2007-10-16Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: (264 commits) [ALSA] version 1.0.15 [ALSA] Fix thinko in cs4231 mce down check [ALSA] sun-cs4231: improved waiting after MCE down [ALSA] sun-cs4231: use cs4231-regs.h [ALSA] This simplifies and fixes waiting loops of the mce_down() [ALSA] This patch adds support for a wavetable chip on [ALSA] This patch removes open_mutex from the ad1848-lib as [ALSA] fix bootup crash in snd_gus_interrupt() [ALSA] hda-codec - Fix SKU ID function for realtek codecs [ALSA] Support ASUS P701 eeepc [0x1043 0x82a1] support [ALSA] hda-codec - Add array terminator for dmic in STAC codec [ALSA] hdsp - Fix zero division [ALSA] usb-audio - Fix double comment [ALSA] hda-codec - Fix STAC922x volume knob control [ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.cz [ALSA] hda-codec - Fix for Fujitsu Lifebook C1410 [ALSA] mpu-401: remove MPU401_INFO_UART_ONLY flag [ALSA] mpu-401: do not require an ACK byte for the ENTER_UART command [ALSA] via82xx - Add DXS quirk for Shuttle AK31v2 [ALSA] hda-codec - Fix input_mux numbers for vaio stac92xx ...
2007-10-16Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: (63 commits) Fix memory leak in dm-crypt SPARC64: sg chaining support SPARC: sg chaining support PPC: sg chaining support PS3: sg chaining support IA64: sg chaining support x86-64: enable sg chaining x86-64: update pci-gart iommu to sg helpers x86-64: update nommu to sg helpers x86-64: update calgary iommu to sg helpers swiotlb: sg chaining support i386: enable sg chaining i386 dma_map_sg: convert to using sg helpers mmc: need to zero sglist on init Panic in blk_rq_map_sg() from CCISS driver remove sglist_len remove blk_queue_max_phys_segments in libata revert sg segment size ifdefs Fixup u14-34f ENABLE_SG_CHAINING qla1280: enable use_sg_chaining option ...
2007-10-16time: introduce xtime_secondsIngo Molnar
improve performance of sys_time(). sys_time() returns time in seconds, but it does so by calling do_gettimeofday() and then returning the tv_sec portion of the GTOD time. But the data structure "xtime", which is updated by every timer/scheduler tick, already offers HZ granularity time. the patch improves the sysbench oltp macrobenchmark by 4-5% on an AMD dual-core system: v2.6.23: #threads 1: transactions: 4073 (407.23 per sec.) 2: transactions: 8530 (852.81 per sec.) 3: transactions: 8321 (831.88 per sec.) 4: transactions: 8407 (840.58 per sec.) 5: transactions: 8070 (806.74 per sec.) v2.6.23 + sys_time-speedup.patch: 1: transactions: 4281 (428.09 per sec.) 2: transactions: 8910 (890.85 per sec.) 3: transactions: 8659 (865.79 per sec.) 4: transactions: 8676 (867.34 per sec.) 5: transactions: 8532 (852.91 per sec.) and by 4-5% on an Intel dual-core system too: 2.6.23: 1: transactions: 4560 (455.94 per sec.) 2: transactions: 10094 (1009.30 per sec.) 3: transactions: 9755 (975.36 per sec.) 4: transactions: 9859 (985.78 per sec.) 5: transactions: 9701 (969.72 per sec.) 2.6.23 + sys_time-speedup.patch: 1: transactions: 4779 (477.84 per sec.) 2: transactions: 10103 (1010.14 per sec.) 3: transactions: 10141 (1013.93 per sec.) 4: transactions: 10371 (1036.89 per sec.) 5: transactions: 10178 (1017.50 per sec.) (the more CPUs the system has, the more speedup this patch gives for this particular workload.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16CREDITS: correct Mikael Pettersson's URLMikael Pettersson
New URL due to local reorganization.
2007-10-16powerpc32 vDSO: linker script indentationRoland McGrath
This cleans up the formatting in the vDSO linker script, mostly just the use of whitespace. It's intended to approximate the kernel standard conventions for indenting C, treating elements of the linker script about like initialized variable definitions. Signed-off-by: Roland McGrath <roland@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16powerpc64 vDSO: linker script indentationRoland McGrath
2007-10-16SH vDSO: linker script indentationRoland McGrath
This cleans up the formatting in the vDSO linker script, mostly just the use of whitespace. It's intended to approximate the kernel standard conventions for indenting C, treating elements of the linker script about like initialized variable definitions. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ia64 vDSO: linker script indentationRoland McGrath
2007-10-16lockdep: fixup the inode dir annotationPeter Zijlstra
A slight oversight tripped lockdep debugging code, each lockdep class should have but a single init site. Rearange the code to make this true. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16scsi_mac.h: Define AUTOSENSE before include of NCR5380.hBoaz Harrosh
- Previese patch to NCR5380 broke scsi_mac because AUTOSENSE was defined after the inclusion of NCR5380.h. Fix it Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16net/sunrpc/xprtrdma/verbs.c printk warning fixAndrew Morton
sparc64: net/sunrpc/xprtrdma/verbs.c:1264: warning: long long unsigned int format, u64 arg (arg 3) net/sunrpc/xprtrdma/verbs.c:1264: warning: long long unsigned int format, u64 arg (arg 4) Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "David S. Miller" <davem@davemloft.net> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tgafb: remove a redundant non-mono test in mono imageblitMaciej W. Rozycki
There is a test in tgafb_mono_imageblit() for a colour image with a fall-back to cfb_imageblit(). The test is not necessary as the only caller, which is tgafb_imageblit(), checks it too and only invokes this function for monochrome images. It looks like a left-over from before some changes to tgafb_imageblit(). Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Antonino Daplas <adaplas@pol.net> Cc: Jay Estabrook <Jay.Estabrook@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tgafb: fix an out-of-range shift in mono imageblitMaciej W. Rozycki
The pixel mask calculation in tgafb_mono_imageblit() uses a variable left-shift on a 32-bit data type by up to 32. Shifting by the width of a data type or more produces an unpredictable result according to the C standard. Rather than widening the data type this fix makes sure the count is between 0 and 31. The reason is not to penalise 32-bit platforms with operation on a "long long" type for a marginal case that is meant not to happen (blitting an image of a zero width). The reason it has escaped for so long is the Alpha, being purely 64-bit, :-) does not mask the shift out to 32 bits. This is a valid implementation -- producing the correct result certainly falls within "unpredictable behaviour". It does trigger on MIPS though and it is the recent merge of the TC support which only enabled the driver for use on anything other than the Alpha. For MIPS when the width is 32 the mask ends up being 0 rather than 0xffffffff as it should be and the frame buffer is not updated. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Antonino Daplas <adaplas@pol.net> Cc: Jay Estabrook <Jay.Estabrook@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbcon: delay the start of the cursor timer until a con_switch()Antonino Daplas
As reported in Bugzilla Bug 9093, upon switching to X, a small rectangular cursor can still be seen blinking in the upper left part of the screen. It is fbcon's text cursor. This is caused by a strange ioctl(..., KDSETMODE, KD_TEXT) call done by something in userspace, perhaps by X itself, while the tty is still in graphics mode. And when the tty is in KD_TEXT mode, the cursor timer is restarted. Although this is a userspace problem, we can work around it by delaying the restart of the cursor timer until an fbcon_switch() is called. In other words, the cursor timer will not be restarted even if a KD_TEXT mode switch is requested. Regression potential: Present but low Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: copyarea function taught to fully support swapped pixel order in bytePavel Pisa
This correct case, when source and destination X coordinates difference is n multiple of pixels in byte. This is probably rare case, but this case should supported for completeness. Reorganization of FB_READL and FB_WRITEL calls results in code size decrease for normal build without swapping support and size with support enabled is reasonable too. [adaplas] Add missing fb_rev_pixels_in_long() prototype. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3fb: do not allow incorrect pixclock settingsKrzysztof Helt
This patch adds check if selected pixclock is valid (is in the PLL range). Previously, if the pixclock could not be set, the new mode resolution was set but pixclock was not set which led to incorrect timings sent to monitor. [adaplas] Fixed a few misplaced curly braces. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16svgalib: mode selection updatesOndrej Zajicek
This patch changes mode selection matching algorithm. It allows to choose mode with matching depth even when requested color lengths are greater than color lengths of every mode with requested color depth. It also fixes bug in s3fb - wrong error value returned when format is not supported by chip. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: default to 480p on DVI-D/HDMI if video=safeGeert Uytterhoeven
Default to the 480p video mode on DVI-D and HDMI displays if `video=safe' is passed on the kernel command line. This is intended to be used by `kboot'-style boot loaders (i.e. first-stage kernels) for the PS3, to provide a failsafe video mode. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fb: move and rename extern declaration for global_mode_optionGeert Uytterhoeven
Move the extern declaration for global_mode_option to <linux/fb.h> and rename the variable to fb_mode_option. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: enhance horizontal panning on firmware 1.90 and upGeert Uytterhoeven
ps3fb: Enhance horizontal panning on firmware 1.90 and up: - On firmware 1.90 and up, L1GPU_CONTEXT_ATTRIBUTE_FB_BLIT supports copying rectangles from XDR to DDR memory with different source and destination line lengths. Hence larger horizontal virtual resolutions can be supported (up to 16368 pixels). - As the actual frame buffer memory layout no longer matches the entries in ps3fb_res[], create fake struct ps3fb_ioctl_res data for the PS3FB_IOCTL_SCREENINFO ioctl, so user space applications that depend on it keep on working. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: add virtual screen and panning supportGeert Uytterhoeven
ps3fb: Add virtual screen and panning support: - The vertical virtual screen size is limited by the amount of memory reserved for ps3fb, - The horizontal virtual screen size is limited to the fullscreen width, - Advertise that we support panning, so fbcon will use it if the virtual screen is enabled. Enabling a virtual screen (using `fbset -vyres nnn') can speed up text console scrolling by a factor of 10-15, depending on the video mode. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: don't keep the borders for non-fullscreen modes in XDR memoryGeert Uytterhoeven
Don't keep the borders for non-fullscreen modes in XDR memory: - Extract ps3fb_sync_image() - Work around the alignment restrictions of L1GPU_CONTEXT_ATTRIBUTE_FB_BLIT by using an offset with L1GPU_CONTEXT_ATTRIBUTE_DISPLAY_FLIP - Only copy the visible part of the screen on every vblank - Always put the real frame buffer at the start of video memory - Clear fullscreen DDR memory on mode change Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: use fb_info.par properlyGeert Uytterhoeven
ps3fb: Use fb_info.par properly: o Move mode-specific fields into struct ps3fb_par o Allocate struct ps3fb_par using framebuffer_alloc() o Protect access to ps3fb_par in ps3fb_sync() using the console semaphore (this semaphore is already held when ps3fb_set_par() is called) o Avoid calling ps3av_set_video_mode() if the actual video mode hasn't changed Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: fix possible overlap of GPU command buffer and frame bufferGeert Uytterhoeven
ps3fb: In the case of non-fullscreen video modes, there was a partial overlap of the GPU command buffer and the frame buffer. Fix and cleanup various issues with overlap and alignment: - Move the GPU command buffer from the beginning to the end of video memory - Exclude the GPU command buffer from the actual frame buffer memory - Align the start of the virtual frame buffer to PAGE_SIZE instead of to 64 KiB, and don't waste memory if it's already aligned (for fullscreen modes) - Take into account the alignment when checking memory requirements and maximum number of frames - Make sure fb_fix_screeninfo.smem_start always points to the virtual frame buffer start, so we don't have to compensate for that in ps3fb_mmap() Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: make ps3fb_wait_for_vsync() and ps3fb_flip_ctl() staticGeert Uytterhoeven
Make ps3fb_wait_for_vsync() and ps3fb_flip_ctl() static, as they're no (longer) used outside ps3fb. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: clean up includesGeert Uytterhoeven
Clean up includes Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: do not print warnings on invalid frame numbersGeert Uytterhoeven
Do not print warnings on invalid frame numbers, as this can be triggered from user space. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3fb: convert from printk()/DPRINTK() to dev_*()/pr_*()Geert Uytterhoeven
Convert ps3fb from printk()/DPRINTK() to dev_*()/pr_*() Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16imxfb: fast read flag and nonstandard field configurablePavel Pisa
The i.MX frame-buffer read operation should be faster for all configurations then drawing each individual character again in response to scroll events. The nonstandard fields allows to configure frame-buffer special options flags for different display configurations by board specific initialization code. One of such specific options is reversed order of pixels in each individual byte. i.MX frame-buffer seems to be designed for big-endian use first. The byte order is correctly configured for little-endian ordering, but if 1, 2 or 4 bits per pixel are used, pixels ordering is incompatible to Linux generic frame-buffer drawing functions. The patch "Allow generic BitBLT functions to work with swapped pixel order in bytes" introduces required functionality into FBDEV core. The pixels ordering selection has to be enabled at compile time CONFIG_FB_CFB_REV_PIXELS_IN_BYTE and for each display configuration which requires it by flag FB_NONSTD_REV_PIX_IN_B in "nonstd" field of info structure. This patch provides way for board specific code to select this option. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: dont distinguish between `boot' and `non-boot' autodetectionGeert Uytterhoeven
don't distinguish between `boot' and `non-boot' autodetection now the autodetection code has been improved Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: remove unused ps3av_set_mode()Geert Uytterhoeven
remove unused ps3av_set_mode() Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: add quirk database for broken monitorsGeert Uytterhoeven
add a quirk database for broken monitors where the `best' advertised video mode doesn't work Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: add autodetection for VESA modesGeert Uytterhoeven
add autodetection for VESA modes Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: treat DVI-D like HDMI in autodetectGeert Uytterhoeven
treat DVI-D monitors like HDMI monitors when autodetecting the best video mode Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: use PS3 video mode ids in autodetect codeGeert Uytterhoeven
It doesn't make much sense to use the PS3AV_CMD_VIDEO_VID_* values in the autodetection code, just to convert them to PS3 video mode ids afterwards. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: eliminate PS3AV_DEBUGGeert Uytterhoeven
ps3av: eliminate PS3AV_DEBUG - Move ps3av_cmd_av_monitor_info_dump from ps3av_cmd.c to ps3av.c, as it's used there only - Integrate ps3av_cmd_av_hw_conf_dump() into its sole user - Use pr_debug() for printing debug info Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ps3av: eliminate unneeded temporary variablesGeert Uytterhoeven
ps3av: eliminate unneeded temporary variables Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16video gfx: merge kconfig menusRandy Dunlap
Move AGP and DRM menus into the video graphics support menu. They use 'menuconfig' so that they can all be disabled with one selection. Make the console menu use 'menuconfig' so that it can all be disabled with one selection. Make the frame buffer menu use 'menuconfig' so that it can all be disabled with one selection. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16bf54x-lq043fb: framebuffer driver for Blackfin BF54x framebuffer device driverMichael Hennerich
Blackfin BF54x framebuffer device driver for a SHARP LQ043T1DG01 TFT LCD [adaplas] Add 'fb' suffix to driver name. Move Makefile entry under platform device section Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbcon: logo: disable logo at bootRandy Dunlap
Add logo.nologo kernel boot option to disable the logo in order to provide more screen space for kernel messages; especially useful when debugging and screen space is more critical. newport_con driver changes are untested. [akpm@linux-foundation.org: cleanups, coding-style fixes] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pmagb-b-fb: improve diagnosticsMaciej W. Rozycki
Add error messages to the probe call. [adaplas] On failure, return actual error value instead of -ENXIO. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16nvidiafb: Correctly assign the i2c class with the port reversalAntonino A. Daplas
If the i2c ports are to be reversed, I2C_CLASS_HWMON assignment must also be reversed. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16vt/vgacon: Check if screen resize request comes from userspaceAntonino A. Daplas
Various console drivers are able to resize the screen via the con_resize() hook. This hook is also visible in userspace via the TIOCWINSZ, VT_RESIZE and VT_RESIZEX ioctl's. One particular utility, SVGATextMode, expects that con_resize() of the VGA console will always return success even if the resulting screen is not compatible with the hardware. However, this particular behavior of the VGA console, as reported in Kernel Bugzilla Bug 7513, can cause undefined behavior if the user starts with a console size larger than 80x25. To work around this problem, add an extra parameter to con_resize(). This parameter is ignored by drivers except for vgacon. If this parameter is non-zero, then the resize request came from a VT_RESIZE or VT_RESIZEX ioctl and vgacon will always return success. If this parameter is zero, vgacon will return -EINVAL if the requested size is not compatible with the hardware. The latter is the more correct behavior. With this change, SVGATextMode should still work correctly while in-kernel and stty resize calls can expect correct behavior from vgacon. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16video gfx: fix menu orderingRandy Dunlap
Move video graphics driver configs to fix menus: Fix FB_PMAGB_B to depend on FB so that the FB menus remain listed in order and indented correctly. Fix FB_IBM_GXT4500 to depend on FB so that the FB menus remain listed in order and indented correctly. The OMAP FB drivers still muck up the FB menu a bit, so I put OMAP drivers at the end of the FB menu. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: more interlaced mode supportKrzysztof Halasa
Intel FB: allow odd- and even-field-first in interlaced modes, and proper sync to vertical retrace Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: force even line count in interlaced modeKrzysztof Halasa
Intel FB: the chip adds two halflines automatically in interlaced mode, force even line count for the right timings. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: obvious changes and correctionsKrzysztof Halasa
Intel FB: obvious changes and corrections Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: whitespace, bracket and other clean-upsKrzysztof Halasa
Intel FB: whitespace, bracket and other clean-ups Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16drivers/video/pmag-ba-fb.c: improve diagnosticsMaciej W. Rozycki
Add error messages to the probe call. While they may rarely trigger, they may be useful when something weird is going on. Also this is good style. [akpm@linux-foundation.org: remove unneeded initialisation] Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Radeonfb Xpress 200M RC410 supportSellout Bessie
Make radeonfb work ith the 200m Xpress RC410. In my tests it was terribly unstable and would freeze until I set a refresh rate in the kernel argument to 75. e.g video=radeonfb:1280x800@75 Now it is rock solid. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
