Apparently there's no hardware monitoring
chip on that one, but SPD EEPROMs, so it's still worth unhiding the
SMBus.
Tested-by: Nuzhna Pomoshch <nuzhna_pomoshch@yahoo.com>
Some devices allow an individual function to be reset without affecting
other functions in the same device: that's what pci_reset_function does.
For devices that have this support, expose reset attribite in sysfs.
This is useful e.g. for virtualization, where a qemu userspace
process wants to reset the device when the guest is reset,
to emulate machine reboot as closely as possible.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
We cannot simply call acpi_get_pci_dev() on any random ACPI handle
and hope that it works, because a PCI root bridge may not have
an associated struct pci_dev.
This is allowed per the PCI specification, and is referred to as a
non-materialized bridge.
So, depending on the type of PCI bridge that the handle points to,
use the appropriate interface to return the struct pci_bus correctly.
Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
We can simplify ACPI drivers if we can tell whether a handle is an
ACPI PCI root or not.
The current mp_bus_to_node array is initialized only by AMD specific
code, since AMD platforms have registers that can be used for
determining mode numbers. On new Intel platforms it's necessary to
initialize this array as well though, otherwise all PCI node numbers
will be 0, when in fact they should be -1 (indicating that I/O isn't
tied to any particular node).
So move the mp_bus_to_node code into the common PCI code, and
initialize it early with a default value of -1. This may be overridden
later by arch code (e.g. the AMD code).
With this change, PCI consistent memory and other node specific
allocations (e.g. skbuff allocs) should occur on the "current" node.
If, for performance reasons, applications want to be bound to specific
nodes, they should open their devices only after being pinned to the
CPU where they'll run, for maximum locality.
Acked-by: Yinghai Lu <yinghai@kernel.org>
Tested-by: Jesse Brandeburg <jesse.brandeburg@gmail.com>
yenta needs this for example.
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Instead of open-coding pci_find_parent_resource and request_resource,
just call pci_claim_resource.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
