2011-05-19MIPS: Alchemy: Rewrite ethernet platform setupManuel Lauss
Rewrite ethernet setup to use runtime cpu detection, and also clean up the ethernet base address mess as far as possible. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2353/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Alchemy: Rewrite UART setup and constants.Manuel Lauss
Detect CPU type at runtime and setup uarts accordingly; also clean up the uart base address mess in the process as far as possible. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2352/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Alchemy: Convert dbdma.c to syscore_opsManuel Lauss
Convert the PM sysdev to syscore_ops and clean up the ddma addresses a bit. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2351/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Alchemy: Convert irq.c to syscore_ops.Manuel Lauss
Convert the PM sysdev to use syscore_ops instead. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2350/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Alchemy: irq code and constant cleanupManuel Lauss
replace au_readl/au_writel with __raw_readl/__raw_writel, and clean up IC-related stuff from the headers. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2354/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Alchemy: update inlinable GPIO APIManuel Lauss
This fixes a build failure with gpio_keys and CONFIG_GPIOLIB=n (mtx1): CC drivers/input/keyboard/gpio_keys.o gpio_keys.c: In function 'gpio_keys_report_event': gpio_keys.c:325:2: error: implicit declaration of function 'gpio_get_value_cansleep' gpio_keys.c: In function 'gpio_keys_setup_key': gpio_keys.c:390:3: error: implicit declaration of function 'gpio_set_debounce' Also add stubs for the other new functions. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2346/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: DB1200: Set Config[OD] for improved stability.Manuel Lauss
Setting Config[OD] gets rid of a _LOT_ of spurious CPLD interrupts, but also decreases overall performance a bit. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2347/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Split do_syscall_trace into two functions.Ralf Baechle
2011-05-19MIPS: Use single define for pending work on syscall exitRalf Baechle
2011-05-19MIPS: IP27: Remove pointless switch statement.Ralf Baechle
2011-05-19MIPS: Lantiq: Add watchdog supportJohn Crispin
This patch adds the driver for the watchdog found inside the Lantiq SoC family. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: linux-mips@linux-mips.org Cc: linux-watchdog@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2327/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add etop board supportJohn Crispin
Register the etop platform device inside the machtype specific init code. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2356/ Patchwork: https://patchwork.linux-mips.org/patch/2370/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add ethernet driverJohn Crispin
This patch adds the driver for the ETOP Packet Processing Engine (PPE32) found inside the XWAY family of Lantiq MIPS SoCs. This driver makes 100MBit ethernet work. Support for all 8 dma channels, gbit and the embedded switch found on the ar9/vr9 still needs to be implemented. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Cc: netdev@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2357/ Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add DMA supportJohn Crispin
This patch adds support for the DMA engine found inside the XWAY family of SoCs. The engine has 5 ports and 20 channels. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2355/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19SERIAL: Lantiq: Add driver for MIPS Lantiq SOCs.John Crispin
Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: alan@lxorguk.ukuu.org.uk Cc: linux-mips@linux-mips.org Cc: linux-serial@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2269/ Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add more gpio driversJohn Crispin
The XWAY family allows to extend the number of gpios by using shift registers or latches. This patch adds the 2 drivers needed for this. The extended gpios are output only. [ralf@linux-mips.org: Fixed ltq_stp_probe section() attributes.] Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2258/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add machtypes for lantiq eval kitsJohn Crispin
This patch adds mach specific code for the Lantiq EASY50712/50601 evaluation boards Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2255/ Patchwork: https://patchwork.linux-mips.org/patch/2361/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add mips_machine supportJohn Crispin
This patch adds support for Gabor's mips_machine patch. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2251/ Patchwork: https://patchwork.linux-mips.org/patch/2358/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add platform device supportJohn Crispin
This patch adds the wrappers for registering our platform devices. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2254/ Patchwork: https://patchwork.linux-mips.org/patch/2360/ Patchwork: https://patchwork.linux-mips.org/patch/2359/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add NOR flash supportJohn Crispin
This patch adds the driver/map for NOR devices attached to the SoC via the External Bus Unit (EBU). Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: linux-mips@linux-mips.org Cc: linux-mtd@lists.infradead.org Acked-by: Artem Bityutskiy <dedekind1@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/2285/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add PCI controller support.John Crispin
The Lantiq family of SoCs have a EBU (External Bus Unit). This patch adds the driver that allows us to use the EBU as a PCI controller. In order for PCI to work the EBU is set to endianess swap all the data. In addition we need to make use of SWAP_IO_SPACE for device->host DMA to work. The clock of the PCI works in several modes (internal/external). If this is not configured correctly the SoC will hang. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2250/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: add SoC specific code for XWAY familyJohn Crispin
Add support for the Lantiq XWAY family of Mips24KEc SoCs. * Danube (PSB50702) * Twinpass (PSB4000) * AR9 (PSB50802) * Amazon SE (PSB5061) The Amazon SE is a lightweight SoC and has no PCI as well as a different clock. We split the code out into seperate files to handle this. The GPIO pins on the SoCs are multi function and there are several bits we can use to configure the pins. To be as compatible as possible to GPIOLIB we add a function int lq_gpio_request(unsigned int pin, unsigned int alt0, unsigned int alt1, unsigned int dir, const char *name); which lets you configure the 2 "alternate function" bits. This way drivers like PCI can make use of GPIOLIB without a cubersome wrapper. The PLL code inside arch/mips/lantiq/xway/clk-xway.c is voodoo to me. It was taken from a 2.4.20 source tree and was never really changed by me since then. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2249/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add initial support for Lantiq SoCsJohn Crispin
Add initial support for Mips based SoCs made by Lantiq. This series will add support for the XWAY family. The series allows booting a minimal system using a initramfs or NOR. Missing drivers and support for Amazon and GPON family will be provided in a later series. [Ralf: Remove some cargo cult programming and fixed formatting.] Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2252/ Patchwork: https://patchwork.linux-mips.org/patch/2371/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Enable kmemleak for MIPSMaxin John
Signed-off-by: Maxin B. John <maxin.john@gmail.com> To: Catalin Marinas <catalin.marinas@arm.com> Cc: Daniel Baluta <dbaluta@ixiacom.com> Cc: naveen yadav <yad.naveen@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Patchwork: https://patchwork.linux-mips.org/patch/2244/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: XLR, XLS: Add PCI support.Jayachandran C
Adds pci/pci-xlr.c to support for XLR PCI/PCI-X interface and XLS PCIe interface. Update irq.c to ack PCI interrupts, use irq handler data to do the PCI/PCIe bus ack. Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2337/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Add default configuration for XLR/XLS processorsJayachandran C
Enable XLR CPU support, SMP, initramfs based root filesystem etc. [ralf@linux-mips.org: shrink the defconfig file through make savedefconfig.] Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2338/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Kconfig and Makefile update for Netlogic XLR/XLSJayachandran C
Add NLM_XLR_BOARD, CPU_XLR and other config options Makefile updates, mostly based on r4k Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2334/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Platform files for XLR/XLS processor supportJayachandran C
* include/asm/netlogic added with files common for all Netlogic processors (common with XLP which will be added later) * include/asm/netlogic/xlr for XLR/XLS chip specific files * netlogic/xlr for XLR/XLS platform files Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2334/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Netlogic: Cache, TLB support and feature overrides for XLRJayachandran C
CPU_XLR case added to mm/tlbex.c CPU_XLR case added to mm/c-r4k.c for PINDEX attribute Feature overrides for XLR cpu. Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2333/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Netlogic: mach-netlogic include filesJayachandran C
Add war.h and irq.h with XLR/XLS definitions. Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2331/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Netlogic XLR/XLS processor IDs.Jayachandran C
Add Netlogic Microsystems company ID and processor IDs for XLR and XLS processors for CPU probe. Add CPU_XLR to cpu_type_enum. Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2367/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18Linux 2.6.39v2.6.39Linus Torvalds
2011-05-18Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: configfs: Fix race between configfs_readdir() and configfs_d_iput() configfs: Don't try to d_delete() negative dentries. ocfs2/dlm: Target node death during resource migration leads to thread spin ocfs2: Skip mount recovery for hard-ro mounts ocfs2/cluster: Heartbeat mismatch message improved ocfs2/cluster: Increase the live threshold for global heartbeat ocfs2/dlm: Use negotiated o2dlm protocol version ocfs2: skip existing hole when removing the last extent_rec in punching-hole codes. ocfs2: Initialize data_ac (might be used uninitialized)
2011-05-18Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: drivercore: revert addition of of_match to struct device of: fix race when matching drivers
2011-05-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Kludge IP27 build for 2.6.39. MIPS: AR7: Fix GPIO register size for Titan variant. MIPS: Fix duplicate invocation of notify_die. MIPS: RB532: Fix iomap resource size miscalculation.
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-18of: fix race when matching driversMilton Miller
If two drivers are probing devices at the same time, both will write their match table result to the dev->of_match cache at the same time. Only write the result if the device matches. In a thread titled "SBus devices sometimes detected, sometimes not", Meelis reported his SBus hme was not detected about 50% of the time. From the debug suggested by Grant it was obvious another driver matched some devices between the call to match the hme and the hme discovery failling. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Milton Miller <miltonm@bga.com> [grant.likely: modified to only call of_match_device() once] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blocklatestLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: don't delay blk_run_queue_async scsi: remove performance regression due to async queue run blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup block: rescan partitions on invalidated devices on -ENOMEDIA too cdrom: always check_disk_change() on open block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
2011-05-18MIPS: Kludge IP27 build for 2.6.39.Ralf Baechle
2011-05-18MIPS: AR7: Fix GPIO register size for Titan variant.Florian Fainelli
The 'size' variable contains the correct register size for both AR7 and Titan, but we never used it to ioremap the correct register size. This problem only shows up on Titan. [ralf@linux-mips.org: Fixed the fix. The original patch as in patchwork recognizes the problem correctly then fails to fix it ...] Reported-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: https://patchwork.linux-mips.org/patch/2380/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18MIPS: Fix duplicate invocation of notify_die.Ralf Baechle
Initial patch by Yury Polyanskiy <ypolyans@princeton.edu>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2373/
2011-05-18MIPS: RB532: Fix iomap resource size miscalculation.Ralf Baechle
This is the MIPS portion of Joe Perches <joe@perches.com>'s https://patchwork.linux-mips.org/patch/2172/ which seems to have been lost in time and space. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18configfs: Fix race between configfs_readdir() and configfs_d_iput()Joel Becker
configfs_readdir() will use the existing inode numbers of inodes in the dcache, but it makes them up for attribute files that aren't currently instantiated. There is a race where a closing attribute file can be tearing down at the same time as configfs_readdir() is trying to get its inode number. We want to get the inode number of open attribute files, because they should match while instantiated. We can't lock down the transition where dentry->d_inode is set to NULL, so we just check for NULL there. We can, however, ensure that an inode we find isn't iput() in configfs_d_iput() until after we've accessed it. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-18configfs: Don't try to d_delete() negative dentries.Joel Becker
When configfs is faking mkdir() on its subsystem or default group objects, it starts by adding a negative dentry. It then tries to instantiate the group. If that should fail, it must clean up after itself. I was using d_delete() here, but configfs_attach_group() promises to return an empty dentry on error. d_delete() explodes with the entry dentry. Let's try d_drop() instead. The unhashing is what we want for our dentry. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-18block: don't delay blk_run_queue_asyncShaohua Li
Let's check a scenario: 1. blk_delay_queue(q, SCSI_QUEUE_DELAY); 2. blk_run_queue_async(); the second one will became a noop, because q->delay_work already has WORK_STRUCT_PENDING_BIT set, so the delayed work will still run after SCSI_QUEUE_DELAY. But blk_run_queue_async actually hopes the delayed work runs immediately. Fix this by doing a cancel on potentially pending delayed work before queuing an immediate run of the workqueue. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] V4L: soc-camera: regression fix: calculate .sizeimage in soc_camera.c [media] v4l2-subdev: fix broken subdev control enumeration [media] Fix cx88 remote control input [media] v4l: Release module if subdev registration fails
2011-05-18Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, AMD: Fix ARAT feature setting again Revert "x86, AMD: Fix APIC timer erratum 400 affecting K8 Rev.A-E processors" x86, apic: Fix spurious error interrupts triggering on all non-boot APs x86, mce, AMD: Fix leaving freed data in a list x86: Fix UV BAU for non-consecutive nasids x86, UV: Fix NMI handler for UV platforms
2011-05-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf evlist: Fix per thread mmap setup perf tools: Honour the cpu list parameter when also monitoring a thread list kprobes, x86: Disable irqs during optimized callback
2011-05-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: fix cifsConvertToUCS() for the mapchars case cifs: add fallback in is_path_accessible for old servers
2011-05-18procfs: add stub for proc_mkdir_mode()Randy Dunlap
Provide a stub for proc_mkdir_mode() when CONFIG_PROC_FS is not enabled, just like the stub for proc_mkdir(). Fixes this linux-next build error: drivers/net/wireless/airo.c:4504: error: implicit declaration of function 'proc_mkdir_mode' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
