2018-05-22prctl: Add speculation control prctlsThomas Gleixner
commit b617cfc858161140d69cc0b5cc211996b557a1c7 upstream Add two new prctls to control aspects of speculation related vulnerabilites and their mitigations to provide finer grained control over performance impacting mitigations. PR_GET_SPECULATION_CTRL returns the state of the speculation misfeature which is selected with arg2 of prctl(2). The return value uses bit 0-2 with the following meaning: Bit Define Description 0 PR_SPEC_PRCTL Mitigation can be controlled per task by PR_SET_SPECULATION_CTRL 1 PR_SPEC_ENABLE The speculation feature is enabled, mitigation is disabled 2 PR_SPEC_DISABLE The speculation feature is disabled, mitigation is enabled If all bits are 0 the CPU is not affected by the speculation misfeature. If PR_SPEC_PRCTL is set, then the per task control of the mitigation is available. If not set, prctl(PR_SET_SPECULATION_CTRL) for the speculation misfeature will fail. PR_SET_SPECULATION_CTRL allows to control the speculation misfeature, which is selected by arg2 of prctl(2) per task. arg3 is used to hand in the control value, i.e. either PR_SPEC_ENABLE or PR_SPEC_DISABLE. The common return values are: EINVAL prctl is not implemented by the architecture or the unused prctl() arguments are not 0 ENODEV arg2 is selecting a not supported speculation misfeature PR_SET_SPECULATION_CTRL has these additional return values: ERANGE arg3 is incorrect, i.e. it's not either PR_SPEC_ENABLE or PR_SPEC_DISABLE ENXIO prctl control of the selected speculation misfeature is disabled The first supported controlable speculation misfeature is PR_SPEC_STORE_BYPASS. Add the define so this can be shared between architectures. Based on an initial patch from Tim Chen and mostly rewritten. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/speculation: Create spec-ctrl.h to avoid include hellThomas Gleixner
commit 28a2775217b17208811fa43a9e96bd1fdf417b86 upstream Having everything in nospec-branch.h creates a hell of dependencies when adding the prctl based switching mechanism. Move everything which is not required in nospec-branch.h to spec-ctrl.h and fix up the includes in the relevant files. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/KVM/VMX: Expose SPEC_CTRL Bit(2) to the guestKonrad Rzeszutek Wilk
commit da39556f66f5cfe8f9c989206974f1cb16ca5d7c upstream Expose the CPUID.7.EDX[31] bit to the guest, and also guard against various combinations of SPEC_CTRL MSR values. The handling of the MSR (to take into account the host value of SPEC_CTRL Bit(2)) is taken care of in patch: KVM/SVM/VMX/x86/spectre_v2: Support the combination of guest and host IBRS Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> [dwmw2: Handle 4.9 guest CPUID differences, rename guest_cpu_has_ibrs() → guest_cpu_has_spec_ctrl()] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs/AMD: Add support to disable RDS on Fam[15,16,17]h if requestedDavid Woodhouse
commit 764f3c21588a059cd783c6ba0734d4db2d72822d upstream AMD does not need the Speculative Store Bypass mitigation to be enabled. The parameters for this are already available and can be done via MSR C001_1020. Each family uses a different bit in that MSR for this. [ tglx: Expose the bit mask via a variable and move the actual MSR fiddling into the bugs code as that's the right thing to do and also required to prepare for dynamic enable/disable ] Suggested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Whitelist allowed SPEC_CTRL MSR valuesKonrad Rzeszutek Wilk
commit 1115a859f33276fe8afb31c60cf9d8e657872558 upstream Intel and AMD SPEC_CTRL (0x48) MSR semantics may differ in the future (or in fact use different MSRs for the same functionality). As such a run-time mechanism is required to whitelist the appropriate MSR values. [ tglx: Made the variable __ro_after_init ] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs/intel: Set proper CPU features and setup RDSKonrad Rzeszutek Wilk
commit 772439717dbf703b39990be58d8d4e3e4ad0598a upstream Intel CPUs expose methods to: - Detect whether RDS capability is available via CPUID.7.0.EDX[31], - The SPEC_CTRL MSR(0x48), bit 2 set to enable RDS. - MSR_IA32_ARCH_CAPABILITIES, Bit(4) no need to enable RRS. With that in mind if spec_store_bypass_disable=[auto,on] is selected set at boot-time the SPEC_CTRL MSR to enable RDS if the platform requires it. Note that this does not fix the KVM case where the SPEC_CTRL is exposed to guests which can muck with it, see patch titled : KVM/SVM/VMX/x86/spectre_v2: Support the combination of guest and host IBRS. And for the firmware (IBRS to be set), see patch titled: x86/spectre_v2: Read SPEC_CTRL MSR during boot and re-use reserved bits [ tglx: Distangled it from the intel implementation and kept the call order ] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Provide boot parameters for the spec_store_bypass_disable mitigationKonrad Rzeszutek Wilk
commit 24f7fc83b9204d20f878c57cb77d261ae825e033 upstream Contemporary high performance processors use a common industry-wide optimization known as "Speculative Store Bypass" in which loads from addresses to which a recent store has occurred may (speculatively) see an older value. Intel refers to this feature as "Memory Disambiguation" which is part of their "Smart Memory Access" capability. Memory Disambiguation can expose a cache side-channel attack against such speculatively read values. An attacker can create exploit code that allows them to read memory outside of a sandbox environment (for example, malicious JavaScript in a web page), or to perform more complex attacks against code running within the same privilege level, e.g. via the stack. As a first step to mitigate against such attacks, provide two boot command line control knobs: nospec_store_bypass_disable spec_store_bypass_disable=[off,auto,on] By default affected x86 processors will power on with Speculative Store Bypass enabled. Hence the provided kernel parameters are written from the point of view of whether to enable a mitigation or not. The parameters are as follows: - auto - Kernel detects whether your CPU model contains an implementation of Speculative Store Bypass and picks the most appropriate mitigation. - on - disable Speculative Store Bypass - off - enable Speculative Store Bypass [ tglx: Reordered the checks so that the whole evaluation is not done when the CPU does not support RDS ] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/cpufeatures: Add X86_FEATURE_RDSKonrad Rzeszutek Wilk
commit 0cc5fa00b0a88dad140b4e5c2cead9951ad36822 upstream Add the CPU feature bit CPUID.7.0.EDX[31] which indicates whether the CPU supports Reduced Data Speculation. [ tglx: Split it out from a later patch ] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Expose /sys/../spec_store_bypassKonrad Rzeszutek Wilk
commit c456442cd3a59eeb1d60293c26cbe2ff2c4e42cf upstream Add the sysfs file for the new vulerability. It does not do much except show the words 'Vulnerable' for recent x86 cores. Intel cores prior to family 6 are known not to be vulnerable, and so are some Atoms and some Xeon Phi. It assumes that older Cyrix, Centaur, etc. cores are immune. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs, KVM: Support the combination of guest and host IBRSKonrad Rzeszutek Wilk
commit 5cf687548705412da47c9cec342fd952d71ed3d5 upstream A guest may modify the SPEC_CTRL MSR from the value used by the kernel. Since the kernel doesn't use IBRS, this means a value of zero is what is needed in the host. But the 336996-Speculative-Execution-Side-Channel-Mitigations.pdf refers to the other bits as reserved so the kernel should respect the boot time SPEC_CTRL value and use that. This allows to deal with future extensions to the SPEC_CTRL interface if any at all. Note: This uses wrmsrl() instead of native_wrmsl(). I does not make any difference as paravirt will over-write the callq *0xfff.. with the wrmsrl assembler code. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Read SPEC_CTRL MSR during boot and re-use reserved bitsKonrad Rzeszutek Wilk
commit 1b86883ccb8d5d9506529d42dbe1a5257cb30b18 upstream The 336996-Speculative-Execution-Side-Channel-Mitigations.pdf refers to all the other bits as reserved. The Intel SDM glossary defines reserved as implementation specific - aka unknown. As such at bootup this must be taken it into account and proper masking for the bits in use applied. A copy of this document is available at https://bugzilla.kernel.org/show_bug.cgi?id=199511 [ tglx: Made x86_spec_ctrl_base __ro_after_init ] Suggested-by: Jon Masters <jcm@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Concentrate bug reporting into a separate functionKonrad Rzeszutek Wilk
commit d1059518b4789cabe34bb4b714d07e6089c82ca1 upstream Those SysFS functions have a similar preamble, as such make common code to handle them. Suggested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/bugs: Concentrate bug detection into a separate functionKonrad Rzeszutek Wilk
commit 4a28bfe3267b68e22c663ac26185aa16c9b879ef upstream Combine the various logic which goes through all those x86_cpu_id matching structures in one function. Suggested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/nospec: Simplify alternative_msr_write()Linus Torvalds
commit 1aa7a5735a41418d8e01fa7c9565eb2657e2ea3f upstream The macro is not type safe and I did look for why that "g" constraint for the asm doesn't work: it's because the asm is more fundamentally wrong. It does movl %[val], %%eax but "val" isn't a 32-bit value, so then gcc will pass it in a register, and generate code like movl %rsi, %eax and gas will complain about a nonsensical 'mov' instruction (it's moving a 64-bit register to a 32-bit one). Passing it through memory will just hide the real bug - gcc still thinks the memory location is 64-bit, but the "movl" will only load the first 32 bits and it all happens to work because x86 is little-endian. Convert it to a type safe inline function with a little trick which hands the feature into the ALTERNATIVE macro. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22btrfs: fix reading stale metadata blocks after degraded raid1 mountsLiu Bo
commit 02a3307aa9c20b4f6626255b028f07f6cfa16feb upstream. If a btree block, aka. extent buffer, is not available in the extent buffer cache, it'll be read out from the disk instead, i.e. btrfs_search_slot() read_block_for_search() # hold parent and its lock, go to read child btrfs_release_path() read_tree_block() # read child Unfortunately, the parent lock got released before reading child, so commit 5bdd3536cbbe ("Btrfs: Fix block generation verification race") had used 0 as parent transid to read the child block. It forces read_tree_block() not to check if parent transid is different with the generation id of the child that it reads out from disk. A simple PoC is included in btrfs/124, 0. A two-disk raid1 btrfs, 1. Right after mkfs.btrfs, block A is allocated to be device tree's root. 2. Mount this filesystem and put it in use, after a while, device tree's root got COW but block A hasn't been allocated/overwritten yet. 3. Umount it and reload the btrfs module to remove both disks from the global @fs_devices list. 4. mount -odegraded dev1 and write some data, so now block A is allocated to be a leaf in checksum tree. Note that only dev1 has the latest metadata of this filesystem. 5. Umount it and mount it again normally (with both disks), since raid1 can pick up one disk by the writer task's pid, if btrfs_search_slot() needs to read block A, dev2 which does NOT have the latest metadata might be read for block A, then we got a stale block A. 6. As parent transid is not checked, block A is marked as uptodate and put into the extent buffer cache, so the future search won't bother to read disk again, which means it'll make changes on this stale one and make it dirty and flush it onto disk. To avoid the problem, parent transid needs to be passed to read_tree_block(). In order to get a valid parent transid, we need to hold the parent's lock until finishing reading child. This patch needs to be slightly adapted for stable kernels, the &first_key parameter added to read_tree_block() is from 4.16+ (581c1760415c4). The fix is to replace 0 by 'gen'. Fixes: 5bdd3536cbbe ("Btrfs: Fix block generation verification race") CC: stable@vger.kernel.org # 4.4+ Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com> Reviewed-by: Filipe Manana <fdmanana@suse.com> Reviewed-by: Qu Wenruo <wqu@suse.com> [ update changelog ] Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Nikolay Borisov <nborisov@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/amd: don't set X86_BUG_SYSRET_SS_ATTRS when running under XenDavid Woodhouse
commit def9331a12977770cc6132d79f8e6565871e8e38 upstream When running as Xen pv guest X86_BUG_SYSRET_SS_ATTRS must not be set on AMD cpus. This bug/feature bit is kind of special as it will be used very early when switching threads. Setting the bit and clearing it a little bit later leaves a critical window where things can go wrong. This time window has enlarged a little bit by using setup_clear_cpu_cap() instead of the hypervisor's set_cpu_features callback. It seems this larger window now makes it rather easy to hit the problem. The proper solution is to never set the bit in case of Xen. Signed-off-by: Juergen Gross <jgross@suse.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Juergen Gross <jgross@suse.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22btrfs: fix crash when trying to resume balance without the resume flagAnand Jain
commit 02ee654d3a04563c67bfe658a05384548b9bb105 upstream. We set the BTRFS_BALANCE_RESUME flag in the btrfs_recover_balance() only, which isn't called during the remount. So when resuming from the paused balance we hit the bug: kernel: kernel BUG at fs/btrfs/volumes.c:3890! :: kernel: balance_kthread+0x51/0x60 [btrfs] kernel: kthread+0x111/0x130 :: kernel: RIP: btrfs_balance+0x12e1/0x1570 [btrfs] RSP: ffffba7d0090bde8 Reproducer: On a mounted filesystem: btrfs balance start --full-balance /btrfs btrfs balance pause /btrfs mount -o remount,ro /dev/sdb /btrfs mount -o remount,rw /dev/sdb /btrfs To fix this set the BTRFS_BALANCE_RESUME flag in btrfs_resume_balance_async(). CC: stable@vger.kernel.org # 4.4+ Signed-off-by: Anand Jain <anand.jain@oracle.com> Reviewed-by: David Sterba <dsterba@suse.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22Btrfs: fix xattr loss after power failureFilipe Manana
commit 9a8fca62aacc1599fea8e813d01e1955513e4fad upstream. If a file has xattrs, we fsync it, to ensure we clear the flags BTRFS_INODE_NEEDS_FULL_SYNC and BTRFS_INODE_COPY_EVERYTHING from its inode, the current transaction commits and then we fsync it (without either of those bits being set in its inode), we end up not logging all its xattrs. This results in deleting all xattrs when replying the log after a power failure. Trivial reproducer $ mkfs.btrfs -f /dev/sdb $ mount /dev/sdb /mnt $ touch /mnt/foobar $ setfattr -n user.xa -v qwerty /mnt/foobar $ xfs_io -c "fsync" /mnt/foobar $ sync $ xfs_io -c "pwrite -S 0xab 0 64K" /mnt/foobar $ xfs_io -c "fsync" /mnt/foobar <power failure> $ mount /dev/sdb /mnt $ getfattr --absolute-names --dump /mnt/foobar <empty output> $ So fix this by making sure all xattrs are logged if we log a file's inode item and neither the flags BTRFS_INODE_NEEDS_FULL_SYNC nor BTRFS_INODE_COPY_EVERYTHING were set in the inode. Fixes: 36283bf777d9 ("Btrfs: fix fsync xattr loss in the fast fsync path") Cc: <stable@vger.kernel.org> # 4.2+ Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ARM: 8772/1: kprobes: Prohibit kprobes on get_user functionsMasami Hiramatsu
commit 0d73c3f8e7f6ee2aab1bb350f60c180f5ae21a2c upstream. Since do_undefinstr() uses get_user to get the undefined instruction, it can be called before kprobes processes recursive check. This can cause an infinit recursive exception. Prohibit probing on get_user functions. Fixes: 24ba613c9d6c ("ARM kprobes: core code") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ARM: 8770/1: kprobes: Prohibit probing on optimized_callbackMasami Hiramatsu
commit 70948c05fdde0aac32f9667856a88725c192fa40 upstream. Prohibit probing on optimized_callback() because it is called from kprobes itself. If we put a kprobes on it, that will cause a recursive call loop. Mark it NOKPROBE_SYMBOL. Fixes: 0dc016dbd820 ("ARM: kprobes: enable OPTPROBES for ARM 32") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ARM: 8769/1: kprobes: Fix to use get_kprobe_ctlblk after irq-disabedMasami Hiramatsu
commit 69af7e23a6870df2ea6fa79ca16493d59b3eebeb upstream. Since get_kprobe_ctlblk() uses smp_processor_id() to access per-cpu variable, it hits smp_processor_id sanity check as below. [ 7.006928] BUG: using smp_processor_id() in preemptible [00000000] code: swapper/0/1 [ 7.007859] caller is debug_smp_processor_id+0x20/0x24 [ 7.008438] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.16.0-rc1-00192-g4eb17253e4b5 #1 [ 7.008890] Hardware name: Generic DT based system [ 7.009917] [<c0313f0c>] (unwind_backtrace) from [<c030e6d8>] (show_stack+0x20/0x24) [ 7.010473] [<c030e6d8>] (show_stack) from [<c0c64694>] (dump_stack+0x84/0x98) [ 7.010990] [<c0c64694>] (dump_stack) from [<c071ca5c>] (check_preemption_disabled+0x138/0x13c) [ 7.011592] [<c071ca5c>] (check_preemption_disabled) from [<c071ca80>] (debug_smp_processor_id+0x20/0x24) [ 7.012214] [<c071ca80>] (debug_smp_processor_id) from [<c03335e0>] (optimized_callback+0x2c/0xe4) [ 7.013077] [<c03335e0>] (optimized_callback) from [<bf0021b0>] (0xbf0021b0) To fix this issue, call get_kprobe_ctlblk() right after irq-disabled since that disables preemption. Fixes: 0dc016dbd820 ("ARM: kprobes: enable OPTPROBES for ARM 32") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22tick/broadcast: Use for_each_cpu() specially on UP kernelsDexuan Cui
commit 5596fe34495cf0f645f417eb928ef224df3e3cb4 upstream. for_each_cpu() unintuitively reports CPU0 as set independent of the actual cpumask content on UP kernels. This causes an unexpected PIT interrupt storm on a UP kernel running in an SMP virtual machine on Hyper-V, and as a result, the virtual machine can suffer from a strange random delay of 1~20 minutes during boot-up, and sometimes it can hang forever. Protect if by checking whether the cpumask is empty before entering the for_each_cpu() loop. [ tglx: Use !IS_ENABLED(CONFIG_SMP) instead of #ifdeffery ] Signed-off-by: Dexuan Cui <decui@microsoft.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Josh Poulson <jopoulso@microsoft.com> Cc: "Michael Kelley (EOSG)" <Michael.H.Kelley@microsoft.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: stable@vger.kernel.org Cc: Rakib Mullick <rakib.mullick@gmail.com> Cc: Jork Loeser <Jork.Loeser@microsoft.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: KY Srinivasan <kys@microsoft.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Link: https://lkml.kernel.org/r/KL1P15301MB000678289FE55BA365B3279ABF990@KL1P15301MB0006.APCP153.PROD.OUTLOOK.COM Link: https://lkml.kernel.org/r/KL1P15301MB0006FA63BC22BEB64902EAA0BF930@KL1P15301MB0006.APCP153.PROD.OUTLOOK.COM Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ARM: 8771/1: kprobes: Prohibit kprobes on do_undefinstrMasami Hiramatsu
commit eb0146daefdde65665b7f076fbff7b49dade95b9 upstream. Prohibit kprobes on do_undefinstr because kprobes on arm is implemented by undefined instruction. This means if we probe do_undefinstr(), it can cause infinit recursive exception. Fixes: 24ba613c9d6c ("ARM kprobes: core code") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22efi: Avoid potential crashes, fix the 'struct efi_pci_io_protocol_32' ↵Ard Biesheuvel
definition for mixed mode commit 0b3225ab9407f557a8e20f23f37aa7236c10a9b1 upstream. Mixed mode allows a kernel built for x86_64 to interact with 32-bit EFI firmware, but requires us to define all struct definitions carefully when it comes to pointer sizes. 'struct efi_pci_io_protocol_32' currently uses a 'void *' for the 'romimage' field, which will be interpreted as a 64-bit field on such kernels, potentially resulting in bogus memory references and subsequent crashes. Tested-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/20180504060003.19618-13-ard.biesheuvel@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/pkeys: Do not special case protection key 0Dave Hansen
commit 2fa9d1cfaf0e02f8abef0757002bff12dfcfa4e6 upstream. mm_pkey_is_allocated() treats pkey 0 as unallocated. That is inconsistent with the manpages, and also inconsistent with mm->context.pkey_allocation_map. Stop special casing it and only disallow values that are actually bad (< 0). The end-user visible effect of this is that you can now use mprotect_pkey() to set pkey=0. This is a bit nicer than what Ram proposed[1] because it is simpler and removes special-casing for pkey 0. On the other hand, it does allow applications to pkey_free() pkey-0, but that's just a silly thing to do, so we are not going to protect against it. The scenario that could happen is similar to what happens if you free any other pkey that is in use: it might get reallocated later and used to protect some other data. The most likely scenario is that pkey-0 comes back from pkey_alloc(), an access-disable or write-disable bit is set in PKRU for it, and the next stack access will SIGSEGV. It's not horribly different from if you mprotect()'d your stack or heap to be unreadable or unwritable, which is generally very foolish, but also not explicitly prevented by the kernel. 1. http://lkml.kernel.org/r/1522112702-27853-1-git-send-email-linuxram@us.ibm.com Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org>p Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellermen <mpe@ellerman.id.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Shuah Khan <shuah@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Cc: stable@vger.kernel.org Fixes: 58ab9a088dda ("x86/pkeys: Check against max pkey to avoid overflows") Link: http://lkml.kernel.org/r/20180509171358.47FD785E@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22x86/pkeys: Override pkey when moving away from PROT_EXECDave Hansen
commit 0a0b152083cfc44ec1bb599b57b7aab41327f998 upstream. I got a bug report that the following code (roughly) was causing a SIGSEGV: mprotect(ptr, size, PROT_EXEC); mprotect(ptr, size, PROT_NONE); mprotect(ptr, size, PROT_READ); *ptr = 100; The problem is hit when the mprotect(PROT_EXEC) is implicitly assigned a protection key to the VMA, and made that key ACCESS_DENY|WRITE_DENY. The PROT_NONE mprotect() failed to remove the protection key, and the PROT_NONE-> PROT_READ left the PTE usable, but the pkey still in place and left the memory inaccessible. To fix this, we ensure that we always "override" the pkee at mprotect() if the VMA does not have execute-only permissions, but the VMA has the execute-only pkey. We had a check for PROT_READ/WRITE, but it did not work for PROT_NONE. This entirely removes the PROT_* checks, which ensures that PROT_NONE now works. Reported-by: Shakeel Butt <shakeelb@google.com> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellermen <mpe@ellerman.id.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Shuah Khan <shuah@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Cc: stable@vger.kernel.org Fixes: 62b5f7d013f ("mm/core, x86/mm/pkeys: Add execute-only protection keys support") Link: http://lkml.kernel.org/r/20180509171351.084C5A71@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22s390: remove indirect branch from do_softirq_own_stackMartin Schwidefsky
commit 9f18fff63cfd6f559daa1eaae60640372c65f84b upstream. The inline assembly to call __do_softirq on the irq stack uses an indirect branch. This can be replaced with a normal relative branch. Cc: stable@vger.kernel.org # 4.16 Fixes: f19fbd5ed6 ("s390: introduce execute-trampolines for branches") Reviewed-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22s390/qdio: don't release memory in qdio_setup_irq()Julian Wiedmann
commit 2e68adcd2fb21b7188ba449f0fab3bee2910e500 upstream. Calling qdio_release_memory() on error is just plain wrong. It frees the main qdio_irq struct, when following code still uses it. Also, no other error path in qdio_establish() does this. So trust callers to clean up via qdio_free() if some step of the QDIO initialization fails. Fixes: 779e6e1c724d ("[S390] qdio: new qdio driver.") Cc: <stable@vger.kernel.org> #v2.6.27+ Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22s390/cpum_sf: ensure sample frequency of perf event attributes is non-zeroHendrik Brueckner
commit 4bbaf2584b86b0772413edeac22ff448f36351b1 upstream. Correct a trinity finding for the perf_event_open() system call with a perf event attribute structure that uses a frequency but has the sampling frequency set to zero. This causes a FP divide exception during the sample rate initialization for the hardware sampling facility. Fixes: 8c069ff4bd606 ("s390/perf: add support for the CPU-Measurement Sampling Facility") Cc: stable@vger.kernel.org # 3.14+ Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Hendrik Brueckner <brueckner@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22s390/qdio: fix access to uninitialized qdio_q fieldsJulian Wiedmann
commit e521813468f786271a87e78e8644243bead48fad upstream. Ever since CQ/QAOB support was added, calling qdio_free() straight after qdio_alloc() results in qdio_release_memory() accessing uninitialized memory (ie. q->u.out.use_cq and q->u.out.aobs). Followed by a kmem_cache_free() on the random AOB addresses. For older kernels that don't have 6e30c549f6ca, the same applies if qdio_establish() fails in the DEV_STATE_ONLINE check. While initializing q->u.out.use_cq would be enough to fix this particular bug, the more future-proof change is to just zero-alloc the whole struct. Fixes: 104ea556ee7f ("qdio: support asynchronous delivery of storage blocks") Cc: <stable@vger.kernel.org> #v3.2+ Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22mm: don't allow deferred pages with NEED_PER_CPU_KMPavel Tatashin
commit ab1e8d8960b68f54af42b6484b5950bd13a4054b upstream. It is unsafe to do virtual to physical translations before mm_init() is called if struct page is needed in order to determine the memory section number (see SECTION_IN_PAGE_FLAGS). This is because only in mm_init() we initialize struct pages for all the allocated memory when deferred struct pages are used. My recent fix in commit c9e97a1997 ("mm: initialize pages on demand during boot") exposed this problem, because it greatly reduced number of pages that are initialized before mm_init(), but the problem existed even before my fix, as Fengguang Wu found. Below is a more detailed explanation of the problem. We initialize struct pages in four places: 1. Early in boot a small set of struct pages is initialized to fill the first section, and lower zones. 2. During mm_init() we initialize "struct pages" for all the memory that is allocated, i.e reserved in memblock. 3. Using on-demand logic when pages are allocated after mm_init call (when memblock is finished) 4. After smp_init() when the rest free deferred pages are initialized. The problem occurs if we try to do va to phys translation of a memory between steps 1 and 2. Because we have not yet initialized struct pages for all the reserved pages, it is inherently unsafe to do va to phys if the translation itself requires access of "struct page" as in case of this combination: CONFIG_SPARSE && !CONFIG_SPARSE_VMEMMAP The following path exposes the problem: start_kernel() trap_init() setup_cpu_entry_areas() setup_cpu_entry_area(cpu) get_cpu_gdt_paddr(cpu) per_cpu_ptr_to_phys(addr) pcpu_addr_to_page(addr) virt_to_page(addr) pfn_to_page(__pa(addr) >> PAGE_SHIFT) We disable this path by not allowing NEED_PER_CPU_KM with deferred struct pages feature. The problems are discussed in these threads: http://lkml.kernel.org/r/20180418135300.inazvpxjxowogyge@wfg-t540p.sh.intel.com http://lkml.kernel.org/r/20180419013128.iurzouiqxvcnpbvz@wfg-t540p.sh.intel.com http://lkml.kernel.org/r/20180426202619.2768-1-pasha.tatashin@oracle.com Link: http://lkml.kernel.org/r/20180515175124.1770-1-pasha.tatashin@oracle.com Fixes: 3a80a7fa7989 ("mm: meminit: initialise a subset of struct pages if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set") Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Steven Sistare <steven.sistare@oracle.com> Cc: Daniel Jordan <daniel.m.jordan@oracle.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Dennis Zhou <dennisszhou@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22powerpc/powernv: Fix NVRAM sleep in invalid context when crashingNicholas Piggin
commit c1d2a31397ec51f0370f6bd17b19b39152c263cb upstream. Similarly to opal_event_shutdown, opal_nvram_write can be called in the crash path with irqs disabled. Special case the delay to avoid sleeping in invalid context. Fixes: 3b8070335f75 ("powerpc/powernv: Fix OPAL NVRAM driver OPAL_BUSY loops") Cc: stable@vger.kernel.org # v3.2 Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22i2c: designware: fix poll-after-enable regressionAlexander Monakov
commit 06cb616b1bca7080824acfedb3d4c898e7a64836 upstream. Not all revisions of DW I2C controller implement the enable status register. On platforms where that's the case (e.g. BG2CD and SPEAr ARM SoCs), waiting for enable will time out as reading the unimplemented register yields zero. It was observed that reading the IC_ENABLE_STATUS register once suffices to avoid getting it stuck on Bay Trail hardware, so replace polling with one dummy read of the register. Fixes: fba4adbbf670 ("i2c: designware: must wait for enable") Signed-off-by: Alexander Monakov <amonakov@ispras.ru> Tested-by: Ben Gardner <gardner.ben@gmail.com> Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22netfilter: nf_tables: can't fail after linking rule into active rule listFlorian Westphal
commit 569ccae68b38654f04b6842b034aa33857f605fe upstream. rules in nftables a free'd using kfree, but protected by rcu, i.e. we must wait for a grace period to elapse. Normal removal patch does this, but nf_tables_newrule() doesn't obey this rule during error handling. It calls nft_trans_rule_add() *after* linking rule, and, if that fails to allocate memory, it unlinks the rule and then kfree() it -- this is unsafe. Switch order -- first add rule to transaction list, THEN link it to public list. Note: nft_trans_rule_add() uses GFP_KERNEL; it will not fail so this is not a problem in practice (spotted only during code review). Fixes: 0628b123c96d12 ("netfilter: nfnetlink: add batch support and use it from nf_tables") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22tracing/x86/xen: Remove zero data size trace events ↵Steven Rostedt (VMware)
trace_xen_mmu_flush_tlb{_all} commit 45dd9b0666a162f8e4be76096716670cf1741f0e upstream. Doing an audit of trace events, I discovered two trace events in the xen subsystem that use a hack to create zero data size trace events. This is not what trace events are for. Trace events add memory footprint overhead, and if all you need to do is see if a function is hit or not, simply make that function noinline and use function tracer filtering. Worse yet, the hack used was: __array(char, x, 0) Which creates a static string of zero in length. There's assumptions about such constructs in ftrace that this is a dynamic string that is nul terminated. This is not the case with these tracepoints and can cause problems in various parts of ftrace. Nuke the trace events! Link: http://lkml.kernel.org/r/20180509144605.5a220327@gandalf.local.home Cc: stable@vger.kernel.org Fixes: 95a7d76897c1e ("xen/mmu: Use Xen specific TLB flush instead of the generic one.") Reviewed-by: Juergen Gross <jgross@suse.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22signals: avoid unnecessary taking of sighand->siglockWaiman Long
commit c7be96af89d4b53211862d8599b2430e8900ed92 upstream. When running certain database workload on a high-end system with many CPUs, it was found that spinlock contention in the sigprocmask syscalls became a significant portion of the overall CPU cycles as shown below. 9.30% 9.30% 905387 dataserver /proc/kcore 0x7fff8163f4d2 [k] _raw_spin_lock_irq | ---_raw_spin_lock_irq | |--99.34%-- __set_current_blocked | sigprocmask | sys_rt_sigprocmask | system_call_fastpath | | | |--50.63%-- __swapcontext | | | | | |--99.91%-- upsleepgeneric | | | |--49.36%-- __setcontext | | ktskRun Looking further into the swapcontext function in glibc, it was found that the function always call sigprocmask() without checking if there are changes in the signal mask. A check was added to the __set_current_blocked() function to avoid taking the sighand->siglock spinlock if there is no change in the signal mask. This will prevent unneeded spinlock contention when many threads are trying to call sigprocmask(). With this patch applied, the spinlock contention in sigprocmask() was gone. Link: http://lkml.kernel.org/r/1474979209-11867-1-git-send-email-Waiman.Long@hpe.com Signed-off-by: Waiman Long <Waiman.Long@hpe.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Stas Sergeev <stsp@list.ru> Cc: Scott J Norton <scott.norton@hpe.com> Cc: Douglas Hatch <doug.hatch@hpe.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22powerpc: Don't preempt_disable() in show_cpuinfo()Benjamin Herrenschmidt
commit 349524bc0da698ec77f2057cf4a4948eb6349265 upstream. This causes warnings from cpufreq mutex code. This is also rather unnecessary and ineffective. If we really want to prevent concurrent unplug, we could take the unplug read lock but I don't see this being critical. Fixes: cd77b5ce208c ("powerpc/powernv/cpufreq: Fix the frequency read by /proc/cpuinfo") Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Acked-by: Michal Suchanek <msuchanek@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22KVM: arm/arm64: VGIC/ITS: protect kvm_read_guest() calls with SRCU lockAndre Przywara
commit bf308242ab98b5d1648c3663e753556bef9bec01 upstream. kvm_read_guest() will eventually look up in kvm_memslots(), which requires either to hold the kvm->slots_lock or to be inside a kvm->srcu critical section. In contrast to x86 and s390 we don't take the SRCU lock on every guest exit, so we have to do it individually for each kvm_read_guest() call. Provide a wrapper which does that and use that everywhere. Note that ending the SRCU critical section before returning from the kvm_read_guest() wrapper is safe, because the data has been *copied*, so we don't need to rely on valid references to the memslot anymore. Cc: Stable <stable@vger.kernel.org> # 4.8+ Reported-by: Jan Glauber <jan.glauber@caviumnetworks.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Christoffer Dall <christoffer.dall@arm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22spi: bcm-qspi: Always read and set BSPI_MAST_N_BOOT_CTRLKamal Dasu
commit 602805fb618b018b7a41fbb3f93c1992b078b1ae upstream. Always confirm the BSPI_MAST_N_BOOT_CTRL bit when enabling or disabling BSPI transfers. Fixes: 4e3b2d236fe00 ("spi: bcm-qspi: Add BSPI spi-nor flash controller driver") Signed-off-by: Kamal Dasu <kdasu.kdev@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22spi: bcm-qspi: Avoid setting MSPI_CDRAM_PCS for spi-nor masterKamal Dasu
commit 5eb9a07a4ae1008b67d8bcd47bddb3dae97456b7 upstream. Added fix for probing of spi-nor device non-zero chip selects. Set MSPI_CDRAM_PCS (peripheral chip select) with spi master for MSPI controller and not for MSPI/BSPI spi-nor master controller. Ensure setting of cs bit in chip select register on chip select change. Fixes: fa236a7ef24048 ("spi: bcm-qspi: Add Broadcom MSPI driver") Signed-off-by: Kamal Dasu <kdasu.kdev@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22spi: pxa2xx: Allow 64-bit DMAAndy Shevchenko
commit efc4a13724b852ddaa3358402a8dec024ffbcb17 upstream. Currently the 32-bit device address only is supported for DMA. However, starting from Intel Sunrisepoint PCH the DMA address of the device FIFO can be 64-bit. Change the respective variable to be compatible with DMA engine expectations, i.e. to phys_addr_t. Fixes: 34cadd9c1bcb ("spi: pxa2xx: Add support for Intel Sunrisepoint") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ALSA: control: fix a redundant-copy issueWenwen Wang
commit 3f12888dfae2a48741c4caa9214885b3aaf350f9 upstream. In snd_ctl_elem_add_compat(), the fields of the struct 'data' need to be copied from the corresponding fields of the struct 'data32' in userspace. This is achieved by invoking copy_from_user() and get_user() functions. The problem here is that the 'type' field is copied twice. One is by copy_from_user() and one is by get_user(). Given that the 'type' field is not used between the two copies, the second copy is *completely* redundant and should be removed for better performance and cleanup. Also, these two copies can cause inconsistent data: as the struct 'data32' resides in userspace and a malicious userspace process can race to change the 'type' field between the two copies to cause inconsistent data. Depending on how the data is used in the future, such an inconsistency may cause potential security risks. For above reasons, we should take out the second copy. Signed-off-by: Wenwen Wang <wang6495@umn.edu> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ALSA: hda: Add Lenovo C50 All in one to the power_save blacklistHans de Goede
commit c8beccc19b92f5172994c0732db689c08f4f98e5 upstream. Power-saving is causing loud plops on the Lenovo C50 All in one, add it to the blacklist. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1572975 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22ALSA: usb: mixer: volume quirk for CM102-A+/102S+Federico Cuello
commit 21493316a3c4598f308d5a9fa31cc74639c4caff upstream. Currently it's not possible to set volume lower than 26% (it just mutes). Also fixes this warning: Warning! Unlikely big volume range (=9472), cval->res is probably wrong. [13] FU [PCM Playback Volume] ch = 2, val = -9473/-1/1 , and volume works fine for full range. Signed-off-by: Federico Cuello <fedux@fedux.com.ar> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22usbip: usbip_host: fix bad unlock balance during stub_probe()Shuah Khan (Samsung OSG)
commit c171654caa875919be3c533d3518da8be5be966e upstream. stub_probe() calls put_busid_priv() in an error path when device isn't found in the busid_table. Fix it by making put_busid_priv() safe to be called with null struct bus_id_priv pointer. This problem happens when "usbip bind" is run without loading usbip_host driver and then running modprobe. The first failed bind attempt unbinds the device from the original driver and when usbip_host is modprobed, stub_probe() runs and doesn't find the device in its busid table and calls put_busid_priv(0 with null bus_id_priv pointer. usbip-host 3-10.2: 3-10.2 is not in match_busid table... skip! [ 367.359679] ===================================== [ 367.359681] WARNING: bad unlock balance detected! [ 367.359683] 4.17.0-rc4+ #5 Not tainted [ 367.359685] ------------------------------------- [ 367.359688] modprobe/2768 is trying to release lock ( [ 367.359689] ================================================================== [ 367.359696] BUG: KASAN: null-ptr-deref in print_unlock_imbalance_bug+0x99/0x110 [ 367.359699] Read of size 8 at addr 0000000000000058 by task modprobe/2768 [ 367.359705] CPU: 4 PID: 2768 Comm: modprobe Not tainted 4.17.0-rc4+ #5 Fixes: 22076557b07c ("usbip: usbip_host: fix NULL-ptr deref and use-after-free errors") in usb-linus Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22usbip: usbip_host: fix NULL-ptr deref and use-after-free errorsShuah Khan (Samsung OSG)
commit 22076557b07c12086eeb16b8ce2b0b735f7a27e7 upstream. usbip_host updates device status without holding lock from stub probe, disconnect and rebind code paths. When multiple requests to import a device are received, these unprotected code paths step all over each other and drive fails with NULL-ptr deref and use-after-free errors. The driver uses a table lock to protect the busid array for adding and deleting busids to the table. However, the probe, disconnect and rebind paths get the busid table entry and update the status without holding the busid table lock. Add a new finer grain lock to protect the busid entry. This new lock will be held to search and update the busid entry fields from get_busid_idx(), add_match_busid() and del_match_busid(). match_busid_show() does the same to access the busid entry fields. get_busid_priv() changed to return the pointer to the busid entry holding the busid lock. stub_probe(), stub_disconnect() and stub_device_rebind() call put_busid_priv() to release the busid lock before returning. This changes fixes the unprotected code paths eliminating the race conditions in updating the busid entries. Reported-by: Jakub Jirasek Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22usbip: usbip_host: run rebind from exit when module is removedShuah Khan (Samsung OSG)
commit 7510df3f29d44685bab7b1918b61a8ccd57126a9 upstream. After removing usbip_host module, devices it releases are left without a driver. For example, when a keyboard or a mass storage device are bound to usbip_host when it is removed, these devices are no longer bound to any driver. Fix it to run device_attach() from the module exit routine to restore the devices to their original drivers. This includes cleanup changes and moving device_attach() code to a common routine to be called from rebind_store() and usbip_host_exit(). Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22usbip: usbip_host: delete device from busid_table after rebindShuah Khan (Samsung OSG)
commit 1e180f167d4e413afccbbb4a421b48b2de832549 upstream. Device is left in the busid_table after unbind and rebind. Rebind initiates usb bus scan and the original driver claims the device. After rescan the device should be deleted from the busid_table as it no longer belongs to usbip_host. Fix it to delete the device after device_attach() succeeds. Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22usbip: usbip_host: refine probe and disconnect debug msgs to be usefulShuah Khan
commit 28b68acc4a88dcf91fd1dcf2577371dc9bf574cc upstream. Refine probe and disconnect debug msgs to be useful and say what is in progress. Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-19Linux 4.9.101v4.9.101Greg Kroah-Hartman
