Patch from Deepak Saxena
The current memset() and memzero() macros on ARM reference the
incoming parameters more than once and this can cause uninted
side-effects. The issue was found while debugging SCTP protocol
and with the specific usage of memzero(skb_put(skb,size),size).
This call would call skb_put(skb,size) twice leading to badness.
The fixed version copies the incoming parameters into local
variables and uses those instead.
Signed-off-by: Deepak Saxena
Signed-off-by: Russell King
Patch from Jeff Lackey
This patch updates arch/arm/mach-pxa/sleep.S to support
the PXA270 CPU. It works around Errata 39 & 50 from the
Intel(R) PXA27x Processor Family Specification Update.
Signed-off-by: Jeff Lackey
Patch from Lucas Correia Villa Real
Adds IISFCON definitions for the S3C2400 at
include/asm-arm/arch-s3c2400/regs-iis.h.
Signed-off-by: Lucas Correia Villa Real
Signed-off-by: Ben Dooks
The S3C2400 doesn't have a cpuid information stored anywhere. This patch adds
support to the S3C2400 at include/asm-arm/arch-s3c2400/uncompress.h by
initializing the cpuid variable to the S3C2410, as they share the same
routine. The GSTATUS1 pin is then used only if not compiling for the S3C2400.
Adds a define to the SPI Card Select bit on the S3C2400 into
include/asm-arm/arch-s3c2410/regs-spi.h
Adds DRAM refresh definitions and sets the BANKSIZE_MASK for the S3C2400 on
include/asm-arm/arch-s3c2400/regs-mem.h
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
void * __iomem foo is not a pointer to iomem - it's an iomem variable
containing void *. A pile of such guys in arch/sparc64/kernel/time.c,
drivers/sbus/char/rtc.c and include/asm-sparc64/mostek.h turned into
intended void __iomem *.
Missing include - usual portability problems...
(!ARCH_S390 && !M68K && !IA64 && !UML) is obviously always true on ARM.
Intended behaviour for ARM is "absent unless we are on RiscPC or
EBSA285". So what we want is added && !ARM in the first term - without
it the last part (|| ARCH_RPC || ARCH_EBSA285, that is) doesn't do
anything.
Missing include, breaks at least on arm.
Turns __get_unaligned() and __put_unaligned into macros. That is
definitely safe; leaving them as inlines breaks on e.g. alpha [try to
build ncpfs there and you'll get unresolved symbols since we end up
getting __get_unaligned() not inlined].
All boards dealt with by I2C_MPC are 32bit. Moreover, driver simply
won't build on ppc64 - it uses ppc32-only types all over the place.
Dependency fixed - it's PPC32, not PPC.
CONFIG_HW_CONSOLE selects vt.c; without the stuff pulled by CONFIG_VT it
will not build. Normally we get both in drivers/char/Kconfig and there
HW_CONSOLE depends on VT. sparc64 does not pull drivers/char/Kconfig
and has that sutff in arch/sparc64/Kconfig instead. However, it forgets
to add the same dependency. As the result, turning VT off [which is
possible] will end up with broken build. For no good reason...
Dumb typo - __get_free_page() takes gfp mask (in this case -
GFP_KERNEL), not the page size...
zonelist_policy() forgot to mask non-zone bits from gfp when comparing
zone number with policy_zone.
ACKed-by: Andi Kleen <ak@suse.de>
Somebody forgot that | has higher priority than ?:. As the result,
allocation is done with bogus flags - instead of GFP_ATOMIC + possibly
GFP_DMA we always get GFP_DMA and no GFP_ATOMIC.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
This patch is required to support cpu removal for IPF systems. Existing code
just fakes the real offline by keeping it run the idle thread, and polling
for the bit to re-appear in the cpu_state to get out of the idle loop.
For the cpu-offline to work correctly, we need to pass control of this CPU
back to SAL so it can continue in the boot-rendez mode. This gives the
SAL control to not pick this cpu as the monarch processor for global MCA
events, and addition does not wait for this cpu to checkin with SAL
for global MCA events as well. The handoff is implemented as documented in
SAL specification section 3.2.5.1 "OS_BOOT_RENDEZ to SAL return State"
Found by Alexander Nyberg, improved by Bjorn Helgaas.
- Fix the incorrect argument to sizeof()
- looks like memcpy() code pass was dervived from code that used
copy_from_user(). But in this case we are doing to kernel space
to kernel space copy, so memcpy is the right routine, but it
doesn't return an error code.
Signed-off-by: Arun Sharma <arun.sharma@intel.com>
The labels after the last put_user patch were misplaced so
exceptions on the real mov instructions would not be handled.
Noted by Brian Gerst <bgerst@didntduck.org>
This breaks serial consoles badly. Thanks to Eric Brower
for tracking down the problem.
We were forgetting to call sunsu_change_speed(). The reason
that replugging in the mouse cable "fixes things" is that
causes a BREAK interrupt which in turn caused a call to
sunsu_change_speed() which would get the chip setup properly.
Provide support for drivers/char/rtc.c ioctls in the
Mostek rtc driver as well as the Sparc specific RTCGET
and RTCSET.
This allows userspace to be much less messy. Currently
util-linux and other spots jump through hoops trying
various ioctl variants until it hits the right one whatever
driver actually being used supports.
Eventually all of this should move over to the genrtc.c
driver, but not today...
While we are here, fix up the register types for sparse.
Thanks to Frans Pop for helping point out this issue.
Use 'daddr' instead of &tmpl->id.daddr, since the latter
might be zero. Also, only perform the lookup when
tmpl->id.spi is non-zero.
Add MSI test for chips that support MSI. If MSI test fails, it will
switch back to INTx mode and will print a message asking the user to
report the failure.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Add MSI support for 5751 C0 and 5752.
Fix a bug in tg3_set_eeprom() when the length is less than 4 and the
offset is not 4-byte aligned.
Add support for the NVRAM lock-out feature for TPM in 5752. If lock-out
is enabled, certain NVRAM registers cannot be written to.
Add bit definitions for the new GPIO3 in 5752. GPIO3 must be driven as
output when it is unused.
The 5752 A0 chip ID is wrong in hardware. The simplest way to workaround
it is to change it to the correct value in tp->pci_chip_rev_id. This
way, it is easier to check for the ASIC_REV_5752 in the rest of the
driver.
Fix tg3_set_power_state to drive GPIOs properly based on the
TG3_FLAG_EEPROM_WRITE_PROTECT flag. Some delays are also added after D0
and D3 power state changes.
Setup proper GPIO settings in tp->grc_local_ctrl before calling
tg3_set_power() state in tg3_get_invariants() and after chip reset.
Split the 1st half of tg3_phy_probe() into tg3_get_eeprom_hw_cfg() so
that the TG3_FLAG_EEPROM_WRITE_PROT can be determined before calling
tg3_set_power_state() in tg3_get_invariants(). This will allow
tg3_set_power_state() to drive the GPIOs correctly based on the config.
information in eeprom.
On the 5752, there are no pull-up resistors on the GPIO pins and it is
necessary to drive the unused GPIOs as output.
Some minor 5752 fixes mostly for correctness and add 5752 PHY ID.
Replace existing ASIC_REV_5752 definition with ASIC_REV_5752_A0,
and add definition for ASIC_REV_5752_A1. Then, add ASIC_REV_5752_A1
to check for setting TG3_FLG2_5750_PLUS in tg3_get_invariants.
Use check of TG3_FLG2_5750_PLUS in tg3_get_invariants to set
TG3_FLG2_5705_PLUS flag.
Rewrite checks in tg3_get_invariants to use TG3_FLG2_5705_PLUS and
TG3_FLG2_5750_PLUS flags.
Rewrite of a couple of troublesome multi-way if statements to use
Replace a number of two-way if statements checking for 5750, and/or
5752 to reference the newly-defined TG3_FLG2_5750_PLUS flag instead.
Define TG3_FLG2_5750_PLUS flag and set it in tg3_get_invariants for
ASIC_REV_5750 or ASIC_REV_5752.
Replace a number of three-way if statements checking for 5705, 5750,
and 5752 to reference the equivalent TG3_FLG2_5705_PLUS flag instead.
Add proper entry for bcm5752 PCI ID to pci_ids.h, and use it in tg3.
I did this separately in case patches like this (i.e. new PCI IDs)
need to come from more "official" sources.
Add hard-coded definition of bcm5752 PCI ID to tg3_pci_tbl.
Next patch will change entry to use pci_ids.h-based definition.
Add ASIC_REV_5752 definition.
Track-down all references to ASIC_REV_5750 and mirror them with
references to the newly defined ASIC_REV_5752.
