* pm-avs:
MAINTAINERS: update entry for drivers/power/avs
PM / AVS: rockchip-io: add driver handling Rockchip io domains
regulator: core: Add REGULATOR_EVENT_PRE_VOLTAGE_CHANGE (and ABORT)
* pm-cpufreq:
cpufreq: cpufreq-dt: fix potential double put of cpu OF node
cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'
cpufreq: ppc-corenet: remove duplicate update of cpu_data
cpufreq: Replace strnicmp with strncasecmp
cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec
cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum
cpufreq: Allow stop CPU callback to be used by all cpufreq drivers
cpufreq: cpu0: Make allocate_resources() work for any CPU
cpufreq: cpu0: try regulators with name "cpu-supply"
cpufreq: cpu0: Move per-cluster initialization code to ->init()
cpufreq: cpu0: use dev_{err|warn|dbg} instead of pr_{err|warn|debug}
cpufreq: cpu0: print relevant error when we defer probe
cpufreq: cpu0: don't validate clock on clk_put()
cpufreq: cpu0: Update Module Author
cpufreq: Add support for per-policy driver data
* pm-cpuidle:
drivers: cpuidle: initialize big.LITTLE driver through DT
drivers: cpuidle: CPU idle ARM64 driver
drivers: cpuidle: implement DT based idle states infrastructure
cpuidle: big.LITTLE: add Exynos5800 compatible string
cpuidle: Replace strnicmp with strncasecmp
arm64: add PSCI CPU_SUSPEND based cpu_suspend support
arm64: kernel: introduce cpu_init_idle CPU operation
arm64: kernel: refactor the CPU suspend API for retention states
Documentation: arm: define DT idle states bindings
* pm-domains: (32 commits)
PM / Domains: Rename cpu_data to cpuidle_data
PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h
PM / Domains: Remove legacy API for adding devices through DT
PM / Domains: Add genpd attach/detach callbacks
PM / Domains: add debugfs listing of struct generic_pm_domain-s
ACPI / PM: Convert acpi_dev_pm_detach() into a static function
ARM: exynos: Move to generic PM domain DT bindings
amba: Add support for attach/detach of PM domains
spi: core: Convert to dev_pm_domain_attach|detach()
mmc: sdio: Convert to dev_pm_domain_attach|detach()
i2c: core: Convert to dev_pm_domain_attach|detach()
drivercore / platform: Convert to dev_pm_domain_attach|detach()
PM / Domains: Add APIs to attach/detach a PM domain for a device
PM / Domains: Add generic OF-based PM domain look-up
ACPI / PM: Assign the ->detach() callback when attaching the PM domain
PM / Domains: Add a detach callback to the struct dev_pm_domain
PM / domains: Spelling s/domian/domain/
PM / domains: Keep declaration of dev_power_governors together
PM / domains: Remove default_stop_ok() API
drivers: sh: Leave disabling of unused PM domains to genpd
* acpi-pm:
ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle
PM / sleep: Rename platform suspend/resume functions in suspend.c
PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq()
* pm-sleep:
PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free()
PM / sleep: new suspend_resume trace event for console resume
PM / sleep: Update test_suspend option documentation
PM / sleep: Enhance test_suspend option with repeat capability
PM / sleep: Support freeze as test_suspend option
PM / sysfs: avoid shadowing variables
* pm-genirq:
PM / genirq: Document rules related to system suspend and interrupts
PCI / PM: Make PCIe PME interrupts wake up from suspend-to-idle
x86 / PM: Set IRQCHIP_SKIP_SET_WAKE for IOAPIC IRQ chip objects
genirq: Simplify wakeup mechanism
genirq: Mark wakeup sources as armed on suspend
genirq: Create helper for flow handler entry check
genirq: Distangle edge handler entry
genirq: Avoid double loop on suspend
genirq: Move MASK_ON_SUSPEND handling into suspend_device_irqs()
genirq: Make use of pm misfeature accounting
genirq: Add sanity checks for PM options on shared interrupt lines
genirq: Move suspend/resume logic into irq/pm code
PM / sleep: Mechanism for aborting system suspends unconditionally
* acpi-processor:
ACPI / processor: use container_of instead of casting first structure member
* acpi-battery:
ACPI / battery: Replace strnicmp with strncasecmp
* acpi-utils:
ACPI / utils: Update acpi_check_dsm() comments
* acpi-fan:
ACPI / fan: printk replacement
printk replaced with corresponding dev_err and dev_info
fixed one broken user-visible string
multiine comment edited for correct commenting style
asm/uaccess.h replaced with linux/uaccess.h
PREFIX removed
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
* acpi-pnp:
ACPI / PNP: remove Fujitsu device IDs from ACPI PNP ID list
* acpi-blacklist:
ACPI / blacklist: add Win8 OSI quirks for some Dell laptop models
* acpi-lpss:
ACPI / LPSS: not using UART RTS override with Auto Flow Control
ACPI / LPSS: remove struct lpss_shared_clock
ACPI / LPSS: support for 133MHz I2C source clock on Baytrail
ACPI / LPSS: drop clkdev_name member from lpss_device_desc
ACPI / LPSS: introduce flags
* acpi-video:
ACPI / video: check _DOD list when creating backlight devices
ACPI / video: force vendor backlight on Lenovo Ideapad Z570
ACPI / video: Remove video_set_use_native_backlight quirk
* acpi-apple:
ACPI / SBS: Fix check in acpi_ac_get_present()
ACPI: Support _OSI("Darwin") correctly
ACPI / SBS: Disable smart battery manager on Apple
ACPI / SBS: Don't assume the existence of an SBS charger
* acpica:
ACPICA: Introduce acpi_enable_all_wakeup_gpes()
ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block()
ACPICA: Update version to 20140828.
ACPICA: Disassembler: Fix for gpio_int interrupt polarity flags.
ACPICA: Headers: Add GTDT flag definitions for the timer subtable.
ACPICA: ACPI 5.1/Disassembler: Add GICC affinity subtable to SRAT table.
ACPICA: Add _PSx names to the METHOD_NAME list.
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of two small fixes, both to code which went in during
the merge window: cxgb4i has a scheduling in atomic bug in its new
ipv6 code and uas fails to work properly with the new scsi-mq code"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
[SCSI] uas: disable use of blk-mq I/O path
[SCSI] cxgb4i: avoid holding mutex in interrupt context
https://git.kernel.org/pub/scm/linux/kernel/git/josh/linux
Pull kconfig fixes for tiny setups from Josh Triplett:
"Two Kconfig bugfixes for 3.17 related to tinification. These fixes
make the Kconfig "General Setup" menu much more usable"
* tag 'tiny/kconfig-for-3.17' of https://git.kernel.org/pub/scm/linux/kernel/git/josh/linux:
init/Kconfig: Fix HAVE_FUTEX_CMPXCHG to not break up the EXPERT menu
init/Kconfig: Hide printk log config if CONFIG_PRINTK=n
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 ("futex: Allow
architectures to skip futex_atomic_cmpxchg_inatomic() test") added the
HAVE_FUTEX_CMPXCHG symbol right below FUTEX. This placed it right in
the middle of the options for the EXPERT menu. However,
HAVE_FUTEX_CMPXCHG does not depend on EXPERT or FUTEX, so Kconfig stops
placing items in the EXPERT menu, and displays the remaining several
EXPERT items (starting with EPOLL) directly in the General Setup menu.
Since both users of HAVE_FUTEX_CMPXCHG only select it "if FUTEX", make
HAVE_FUTEX_CMPXCHG itself depend on FUTEX. With this change, the
subsequent items display as part of the EXPERT menu again; the EMBEDDED
menu now appears as the next top-level item in the General Setup menu,
which makes General Setup much shorter and more usable.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Cc: stable <stable@vger.kernel.org>
The buffers sized by CONFIG_LOG_BUF_SHIFT and
CONFIG_LOG_CPU_MAX_BUF_SHIFT do not exist if CONFIG_PRINTK=n, so don't
ask about their size at all.
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Two i2c driver bugfixes"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: qup: Fix order of runtime pm initialization
i2c: rk3x: fix 0 length write transfers
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull trace ring buffer iterator fix from Steven Rostedt:
"While testing some new changes for 3.18, I kept hitting a bug every so
often in the ring buffer. At first I thought it had to do with some
of the changes I was working on, but then testing something else I
realized that the bug was in 3.17 itself. I ran several bisects as
the bug was not very reproducible, and finally came up with the commit
that I could reproduce easily within a few minutes, and without the
change I could run the tests over an hour without issue. The change
fit the bug and I figured out a fix. That bad commit was:
Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page"
This commit fixed a bug, but in the process created another one. It
used the wrong value as the cached value that is used to see if things
changed while an iterator was in use. This made it look like a change
always happened, and could cause the iterator to go into an infinite
loop"
* tag 'trace-fixes-v3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer: Fix infinite spin in reading buffer
Pull cifs/smb3 fixes from Steve French:
"Fix for CIFS/SMB3 oops on reconnect during readpages (3.17 regression)
and for incorrectly closing file handle in symlink error cases"
* 'for-linus' of git://git.samba.org/sfrench/cifs-2.6:
CIFS: Fix readpages retrying on reconnects
Fix problem recognizing symlinks
Pull raid5 discard fix from Neil Brown:
"One fix for raid5 discard issue"
* tag 'md/3.17-final-fix' of git://neil.brown.name/md:
md/raid5: disable 'DISCARD' by default due to safety concerns.
Pull drm fixes from Dave Airlie:
"Nothing too major or scary.
One i915 regression fix, nouveau has a tmds regression fix, along with
a regression fix for the runtime pm code for optimus laptops not
restoring the display hw correctly"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau: make sure display hardware is reinitialised on runtime resume
drm/nouveau: punt fbcon resume out to a workqueue
drm/nouveau: fix regression on original nv50 board
drm/nv50/disp: fix dpms regression on certain boards
drm/i915: Flush the PTEs after updating them before suspend
The "cpu_data" are defined for some archs and thus conflicting with the
"cpu_data" member in the struct gpd_cpu_data. This causes a compiler
error for those archs.
Let's fix it by rename the member to cpuidle_data. In this context it
also seems appropriate to rename the struct to gpd_cpuidle_data to
better reflect its use.
Fixes: f48c767ce895 (PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h)
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Pavel Machek <pavel@ucw.cz>
If cpufreq_generic_init() fails we jump into the resource
cleanup path which contains a of_node_put() call. Another
instance of this has already been called at that time
resulting a double decrement of the refcount.
Fix this by calling of_node_put() only after we are sure
that nothing has gone wrong.
Fixes: d2f31f1da54f "cpufreq: cpu0: Move per-cluster initialization code to ->init()"
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
The naming convention of this driver was always under the scanner, people
complained that it should have a more generic name than cpu0, as it manages all
CPUs that are sharing clock lines.
Also, in future it will be modified to support any number of clusters with
separate clock/voltage lines.
Lets rename it to 'cpufreq_dt' from 'cpufreq_cpu0'.
Tested-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
The uas driver uses the block layer tag for USB3 stream IDs. With
blk-mq we can get larger tag numbers that the queue depth, which breaks
this assumption. A fix is under way for 3.18, but sits on top of
large changes so can't easily be backported. Set the disable_blk_mq
path so that a uas device can't easily crash the system when using
blk-mq for SCSI.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Pull ACPI and power management fixes from Rafael Wysocki:
"These are three regression fixes (cpufreq core, pcc-cpufreq, i915 /
ACPI) and one trivial fix for a callback return value mismatch in the
cpufreq integrator driver.
Specifics:
- A recent cpufreq core fix went too far and introduced a regression
in the system suspend code path. Fix from Viresh Kumar.
- An ACPI-related commit in the i915 driver that fixed backlight
problems for some Thinkpads inadvertently broke a Dell machine (in
3.16). Fix from Aaron Lu.
- The pcc-cpufreq driver was broken during the 3.15 cycle by a commit
that put wait_event() under a spinlock by mistake. Fix that
(Rafael J Wysocki).
- The return value type of integrator_cpufreq_remove() is void, but
should be int. Fix from Arnd Bergmann"
* tag 'pm+acpi-3.17-final' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: update 'cpufreq_suspended' after stopping governors
ACPI / i915: Update the condition to ignore firmware backlight change request
cpufreq: integrator: fix integrator_cpufreq_remove return type
cpufreq: pcc-cpufreq: Fix wait_event() under spinlock
git://anongit.freedesktop.org/drm-intel into drm-fixes
final regression fix for 3.17.
* tag 'drm-intel-fixes-2014-10-02' of git://anongit.freedesktop.org/drm-intel:
The runtime pm calls need to be done before populating the children via the
i2c_add_adapter call. If this is not done, a child can run into issues trying
to do i2c read/writes due to the pm_runtime_sync failing.
Signed-off-by: Andy Gross <agross@codeaurora.org>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
i2cdetect -q was broken (everything was a false positive, and no transfers were
actually being sent over i2c). The way it works is by sending a 0 length write
request and checking for NACK. This patch fixes the 0 length writes and actually
sends them.
Reported-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Alexandru M Stan <amstan@chromium.org>
Tested-by: Doug Anderson <dianders@chromium.org>
Tested-by: Max Schwarz <max.schwarz@online.de>
* pm-cpufreq:
* acpi-video:
Merge fixes from Andrew Morton:
"5 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: page_alloc: fix zone allocation fairness on UP
perf: fix perf bug in fork()
MAINTAINERS: change git URL for mpc5xxx tree
mm: memcontrol: do not iterate uninitialized memcgs
ocfs2/dlm: should put mle when goto kill in dlm_assert_master_handler
The zone allocation batches can easily underflow due to higher-order
allocations or spills to remote nodes. On SMP that's fine, because
underflows are expected from concurrency and dealt with by returning 0.
But on UP, zone_page_state will just return a wrapped unsigned long,
which will get past the <= 0 check and then consider the zone eligible
until its watermarks are hit.
Commit 3a025760fc15 ("mm: page_alloc: spill to remote nodes before
waking kswapd") already made the counter-resetting use
atomic_long_read() to accomodate underflows from remote spills, but it
didn't go all the way with it.
Make it clear that these batches are expected to go negative regardless
of concurrency, and use atomic_long_read() everywhere.
Fixes: 81c0a2bb515f ("mm: page_alloc: fair zone allocator policy")
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Leon Romanovsky <leon@leon.nu>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: <stable@vger.kernel.org> [3.12+]
Oleg noticed that a cleanup by Sylvain actually uncovered a bug; by
calling perf_event_free_task() when failing sched_fork() we will not yet
have done the memset() on ->perf_event_ctxp[] and will therefore try and
'free' the inherited contexts, which are still in use by the parent
process. This is bad..
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Sylvain 'ythier' Hitier <sylvain.hitier@gmail.com>
The repository for mpc5xxx has been moved, update git URL to new
location.
The cgroup iterators yield css objects that have not yet gone through
css_online(), but they are not complete memcgs at this point and so the
memcg iterators should not return them. Commit d8ad30559715 ("mm/memcg:
iteration skip memcgs not yet fully initialized") set out to implement
exactly this, but it uses CSS_ONLINE, a cgroup-internal flag that does
not meet the ordering requirements for memcg, and so the iterator may
skip over initialized groups, or return partially initialized memcgs.
The cgroup core can not reasonably provide a clear answer on whether the
object around the css has been fully initialized, as that depends on
controller-specific locking and lifetime rules. Thus, introduce a
memcg-specific flag that is set after the memcg has been initialized in
css_online(), and read before mem_cgroup_iter() callers access the memcg
members.
Cc: Tejun Heo <tj@kernel.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
In dlm_assert_master_handler, the mle is get in dlm_find_mle, should be
put when goto kill, otherwise, this mle will never be released.
Signed-off-by: Alex Chen <alex.chen@huawei.com>
Reviewed-by: Joseph Qi <joseph.qi@huawei.com>
Reviewed-by: joyce.xue <xuejiufei@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fix from Mauro Carvalho Chehab:
"One last time regression fix at em28xx. The removal of .reset_resume
broke suspend/resume on this driver for some devices.
There are more fixes to be done for em28xx suspend/resume to be better
handled, but I'm opting to let them to stay for a while at the media
devel tree, in order to get more tests. So, for now, let's just
revert this patch"
* tag 'media/v3.17-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
Revert "[media] media: em28xx - remove reset_resume interface"
fixed one bug but in the process caused another one. The reset is to
update the header page, but that fix also changed the way the cached
reads were updated. The cache reads are used to test if an iterator
needs to be updated or not.
A ring buffer iterator, when created, disables writes to the ring buffer
but does not stop other readers or consuming reads from happening.
Although all readers are synchronized via a lock, they are only
synchronized when in the ring buffer functions. Those functions may
be called by any number of readers. The iterator continues down when
its not interrupted by a consuming reader. If a consuming read
occurs, the iterator starts from the beginning of the buffer.
The way the iterator sees that a consuming read has happened since
its last read is by checking the reader "cache". The cache holds the
last counts of the read and the reader page itself.
Commit 651e22f2701b changed what was saved by the cache_read when
the rb_iter_reset() occurred, making the iterator never match the cache.
Then if the iterator calls rb_iter_reset(), it will go into an
infinite loop by checking if the cache doesn't match, doing the reset
and retrying, just to see that the cache still doesn't match! Which
should never happen as the reset is suppose to set the cache to the
current value and there's locks that keep a consuming reader from
having access to the data.
Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page"
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fix from Helge Deller:
"One late but trivial patch to fix the serial console on parisc
machines which got broken during the 3.17 release cycle"
* 'parisc-3.17-8' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Fix serial console for machines with serial port on superio chip
If we got a reconnect error from async readv we re-add pages back
to page_list and continue loop. That is wrong because these pages
have been already added to the pagecache but page_list has pages that
have not been added to the pagecache yet. This ends up with a general
protection fault in put_pages after readpages. Fix it by not retrying
the read of these pages and falling back to readpage instead.
Fixes debian bug 762306
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
Signed-off-by: Steve French <smfrench@gmail.com>
Tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
Changeset eb85d94bd introduced a problem where if a cifs open
fails during query info of a file we
will still try to close the file (happens with certain types
of reparse points) even though the file handle is not valid.
In addition for SMB2/SMB3 we were not mapping the return code returned
by Windows when trying to open a file (like a Windows NFS symlink)
which is a reparse point.
Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org>
CC: stable <stable@vger.kernel.org> #v3.13+
Merge NUMA balancing related fixlets from Mel Gorman:
"There were a few minor changes so am resending just the two patches
that are mostly likely to affect the bug Dave and Sasha saw and marked
them for stable.
I'm less confident it will address Sasha's problem because while I
have not kept up to date, I believe he's also seeing memory corruption
issues in next from an unknown source. Still, it would be nice to see
how they affect trinity testing.
I'll send the MPOL_MF_LAZY patch separately because it's not urgent"
* emailed patches from Mel Gorman <mgorman@suse.de>:
mm: numa: Do not mark PTEs pte_numa when splitting huge pages
mm: migrate: Close race between migration completion and mprotect
This patch reverts 1ba6e0b50b ("mm: numa: split_huge_page: transfer the
NUMA type from the pmd to the pte"). If a huge page is being split due
a protection change and the tail will be in a PROT_NONE vma then NUMA
hinting PTEs are temporarily created in the protected VMA.
VM_RW|VM_PROTNONE
split here
In the specific case above, it should get fixed up by change_pte_range()
but there is a window of opportunity for weirdness to happen. Similarly,
if a huge page is shrunk and split during a protection update but before
pmd_numa is cleared then a pte_numa can be left behind.
Instead of adding complexity trying to deal with the case, this patch
will not mark PTEs NUMA when splitting a huge page. NUMA hinting faults
will not be triggered which is marginal in comparison to the complexity
in dealing with the corner cases during THP split.
Cc: stable@vger.kernel.org
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
A migration entry is marked as write if pte_write was true at the time the
entry was created. The VMA protections are not double checked when migration
entries are being removed as mprotect marks write-migration-entries as
read. It means that potentially we take a spurious fault to mark PTEs write
again but it's straight-forward. However, there is a race between write
migrations being marked read and migrations finishing. This potentially
allows a PTE to be write that should have been read. Close this race by
double checking the VMA permissions using maybe_mkwrite when migration
completes.
[torvalds@linux-foundation.org: use maybe_mkwrite]
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Just a few pending bits of random fixes in ASoC. Nothing exciting,
but would be nice to be merged in 3.17, as most of them are also for
stable kernels"
* tag 'sound-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: ssm2602: do not hardcode type to SSM2602
ASoC: core: fix possible ZERO_SIZE_PTR pointer dereferencing error.
MAINTAINERS: add atmel audio alsa driver maintainer entry
ASoC: rt286: Fix sync function
ASoC: rt286: Correct default value
ASoC: soc-compress: fix double unlock of fe card mutex
ASoC: fsl_ssi: fix kernel panic in probe function
