Russ reported SGI UV is broken recently. He said:
| The SRAT table shows that memory range is spread over two nodes.
| SRAT: Node 0 PXM 0 100000000-800000000
| SRAT: Node 1 PXM 1 800000000-1000000000
| SRAT: Node 0 PXM 0 1000000000-1080000000
|Previously, the kernel early_node_map[] would show three entries
|with the proper node.
|[ 0.000000] 0: 0x00100000 -> 0x00800000
|[ 0.000000] 1: 0x00800000 -> 0x01000000
|[ 0.000000] 0: 0x01000000 -> 0x01080000
|The problem is recent community kernel early_node_map[] shows
|only two entries with the node 0 entry overlapping the node 1
|entry.
| 0: 0x00100000 -> 0x01080000
After looking at the changelog, Found out that it has been broken for a while by
following commit
|commit 8716273caef7f55f39fe4fc6c69c5f9f197f41f1
|Author: David Rientjes <rientjes@google.com>
|Date: Fri Sep 25 15:20:04 2009 -0700
| x86: Export srat physical topology
Before that commit, register_active_regions() is called for every SRAT memory
entry right away.
Use nodememblk_range[] instead of nodes[] in order to make sure we
capture the actual memory blocks registered with each node. nodes[]
contains an extended range which spans all memory regions associated
with a node, but that does not mean that all the memory in between are
included.
Reported-by: Russ Anderson <rja@sgi.com>
Tested-by: Russ Anderson <rja@sgi.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4CB27BDF.5000800@kernel.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: <stable@kernel.org> 2.6.33 .34 .35 .36
This fixes possible cases of not collecting valid error info in
the MCE error thresholding groups on F10h hardware.
The current code contains a subtle problem of checking only the
Valid bit of MSR0000_0413 (which is MC4_MISC0 - DRAM
thresholding group) in its first iteration and breaking out if
the bit is cleared.
But (!), this MSR contains an offset value, BlkPtr[31:24], which
points to the remaining MSRs in this thresholding group which
might contain valid information too. But if we bail out only
after we checked the valid bit in the first MSR and not the
block pointer too, we miss that other information.
The thing is, MC4_MISC0[BlkPtr] is not predicated on
MCi_STATUS[MiscV] or MC4_MISC0[Valid] and should be checked
prior to iterating over the MCI_MISCj thresholding group,
irrespective of the MC4_MISC0[Valid] setting.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
When the feature PTS is not supported by CPU, the sysfile
package_power_limit_count for package should not be
generated.
This patch is used for fixing missing { and }.
The patch is not complete as there are other error handling
problems in this function - but that can wait until the
merge window.
Signed-off-by: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Reviewed-by: Fenghua Yu <fenghua.yu@initel.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: Brown Len <len.brown@intel.com>
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: lm-sensors@lm-sensors.org <lm-sensors@lm-sensors.org>
LKML-Reference: <4C7625D1.4060201@np.css.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
HWPOISON: Stop shrinking at right page count
HWPOISON: Report correct address granuality for AO huge page errors
HWPOISON: Copy si_addr_lsb to user
page-types.c: fix name of unpoison interface
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
elevator: fix oops on early call to elevator_change()
* 'for-linus' of git://neil.brown.name/md:
md: check return code of read_sb_page
md/raid1: minor bio initialisation improvements.
md/raid1: avoid overflow in raid1 resync when bitmap is in use.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: don't drop handle reference on unload
drm/ttm: Fix two race conditions + fix busy codepaths
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: wacom - fix runtime PM related deadlock
Input: joydev - fix JSIOCSAXMAP ioctl
Input: uinput - setup MT usage during device creation
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: properly account for reclaimed inodes
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (37 commits)
V4L/DVB: v4l: radio: si470x: fix unneeded free_irq() call
V4L/DVB: v4l: videobuf: prevent passing a NULL to dma_free_coherent()
V4L/DVB: ir-core: Fix null dereferences in the protocols sysfs interface
V4L/DVB: v4l: s5p-fimc: Fix 3-planar formats handling and pixel offset error on S5PV210 SoCs
V4L/DVB: v4l: s5p-fimc: Fix return value on probe() failure
V4L/DVB: uvcvideo: Restrict frame rates for Chicony CNF7129 webcam
V4L/DVB: uvcvideo: Fix support for Medion Akoya All-in-one PC integrated webcam
V4L/DVB: ivtvfb: prevent reading uninitialized stack memory
V4L/DVB: cx25840: Fix typo in volume control initialization: 65335 vs. 65535
V4L/DVB: v4l: mem2mem_testdev: add missing release for video_device
V4L/DVB: v4l: mem2mem_testdev: fix errorenous comparison
V4L/DVB: mt9v022.c: Fixed compilation warning
V4L/DVB: mt9m111: added current colorspace at g_fmt
V4L/DVB: mt9m111: cropcap and s_crop check if type is VIDEO_CAPTURE
V4L/DVB: mx2_camera: fix a race causing NULL dereference
V4L/DVB: tm6000: bugfix data handling
V4L/DVB: gspca - sn9c20x: Bad transfer size of Bayer images
V4L/DVB: videobuf-dma-sg: set correct size in last sg element
V4L/DVB: cx231xx: Avoid an OOPS when card is unknown (card=0)
V4L/DVB: dvb: fix smscore_getbuffer() logic
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
of/i2c: Fix module load order issue caused by of_i2c.c
i2c: Fix checks which cause legacy suspend to never get called
i2c-pca: Fix waitforcompletion() return value
i2c: Fix for suspend/resume issue
i2c: Remove obsolete cleanup for clientdata
When proc_doulongvec_minmax() is used with an array of longs, and no
min/max check requested (.extra1 or .extra2 being NULL), we dereference a
NULL pointer for the second element of the array.
Noticed while doing some changes in network stack for the "16TB problem"
Fix is to not change min & max pointers in __do_proc_doulongvec_minmax(),
so that all elements of the vector share an unique min/max limit, like
proc_dointvec_minmax().
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Add Samsung S5P series FIMC(Camera Interface) maintainers.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
We need to check parent's thresholds if parent has use_hierarchy == 1 to
be sure that parent's threshold events will be triggered even if parent
itself is not active (no MEM_CGROUP_EVENTS).
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
During boot of a 16TB system, the following is printed:
Dentry cache hash table entries: -2147483648 (order: 22, 17179869184 bytes)
Signed-off-by: Robin Holt <holt@sgi.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
When we call the slab shrinker to free a page we need to stop at
page count one because the caller always holds a single reference, not zero.
This avoids useless looping over slab shrinkers and freeing too much
memory.
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
The SIGBUS user space signalling is supposed to report the
address granuality of a corruption. Pass this information correctly
for huge pages by querying the hpage order.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
The original hwpoison code added a new siginfo field si_addr_lsb to
pass the granuality of the fault address to user space. Unfortunately
this field was never copied to user space. Fix this here.
I added explicit checks for the MCEERR codes to avoid having
to patch all potential callers to initialize the field.
The page-types utility still uses an out of date name for the
unpoison interface: debugfs:hwpoison/renew-pfn
This patch renames and fixes it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
2.6.36 introduces an API for drivers to switch the IO scheduler
instead of manually calling the elevator exit and init functions.
This API was added since q->elevator must be cleared in between
those two calls. And since we already have this functionality
directly from use by the sysfs interface to switch schedulers
online, it was prudent to reuse it internally too.
But this API needs the queue to be in a fully initialized state
before it is called, or it will attempt to unregister elevator
kobjects before they have been added. This results in an oops
like this:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000051
IP: [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0
PGD 47ddfc067 PUD 47c6a1067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/0000:04:00.1/irq
CPU 2
Modules linked in: t(+) loop hid_apple usbhid ahci ehci_hcd uhci_hcd libahci usbcore nls_base igb
Pid: 7319, comm: modprobe Not tainted 2.6.36-rc6+ #132 QSSC-S4R/QSSC-S4R
RIP: 0010:[<ffffffff8116f15e>] [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0
RSP: 0018:ffff88027da25d08 EFLAGS: 00010246
RAX: ffff88047c68c528 RBX: 00000000fffffffe RCX: 0000000000000000
RDX: 000000000000002f RSI: 000000000000002f RDI: ffff88047e196c88
RBP: ffff88027da25d38 R08: 0000000000000000 R09: d84156c5635688c0
R10: d84156c5635688c0 R11: 0000000000000000 R12: ffff88047e196c88
R13: 0000000000000000 R14: 0000000000000000 R15: ffff88047c68c528
FS: 00007fcb0b26f6e0(0000) GS:ffff880287400000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000051 CR3: 000000047e76e000 CR4: 00000000000006e0
Process modprobe (pid: 7319, threadinfo ffff88027da24000, task ffff88027d377090)
Stack:
ffff88027da25d58 ffff88047c68c528 00000000fffffffe ffff88047e196c88
<0> ffff88047c68c528 ffff88047e05bd90 ffff88027da25d78 ffffffff8123fb77
<0> ffff88047e05bd90 0000000000000000 ffff88047e196c88 ffff88047c68c528
Call Trace:
[<ffffffff8123fb77>] kobject_add_internal+0xe7/0x1f0
[<ffffffff8123fd98>] kobject_add_varg+0x38/0x60
[<ffffffff8123feb9>] kobject_add+0x69/0x90
[<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0
[<ffffffff8103d48d>] ? sub_preempt_count+0x9d/0xe0
[<ffffffff8143de20>] ? _raw_spin_unlock+0x30/0x50
[<ffffffff8116eff4>] ? sysfs_remove_dir+0x34/0xa0
[<ffffffff81224204>] elv_register_queue+0x34/0xa0
[<ffffffff81224aad>] elevator_change+0xfd/0x250
[<ffffffffa007e000>] ? t_init+0x0/0x361 [t]
[<ffffffffa007e0a8>] t_init+0xa8/0x361 [t]
[<ffffffff810001de>] do_one_initcall+0x3e/0x170
[<ffffffff8108c3fd>] sys_init_module+0xbd/0x220
[<ffffffff81002f2b>] system_call_fastpath+0x16/0x1b
Code: e5 41 56 41 55 41 54 49 89 fc 53 48 83 ec 10 48 85 ff 74 52 48 8b 47 18 49 c7 c5 00 46 61 81 48 85 c0 74 04 4c 8b 68 30 45 31 f6 <41> 80 7d 51 00 74 0e 49 8b 44 24 28 4c 89 e7 ff 50 20 49 89 c6
RIP [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0
RSP <ffff88027da25d08>
---[ end trace a6541d3bf07945df ]---
Fix this by adding a registered bit to the elevator queue, which is
set when the sysfs kobjects have been registered.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
since the handle references are all tied to a file_priv, and when it disappears
all the handle refs go with it.
The fbcon ones we'd only notice on unload, but the nouveau notifier one
would would happen on reboot.
nouveau: Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
nouveau: Tested-by: Marc Dionne <marc.c.dionne@gmail.com>
i915 unload: Reported-by: Keith Packard <keithp@keithp.com>
Acked-by: Ben Skeggs <bskeggs@redhat.com>
When marking an inode reclaimable, a per-AG counter is increased, the
inode is tagged reclaimable in its per-AG tree, and, when this is the
first reclaimable inode in the AG, the AG entry in the per-mount tree
is also tagged.
When an inode is finally reclaimed, however, it is only deleted from
the per-AG tree. Neither the counter is decreased, nor is the parent
tree's AG entry untagged properly.
Since the tags in the per-mount tree are not cleared, the inode
shrinker iterates over all AGs that have had reclaimable inodes at one
point in time.
The counters on the other hand signal an increasing amount of slab
objects to reclaim. Since "70e60ce xfs: convert inode shrinker to
per-filesystem context" this is not a real issue anymore because the
shrinker bails out after one iteration.
But the problem was observable on a machine running v2.6.34, where the
reclaimable work increased and each process going into direct reclaim
eventually got stuck on the xfs inode shrinking path, trying to scan
several million objects.
Fix this by properly unwinding the reclaimable-state tracking of an
inode when it is reclaimed.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: stable@kernel.org
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
Function read_sb_page may return ERR_PTR(...). Check for it.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Cc: Neil Brown <neilb@suse.de>
Signed-off-by: NeilBrown <neilb@suse.de>
When performing a resync we pre-allocate some bios and repeatedly use
them. This requires us to re-initialise them each time.
One field (bi_comp_cpu) and some flags weren't being initiaised
reliably.
bitmap_start_sync returns - via a pass-by-reference variable - the
number of sectors before we need to check with the bitmap again.
Since commit ef4256733506f245 this number can be substantially larger,
2^27 is a common value.
Unfortunately it is an 'int' and so when raid1.c:sync_request shifts
it 9 places to the left it becomes 0. This results in a zero-length
read which the scsi layer justifiably complains about.
This patch just removes the shift so the common case becomes safe with
a trivially-correct patch.
In the next merge window we will convert this 'int' to a 'sector_t'
Reported-by: "George Spelvin" <linux@horizon.com>
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus:
MIPS: Octeon: Place cnmips_cu2_setup in __init memory.
MIPS: Don't place cu2 notifiers in __cpuinitdata
MIPS: Calculate VMLINUZ_LOAD_ADDRESS based on the length of vmlinux.bin
MIPS: Alchemy: Resolve prom section mismatches
MIPS: Fix syscall 64 bit number comments.
MIPS: Hookup fanotify_init, fanotify_mark, and prlimit64 syscalls.
MIPS: TX49xx: Rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN
MIPS: N32: Fix getdents64 syscall for n32
MIPS: Remove pr_<level> uses of KERN_<level>
MIPS: PNX8550: Sort out machine halt, restart and powerdown functions.
MIPS: GIC: Remove dependencies from Malta files.
MIPS: Kconfig: Fix and clarify kconfig help text for VSMP and SMTC.
MIPS: DMA: Fix computation of DMA flags from device's coherent_dma_mask.
MIPS: Audit: Fix hang in entry.S.
MIPS: Document why RELOC_HIDE is there.
MIPS: Octeon: Determine if helper needs to be built
MIPS: Use generic atomic64 for 32-bit kernels
MIPS: RM7000: Symbol should be static
MIPS: kspd: Adjust confusing if indentation
MIPS: Fix a typo.
writeback: always use sb->s_bdi for writeback purposes
git://xenbits.xen.org/people/sstabellini/linux-pvhvm
* 'v2.6.36-rc6-urgent-fixes' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm:
xen: do not initialize PV timers on HVM if !xen_have_vector_callback
xen: do not set xenstored_ready before xenbus_probe on hvm
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: Initialize total_len in fuse_retrieve()
Since powerpc uses -Werror on arch powerpc, the build was broken like
this:
cc1: warnings being treated as errors
arch/powerpc/kernel/module.c: In function 'module_finalize':
arch/powerpc/kernel/module.c:66: error: unused variable 'err'
This fixes a race pointed out by Dave Airlie where we don't take a buffer
object about to be destroyed off the LRU lists properly. It also fixes a rare
case where a buffer object could be destroyed in the middle of an
accelerated eviction.
The patch also adds a utility function that can be used to prematurely
release GPU memory space usage of an object waiting to be destroyed.
For example during eviction or swapout.
The above mentioned commit didn't queue the buffer on the delayed destroy
list under some rare circumstances. It also didn't completely honor the
remove_all parameter.
Fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=615505
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=591061
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: rcu_read_lock_bh_held(): disabling irqs also disables bh
generic-ipi: Fix deadlock in __smp_call_function_single
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf trace scripting: Fix extern struct definitions
perf ui hist browser: Fix segfault on 'a' for annotate
perf tools: Fix build breakage
perf, x86: Handle in flight NMIs on P4 platform
oprofile, ARM: Release resources on failure
oprofile: Add Support for Intel CPU Family 6 / Model 29
The "flags" member of "struct wait_queue_t" is used in several places in
the kernel code without beeing initialized by init_wait(). "flags" is
used in bitwise operations.
If "flags" not initialized then unexpected behaviour may take place.
Incorrect flags might used later in code.
Added initialization of "wait_queue_t.flags" with zero value into
"init_wait".
Signed-off-by: Evgeny Kuznetsov <EXT-Eugeny.Kuznetsov@nokia.com>
[ The bit we care about does end up being initialized by both
prepare_to_wait() and add_to_wait_queue(), so this doesn't seem to
cause actual bugs, but is definitely the right thing to do -Linus ]
With all the recent module loading cleanups, we've minimized the code
that sits under module_mutex, fixing various deadlocks and making it
possible to do most of the module loading in parallel.
However, that whole conversion totally missed the rather obscure code
that adds a new module to the list for BUG() handling. That code was
doubly obscure because (a) the code itself lives in lib/bugs.c (for
dubious reasons) and (b) it gets called from the architecture-specific
"module_finalize()" rather than from generic code.
Calling it from arch-specific code makes no sense what-so-ever to begin
with, and is now actively wrong since that code isn't protected by the
module loading lock any more.
So this commit moves the "module_bug_{finalize,cleanup}()" calls away
from the arch-specific code, and into the generic code - and in the
process protects it with the module_mutex so that the list operations
are now safe.
Future fixups:
- move the module list handling code into kernel/module.c where it
belongs.
- get rid of 'module_bug_list' and just use the regular list of modules
(called 'modules' - imagine that) that we already create and maintain
for other reasons.
Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Adrian Bunk <bunk@kernel.org>
if !xen_have_vector_callback do not initialize PV timer unconditionally
because we still don't know how many cpus are available and if there is
more than one we won't be able to receive the timer interrupts on
cpu > 0.
This patch fixes an hang at boot when Xen does not support vector
callbacks and the guest has multiple vcpus.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
Register_xenstore_notifier should guarantee that the caller gets
notified even if xenstore is already up.
Therefore we revert "do not notify callers from
register_xenstore_notifier" and set xenstored_read at the right time for
PV on HVM guests too.
In fact in case of PV on HVM guests xenstored is ready only after the
platform pci driver has completed the initialization, so do not set
xenstored_ready before the call to xenbus_probe().
This patch fixes a shutdown_event watcher registration bug that causes
"xm shutdown" not to work properly.
When runtime PM is enabled by default for input devices, X hangs in
wacom open:
[<ffffffff814a00ea>] mutex_lock+0x1a/0x40
[<ffffffffa02bc94b>] wacom_resume+0x3b/0x90 [wacom]
[<ffffffff81327a32>] usb_resume_interface+0xd2/0x190
[<ffffffff81327b5d>] usb_resume_both+0x6d/0x110
[<ffffffff81327c24>] usb_runtime_resume+0x24/0x40
[<ffffffff8130a2cf>] __pm_runtime_resume+0x26f/0x450
[<ffffffff8130a23a>] __pm_runtime_resume+0x1da/0x450
[<ffffffff8130a53a>] pm_runtime_resume+0x2a/0x50
[<ffffffff81328176>] usb_autopm_get_interface+0x26/0x60
[<ffffffffa02bc626>] wacom_open+0x36/0x90 [wacom]
wacom_open() takes wacom->lock and calls usb_autopm_get_interface(),
which in turn calls wacom_resume() which tries to acquire the lock
again.
The fix is to call usb_autopm_get_interface() first, before we take
the lock.
Since we do not do usb_autopm_put_interface() until wacom_close()
is called runtime PM is effectively disabled for the driver, however
changing it now would risk regressions so the complete fix will
have to wait till the next merge window.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Acked-by: Oliver Neukum <oneukum@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
regulator: max8649 - fix setting extclk_freq
regulator: fix typo in current units
regulator: fix device_register() error handling
* 'merge-powerpc' of git://git.secretlab.ca/git/linux-2.6:
powerpc/5200: tighten up ac97 reset timing
powerpc/5200: efika.c: Add of_node_put to avoid memory leak
powerpc/512x: fix clk_get() return value
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'fix/misc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: i2c/other/ak4xx-adda: Fix a compile warning with CONFIG_PROCFS=n
ALSA: prevent heap corruption in snd_ctl_new()
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: f71882fg: use a muxed resource lock for the Super I/O port
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Fix memory leaks in pcc_cpufreq_do_osc
[CPUFREQ] acpi-cpufreq: add missing __percpu markup
* 'merge-spi' of git://git.secretlab.ca/git/linux-2.6:
of/spi: Fix OF-style driver binding of spi devices
spi: spi-gpio.c tests SPI_MASTER_NO_RX bit twice, but not SPI_MASTER_NO_TX
spi/mpc8xxx: fix buffer overrun on large transfers
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
vlan: dont drop packets from unknown vlans in promiscuous mode
Phonet: Correct header retrieval after pskb_may_pull
um: Proper Fix for f25c80a4: remove duplicate structure field initialization
ip_gre: Fix dependencies wrt. ipv6.
net-2.6: SYN retransmits: Add new parameter to retransmits_timed_out()
iwl3945: queue the right work if the scan needs to be aborted
mac80211: fix use-after-free
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel
* 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel:
drm/i915: Rephrase pwrite bounds checking to avoid any potential overflow
drm/i915: Sanity check pread/pwrite
drm/i915: Use pipe state to tell when pipe is off
drm/i915: vblank status not valid while training display port
drivers/gpu/drm/i915/i915_gem.c: Add missing error handling code
drm/i915: Fix refleak during eviction.
drm/i915: fix GMCH power reporting
Building under memory pressure, with KSM on 2.6.36-rc5, collapsed with
an internal compiler error: typically indicating an error in swapping.
Perhaps there's a timing issue which makes it now more likely, perhaps
it's just a long time since I tried for so long: this bug goes back to
KSM swapping in 2.6.33.
Notice how reuse_swap_page() allows an exclusive page to be reused, but
only does SetPageDirty if it can delete it from swap cache right then -
if it's currently under Writeback, it has to be left in cache and we
don't SetPageDirty, but the page can be reused. Fine, the dirty bit
will get set in the pte; but notice how zap_pte_range() does not bother
to transfer pte_dirty to page_dirty when unmapping a PageAnon.
If KSM chooses to share such a page, it will look like a clean copy of
swapcache, and not be written out to swap when its memory is needed;
then stale data read back from swap when it's needed again.
We could fix this in reuse_swap_page() (or even refuse to reuse a
page under writeback), but it's more honest to fix my oversight in
KSM's write_protect_page(). Several days of testing on three machines
confirms that this fixes the issue they showed.
2.6.36-rc1 commit 21d0d443cdc1658a8c1484fdcece4803f0f96d0e "rmap:
resurrect page_address_in_vma anon_vma check" was right to resurrect
that check; but now that it's comparing anon_vma->roots instead of
just anon_vmas, there's a danger of oopsing on a NULL anon_vma.
In most cases no NULL anon_vma ever gets here; but it turns out that
occasionally KSM, when enabled on a forked or forking process, will
itself call page_address_in_vma() on a "half-KSM" page left over from
an earlier failed attempt to merge - whose page_anon_vma() is NULL.
It's my bug that those should be getting here at all: I thought they
were already dealt with, this oops proves me wrong, I'll fix it in
the next release - such pages are effectively pinned until their
process exits, since rmap cannot find their ptes (though swapoff can).
For now just work around it by making page_address_in_vma() safe (and
add a comment on why that check is wanted anyway). A similar check
in __page_check_anon_rmap() is safe because do_page_add_anon_rmap()
already excluded KSM pages.
