When we have shared qdiscs, packets come out of the qdiscs
for multiple transmit queues.
Therefore it doesn't make any sense to schedule the transmit
queue when logically we cannot know ahead of time the TX
queue of the SKB that the qdisc->dequeue() will give us.
Just for sanity I added a BUG check to make sure we never
get into a state where the noop_qdisc is scheduled.
When code wants to lock the qdisc tree state, the logic
operation it's doing is locking the top-level qdisc that
sits of the root of the netdev_queue.
Add qdisc_root_lock() to represent this and convert the
easiest cases.
In order for this to work out in all cases, we have to
hook up the noop_qdisc to a dummy netdev_queue.
Currently it is associated with a netdev_queue, but when we have
qdisc sharing that no longer makes any sense.
We liberate any dangling gso_skb during qdisc destruction.
It really only matters for the root qdisc. But when qdiscs
can be shared by multiple netdev_queue objects, we can't
have the gso_skb in the netdev_queue any more.
No more users.
They logically all want to trigger a schedule for all device
TX queues.
It just xor hashes over IPv4/IPv6 addresses and ports of transport.
The only assumption it makes is that skb_network_header() is set
correctly.
With bug fixes from Eric Dumazet.
The only behavior change is that we do not drop packets under any
circumstances. If that is absolutely needed, we could easily add it
back.
With cleanups and help from Johannes Berg.
Devices or device layers can set this to control the queue selection
performed by dev_pick_tx().
This function runs under RCU protection, which allows overriding
functions to have some way of synchronizing with things like dynamic
->real_num_tx_queues adjustments.
This makes the spinlock prefetch in dev_queue_xmit() a little bit
less effective, but that's the price right now for correctness.
The private area of a netdev is now at a fixed offset once more.
Unfortunately, some assumptions that netdev_priv() == netdev->priv
crept back into the tree. In particular this happened in the
loopback driver. Make it use netdev->ml_priv.
No longer used.
This effectively "flips the switch" by making the core networking
and multiqueue-aware drivers use the new TX multiqueue structures.
Non-multiqueue drivers need no changes. The interfaces they use such
as netif_stop_queue() degenerate into an operation on TX queue zero.
So everything "just works" for them.
Code that really wants to do "X" to all TX queues now invokes a
routine that does so, such as netif_tx_wake_all_queues(),
netif_tx_stop_all_queues(), etc.
pktgen and netpoll required a little bit more surgery than the others.
In particular the pktgen changes, whilst functional, could be largely
improved. The initial check in pktgen_xmit() will sometimes check the
wrong queue, which is mostly harmless. The thing to do is probably to
invoke fill_packet() earlier.
The bulk of the netpoll changes is to make the code operate solely on
the TX queue indicated by by the SKB queue mapping.
Setting of the SKB queue mapping is entirely confined inside of
net/core/dev.c:dev_pick_tx(). If we end up needing any kind of
special semantics (drops, for example) it will be implemented here.
Finally, we now have a "real_num_tx_queues" which is where the driver
indicates how many TX queues are actually active.
With IGB changes from Jeff Kirsher.
We will undo this after a few changsets.
This actually fixes a bug added by the RR scheduler changes. The
->bands and ->prio2band parameters were being set outside of the
sch_tree_lock() and thus could result in strange behavior and
inconsistencies.
It might be possible, in the new design (where there will be one qdisc
per device TX queue) to allow similar functionality via a TX hash
algorithm for RR but I really see no reason to export this aspect of
how these multiqueue cards actually implement the scheduling of the
the individual DMA TX rings and the single physical MAC/PHY port.
There is no need for a feature bit for something that
can be tested by simply checking the TX queue count.
alloc_netdev_mq() now allocates an array of netdev_queue
structures for TX, based upon the queue_count argument.
Furthermore, all accesses to the TX queues are now vectored
through the netdev_get_tx_queue() and netdev_for_each_tx_queue()
interfaces. This makes it easy to grep the tree for all
things that want to get to a TX queue of a net device.
Problem spots which are not really multiqueue aware yet, and
only work with one queue, can easily be spotted by grepping
for all netdev_get_tx_queue() calls that pass in a zero index.
Increase reliability by retrying to send JoinIn messages after memory
allocation failures on each TRANSMIT_PDU event until it succeeds.
in __neigh_event_send, if we have a neighbour entry which is in
NUD_INCOMPLETE state, we enqueue any outbound frames to that neighbour
to the neighbours arp_queue, which is default capped to a length of 3
skbs. If that queue exceeds its set length, it will drop an skb on
the queue to enqueue the newly arrived skb. This results in a drop
for which we have no statistics incremented. This patch adds an
unresolved_discards stat to /proc/net/stat/ndisc_cache to track these
lost frames.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Done with NET_XXX_STATS macros :)
To be continued...
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This one is tricky.
The thing is that this macro is only used when killing tw buckets,
but since this killer is promiscuous wrt to which net each particular
tw belongs to, I have to use it only when NET_NS is off. When the net
namespaces are on, I use the INET_INC_STATS_BH for each bucket.
These places have a tcp_sock, but we'd prefer the sock itself to
get net from it. Fortunately, tcp_sk macro is just a type cast, so
this replace is really cheap.
The tcp_enter_memory_pressure calls NET_INC_STATS, but doesn't
have where to get the net from.
I decided to add a sk argument, not the net itself, only to factor
all the required sock_net(sk) calls inside the enter_memory_pressure
callback itself.
Now we're done with the TCP_XXX_STATS macros.
Same as before - the sock is always there to get the net from,
but there are also some places with the net already saved on
the stack.
Fortunately (almost) all the TCP code has a sock to get the net from :)
This one sets TCP MIBs after zeroing them, and thus requires
the net.
The existing single caller can use init_net (temporarily).
TCP_INC_STATS_USER and TCP_ADD_STATS_BH are currently unused.
This is the same as the first patch in the set, but preparing
the net for TCP_XXX_STATS - save the struct net on the stack
where required and possible.
Very simple - only ip_evictor (fragments) requires such.
This patch ends up the IP_XXX_STATS patching.
All the callers already have either the net itself, or the place
where to get it from.
Some places, that deal with IP statistics already have where to
get a struct net from, but use it directly, without declaring
a separate variable on the stack.
So, save this net on the stack for future IP_XXX_STATS macros.
Currently VLAN filtering is enabled when the first VLAN is added.
Obviously before that there's no point in receiving any VLAN packets.
Now that we disable VLAN filtering in promiscous mode, we can keep
the VLAN filters enabled the remaining time.
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
As discussed in this thread:
http://www.mail-archive.com/netdev@vger.kernel.org/msg53976.html
promiscous mode means to disable *all* filters. Currently only unicast
and multicast filtering is disabled. This patch changes all Intel
drivers to also disable VLAN filtering.
Change PULLHUP to POLLHUP in tcp_poll comments and clean up another
comment for grammar and coding style.
Signed-off-by: Will Newton <will.newton@gmail.com>
net/core/skbuff.c:1335:5: warning: symbol '__skb_splice_bits' was not declared. Should it be static?
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
git://git.stealer.net/linux-2.6
This patch enhances the synchronization of the closing connections
between the master and the backup director. It prevents the closed
connections to expire with the 15 min timeout of the ESTABLISHED
state on the backup and makes them expire as they would do on the
master with much shorter timeouts.
Signed-off-by: Rumen G. Bogdanovski <rumen@voicecho.com>
Acked-by: Simon Horman <horms@verge.net.au>
So that kthread_stop() can wake up the thread and we don't have to wait one
second in the worst case for the daemon to actually stop.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Instead of doing an endless loop with sleeping for one second, we now put the
backup thread onto the mcast socket wait queue and it gets woken up as soon as
we have data to process.
This also moves the setup code out of the daemons, so that we're able to
return proper error codes to user space. The current code will return success
to user space when the daemon is started with an invald mcast interface. With
these changes we get an appropriate "No such device" error.
We longer need our own completion to be sure the daemons are actually running,
because they no longer contain code that can fail and kthread_run() takes care
of the rest.
make_send_sock()
The additional information we now return to the caller is currently not used,
but will be used to return errors to user space.
