No need to hold the bkl to seek here, none of the other
fops callbacks use it.
Use generic_file_llseek explicitly.
Cc: John Kacur <jkacur@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
/proc/kcore has no llseek and then falls down to use default_llseek.
This is racy against read_kcore() that directly manipulates fpos
but it doesn't hold the bkl there so using it in llseek doesn't
protect anything.
Let's use generic_file_llseek() instead.
We don't use the BKL elsewhere, so use generic_file_llseek
so we can avoid default_llseek taking the BKL.
[restore proc_fdinfo_file_operations as non-seekable]
Add a MAINTAINERS record for the key management facility.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
CRED: Fix memory leak in error handling
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs:
[LogFS] Erase new journal segments
[LogFS] Move reserved segments with journal
[LogFS] Clear PagePrivate when moving journal
Simplify and fix pad_wbuf
Prevent data corruption in logfs_rewrite_block()
Use deactivate_locked_super
Fix logfs_get_sb_final error path
Write out both superblocks on mismatch
Prevent schedule while atomic in __logfs_readdir
Plug memory leak in writeseg_end_io
Limit max_pages for insane devices
Open segment file before using it
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Do not free zero sized per cpu areas
x86: Make sure free_init_pages() frees pages on page boundary
x86: Make smp_locks end with page alignment
Fix a memory leak on an OOM condition in prepare_usermodehelper_creds().
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2: Fix a race in o2dlm lockres mastery
Ocfs2: Handle deletion of reflinked oprhan inodes correctly.
Ocfs2: Journaling i_flags and i_orphaned_slot when adding inode to orphan dir.
ocfs2: Clear undo bits when local alloc is freed
ocfs2: Init meta_ac properly in ocfs2_create_empty_xattr_block.
ocfs2: Fix the update of name_offset when removing xattrs
ocfs2: Always try for maximum bits with new local alloc windows
ocfs2: set i_mode on disk during acl operations
ocfs2: Update i_blocks in reflink operations.
ocfs2: Change bg_chain check for ocfs2_validate_gd_parent.
[PATCH] Skip check for mandatory locks when unlocking
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (28 commits)
ceph: update discussion list address in MAINTAINERS
ceph: some documentations fixes
ceph: fix use after free on mds __unregister_request
ceph: avoid loaded term 'OSD' in documention
ceph: fix possible double-free of mds request reference
ceph: fix session check on mds reply
ceph: handle kmalloc() failure
ceph: propagate mds session allocation failures to caller
ceph: make write_begin wait propagate ERESTARTSYS
ceph: fix snap rebuild condition
ceph: avoid reopening osd connections when address hasn't changed
ceph: rename r_sent_stamp r_stamp
ceph: fix connection fault con_work reentrancy problem
ceph: prevent dup stale messages to console for restarting mds
ceph: fix pg pool decoding from incremental osdmap update
ceph: fix mds sync() race with completing requests
ceph: only release unused caps with mds requests
ceph: clean up handle_cap_grant, handle_caps wrt session mutex
ceph: fix session locking in handle_caps, ceph_check_caps
ceph: drop unnecessary WARN_ON in caps migration
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (asc7621) Add X58 entry in Kconfig
hwmon: (w83793) Saving negative errors in unsigned
hwmon: (coretemp) Add missing newline to dev_warn() message
hwmon: (coretemp) Fix cpu model output
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
pata_via: fix VT6410/6415/6330 detection issue
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits)
r8169: offical fix for CVE-2009-4537 (overlength frame DMAs)
ipv6: Don't drop cache route entry unless timer actually expired.
tulip: Add missing parens.
r8169: fix broken register writes
pcnet_cs: add new id
bonding: fix broken multicast with round-robin mode
drivers/net: Fix continuation lines
e1000: do not modify tx_queue_len on link speed change
net: ipmr/ip6mr: prevent out-of-bounds vif_table access
ixgbe: Do not run all Diagnostic offline tests when VFs are active
igb: use correct bits to identify if managability is enabled
benet: Fix compile warnnings in drivers/net/benet/be_ethtool.c
net: Add MSG_WAITFORONE flag to recvmmsg
e1000e: do not modify tx_queue_len on link speed change
igbvf: do not modify tx_queue_len on link speed change
ipv4: Restart rt_intern_hash after emergency rebuild (v2)
ipv4: Cleanup struct net dereference in rt_intern_hash
net: fix netlink address dumping in IPv4/IPv6
tulip: Fix null dereference in uli526x_rx_packet()
gianfar: fix undo of reserve()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc64: Properly truncate pt_regs framepointer in perf callback.
arch/sparc/kernel: Use set_cpus_allowed_ptr
sparc: Fix use of uid16_t and gid16_t in asm/stat.h
In commit 9df93939b735 ("ext3: Use bitops to read/modify
EXT3_I(inode)->i_state") ext3 changed its internal 'i_state' variable to
use bitops for its state handling. However, unline the same ext4
change, it didn't actually change the name of the field when it changed
the semantics of it.
As a result, an old use of 'i_state' remained in fs/ext3/ialloc.c that
initialized the field to EXT3_STATE_NEW. And that does not work
_at_all_ when we're now working with individually named bits rather than
values that get masked. So the code tried to mark the state to be new,
but in actual fact set the field to EXT3_STATE_JDATA. Which makes no
sense at all, and screws up all the code that checks whether the inode
was newly allocated.
In particular, it made the xattr code unhappy, and caused various random
behavior, like apparently
https://bugzilla.redhat.com/show_bug.cgi?id=577911
So fix the initialization, and rename the field to match ext4 so that we
don't have this happen again.
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Daniel J Walsh <dwalsh@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Official patch to fix the r8169 frame length check error.
Based on this initial thread:
http://marc.info/?l=linux-netdev&m=126202972828626&w=1
This is the official patch to fix the frame length problems in the r8169
driver. As noted in the previous thread, while this patch incurs a performance
hit on the driver, its possible to improve performance dynamically by updating
the mtu and rx_copybreak values at runtime to return performance to what it was
for those NICS which are unaffected by the ideosyncracy (if there are any).
Summary:
A while back Eric submitted a patch for r8169 in which the proper
allocated frame size was written to RXMaxSize to prevent the NIC from dmaing too
much data. This was done in commit fdd7b4c3302c93f6833e338903ea77245eb510b4. A
long time prior to that however, Francois posted
126fa4b9ca5d9d7cb7d46f779ad3bd3631ca387c, which expiclitly disabled the MaxSize
setting due to the fact that the hardware behaved in odd ways when overlong
frames were received on NIC's supported by this driver. This was mentioned in a
security conference recently:
http://events.ccc.de/congress/2009/Fahrplan//events/3596.en.html
It seems that if we can't enable frame size filtering, then, as Eric correctly
noticed, we can find ourselves DMA-ing too much data to a buffer, causing
corruption. As a result is seems that we are forced to allocate a frame which
is ready to handle a maximally sized receive.
This obviously has performance issues with it, so to mitigate that issue, this
patch does two things:
1) Raises the copybreak value to the frame allocation size, which should force
appropriately sized packets to get allocated on rx, rather than a full new 16k
buffer.
2) This patch only disables frame filtering initially (i.e., during the NIC
open), changing the MTU results in ring buffer allocation of a size in relation
to the new mtu (along with a warning indicating that this is dangerous).
Because of item (2), individuals who can't cope with the performance hit (or can
otherwise filter frames to prevent the bug), or who have hardware they are sure
is unaffected by this issue, can manually lower the copybreak and reset the mtu
such that performance is restored easily.
Signed-off-by: Neil Horman <nhorman@redhat.com>
For 32-bit processes, we save the full 64-bits of the regs in pt_regs.
But unlike when the userspace actually does load and store
instructions, the top 32-bits don't get automatically truncated by the
cpu in kernel mode (because the kernel doesn't execute with PSTATE_AM
address masking enabled).
So we have to do it by hand.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Intel X58 have asc7621a chip. So added X58 entry in Kconfig for asc7621.
Also arranged existing models in ascending order.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
"ret" is used to store the return value for watchdog_trigger() and it
should be signed for the error handling to work.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Add missing newline to dev_warn() message string. This is more of an issue
with older kernels that don't automatically add a newline if it was missing
from the end of the previous line.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
Cc: stable@kernel.org
Avoid hex and decimal confusion when printing out the cpu model.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
If the device contains on old logfs image and the journal is moved to
segment that have never been used by the current logfs and not all
journal segments are erased before the next mount, the old content can
confuse mount code. To prevent this, always erase the new journal
segments.
Signed-off-by: Joern Engel <joern@logfs.org>
Fixes a GC livelock.
This avoids an infinite loop in free_early_partial().
Add a warning to free_early_partial() to catch future problems.
-v5: put back start > end back into WARN_ONCE()
-v6: use one line for warning, suggested by Linus
-v7: more tests
-v8: remove the function name as suggested by Johannes
WARN_ONCE() will print out that function name.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Tested-by: Joel Becker <joel.becker@oracle.com>
Tested-by: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <1269830604-26214-4-git-send-email-yinghai@kernel.org>
When CONFIG_NO_BOOTMEM=y, it could use memory more effiently, or
in a more compact fashion.
Example:
Allocated new RAMDISK: 00ec2000 - 0248ce57
Move RAMDISK from 000000002ea04000 - 000000002ffcee56 to 00ec2000 - 0248ce56
The new RAMDISK's end is not page aligned.
Last page could be shared with other users.
When free_init_pages are called for initrd or .init, the page
could be freed and we could corrupt other data.
code segment in free_init_pages():
| for (; addr < end; addr += PAGE_SIZE) {
| ClearPageReserved(virt_to_page(addr));
| init_page_count(virt_to_page(addr));
| memset((void *)(addr & ~(PAGE_SIZE-1)),
| POISON_FREE_INITMEM, PAGE_SIZE);
| free_page(addr);
| totalram_pages++;
last half page could be used as one whole free page.
So page align the boundaries.
-v2: make the original initramdisk to be aligned, according to
Johannes, otherwise we have the chance to lose one page.
we still need to keep initrd_end not aligned, otherwise it could
confuse decompressor.
-v3: change to WARN_ON instead, suggested by Johannes.
-v4: use PAGE_ALIGN, suggested by Johannes.
We may fix that macro name later to PAGE_ALIGN_UP, and PAGE_ALIGN_DOWN
Add comments about assuming ramdisk start is aligned
in relocate_initrd(), change to re get ramdisk_image instead of save it
to make diff smaller. Add warning for wrong range, suggested by Johannes.
-v6: remove one WARN()
We need to align beginning in free_init_pages()
do not copy more than ramdisk_size, noticed by Johannes
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <1269830604-26214-3-git-send-email-yinghai@kernel.org>
Signed-off-by: Sage Weil <sage@newdream.net>
New documentation should have an entry in the 00-INDEX. Correct git
urls.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Fix:
WARNING: at arch/x86/mm/init.c:342 free_init_pages+0x4c/0xfa()
free_init_pages: range [0x40daf000, 0x40db5c24] is not aligned
Modules linked in:
Pid: 0, comm: swapper Not tainted
2.6.34-rc2-tip-03946-g4f16b23-dirty #50 Call Trace:
[<40232e9f>] warn_slowpath_common+0x65/0x7c
[<4021c9f0>] ? free_init_pages+0x4c/0xfa
[<40881434>] ? _etext+0x0/0x24
[<40232eea>] warn_slowpath_fmt+0x24/0x27
[<4021c9f0>] free_init_pages+0x4c/0xfa
[<40d3f4bd>] alternative_instructions+0xf6/0x100
[<40d3fe4f>] check_bugs+0xbd/0xbf
[<40d398a7>] start_kernel+0x2d5/0x2e4
[<40d390ce>] i386_start_kernel+0xce/0xd5
---[ end trace 4eaa2a86a8e2da22 ]---
Comments in vmlinux.lds.S already said:
| * smp_locks might be freed after init
| * start/end must be page aligned
LKML-Reference: <1269830604-26214-2-git-send-email-yinghai@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6:
Revert "ide: skip probe if there are no devices on the port (v2)"
Revert "via82cxxx: workaround h/w bugs"
Commit b26b2d494b659f9 ("resource/PCI: align functions now return start
of resource") added lines with missing semicolons.
Add the missing semicolons to the FRV and CRIS arch code.
Cc: linux@dominikbrodowski.net
CONFIG_SLOW_WORK_PROC was changed to CONFIG_SLOW_WORK_DEBUG, but not in all
instances. Change the remaining instances. This makes the debugfs file
display the time mark and the owner's description again.
Otherwise we can get an oops if the user has no get_ref/put_ref
requirement.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda: Use LPIB for ga-ma770-ud3 board
ALSA: ac97: Add Toshiba P500 to ac97 jack sense blacklist
ALSA: pcm_lib - fix xrun functionality
ALSA: ac97: Add IBM ThinkPad R40e to Headphone/Line Jack Sense blacklist
ALSA: hda - Don't set invalid connection index in Realtek initialiaiton
FC disable is bit 3 of the txmac ctl register, but commit 6720949d5562
("Staging: et131x: Kil the txmac type") accidentally changed the code to
set bit 2 instead.
Signed-off-by: Nick Bowler <nbowler@draconx.ca>
BugLink: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=575669
The OR states that position_fix=1 is necessary to work around glitching
during volume adjustments using PulseAudio.
Reported-by: Carlos Laviola <claviola@debian.org>
Tested-by: Carlos Laviola <claviola@debian.org>
Cc: <stable@kernel.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
BugLink: https://launchpad.net/bugs/481058
The OR has verified that both 'Headphone Jack Sense' and 'Line Jack Sense'
need to be muted for sound to be audible, so just add the machine's SSID
to the ac97 jack sense blacklist.
Reported-by: Richard Gagne
Tested-by: Richard Gagne
There was a use after free in __unregister_request that would trigger
whenever the request map held the last reference. This appears to have
triggered an oops during 'umount -f' when requests are being torn down.
This is ipv6 variant of the commit 5e016cbf6.. ("ipv4: Don't drop
redirected route cache entry unless PTMU actually expired")
by Guenter Roeck <guenter.roeck@ericsson.com>.
Remove cache route entry in ipv6_negative_advice() only if
the timer is expired.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This reverts commit a20b2a44eca52818ef52a94959480b7e6ea2f528.
As requested by David Fries. This makes CDROMs which are slave drives
on a ribbon without a master disappear and causes other similar kinds
of badness.
As reported by Stephen Rothwell.
drivers/net/tulip/uli526x.c: In function 'uli526x_rx_packet':
drivers/net/tulip/uli526x.c:861: warning: assignment makes pointer from integer without a cast
do_logfs_journal_wl_pass() must call freeseg(), thereby clear
PagePrivate on all pages of the current journal segment.
A comment in the old code read:
/* The math in this function can surely use some love */
And indeed it did. In the case that area->a_used_bytes is exactly
4096 bytes below segment size it fell apart. pad_wbuf is now split
into two helpers that are significantly less complicated.
The comment was correct, so make the code match the comment. As the
new comment indicates, we might be able to do a little less work. But
for the current -rc series let's keep it simple and just fix the bug.
When using VT6410/6415/6330 chips on some VIA's platforms, the HDD
connection to VT6410/6415/6330 cannot be detected.
It is because the driver detects wrong via_isa_bridge ID, and then
causes this issue to happen.
Signed-off-by: Joseph Chan <josephchan@via.com.tw>
Use set_cpus_allowed_ptr rather than set_cpus_allowed.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression E1,E2;
- set_cpus_allowed(E1, cpumask_of_cpu(E2))
+ set_cpus_allowed_ptr(E1, cpumask_of(E2))
expression E;
identifier I;
- set_cpus_allowed(E, I)
+ set_cpus_allowed_ptr(E, &I)
// </smpl>
This is quite similar to b39fe41f481d20c201012e4483e76c203802dda7
though said registers are not even documented as 64-bit registers
- as opposed to the initial TxDescStartAddress ones - but as single
bytes which must be combined into 32 bits at the MMIO read/write
level before being merged into a 64 bit logical entity.
Credits go to Ben Hutchings <ben@decadent.org.uk> for the MAR
registers (aka "multicast is broken for ages on ARM) and to
Timo Teräs <timo.teras@iki.fi> for the MAC registers.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
pcnet_cs:
*add new id (Allied Telesis LM33-PCM-T Lan&Modem multifunction card)
*use PROD_ID for LA-PCM.(because LA-PCM and LM33-PCM-T use the same MANF_ID).
Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp>
