Intel WiFi devices 3945 and 4965 now have their own driver in the folder
drivers/net/wireless/iwlegacy
Add support to build these drivers independently of the driver for
AGN devices. Selecting the 3945 builds iwl3945.ko and iwl_legacy.ko,
and selecting the 4965 builds iwl4965.ko and iwl_legacy.ko. iwl-legacy.ko
contains code shared between both devices.
The 3945 is an ABG/BG device, with no support for 802.11n. The 4965 is a 2x3
ABGN device.
Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com>
Acked-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
For non-combo devices, 2-wire BT coex is needed to make sure BT coex
still function with external BT devices
During uCode loading, if the reply_alive come back with "failure",
try to load the same uCode again.
If device has serious problem and cause firmware can not recover itself.
Keep reloading firmware will not help, it can only fill up the syslog and
lock up the system because busy reloading.
Introduce the limit reload counter, if the reload reach the maximum within
the pre-defined duration;stop the reload operation.
drivers/bluetooth/ath3k.c
drivers/bluetooth/btusb.c
Clear IEEE80211_STA_NULLFUNC_ACKED flag on disabling power
save. Without this fix, there is a chance of setting CONF_PS
before sending nullfunc frame.
Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com>
Initialize caldata to avoid compilation warning.
CC [M] drivers/net/wireless/ath/ath9k/htc_drv_main.o
drivers/net/wireless/ath/ath9k/htc_drv_main.c: In function ‘ath9k_htc_config’:
drivers/net/wireless/ath/ath9k/htc_drv_main.c:172: warning: ‘caldata’ may be used uninitialized in this function
drivers/net/wireless/ath/ath9k/htc_drv_main.c:172: note: ‘caldata’ was declared here
"def_bool n" without prompt is pointless, this should be just "bool".
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
It was incorrectly introduced in d2730b2a6a019d14455556019d744ab051e6554b. We
have already fixed function to use correct define, but forgot remove old one.
Cc: Gábor Stefanik <netrolller.3d@gmail.com>
The module parameter ieee80211_disable_40mhz_24ghz
was meant to allow disabling 40 MHz operation in
the 2.4 GHz band by default. However, it is buggy
as implemented because while it advertises to the
AP that the device doesn't support 40 MHz, it will
itself still use 40 MHz configurations.
To fix this, clear the 40 MHz bits from the sband
completely instead of overriding where used.
Commit 59eb21a65047 "cfg80211: Extend channel to frequency mapping for 802.11j"
changed the definition of the ieee80211_channel_to_frequency; so fix its
usage in brcmfmac.
Signed-off-by: Stanislav Fomichev <kernel@fomichev.me>
Reviewed-by: Henry Ptasinski <henryp@broadcom.com>
Signed-off-by: Ben Greear <greearb@candelatech.com>
If any of the p54-based drivers are built with CONFIG_P54_LEDS not
defined, the following warning is generated:
CC [M] drivers/net/wireless/p54/main.o
drivers/net/wireless/p54/main.c: In function ‘p54_register_common’:
drivers/net/wireless/p54/main.c:614:21: warning: unused variable ‘priv’
Johannes pointed out the mess of external function prototypes in the
mac80211-ops.c file. Woe to anyone who changes these functions...
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
ssb_wait_bit was designed for only one-bit bitmasks.
People start using it for multi-bit bitmasks. Make the "set" case
is safe for this. The "unset" case is already safe.
This does not change behavior of the current code.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
Correct channel setting function must be used for AR2317.
When I tested ahb patch on bullet2 all seemed to work fine,
but it couldn't connect another host (using ibss for example).
During an analysis I observed that it's transmitting on another
channel. I looked into madwifi code and understood that
the problem is in channel setting function. So atheros RF2317 not
fully handled in the current ath5k version and must be patched.
Signed-off-by: Nikolay Ledovskikh <nledovskikh@gmail.com>
Acked-by: Bob Copeland <me@bobcopeland.com>
taken two RT35XX EDIMAX from DPO_RT3562_3592_3062_LinuxSTA_V2.4.1.1_20101217
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
Low level driver could pass rx frames to us after disassociate, what
can lead to run conn_mon_timer by ieee80211_sta_rx_notify(). That
is obviously wrong, but nothing happens until we unload modules and
resources are used after free. If kernel debugging is enabled following
warning could be observed:
WARNING: at lib/debugobjects.c:259 debug_print_object+0x65/0x70()
Hardware name: HP xw8600 Workstation
ODEBUG: free active (active state 0) object type: timer_list
Modules linked in: iwlagn(-) iwlcore mac80211 cfg80211 aes_x86_64 aes_generic fuse cpufreq_ondemand acpi_cpufreq freq_table mperf xt_physdev ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 ext3 jbd dm_mirror dm_region_hash dm_log dm_mod uinput hp_wmi sparse_keymap sg wmi arc4 microcode serio_raw ecb tg3 shpchp rfkill ext4 mbcache jbd2 sr_mod cdrom sd_mod crc_t10dif firewire_ohci firewire_core crc_itu_t mptsas mptscsih mptbase scsi_transport_sas ahci libahci pata_acpi ata_generic ata_piix floppy nouveau ttm drm_kms_helper drm i2c_algo_bit i2c_core video [last unloaded: cfg80211]
Pid: 13827, comm: rmmod Tainted: G W 2.6.38-rc4-wl+ #22
Call Trace:
[<ffffffff810649cf>] ? warn_slowpath_common+0x7f/0xc0
[<ffffffff81064ac6>] ? warn_slowpath_fmt+0x46/0x50
[<ffffffff81226fc5>] ? debug_print_object+0x65/0x70
[<ffffffff81227625>] ? debug_check_no_obj_freed+0x125/0x210
[<ffffffff8109ebd7>] ? debug_check_no_locks_freed+0xf7/0x170
[<ffffffff81156092>] ? kfree+0xc2/0x2f0
[<ffffffff813ec5c5>] ? netdev_release+0x45/0x60
[<ffffffff812f1067>] ? device_release+0x27/0xa0
[<ffffffff81216ddd>] ? kobject_release+0x8d/0x1a0
[<ffffffff81216d50>] ? kobject_release+0x0/0x1a0
[<ffffffff812183b7>] ? kref_put+0x37/0x70
[<ffffffff81216c57>] ? kobject_put+0x27/0x60
[<ffffffff813d5d1b>] ? netdev_run_todo+0x1ab/0x270
[<ffffffff813e771e>] ? rtnl_unlock+0xe/0x10
[<ffffffffa0581188>] ? ieee80211_unregister_hw+0x58/0x120 [mac80211]
[<ffffffffa0377ed7>] ? iwl_pci_remove+0xdb/0x22a [iwlagn]
[<ffffffff8123cde2>] ? pci_device_remove+0x52/0x120
[<ffffffff812f5205>] ? __device_release_driver+0x75/0xe0
[<ffffffff812f5348>] ? driver_detach+0xd8/0xe0
[<ffffffff812f4111>] ? bus_remove_driver+0x91/0x100
[<ffffffff812f5b62>] ? driver_unregister+0x62/0xa0
[<ffffffff8123d194>] ? pci_unregister_driver+0x44/0xa0
[<ffffffffa0377df5>] ? iwl_exit+0x15/0x1c [iwlagn]
[<ffffffff810ab492>] ? sys_delete_module+0x1a2/0x270
[<ffffffff81498889>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8100bf42>] ? system_call_fastpath+0x16/0x1b
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
As warned by checkpatch.pl, use #include <linux/uaccess.h> instead of
<asm/uaccess.h>.
If the new connection update parameter are accepted, the LE master
host sends the LE Connection Update Command to its controller informing
the new requested parameters.
Signed-off-by: Claudio Takahasi <claudio.takahasi@openbossa.org>
Use proper timer instead of hci command flow control to timeout
failed hci commands. Otherwise stack ends up sending commands
when flow control is used to block new commands.
2010-09-01 18:29:41.592132 < HCI Command: Remote Name Request (0x01|0x0019) plen 10
bdaddr 00:16:CF:E1:C7:D7 mode 2 clkoffset 0x0000
2010-09-01 18:29:41.592681 > HCI Event: Command Status (0x0f) plen 4
Remote Name Request (0x01|0x0019) status 0x00 ncmd 0
2010-09-01 18:29:51.022033 < HCI Command: Remote Name Request Cancel (0x01|0x001a) plen 6
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Make /sys/class/bluetooth/hciX a symlink to
path under corresponding tty.
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
If the fail happens the HCI del_timer may timeout after the the hci dev
unregister. This lead to a kernel crash.
Reported-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Implements L2CAP Connection Parameter Update Response defined in
the Bluetooth Core Specification, Volume 3, Part A, section 4.21.
Address the LE Connection Parameter Procedure initiated by the slave.
Connection Interval Minimum and Maximum have the same range: 6 to
3200. Time = N * 1.25ms. Minimum shall be less or equal to Maximum.
The Slave Latency field shall have a value in the range of 0 to
((connSupervisionTimeout / connIntervalMax) - 1). Latency field shall
be less than 500. connSupervisionTimeout = Timeout Multiplier * 10 ms.
Multiplier field shall have a value in the range of 10 to 3200.
This patch splits the L2CAP command handling function in order to
have a clear separation between the commands related to BR/EDR and
LE. Commands and responses in the LE signaling channel are not being
handled yet, command reject is sent to all received requests. Bluetooth
Core Specification, Volume 3, Part A, section 4 defines the signaling
packets formats and allowed commands/responses over the LE signaling
channel.
Instead set urb structure directly we call usb_fill_int_urb() to set the
values to us.
Add command structures for security manager protocol.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Separate LE and ACL timeouts. Othervise ACL connections
on non LE hw will time out after 45 secs.
Fix LE connections not being marked as master.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
l2cap over LE links can be disconnected without sending
disconnect command first.
Add support for LE server sockets.
Add basic LE connection support to L2CAP. LE
connection can be created by specifying cid
in struct sockaddr_l2
Bluetooth chips may have separate buffers for LE traffic.
This patch add support to use LE buffers provided by the chip.
Bluetooth V4.0 adds support for Low Energy (LE) connections.
Specification introduces new set of hci commands to control LE
connection. This patch adds logic to create, cancel and disconnect
LE connections.
Add needed HCI command and event structs to
create LE connections.
Add the btusb.c blacklist [0489:e02c] for Atheros AR5BBU12 BT
and add to ath3k.c supported this device.
Signed-off-by: Cho, Yu-Chen <acho@novell.com>
