2010-08-04fix comment typo "choosed" -> "chosen"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04hostap:hostap_hw.c Fix typo in commentJustin P. Mattock
The patch below fixes a typo in a comment. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04Fix spelling contorller -> controller in commentsStefan Weil
Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-21Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> FaultTakuya Yoshikawa
The last 't' of 'fault' is missing in the description of FAIL_IO_TIMEOUT. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20fs/Kconfig: Fix typo Userpace -> UserspaceStephen Boyd
Signed-off-by: Stephen Boyd <bebarino@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20Removing dead MACH_U300_BS26Christoph Egger
MACH_U300_BS26 doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20drivers/infiniband: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20fs/ocfs2: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20libfc: use ARRAY_SIZEKulikov Vasiliy
Change sizeof(x) / sizeof(*x) to ARRAY_SIZE(x). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20scsi: bfa: use ARRAY_SIZEKulikov Vasiliy
2010-07-20drm: i915: use ARRAY_SIZEKulikov Vasiliy
2010-07-20drm: drm_edid: use ARRAY_SIZEKulikov Vasiliy
2010-07-20synclink: use ARRAY_SIZEKulikov Vasiliy
Change sizeof(x) / sizeof(*x) to ARRAY_SIZE(x). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-20block: cciss: use ARRAY_SIZEKulikov Vasiliy
Change sizeof(x) / sizeof(*x) to ARRAY_SIZE(x). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-19comment typo fixes: charater => characterThomas Weber
Fix typo in comments. Replace charater with character. Characteristics too. Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-19fix comment typos concerning "challenge"Uwe Kleine-König
2010-07-19arm: plat-spear: fix typo in kerneldocDavidlohr Bueso
Trivial fix in a typo (enalbed for enabled). Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-19reiserfs: typo comment fixDavidlohr Bueso
Fix trivial typo in code comment (change adn for and), also change comment style for proper coding style. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-19update email addressPavel Machek
pavel@suse.cz no longer works, replace it with working address. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-15Kconfig: fixo typo in "Xilinx'"Michael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-12fix comnment/printk typos concerning "empty"Uwe Kleine-König
2010-07-11trivial: no changes to ov511 driverJiri Kosina
This is a partial revert of 421f91d21ad6f799dc7b489bb33cc560ccc56f98 ("fix typos concerning "initiali[zs]e"") for ov511 driver, as it is going to be completely removed in the next release anyway. Fixes conflict in linux-next. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-11remove a duplicated comment lineUwe Kleine-König
2010-07-11fscache: fix missing kerneldoc annotationSuresh Jayaraman
.. and make kerneldoc scripts happy. Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-11fscache: fix a trivial typo in the commentSuresh Jayaraman
2010-07-11Documentation: pci.txt: fix typoKulikov Vasiliy
Doubled 'not'. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-11lib/devres.c: fix comment typoKulikov Vasiliy
'Unamp' should be 'Unmap'. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-11Documentation update broken web addressesJustin P. Mattock
I've found some web addresses not responding, giving the cannot connect error when trying to load them. The below patch updates the addresses that are not connecting with the best that I can find, and also fixes a couple of addresses, so people can either choose an older version of the package and/or a newer version(i.e. ppp). Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-11fix comment/printk typos concerning "already"Uwe Kleine-König
2010-07-11fix comment typos concerning "sequential"Uwe Kleine-König
2010-07-11fix #warning about using kernel headers in userpsaceJustin P. Mattock
Move the preprocessor #warning message: warning: #warning Attempt to use kernel headers from user space, see http://kernelnewbies.org/KernelHeaders from kernel.h to types.h. And also fixe the #warning message due to the preprocessor not being able to read the web address due to it thinking it was the start of a comment. also remove the extra #ifndef _KERNEL_ since it's already there. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-30Revert "Remove dead CONFIG_SIBYTE_BCM1480_PROF"Jiri Kosina
This reverts commit 22c1d8b4f8f04882046ebe592f9a9eaea443cb45. It has been nacked by MIPS maintainer Ralf Baechle.
2010-06-28Documentation/sysctl/vm.txt typoKulikov Vasiliy
Fix trivial typo: duplicated word. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-28Fix comment spelling errors in ncpfs/inode.cMatthew Whitworth
2010-06-17fix typos concerning "precedence"Uwe Kleine-König
2010-06-17trivial: don't touch drivers/stagingJiri Kosina
This is a partial revert of 421f91d21ad6f ("fix typos concerning "initiali[zs]e"), as we don't want to touch staging drivers from other trees than staging itself. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-16fix typos concerning "associate"Uwe Kleine-König
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "instead"Uwe Kleine-König
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
2010-06-16fix typos concerning "management"Uwe Kleine-König
2010-06-16fix typos concerning "first"Uwe Kleine-König
2010-06-16fix typos concerning "acquire"Uwe Kleine-König
2010-06-16fix typos concerning "hierarchy"Uwe Kleine-König
2010-06-16Remove dead CONFIG_SIBYTE_BCM1480_PROFChristoph Egger
CONFIG_SIBYTE_BCM1480_PROF doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-16arch/cris: Remove unnecessary kmalloc castsJoe Perches
And separate declaration from allocation Still no error checking on failure, but it probably doesn't matter. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-11Linux 2.6.35-rc3v2.6.35-rc3Linus Torvalds
2010-06-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: wimax/i2400m: fix missing endian correction read in fw loader net8139: fix a race at the end of NAPI pktgen: Fix accuracy of inter-packet delay. pkt_sched: gen_estimator: add a new lock net: deliver skbs on inactive slaves to exact matches ipv6: fix ICMP6_MIB_OUTERRORS r8169: fix mdio_read and update mdio_write according to hw specs gianfar: Revive the driver for eTSEC devices (disable timestamping) caif: fix a couple range checks phylib: Add support for the LXT973 phy. net: Print num_rx_queues imbalance warning only when there are allocated queues
2010-06-11Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / x86: Save/restore MISC_ENABLE register
2010-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: The file argument for fsync() is never null Btrfs: handle ERR_PTR from posix_acl_from_xattr() Btrfs: avoid BUG when dropping root and reference in same transaction Btrfs: prohibit a operation of changing acl's mask when noacl mount option used Btrfs: should add a permission check for setfacl Btrfs: btrfs_lookup_dir_item() can return ERR_PTR Btrfs: btrfs_read_fs_root_no_name() returns ERR_PTRs Btrfs: unwind after btrfs_start_transaction() errors Btrfs: btrfs_iget() returns ERR_PTR Btrfs: handle kzalloc() failure in open_ctree() Btrfs: handle error returns from btrfs_lookup_dir_item() Btrfs: Fix BUG_ON for fs converted from extN Btrfs: Fix null dereference in relocation.c Btrfs: fix remap_file_pages error Btrfs: uninitialized data is check_path_shared() Btrfs: fix fallocate regression Btrfs: fix loop device on top of btrfs
