Get rid of the mdesc pointer in the fixup function call. No one uses
the mdesc pointer, it shouldn't be modified anyway, and we can't wrap
it, so let's remove it.
Platform files found by:
$ regexp=$(git grep -h '\.fixup.*=' arch/arm |
sed 's!.*= *\([^,]*\),* *!\1!' | sort -u |
tr '\n' '|' | sed 's,|$,,;s,|,\\|,g')
$ git grep $regexp arch/arm
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
ARM uses its own BUG() handler which makes its output slightly different
from other archtectures.
One of the problems is that the ARM implementation doesn't report the function
with the BUG() in it, but always reports the PC being in __bug(). The generic
implementation doesn't have this problem.
Currently we get something like:
kernel BUG at fs/proc/breakme.c:35!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
PC is at __bug+0x20/0x2c
With this patch it displays:
Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP
PC is at write_breakme+0xd0/0x1b4
This implementation uses an undefined instruction to implement BUG, and sets up
a bug table containing the relevant information. Many versions of gcc do not
support %c properly for ARM (inserting a # when they shouldn't) so we work
around this using distasteful macro magic.
v1: Initial version to replace existing ARM BUG() implementation with something
more similar to other architectures.
v2: Add Thumb support, remove backtrace whitespace output changes. Change to
use macros instead of requiring the asm %d flag to work (thanks to
Dave Martin <dave.martin@linaro.org>)
v3: Remove old BUG() implementation in favor of this one.
Remove the Backtrace: message (will submit this separately).
Use ARM_EXIT_KEEP() so that some architectures can dump exit text at link time
thanks to Stephen Boyd <sboyd@codeaurora.org> (although since we always
define GENERIC_BUG this might be academic.)
Rebase to linux-2.6.git master.
v4: Allow BUGS in modules (these were not reported correctly in v3)
(thanks to Stephen Boyd <sboyd@codeaurora.org> for suggesting that.)
Remove __bug() as this is no longer needed.
v5: Add %progbits as the section flags.
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Tested-by: Stephen Boyd <sboyd@codeaurora.org>
Update the Integrator defconfig with some sensible defaults:
- Compile a combined image supporting Integrator/AP and
Integrator/CP, with the core modules CM720, CM920, CM922,
CM926, CM1020, CM1022 and CM1026 in a single image, this
works just fine and gives some nice compilation coverage
- NOHZ (tickless) and HRTIMERS turned on
- Compile using EABI, let's assume recent compilers are used
now (tested using GCC 4.4.1)
- Remove forced 32MiB at command line, the bootloader usually
knows this better, and my U-Boot patches nowadays make that
boot loader pass the correct adjusted value
- Enable the MTD Physmap flash driver, so that the changes done
earlier by Marc Zyngier replacing integrator-flash takes
effect
- Enable the PL030 RTC driver that has not been default-compiled
with any config for a while
This has been tested on the real hardware Integrator AP with
both an ARM920T and ARM926EJ-S core module.
Cc: Marc Zyngier <Marc.Zyngier@arm.com>
We already have a clock definition for the 24MHz clock in
the Integrator, use that instead of some unclear defines
from the platform.h header. Also delete the senseless
comment that the file shouldn't be edited, I just edited it
and the world didn't come to an end, so it's obviously
false. If anyone still has the mentioned ".s file" and the
s2h awk script generating that header, raise your hand
(and give me your files).
Drop mult, shift and delta calculations and let the
clockevent core scale this as appropriate.
Set the minimum interval to 1 rather than 15 (0xf), there
is nothing in the data sheets I have indicating that 15
should be some minimum value.
The Integrator AP timer has no problem supporting oneshot
ticks with proper code, so let's do it so we can have
NOHZ configured in for this platform too.
These macros are not used by anything since the switch to
generic time in commit b9cedda230793cbf58eb012ddadedd490cc8e129
so let's retire them.
As per request of rmk, the options should be sorted alphabetically.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Remove the legacy ARM LED code for simpad devices and
register a stadard LED platform device using GPIO line
instead.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
Register keyboard, polled keyboard and I2C platform
devices based on GPIOs.
- prepend CS3 accessors by simpad_ to indicate they
are specific to simpad devices.
- use spinlock to protect shadow register.
- implement 8 read-only pins.
- use readl/writel macros so barriers are used where
necessary.
- register CS3 as GPIO controller with 24 pins
(16 output only and 8 input only).
- fix PCMCIA driver to access the read-only pins
rather than the shadow register for status bits.
Add ucb1x00 GPIO definitions to simpad.h and add gpio_base
to ucb1x00 platform device so the pins are available using
the GPIO API.
Currently, show_regs calls __backtrace which does
nothing if CONFIG_FRAME_POINTER is not set. Switch to
dump_stack which handles both CONFIG_FRAME_POINTER and
CONFIG_ARM_UNWIND correctly.
__backtrace is now superseded by dump_stack in general
and show_regs was the last caller so remove __backtrace
as well.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Current Versatile Express CPU hotplug code includes a hardcoded WFI
instruction, in ARM encoding. When the kernel is compiled in Thumb-2
mode, this is invalid and causes the machine to hang hard when a CPU
is offlined.
Using the wfi macro (which uses the appropriate assembler mnemonic)
causes the correct instruction to be emitted in either case. As a
consequence of this change, an apparently vestigial "cc" clobber is
dropped from the asm (the macro uses "memory" only).
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
Reviewed-by: Jamie Iles <jamie@jamieiles.com>
When v6 and >=v7 boards are supported in the same kernel, the
__und_usr code currently makes a build-time assumption that Thumb-2
instructions occurring in userspace don't need to be supported.
Strictly speaking this is incorrect.
This patch fixes the above case by doing a run-time check on the
CPU architecture in these cases. This only affects kernels which
support v6 and >=v7 CPUs together: plain v6 and plain v7 kernels
are unaffected.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
Reviewed-by: Jon Medhurst <tixy@yxit.co.uk>
instructions
When testing whether a Thumb-2 instruction is 32 bits long or not,
the masking done in order to test bits 11-15 of the first
instruction halfword won't affect the result of the comparison, so
remove it.
The CPU architecture really should not be changing at runtime, so
make it a global variable instead of a function.
The cpu_architecture() function declared in <asm/system.h> remains
the correct way to read this variable from C code.
Boards used to specify zreladdr in their Makefile.boot with
zreladdr-y := x, so conflicting zreladdrs were silently overwritten.
This patch changes this to zreladdr-y += x, so that we end
up with multiple words in zreladdr in such a case. We can
detect this later and complain if necessary.
uImages need a load address specified. This makes them
incompatible with multiple zreladdrs. Catch this error
before building an uImage so that we do not end up with
broken uImages. The load address can still be specified
with LOADADDR= on the command line.
Without CONFIG_AUTO_ZRELADDR being set the kernel needs a single
zreladdr for building zImages. Bail out if we detect multiple
zreladdrs without CONFIG_AUTO_ZRELADDR.
With d8ecc5c (kbuild: asm-generic support, 2011-04-27) we can
remove a handful of asm-generic wrappers in ARM code. Since the
generic version of sizes.h doesn't contain SZ_48M, we replace
the 4 users of SZ_48M with the equivalent SZ_32M + SZ_16M.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Eric Miao <eric.y.miao@gmail.com>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm:
ARM: 7088/1: entry: fix wrong parameter name used in do_thumb_abort
ARM: 7080/1: l2x0: make sure I&D are not locked down on init
ARM: 7081/1: mach-integrator: fix the clocksource
NET: am79c961: fix race in link status code
ARM: 7067/1: mm: keep significant bits in pfn_valid
Commit be020f8618ca, "ARM: entry: abort-macro: specify registers to be
used for macros", while replacing register numbers with macro parameter
names, mismatched the name used for r1. For me, this resulted in user
space built for EABI with -march=armv4t -mtune=arm920t -mthumb-interwork
-mthumb broken on my OMAP1510 based Amstrad Delta (old ABI and no thumb
still worked for me though).
Fix this by using correct parameter name fsr instead of mismatched psr,
used by callers for another purpose.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Since backlight_types[] isn't modified, let's declare it const. That
was probably the intention of the author of commit bb7ca747f8d6
("backlight: add backlight type"), via which the "const char const *"
construct was introduced. The duplicate const was detected by sparse.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
* 'for-linus' of git://neil.brown.name/md:
md: Fix handling for devices from 2TB to 4TB in 0.90 metadata.
md/raid1,10: Remove use-after-free bug in make_request.
md/raid10: unify handling of write completion.
Avoid dereferencing a 'request_queue' after last close.
0.90 metadata uses an unsigned 32bit number to count the number of
kilobytes used from each device.
This should allow up to 4TB per device.
However we multiply this by 2 (to get sectors) before casting to a
larger type, so sizes above 2TB get truncated.
Also we allow rdev->sectors to be larger than 4TB, so it is possible
for the array to be resized larger than the metadata can handle.
So make sure rdev->sectors never exceeds 4TB when 0.90 metadata is in
used.
Also the sanity check at the end of super_90_load should include level
1 as it used ->size too. (RAID0 and Linear don't use ->size at all).
Reported-by: Pim Zandbergen <P.Zandbergen@macroscoop.nl>
Cc: stable@kernel.org
Signed-off-by: NeilBrown <neilb@suse.de>
A single request to RAID1 or RAID10 might result in multiple
requests if there are known bad blocks that need to be avoided.
To detect if we need to submit another write request we test:
if (sectors_handled < (bio->bi_size >> 9)) {
However this is after we call **_write_done() so the 'bio' no longer
belongs to us - the writes could have completed and the bio freed.
So move the **_write_done call until after the test against
bio->bi_size.
This addresses https://bugzilla.kernel.org/show_bug.cgi?id=41862
Reported-by: Bruno Wolff III <bruno@wolff.to>
Tested-by: Bruno Wolff III <bruno@wolff.to>
A write can complete at two different places:
1/ when the last member-device write completes, through
raid10_end_write_request
2/ in make_request() when we remove the initial bias from ->remaining.
These two should do exactly the same thing and the comment says they
do, but they don't.
So factor the correct code out into a function and call it in both
places. This makes the code much more similar to RAID1.
The difference is only significant if there is an error, and they
usually take a while, so it is unlikely that there will be an error
already when make_request is completing, so this is unlikely to cause
real problems.
On the last close of an 'md' device which as been stopped, the device
is destroyed and in particular the request_queue is freed. The free
is done in a separate thread so it might happen a short time later.
__blkdev_put calls bdev_inode_switch_bdi *after* ->release has been
called.
Since commit f758eeabeb96f878c860e8f110f94ec8820822a9
bdev_inode_switch_bdi will dereference the 'old' bdi, which lives
inside a request_queue, to get a spin lock. This causes the last
close on an md device to sometime take a spin_lock which lives in
freed memory - which results in an oops.
So move the called to bdev_inode_switch_bdi before the call to
->release.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Modifying the Maximum Read Request Size to 0 (value of 128Bytes) has
massive negative ramifications on some devices. Without knowing which
devices have this issue, do not modify from the default value when
walking the PCI-E bus in pcie_bus_safe mode. Also, make pcie_bus_safe
the default procedure.
Tested-by: Sven Schnelle <svens@stackframe.org>
Tested-by: Simon Kirby <sim@hostway.ca>
Tested-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Reported-and-tested-by: Niels Ole Salscheider <niels_ole@salscheider-online.de>
References: https://bugzilla.kernel.org/show_bug.cgi?id=42162
Signed-off-by: Jon Mason <mason@myri.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Commit b03e7495a862 ("PCI: Set PCI-E Max Payload Size on fabric")
introduced a potential NULL pointer dereference in calls to
pcie_bus_configure_settings due to attempts to access pci_bus self
variables when the self pointer is NULL.
To correct this, verify that the self pointer in pci_bus is non-NULL
before dereferencing it.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Shyam Iyer <shyam_iyer@dell.com>
* 'for-linus' of git://dev.laptop.org/users/cjb/mmc:
mmc: sdhci-s3c: Fix mmc card I/O problem
mmc: sd: UHS-I bus speed should be set last in UHS initialization
mmc: sdhi: initialise mmc_data->flags before use
mmc: core: use non-reentrant workqueue for clock gating
mmc: core: prevent aggressive clock gating racing with ios updates
mmc: rename mmc_host_clk_{ungate|gate} to mmc_host_clk_{hold|release}
mmc: sdhci-esdhc-imx: add missing inclusion of linux/module.h
* 'for-linus' of git://ceph.newdream.net/git/ceph-client:
libceph: fix leak of osd structs during shutdown
ceph: fix memory leak
ceph: fix encoding of ino only (not relative) paths
libceph: fix msgpool
Prior to 2.6.38 automount would not trigger on either stat(2) or
lstat(2) on the automount point.
After 2.6.38, with the introduction of the ->d_automount()
infrastructure, stat(2) and others would start triggering automount
while lstat(2), etc. still would not. This is a regression and a
userspace ABI change.
Problem originally reported here:
http://thread.gmane.org/gmane.linux.kernel.autofs/6098
It appears that there was an attempt at fixing various userspace tools
to not trigger the automount. But since the stat system call is
rather common it is impossible to "fix" all userspace.
This patch reverts the original behavior, which is to not trigger on
stat(2) and other symlink following syscalls.
[ It's not really clear what the right behavior is. Apparently Solaris
does the "automount on stat, leave alone on lstat". And some programs
can get unhappy when "stat+open+fstat" ends up giving a different
result from the fstat than from the initial stat.
But the change in 2.6.38 resulted in problems for some people, so
we're going back to old behavior. Maybe we can re-visit this
discussion at some future date - Linus ]
Reported-by: Leonardo Chiquitto <leonardo.lists@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Ian Kent <raven@themaw.net>
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine/ste_dma40: fix memory leak due to prepared descriptors
dmaengine/ste_dma40: fix Oops due to double free of client descriptor
dmaengine/ste_dma40: remove duplicate call to d40_pool_lli_free().
dmaengine/ste_dma40: add missing kernel doc for pending_queue
* 'for-linus' of git://opensource.wolfsonmicro.com/regmap:
regmap: Remove bitrotted module_put()s
* 'for-linus' of git://twin.jikos.cz/jikos/hid:
HID: wacom: Unregister sysfs attributes on remove
HID: wacom: Fix error path of power-supply initialization
HID: add support for HuiJia USB Gamepad connector
HID: magicmouse: ignore 'ivalid report id' while switching modes, v2
HID: magicmouse: Set resolution of touch surfaces
* 'for-31-rc5/i2c-fixes' of git://git.fluff.org/bjdooks/linux:
i2c-tegra: fix possible race condition after tx
i2c-tegra: add I2C_FUNC_SMBUS_EMUL
i2c-tegra: Add of_match_table
i2c-pxa2xx: return proper error code in ce4100_i2c_probe error paths
* 'amd/fixes' of git://git.8bytes.org/scm/iommu:
iommu/amd: Don't take domain->lock recursivly
iommu/amd: Make sure iommu->need_sync contains correct value
Fix kernel-doc warning about internal/private data by marking it
as "private:" so that kernel-doc will ignore it.
Warning(include/linux/regulator/consumer.h:128): No description found for parameter 'ret'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Fix kernel-doc warning in net/cfg80211.h:
Warning(include/net/cfg80211.h:1884): No description found for parameter 'registered'
* 'timers-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
rtc: twl: Fix registration vs. init order
rtc: Initialized rtc_time->tm_isdst
rtc: Fix RTC PIE frequency limit
rtc: rtc-twl: Remove lockdep related local_irq_enable()
rtc: rtc-twl: Switch to using threaded irq
rtc: ep93xx: Fix 'rtc' may be used uninitialized warning
alarmtimers: Avoid possible denial of service with high freq periodic timers
alarmtimers: Memset itimerspec passed into alarm_timer_get
alarmtimers: Avoid possible null pointer traversal
* 'sched-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
sched: Fix a memory leak in __sdt_free()
sched: Move blk_schedule_flush_plug() out of __schedule()
sched: Separate the scheduler entry for preemption
* 'perf-fixes-for-linus' of git://tesla.tglx.de/git/linux-2.6-tip:
x86, perf: Check that current->mm is alive before getting user callchain
perf_event: Fix broken calc_timer_values()
perf events: Fix slow and broken cgroup context switch code
git://git.infradead.org/ubi-2.6
* branch 'linux-next' of git://git.infradead.org/ubifs-2.6:
UBIFS: not build debug messages with CONFIG_UBIFS_FS_DEBUG disabled
* branch 'linux-next' of git://git.infradead.org/ubi-2.6:
UBI: do not link debug messages when debugging is disabled
* 'hwmon-for-linus' of git://github.com/groeck/linux:
hwmon: (ucd9000/ucd9200) Optimize array walk
hwmon: (max16065) Add chip access warning to documentation
hwmon: (max16065) Fix current calculation
* 'for-linus' of git://github.com/ericvh/linux:
fs/9p: Use protocol-defined value for lock/getlock 'type' field.
fs/9p: Always ask new inode in lookup for cache mode disabled
fs/9p: Add OS dependent open flags in 9p protocol
net/9p: Fix kernel crash with msize 512K
fs/9p: Don't update file type when updating file attributes
fs/9p: Add fid before dentry instantiation
* 'stable/bug.fixes' of git://oss.oracle.com/git/kwilk/xen:
xen/smp: Warn user why they keel over - nosmp or noapic and what to use instead.
xen: x86_32: do not enable iterrupts when returning from exception in interrupt context
xen: use maximum reservation to limit amount of usable RAM
* 'kvm-updates/3.1' of git://github.com/avikivity/kvm:
KVM: Fix instruction size issue in pvclock scaling
