2007-10-30x86 gart: rename iommu.h to gart.hJoerg Roedel
This patch renames the include file asm-x86/iommu.h to asm-x86/gart.h to make clear to which IOMMU implementation it belongs. The patch also adds "GART" to the Kconfig line. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-30x86: additional CPUID strings; fix strings for AMD-ecxH. Peter Anvin
Additional CPUID strings (sse4_1, sse4_2, sse5, skinit, wdt); fix the positioning of the AMD ecx strings (cr8_legacy was duplicated under two different names, so the alignment of all the other strings were off by one.) Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (34 commits) [MIPS] tb0219: Update copyright message. [MIPS] MT: Fix bug in multithreaded kernels. [MIPS] Alchemy: Remove CONFIG_TS_AU1X00_ADS7846 from defconfigs. Author: Ralf Baechle <ralf@linux-mips.org> [MIPS] sb1250: Enable GenBus IDE in defconfig. [MIPS] vmlinux.ld.S: correctly indent .data section [MIPS] c-r3k: Implement flush_cache_range() [MIPS] Store sign-extend register values for PTRACE_GETREGS [MIPS] Alchemy: Register platform devices [MIPS] Add len and addr validation for MAP_FIXED mappings. [MIPS] IRIX: Fix off-by-one error in signal compat code. [MIPS] time: Replace plat_timer_setup with modern APIs. [MIPS] time: Fix cut'n'paste bug in Sibyte clockevent driver. [MIPS] time: Make c0_compare_int_usable faster [MIPS] time: Fix cevt-r4k.c for 64-bit kernel [MIPS] Sibyte: Delete {sb1250,bcm1480}_steal_irq(). [MIPS] txx9tmr clockevent/clocksource driver [MIPS] Add mips_hpt_frequency check to mips_clockevent_init(). [MIPS] IP32: Fixes after interrupt renumbering. [MIPS] IP27: Fix slice logic to work for arbitrary number of slices. ...
2007-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: fix style in kernel/sched.c sched: fix style of swap() macro in kernel/sched_fair.c sched: report CPU usage in CFS cgroup directories sched: move rcu_head to task_group struct sched: fix incorrect assumption that cpu 0 exists sched: keep utime/stime monotonic sched: make kernel/sched.c:account_guest_time() static
2007-10-29Revert "x86_64: allocate sparsemem memmap above 4G"Linus Torvalds
This reverts commit 2e1c49db4c640b35df13889b86b9d62215ade4b6. First off, testing in Fedora has shown it to cause boot failures, bisected down by Martin Ebourne, and reported by Dave Jobes. So the commit will likely be reverted in the 2.6.23 stable kernels. Secondly, in the 2.6.24 model, x86-64 has now grown support for SPARSEMEM_VMEMMAP, which disables the relevant code anyway, so while the bug is not visible any more, it's become invisible due to the code just being irrelevant and no longer enabled on the only architecture that this ever affected. Reported-by: Dave Jones <davej@redhat.com> Tested-by: Martin Ebourne <fedora@ebourne.me.uk> Cc: Zou Nan hai <nanhai.zou@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29sched: fix style in kernel/sched.cIngo Molnar
fallout of recent commits: small coding style fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29sched: fix style of swap() macro in kernel/sched_fair.cIngo Molnar
fix style of swap() macro in kernel/sched_fair.c. ( this macro should eventually move to a general header, as ext3 uses a similar construct too. ) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29sched: report CPU usage in CFS cgroup directoriesPaul Menage
Adds a cpu.usage file to the CFS cgroup that reports CPU usage in milliseconds for that cgroup's tasks [ mingo@elte.hu: style cleanups. ] Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29sched: move rcu_head to task_group structSrivatsa Vaddagiri
Peter Zijlstra noticed that the rcu_head object need not be present in every cfs_rq of a group. Move it to the task_group structure instead. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29sched: fix incorrect assumption that cpu 0 existsJames Bottomley
This patch: commit 9b5b77512dce239fa168183fa71896712232e95a Author: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Date: Mon Oct 15 17:00:09 2007 +0200 sched: clean up code under CONFIG_FAIR_GROUP_SCHED Introduced an assumption of the existence of CPU0 via this line cfs_rq = tg->cfs_rq[0]; If you have no CPU0, that will be NULL. The fix seems to be just to take whatever cfs_rq queue comes out of the for_each_possible_cpu() loop, since they're all equally good for the destruction operation. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29sched: keep utime/stime monotonicPeter Zijlstra
keep utime/stime monotonic. cpustats use utime/stime as a ratio against sum_exec_runtime, as a consequence it can happen - when the ratio changes faster than time accumulates - that either can be appear to go backwards. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29sched: make kernel/sched.c:account_guest_time() staticAdrian Bunk
account_guest_time() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29[MIPS] tb0219: Update copyright message.Ralf Baechle
2007-10-29[MIPS] MT: Fix bug in multithreaded kernels.Ralf Baechle
When GDB writes a breakpoint into address area of inferior process the kernel needs to invalidate the modified memory in the inferior which is done by calling flush_cache_page which in turns calls r4k_flush_cache_page and local_r4k_flush_cache_page for VSMP or SMTC kernel via r4k_on_each_cpu(). As the VSMP and SMTC SMP kernels for 34K are running on a single shared caches it is possible to get away without interprocessor function calls. This optimization is implemented in r4k_on_each_cpu, so local_r4k_flush_cache_page is only ever called on the local CPU. This is where the following code in local_r4k_flush_cache_page() strikes: /* * If ownes no valid ASID yet, cannot possibly have gotten * this page into the cache. */ if (cpu_context(smp_processor_id(), mm) == 0) return; On VSMP and SMTC had a function of cpu_context() for each CPU(TC). So in case another CPU than the CPU executing local_r4k_cache_flush_page has not accessed the mm but one of the other CPUs has there may be data to be flushed in the cache yet local_r4k_cache_flush_page will falsely return leaving the I-cache inconsistent for the breakpoint. While the issue was discovered with GDB it also exists in local_r4k_flush_cache_range() and local_r4k_flush_cache(). Fixed by introducing a new function has_valid_asid which on MT kernels returns true if a mm is active on any processor in the system. This is relativly expensive since for memory acccesses in that loop cache misses have to be assumed but it seems the most viable solution for 2.6.23 and older -stable kernels. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: Remove CONFIG_TS_AU1X00_ADS7846 from defconfigs.Ralf Baechle
2007-10-29Author: Ralf Baechle <ralf@linux-mips.org>Ralf Baechle
[MIPS] MSP71xx: Fix bitrot. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] sb1250: Enable GenBus IDE in defconfig.Maciej W. Rozycki
Enable the onboard GenBus IDE interface in the default configuration. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] vmlinux.ld.S: correctly indent .data sectionFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] c-r3k: Implement flush_cache_range()Maciej W. Rozycki
Contrary to the belief of some, the R3000 and related processors did have caches, both a data and an instruction cache. Here is an implementation of r3k_flush_cache_page(), which is the processor-specific back-end for flush_cache_range(), done according to the spec in Documentation/cachetlb.txt. While at it, remove an unused local function: get_phys_page(), do some trivial formatting fixes and modernise debugging facilities. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Store sign-extend register values for PTRACE_GETREGSAtsushi Nemoto
A comment on ptrace_getregs() states "Registers are sign extended to fill the available space." but it is not true. Fix code to match the comment. Also fix casts on each caller to get rid of some warnings. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: Register platform devicesFlorian Fainelli
This patch separates the platform devices registration for the MTX-1 specific devices: GPIO leds and watchdog. [Minor fixup and formatting change -- Ralf] Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Add len and addr validation for MAP_FIXED mappings.David Daney
Mmap with MAP_FIXED was not validating the addr and len parameters. This leads to the failure of GCC's gcc.c-torture/execute/loop-2[fg].c testcases when using the o32 ABI on a 64 bit kernel. These testcases try to mmap 65536 bytes at 0x7fff8000 and then access all the memory. In 2.6.18 and 2.6.23.1 (and likely other versions as well) the kernel maps the requested memory, but since half of it is above 0x80000000 a SIGBUS is generated when it is accessed. This patch moves the len validation above the MAP_FIXED processing so that it is always validated. It also adds validation to the addr parameter for MAP_FIXED mappings. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] IRIX: Fix off-by-one error in signal compat code.Ralf Baechle
Based on original patch by Roel Kluin <12o3l@tiscali.nl>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Replace plat_timer_setup with modern APIs.Ralf Baechle
plat_timer_setup is no longer getting called. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Fix cut'n'paste bug in Sibyte clockevent driver.Ralf Baechle
2007-10-29[MIPS] time: Make c0_compare_int_usable fasterAtsushi Nemoto
Try increasingly longer time periods starting of at 0x10 cycles. This should be fast on hardware and work nicely with emulators. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Fix cevt-r4k.c for 64-bit kernelAtsushi Nemoto
The expression "(long)(read_c0_count() - cnt)" can never be a negative value on 64-bit kernel. Cast to "int" before comparison. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Sibyte: Delete {sb1250,bcm1480}_steal_irq().Ralf Baechle
They break the timer interrupt initialization and only seem to be a kludge for initialization happening in the wrong order. Further testing done by Thiemo confirms the suspicion that the other invocations also seem to have useless. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] txx9tmr clockevent/clocksource driverAtsushi Nemoto
Convert jmr3927_clock_event_device to more generic txx9tmr_clock_event_device which supports one-shot mode. The txx9tmr_clock_event_device can be used for TX49 too if the cp0 timer interrupt was not available. Convert jmr3927_hpt_read to txx9_clocksource driver which does not depends jiffies anymore. The txx9_clocksource itself can be used for TX49, but normally TX49 uses higher precision clocksource_mips. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Add mips_hpt_frequency check to mips_clockevent_init().Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] IP32: Fixes after interrupt renumbering.Ralf Baechle
And general untangling. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] IP27: Fix slice logic to work for arbitrary number of slices.Ralf Baechle
2007-10-29[MIPS] SNI: Convert a20r timer to clockevent device.Ralf Baechle
2007-10-29[MIPS] time: Merge eXcite plat_timer_setup into plat_time_init.Ralf Baechle
Fixme: At the time of this writing cevt-r4k.c doesn't yet know about how to handle the alternate timer interrupt of the RM9000. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Merge lasat plat_timer_setup into plat_time_init.Ralf Baechle
Since the cp0 compare interrupt handler isn't initialized by the time plat_time_init is called don't set IE_IRQ5 anymore, cevt-r4k.c will do that a little later itself. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Remove wrppmc's definition of plat_timer_setup.Ralf Baechle
The only thing it used to do is now done by cevt-r4k.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Cause platform definitions of plat_timer_setup to cause error.Ralf Baechle
2007-10-29[MIPS] time: Remove declaration of plat_timer_setup, there is no caller.Ralf Baechle
2007-10-29[MIPS] Alchemy: Convert from plat_timer_setup to plat_time_init.Ralf Baechle
The old plat_timer_setup hook is no longer getting called so the Alchemy time initialization was getting skipped. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] vpe: Use p_paddr instead of p_vaddr loader.Ralf Baechle
This subtle difference makes ELF overlays work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Cleanup random difference between the lmo and kernel.org tree.Ralf Baechle
2007-10-29[MIPS] time: set clock before clockevent_delta2ns() in GT641xx.Yoichi Yuasa
clockevent_delta2ns() use the shift and mult value, so clockevent_set_clock() should be called first. Pointed out by Atsushi Nemoto. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] time: Use non-interrupt locks in GT641xx clockevent driverYoichi Yuasa
set_next_event() and set_mode() are always called with interrupt disabled. irqsave and irqrestore are not necessary for spinlock. Pointed out by Atsushi Nemoto. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: micro-optimizatize time code.Ralf Baechle
2007-10-29[MIPS] Alchemy: Nuke homebrew setup_irq(), it's broken and unnecessary.Ralf Baechle
2007-10-29[MIPS] SMTC: Allow control over TC assignment to vpe0.Kevin D. Kissell
Modify the SMTC initialization code to allow boot-time specification not only of how many VPEs and TCs to use, but also how many TCs out of the allowed pool are to be bound to VPE 0. The new boot option is "vpe0tcs=N", where N is an integer. Using it in combination with the existing options allows arbitrary assignments across the 2 VPEs of a 34K. e.g. "maxtcs=3 vpe0tcs=1" forces VPE0 to have 1 TC, while VPE1 has 2, and "maxtcs=4 vpe0tcs=3" forces VPE0 to have 3 TCs, while VPE1 gets 1. If no vpe0tcs option is specified, the traditional algorithm of evenly dividing TCs between available VPEs, with the odd "slop" going to VPE0, is retained. The reason for doing this is to allow a finer balancing of TCs which can handle I/O interrupts on Malta (those on VPE 0) and those which cannot. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29Merge branch 'alpm' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'alpm' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] AHCI: add hw link power management support [libata] Link power management infrastructure
2007-10-29Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] AHCI: fix newly introduced host-reset bug [libata] sata_nv: fix SWNCQ enabling libata: add MAXTOR 7V300F0/VA111900 to NCQ blacklist libata: no need to speed down if already at PIO0 libata: relocate forcing PIO0 on reset pata_ns87415: define SUPERIO_IDE_MAX_RETRIES [libata] Address some checkpatch-spotted issues [libata] fix 'if(' and similar areas that lack whitespace libata: implement ata_wait_after_reset() libata: track SLEEP state and issue SRST to wake it up libata: relocate and fix post-command processing
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (22 commits) Fix ethernet multicast for ucc_geth. netdrvr/pcmcia: use IRQ_TYPE_DYNAMIC_SHARING flag for irq.Attributes. FEC - fast ethernet controller for mpc52xx ehea: add kexec support e1000e: Remove legacy jumbo frame receive code e1000e: Re-enable SECRC - crc stripping e1000e: Fix PBA calculation for jumbo frame packets e1000e: Fix jumbo frame receive code. drivers/net/irda/au1k_ir: fix obvious irq handler bugs ipg: Kconfig whitepaces/tab damages ipg: missing Kconfig dependency r8169: remove poll_locked logic r8169: napi config [PATCH] iwl3945: fix direct scan problem [PATCH] iwl3945: cancel scan on rxon command [PATCH] iwl4965: fix scan problem [PATCH] iwl4965: fix driver hang related to hardware scan [PATCH] iwlwifi: fix sending probe request in iwl 4965 [PATCH] rtl8187: Allow multicast frames [PATCH] b43/b43legacy: jiffies_round -> jiffies_round_relative ...
2007-10-29Merge branch 'warnings-upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'warnings-upstream' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6: [ISDN] capidrv: address two longstanding warnings
