2006-03-21[ARM] Rename chipdata to 'base' and make it an iomem pointerRussell King
In all current use cases, "chipdata" is used to store an iomem address. Mark it with __iomem, and rename it to 'base'. Leave the accessor macros alone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Move IRQ enable after coprocessor number decodeRussell King
Allow the individual coprocessor handlers to decide when to enable interrupts, rather than unconditionally enabling them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Remove unnecessary asm/hardware.h includesRussell King
asm/hardware.h is not required for the majority of processor support files, ioremap support, mm initialisation, acorn IO support, nor the debug code (which picks up its machine specific includes via debug-macros.S) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Fix HZ definition for OMAP without 32K timerRussell King
Unfortunately, OMAP platforms without the 32K timer left HZ set to an empty value. Fix this by making the dependency on OMAP_32K_TIMER rather than OMAP_32K_TIMER_HZ. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Remove asm/arch/irq.hRussell King
asm/arch/irq.h used to be included from asm/irq.h, but was removed from the ARM kernel a long time ago. Consequently, the contents of asm/arch/irq.h (which mostly contain a definition for fixup_irq()) have not been used. Hence, remove asm/arch/irq.h. Some machine support files incorrectly included this file, making little or no use of the contents. Move the contents to a local include file, and remove those include statements as well. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Move HZ definition into KconfigRussell King
Move the HZ definition into Kconfig, and set appropriate defaults for platforms. Remove mostly empty asm/arch/param.h include file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21Merge master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6: [CRYPTO] aes: Fixed array boundary violation [CRYPTO] tcrypt: Fix key alignment [CRYPTO] all: Add missing cra_alignmask [CRYPTO] all: Use kzalloc where possible [CRYPTO] api: Align tfm context as wide as possible [CRYPTO] twofish: Use rol32/ror32 where appropriate
2006-03-21Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (235 commits) [NETFILTER]: Add H.323 conntrack/NAT helper [TG3]: Don't mark tg3_test_registers() as returning const. [IPV6]: Cleanups for net/ipv6/addrconf.c (kzalloc, early exit) v2 [IPV6]: Nearly complete kzalloc cleanup for net/ipv6 [IPV6]: Cleanup of net/ipv6/reassambly.c [BRIDGE]: Remove duplicate const from is_link_local() argument type. [DECNET]: net/decnet/dn_route.c: fix inconsequent NULL checking [TG3]: make drivers/net/tg3.c:tg3_request_irq() static [BRIDGE]: use LLC to send STP [LLC]: llc_mac_hdr_init const arguments [BRIDGE]: allow show/store of group multicast address [BRIDGE]: use llc for receiving STP packets [BRIDGE]: stp timer to jiffies cleanup [BRIDGE]: forwarding remove unneeded preempt and bh diasables [BRIDGE]: netfilter inline cleanup [BRIDGE]: netfilter VLAN macro cleanup [BRIDGE]: netfilter dont use __constant_htons [BRIDGE]: netfilter whitespace [BRIDGE]: optimize frame pass up [BRIDGE]: use kzalloc ...
2006-03-21Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (81 commits) [PATCH] USB: omninet: fix up debugging comments [PATCH] USB serial: add navman driver [PATCH] USB: Fix irda-usb use after use [PATCH] USB: rtl8150 small fix [PATCH] USB: ftdi_sio: add Icom ID1 USB product and vendor ids [PATCH] USB: cp2101: add new device IDs [PATCH] USB: fix check_ctrlrecip to allow control transfers in state ADDRESS [PATCH] USB: vicam.c: fix a NULL pointer dereference [PATCH] USB: ZC0301 driver bugfix [PATCH] USB: add support for Creativelabs Silvercrest USB keyboard [PATCH] USB: storage: new unusual_devs.h entry: Mitsumi 7in1 Card Reader [PATCH] USB: storage: unusual_devs.h entry 0420:0001 [PATCH] USB: storage: another unusual_devs.h entry [PATCH] USB: storage: sandisk unusual_devices entry [PATCH] USB: fix initdata issue in isp116x-hcd [PATCH] USB: usbcore: usb_set_configuration oops (NULL ptr dereference) [PATCH] USB: usbcore: Don't assume a USB configuration includes any interfaces [PATCH] USB: ub 03 drop stall clearing [PATCH] USB: ub 02 remove diag [PATCH] USB: ub 01 remove first_open ...
2006-03-21Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (23 commits) [PATCH] sysfs: fix a kobject leak in sysfs_add_link on the error path [PATCH] sysfs: don't export dir symbols [PATCH] get_cpu_sysdev() signedness fix [PATCH] kobject_add_dir [PATCH] debugfs: Add debugfs_create_blob() helper for exporting binary data [PATCH] sysfs: fix problem with duplicate sysfs directories and files [PATCH] Kobject: kobject.h: fix a typo [PATCH] Kobject: provide better warning messages when people do stupid things [PATCH] Driver core: add macros notice(), dev_notice() [PATCH] firmware: fix BUG: in fw_realloc_buffer [PATCH] sysfs: kzalloc conversion [PATCH] fix module sysfs files reference counting [PATCH] add EXPORT_SYMBOL_GPL_FUTURE() to USB subsystem [PATCH] add EXPORT_SYMBOL_GPL_FUTURE() to RCU subsystem [PATCH] add EXPORT_SYMBOL_GPL_FUTURE() [PATCH] Clean up module.c symbol searching logic [PATCH] kobj_map semaphore to mutex conversion [PATCH] kref: avoid an atomic operation in kref_put() [PATCH] handle errors returned by platform_get_irq*() [PATCH] driver core: platform_get_irq*(): return -ENXIO on error ...
2006-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: README: bzip2 is not new Documentation/Changes: remove outdated translation references remove dead Radeon URL SCSI_AACRAID: add a help text update the i386 defconfig MAINTAINERS: remove the LANMEDIA entry Move ip2.c and ip2main.c to drivers/char/ip2/ where the other files
2006-03-21Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Update defconfigs. [MIPS] Separate CPU entries in /proc/cpuinfo with a blank line. [MIPS] sys_mmap2 offset argument should always be shifted 12, not PAGE_SHIFT. [MIPS] TX49XX has prefetch. [MIPS] Kill tlb-andes.c. [MIPS] War on whitespace: cleanup initial spaces followed by tabs. [MIPS] Makefile crapectomy. [MIPS] Reformat __xchg(). [MIPS] Mention Broadcom part number for BigSur board [MIPS] Remove CONFIG_BUILD_ELF64. [MIPS] Further sparsification for 32-bit compat code. [MIPS] fix wrong __user usage in _sysn32_rt_sigsuspend [MIPS] Signal cleanup [MIPS] Reformat all of signal32.c with tabs instead of space for consistency [MIPS] Delete unused sys32_waitpid. [MIPS] Make I/O helpers more customizable [MIPS] Symmetric Uniprocessor support for Qemu. [MIPS] sc-rm7k.c cleanup [MIPS] MIPS64 R2 optimizations for 64-bit endianess swapping. [MIPS] Add early console for Cobalt.
2006-03-21Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: (47 commits) IB/mthca: Query SRQ srq_limit fixes IPoIB: Get rid of useless test of queue length IB/mthca: Correct reported SRQ size in MemFree case. IB/mad: Fix oopsable race on device removal IB/srp: Coverity fix to srp_parse_options() IB/mthca: Coverity fix to mthca_init_eq_table() IB: Coverity fixes to sysfs.c IPoIB: Move ipoib_ib_dev_flush() to ipoib workqueue IPoIB: Fix build now that neighbour destructor is in neigh_params IB/uverbs: Use correct alt_pkey_index in modify QP IB/umad: Add support for large RMPP transfers IB/srp: Add SCSI host attributes to show target port IB/cm: Check cm_id state before handling a REP IB/mthca: Update firmware versions IB/mthca: Optimize large messages on Sinai HCAs IB/uverbs: Fix query QP return of sq_sig_all IB: Fix modify QP checking of "current QP state" attribute IPoIB: Fix multicast race between canceling and completing IPoIB: Clean up if posting receives fails IB/mthca: Use an enum for HCA page size ...
2006-03-21Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] Fix cosmetic typo in asm/irq.h [ARM] 3367/1: CLCD mode no longer supported on the RealView boards [ARM] 3366/1: Allow the 16bpp mode configuration in the CLCD control register
2006-03-21Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: (112 commits) [libata] sata_mv: fix irq port status usage [PATCH] libata: move IDENTIFY info printing from ata_dev_read_id() to ata_dev_configure() [PATCH] libata: use local *id instead of dev->id in ata_dev_configure() [PATCH] libata: check Word 88 validity in ata_id_xfer_mask() [PATCH] libata: fix class handling in ata_bus_probe() [PATCH] ahci: enable prefetching for PACKET commands libata: turn on ATAPI by default [PATCH] sata_sil24: lengthen softreset timeout [PATCH] sata_sil24: exit early from softreset if SStatus reports no device [PATCH] libata: fix missing classes[] initialization in ata_bus_probe() [PATCH] libata: kill unused xfer_mode functions [PATCH] libata: reimplement ata_set_mode() using xfer_mask helpers [PATCH] libata: use xfer_mask helpers in ata_dev_set_mode() [PATCH] libata: use ata_id_xfermask() in ata_dev_configure() [PATCH] libata: add xfer_mask handling functions [PATCH] libata: improve xfer mask constants and update ata_mode_string() [PATCH] libata: rename ATA_FLAG_FLUSH_PIO_TASK to ATA_FLAG_FLUSH_PORT_TASK [PATCH] libata: kill unused pio_task and packet_task [PATCH] libata: convert pio_task and packet_task to port_task [PATCH] libata: implement port_task ...
2006-03-21Merge kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb.git with fixupsLinus Torvalds
This merges the DVB tree, but fixes up the history that had gotten screwed up by a broken commit. The history is fixed up by re-doing the commit properly (taking the resolve from the final result of the original), and then cherry-picking the commits that followed the broken merge. * dvb: (190 commits) V4L/DVB (3545): Fixed no_overlay option and quirks on saa7134 driver V4L/DVB (3543): Fix Makefile to adapt to bt8xx/ conversion V4L/DVB (3538): Bt8xx documentation update V4L/DVB (3537a): Whitespace cleanup V4L/DVB (3533): Add WSS (wide screen signalling) module parameters V4L/DVB (3532): Moved duplicated code of ALPS BSRU6 tuner to a standalone file. V4L/DVB (3530): Kconfig: remove VIDEO_AUDIO_DECODER V4L/DVB (3529): Kconfig: add menu items for cs53l32a and wm8775 A/D converters V4L/DVB (3528): Kconfig: fix ATSC frontend menu item names by manufacturer V4L/DVB (3527): VIDEO_CPIA2 must depend on USB V4L/DVB (3525): Kconfig: remove VIDEO_DECODER V4L/DVB (3524): Kconfig: add menu items for saa7115 and saa7127 V4L/DVB (3494): Kconfig: select VIDEO_MSP3400 to build msp3400.ko V4L/DVB (3522): Fixed a trouble with other PAL standards V4L/DVB (3521): Avoid warnings at video-buf.c V4L/DVB (3514): SAA7113 doesn't have auto std chroma detection mode V4L/DVB (3513): Remove saa711x driver V4L/DVB (3509): Make a needlessly global function static. V4L/DVB (3506): Cinergy T2 dmx cleanup on disconnect V4L/DVB (3504): Medion 7134: Autodetect second bridge chip ... Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21V4L/DVB (3545): Fixed no_overlay option and quirks on saa7134 driverMauro Carvalho Chehab
Some chipsets have several problems when pci to pci transfers are activated on overlay mode. the option no_overlay allows disabling such feature of the driver, in favor of keeping the system stable. The default is to use pcipci_fail flag defined on drivers/pci/quirks.c. It also allows the user to override it by forcing disable overlay or forcing enable. Forcing enable may generate PCI transfer corruption, including disk mass corruption, so should be used with care. Added a text description to this option and make messages looks the same at both bttv and saa7134 drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3543): Fix Makefile to adapt to bt8xx/ conversionManu Abraham
Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3538): Bt8xx documentation updateUwe Bugla
Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3537a): Whitespace cleanupMauro Carvalho Chehab
2006-03-21V4L/DVB (3533): Add WSS (wide screen signalling) module parametersOliver Endriss
Add wss_cfg_4_3 and wss_cfg_16_9 configuration options. Firmware 2623 or later required. Both parameters are bit masks: - bit 15: disable WSS - bit 14: send short WSS burst, then turn off WSS - bit 13..0: WSS bits as specified by the standard These parameters are useful if you own a broken tv set which does not handle wss correctly. Default settings: - wss_cfg_4_3: 0x4008 - wss_cfg_16_9: 0x0007 These should work with most devices. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3532): Moved duplicated code of ALPS BSRU6 tuner to a standalone file.Perceval Anichini
Moved duplicated code of ALPS BSRU6 tuner to a standalone file. Modified av7110 and budget drivers to include the new file. Signed-off-by: Perceval Anichini <perceval.anichini@streamvision.fr> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3530): Kconfig: remove VIDEO_AUDIO_DECODERMichael Krufky
- removed VIDEO_AUDIO_DECODER Kconfig menu item. VIDEO_MSP3400, VIDEO_CS53L32A and VIDEO_WM8775 now each have their own menu items. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3529): Kconfig: add menu items for cs53l32a and wm8775 A/D convertersMichael Krufky
- created Kconfig item, VIDEO_CS53L32A, for the cs53l32a module which supports the Cirrus Logic CS53L32A Low Voltage Stereo A/D Converter. - created Kconfig item, VIDEO_WM8775, for the wm8775 module which supports the Wolfson Microelectronics WM8775 high performance stereo A/D Converter. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3528): Kconfig: fix ATSC frontend menu item names by manufacturerMichael Krufky
- Corrected typo for NxtWave NXT200X - Added "Oren" manufacturer name to menu items for OR51132 and OR51211 - Removed "(pcHDTV HDx000 card)" from Oren frontends menu item names, This isn't necessary, as these frontends are selected by the card drivers, build configuration (DVB_BT8XX and VIDEO_CX88_DVB). Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3527): VIDEO_CPIA2 must depend on USBAdrian Bunk
CONFIG_VIDEO_CPIA2=y, CONFIG_USB=n results in the following compile <-- snip --> ... LD .tmp_vmlinux1 drivers/built-in.o: In function `set_alternate':cpia2_usb.c:(.text+0x443aa2): undefined reference to `usb_set_interface' drivers/built-in.o: In function `cpia2_usb_stream_resume': undefined reference to `usb_alloc_urb' drivers/built-in.o: In function `cpia2_usb_stream_resume': undefined reference to `usb_submit_urb' drivers/built-in.o: In function `cpia2_usb_stream_pause': undefined reference to `usb_kill_urb' drivers/built-in.o: In function `cpia2_usb_stream_pause': undefined reference to `usb_free_urb' drivers/built-in.o: In function `cpia2_usb_disconnect':cpia2_usb.c:(.text+0x443e14): undefined reference to `usb_driver_release_interface' drivers/built-in.o: In function `cpia2_usb_transfer_cmd': undefined reference to `usb_control_msg' drivers/built-in.o: In function `cpia2_usb_transfer_cmd': undefined reference to `usb_control_msg' drivers/built-in.o: In function `cpia2_usb_complete':cpia2_usb.c:(.text+0x444836): undefined reference to `usb_submit_urb' drivers/built-in.o: In function `cpia2_usb_cleanup': undefined reference to `usb_deregister' drivers/built-in.o: In function `cpia2_usb_init': undefined reference to `usb_register_driver' Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3525): Kconfig: remove VIDEO_DECODERMichael Krufky
- removed VIDEO_DECODER Kconfig menu item. VIDEO_CX25840, VIDEO_SAA711X and VIDEO_SAA7127 now each have their own menu items. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3524): Kconfig: add menu items for saa7115 and saa7127Michael Krufky
- created Kconfig menu item, VIDEO_SAA711X, for the saa7115 module, which supports SAA7113, SAA7114 and SAA7115 video decoders. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3494): Kconfig: select VIDEO_MSP3400 to build msp3400.koMichael Krufky
The msp3400 driver is currently only being built if the bttv driver is selected. There are new drivers that will be needing msp3400, so simply including msp3400 in the Makefile is no longer appropriate. This patch creates VIDEO_MSP3400, and alters VIDEO_BT848, VIDEO_PVRUSB2 and VIDEO_AUDIO_DECODER each to select VIDEO_MSP3400. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3522): Fixed a trouble with other PAL standardsMauro Carvalho Chehab
V4L2_STD_PAL define is not correct. It specifies only 50Hz PAL standards. This patch fixes saa7113 color config for other PAL video standards. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3521): Avoid warnings at video-buf.cMauro Carvalho Chehab
2006-03-21V4L/DVB (3514): SAA7113 doesn't have auto std chroma detection modeMauro Carvalho Chehab
This patch makes chroma standard selection based at possible values, according with datasheet. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3513): Remove saa711x driverMauro Carvalho Chehab
Now, em28xx uses saa7115 instead of saa711x. saa7115 driver is capable of handling saa 7113, 7114 and 7115. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3509): Make a needlessly global function static.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3506): Cinergy T2 dmx cleanup on disconnectMarkus Rechberger
Detaching the device didn't clean up several device files in /dev/dvb, after applying that patch all dvb devices disappeared as expected. Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3504): Medion 7134: Autodetect second bridge chipMichael Krufky
The device, Medion 7134, has two saa7134 chips on it, but only one of them is functional in the current saa7134 driver. This patch adds autodetection for the second, unsupported saa7134 chip, as SAA7134_BOARD_MD7134_BRIDGE_2, and displays a message to the user (in dmesg) indicating that the second chip isn't yet functional. This is useful for users, since two instances of the saa7134 driver will spawn. This patch will prevent confusion by warning the user that only one of the chips on the board are functional. There are other versions of the SAA7134_BOARD_MD7134 with only a single saa7134 bridge/decoder -- those devices will not be affected by this patch. Only devices containing the second chip will display the warning. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3503): Whitespace: fix incorrect indentation of curly bracketMichael Krufky
2006-03-21V4L/DVB (3502): Saa7134: make unsupported secondary decoder message genericMichael Krufky
There are already some supported devices that contain two saa713x chips on-board, where only one of these chips is currently functional in the driver. We are already printing a warning message for the second saa7134 decoder in SAA7134_BOARD_AVERMEDIA_A169_B. This patch alters that case to make it generic, so that other cards in the same situation can use it. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3501): Dmxdev: use dvb_ringbufferAndreas Oberritter
Use dvb_ringbuffer instead of an own buffer implementation in dmxdev.[ch]. Signed-off-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3500): Ringbuffer: don't reset pointers to zeroAndreas Oberritter
Oliver Endriss spotted, that resetting read and write pointers on flush() requires additional locking and breaks the av7110 driver. Therefore this patch partially reverts the previous patch titled "make dvb_ringbuffer compatible to dmxdev_buffer". Signed-off-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3499): Fix a bug when more than MAXBOARDS were plugged on em28xxMauro Carvalho Chehab
Coverity reported a bug at checking max number of supported boards by em28xx init code. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3497): Remove redundant makefile inclusion of tuner.oMichael Krufky
VIDEO_MXB selects VIDEO_TUNER, so we don't have to include tuner.o in the Makefile. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3496): Cpia2: move Kconfig build logic into cpia2/KconfigMichael Krufky
2006-03-21V4L/DVB (3495): Kconfig: select VIDEO_CX25840 to build cx25840 a/v decoder ↵Michael Krufky
module The cx25840 module requires external firmware in order to function, so it must select FW_LOADER, but saa7115 and saa7129 do not require it. This patch creates VIDEO_CX25840, and alters VIDEO_DECODER to select it. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3488): Snd_cx88_create: don't dereference NULL coreDuncan Sands
If the call to cx88_core_get returns a NULL value, it is dereferenced by cx88_reset, and perhaps by cx88_core_put. Spotted by the Coverity checker. Signed-off-by: Duncan Sands <baldrick@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3485): BUG_ON() Conversion in drivers/video/mediaEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3484): Make dvb_ringbuffer compatible to dmxdev_bufferAndreas Oberritter
Added variable 'error' to struct dvb_ringbuffer, which is set to zero on init() and flush(). Also reset read an write pointers to zero on flush() to get less fragmented data. Signed-off-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3479): Cleanup mangled whitespaceMichael Krufky
2006-03-21V4L/DVB (3449): Cx88 default picture controls valuesMarcin Rudowski
This patch fixes default values for some picture controls: - brightness set to 50% by default (now is 0%) - hue set to 50% by default (now is 0%) - sets saturation to datasheet value - volume set to 0dB (now is -32dB) and some left small fixes: - twice offset adding - balance didn't follow datasheet (bits[0:5] = attenuation; bit[6] = channel to provide attenuation) Signed-off-by: Marcin Rudowski <mar_rud@poczta.onet.pl> Signed-off-by: Ian Pickworth <ian@pickworth.me.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3448): Cx88-input.c: add IR remote control support to ↵Matheus Izvekov
CX88_BOARD_PROLINK_PLAYTVPVR This patch adds support for the IR remote control found in the card CX88_BOARD_PROLINK_PLAYTVPVR. Signed-off-by: Matheus Izvekov <mizvekov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
