Use the reserved by never used NETLINK_SKIP value instead.
Signed-off-by: Cal Peake <cp@absolutedigital.net>
Patch from Lucas Correia Villa Real
This patch replaces the sizeof()'s %d specifier by %ld on a S3C2410 DMA
printk.
Signed-off-by: Lucas Correia Villa Real <lucasvr@gobolinux.org>
http://bugzilla.kernel.org/show_bug.cgi?id=4534
Signed-off-by: Luming Yu <luming.yu@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
It is no longer valid to not replace instructions, since we depend on
different behaviour depending on CPU capabilities.
If you need to limit the capabilities of the replacements (because the
boot CPU has features that non-boot CPU's do not have, for example), you
need to explicitly disable those capabilities that are not shared across
all CPU's.
For example, if your boot CPU has FXSR, but other CPU's in your system
do not, you need to use the "nofxsr" kernel command line, not disable
instruction replacement per se.
This one ends up using an inline asm format that claims to read memory
and then clobber it (rather than just write it directly), which made it
easier to use the existing "alternative_input()" infrastructure support.
Now the fxsave code matches the fxrstor.
More unusable TCF_META_* match types that need to get eliminated
before 2.6.13 goes out the door.
Acked-by: Thomas Graf <tgraf@suug.ch>
It's really just a single instruction, conditional on whether the CPU
supports FXSR or not, so implement it as such instead of making it a
function that queries FXSR dynamically.
This means that the instruction just gets automatically rewritten to the
correct one at boot-time.
I broke this in the patch that consolidated MAC logging.
on unload
Fixes a crash when unloading ip_conntrack.
The portptr pointing to the port in the conntrack tuple is declared static,
which could result in memory corruption when two packets of the same
protocol are NATed at the same time and one conntrack goes away.
Already fixed in ip_queue, ip6_queue was missed.
These days %gs is normally the TLS segment, so it's no longer zero. As
a result, we shouldn't just assume that %fs/%gs tend to be zero
together, but test them independently instead.
Also, fix setting of debug registers to use the "next" pointer instead
of "current". It so happens that the scheduler will have set the new
current pointer before calling __switch_to(), but that's just an
implementation detail.
It won't exist any longer when we shrink the SKB in 2.6.14,
and we should kill this off before anyone in userspace starts
using it.
Signed-off-by: Loic Le Loarer <loic.le-loarer+lk@polytechnique.org>
If a connection tracking helper tells us to expect a connection, and
we're already expecting that connection, we simply free the one they
gave us and return success.
The problem is that NAT helpers (eg. FTP) have to allocate the
expectation first (to see what port is available) then rewrite the
packet. If that rewrite fails, they try to remove the expectation,
but it was freed in ip_conntrack_expect_related.
This is one example of a larger problem: having registered the
expectation, the pointer is no longer ours to use. Reference counting
is needed for ctnetlink anyway, so introduce it now.
To have a single "put" path, we need to grab the reference to the
connection on creation, rather than open-coding it in the caller.
mailbox converted to pci_alloc_consistent()
- request_region() is not needed: zatm_init_one() issues
pci_request_regions();
- the warning related to kfree(zatm_dev->mbx_start) disappears;
Compiled with i386 and sparc64 as target.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
It was overwriting the computer n->tc_verd value over
and over with skb->tc_verd, by mistake.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
NETCONSOLE=y and INET=n results in the following compile error:
net/built-in.o: In function `netpoll_parse_options':
: undefined reference to `in_aton'
BRIDGE_EBT_ARPREPLY=y and INET=n results in the following compile error:
net/built-in.o: In function `ebt_target_reply':
ebt_arpreply.c:(.text+0x68fb9): undefined reference to `arp_send'
make: *** [.tmp_vmlinux1] Error 1
Signed-off-by: Duncan Sands <baldrick@free.fr>
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br>
Signed-off-by: Domen Puncer <domen@coderock.org>
Signed-off-by: Olaf Hering <olh@suse.de>
Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br>
<martin_whitaker@ntlworld.com>)
This patch fixes the following kconfig warning:
net/ipv4/Kconfig:92:warning: defaults for choice values not supported
Put NETCONSOLE and NETPOLL options together since they are related.
This cuts down on the hassle of flipping back and forth between
the Networking menu and the Network drivers menu to change their
config settings.
Tested with menuconfig, gconfig, and xconfig.
gconfig has a small problem with this. I think that it's
a bug in gconfig and I will take it up with Romain Lievin.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Audit return of create_proc_* functions.
Signed-off-by: Christophe Lucas <clucas@rotomalug.org>
Fix the sparse warning "implicit cast to nocast type"
Thomas Graf states:
> I used to mark such ids as obsolete in the header but since
> skb is on diet anyway and there has been no official
> iproute2 release with the ematch bits included it might be
> a better idea to remove the ids from the header completely.
> Those that have picked up my patch on netdev shouldn't care
> about a ABI breakage, actually I doubt that someone is using
> it already.
So here's the patch to remove it.
The current call to __qdisc_dequeue_head leads to a branch
misprediction for every loop iteration, the fact that the
most common priority is 2 makes this even worse. This issue
has been brought up by Eric Dumazet <dada1@cosmosbay.com>
but unlike his solution which was to manually unroll the loop,
this approach preserves the possibility to increase the number
of bands at compile time.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Add support for SIIG Quartet Serial card. This card has Oxford
Semiconducor 16954 quad UART which is clocked by 10x faster
(18.432 MHz) quartz.
Signed-off-by: Andrey Panin <pazke@donpac.ru>
